--- ray/src/hd/rhd_glx.c 1997/12/24 15:55:43 3.3 +++ ray/src/hd/rhd_glx.c 1998/08/21 11:38:21 3.21 @@ -1,4 +1,4 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ +/* Copyright (c) 1998 Silicon Graphics, Inc. */ #ifndef lint static char SCCSid[] = "$SunId$ SGI"; @@ -6,44 +6,42 @@ static char SCCSid[] = "$SunId$ SGI"; /* * OpenGL GLX driver for holodeck display. - * Based on x11 driver. + * Based on old GLX driver using cones. + * + * Define symbol STEREO for stereo viewing. + * Define symbol DOBJ for display object viewing. */ +#ifdef NOSTEREO +#ifdef STEREO +#undef STEREO +#else +#undef NOSTEREO +#endif +#endif + #include "standard.h" -#include "tonemap.h" -#include "rhdriver.h" +#include "rhd_sample.h" -#include - -#include "x11icon.h" - -#ifndef FEQ -#define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY) +#include +#include +#include +#ifdef STEREO +#include #endif - -#ifndef int4 -#define int4 int +#ifdef DOBJ +#include "rhdobj.h" #endif -#ifndef FREEPCT -#define FREEPCT 10 /* percentage of values to free */ +#include "x11icon.h" + +#ifndef RAYQLEN +#define RAYQLEN 250 /* max. rays to queue before flush */ #endif -#ifndef NCONEV -#define NCONEV 7 /* number of cone base vertices */ +#ifndef FEQ +#define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY) #endif -#ifndef CONEH -#define CONEH 3. /* cone height (fraction of depth) */ -#endif -#ifndef CONEW -#define CONEW 0.05 /* cone width (fraction of screen) */ -#endif -#ifndef DIRPEN -#define DIRPEN 0.001 /* direction penalty factor */ -#endif -#ifndef VALUA -#define VALUA 16 /* target value area (pixels) */ -#endif #define GAMMA 1.4 /* default gamma correction */ @@ -52,6 +50,10 @@ static char SCCSid[] = "$SunId$ SGI"; #define MOVDEG (-5) /* degrees to orbit CW/down /frame */ #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0) +#ifndef TARGETFPS +#define TARGETFPS 4.0 /* target frames/sec during motion */ +#endif + #define MINWIDTH 480 /* minimum graphics window width */ #define MINHEIGHT 400 /* minimum graphics window height */ @@ -59,6 +61,10 @@ static char SCCSid[] = "$SunId$ SGI"; #define BORWIDTH 5 /* border width */ +#define setstereobuf(bid) (glXWaitGL(), \ + XSGISetStereoBuffer(ourdisplay, gwind, bid), \ + glXWaitX()) + #define ourscreen DefaultScreen(ourdisplay) #define ourroot RootWindow(ourdisplay,ourscreen) #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\ @@ -68,6 +74,10 @@ static char SCCSid[] = "$SunId$ SGI"; struct driver odev; /* global device driver structure */ +static VIEW vwright; /* right eye view */ + +static int rayqleft = 0; /* rays left to queue before flush */ + static XEvent currentevent; /* current event */ static int mapped = 0; /* window is mapped? */ @@ -78,66 +88,62 @@ static XVisualInfo *ourvinf; /* our visual informati static Window gwind = 0; /* our graphics window */ static GLXContext gctx; /* our GLX context */ -static double mindepth = FHUGE; /* minimum depth value so far */ -static double maxdepth = 0.; /* maximum depth value so far */ - static double pwidth, pheight; /* pixel dimensions (mm) */ -static FVECT conev[NCONEV]; /* drawing cone */ -static double coneh; /* cone height */ +static double mindpth, maxdpth; /* min. and max. depth */ +double dev_zmin, dev_zmax; /* fore and aft clipping plane dist. */ + static int inpresflags; /* input result flags */ static int headlocked = 0; /* lock vertical motion */ -static int quicken = 0; /* quicker, sloppier update rate? */ +static int resizewindow(), getevent(), getkey(), moveview(), wipeclean(), + setglpersp(), getmove(), fixwindow(), mytmflags(); -static struct { - float (*wp)[3]; /* world intersection point array */ - int4 *wd; /* world direction array */ - TMbright *brt; /* encoded brightness array */ - BYTE (*chr)[3]; /* encoded chrominance array */ - BYTE (*rgb)[3]; /* tone-mapped color array */ - BYTE *alpha; /* alpha values */ - int nl; /* count of values */ - int bl, tl; /* bottom and top (next) value index */ - int tml; /* next value needing tone-mapping */ - int