--- ray/src/hd/rhd_glx.c 1997/12/26 21:56:43 3.8 +++ ray/src/hd/rhd_glx.c 1998/08/25 18:11:17 3.22 @@ -1,4 +1,4 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ +/* Copyright (c) 1998 Silicon Graphics, Inc. */ #ifndef lint static char SCCSid[] = "$SunId$ SGI"; @@ -6,33 +6,43 @@ static char SCCSid[] = "$SunId$ SGI"; /* * OpenGL GLX driver for holodeck display. - * Based on x11 driver. + * Based on old GLX driver using cones. + * + * Define symbol STEREO for stereo viewing. + * Define symbol DOBJ for display object viewing. */ +#ifdef NOSTEREO +#ifdef STEREO +#undef STEREO +#else +#undef NOSTEREO +#endif +#endif + #include "standard.h" -#include "rhd_qtree.h" +#include "rhd_sample.h" -#include +#include +#include +#include +#ifdef STEREO +#include +#endif +#ifdef DOBJ +#include "rhdobj.h" +#endif -#include "x11icon.h" +#include "x11icon.h" +#ifndef RAYQLEN +#define RAYQLEN 250 /* max. rays to queue before flush */ +#endif + #ifndef FEQ #define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY) #endif -#ifndef MAXCONE -#define MAXCONE 16 /* number of different cone sizes */ -#endif -#ifndef MAXVERT -#define MAXVERT 32 /* maximum number of cone vertices */ -#endif -#ifndef MINVERT -#define MINVERT 4 /* minimum number of cone vertices */ -#endif -#ifndef DEPTHFACT -#define DEPTHFACT 16. /* multiplier for depth tests */ -#endif - #define GAMMA 1.4 /* default gamma correction */ #define MOVPCT 7 /* percent distance to move /frame */ @@ -40,6 +50,10 @@ static char SCCSid[] = "$SunId$ SGI"; #define MOVDEG (-5) /* degrees to orbit CW/down /frame */ #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0) +#ifndef TARGETFPS +#define TARGETFPS 4.0 /* target frames/sec during motion */ +#endif + #define MINWIDTH 480 /* minimum graphics window width */ #define MINHEIGHT 400 /* minimum graphics window height */ @@ -47,6 +61,10 @@ static char SCCSid[] = "$SunId$ SGI"; #define BORWIDTH 5 /* border width */ +#define setstereobuf(bid) (glXWaitGL(), \ + XSGISetStereoBuffer(ourdisplay, gwind, bid), \ + glXWaitX()) + #define ourscreen DefaultScreen(ourdisplay) #define ourroot RootWindow(ourdisplay,ourscreen) #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\ @@ -56,6 +74,10 @@ static char SCCSid[] = "$SunId$ SGI"; struct driver odev; /* global device driver structure */ +static VIEW vwright; /* right eye view */ + +static int rayqleft = 0; /* rays left to queue before flush */ + static XEvent currentevent; /* current event */ static int mapped = 0; /* window is mapped? */ @@ -68,42 +90,60 @@ static GLXContext gctx; /* our GLX context */ static double pwidth, pheight; /* pixel dimensions (mm) */ -static double curzmax = 1e4; /* current depth upper limit */ -static double nxtzmax = 0.; /* maximum (finite) depth so far */ +static double mindpth, maxdpth; /* min. and max. depth */ -static struct { - double rad; /* cone radius */ - int nverts; /* number of vertices */ - FVECT *va; /* allocated vertex array */ -} cone[MAXCONE]; /* precomputed cones for drawing */ +double dev_zmin, dev_zmax; /* fore and aft clipping plane dist. */ static int inpresflags; /* input result flags */ static int headlocked = 0; /* lock vertical motion */ -static int resizewindow(), getevent(), getkey(), moveview(), - initcones(), freecones(), - getmove(), fixwindow(), mytmflags(); +static int resizewindow(), getevent(), getkey(), moveview(), wipeclean(), + setglpersp(), getmove(), fixwindow(), mytmflags(); +#ifdef