--- ray/src/hd/rhd_glx.c 1998/12/28 17:58:45 3.26 +++ ray/src/hd/rhd_glx.c 2003/02/22 02:07:24 3.29 @@ -1,9 +1,6 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rhd_glx.c,v 3.29 2003/02/22 02:07:24 greg Exp $"; #endif - /* * OpenGL GLX driver for holodeck display. * Based on old GLX driver using cones. @@ -22,7 +19,6 @@ static char SCCSid[] = "$SunId$ SGI"; #include "standard.h" -#include #include #include #ifdef STEREO @@ -54,7 +50,7 @@ static char SCCSid[] = "$SunId$ SGI"; #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0) #ifndef TARGETFPS -#define TARGETFPS 4.0 /* target frames/sec during motion */ +#define TARGETFPS 2.0 /* target frames/sec during motion */ #endif #define MINWIDTH 480 /* minimum graphics window width */ @@ -111,6 +107,9 @@ static int resizewindow(), getevent(), getkey(), move #ifdef STEREO static int pushright(), popright(); #endif +static double getdistance(); +#define mapdepth(d) ((d)> 0.9995 ? FHUGE: dev_zmin/ \ + (1.-(d)*(1.-dev_zmin/dev_zmax))) extern time_t time(); @@ -261,7 +260,7 @@ dev_close() /* close our display and free resources dev_clear() /* clear our representation */ { smInit(rsL.max_samp); - wipeclean(); + wipeclean(1); rayqleft = 0; /* hold off update */ } @@ -308,14 +307,14 @@ register VIEW *nv; dev_input(); /* get resize event */ } copystruct(&odev.v, nv); /* setview() already called */ + } #ifdef STEREO - copystruct(&vwright, nv); - d = eyesepdist / sqrt(nv->hn2); - VSUM(vwright.vp, nv->vp, nv->hvec, d); - /* setview(&vwright); -- Unnecessary */ + copystruct(&vwright, nv); + d = eyesepdist / sqrt(nv->hn2); + VSUM(vwright.vp, nv->vp, nv->hvec, d); + /* setview(&vwright); -- Unnecessary */ #endif - } - wipeclean(); + wipeclean(0); return(1); } @@ -405,13 +404,13 @@ dev_flush() /* flush output */ if (mapped) { #ifdef STEREO pushright(); /* update right eye */ - smUpdate(&vwright, 100); + smUpdate(&vwright, MAXQUALITY); #ifdef DOBJ dobj_render(); /* usually in foreground */ #endif popright(); /* update left eye */ #endif - smUpdate(&odev.v, 100); + smUpdate(&odev.v, MAXQUALITY); checkglerr("rendering mesh"); #ifdef DOBJ dobj_render(); @@ -533,14 +532,31 @@ int fore; checkglerr("drawing grid lines"); } +static double +getdistance(dx, dy, direc) /* distance from fore plane along view ray */ +int dx, dy; +FVECT direc; +{ + GLfloat gldepth; + double dist; + if (dx<0 | dx>=odev.hres | dy<0 | dy>=odev.vres) + return(FHUGE); + glReadPixels(dx,dy, 1,1, GL_DEPTH_COMPONENT,GL_FLOAT, &gldepth); + dist = mapdepth(gldepth); + if (dist >= .99*FHUGE) + return(FHUGE); + return((dist-odev.v.vfore)/DOT(direc,odev.v.vdir)); +} + + static moveview(dx, dy, mov, orb) /* move our view */ int dx, dy, mov, orb; { VIEW nv; FVECT odir, v1, wip; - double d; + double d,d1; register int li; /* start with old view */ copystruct(&nv, &odev.v); @@ -549,23 +565,18 @@ int dx, dy, mov, orb; (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY) return(0); /* outside view */ if (mov | orb) { /* moving relative to geometry */ + d = getdistance(dx, dy, odir);/*distance from front plane */ #ifdef DOBJ - d = dobj_trace(NULL, v1, odir); /* check objects */ + d1 = dobj_trace(NULL, v1, odir); /* check objects */ /* check holodeck */ - if ((li = smFindSamp(v1, odir)) >= 0) { - VCOPY(wip, rsL.wp[li]); - if (d < .99*FHUGE && d*d <= dist2(v1, wip)) - li = -1; /* object is closer */ - } else if (d >= .99*FHUGE) - return(0); /* nothing