1 |
greg |
3.1 |
#ifndef lint |
2 |
greg |
3.11 |
static const char RCSid[] = "$Id: rhd_glx1.c,v 3.10 2018/10/05 19:19:16 greg Exp $"; |
3 |
greg |
3.1 |
#endif |
4 |
5 |
* OpenGL GLX driver for holodeck display. |
6 |
* Based on x11 driver. |
7 |
8 |
9 |
#include "standard.h" |
10 |
11 |
#include <GL/glx.h> |
12 |
schorsch |
3.3 |
#include <GL/glu.h> |
13 |
greg |
3.1 |
14 |
schorsch |
3.4 |
#include "platform.h" |
15 |
greg |
3.1 |
#include "rhd_qtree.h" |
16 |
schorsch |
3.3 |
#include "rhdriver.h" |
17 |
#include "rhdisp.h" |
18 |
greg |
3.1 |
#include "x11icon.h" |
19 |
20 |
#ifndef RAYQLEN |
21 |
#define RAYQLEN 50000 /* max. rays to queue before flush */ |
22 |
#endif |
23 |
24 |
#ifndef MAXCONE |
25 |
#define MAXCONE 16 /* number of different cone sizes */ |
26 |
#endif |
27 |
#ifndef MAXVERT |
28 |
#define MAXVERT 64 /* maximum number of cone vertices */ |
29 |
#endif |
30 |
#ifndef MINVERT |
31 |
#define MINVERT 4 /* minimum number of cone vertices */ |
32 |
#endif |
33 |
#ifndef DEPTHFACT |
34 |
#define DEPTHFACT 16. /* multiplier for depth tests */ |
35 |
#endif |
36 |
37 |
#define GAMMA 1.4 /* default gamma correction */ |
38 |
39 |
#define MOVPCT 7 /* percent distance to move /frame */ |
40 |
#define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1) |
41 |
#define MOVDEG (-5) /* degrees to orbit CW/down /frame */ |
42 |
#define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0) |
43 |
44 |
#define MINWIDTH 480 /* minimum graphics window width */ |
45 |
#define MINHEIGHT 400 /* minimum graphics window height */ |
46 |
47 |
#define VIEWDIST 356 /* assumed viewing distance (mm) */ |
48 |
49 |
#define BORWIDTH 5 /* border width */ |
50 |
51 |
#define ourscreen DefaultScreen(ourdisplay) |
52 |
#define ourroot RootWindow(ourdisplay,ourscreen) |
53 |
#define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\ |
54 |
ButtonPressMask|ButtonReleaseMask) |
55 |
56 |
#define levptr(etype) ((etype *)¤tevent) |
57 |
58 |
struct driver odev; /* global device driver structure */ |
59 |
60 |
greg |
3.5 |
TMstruct *tmGlobal; /* global tone-mapping structure */ |
61 |
62 |
greg |
3.1 |
char odev_args[64]; /* command arguments */ |
63 |
64 |
static XEvent currentevent; /* current event */ |
65 |
66 |
static int mapped = 0; /* window is mapped? */ |
67 |
static unsigned long ourblack=0, ourwhite=~0; |
68 |
69 |
static Display *ourdisplay = NULL; /* our display */ |
70 |
static XVisualInfo *ourvinf; /* our visual information */ |
71 |
static Window gwind = 0; /* our graphics window */ |
72 |
static GLXContext gctx; /* our GLX context */ |
73 |
74 |
static double pwidth, pheight; /* pixel dimensions (mm) */ |
75 |
76 |
static double curzmax = 1e4; /* current depth upper limit */ |
77 |
static double nxtzmax = 0.; /* maximum (finite) depth so far */ |
78 |
79 |
static struct { |
80 |
double rad; /* cone radius */ |
81 |
int nverts; /* number of vertices */ |
82 |
FVECT *va; /* allocated vertex array */ |
83 |
} cone[MAXCONE]; /* precomputed cones for drawing */ |
84 |
85 |
