--- ray/src/hd/rhd_glx1.c 2012/09/06 00:07:43 3.8 +++ ray/src/hd/rhd_glx1.c 2018/10/05 19:19:16 3.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rhd_glx1.c,v 3.8 2012/09/06 00:07:43 greg Exp $"; +static const char RCSid[] = "$Id: rhd_glx1.c,v 3.10 2018/10/05 19:19:16 greg Exp $"; #endif /* * OpenGL GLX driver for holodeck display. @@ -104,7 +104,7 @@ static void fixwindow(XExposeEvent *eexp); static void resizewindow(XConfigureEvent *ersz); -extern void +void dev_open( char *id ) @@ -204,7 +204,7 @@ dev_open( } -extern void +void dev_close(void) /* close our display and free resources */ { glXMakeCurrent(ourdisplay, None, NULL); @@ -222,7 +222,7 @@ dev_close(void) /* close our display and free resour } -extern void +void dev_clear(void) /* clear our quadtree */ { qtCompost(100); @@ -231,9 +231,9 @@ dev_clear(void) /* clear our quadtree */ } -extern int +int dev_view( /* assign new driver view */ - register VIEW *nv + VIEW *nv ) { if (nv->type == VT_PAR || /* check view legality */ @@ -284,7 +284,7 @@ dev_view( /* assign new driver view */ } -extern void +void dev_section( /* add octree for geometry rendering */ char *gfn, char *pfn @@ -294,7 +294,7 @@ dev_section( /* add octree for geometry rendering */ } -extern void +void dev_auxcom( /* process an auxiliary command */ char *cmd, char *args @@ -305,7 +305,7 @@ dev_auxcom( /* process an auxiliary command */ } -extern VIEW * +VIEW * dev_auxview( /* return nth auxiliary view */ int n, int hvres[2] @@ -318,7 +318,7 @@ dev_auxview( /* return nth auxiliary view */ } -extern int +int dev_input(void) /* get X11 input */ { inpresflags = 0; @@ -332,7 +332,7 @@ dev_input(void) /* get X11 input */ } -extern int +int dev_flush(void) /* flush output */ { qtUpdate(); @@ -342,14 +342,14 @@ dev_flush(void) /* flush output */ } -extern void +void dev_cone( /* render a cone in view coordinates */ uby8 rgb[3], FVECT ip, double rad ) { - register int ci, j; + int ci, j; double apexh, basez; /* is window mapped? */ if (!mapped) @@ -387,7 +387,7 @@ static int mytmflags(void) /* figure out tone mapping flags */ { extern char *progname; - register char *cp, *tail; + char *cp, *tail; /* find basic name */ for (cp = tail = progname; *cp; cp++) if (*cp == '/') @@ -406,7 +406,7 @@ mytmflags(void) /* figure out tone mapping flags */ static void initcones(void) /* initialize cone vertices */ { - register int i, j; + int i, j; double minrad, d; if (cone[0].nverts) @@ -433,7 +433,7 @@ initcones(void) /* initialize cone vertices */ static void freecones(void) /* free cone vertices */ { - register int i; + int i; for (i = MAXCONE; i--; ) if (cone[i].nverts) { @@ -465,7 +465,14 @@ getevent(void) /* get next event */ getkey(levptr(XKeyPressedEvent)); break; case ButtonPress: - getmove(levptr(XButtonPressedEvent)); + switch (levptr(XButtonPressedEvent)->button) { + case Button4: /* wheel up */ + case Button5: /* wheel down */ + break; + default: + getmove(levptr(XButtonPressedEvent)); + break; + } break; } } @@ -473,7 +480,7 @@ getevent(void) /* get next event */ static void draw3dline( /* draw 3d line in world coordinates */ - register FVECT wp[2] + FVECT wp[2] ) { glVertex3d(wp[0][0], wp[0][1], wp[0][2]); @@ -538,7 +545,7 @@ moveview( /* move our view */ VIEW nv; FVECT odir, v1; double d; - register int li; + int li; /* start with old view */ nv = odev.v; /* change view direction */ @@ -623,7 +630,7 @@ getmove( /* get view change */ static void getkey( /* get input key */ - register XKeyPressedEvent *ekey + XKeyPressedEvent *ekey ) { int n; @@ -695,7 +702,7 @@ getkey( /* get input key */ static void fixwindow( /* repair damage to window */ - register XExposeEvent *eexp + XExposeEvent *eexp ) { int xmin, xmax, ymin, ymax; @@ -721,7 +728,7 @@ fixwindow( /* repair damage to window */ static void resizewindow( /* resize window */ - register XConfigureEvent *ersz + XConfigureEvent *ersz ) { glViewport(0, 0, ersz->width, ersz->height);