drl; /* next value in need of drawing */ - char *base; /* base of allocated memory */ -} rV; /* our collection of values */ +#ifdef STEREO +static int pushright(), popright(); +#endif -static int *valmap = NULL; /* sorted map of screen values */ -static int vmaplen = 0; /* value map length */ +extern time_t time(); -#define redraw() (rV.drl = rV.bl) -static int resizewindow(), getevent(), getkey(), moveview(), - setGLview(), getmove(), fixwindow(), mytmflags(), - drawvalue(), valcmp(), clralphas(), setalphas(), mergalphas(), - IndexValue(), Compost(), FindValue(), TMapValues(), - AllocValues(), FreeValues(); - -extern int4 encodedir(); -extern double fdir2diff(), dir2diff(); - - -dev_open(id) /* initialize X11 driver */ +dev_open(id) /* initialize GLX driver */ char *id; { extern char *getenv(); + static RGBPRIMS myprims = STDPRIMS; static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,8, GLX_GREEN_SIZE,8, GLX_BLUE_SIZE,8, - GLX_ALPHA_SIZE,8, GLX_DEPTH_SIZE,15, - None}; - char *gv; + GLX_DEPTH_SIZE,15, None}; + char *ev; double gamval = GAMMA; + RGBPRIMP dpri = stdprims; XSetWindowAttributes ourwinattr; XWMHints ourxwmhints; XSizeHints oursizhints; + /* check for unsupported stereo */ +#ifdef NOSTEREO + error(USER, "stereo display driver unavailable"); +#endif /* open display server */ ourdisplay = XOpenDisplay(NULL); if (ourdisplay == NULL) error(USER, "cannot open X-windows; DISPLAY variable set?\n"); +#ifdef STEREO + switch (XSGIQueryStereoMode(ourdisplay, ourroot)) { + case STEREO_TOP: + case STEREO_BOTTOM: + break; + case STEREO_OFF: + error(USER, + "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first"); + case X_STEREO_UNSUPPORTED: + error(USER, "stereo mode not supported on this screen"); + default: + error(INTERNAL, "unknown stereo mode"); + } +#endif /* find a usable visual */ ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest); if (ourvinf == NULL) @@ -145,10 +151,17 @@ char *id; /* get a context */ gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE); /* set gamma and tone mapping */ - if ((gv = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL - || (gv = getenv("DISPLAY_GAMMA")) != NULL) - gamval = atof(gv); - if (tmInit(mytmflags(), stdprims, gamval) == NULL) + if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL + || (ev = getenv("DISPLAY_GAMMA")) != NULL) + gamval = atof(ev); + if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL && + sscanf(ev, "%f %f %f %f %f %f %f %f", + &myprims[RED][CIEX],&myprims[RED][CIEY], + &myprims[GRN][CIEX],&myprims[GRN][CIEY], + &myprims[BLU][CIEX],&myprims[BLU][CIEY], + &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6) + dpri = myprims; + if (tmInit(mytmflags(), dpri, gamval) == NULL) error(SYSTEM, "not enough memory in dev_open"); /* open window */ ourwinattr.background_pixel = ourblack; @@ -159,7 +172,11 @@ char *id; ourvinf->visual, AllocNone); gwind = XCreateWindow(ourdisplay, ourroot, 0, 0, DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH, +#ifdef STEREO + (DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH)/2, +#else DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH, +#endif BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual, CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr); if (gwind == 0) @@ -172,30 +189,43 @@ char *id; gwind, x11icon_bits, x11icon_width, x11icon_height); XSetWMHints(ourdisplay, gwind, &ourxwmhints); oursizhints.min_width = MINWIDTH; +#ifdef STEREO + oursizhints.min_height = MINHEIGHT/2; + oursizhints.max_width = DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH; + oursizhints.max_height = (DisplayHeight(ourdisplay,ourscreen) - + 2*BORWIDTH)/2; + oursizhints.flags = PMinSize|PMaxSize; +#else oursizhints.min_height = MINHEIGHT; oursizhints.flags = PMinSize; +#endif XSetNormalHints(ourdisplay, gwind, &oursizhints); /* set GLX context */ glXMakeCurrent(ourdisplay, gwind, gctx); glEnable(GL_DEPTH_TEST); glDepthFunc(GL_LEQUAL); - glShadeModel(GL_FLAT); + glShadeModel(GL_SMOOTH); glDisable(GL_DITHER); + glDisable(GL_CULL_FACE); /* figure