root/radiance/ray/src/hd/rhd_glx.c
Revision: 3.28
Committed: Thu Jun 10 15:22:21 1999 UTC (24 years, 10 months ago) by gwlarson
Changes since 3.27: +57 -39 lines
Implemented sample quadtree in place of triangle quadtree
Made geometric predicates more robust
Added #define LORES which utilizes a single precision floating point
  sample array, the default is a double sample array
Added topology DEBUG commands (for DEBUG > 1)
Made code optimizations
1 /* Copyright (c) 1999 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * OpenGL GLX driver for holodeck display.
9 * Based on old GLX driver using cones.
10 *
11 * Define symbol STEREO for stereo viewing.
12 * Define symbol DOBJ for display object viewing.
13 */
14
15 #ifdef NOSTEREO
16 #ifdef STEREO
17 #undef STEREO
18 #else
19 #undef NOSTEREO
20 #endif
21 #endif
22
23 #include "standard.h"
24
25 #include <GL/glx.h>
26 #include <GL/glu.h>
27 #ifdef STEREO
28 #include <X11/extensions/SGIStereo.h>
29 #endif
30
31 #include "rhd_sample.h"
32 #ifdef DOBJ
33 #include "rhdobj.h"
34 #endif
35
36 #include "x11icon.h"
37
38 #ifndef RAYQLEN
39 #define RAYQLEN 1024 /* max. rays to queue before flush */
40 #endif
41
42 #ifndef FEQ
43 #define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY)
44 #endif
45
46 #define GAMMA 1.4 /* default gamma correction */
47
48 #define FRAMESTATE(s) (((s)&(ShiftMask|ControlMask))==(ShiftMask|ControlMask))
49
50 #define MOVPCT 7 /* percent distance to move /frame */
51 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
52 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
53 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
54
55 #ifndef TARGETFPS
56 #define TARGETFPS 2.0 /* target frames/sec during motion */
57 #endif
58
59 #define MINWIDTH 480 /* minimum graphics window width */
60 #define MINHEIGHT 400 /* minimum graphics window height */
61
62 #define VIEWDIST 356 /* assumed viewing distance (mm) */
63
64 #define BORWIDTH 5 /* border width */
65
66 #define setstereobuf(bid) (glXWaitGL(), \
67 XSGISetStereoBuffer(ourdisplay, gwind, bid), \
68 glXWaitX())
69
70 #define ourscreen DefaultScreen(ourdisplay)
71 #define ourroot RootWindow(ourdisplay,ourscreen)
72 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
73 ButtonPressMask|ButtonReleaseMask)
74
75 #define levptr(etype) ((etype *)&currentevent)
76
77 struct driver odev; /* global device driver structure */
78
79 char odev_args[64]; /* command arguments */
80
81 #ifdef STEREO
82 static VIEW vwright; /* right eye view */
83 #endif
84
85 static int rayqleft = 0; /* rays left to queue before flush */
86
87 static XEvent currentevent; /* current event */
88
89 static int mapped = 0; /* window is mapped? */
90 static unsigned long ourblack=0, ourwhite=~0;
91
92 static Display *ourdisplay = NULL; /* our display */
93 static XVisualInfo *ourvinf; /* our visual information */
94 static Window gwind = 0; /* our graphics window */
95 static GLXContext gctx; /* our GLX context */
96
97 static double pwidth, pheight; /* pixel dimensions (mm) */
98
99 static double mindpth, maxdpth; /* min. and max. depth */
100
101 double dev_zmin, dev_zmax; /* fore and aft clipping plane dist. */
102
103 static int inpresflags; /* input result flags */
104
105 static int headlocked = 0; /* lock vertical motion */
106
107 static int resizewindow(), getevent(), getkey(), moveview(), wipeclean(),
108 setglpersp(), getframe(), getmove(), fixwindow(), mytmflags();