STEREO +static int pushright(), popright(); +#endif -dev_open(id) /* initialize X11 driver */ +extern time_t time(); + + +dev_open(id) /* initialize GLX driver */ char *id; { extern char *getenv(); + static RGBPRIMS myprims = STDPRIMS; static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,8, GLX_GREEN_SIZE,8, GLX_BLUE_SIZE,8, GLX_DEPTH_SIZE,15, None}; - char *gv; + char *ev; double gamval = GAMMA; + RGBPRIMP dpri = stdprims; XSetWindowAttributes ourwinattr; XWMHints ourxwmhints; XSizeHints oursizhints; - /* set quadtree globals */ - qtMinNodesiz = 3; + /* check for unsupported stereo */ +#ifdef NOSTEREO + error(INTERNAL, "stereo display driver unavailable"); +#endif /* open display server */ ourdisplay = XOpenDisplay(NULL); if (ourdisplay == NULL) error(USER, "cannot open X-windows; DISPLAY variable set?\n"); +#ifdef STEREO + switch (XSGIQueryStereoMode(ourdisplay, ourroot)) { + case STEREO_TOP: + case STEREO_BOTTOM: + break; + case STEREO_OFF: + error(USER, + "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first"); + case X_STEREO_UNSUPPORTED: + error(USER, "stereo mode not supported on this screen"); + default: + error(INTERNAL, "unknown stereo mode"); + } +#endif /* find a usable visual */ ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest); if (ourvinf == NULL) @@ -111,10 +151,17 @@ char *id; /* get a context */ gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE); /* set gamma and tone mapping */ - if ((gv = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL - || (gv = getenv("DISPLAY_GAMMA")) != NULL) - gamval = atof(gv); - if (tmInit(mytmflags(), stdprims, gamval) == NULL) + if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL + || (ev = getenv("DISPLAY_GAMMA")) != NULL) + gamval = atof(ev); + if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL && + sscanf(ev, "%f %f %f %f %f %f %f %f", + &myprims[RED][CIEX],&myprims[RED][CIEY], + &myprims[GRN][CIEX],&myprims[GRN][CIEY], + &myprims[BLU][CIEX],&myprims[BLU][CIEY], + &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6) + dpri = myprims; + if (tmInit(mytmflags(), dpri, gamval) == NULL) error(SYSTEM, "not enough memory in dev_open"); /* open window */ ourwinattr.background_pixel = ourblack; @@ -125,7 +172,11 @@ char *id; ourvinf->visual, AllocNone); gwind = XCreateWindow(ourdisplay, ourroot, 0, 0, DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH, +#ifdef STEREO + (DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH)/2, +#else DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH, +#endif BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual, CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr); if (gwind == 0) @@ -138,63 +189,82 @@ char *id; gwind, x11icon_bits, x11icon_width, x11icon_height); XSetWMHints(ourdisplay, gwind, &ourxwmhints); oursizhints.min_width = MINWIDTH; +#ifdef STEREO + oursizhints.min_height = MINHEIGHT/2; + oursizhints.max_width = DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH; + oursizhints.max_height = (DisplayHeight(ourdisplay,ourscreen) - + 2*BORWIDTH)/2; + oursizhints.flags = PMinSize|PMaxSize; +#else oursizhints.min_height = MINHEIGHT; oursizhints.flags = PMinSize; +#endif XSetNormalHints(ourdisplay, gwind, &oursizhints); /* set GLX context */ glXMakeCurrent(ourdisplay, gwind, gctx); glEnable(GL_DEPTH_TEST); glDepthFunc(GL_LEQUAL); - glShadeModel(GL_FLAT); + glShadeModel(GL_SMOOTH); glDisable(GL_DITHER); glDisable(GL_CULL_FACE); - glMatrixMode(GL_PROJECTION); - glOrtho(0., 