static int inpresflags; /* input result flags */ |
86 |
87 |
static int headlocked = 0; /* lock vertical motion */ |
88 |
89 |
90 |
schorsch |
3.3 |
static int mytmflags(void); |
91 |
static void initcones(void); |
92 |
static void freecones(void); |
93 |
static void getevent(void); |
94 |
static void draw3dline(FVECT wp[2]); |
95 |
static void draw_grids(void); |
96 |
static int moveview(int dx, int dy, int mov, int orb); |
97 |
static void getmove(XButtonPressedEvent *ebut); |
98 |
static void getkey(XKeyPressedEvent *ekey); |
99 |
static void fixwindow(XExposeEvent *eexp); |
100 |
static void resizewindow(XConfigureEvent *ersz); |
101 |
102 |
103 |
greg |
3.10 |
void |
104 |
schorsch |
3.3 |
dev_open( |
105 |
char *id |
106 |
107 |
greg |
3.1 |
108 |
extern char *getenv(); |
109 |
static RGBPRIMS myprims = STDPRIMS; |
110 |
static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,8, |
111 |
GLX_GREEN_SIZE,8, GLX_BLUE_SIZE,8, |
112 |
GLX_DEPTH_SIZE,15, None}; |
113 |
char *ev; |
114 |
double gamval = GAMMA; |
115 |
RGBPRIMP dpri = stdprims; |
116 |
XSetWindowAttributes ourwinattr; |
117 |
XWMHints ourxwmhints; |
118 |
XSizeHints oursizhints; |
119 |
/* set quadtree globals */ |
120 |
qtMinNodesiz = 3; |
121 |
qtDepthEps = 0.07; |
122 |
/* open display server */ |
123 |
ourdisplay = XOpenDisplay(NULL); |
124 |
if (ourdisplay == NULL) |
125 |
error(USER, "cannot open X-windows; DISPLAY variable set?\n"); |
126 |
/* find a usable visual */ |
127 |
ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest); |
128 |
if (ourvinf == NULL) |
129 |
error(USER, "no suitable visuals available"); |
130 |
/* get a context */ |
131 |
gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE); |
132 |
/* set gamma and tone mapping */ |
133 |
if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL |
134 |
|| (ev = getenv("DISPLAY_GAMMA")) != NULL) |
135 |
gamval = atof(ev); |
136 |
if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL && |
137 |
sscanf(ev, "%f %f %f %f %f %f %f %f", |
138 |
&myprims[RED][CIEX],&myprims[RED][CIEY], |
139 |
&myprims[GRN][CIEX],&myprims[GRN][CIEY], |
140 |
&myprims[BLU][CIEX],&myprims[BLU][CIEY], |
141 |
&myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6) |
142 |
dpri = myprims; |
143 |
greg |
3.5 |
tmGlobal = tmInit(mytmflags(), dpri, gamval); |
144 |
if (tmGlobal == NULL) |
145 |
greg |
3.1 |
error(SYSTEM, "not enough memory in dev_open"); |
146 |
/* open window */ |
147 |
ourwinattr.background_pixel = ourblack; |
148 |
ourwinattr.border_pixel = ourblack; |
149 |
ourwinattr.event_mask = ourmask; |
150 |
/* this is stupid */ |
151 |
ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot, |
152 |
ourvinf->visual, AllocNone); |
153 |
gwind = XCreateWindow(ourdisplay, ourroot, 0, 0, |
154 |
DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH, |
155 |
DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH, |
156 |
BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual, |
157 |
CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr); |
158 |
if (gwind == 0) |