109
110 #ifdef STEREO
111 static int pushright(), popright();
112 #endif
113 static double getdistance();
114 #define mapdepth(d) ((d)> 0.9995 ? FHUGE: dev_zmin/ \
115 (1.-(d)*(1.-dev_zmin/dev_zmax)))
116
117 extern time_t time();
118
119
120 dev_open(id) /* initialize GLX driver */
121 char *id;
122 {
123 extern char *getenv();
124 static RGBPRIMS myprims = STDPRIMS;
125 static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,8,
126 GLX_GREEN_SIZE,8, GLX_BLUE_SIZE,8,
127 GLX_DEPTH_SIZE,15, None};
128 char *ev;
129 double gamval = GAMMA;
130 RGBPRIMP dpri = stdprims;
131 XSetWindowAttributes ourwinattr;
132 XWMHints ourxwmhints;
133 XSizeHints oursizhints;
134 /* check for unsupported stereo */
135 #ifdef NOSTEREO
136 error(INTERNAL, "stereo display driver unavailable");
137 #endif
138 /* open display server */
139 ourdisplay = XOpenDisplay(NULL);
140 if (ourdisplay == NULL)
141 error(USER, "cannot open X-windows; DISPLAY variable set?\n");
142 #ifdef STEREO
143 switch (XSGIQueryStereoMode(ourdisplay, ourroot)) {
144 case STEREO_TOP:
145 case STEREO_BOTTOM:
146 break;
147 case STEREO_OFF:
148 error(USER,
149 "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first");
150 case X_STEREO_UNSUPPORTED:
151 error(USER, "stereo mode not supported on this screen");
152 default:
153 error(INTERNAL, "unknown stereo mode");
154 }
155 #endif
156 /* find a usable visual */
157 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
158 if (ourvinf == NULL)
159 error(USER, "no suitable visuals available");
160 /* get a context */
161 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
162 /* set gamma and tone mapping */
163 if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
164 || (ev = getenv("DISPLAY_GAMMA")) != NULL)
165 gamval = atof(ev);
166 if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL &&
167 sscanf(ev, "%f %f %f %f %f %f %f %f",
168 &myprims[RED][CIEX],&myprims[RED][CIEY],
169 &myprims[GRN][CIEX],&myprims[GRN][CIEY],
170 &myprims[BLU][CIEX],&myprims[BLU][CIEY],
171 &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6)
172 dpri = myprims;
173 if (tmInit(mytmflags(), dpri, gamval) == NULL)
174 error(SYSTEM, "not enough memory in dev_open");
175 /* open window */
176 ourwinattr.background_pixel = ourblack;
177 ourwinattr.border_pixel = ourblack;
178 ourwinattr.event_mask = ourmask;
179 /* this is stupid */
180 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
181 ourvinf->visual, AllocNone);
182 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
183 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
184 #ifdef STEREO
185 (DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH)/2,
186 #else
187 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
188 #endif
189 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
190 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
191 if (gwind == 0)
192 error(SYSTEM, "cannot create window\n");
193 XStoreName(ourdisplay, gwind, id);
194 /* set window manager hints */
195 ourxwmhints.flags = InputHint|IconPixmapHint;
196 ourxwmhints.input = True;
197 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
198 gwind, x11icon_bits, x11icon_width, x11icon_height);
199 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
200 oursizhints.min_width = MINWIDTH;
201 #ifdef STEREO
202 oursizhints.min_height = MINHEIGHT/2;
