--- ray/src/hd/rhd_glx.c 1997/12/23 18:31:00 3.1 +++ ray/src/hd/rhd_glx.c 1997/12/24 14:06:40 3.2 @@ -6,7 +6,7 @@ static char SCCSid[] = "$SunId$ SGI"; /* * OpenGL GLX driver for holodeck display. - * Based on rview driver. + * Based on x11 driver. */ #include "standard.h" @@ -26,20 +26,23 @@ static char SCCSid[] = "$SunId$ SGI"; #endif #ifndef FREEPCT -#define FREEPCT 25 /* percentage of values to free */ +#define FREEPCT 10 /* percentage of values to free */ #endif #ifndef NCONEV #define NCONEV 7 /* number of cone base vertices */ #endif #ifndef CONEH -#define CONEH 0.25 /* cone height (fraction of depth) */ +#define CONEH 5. /* cone height (fraction of depth) */ #endif #ifndef CONEW -#define CONEW 0.035 /* cone width (fraction of screen) */ +#define CONEW 0.07 /* cone width (fraction of screen) */ #endif +#ifndef DIRPEN +#define DIRPEN 0.001 /* direction penalty factor */ +#endif -#define GAMMA 2.2 /* default gamma correction */ +#define GAMMA 1.4 /* default gamma correction */ #define MOVPCT 7 /* percent distance to move /frame */ #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1) @@ -65,7 +68,6 @@ struct driver odev; /* global device driver structur static XEvent currentevent; /* current event */ static int mapped = 0; /* window is mapped? */ -static unsigned long *pixval = NULL; /* allocated pixels */ static unsigned long ourblack=0, ourwhite=~0; static Display *ourdisplay = NULL; /* our display */ @@ -74,7 +76,7 @@ static Window gwind = 0; /* our graphics window */ static GLXContext gctx; /* our GLX context */ static double mindepth = FHUGE; /* minimum depth value so far */ -static double maxdepth = 0.; /* maximum depth value */ +static double maxdepth = 0.; /* maximum depth value so far */ static double pwidth, pheight; /* pixel dimensions (mm) */ @@ -99,26 +101,29 @@ static struct { char *base; /* base of allocated memory */ } rV; /* our collection of values */ +static int *valmap = NULL; /* sorted map of screen values */ +static int vmaplen = 0; /* value map length */ + #define redraw() (rV.drl = rV.bl) static int resizewindow(), getevent(), getkey(), moveview(), setGLview(), getmove(), fixwindow(), mytmflags(), - newvalue(), drawvalue(), Compost(), - FindValue(), AllocValues(), TMapValues(), FreeValues(); + drawvalue(), valcmp(), clralphas(), setalphas(), mergalphas(), + IndexValue(), Compost(), FindValue(), TMapValues(), + AllocValues(), FreeValues(); +extern int4 encodedir(); +extern double fdir2diff(), dir2diff(); + dev_open(id) /* initialize X11 driver */ char *id; { extern char *getenv(); static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,8, GLX_GREEN_SIZE,8, GLX_BLUE_SIZE,8, - GLX_ALPHA_SIZE,8, GLX_DEPTH_SIZE,23, - /*GLX_DOUBLEBUFFER,*/ None}; - static int atlOK[] = {GLX_RGBA, GLX_RED_SIZE,4, - GLX_GREEN_SIZE,4, GLX_BLUE_SIZE,4, - GLX_ALPHA_SIZE,4, GLX_DEPTH_SIZE,15, - /*GLX_DOUBLEBUFFER,*/ None}; + GLX_ALPHA_SIZE,8, GLX_DEPTH_SIZE,15, + None}; char *gv; double gamval = GAMMA; XSetWindowAttributes ourwinattr; @@ -131,8 +136,6 @@ char *id; /* find a usable visual */ ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest); if (ourvinf == NULL) - ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlOK); - if (ourvinf == NULL) error(USER, "no suitable visuals available"); /* get a context */ gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE); @@ -167,13 +170,12 @@ char *id; oursizhints.min_height = MINHEIGHT; oursizhints.flags = PMinSize; XSetNormalHints(ourdisplay, gwind, &oursizhints); - /* map the window and get its size */ - XMapWindow(ourdisplay, gwind); - dev_input(); - /* allocate our value list */ - if (!AllocValues(DisplayWidth(ourdisplay,ourscreen) * - DisplayHeight(ourdisplay,ourscreen) / 