159 |
error(SYSTEM, "cannot create window\n"); |
160 |
XStoreName(ourdisplay, gwind, id); |
161 |
/* set window manager hints */ |
162 |
ourxwmhints.flags = InputHint|IconPixmapHint; |
163 |
ourxwmhints.input = True; |
164 |
ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay, |
165 |
gwind, x11icon_bits, x11icon_width, x11icon_height); |
166 |
XSetWMHints(ourdisplay, gwind, &ourxwmhints); |
167 |
oursizhints.min_width = MINWIDTH; |
168 |
oursizhints.min_height = MINHEIGHT; |
169 |
oursizhints.flags = PMinSize; |
170 |
XSetNormalHints(ourdisplay, gwind, &oursizhints); |
171 |
/* set GLX context */ |
172 |
glXMakeCurrent(ourdisplay, gwind, gctx); |
173 |
glEnable(GL_DEPTH_TEST); |
174 |
glDepthFunc(GL_LEQUAL); |
175 |
glShadeModel(GL_FLAT); |
176 |
glDisable(GL_DITHER); |
177 |
glDisable(GL_CULL_FACE); |
178 |
glMatrixMode(GL_PROJECTION); |
179 |
glOrtho(0., 1., 0., 1., -.01, 1.01); |
180 |
glTranslated(0., 0., -1.01); |
181 |
/* figure out sensible view */ |
182 |
pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) / |
183 |
DisplayWidth(ourdisplay, ourscreen); |
184 |
pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) / |
185 |
DisplayHeight(ourdisplay, ourscreen); |
186 |
schorsch |
3.2 |
odev.v = stdview; |
187 |
greg |
3.1 |
odev.v.type = VT_PER; |
188 |
/* map the window */ |
189 |
XMapWindow(ourdisplay, gwind); |
190 |
dev_input(); /* sets size and view angles */ |
191 |
/* allocate our leaf pile */ |
192 |
if (!qtAllocLeaves(DisplayWidth(ourdisplay,ourscreen) * |
193 |
DisplayHeight(ourdisplay,ourscreen) * 3 / |
194 |
(qtMinNodesiz*qtMinNodesiz*2))) |
195 |
error(SYSTEM, "insufficient memory for value storage"); |
196 |
odev.name = id; |
197 |
odev.ifd = ConnectionNumber(ourdisplay); |
198 |
/* initialize cone array */ |
199 |
initcones(); |
200 |
201 |
202 |
203 |
greg |
3.10 |
void |
204 |
schorsch |
3.3 |
dev_close(void) /* close our display and free resources */ |
205 |
greg |
3.1 |
206 |
glXMakeCurrent(ourdisplay, None, NULL); |
207 |
glXDestroyContext(ourdisplay, gctx); |
208 |
XDestroyWindow(ourdisplay, gwind); |
209 |
gwind = 0; |
210 |
XCloseDisplay(ourdisplay); |
211 |
ourdisplay = NULL; |
212 |
qtFreeLeaves(); |
213 |
greg |
3.5 |
tmDone(tmGlobal); |
214 |
greg |
3.1 |
freecones(); |
215 |
odev.v.type = 0; |
216 |
odev.hres = odev.vres = 0; |
217 |
odev.ifd = -1; |
218 |
219 |
220 |
221 |
greg |
3.10 |
void |
222 |
schorsch |
3.3 |
dev_clear(void) /* clear our quadtree */ |
223 |
greg |
3.1 |
224 |
qtCompost(100); |
225 |
glClear(GL_DEPTH_BUFFER_BIT); |
226 |
rayqleft = 0; /* hold off update */ |
227 |
228 |
229 |
230 |
greg |
3.10 |
int |
231 |
schorsch |
3.3 |
dev_view( /* assign new driver view */ |
232 |
greg |
3.10 |
VIEW *nv |
233 |
schorsch |
3.3 |
234 |
greg |
3.1 |
235 |
if (nv->type == VT_PAR || /* check view legality */ |
236 |
nv->horiz > 160. || nv->vert > 160.) { |
237 |
error(COMMAND, "illegal view type/angle"); |
238 |
nv->type = odev.v.type; |
239 |
nv->horiz = odev.v.horiz; |
240 |
nv->vert = odev.v.vert; |
241 |
return(0); |
242 |