203 oursizhints.max_width = DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH;
204 oursizhints.max_height = (DisplayHeight(ourdisplay,ourscreen) -
205 2*BORWIDTH)/2;
206 oursizhints.flags = PMinSize|PMaxSize;
207 #else
208 oursizhints.min_height = MINHEIGHT;
209 oursizhints.flags = PMinSize;
210 #endif
211 XSetNormalHints(ourdisplay, gwind, &oursizhints);
212 /* set GLX context */
213 glXMakeCurrent(ourdisplay, gwind, gctx);
214 glEnable(GL_DEPTH_TEST);
215 glDepthFunc(GL_LEQUAL);
216 glShadeModel(GL_SMOOTH);
217 glDisable(GL_DITHER);
218 glDisable(GL_CULL_FACE);
219 /* figure out sensible view */
220 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
221 DisplayWidth(ourdisplay, ourscreen);
222 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
223 DisplayHeight(ourdisplay, ourscreen);
224 #ifdef STEREO
225 pheight *= 2.;
226 setstereobuf(STEREO_BUFFER_LEFT);
227 #endif
228 checkglerr("setting rendering parameters");
229 copystruct(&odev.v, &stdview);
230 odev.v.type = VT_PER;
231 /* map the window */
232 XMapWindow(ourdisplay, gwind);
233 dev_input(); /* sets size and view angles */
234 /* allocate our samples */
235 if (!smInit(DisplayWidth(ourdisplay,ourscreen) *
236 DisplayHeight(ourdisplay,ourscreen) / 10))
237 error(SYSTEM, "insufficient memory for value storage");
238 mindpth = FHUGE; maxdpth = FTINY;
239 odev.name = id;
240 odev.ifd = ConnectionNumber(ourdisplay);
241 }
242
243
244 dev_close() /* close our display and free resources */
245 {
246 smInit(0);
247 #ifdef DOBJ
248 dobj_cleanup();
249 #endif
250 glXMakeCurrent(ourdisplay, None, NULL);
251 glXDestroyContext(ourdisplay, gctx);
252 XDestroyWindow(ourdisplay, gwind);
253 gwind = 0;
254 XCloseDisplay(ourdisplay);
255 ourdisplay = NULL;
256 tmDone(NULL);
257 odev.v.type = 0;
258 odev.hres = odev.vres = 0;
259 odev.ifd = -1;
260 }
261
262
263 dev_clear() /* clear our representation */
264 {
265 smInit(rsL.max_samp);
266 wipeclean(1);
267 rayqleft = 0; /* hold off update */
268 }
269
270
271 int
272 dev_view(nv) /* assign new driver view */
273 register VIEW *nv;
274 {
275 double d;
276
277 if (nv->type != VT_PER || /* check view legality */
278 nv->horiz > 160. || nv->vert > 160.) {
279 error(COMMAND, "illegal view type/angle");
280 nv->type = odev.v.type;
281 nv->horiz = odev.v.horiz;
282 nv->vert = odev.v.vert;
283 return(0);
284 }
285 if (nv != &odev.v) {
286 /* resize window? */
287 if (!FEQ(nv->horiz,odev.v.horiz) ||
288 !FEQ(nv->vert,odev.v.vert)) {
289 int dw = DisplayWidth(ourdisplay,ourscreen);
290 int dh = DisplayHeight(ourdisplay,ourscreen);
291
292 dw -= 25; /* for window frame */
293 dh -= 50;
294 #ifdef STEREO
295 dh /= 2;
296 #endif
297 odev.hres = 2.*VIEWDIST/pwidth *
298 tan(PI/180./2.*nv->horiz);
299 odev.vres = 2.*VIEWDIST/pheight *
300 tan(PI/180./2.*nv->vert);
301 if (odev.hres > dw) {
302 odev.vres = dw * odev.vres / odev.hres;
303 odev.hres = dw;
304 }
305 if (odev.vres > dh) {
306 odev.hres = dh * odev.hres / odev.vres;
307 odev.vres = dh;
308 }
309 XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres);
310 dev_input(); /* get resize event */
311 }
312 copystruct(&odev.v, nv); /* setview() already called */
313 }
314 #ifdef STEREO
315 copystruct(&vwright, nv);
316 d = eyesepdist / sqrt(nv->hn2);
317 VSUM(vwright.vp, nv->vp, nv->hvec, d);
318 /* setview(&vwright); -- Unnecessary */
319 #endif
320 wipeclean(0);
321 return(1);
322 }
323
324
325 dev_section(gfn, pfn) /* add octree for geometry rendering */