1., 0., 1., -.01, 1.01); - glTranslated(0., 0., -1.01); /* figure out sensible view */ pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) / DisplayWidth(ourdisplay, ourscreen); pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) / DisplayHeight(ourdisplay, ourscreen); +#ifdef STEREO + pheight *= 2.; + setstereobuf(STEREO_BUFFER_LEFT); +#endif copystruct(&odev.v, &stdview); odev.v.type = VT_PER; /* map the window */ XMapWindow(ourdisplay, gwind); dev_input(); /* sets size and view angles */ - /* allocate our leaf pile */ - if (!qtAllocLeaves(2 * DisplayWidth(ourdisplay,ourscreen) * - DisplayHeight(ourdisplay,ourscreen) / - (qtMinNodesiz*qtMinNodesiz))) + /* allocate our samples */ + if (!smInit(DisplayWidth(ourdisplay,ourscreen) * + DisplayHeight(ourdisplay,ourscreen) / 10)) error(SYSTEM, "insufficient memory for value storage"); + mindpth = FHUGE; maxdpth = FTINY; odev.name = id; odev.ifd = ConnectionNumber(ourdisplay); - /* initialize cone array */ - initcones(); } dev_close() /* close our display and free resources */ { + smInit(0); +#ifdef DOBJ + dobj_cleanup(); +#endif glXMakeCurrent(ourdisplay, None, NULL); glXDestroyContext(ourdisplay, gctx); XDestroyWindow(ourdisplay, gwind); gwind = 0; XCloseDisplay(ourdisplay); ourdisplay = NULL; - qtFreeLeaves(); tmDone(NULL); - freecones(); odev.v.type = 0; odev.hres = odev.vres = 0; odev.ifd = -1; } +dev_clear() /* clear our representation */ +{ + smInit(rsL.max_samp); + wipeclean(); + rayqleft = 0; /* hold off update */ +} + + int dev_view(nv) /* assign new driver view */ register VIEW *nv; { - if (nv->type == VT_PAR || /* check view legality */ + double d; + + if (nv->type != VT_PER || /* check view legality */ nv->horiz > 160. || nv->vert > 160.) { error(COMMAND, "illegal view type/angle"); nv->type = odev.v.type; @@ -202,19 +272,18 @@ register VIEW *nv; nv->vert = odev.v.vert; return(0); } - if (nv->vfore > FTINY) { - error(COMMAND, "cannot handle fore clipping"); - nv->vfore = 0.; - return(0); - } if (nv != &odev.v) { - if (!FEQ(nv->horiz,odev.v.horiz) || /* resize window? */ + /* resize window? */ + if (!FEQ(nv->horiz,odev.v.horiz) || !FEQ(nv->vert,odev.v.vert)) { int dw = DisplayWidth(ourdisplay,ourscreen); int dh = DisplayHeight(ourdisplay,ourscreen); dw -= 25; /* for window frame */ dh -= 50; +#ifdef STEREO + dh /= 2; +#endif odev.hres = 2.*VIEWDIST/pwidth * tan(PI/180./2.*nv->horiz); odev.vres = 2.*VIEWDIST/pheight * @@ -230,18 +299,47 @@ register VIEW *nv; XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres); dev_input(); /* get resize event */ } - copystruct(&odev.v, nv); + copystruct(&odev.v, nv); /* setview() already called */ +#ifdef STEREO + copystruct(&vwright, nv); + d = eyesepdist / sqrt(nv->hn2); + VSUM(vwright.vp, nv->vp, nv->hvec, d); + /* setview(&vwright); -- Unnecessary */ +#endif } - if (nxtzmax > FTINY) { - curzmax = nxtzmax; - nxtzmax = 0.; - } - glClear(GL_DEPTH_BUFFER_BIT); - qtReplant(); + wipeclean(); return(1); } +dev_auxcom(cmd, args) /* process an auxiliary command */ +char *cmd, *args; +{ +#ifdef DOBJ + if (dobj_command(cmd, args) >= 0) + return; +#endif + sprintf(errmsg, "%s: unknown command", cmd); + error(COMMAND, errmsg); +} + + +VIEW * +dev_auxview(n, hvres) /* return nth auxiliary view */ +int n; +int hvres[2]; +{ + hvres[0] = odev.hres; hvres[1] = odev.vres; + if (n == 0) + return(&odev.v); +#ifdef STEREO + if (n == 