243 |
if (nv->vfore > FTINY) { |
244 |
error(COMMAND, "cannot handle fore clipping"); |
245 |
nv->vfore = 0.; |
246 |
return(0); |
247 |
248 |
if (nv != &odev.v) { |
249 |
greg |
3.11 |
if (!FABSEQ(nv->horiz,odev.v.horiz) || /* resize window? */ |
250 |
!FABSEQ(nv->vert,odev.v.vert)) { |
251 |
greg |
3.1 |
int dw = DisplayWidth(ourdisplay,ourscreen); |
252 |
int dh = DisplayHeight(ourdisplay,ourscreen); |
253 |
254 |
dw -= 25; /* for window frame */ |
255 |
dh -= 50; |
256 |
odev.hres = 2.*VIEWDIST/pwidth * |
257 |
tan(PI/180./2.*nv->horiz); |
258 |
odev.vres = 2.*VIEWDIST/pheight * |
259 |
tan(PI/180./2.*nv->vert); |
260 |
if (odev.hres > dw) { |
261 |
odev.vres = dw * odev.vres / odev.hres; |
262 |
odev.hres = dw; |
263 |
264 |
if (odev.vres > dh) { |
265 |
odev.hres = dh * odev.hres / odev.vres; |
266 |
odev.vres = dh; |
267 |
268 |
XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres); |
269 |
dev_input(); /* get resize event */ |
270 |
271 |
schorsch |
3.2 |
odev.v = *nv; |
272 |
greg |
3.1 |
273 |
if (nxtzmax > FTINY) { |
274 |
curzmax = nxtzmax; |
275 |
nxtzmax = 0.; |
276 |
277 |
278 |
qtReplant(); |
279 |
return(1); |
280 |
281 |
282 |
283 |
greg |
3.10 |
void |
284 |
schorsch |
3.3 |
dev_section( /* add octree for geometry rendering */ |
285 |
schorsch |
3.6 |
char *gfn, |
286 |
char *pfn |
287 |
schorsch |
3.3 |
288 |
greg |
3.1 |
289 |
/* unimplemented */ |
290 |
291 |
292 |
293 |
greg |
3.10 |
void |
294 |
schorsch |
3.3 |
dev_auxcom( /* process an auxiliary command */ |
295 |
char *cmd, |
296 |
char *args |
297 |
298 |
greg |
3.1 |
299 |
sprintf(errmsg, "%s: unknown command", cmd); |
300 |
error(COMMAND, errmsg); |
301 |
302 |
303 |
304 |
greg |
3.10 |
VIEW * |
305 |
schorsch |
3.3 |
dev_auxview( /* return nth auxiliary view */ |
306 |
int n, |
307 |
int hvres[2] |
308 |
309 |
greg |
3.1 |
310 |
if (n) |
311 |
return(NULL); |
312 |
hvres[0] = odev.hres; hvres[1] = odev.vres; |
313 |
return(&odev.v); |
314 |
315 |
316 |
317 |
greg |
3.10 |
int |
318 |
schorsch |
3.3 |
dev_input(void) /* get X11 input */ |
319 |
greg |
3.1 |
320 |
inpresflags = 0; |
321 |
322 |
do |
323 |
getevent(); |
324 |
325 |
while (XQLength(ourdisplay) > 0); |
326 |
327 |
return(inpresflags); |
328 |
329 |
330 |
331 |
greg |
3.10 |
int |
332 |
schorsch |
3.3 |
dev_flush(void) /* flush output */ |
333 |
greg |
3.1 |
334 |
qtUpdate(); |
335 |
glFlush(); |
336 |
rayqleft = RAYQLEN; |
337 |
return(XPending(ourdisplay)); |
338 |
339 |
340 |
341 |
greg |
3.10 |
void |
342 |
schorsch |
3.3 |
dev_cone( /* render a cone in view coordinates */ |
343 |
greg |
3.7 |
uby8 rgb[3], |
344 |
schorsch |
3.3 |
FVECT ip, |
345 |
double rad |
346 |
347 |
greg |
3.1 |
348 |
greg |
3.10 |
int ci, j; |
349 |
greg |
3.1 |
double apexh, basez; |
350 |
/* is window mapped? */ |
351 |
if (!mapped) |
352 |
return; |
353 |
/* compute apex height (0. to 1.) */ |
354 |
if (ip[2] > 1e6) |
355 |
apexh = 1. - 1./DEPTHFACT; |
356 |
else { |
357 |
if (ip[2] > nxtzmax) |
358 |
nxtzmax = ip[2]; |
359 |
if (ip[2] >= curzmax) |
360 |