326 char *gfn, *pfn;
327 {
328 /* unimplemented */
329 }
330
331
332 dev_auxcom(cmd, args) /* process an auxiliary command */
333 char *cmd, *args;
334 {
335 #ifdef DOBJ
336 if (dobj_command(cmd, args) >= 0)
337 return;
338 #endif
339 sprintf(errmsg, "%s: unknown command", cmd);
340 error(COMMAND, errmsg);
341 }
342
343
344 VIEW *
345 dev_auxview(n, hvres) /* return nth auxiliary view */
346 int n;
347 int hvres[2];
348 {
349 hvres[0] = odev.hres; hvres[1] = odev.vres;
350 if (n == 0)
351 return(&odev.v);
352 #ifdef STEREO
353 if (n == 1)
354 return(&vwright);
355 #endif
356 return(NULL);
357 }
358
359
360 int
361 dev_input() /* get X11 input */
362 {
363 inpresflags = 0;
364
365 do
366 getevent();
367
368 while (XPending(ourdisplay) > 0);
369
370 odev.inpready = 0;
371
372 return(inpresflags);
373 }
374
375
376 dev_value(c, d, p) /* add a pixel value to our mesh */
377 COLR c;
378 FVECT d, p;
379 {
380 double depth;
381 #ifdef DOBJ
382 if (dobj_lightsamp != NULL) { /* in light source sampling */
383 (*dobj_lightsamp)(c, d, p);
384 return;
385 }
386 #endif
387 if (p != NULL) { /* add depth to our range */
388 depth = (p[0] - odev.v.vp[0])*d[0] +
389 (p[1] - odev.v.vp[1])*d[1] +
390 (p[2] - odev.v.vp[2])*d[2];
391 if (depth > FTINY) {
392 if (depth < mindpth)
393 mindpth = depth;
394 if (depth > maxdpth)
395 maxdpth = depth;
396 }
397 }
398 smNewSamp(c, d, p); /* add to display representation */
399 if (!--rayqleft)
400 dev_flush(); /* flush output */
401 }
402
403
404 int
405 dev_flush() /* flush output */
406 {
407 if (mapped) {
408 #ifdef STEREO
409 pushright(); /* update right eye */
410 smUpdate(&vwright, MAXQUALITY);
411 #ifdef DOBJ
412 dobj_render(); /* usually in foreground */
413 #endif
414 popright(); /* update left eye */
415 #endif
416 smUpdate(&odev.v, MAXQUALITY);
417 checkglerr("rendering mesh");
418 #ifdef DOBJ
419 dobj_render();
420 #endif
421 glFlush(); /* flush OGL */
422 }
423 rayqleft = RAYQLEN;
424 /* flush X11 and return # pending */
425 return(odev.inpready = XPending(ourdisplay));
426 }
427
428
429 checkglerr(where) /* check for GL or GLU error */
430 char *where;
431 {
432 register GLenum errcode;
433
434 while ((errcode = glGetError()) != GL_NO_ERROR) {
435 sprintf(errmsg, "OpenGL error %s: %s",
436 where, gluErrorString(errcode));
437 error(WARNING, errmsg);
438 }
439 }
440
441
442 #ifdef STEREO
443 static
444 pushright() /* push on right view */
445 {
446 double d;
447
448 setstereobuf(STEREO_BUFFER_RIGHT);
449 glMatrixMode(GL_MODELVIEW);
450 glPushMatrix();
451 d = -eyesepdist / sqrt(odev.v.hn2);
452 glTranslated(d*odev.v.hvec[0], d*odev.v.hvec[1], d*odev.v.hvec[2]);
453 checkglerr("setting right view");
454 }
455
456
457 static
458 popright() /* pop off right view */
459 {
460 glMatrixMode(GL_MODELVIEW);
461 glPopMatrix();
462 setstereobuf(STEREO_BUFFER_LEFT);
463 }
464 #endif
465
466
467 static int
468 mytmflags() /* figure out tone mapping flags */
469 {
470 extern char *progname;
471 register char *cp, *tail;
472 /* find basic name */
473 for (cp = tail = progname; *cp; cp++)
474 if (*cp == '/')
475 tail = cp+1;
476 for (cp = tail; *cp && *cp != '.'; cp++)
477 ;
478 if (cp > tail && cp[-1] == 'h')
479 return(TM_F_HUMAN|TM_F_NOSTDERR);
480 else
481 return(TM_F_CAMERA|TM_F_NOSTDERR);
482 }
483
484
485 static
486 getevent() /* get next event */
487 {
488 XNextEvent(ourdisplay, levptr(XEvent));