out sensible view */ pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) / DisplayWidth(ourdisplay, ourscreen); pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) / DisplayHeight(ourdisplay, ourscreen); +#ifdef STEREO + pheight *= 2.; + setstereobuf(STEREO_BUFFER_LEFT); +#endif copystruct(&odev.v, &stdview); odev.v.type = VT_PER; /* map the window */ XMapWindow(ourdisplay, gwind); dev_input(); /* sets size and view angles */ - glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); - /* allocate our value list */ - if (!AllocValues(DisplayWidth(ourdisplay,ourscreen) * - DisplayHeight(ourdisplay,ourscreen) / VALUA)) + /* allocate our samples */ + if (!smInit(DisplayWidth(ourdisplay,ourscreen) * + DisplayHeight(ourdisplay,ourscreen) / 10)) error(SYSTEM, "insufficient memory for value storage"); + mindpth = FHUGE; maxdpth = FTINY; odev.name = id; odev.ifd = ConnectionNumber(ourdisplay); } @@ -203,6 +233,10 @@ char *id; dev_close() /* close our display and free resources */ { + smInit(0); +#ifdef DOBJ + dobj_cleanup(); +#endif glXMakeCurrent(ourdisplay, None, NULL); glXDestroyContext(ourdisplay, gctx); XDestroyWindow(ourdisplay, gwind); @@ -210,478 +244,223 @@ dev_close() /* close our display and free resources XCloseDisplay(ourdisplay); ourdisplay = NULL; tmDone(NULL); - FreeValues(); odev.v.type = 0; odev.hres = odev.vres = 0; odev.ifd = -1; } +dev_clear() /* clear our representation */ +{ + smInit(rsL.max_samp); + wipeclean(); + rayqleft = 0; /* hold off update */ +} + + int dev_view(nv) /* assign new driver view */ register VIEW *nv; { + double d; + if (nv->type != VT_PER || /* check view legality */ - nv->horiz > 120. || nv->vert > 120.) { + nv->horiz > 160. || nv->vert > 160.) { error(COMMAND, "illegal view type/angle"); - nv->type = VT_PER; + nv->type = odev.v.type; nv->horiz = odev.v.horiz; nv->vert = odev.v.vert; return(0); } - if (nv != &odev.v) { - if (!FEQ(nv->horiz,odev.v.horiz) || /* resize window? */ - !FEQ(nv->vert,odev.v.vert)) { - int dw = DisplayWidth(ourdisplay,ourscreen); - int dh = DisplayHeight(ourdisplay,ourscreen); + if (nv != &odev.v && /* resize window? */ + (!FEQ(nv->horiz,odev.v.horiz) || + !FEQ(nv->vert,odev.v.vert))) { + int dw = DisplayWidth(ourdisplay,ourscreen); + int dh = DisplayHeight(ourdisplay,ourscreen); - dw -= 25; /* for window frame */ - dh -= 50; - odev.hres = 2.*VIEWDIST/pwidth * - tan(PI/180./2.*nv->horiz); - odev.vres = 2.*VIEWDIST/pheight * - tan(PI/180./2.*nv->vert); - if (odev.hres > dw) { - odev.vres = dw * odev.vres / odev.hres; - odev.hres = dw; - } - if (odev.vres > dh) { - odev.hres = dh * odev.hres / odev.vres; - odev.vres = dh; - } - XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres); - dev_input(); /* get resize event */ + dw -= 25; /* for window frame */ + dh -= 50; +#ifdef STEREO + dh /= 2; +#endif + odev.hres = 2.*VIEWDIST/pwidth * + tan(PI/180./2.*nv->horiz); + odev.vres = 2.*VIEWDIST/pheight * + tan(PI/180./2.*nv->vert); + if (odev.hres > dw) { + odev.vres = dw * odev.vres / odev.hres; + odev.hres = dw; } - copystruct(&odev.v, nv); - setGLview(); - glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); - redraw(); + if (odev.vres > dh) { + odev.hres = dh * odev.hres / odev.vres; + odev.vres = dh; + } + XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres); + dev_input(); /* get resize event */ } + copystruct(&odev.v, nv); /* setview() already called */ + setglpersp(&odev.v); +#ifdef STEREO + copystruct(&vwright, nv); + d = eyesepdist / sqrt(nv->hn2); + VSUM(vwright.vp, nv->vp, nv->hvec, d); + /* setview(&vwright); -- Unnecessary */ +#endif + checkglerr("setting view"); + wipeclean(); return(1); } -int -dev_input() /* get X11 input */ +dev_auxcom(cmd, args) /* process an auxiliary command */ +char *cmd, *args; { - inpresflags = 0; - - do - getevent(); - - while (XQLength(ourdisplay) > 0); - - return(inpresflags); +#ifdef DOBJ + if (dobj_command(cmd, args) >= 0) + return; +#endif + sprintf(errmsg, "%s: unknown