361 |
else |
362 |
apexh = 1. - ip[2]/(curzmax*DEPTHFACT); |
363 |
364 |
rad *= 1.25; /* find conservative cone match */ |
365 |
for (ci = 0; ci < MAXCONE-1; ci++) |
366 |
if (cone[ci].rad >= rad) |
367 |
break; |
368 |
/* draw it */ |
369 |
glColor3ub(rgb[0], rgb[1], rgb[2]); |
370 |
glBegin(GL_TRIANGLE_FAN); |
371 |
glVertex3d(ip[0], ip[1], apexh); /* start with apex */ |
372 |
basez = apexh*cone[ci].va[0][2]; /* base z's all the same */ |
373 |
for (j = 0; j < cone[ci].nverts; j++) /* draw each face */ |
374 |
glVertex3d(ip[0]+cone[ci].va[j][0], ip[1]+cone[ci].va[j][1], |
375 |
basez); |
376 |
/* connect last to first */ |
377 |
glVertex3d(ip[0]+cone[ci].va[0][0], ip[1]+cone[ci].va[0][1], basez); |
378 |
glEnd(); /* all done */ |
379 |
380 |
381 |
382 |
static int |
383 |
schorsch |
3.3 |
mytmflags(void) /* figure out tone mapping flags */ |
384 |
greg |
3.1 |
385 |
extern char *progname; |
386 |
greg |
3.10 |
char *cp, *tail; |
387 |
greg |
3.1 |
/* find basic name */ |
388 |
for (cp = tail = progname; *cp; cp++) |
389 |
if (*cp == '/') |
390 |
tail = cp+1; |
391 |
for (cp = tail; *cp && *cp != '.'; cp++) |
392 |
393 |
if (cp-tail == 4 && !strncmp(tail, "glx1", 4)) |
394 |
return(TM_F_CAMERA|TM_F_NOSTDERR); |
395 |
if (cp-tail == 5 && !strncmp(tail, "glx1h", 5)) |
396 |
return(TM_F_HUMAN|TM_F_NOSTDERR); |
397 |
error(USER, "illegal driver name"); |
398 |
schorsch |
3.3 |
return -1; /* pro forma return */ |
399 |
greg |
3.1 |
400 |
401 |
402 |
schorsch |
3.3 |
static void |
403 |
initcones(void) /* initialize cone vertices */ |
404 |
greg |
3.1 |
405 |
greg |
3.10 |
int i, j; |
406 |
greg |
3.1 |
double minrad, d; |
407 |
408 |
if (cone[0].nverts) |
409 |
freecones(); |
410 |
minrad = 2.*qtMinNodesiz/(double)(DisplayWidth(ourdisplay,ourscreen) + |
411 |
DisplayHeight(ourdisplay,ourscreen)); |
412 |
for (i = 0; i < MAXCONE; i++) { |
413 |
d = (double)i/(MAXCONE-1); d *= d; /* x^2 distribution */ |
414 |
cone[i].rad = minrad + (1.-minrad)*d; |
415 |
cone[i].nverts = MINVERT + 0.5 + (MAXVERT-MINVERT)*d; |
416 |
cone[i].va = (FVECT *)malloc(cone[i].nverts*sizeof(FVECT)); |
417 |
if (cone[i].va == NULL) |
418 |
error(SYSTEM, "out of memory in initcones"); |
419 |
for (j = cone[i].nverts; j--; ) { |
420 |
d = 2.*PI * (j+.5) / (cone[i].nverts); |
421 |
cone[i].va[j][0] = cos(d) * cone[i].rad; |
422 |
cone[i].va[j][1] = sin(d) * cone[i].rad; |
423 |
cone[i].va[j][2] = 1. - cone[i].rad; |
424 |
425 |
426 |
427 |
428 |
429 |
schorsch |
3.3 |
static void |
430 |
freecones(void) /* free cone vertices */ |
431 |
greg |
3.1 |
432 |
greg |
3.10 |
int i; |
433 |
greg |
3.1 |
434 |
for (i = MAXCONE; i--; ) |
435 |
if (cone[i].nverts) { |
436 |
free((void *)cone[i].va); |
437 |
cone[i].va = NULL; |
438 |
cone[i].nverts = 0; |
439 |
440 |
441 |
442 |
443 |
schorsch |
3.3 |
static void |
444 |
getevent(void) /* get next event */ |
445 |
greg |
3.1 |
446 |
XNextEvent(ourdisplay, levptr(XEvent)); |
447 |
switch (levptr(XEvent)->type) { |
448 |
case ConfigureNotify: |
449 |
resizewindow(levptr(XConfigureEvent)); |