4)) - error(SYSTEM, "insufficient memory for value storage"); + /* set GLX context */ + glXMakeCurrent(ourdisplay, gwind, gctx); + glEnable(GL_DEPTH_TEST); + glDepthFunc(GL_LEQUAL); + glShadeModel(GL_FLAT); + glDisable(GL_DITHER); /* figure out sensible view */ pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) / DisplayWidth(ourdisplay, ourscreen); @@ -181,20 +183,16 @@ char *id; DisplayHeight(ourdisplay, ourscreen); copystruct(&odev.v, &stdview); odev.v.type = VT_PER; - odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres); - odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres); + /* map the window */ + XMapWindow(ourdisplay, gwind); + dev_input(); /* sets size and view angles */ + glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); + /* allocate our value list */ + if (!AllocValues(DisplayWidth(ourdisplay,ourscreen) * + DisplayHeight(ourdisplay,ourscreen) / 4)) + error(SYSTEM, "insufficient memory for value storage"); odev.name = id; odev.ifd = ConnectionNumber(ourdisplay); - /* set GLX context and clear buffers */ - glXMakeCurrent(ourdisplay, gwind, gctx); - glEnable(GL_DEPTH_TEST); - glDepthFunc(GL_LEQUAL); - glShadeModel(GL_FLAT); - glDisable(GL_DITHER); - glDrawBuffer(GL_FRONT_AND_BACK); - glReadBuffer(GL_BACK); - glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); - setGLview(); /* initialize view */ } @@ -247,12 +245,13 @@ register VIEW *nv; odev.vres = dh; } XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres); + dev_input(); /* get resize event */ } copystruct(&odev.v, nv); setGLview(); + glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); + redraw(); } - glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); - redraw(); return(1); } @@ -277,7 +276,11 @@ FVECT p, v; { register int li; - li = newvalue(); + li = rV.tl++; + if (rV.tl >= rV.nl) /* get next leaf in ring */ + rV.tl = 0; + if (rV.tl == rV.bl) /* need to shake some free */ + Compost(FREEPCT); VCOPY(rV.wp[li], p); rV.wd[li] = encodedir(v); tmCvColrs(&rV.brt[li], rV.chr[li], c, 1); @@ -331,7 +334,7 @@ setGLview() /* set our GL view */ return; if (mindepth < maxdepth) { zmin = 0.25*mindepth; - zmax = 8.0*maxdepth; + zmax = 4.0*(1.+CONEH)*maxdepth; } else { zmin = 0.01; zmax = 1000.; @@ -379,66 +382,57 @@ setGLview() /* set our GL view */ } -static int -newvalue() /* allocate a leaf from our pile */ -{ - int li; - - li = rV.tl++; - if (rV.tl >= rV.nl) /* get next leaf in ring */ - rV.tl = 0; - if (rV.tl == rV.bl) /* need to shake some free */ - Compost(FREEPCT); - return(li); -} - - static drawvalue(li) /* draw a pixel value as a cone */ register int li; { - static FVECT apex, disp; - double d, h, v; + static FVECT disp; + FVECT apex; + double d, dorg, dnew, h, v; register int i; - /* compute cone's base displacement */ - VCOPY(apex, rV.wp[li]); - disp[0] = apex[0] - odev.v.vp[0]; - disp[1] = apex[1] - odev.v.vp[1]; - disp[2] = apex[2] - odev.v.vp[2]; - if ((d = DOT(disp,odev.v.vdir)) <= odev.v.vfore || d <= FTINY) - return; - if (d > 1e5) { /* background region */ - if (odev.v.vaft > FTINY) - return; - h = maxdepth/d; - disp[0] *= h; disp[1] *= h; disp[2] *= h; - apex[0] = odev.v.vp[0] + disp[0]; - apex[1] = odev.v.vp[1] + disp[1]; - apex[2] = odev.v.vp[2] + disp[2]; - d = maxdepth; - } else if (d > maxdepth) - maxdepth = d; - h = DOT(disp,odev.v.hvec)/(d*odev.v.hn2); - v = DOT(disp,odev.v.vvec)/(d*odev.v.vn2); - if (fabs(h - odev.v.hoff) < 0.5 && fabs(v - odev.v.voff) < 0.5 && - d < mindepth) -{ -fprintf(stderr, "min depth now %lf (%lf,%lf,%lf)\n", d, apex[0], apex[1], apex[2]); - mindepth = d; -} + /* compute cone coordinates */ + disp[0] = rV.wp[li][0] - odev.v.vp[0]; + disp[1] = rV.wp[li][1] - odev.v.vp[1]; + disp[2] = rV.wp[li][2] - odev.v.vp[2]; + dorg = DOT(disp,odev.v.vdir); + if (dorg <= odev.v.vfore) + return; /* clipped too near */ + if (odev.v.vaft > FTINY && dorg > odev.v.vaft) + return; /* clipped too far */ + if (dorg > 1e5) { /* background pixel */ + dnew = maxdepth; + d = dnew/dorg; + } else { /* foreground pixel, compute penalty */ + normalize(disp); + d = dnew = dorg + coneh*fdir2diff(rV.wd[li],disp)*DIRPEN; + } + /* compute adjusted apex position */ + disp[0] *= d; disp[1] *= d; disp[2] *= d; + apex[0] = odev.v.vp[0] + disp[0]; + apex[1] = odev.v.vp[1] + disp[1]; + apex[2] = odev.v.vp[2] + disp[2]; + /* compute view position and base offset */ + h = DOT(disp,odev.v.hvec)/(dnew*odev.v.hn2); + v = DOT(disp,odev.v.vvec)/(dnew*odev.v.vn2); + if (fabs(h - odev.v.hoff) > 0.5 || fabs(v - odev.v.voff) > 0.5) + return; /* clipped off screen */ + if (dorg < mindepth) + mindepth = dorg; + if (dorg > maxdepth) + maxdepth = dorg; for (i = 0; i < 3; i++) disp[i] = apex[i] + coneh*(h*odev.v.hvec[i] + v*odev.v.vvec[i]); - /* draw pyramid (cone approx.) */ + /* draw cone (pyramid approx.) */ glColor4ub(rV.rgb[li][0], rV.rgb[li][1], rV.rgb[li][2], rV.alpha[li]); glBegin(GL_TRIANGLE_FAN); glVertex3f(apex[0], apex[1], apex[2]); for (i = 0; i < NCONEV; i++) glVertex3d(conev[i][0] + disp[0], conev[i][1] + disp[1], conev[i][2] + disp[2]); - /* connect last side to first */ + /* connect last face to first */ glVertex3d(conev[0][0] + disp[0], conev[0][1] + disp[1], conev[0][2] + disp[2]); - glEnd(); /* done */ + glEnd(); /* done */ } @@ -493,6 +487,109 @@ FreeValues() /* free our allocated values */ static +clralphas() /* prepare for new alpha values */ +{ + if (!vmaplen) + return; + free((char *)valmap); + valmap = NULL; + vmaplen = 0; +} + + +static int +valcmp(v1p, v2p) /* compare two pixel values */ +int *v1p, *v2p; +{ + register int v1 = *v1p, v2 = *v2p; + register int c; + + if ((c = rV.rgb[v1][0] - rV.rgb[v2][0])) return(c); + if ((c = rV.rgb[v1][1] - rV.rgb[v2][1])) return(c); + if ((c = rV.rgb[v1][2] - rV.rgb[v2][2])) return(c); + return(rV.alpha[v1] - rV.alpha[v2]); +} + + +static +mergalphas(adest, al1, n1, al2, n2) /* merge two sorted alpha lists */ +register int *adest, *al1, *al2; +int n1, n2; +{ + register int cmp; + + while (n1 | n2) { + if (!n1) cmp = 1; + else if (!n2) cmp = -1; + else cmp = valcmp(al1, al2); + if (cmp > 0) { + *adest++ = *al2++; + n2--; + } else { + *adest++ = *al1++; + n1--; + } + } +} + + +static +setalphas(vbeg, nvals) /* add values to our map and set alphas */ +int vbeg, nvals; +{ + register int *newmap; + short ccmp[3], lastalpha; + int newmaplen; + + if (nvals <= 0) + return; + newmaplen = vmaplen + nvals; /* allocate new map */ + newmap = (int *)malloc(newmaplen*sizeof(int)); + if (newmap == NULL) + error(SYSTEM, "out of memory in setalphas"); + while (nvals--) { /* add new values to end */ + rV.alpha[vbeg] = 255; + newmap[vmaplen+nvals] = vbeg++; + } + if (nvals >= 3*vmaplen) { /* resort the combined array */ + while (vmaplen--) + newmap[vmaplen] = valmap[vmaplen]; + qsort((char *)newmap, newmaplen, sizeof(int), valcmp); + } else { /* perform merge sort */ + qsort((char *)(newmap+vmaplen), newmaplen-vmaplen, + sizeof(int), valcmp); + mergalphas(newmap, valmap, vmaplen, + newmap+vmaplen, newmaplen-vmaplen); + } + if (valmap != NULL) /* free old map and assign new one */ + free((char *)valmap); + valmap = newmap; + vmaplen = newmaplen; + lastalpha = 0; /* set new alpha values */ + ccmp[0] = ccmp[1] = ccmp[2] = 256; + while (newmaplen--) + if (rV.rgb[*newmap][0] == ccmp[0] && + rV.rgb[*newmap][1] == ccmp[1] && + rV.rgb[*newmap][2] == ccmp[2]) { + if (lastalpha >= 255) + newmap++; + else if (rV.alpha[*newmap] < 255) + lastalpha = rV.alpha[*newmap++]; + else + rV.alpha[*newmap++] = ++lastalpha; + } else { + ccmp[0] = rV.rgb[*newmap][0]; + ccmp[1] = rV.rgb[*newmap][1]; + ccmp[2] = rV.rgb[*newmap][2]; + if (rV.alpha[*newmap] < 255) + lastalpha = rV.alpha[*newmap++]; + else + rV.alpha[*newmap++] = lastalpha = 1; + } +} + + +static TMapValues(redo) /* map our values to RGB */ int redo; { @@ -521,7 +618,8 @@ int redo; tmAddHisto(rV.brt+borg, blen, 1); if (tmComputeMapping(0., 0., 0.) != TM_E_OK) return(0); - rV.drl = rV.bl; + clralphas(); /* restart value list */ + rV.drl = rV.bl; /* need to redraw */ } if (tmMapPixels(rV.rgb+aorg, rV.brt+aorg, rV.chr+aorg, alen) != TM_E_OK) @@ -529,8 +627,10 @@ int redo; if (blen > 0) tmMapPixels(rV.rgb+borg, rV.brt+borg, rV.chr+borg, blen); - /* compute unique alpha values */ - rV.tml = rV.tl; + setalphas(aorg, alen); /* compute add'l alpha values */ + if (blen > 0) + setalphas(borg, blen); + rV.tml = rV.tl; /* we're all up to date */ return(1); } @@ -547,7 +647,7 @@ int pct; nclear -= rV.nl - nused; if (nclear <= 0) return(0); - if (nclear >= nused) { /* clear them all */ + if (nclear >= nused) { /* clear them all? */ rV.drl = rV.tml = rV.bl = rV.tl = 0; return(nused); } @@ -603,7 +703,7 @@ register FVECT wp[2]; static draw_grids() /* draw holodeck section grids */ { - static GLubyte gridrgba[4] = {0x0, 0xff, 0xff, 0x00}; + static BYTE gridrgba[4] = {0x0, 0xff, 0xff, 0x00}; if (!mapped) return; @@ -616,10 +716,37 @@ draw_grids() /* draw holodeck section grids */ static int +IndexValue(rgba) /* locate a pixel by it's framebuffer value */ +register BYTE rgba[4]; +{ + register int *vp; + /* check legality */ + if (rgba[3] == 0 || rgba[3] == 255) + return(-1); + /* borrow a value slot */ + rV.rgb[rV.tl][0] = rgba[0]; + rV.rgb[rV.tl][1] = rgba[1]; + rV.rgb[rV.tl][2] = rgba[2]; + rV.alpha[rV.tl] = rgba[3]; + /* find it */ + vp = (int *)bsearch((char *)&rV.tl, (char *)valmap, vmaplen, + sizeof(int), valcmp); + if (vp == NULL) + return(-1); + return(*vp); +} + + +static int FindValue(dx, dy) /* find a value on the display */ int dx, dy; { - return(-1); /* not found */ + BYTE rgba[4]; + + if (dx < 0 || dy < 0 || dx >= odev.hres || dy >= odev.vres) + return(-1); + glReadPixels(dx, dy, 1, 1, GL_RGBA, GL_UNSIGNED_BYTE, rgba); + return(IndexValue(rgba)); } @@ -702,6 +829,9 @@ XButtonPressedEvent *ebut; wx = levptr(XButtonReleasedEvent)->x; wy = levptr(XButtonReleasedEvent)->y; moveview(wx, odev.vres-1-wy, movdir, movorb); + } else { + glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); + redraw(); } dev_flush(); } @@ -739,17 +869,16 @@ register XKeyPressedEvent *ekey; return; case CTRL('R'): /* redraw screen */ TMapValues(1); + glClear(GL_DEPTH_BUFFER_BIT); redraw(); return; case CTRL('L'): /* refresh from server */ if (inpresflags & DFL(DC_REDRAW)) return; glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); - glDrawBuffer(GL_FRONT); glDisable(GL_DEPTH_TEST); draw_grids(); glEnable(GL_DEPTH_TEST); - glDrawBuffer(GL_FRONT_AND_BACK); glFlush(); Compost(100); /* get rid of old values */ inpresflags |= DFL(DC_REDRAW); /* resend values from server */ @@ -777,14 +906,14 @@ static fixwindow(eexp) /* repair damage to window */ register XExposeEvent *eexp; { - if (odev.hres == 0 || odev.vres == 0) { /* first exposure */ - odev.hres = eexp->width; - odev.vres = eexp->height; - } + if (odev.hres == 0 || odev.vres == 0) /* first exposure */ + resizewindow((XConfigureEvent *)eexp); if (eexp->width == odev.hres && eexp->height == odev.vres) TMapValues(1); - if (!eexp->count) + if (!eexp->count) { + glClear(GL_DEPTH_BUFFER_BIT); redraw(); + } }