command", cmd); + error(COMMAND, errmsg); } -dev_value(c, p, v) /* add a pixel value to our list */ -COLR c; -FVECT p, v; +VIEW * +dev_auxview(n, hvres) /* return nth auxiliary view */ +int n; +int hvres[2]; { - register int li; - - li = rV.tl++; - if (rV.tl >= rV.nl) /* get next leaf in ring */ - rV.tl = 0; - if (rV.tl == rV.bl) /* need to shake some free */ - Compost(FREEPCT); - VCOPY(rV.wp[li], p); - rV.wd[li] = encodedir(v); - tmCvColrs(&rV.brt[li], rV.chr[li], c, 1); + hvres[0] = odev.hres; hvres[1] = odev.vres; + if (n == 0) + return(&odev.v); +#ifdef STEREO + if (n == 1) + return(&vwright); +#endif + return(NULL); } int -dev_flush() /* flush output */ +dev_input() /* get X11 input */ { - if (mapped) { - TMapValues(0); - while (rV.drl != rV.tl) { - drawvalue(rV.drl); - if (++rV.drl >= rV.nl) - rV.drl = 0; - } - glFlush(); - } - return(XPending(ourdisplay)); -} + inpresflags = 0; + do + getevent(); -static int -mytmflags() /* figure out tone mapping flags */ -{ - extern char *progname; - register char *cp, *tail; - /* find basic name */ - for (cp = tail = progname; *cp; cp++) - if (*cp == '/') - tail = cp+1; - for (cp = tail; *cp && *cp != '.'; cp++) - ; - if (cp-tail == 3 && !strncmp(tail, "glx", 3)) - return(TM_F_CAMERA); - if (cp-tail == 4 && !strncmp(tail, "glxh", 4)) - return(TM_F_HUMAN); - error(USER, "illegal driver name"); -} + while (XPending(ourdisplay) > 0); + odev.inpready = 0; -static -setGLview() /* set our GL view */ -{ - double xmin, xmax, ymin, ymax, zmin, zmax; - double d, cx, sx, crad; - FVECT vx, vy; - register int i, j; - /* compute view frustum */ - if (normalize(odev.v.vdir) == 0.0) - return; - if (mindepth < maxdepth) { - zmin = 0.25*mindepth; - zmax = 4.0*(1.+CONEH)*maxdepth; - } else { - zmin = 0.01; - zmax = 1000.; - } - if (odev.v.vfore > FTINY) - zmin = odev.v.vfore; - if (odev.v.vaft > FTINY) - zmax = odev.v.vaft; - xmax = zmin * tan(PI/180./2. * odev.v.horiz); - xmin = -xmax; - d = odev.v.hoff * (xmax - xmin); - xmin += d; xmax += d; - ymax = zmin * tan(PI/180./2. * odev.v.vert); - ymin = -ymax; - d = odev.v.voff * (ymax - ymin); - ymin += d; ymax += d; - /* set view matrix */ - glMatrixMode(GL_PROJECTION); - glLoadIdentity(); - glFrustum(xmin, xmax, ymin, ymax, zmin, zmax); - gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2], - odev.v.vp[0] + odev.v.vdir[0], - odev.v.vp[1] + odev.v.vdir[1], - odev.v.vp[2] + odev.v.vdir[2], - odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]); - /* set viewport */ - glViewport(0, 0, odev.hres, odev.vres); - /* initialize cone for Vornoi polys */ - coneh = CONEH*(zmax - zmin); - crad = 0.5 * CONEW * 0.5*(xmax-xmin + ymax-ymin) * (zmin+coneh)/zmin; - vy[0] = vy[1] = vy[2] = 0.; - for (i = 0; i < 3; i++) - if (odev.v.vdir[i] < 0.6 && odev.v.vdir[i] > -0.6) - break; - vy[i] = 1.; - fcross(vx, vy, odev.v.vdir); - normalize(vx); - fcross(vy, odev.v.vdir, vx); - for (j = 0, d = 0.; j < NCONEV; j++, d += 2.*PI/NCONEV) { - cx = crad*cos(d); sx = crad*sin(d); - for (i = 0; i < 3; i++) - conev[j][i] = coneh*odev.v.vdir[i] + - cx*vx[i] + sx*vy[i]; - } + return(inpresflags); } -#define SUCCSTEP 8 /* skip step when successful */ -#define MAXSTEP 64 - -static -drawvalue(li) /* draw a pixel value as a cone */ -register int li; +dev_value(c, d, p) /* add a pixel value to our mesh */ +COLR c; +FVECT d, p; { - static int skipstep = 1; - static FVECT disp; - FVECT apex; - double d, dorg, dnew, h, v; - register int i; - /* check for quicker update */ - if (quicken) { - if (li % skipstep) - return; - if (skipstep < MAXSTEP) - skipstep++; + double depth; +#ifdef DOBJ + if (dobj_lightsamp != NULL) { /* in light source sampling */ + (*dobj_lightsamp)(c, d, p); + return; } - /* compute cone coordinates */ - disp[0] = rV.wp[li][0] - odev.v.vp[0]; - disp[1] = rV.wp[li][1] - odev.v.vp[1]; - disp[2] = rV.wp[li][2] - odev.v.vp[2]; - dorg = DOT(disp,odev.v.vdir); - if (dorg <= odev.v.vfore) - return; /* clipped too near */ - if (odev.v.vaft > FTINY && dorg > odev.v.vaft) - return; /* clipped