450 |
break; |
451 |
case UnmapNotify: |
452 |
mapped = 0; |
453 |
break; |
454 |
case MapNotify: |
455 |
mapped = 1; |
456 |
break; |
457 |
case Expose: |
458 |
fixwindow(levptr(XExposeEvent)); |
459 |
break; |
460 |
case KeyPress: |
461 |
getkey(levptr(XKeyPressedEvent)); |
462 |
break; |
463 |
case ButtonPress: |
464 |
greg |
3.9 |
switch (levptr(XButtonPressedEvent)->button) { |
465 |
case Button4: /* wheel up */ |
466 |
case Button5: /* wheel down */ |
467 |
break; |
468 |
default: |
469 |
getmove(levptr(XButtonPressedEvent)); |
470 |
break; |
471 |
472 |
greg |
3.1 |
break; |
473 |
474 |
475 |
476 |
477 |
schorsch |
3.3 |
static void |
478 |
draw3dline( /* draw 3d line in world coordinates */ |
479 |
greg |
3.10 |
FVECT wp[2] |
480 |
schorsch |
3.3 |
481 |
greg |
3.1 |
482 |
glVertex3d(wp[0][0], wp[0][1], wp[0][2]); |
483 |
glVertex3d(wp[1][0], wp[1][1], wp[1][2]); |
484 |
485 |
486 |
487 |
schorsch |
3.3 |
static void |
488 |
draw_grids(void) /* draw holodeck section grids */ |
489 |
greg |
3.1 |
490 |
greg |
3.7 |
static uby8 gridrgba[4] = {0x0, 0xff, 0xff, 0x00}; |
491 |
greg |
3.1 |
double xmin, xmax, ymin, ymax, zmin, zmax; |
492 |
schorsch |
3.3 |
double d; |
493 |
greg |
3.1 |
/* can we even do it? */ |
494 |
if (!mapped || odev.v.type != VT_PER) |
495 |
return; |
496 |
/* compute view frustum */ |
497 |
if (normalize(odev.v.vdir) == 0.0) |
498 |
return; |
499 |
zmin = 0.01; |
500 |
zmax = 10000.; |
501 |
if (odev.v.vfore > FTINY) |
502 |
zmin = odev.v.vfore; |
503 |
if (odev.v.vaft > FTINY) |
504 |
zmax = odev.v.vaft; |
505 |
xmax = zmin * tan(PI/180./2. * odev.v.horiz); |
506 |
xmin = -xmax; |
507 |
d = odev.v.hoff * (xmax - xmin); |
508 |
xmin += d; xmax += d; |
509 |
ymax = zmin * tan(PI/180./2. * odev.v.vert); |
510 |
ymin = -ymax; |
511 |
d = odev.v.voff * (ymax - ymin); |
512 |
ymin += d; ymax += d; |
513 |
/* set view matrix */ |
514 |
515 |
glPushMatrix(); |
516 |
glLoadIdentity(); |
517 |
glFrustum(xmin, xmax, ymin, ymax, zmin, zmax); |
518 |
gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2], |
519 |
odev.v.vp[0] + odev.v.vdir[0], |
520 |
odev.v.vp[1] + odev.v.vdir[1], |
521 |
odev.v.vp[2] + odev.v.vdir[2], |
522 |
odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]); |
523 |
glDisable(GL_DEPTH_TEST); /* write no depth values */ |
524 |
glColor4ub(gridrgba[0], gridrgba[1], gridrgba[2], gridrgba[3]); |
525 |
glBegin(GL_LINES); /* draw each grid line */ |
526 |
gridlines(draw3dline); |
527 |
glEnd(); |
528 |
glEnable(GL_DEPTH_TEST); /* restore rendering params */ |
529 |
glPopMatrix(); |
530 |
531 |
532 |
533 |
schorsch |
3.3 |
static int |
534 |
moveview( /* move our view */ |
535 |
int dx, |
536 |
int dy, |
537 |
int mov, |
538 |
int orb |
539 |
540 |
greg |
3.1 |
541 |
VIEW nv; |
542 |
FVECT odir, v1; |
543 |
double d; |
544 |
greg |
3.10 |
int li; |
545 |
greg |
3.1 |
/* start with old view */ |
546 |
schorsch |
3.2 |
nv = odev.v; |
547 |
greg |
3.1 |
/* change view direction */ |
548 |
if (mov | orb) { |
549 |
if ((li = qtFindLeaf(dx, dy)) < 0) |