489 switch (levptr(XEvent)->type) {
490 case ConfigureNotify:
491 resizewindow(levptr(XConfigureEvent));
492 break;
493 case UnmapNotify:
494 mapped = 0;
495 break;
496 case MapNotify:
497 mapped = 1;
498 break;
499 case Expose:
500 fixwindow(levptr(XExposeEvent));
501 break;
502 case KeyPress:
503 getkey(levptr(XKeyPressedEvent));
504 break;
505 case ButtonPress:
506 if (FRAMESTATE(levptr(XButtonPressedEvent)->state))
507 getframe(levptr(XButtonPressedEvent));
508 else
509 getmove(levptr(XButtonPressedEvent));
510 break;
511 }
512 }
513
514
515 static
516 draw3dline(wp) /* draw 3d line in world coordinates */
517 register FVECT wp[2];
518 {
519 glVertex3d(wp[0][0], wp[0][1], wp[0][2]);
520 glVertex3d(wp[1][0], wp[1][1], wp[1][2]);
521 }
522
523
524 static
525 draw_grids(fore) /* draw holodeck section grids */
526 int fore;
527 {
528 if (fore)
529 glColor4ub(0, 255, 255, 0);
530 else
531 glColor4ub(0, 0, 0, 0);
532 glBegin(GL_LINES); /* draw each grid line */
533 gridlines(draw3dline);
534 glEnd();
535 checkglerr("drawing grid lines");
536 }
537
538 static double
539 getdistance(dx, dy, direc) /* distance from fore plane along view ray */
540 int dx, dy;
541 FVECT direc;
542 {
543 GLfloat gldepth;
544 double dist;
545
546 if (dx<0 | dx>=odev.hres | dy<0 | dy>=odev.vres)
547 return(FHUGE);
548 glReadPixels(dx,dy, 1,1, GL_DEPTH_COMPONENT,GL_FLOAT, &gldepth);
549 dist = mapdepth(gldepth);
550 if (dist >= .99*FHUGE)
551 return(FHUGE);
552 return((dist-odev.v.vfore)/DOT(direc,odev.v.vdir));
553 }
554
555
556 static
557 moveview(dx, dy, mov, orb) /* move our view */
558 int dx, dy, mov, orb;
559 {
560 VIEW nv;
561 FVECT odir, v1, wip;
562 double d,d1;
563 register int li;
564 /* start with old view */
565 copystruct(&nv, &odev.v);
566 /* orient our motion */
567 if (viewray(v1, odir, &odev.v,
568 (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY)
569 return(0); /* outside view */
570 if (mov | orb) { /* moving relative to geometry */
571 d = getdistance(dx, dy, odir);/*distance from front plane */
572 #ifdef DOBJ
573 d1 = dobj_trace(NULL, v1, odir); /* check objects */
574 /* check holodeck */
575 if (d1 < d)
576 d = d1;
577 #endif
578 if (d >= .99*FHUGE)
579 d = 0.5*(dev_zmax+dev_zmin); /* just guess */
580 VSUM(wip, v1, odir, d);
581 VSUB(odir, wip, odev.v.vp);
582 #if 0
583 fprintf(stderr, "moveview: hit %s at (%f,%f,%f) (t=%f)\n",
584 li < 0 ? "object" : "mesh",
585 wip[0], wip[1], wip[2],
586 (wip[0]-odev.v.vp[0])*odir[0] +
587 (wip[1]-odev.v.vp[1])*odir[1] +
588 (wip[2]-odev.v.vp[2])*odir[2]);
589 #endif
590 } else /* panning with constant viewpoint */
591 VCOPY(nv.vdir, odir);
592 if (orb && mov) { /* orbit left/right */
593 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
594 VSUM(nv.vp, wip, odir, -1.);
595 spinvector(nv.vdir, nv.vdir, nv.vup, d);
596 } else if (orb) { /* orbit up/down */
597 fcross(v1, odir, nv.vup);
598 if (normalize(v1) == 0.)
599 return(0);
600 spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
601 VSUM(nv.vp, wip, odir, -1.);
602 spinvector(nv.vdir, nv.vdir, v1, d);
603 } else if (mov) { /* move forward/backward */
604 d = MOVPCT/100. * mov;
605 VSUM(nv.vp, nv.vp, odir, d);
606 }
607 if (!mov ^ !orb && headlocked) { /* restore head height */
608 VSUM(v1, odev.v.vp, nv.vp, -1.);
609 d = DOT(v1, nv.vup);
610 VSUM(nv.vp, nv.vp, odev.v.vup, d);
611 }
612 if (setview(&nv) != NULL)