too far */ - if (dorg > 1e5) { /* background pixel */ - dnew = maxdepth; - d = dnew/dorg; - dorg = maxdepth; - } else { /* foreground pixel, compute penalty */ - normalize(disp); - d = dnew = dorg + coneh*fdir2diff(rV.wd[li],disp)*DIRPEN; +#endif + smNewSamp(c, d, p); /* add to display representation */ + if (p != NULL) { + depth = (p[0] - odev.v.vp[0])*d[0] + + (p[1] - odev.v.vp[1])*d[1] + + (p[2] - odev.v.vp[2])*d[2]; + if (depth > FTINY) { + if (depth < mindpth) + mindpth = depth; + if (depth > maxdpth) + maxdpth = depth; + } } - /* compute adjusted apex position */ - disp[0] *= d; disp[1] *= d; disp[2] *= d; - apex[0] = odev.v.vp[0] + disp[0]; - apex[1] = odev.v.vp[1] + disp[1]; - apex[2] = odev.v.vp[2] + disp[2]; - /* compute view position and base offset */ - h = DOT(disp,odev.v.hvec)/(dnew*odev.v.hn2); - v = DOT(disp,odev.v.vvec)/(dnew*odev.v.vn2); - if (fabs(h - odev.v.hoff) > 0.5 || fabs(v - odev.v.voff) > 0.5) - return; /* clipped off screen */ - if (dorg < mindepth) - mindepth = dorg; - if (dorg > maxdepth) - maxdepth = dorg; - for (i = 0; i < 3; i++) - disp[i] = apex[i] + coneh*(h*odev.v.hvec[i] + v*odev.v.vvec[i]); - /* draw cone (pyramid approx.) */ - glColor4ub(rV.rgb[li][0], rV.rgb[li][1], rV.rgb[li][2], rV.alpha[li]); - glBegin(GL_TRIANGLE_FAN); - glVertex3f(apex[0], apex[1], apex[2]); - for (i = 0; i < NCONEV; i++) - glVertex3d(conev[i][0] + disp[0], conev[i][1] + disp[1], - conev[i][2] + disp[2]); - /* connect last face to first */ - glVertex3d(conev[0][0] + disp[0], conev[0][1] + disp[1], - conev[0][2] + disp[2]); - glEnd(); /* done */ - skipstep = SUCCSTEP; + if (!--rayqleft) + dev_flush(); /* flush output */ } -#undef SUCCSTEP -#undef MAXSTEP - -#define LEAFSIZ (3*sizeof(float)+sizeof(int4)+\ - sizeof(TMbright)+7*sizeof(BYTE)) - -static -AllocValues(n) /* allocate space for n values */ -register int n; +int +dev_flush() /* flush output */ { - unsigned nbytes; - register unsigned i; - - if (n <= 0) - return(0); - if (rV.nl >= n) - return(rV.nl); - else if (rV.nl > 0) - free(rV.base); - /* round space up to nearest power of 2 */ - nbytes = n*LEAFSIZ + 8; - for (i = 1024; nbytes > i; i <<= 1) - ; - n = (i - 8) / LEAFSIZ; /* should we make sure n is even? */ - rV.base = (char *)malloc(n*LEAFSIZ); - if (rV.base == NULL) - return(0); - /* assign larger alignment types earlier */ - rV.wp = (float (*)[3])rV.base; - rV.wd = (int4 *)(rV.wp + n); - rV.brt = (TMbright *)(rV.wd + n); - rV.chr = (BYTE (*)[3])(rV.brt + n); - rV.rgb = (BYTE (*)[3])(rV.chr + n); - rV.alpha = (BYTE *)(rV.rgb + n); - rV.nl = n; - rV.drl = rV.tml = rV.bl = rV.tl = 0; - return(n); +#ifdef STEREO + pushright(); /* update right eye */ + glClear(GL_DEPTH_BUFFER_BIT); + smUpdate(&vwright, 100); +#ifdef DOBJ + dobj_render(); /* usually in foreground */ +#endif + popright(); /* update left eye */ + glClear(GL_DEPTH_BUFFER_BIT); +#endif + smUpdate(&odev.v, 100); +#ifdef DOBJ + dobj_render(); +#endif + glFlush(); /* flush OGL */ + checkglerr("flushing display"); + rayqleft = RAYQLEN; + /* flush X11 and return # pending */ + return(odev.inpready = XPending(ourdisplay)); } -#undef LEAFSIZ - -static -FreeValues() /* free our allocated values */ +checkglerr(where) /* check for GL or GLU error */ +char *where; { - if (rV.nl <= 0) - return; - free(rV.base); - rV.base = NULL; - rV.nl = 0; -} + register GLenum errcode; - -static -clralphas() /* prepare for new alpha values */ -{ - if (!vmaplen) - return; - free((char *)valmap); - valmap = NULL; - vmaplen = 0; -} - - -static int -valcmp(v1p, v2p) /* compare two pixel values */ -int *v1p, *v2p; -{ - register int v1 = *v1p, v2 = *v2p; - register int c; - - if ((c = rV.rgb[v1][0] - rV.rgb[v2][0])) return(c); - if ((c = rV.rgb[v1][1] - rV.rgb[v2][1])) return(c); - if ((c = rV.rgb[v1][2] - rV.rgb[v2][2])) return(c); - return(rV.alpha[v1] - rV.alpha[v2]); -} - - -static -mergalphas(adest, al1, n1, al2, n2) /* merge two sorted alpha lists */ -register int *adest, *al1, *al2; -int n1, n2; -{ - register int cmp; - - while (n1 | n2) { - if (!n1) cmp = 1; - else if (!n2) cmp = -1; - else cmp = valcmp(al1, al2); - if (cmp > 0) { - *adest++ = *al2++; - n2--; - } else { - *adest++ = *al1++; - n1--; - } + while ((errcode = glGetError()) != GL_NO_ERROR) { + sprintf(errmsg, "OpenGL error %s: %s", + where, gluErrorString(errcode)); + error(WARNING, errmsg); } } +#ifdef STEREO static -setalphas(vbeg, nvals) /* add values to our map and set alphas */ -int vbeg, nvals; +pushright() /* push on right view */ { - register int *newmap; - short ccmp[3], lastalpha; - int newmaplen; + double d; - if (nvals <= 0) - return; - newmaplen = vmaplen + nvals; /* allocate new map */ - newmap = (int *)malloc(newmaplen*sizeof(int)); - if (newmap == NULL) - error(SYSTEM, "out of memory in setalphas"); - while (nvals--) { /* add new values to end */ - rV.alpha[vbeg] = 255; - newmap[vmaplen+nvals] = vbeg++; - } - if (nvals >= 3*vmaplen) { /* resort the combined array */ - while (vmaplen--) - newmap[vmaplen] = valmap[vmaplen]; - qsort((char *)newmap, newmaplen, sizeof(int), valcmp); - } else { /* perform merge sort */ - qsort((char *)(newmap+vmaplen), newmaplen-vmaplen, - sizeof(int), valcmp); - mergalphas(newmap, valmap, vmaplen, - newmap+vmaplen, newmaplen-vmaplen); - } - if (valmap != NULL) /* free old map and assign new one */ - free((char *)valmap); - valmap = newmap; - vmaplen = newmaplen; - lastalpha = 0; /* set new alpha values */ - ccmp[0] = ccmp[1] = ccmp[2] = 256; - while (newmaplen--) - if (rV.rgb[*newmap][0] == ccmp[0] && - rV.rgb[*newmap][1] == ccmp[1] && - rV.rgb[*newmap][2] == ccmp[2]) { - if (lastalpha >= 255) - newmap++; - else if (rV.alpha[*newmap] < 255) - lastalpha = rV.alpha[*newmap++]; - else - rV.alpha[*newmap++] = ++lastalpha; - } else { - ccmp[0] = rV.rgb[*newmap][0]; - ccmp[1] = rV.rgb[*newmap][1]; - ccmp[2] = rV.rgb[*newmap][2]; - if (rV.alpha[*newmap] < 255) - lastalpha = rV.alpha[*newmap++]; - else - rV.alpha[*newmap++] = lastalpha = 1; - } + setstereobuf(STEREO_BUFFER_RIGHT); + glMatrixMode(GL_MODELVIEW); + glPushMatrix(); + d = -eyesepdist / sqrt(odev.v.hn2); + glTranslated(d*odev.v.hvec[0], d*odev.v.hvec[1], d*odev.v.hvec[2]); } static -TMapValues(redo) /* map our values to RGB */ -int redo; +popright() /* pop off right view */ { - int aorg, alen, borg, blen; - /* recompute mapping? */ - if (redo) - rV.tml = rV.bl; - /* already done? */ - if (rV.tml == rV.tl) - return(1); - /* compute segments */ - aorg = rV.tml; - if (rV.tl >= aorg) { - alen = rV.tl - aorg; - blen = 0; - } else { - alen = rV.nl - aorg; - borg = 0; - blen = rV.tl; - } - /* (re)compute tone mapping? */ - if (rV.tml == rV.bl) { - tmClearHisto(); - tmAddHisto(rV.brt+aorg, alen, 1); - if (blen > 0) - tmAddHisto(rV.brt+borg, blen, 1); - if (tmComputeMapping(0., 0., 0.) != TM_E_OK) - return(0); - clralphas(); /* restart value list */ - rV.drl = rV.bl; /* need to redraw */ - } - if (tmMapPixels(rV.rgb+aorg, rV.brt+aorg, - rV.chr+aorg, alen) != TM_E_OK) - return(0); - if (blen > 0) - tmMapPixels(rV.rgb+borg, rV.brt+borg, - rV.chr+borg, blen); - setalphas(aorg, alen); /* compute add'l alpha values */ - if (blen > 0) - setalphas(borg, blen); - rV.tml = rV.tl; /* we're all up to date */ - return(1); + glMatrixMode(GL_MODELVIEW); + glPopMatrix(); + setstereobuf(STEREO_BUFFER_LEFT); } +#endif static int -Compost(pct) /* free up some values */ -int pct; +mytmflags() /* figure out tone mapping flags */ { - int nused, nclear, nmapped, ndrawn; - /* figure out how many values to clear */ - nclear = rV.nl * pct / 100; - nused = rV.tl - rV.bl; - if (nused <= 0) nused += rV.nl; - nclear -= rV.nl - nused; - if (nclear <= 0) - return(0); - if (nclear >= nused) { /* clear them all? */ - rV.drl = rV.tml = rV.bl = rV.tl = 0; - return(nused); - } - /* else clear values from bottom */ - ndrawn = rV.drl - rV.bl; - if (ndrawn < 0) ndrawn += rV.nl; - nmapped = rV.tml - rV.bl; - if (nmapped < 0) nmapped += rV.nl; - rV.bl += nclear; - if (rV.bl >= rV.nl) rV.bl -= rV.nl; - if (ndrawn < nclear) rV.drl = rV.bl; - if (nmapped < nclear) rV.tml = rV.bl; - return(nclear); + extern char *progname; + register char *cp, *tail; + /* find basic name */ + for (cp = tail = progname; *cp; cp++) + if (*cp == '/') + tail = cp+1; + for (cp = tail; *cp && *cp != '.'; cp++) + ; + if (cp > tail && cp[-1] == 'h') + return(TM_F_HUMAN|TM_F_NOSTDERR); + else + return(TM_F_CAMERA|TM_F_NOSTDERR); } @@ -729,78 +508,57 @@ draw_grids() /* draw holodeck section grids */ if (!mapped) return; glColor4ub(gridrgba[0], gridrgba[1], gridrgba[2], gridrgba[3]); - /* draw each grid line */ - glBegin(GL_LINES); + glBegin(GL_LINES); /* draw each grid line */ gridlines(draw3dline); glEnd(); } -static int -IndexValue(rgba) /* locate a pixel by it's framebuffer value */ -register BYTE rgba[4]; -{ - register int *vp; - /* check legality */ - if (rgba[3] == 0 || rgba[3] == 255) - return(-1); - /* borrow a value slot */ - rV.rgb[rV.tl][0] = rgba[0]; - rV.rgb[rV.tl][1] = rgba[1]; - rV.rgb[rV.tl][2] = rgba[2]; - rV.alpha[rV.tl] = rgba[3]; - /* find it */ - vp = (int *)bsearch((char *)&rV.tl, (char *)valmap, vmaplen, - sizeof(int), valcmp); - if (vp == NULL) - return(-1); - return(*vp); -} - - -static int -FindValue(dx, dy) /* find a value on the display */ -int dx, dy; -{ - BYTE rgba[4]; - - if (dx < 0 || dy < 0 || dx >= odev.hres || dy >= odev.vres) - return(-1); - glReadPixels(dx, dy, 1, 1, GL_RGBA, GL_UNSIGNED_BYTE, rgba); - return(IndexValue(rgba)); -} - - static moveview(dx, dy, mov, orb) /* move our view */ int dx, dy, mov, orb; { VIEW nv; - FVECT odir, v1; + FVECT odir, v1, wip; double d; register int li; /* start with old view */ copystruct(&nv, &odev.v); /* change view direction */ + if (viewray(v1, odir, &odev.v, + (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY) + return(0); /* outside view */ if (mov | orb) { - if ((li = FindValue(dx, dy)) < 0) +#ifdef DOBJ + d = dobj_trace(NULL, v1, odir); /* check objects */ + /* is holodeck in front? */ + if ((li = smFindSamp(v1, odir)) >= 0 && + (rsL.wp[li][0] - nv.vp[0])*odir[0] + + (rsL.wp[li][1] - nv.vp[1])*odir[1] + + (rsL.wp[li][2] - nv.vp[2])*odir[2] < d) + VCOPY(wip, rsL.wp[li]); + else if (d < .99*FHUGE) /* object is closer */ + VSUM(wip, nv.vp, odir, d); + else /* nothing visible */ + return(0); +#else + if ((li = smFindSamp(v1, odir)) < 0) return(0); /* not on window */ - VSUM(odir, rV.wp[li], nv.vp, -1.); - } else { - if (viewray(nv.vp, nv.vdir, &odev.v, - (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY) - return(0); /* outside view */ - } + VCOPY(wip, rsL.wp[li]); +#endif + VSUM(odir, wip, nv.vp, -1.); + } else + VCOPY(nv.vdir, odir); if (orb && mov) { /* orbit left/right */ spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov); - VSUM(nv.vp, rV.wp[li], odir, -1.); + VSUM(nv.vp, wip, odir, -1.); spinvector(nv.vdir, nv.vdir, nv.vup, d); } else if (orb) { /* orbit up/down */ fcross(v1, odir, nv.vup); if (normalize(v1) == 0.) return(0); spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb); - VSUM(nv.vp, rV.wp[li], odir, -1.); + VSUM(nv.vp, wip, odir, -1.); spinvector(nv.vdir, nv.vdir, v1, d); } else if (mov) { /* move forward/backward */ d = MOVPCT/100. * mov; @@ -825,13 +583,16 @@ XButtonPressedEvent *ebut; { int movdir = MOVDIR(ebut->button); int movorb = MOVORB(ebut->state); + int qlevel = 99; + time_t lasttime, thistime; + int nframes; Window rootw, childw; int rootx, rooty, wx, wy; unsigned int statemask; - quicken = 1; /* accelerate update rate */ XNoOp(ourdisplay); + lasttime = time(0); nframes = 0; while (!XCheckMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent))) { @@ -841,26 +602,109 @@ XButtonPressedEvent *ebut; if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) { sleep(1); + lasttime++; continue; } +#ifdef STEREO + pushright(); + glClear(GL_COLOR_BUFFER_BIT); draw_grids(); - dev_flush(); + smUpdate(&vwright, qlevel); +#ifdef DOBJ + dobj_render(); +#endif + popright(); +#endif + glClear(GL_COLOR_BUFFER_BIT); + draw_grids(); + smUpdate(&odev.v, qlevel); +#ifdef DOBJ + dobj_render(); +#endif + glFlush(); + checkglerr("moving view"); + nframes++; + thistime = time(0); + if (thistime - lasttime >= 3 || + nframes > (int)(3*3*TARGETFPS)) { + qlevel = thistime<=lasttime ? 