550 |
return(0); /* not on window */ |
551 |
VSUM(odir, qtL.wp[li], nv.vp, -1.); |
552 |
} else { |
553 |
if (viewray(nv.vp, nv.vdir, &odev.v, |
554 |
(dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY) |
555 |
return(0); /* outside view */ |
556 |
557 |
if (orb && mov) { /* orbit left/right */ |
558 |
spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov); |
559 |
VSUM(nv.vp, qtL.wp[li], odir, -1.); |
560 |
spinvector(nv.vdir, nv.vdir, nv.vup, d); |
561 |
} else if (orb) { /* orbit up/down */ |
562 |
greg |
3.8 |
if (geodesic(odir, odir, nv.vup, |
563 |
d=MOVDEG*PI/180.*orb, GEOD_RAD) == 0.0) |
564 |
greg |
3.1 |
return(0); |
565 |
566 |
greg |
3.8 |
geodesic(nv.vdir, nv.vdir, nv.vup, d, GEOD_RAD); |
567 |
greg |
3.1 |
} else if (mov) { /* move forward/backward */ |
568 |
d = MOVPCT/100. * mov; |
569 |
VSUM(nv.vp, nv.vp, odir, d); |
570 |
571 |
if (!mov ^ !orb && headlocked) { /* restore head height */ |
572 |
VSUM(v1, odev.v.vp, nv.vp, -1.); |
573 |
d = DOT(v1, odev.v.vup); |
574 |
VSUM(nv.vp, nv.vp, odev.v.vup, d); |
575 |
576 |
if (setview(&nv) != NULL) |
577 |
return(0); /* illegal view */ |
578 |
dev_view(&nv); |
579 |
inpresflags |= DFL(DC_SETVIEW); |
580 |
return(1); |
581 |
582 |
583 |
584 |
schorsch |
3.3 |
static void |
585 |
getmove( /* get view change */ |
586 |
XButtonPressedEvent *ebut |
587 |
588 |
greg |
3.1 |
589 |
int movdir = MOVDIR(ebut->button); |
590 |
int movorb = MOVORB(ebut->state); |
591 |
int oldnodesiz = qtMinNodesiz; |
592 |
Window rootw, childw; |
593 |
int rootx, rooty, wx, wy; |
594 |
unsigned int statemask; |
595 |
596 |
qtMinNodesiz = 24; /* accelerate update rate */ |
597 |
XNoOp(ourdisplay); |
598 |
599 |
while (!XCheckMaskEvent(ourdisplay, |
600 |
ButtonReleaseMask, levptr(XEvent))) { |
601 |
602 |
if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw, |
603 |
&rootx, &rooty, &wx, &wy, &statemask)) |
604 |
break; /* on another screen */ |
605 |
606 |
if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) { |
607 |
sleep(1); |
608 |
continue; |
609 |
610 |
glClear(GL_COLOR_BUFFER_BIT); |
611 |
qtUpdate(); |
612 |
draw_grids(); |
613 |
glFlush(); |
614 |
615 |
if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */ |
616 |
movdir = MOVDIR(levptr(XButtonReleasedEvent)->button); |
617 |
wx = levptr(XButtonReleasedEvent)->x; |
618 |
wy = levptr(XButtonReleasedEvent)->y; |
619 |
moveview(wx, odev.vres-1-wy, movdir, movorb); |
620 |
621 |
dev_flush(); |
622 |
623 |
qtMinNodesiz = oldnodesiz; /* restore quadtree resolution */ |
624 |
625 |
626 |
627 |
schorsch |
3.3 |
static void |
628 |
getkey( /* get input key */ |
629 |
greg |
3.10 |
XKeyPressedEvent *ekey |
630 |
schorsch |
3.3 |
631 |
greg |
3.1 |
632 |
int n; |
633 |
char buf[8]; |
634 |
635 |
n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL); |
636 |
if (n != 1) |
637 |
return; |
638 |
switch (buf[0]) { |
639 |
case 'h': /* turn on height motion lock */ |
640 |
headlocked = 1; |
641 |
return; |
642 |
case 'H': /* turn off height motion lock */ |
643 |
headlocked = 0; |