1) + return(&vwright); +#endif + return(NULL); +} + + int dev_input() /* get X11 input */ { @@ -250,57 +348,106 @@ dev_input() /* get X11 input */ do getevent(); - while (XQLength(ourdisplay) > 0); + while (XPending(ourdisplay) > 0); + odev.inpready = 0; + return(inpresflags); } +dev_value(c, d, p) /* add a pixel value to our mesh */ +COLR c; +FVECT d, p; +{ + double depth; +#ifdef DOBJ + if (dobj_lightsamp != NULL) { /* in light source sampling */ + (*dobj_lightsamp)(c, d, p); + return; + } +#endif + if (p != NULL) { /* add depth to our range */ + depth = (p[0] - odev.v.vp[0])*d[0] + + (p[1] - odev.v.vp[1])*d[1] + + (p[2] - odev.v.vp[2])*d[2]; + if (depth > FTINY) { + if (depth < mindpth) + mindpth = depth; + if (depth > maxdpth) + maxdpth = depth; + } + } + smNewSamp(c, d, p); /* add to display representation */ + if (!--rayqleft) + dev_flush(); /* flush output */ +} + + int dev_flush() /* flush output */ { - qtUpdate(); - glFlush(); - return(XPending(ourdisplay)); + if (mapped) { +#ifdef STEREO + pushright(); /* update right eye */ + glClear(GL_DEPTH_BUFFER_BIT); + smUpdate(&vwright, 100); +#ifdef DOBJ + dobj_render(); /* usually in foreground */ +#endif + popright(); /* update left eye */ + glClear(GL_DEPTH_BUFFER_BIT); +#endif + smUpdate(&odev.v, 100); + checkglerr("rendering mesh"); +#ifdef DOBJ + dobj_render(); +#endif + glFlush(); /* flush OGL */ + } + rayqleft = RAYQLEN; + /* flush X11 and return # pending */ + return(odev.inpready = XPending(ourdisplay)); } -dev_cone(rgb, ip, rad) /* render a cone in view coordinates */ -BYTE rgb[3]; -FVECT ip; -double rad; +checkglerr(where) /* check for GL or GLU error */ +char *where; { - register int ci, j; - double apexh, basez; - /* compute apex height (0. to 1.) */ - if (ip[2] > 1e6) - apexh = 1. - 1./DEPTHFACT; - else { - if (ip[2] > nxtzmax) - nxtzmax = ip[2]; - if (ip[2] >= curzmax) - apexh = 1. - 1./DEPTHFACT; - else - apexh = 1. - ip[2]/(curzmax*DEPTHFACT); + register GLenum errcode; + + while ((errcode = glGetError()) != GL_NO_ERROR) { + sprintf(errmsg, "OpenGL error %s: %s", + where, gluErrorString(errcode)); + error(WARNING, errmsg); } - rad *= 1.25; /* find conservative cone match */ - for (ci = 0; ci < MAXCONE-1; ci++) - if (cone[ci].rad >= rad) - break; - /* draw it */ - glColor3ub(rgb[0], rgb[1], rgb[2]); - glBegin(GL_TRIANGLE_FAN); - glVertex3d(ip[0], ip[1], apexh); /* start with apex */ - basez = apexh*cone[ci].va[0][2]; /* base z's all the same */ - for (j = 0; j < cone[ci].nverts; j++) /* draw each face */ - glVertex3d(ip[0]+cone[ci].va[j][0], ip[1]+cone[ci].va[j][1], - basez); - /* connect last to first */ - glVertex3d(ip[0]+cone[ci].va[0][0], ip[1]+cone[ci].va[0][1], basez); - glEnd(); /* all done */ } +#ifdef STEREO +static +pushright() /* push on right view */ +{ + double d; + + setstereobuf(STEREO_BUFFER_RIGHT); + glMatrixMode(GL_MODELVIEW); + glPushMatrix(); + d = -eyesepdist / sqrt(odev.v.hn2); + glTranslated(d*odev.v.hvec[0], d*odev.v.hvec[1], d*odev.v.hvec[2]); +} + + +static +popright() /* pop off right view */ +{ + glMatrixMode(GL_MODELVIEW); + glPopMatrix(); + setstereobuf(STEREO_BUFFER_LEFT); +} +#endif + + static int mytmflags() /* figure out tone mapping flags */ { @@ -312,56 +459,14 @@ mytmflags() /* figure out tone mapping flags */ tail = cp+1; for (cp = tail; *cp && *cp != '.'; cp++) ; - if (cp-tail == 3 && !strncmp(tail, "glx", 3)) - return(TM_F_CAMERA); - if (cp-tail == 4 && !strncmp(tail, "glxh", 4)) - return(TM_F_HUMAN); - error(USER, "illegal driver name"); + if (cp > tail && cp[-1] == 'h') + return(TM_F_HUMAN|TM_F_NOSTDERR); + else + return(TM_F_CAMERA|TM_F_NOSTDERR); } static -initcones() /* initialize cone vertices */ -{ - register int i, j; - double minrad, d; - - if (cone[0].nverts) - freecones(); - minrad = 2.