1000 : + (int)((double)nframes/(thistime-lasttime) + / TARGETFPS * qlevel + 0.5); + lasttime = thistime; nframes = 0; + if (qlevel > 99) { + if (qlevel > 300) { /* put on the brakes */ + sleep(1); + lasttime++; + } + qlevel = 99; + } else if (qlevel < 1) + qlevel = 1; + } } if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */ movdir = MOVDIR(levptr(XButtonReleasedEvent)->button); wx = levptr(XButtonReleasedEvent)->x; wy = levptr(XButtonReleasedEvent)->y; moveview(wx, odev.vres-1-wy, movdir, movorb); + } +} + + +static +setglpersp(vp) /* set perspective view in GL */ +register VIEW *vp; +{ + double d, xmin, xmax, ymin, ymax; + + if (mindpth >= maxdpth) { + dev_zmin = 0.1; + dev_zmax = 100.; } else { - glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); - redraw(); + dev_zmin = 0.5*mindpth; + dev_zmax = 1.5*maxdpth; + if (dev_zmin > dev_zmax/100.) + dev_zmin = dev_zmax/100.; } - quicken = 0; - dev_flush(); + if (odev.v.vfore > FTINY) + dev_zmin = odev.v.vfore; + if (odev.v.vaft > FTINY) + dev_zmax = odev.v.vaft; + if (dev_zmin < dev_zmax/5000.) + dev_zmin = dev_zmax/5000.; + xmax = dev_zmin * tan(PI/180./2. * odev.v.horiz); + xmin = -xmax; + d = odev.v.hoff * (xmax - xmin); + xmin += d; xmax += d; + ymax = dev_zmin * tan(PI/180./2. * odev.v.vert); + ymin = -ymax; + d = odev.v.voff * (ymax - ymin); + ymin += d; ymax += d; + /* set view matrix */ + glMatrixMode(GL_PROJECTION); + glLoadIdentity(); + glFrustum(xmin, xmax, ymin, ymax, dev_zmin, dev_zmax); + gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2], + odev.v.vp[0] + odev.v.vdir[0], + odev.v.vp[1] + odev.v.vdir[1], + odev.v.vp[2] + odev.v.vdir[2], + odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]); } static +wipeclean() /* prepare for redraw */ +{ +#ifdef STEREO + setstereobuf(STEREO_BUFFER_RIGHT); + glClear(GL_DEPTH_BUFFER_BIT); + setstereobuf(STEREO_BUFFER_LEFT); +#endif + glClear(GL_DEPTH_BUFFER_BIT); + smClean(); +} + + +static getkey(ekey) /* get input key */ register XKeyPressedEvent *ekey; { @@ -891,9 +735,7 @@ register XKeyPressedEvent *ekey; inpresflags |= DFL(DC_RESUME); return; case CTRL('R'): /* redraw screen */ - TMapValues(1); - glClear(GL_DEPTH_BUFFER_BIT); - redraw(); + wipeclean(); return; case CTRL('L'): /* refresh from server */ if (inpresflags & DFL(DC_REDRAW)) @@ -901,10 +743,17 @@ register XKeyPressedEvent *ekey; glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); glDisable(GL_DEPTH_TEST); draw_grids(); +#ifdef STEREO + pushright(); + glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); + draw_grids(); + popright(); +#endif glEnable(GL_DEPTH_TEST); glFlush(); - Compost(100); /* get rid of old values */ + smInit(rsL.max_samp); /* get rid of old values */ inpresflags |= DFL(DC_REDRAW); /* resend values from server */ + rayqleft = 0; /* hold off update */ return; case 'K': /* kill rtrace process(es) */ inpresflags |= DFL(DC_KILL); @@ -929,14 +778,13 @@ static fixwindow(eexp) /* repair damage to window */ register XExposeEvent *eexp; { - if (odev.hres == 0 || odev.vres == 0) /* first exposure */ + if (odev.hres == 0 | odev.vres == 0) { /* first exposure */ resizewindow((XConfigureEvent *)eexp); - if (eexp->width == odev.hres && eexp->height == odev.vres) - TMapValues(1); - if (!eexp->count) { - glClear(GL_DEPTH_BUFFER_BIT); - redraw(); + return; } + if (eexp->count) /* wait for final exposure */ + return; + wipeclean(); /* clear depth */ } @@ -944,6 +792,8 @@ static resizewindow(ersz) /* resize window */ register XConfigureEvent *ersz; { + glViewport(0, 0, ersz->width, ersz->height); + if (ersz->width == odev.hres && ersz->height == odev.vres) return; @@ -952,8 +802,6 @@ register XConfigureEvent *ersz; odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres); odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres); - - setGLview(); inpresflags |= DFL(DC_SETVIEW); }