644 |
return; |
645 |
case 'l': /* retrieve last view */ |
646 |
inpresflags |= DFL(DC_LASTVIEW); |
647 |
return; |
648 |
case 'p': /* pause computation */ |
649 |
inpresflags |= DFL(DC_PAUSE); |
650 |
return; |
651 |
case 'v': /* spit out view */ |
652 |
inpresflags |= DFL(DC_GETVIEW); |
653 |
return; |
654 |
case '\n': |
655 |
case '\r': /* resume computation */ |
656 |
inpresflags |= DFL(DC_RESUME); |
657 |
return; |
658 |
case CTRL('R'): /* redraw screen */ |
659 |
660 |
661 |
nxtzmax = 0.; |
662 |
663 |
664 |
qtRedraw(0, 0, odev.hres, odev.vres); |
665 |
return; |
666 |
case CTRL('L'): /* refresh from server */ |
667 |
if (inpresflags & DFL(DC_REDRAW)) |
668 |
return; |
669 |
670 |
671 |
nxtzmax = 0.; |
672 |
673 |
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); |
674 |
draw_grids(); |
675 |
glFlush(); |
676 |
qtCompost(100); /* get rid of old values */ |
677 |
inpresflags |= DFL(DC_REDRAW); /* resend values from server */ |
678 |
679 |
return; |
680 |
case 'K': /* kill rtrace process(es) */ |
681 |
inpresflags |= DFL(DC_KILL); |
682 |
break; |
683 |
case 'R': /* restart rtrace */ |
684 |
inpresflags |= DFL(DC_RESTART); |
685 |
break; |
686 |
case 'C': /* clobber holodeck */ |
687 |
inpresflags |= DFL(DC_CLOBBER); |
688 |
break; |
689 |
case 'q': /* quit the program */ |
690 |
inpresflags |= DFL(DC_QUIT); |
691 |
return; |
692 |
default: |
693 |
XBell(ourdisplay, 0); |
694 |
return; |
695 |
696 |
697 |
698 |
699 |
schorsch |
3.3 |
static void |
700 |
fixwindow( /* repair damage to window */ |
701 |
greg |
3.10 |
XExposeEvent *eexp |
702 |
schorsch |
3.3 |
703 |
greg |
3.1 |
704 |
int xmin, xmax, ymin, ymax; |
705 |
706 |
if (odev.hres == 0 || odev.vres == 0) /* first exposure */ |
707 |
resizewindow((XConfigureEvent *)eexp); |
708 |
xmin = eexp->x; xmax = eexp->x + eexp->width; |
709 |
ymin = odev.vres - eexp->y - eexp->height; ymax = odev.vres - eexp->y; |
710 |
/* clear portion of depth */ |
711 |
glColorMask(GL_FALSE, GL_FALSE, GL_FALSE, GL_FALSE); |
712 |
glDepthFunc(GL_ALWAYS); |
713 |
glBegin(GL_POLYGON); |
714 |
glVertex3d((double)xmin/odev.hres, (double)ymin/odev.vres, 0.); |
715 |
glVertex3d((double)xmax/odev.hres, (double)ymin/odev.vres, 0.); |
716 |
glVertex3d((double)xmax/odev.hres, (double)ymax/odev.vres, 0.); |
717 |
glVertex3d((double)xmin/odev.hres, (double)ymax/odev.vres, 0.); |
718 |
glEnd(); |
719 |
glColorMask(GL_TRUE, GL_TRUE, GL_TRUE, GL_TRUE); |
720 |
721 |
qtRedraw(xmin, ymin, xmax, ymax); |
722 |
723 |
724 |
725 |
schorsch |
3.3 |
static void |
726 |
resizewindow( /* resize window */ |
727 |
greg |
3.10 |
XConfigureEvent *ersz |
728 |
schorsch |
3.3 |
729 |
greg |
3.1 |
730 |
glViewport(0, 0, ersz->width, ersz->height); |
731 |
732 |
if (ersz->width == odev.hres && ersz->height == odev.vres) |
733 |
return; |
734 |
735 |
odev.hres = ersz->width; |
736 |
odev.vres = ersz->height; |
737 |
738 |
odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres); |
739 |
odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres); |
740 |
741 |
742 |