visible */ - if (li < 0) - VSUM(wip, v1, odir, d); /* else get object point */ -#else - if ((li = smFindSamp(v1, odir)) < 0) - return(0); /* not on window */ - VCOPY(wip, rsL.wp[li]); + if (d1 < d) + d = d1; #endif -#ifdef DEBUG + if (d >= .99*FHUGE) + d = 0.5*(dev_zmax+dev_zmin); /* just guess */ + VSUM(wip, v1, odir, d); + VSUB(odir, wip, odev.v.vp); +#if 0 fprintf(stderr, "moveview: hit %s at (%f,%f,%f) (t=%f)\n", li < 0 ? "object" : "mesh", wip[0], wip[1], wip[2], @@ -573,7 +584,6 @@ int dx, dy, mov, orb; (wip[1]-odev.v.vp[1])*odir[1] + (wip[2]-odev.v.vp[2])*odir[2]); #endif - VSUM(odir, wip, odev.v.vp, -1.); } else /* panning with constant viewpoint */ VCOPY(nv.vdir, odir); if (orb && mov) { /* orbit left/right */ @@ -633,7 +643,7 @@ XButtonPressedEvent *ebut; { int movdir = MOVDIR(ebut->button); int movorb = MOVORB(ebut->state); - int qlevel = 99; + int qlevel = MAXQUALITY-1; time_t lasttime, thistime; int nframes; Window rootw, childw; @@ -642,7 +652,7 @@ XButtonPressedEvent *ebut; XNoOp(ourdisplay); /* makes sure we're not idle */ - lasttime = time(0); nframes = 0; + nframes = 0; while (!XCheckMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent))) { /* get cursor position */ @@ -676,20 +686,24 @@ XButtonPressedEvent *ebut; dobj_render(); /* redraw object */ #endif glFlush(); - nframes++; /* figure out good quality level */ + /* figure out good quality level */ + if (!nframes++) { /* ignore first frame */ + lasttime = time(0); + continue; + } thistime = time(0); - if (thistime - lasttime >= 3 || + if (thistime - lasttime >= 6 || nframes > (int)(3*3*TARGETFPS)) { - qlevel = thistime<=lasttime ? 1000 : + qlevel = thistime<=lasttime ? 3*MAXQUALITY : (int)((double)nframes/(thistime-lasttime) / TARGETFPS * qlevel + 0.5); - lasttime = thistime; nframes = 0; - if (qlevel > 99) { - if (qlevel > 300) { /* put on the brakes */ + nframes = 0; + if (qlevel >= MAXQUALITY) { + if (qlevel >= 3*MAXQUALITY) { /* brakes!! */ sleep(1); lasttime++; } - qlevel = 99; + qlevel = MAXQUALITY-1; } else if (qlevel < 1) qlevel = 1; } @@ -713,15 +727,15 @@ register VIEW *vp; dev_zmin = 1.; dev_zmax = 100.; } else { - dev_zmin = 0.5*mindpth; + dev_zmin = 0.1*mindpth; dev_zmax = 5.0*maxdpth; } if (odev.v.vfore > FTINY) dev_zmin = odev.v.vfore; if (odev.v.vaft > FTINY) dev_zmax = odev.v.vaft; - if (dev_zmin < dev_zmax/100.) - dev_zmin = dev_zmax/100.; + if (dev_zmin*500. < dev_zmax) + dev_zmax = dev_zmin*500.; xmax = dev_zmin * tan(PI/180./2. * odev.v.horiz); xmin = -xmax; d = odev.v.hoff * (xmax - xmin); @@ -744,7 +758,8 @@ register VIEW *vp; static -wipeclean() /* prepare for redraw */ +wipeclean(tmflag) /* prepare for redraw */ +int tmflag; { /* clear depth buffer */ #ifdef STEREO @@ -753,7 +768,7 @@ wipeclean() /* prepare for redraw */ setstereobuf(STEREO_BUFFER_LEFT); #endif glClear(GL_DEPTH_BUFFER_BIT); - smClean(); /* reset drawing routines */ + smClean(tmflag); /* reset drawing routines */ setglpersp(&odev.v); /* reset view & clipping planes */ } @@ -804,7 +819,7 @@ register XKeyPressedEvent *ekey; inpresflags |= DFL(DC_RESUME); return; case CTRL('R'): /* redraw screen */ - wipeclean(); + wipeclean(1); return; case CTRL('L'): /* refresh from server */ if (inpresflags & DFL(DC_REDRAW)) @@ -854,7 +869,7 @@ register XExposeEvent *eexp; } if (eexp->count) /* wait for final exposure */ return; - wipeclean(); /* clear depth */ + wipeclean(0); /* clear depth */ }
