Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
Implemented sample quadtree in place of triangle quadtree Made geometric predicates more robust Added #define LORES which utilizes a single precision floating point sample array, the default is a double sample array Added topology DEBUG commands (for DEBUG > 1) Made code optimizations
fixed bug in stereo view computation after window resize
New insertion routine New Culling routine based on insertion algorithm Adapted old insertion code: now used by picking Point location code returns on-vertex,on-edge, or in-triangle Added on_edge case for subdivision implemented unordered sets Removed deletion from quadtree- added set compression to replace functionality
created "frame" command to focus calculation
improved grid drawing in stereo mode
bug fixes and improved interactive drawing
changed dobj_trace() to return name of intersected object improved "show" lighting with front-directed light source changed MINTHRESH and cosmetic fixes
bug fix for window resizing
first attempt and Delaunay triangulation driver
added dev_auxcom() for auxiliary command handling
added multiple device view capability
increased number of vertices in cone approximations
added check of DISPLAY_PRIMARIES environment variable
created dev_clear() routine to clear device ray cache
delay update after ^L
added missing test for unmapped window in dev_cone()
increased leaf allocation by 50%
changed depth epsilon and reduced leaf allocation
added resetting of curzmax to ^R and ^L commands
removed unnecessary call to glClear()
fixed viewport resizing
added conservative check for cone radius
reverted to using quadtree for GLX driver
added fast redraw for mouse-controlled movement
first fully working version