613 return(0); /* illegal view */
614 dev_view(&nv);
615 inpresflags |= DFL(DC_SETVIEW);
616 return(1);
617 }
618
619
620 static
621 getframe(ebut) /* get focus frame */
622 XButtonPressedEvent *ebut;
623 {
624 int startx = ebut->x, starty = ebut->y;
625 int endx, endy;
626
627 XMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent));
628 endx = levptr(XButtonReleasedEvent)->x;
629 endy = levptr(XButtonReleasedEvent)->y;
630 if (endx == startx | endy == starty) {
631 XBell(ourdisplay, 0);
632 return;
633 }
634 if (endx < startx) {register int c = endx; endx = startx; startx = c;}
635 if (endy < starty) {register int c = endy; endy = starty; starty = c;}
636 sprintf(odev_args, "%.3f %.3f %.3f %.3f",
637 (startx+.5)/odev.hres, 1.-(endy+.5)/odev.vres,
638 (endx+.5)/odev.hres, 1.-(starty+.5)/odev.vres);
639 inpresflags |= DFL(DC_FOCUS);
640 }
641
642
643 static
644 getmove(ebut) /* get view change */
645 XButtonPressedEvent *ebut;
646 {
647 int movdir = MOVDIR(ebut->button);
648 int movorb = MOVORB(ebut->state);
649 int qlevel = MAXQUALITY-1;
650 time_t lasttime, thistime;
651 int nframes;
652 Window rootw, childw;
653 int rootx, rooty, wx, wy;
654 unsigned int statemask;
655
656 XNoOp(ourdisplay); /* makes sure we're not idle */
657
658 nframes = 0;
659 while (!XCheckMaskEvent(ourdisplay,
660 ButtonReleaseMask, levptr(XEvent))) {
661 /* get cursor position */
662 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
663 &rootx, &rooty, &wx, &wy, &statemask))
664 break; /* on another screen */
665
666 draw_grids(0); /* clear old grid lines */
667 #ifdef STEREO
668 pushright(); draw_grids(0); popright();
669 #endif
670 /* compute view motion */
671 if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) {
672 sleep(1);
673 lasttime++;
674 continue; /* cursor in bad place */
675 }
676 draw_grids(1); /* redraw grid */
677 #ifdef STEREO
678 pushright();
679 draw_grids(1);
680 smUpdate(&vwright, qlevel);
681 #ifdef DOBJ
682 dobj_render();
683 #endif
684 popright();
685 #endif
686 /* redraw mesh */
687 smUpdate(&odev.v, qlevel);
688 #ifdef DOBJ
689 dobj_render(); /* redraw object */
690 #endif
691 glFlush();
692 /* figure out good quality level */
693 if (!nframes++) { /* ignore first frame */
694 lasttime = time(0);
695 continue;
696 }
697 thistime = time(0);
698 if (thistime - lasttime >= 6 ||
699 nframes > (int)(3*3*TARGETFPS)) {
700 qlevel = thistime<=lasttime ? 3*MAXQUALITY :
701 (int)((double)nframes/(thistime-lasttime)
702 / TARGETFPS * qlevel + 0.5);
703 nframes = 0;
704 if (qlevel >= MAXQUALITY) {
705 if (qlevel >= 3*MAXQUALITY) { /* brakes!! */
706 sleep(1);
707 lasttime++;
708 }
709 qlevel = MAXQUALITY-1;
710 } else if (qlevel < 1)
711 qlevel = 1;
712 }
713 }
714 if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */
715 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
716 wx = levptr(XButtonReleasedEvent)->x;
717 wy = levptr(XButtonReleasedEvent)->y;
718 moveview(wx, odev.vres-1-wy, movdir, movorb);
719 }
720 }
721
722
723 static
724 setglpersp(vp) /* set perspective view in GL */
725 register VIEW *vp;
726 {
727 double d, xmin, xmax, ymin, ymax;
728
729 if (mindpth >= maxdpth) {
730 dev_zmin = 1.;
731 dev_zmax = 100.;
732 } else {
733 dev_zmin = 0.1*mindpth;
734 dev_zmax = 5.0*maxdpth;
735 }
736 if (odev.v.vfore > FTINY)
737 dev_zmin = odev.v.vfore;
738 if (odev.v.vaft > FTINY)
739 dev_zmax = odev.v.vaft;
740 if (dev_zmin < dev_zmax/500.)