*qtMinNodesiz/(double)(DisplayWidth(ourdisplay,ourscreen) + - DisplayHeight(ourdisplay,ourscreen)); - for (i = 0; i < MAXCONE; i++) { - d = (double)i/(MAXCONE-1); d *= d; /* x^2 distribution */ - cone[i].rad = minrad + (1.-minrad)*d; - cone[i].nverts = MINVERT + (MAXVERT-MINVERT)*d; - cone[i].va = (FVECT *)malloc(cone[i].nverts*sizeof(FVECT)); - if (cone[i].va == NULL) - error(SYSTEM, "out of memory in initcones"); - for (j = cone[i].nverts; j--; ) { - d = 2.*PI * (j+.5) / (cone[i].nverts); - cone[i].va[j][0] = cos(d) * cone[i].rad; - cone[i].va[j][1] = sin(d) * cone[i].rad; - cone[i].va[j][2] = 1. - cone[i].rad; - } - } -} - - -static -freecones() /* free cone vertices */ -{ - register int i; - - for (i = MAXCONE; i--; ) - if (cone[i].nverts) { - free((char *)cone[i].va); - cone[i].va = NULL; - cone[i].nverts = 0; - } -} - - -static getevent() /* get next event */ { XNextEvent(ourdisplay, levptr(XEvent)); @@ -398,50 +503,18 @@ register FVECT wp[2]; static -draw_grids() /* draw holodeck section grids */ +draw_grids(fore) /* draw holodeck section grids */ +int fore; { - static BYTE gridrgba[4] = {0x0, 0xff, 0xff, 0x00}; - double xmin, xmax, ymin, ymax, zmin, zmax; - double d, cx, sx, crad; - FVECT vx, vy; - register int i, j; - /* can we even do it? */ - if (!mapped || odev.v.type != VT_PER) + if (!mapped) return; - /* compute view frustum */ - if (normalize(odev.v.vdir) == 0.0) - return; - zmin = 0.01; - zmax = 10000.; - if (odev.v.vfore > FTINY) - zmin = odev.v.vfore; - if (odev.v.vaft > FTINY) - zmax = odev.v.vaft; - xmax = zmin * tan(PI/180./2. * odev.v.horiz); - xmin = -xmax; - d = odev.v.hoff * (xmax - xmin); - xmin += d; xmax += d; - ymax = zmin * tan(PI/180./2. * odev.v.vert); - ymin = -ymax; - d = odev.v.voff * (ymax - ymin); - ymin += d; ymax += d; - /* set view matrix */ - glMatrixMode(GL_PROJECTION); - glPushMatrix(); - glLoadIdentity(); - glFrustum(xmin, xmax, ymin, ymax, zmin, zmax); - gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2], - odev.v.vp[0] + odev.v.vdir[0], - odev.v.vp[1] + odev.v.vdir[1], - odev.v.vp[2] + odev.v.vdir[2], - odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]); - glDisable(GL_DEPTH_TEST); /* write no depth values */ - glColor4ub(gridrgba[0], gridrgba[1], gridrgba[2], gridrgba[3]); + if (fore) + glColor4ub(0, 255, 255, 0); + else + glColor4ub(0, 0, 0, 0); glBegin(GL_LINES); /* draw each grid line */ gridlines(draw3dline); glEnd(); - glEnable(GL_DEPTH_TEST); /* restore rendering params */ - glPopMatrix(); } @@ -450,31 +523,45 @@ moveview(dx, dy, mov, orb) /* move our view */ int dx, dy, mov, orb; { VIEW nv; - FVECT odir, v1; + FVECT odir, v1, wip; double d; register int li; /* start with old view */ copystruct(&nv, &odev.v); - /* change view direction */ - if (mov | orb) { - if ((li = qtFindLeaf(dx, dy)) < 0) + /* orient our motion */ + if (viewray(v1, odir, &odev.v, + (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY) + return(0); /* outside view */ + if (mov | orb) { /* moving relative to geometry */ +#ifdef DOBJ + d = dobj_trace(NULL, v1, odir); /* check objects */ + /* check holodeck */ + if ((li = smFindSamp(v1, odir)) >= 0) { + VCOPY(wip, rsL.wp[li]); + if (d < .99*FHUGE && d*d <= dist2(v1, wip)) + li = -1; /* object is closer */ + } else if (d >= .99*FHUGE) + return(0); /* nothing visible */ + if (li < 0) + VSUM(wip, v1, odir, d); /* else get object point */ +#else + if ((li = smFindSamp(v1, odir)) < 0) return(0); /* not on window */ - VSUM(odir, qtL.wp[li], nv.vp, -1.); - } else { - if (viewray(nv.vp, nv.vdir, &odev.v, - (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY) - return(0); /* outside view */ - } + VCOPY(wip, rsL.wp[li]); +#endif + VSUM(odir, wip, odev.v.vp, -1.); + } else /* panning with constant viewpoint */ + VCOPY(nv.vdir, odir); if (orb && mov) { /* orbit left/right */ spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov); - VSUM(nv.vp, qtL.wp[li], odir, -1.); + VSUM(nv.vp, wip, odir, -1.); spinvector(nv.vdir, nv.vdir, nv.vup, d); } else if (orb) { /* orbit up/down */ fcross(v1, odir, nv.vup); if (normalize(v1) == 0.) return(0); spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb); - VSUM(nv.vp, qtL.wp[li], odir, -1.); + VSUM(nv.vp, wip, odir, -1.); spinvector(nv.vdir, nv.vdir, v1, d); } else if (mov) { /* move forward/backward */ d = MOVPCT/100. * mov; @@ -482,7 +569,7 @@ int dx, dy, mov, orb; } if (!mov ^ !orb && headlocked) { /* restore head height */ VSUM(v1, odev.v.vp, nv.vp, -1.); - d = DOT(v1, odev.v.vup); + d = DOT(v1, nv.vup); VSUM(nv.vp, nv.vp, odev.v.vup, d); } if (setview(&nv) != NULL) @@ -499,14 +586,16 @@ XButtonPressedEvent *ebut; { int movdir = MOVDIR(ebut->button); int movorb = MOVORB(ebut->state); - int oldnodesiz = qtMinNodesiz; + int qlevel = 99; + time_t lasttime, thistime; + int nframes; Window rootw, childw; int rootx, rooty, wx, wy; unsigned int statemask; - qtMinNodesiz = 24; /* accelerate update rate */ XNoOp(ourdisplay); + lasttime = time(0); nframes = 0; while (!XCheckMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent))) { @@ -514,14 +603,45 @@ XButtonPressedEvent *ebut; &rootx, &rooty, &wx, &wy, &statemask)) break; /* on another screen */ + draw_grids(0); /* clear old grid lines */ if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) { sleep(1); + lasttime++; continue; } - glClear(GL_COLOR_BUFFER_BIT); - qtUpdate(); - draw_grids(); +#ifdef STEREO + pushright(); + draw_grids(1); + smUpdate(&vwright, qlevel); +#ifdef DOBJ + dobj_render(); +#endif + popright(); +#endif + draw_grids(1); + smUpdate(&odev.v, qlevel); +#ifdef DOBJ + dobj_render(); +#endif glFlush(); + checkglerr("moving view"); + nframes++; + thistime = time(0); + if (thistime - lasttime >= 3 || + nframes > (int)(3*3*TARGETFPS)) { + qlevel = thistime<=lasttime ? 1000 : + (int)((double)nframes/(thistime-lasttime) + / TARGETFPS * qlevel + 0.5); + lasttime = thistime; nframes = 0; + if (qlevel > 99) { + if (qlevel > 300) { /* put on the brakes */ + sleep(1); + lasttime++; + } + qlevel = 99; + } else if (qlevel < 1) + qlevel = 1; + } } if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */ movdir = MOVDIR(levptr(XButtonReleasedEvent)->button); @@ -529,13 +649,66 @@ XButtonPressedEvent *ebut; wy = levptr(XButtonReleasedEvent)->y; moveview(wx, odev.vres-1-wy, movdir, movorb); } - dev_flush(); +} - qtMinNodesiz = oldnodesiz; /* restore quadtree resolution */ + +static +setglpersp(vp) /* set perspective view in GL */ +register VIEW *vp; +{ + double d, xmin, xmax, ymin, ymax; + + if (mindpth >= maxdpth) { + dev_zmin = 0.1; + dev_zmax = 100.; + } else { + dev_zmin = 0.5*mindpth; + dev_zmax = 1.5*maxdpth; + if (dev_zmin > dev_zmax/100.) + dev_zmin = dev_zmax/100.; + } + if (odev.v.vfore > FTINY) + dev_zmin = odev.v.vfore; + if (odev.v.vaft > FTINY) + dev_zmax = odev.v.vaft; + if (dev_zmin < dev_zmax/5000.) + dev_zmin = dev_zmax/5000.; + xmax = dev_zmin * tan(PI/180./2. * odev.v.horiz); + xmin = -xmax; + d = odev.v.hoff * (xmax - xmin); + xmin += d; xmax += d; + ymax = dev_zmin * tan(PI/180./2. * odev.v.vert); + ymin = -ymax; + d = odev.v.voff * (ymax - ymin); + ymin += d; ymax += d; + /* set view matrix */ + glMatrixMode(GL_PROJECTION); + glLoadIdentity(); + glFrustum(xmin, xmax, ymin, ymax, dev_zmin, dev_zmax); + gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2], + odev.v.vp[0] + odev.v.vdir[0], + odev.v.vp[1] + odev.v.vdir[1], + odev.v.vp[2] + odev.v.vdir[2], + odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]); } static +wipeclean() /* prepare for redraw */ +{ + /* clear depth buffer */ +#ifdef STEREO + setstereobuf(STEREO_BUFFER_RIGHT); + glClear(GL_DEPTH_BUFFER_BIT); + setstereobuf(STEREO_BUFFER_LEFT); +#endif + glClear(GL_DEPTH_BUFFER_BIT); + smClean(); /* reset drawing routines */ + setglpersp(&odev.v); /* reset view & clipping planes */ +} + + +static getkey(ekey) /* get input key */ register XKeyPressedEvent *ekey; { @@ -566,25 +739,26 @@ register XKeyPressedEvent *ekey; inpresflags |= DFL(DC_RESUME); return; case CTRL('R'): /* redraw screen */ - if (nxtzmax > FTINY) { - curzmax = nxtzmax; - nxtzmax = 0.; - } - glClear(GL_DEPTH_BUFFER_BIT); - qtRedraw(0, 0, odev.hres, odev.vres); + wipeclean(); return; case CTRL('L'): /* refresh from server */ if (inpresflags & DFL(DC_REDRAW)) return; - if (nxtzmax > FTINY) { - curzmax = nxtzmax; - nxtzmax = 0.; - } glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); - draw_grids(); + glDisable(GL_DEPTH_TEST); + draw_grids(1); +#ifdef STEREO + pushright(); + glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); + draw_grids(1); + popright(); +#endif + glEnable(GL_DEPTH_TEST); glFlush(); - qtCompost(100); /* get rid of old values */ + smInit(rsL.max_samp); /* get rid of old values */ inpresflags |= DFL(DC_REDRAW); /* resend values from server */ + setglpersp(&odev.v); /* reset clipping planes */ + rayqleft = 0; /* hold off update */ return; case 'K': /* kill rtrace process(es) */ inpresflags |= DFL(DC_KILL); @@ -609,24 +783,13 @@ static fixwindow(eexp) /* repair damage to window */ register XExposeEvent *eexp; { - int xmin, xmax, ymin, ymax; - - if (odev.hres == 0 || odev.vres == 0) /* first exposure */ + if (odev.hres == 0 | odev.vres == 0) { /* first exposure */ resizewindow((XConfigureEvent *)eexp); - xmin = eexp->x; xmax = eexp->x + eexp->width; - ymin = odev.vres - eexp->y - eexp->height; ymax = odev.vres - eexp->y; - /* clear portion of depth */ - glColorMask(GL_FALSE, GL_FALSE, GL_FALSE, GL_FALSE); - glDepthFunc(GL_ALWAYS); - glBegin(GL_POLYGON); - glVertex3d((double)xmin/odev.hres, (double)ymin/odev.vres, 0.); - glVertex3d((double)xmax/odev.hres, (double)ymin/odev.vres, 0.); - glVertex3d((double)xmax/odev.hres, (double)ymax/odev.vres, 0.); - glVertex3d((double)xmin/odev.hres, (double)ymax/odev.vres, 0.); - glEnd(); - glColorMask(GL_TRUE, GL_TRUE, GL_TRUE, GL_TRUE); - glDepthFunc(GL_LEQUAL); - qtRedraw(xmin, ymin, xmax, ymax); + return; + } + if (eexp->count) /* wait for final exposure */ + return; + wipeclean(); /* clear depth */ }