741 dev_zmin = dev_zmax/500.;
742 xmax = dev_zmin * tan(PI/180./2. * odev.v.horiz);
743 xmin = -xmax;
744 d = odev.v.hoff * (xmax - xmin);
745 xmin += d; xmax += d;
746 ymax = dev_zmin * tan(PI/180./2. * odev.v.vert);
747 ymin = -ymax;
748 d = odev.v.voff * (ymax - ymin);
749 ymin += d; ymax += d;
750 /* set view matrix */
751 glMatrixMode(GL_PROJECTION);
752 glLoadIdentity();
753 glFrustum(xmin, xmax, ymin, ymax, dev_zmin, dev_zmax);
754 gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2],
755 odev.v.vp[0] + odev.v.vdir[0],
756 odev.v.vp[1] + odev.v.vdir[1],
757 odev.v.vp[2] + odev.v.vdir[2],
758 odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]);
759 checkglerr("setting perspective view");
760 }
761
762
763 static
764 wipeclean(tmflag) /* prepare for redraw */
765 int tmflag;
766 {
767 /* clear depth buffer */
768 #ifdef STEREO
769 setstereobuf(STEREO_BUFFER_RIGHT);
770 glClear(GL_DEPTH_BUFFER_BIT);
771 setstereobuf(STEREO_BUFFER_LEFT);
772 #endif
773 glClear(GL_DEPTH_BUFFER_BIT);
774 smClean(tmflag); /* reset drawing routines */
775 setglpersp(&odev.v); /* reset view & clipping planes */
776 }
777
778
779 static
780 getkey(ekey) /* get input key */
781 register XKeyPressedEvent *ekey;
782 {
783 Window rootw, childw;
784 int rootx, rooty, wx, wy;
785 unsigned int statemask;
786 int n;
787 char buf[8];
788
789 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
790 if (n != 1)
791 return;
792 switch (buf[0]) {
793 case 'h': /* turn on height motion lock */
794 headlocked = 1;
795 return;
796 case 'H': /* turn off height motion lock */
797 headlocked = 0;
798 return;
799 case 'l': /* retrieve last view */
800 inpresflags |= DFL(DC_LASTVIEW);
801 return;
802 case 'p': /* pause computation */
803 inpresflags |= DFL(DC_PAUSE);
804 return;
805 case 'v': /* spit out view */
806 inpresflags |= DFL(DC_GETVIEW);
807 return;
808 case 'f': /* frame view position */
809 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
810 &rootx, &rooty, &wx, &wy, &statemask))
811 return; /* on another screen */
812 sprintf(odev_args, "%.4f %.4f", (wx+.5)/odev.hres,
813 1.-(wy+.5)/odev.vres);
814 inpresflags |= DFL(DC_FOCUS);
815 return;
816 case 'F': /* unfocus */
817 odev_args[0] = '\0';
818 inpresflags |= DFL(DC_FOCUS);
819 return;
820 case '\n':
821 case '\r': /* resume computation */
822 inpresflags |= DFL(DC_RESUME);
823 return;
824 case CTRL('R'): /* redraw screen */
825 wipeclean(1);
826 return;
827 case CTRL('L'): /* refresh from server */
828 if (inpresflags & DFL(DC_REDRAW))
829 return;
830 setglpersp(&odev.v); /* reset clipping planes */
831 glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
832 glDisable(GL_DEPTH_TEST); /* so grids will clear */
833 draw_grids(1);
834 #ifdef STEREO
835 pushright();
836 glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
837 draw_grids(1);
838 popright();
839 #endif
840 glEnable(GL_DEPTH_TEST);
841 glFlush();
842 smInit(rsL.max_samp); /* get rid of old values */
843 inpresflags |= DFL(DC_REDRAW); /* resend values from server */
844 rayqleft = 0; /* hold off update */
845 return;
846 case 'K': /* kill rtrace process(es) */
847 inpresflags |= DFL(DC_KILL);
848 break;
849 case 'R': /* restart rtrace */
850 inpresflags |= DFL(DC_RESTART);
851 break;
852 case 'C': /* clobber holodeck */
853 inpresflags |= DFL(DC_CLOBBER);
854 break;
855 case 'q': /* quit the program */
856 inpresflags |= DFL(DC_QUIT);
857 return;
858 default:
859 XBell(ourdisplay, 0);
860 return;
861 }
862 }
863
864
865 static
866 fixwindow(eexp) /* repair damage to window */
867 register XExposeEvent *eexp;
868 {
869 if (odev.hres == 0 | odev.vres == 0) { /* first exposure */
870 resizewindow((XConfigureEvent *)eexp);
871 return;
872 }
873 if (eexp->count) /* wait for final exposure */
874 return;
875 wipeclean(0); /* clear depth */
876 }
877
878
879 static
880 resizewindow(ersz) /* resize window */
881 register XConfigureEvent *ersz;
882 {
883 glViewport(0, 0, ersz->width, ersz->height);
884
885 if (ersz->width == odev.hres && ersz->height == odev.vres)
886 return;
887
888 odev.hres = ersz->width;
889 odev.vres = ersz->height;
890
891 odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres);
892 odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres);
893
894 inpresflags |= DFL(DC_SETVIEW);
895 }
