| 1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ SGI";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* OpenGL GLX driver for holodeck display.
| 9 |
* Based on x11 driver.
| 10 |
| 11 |
| 12 |
#include "standard.h"
| 13 |
#include "rhd_qtree.h"
| 14 |
| 15 |
#include <GL/glx.h>
| 16 |
| 17 |
#include "x11icon.h"
| 18 |
| 19 |
#ifndef RAYQLEN
| 20 |
#define RAYQLEN 50000 /* max. rays to queue before flush */
| 21 |
#endif
| 22 |
| 23 |
#ifndef FEQ
| 24 |
#define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY)
| 25 |
#endif
| 26 |
| 27 |
#ifndef MAXCONE
| 28 |
#define MAXCONE 16 /* number of different cone sizes */
| 29 |
#endif
| 30 |
#ifndef MAXVERT
| 31 |
#define MAXVERT 64 /* maximum number of cone vertices */
| 32 |
#endif
| 33 |
#ifndef MINVERT
| 34 |
#define MINVERT 4 /* minimum number of cone vertices */
| 35 |
#endif
| 36 |
#ifndef DEPTHFACT
| 37 |
#define DEPTHFACT 16. /* multiplier for depth tests */
| 38 |
#endif
| 39 |
| 40 |
#define GAMMA 1.4 /* default gamma correction */
| 41 |
| 42 |
#define MOVPCT 7 /* percent distance to move /frame */
| 43 |
#define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
| 44 |
#define MOVDEG (-5) /* degrees to orbit CW/down /frame */
| 45 |
#define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
| 46 |
| 47 |
#define MINWIDTH 480 /* minimum graphics window width */
| 48 |
#define MINHEIGHT 400 /* minimum graphics window height */
| 49 |
| 50 |
#define VIEWDIST 356 /* assumed viewing distance (mm) */
| 51 |
| 52 |
#define BORWIDTH 5 /* border width */
| 53 |
| 54 |
#define ourscreen DefaultScreen(ourdisplay)
| 55 |
#define ourroot RootWindow(ourdisplay,ourscreen)
| 56 |
#define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
| 57 |
ButtonPressMask|ButtonReleaseMask)
| 58 |
| 59 |
#define levptr(etype) ((etype *)¤tevent)
| 60 |
| 61 |
struct driver odev; /* global device driver structure */
| 62 |
| 63 |
static XEvent currentevent; /* current event */
| 64 |
| 65 |
static int mapped = 0; /* window is mapped? */
| 66 |
static unsigned long ourblack=0, ourwhite=~0;
| 67 |
| 68 |
static Display *ourdisplay = NULL; /* our display */
| 69 |
static XVisualInfo *ourvinf; /* our visual information */
| 70 |
static Window gwind = 0; /* our graphics window */
| 71 |
static GLXContext gctx; /* our GLX context */
| 72 |
| 73 |
static double pwidth, pheight; /* pixel dimensions (mm) */
| 74 |
| 75 |
static double curzmax = 1e4; /* current depth upper limit */
| 76 |
static double nxtzmax = 0.; /* maximum (finite) depth so far */
| 77 |
| 78 |
static struct {
| 79 |
double rad; /* cone radius */
| 80 |
int nverts; /* number of vertices */
| 81 |
FVECT *va; /* allocated vertex array */
| 82 |
} cone[MAXCONE]; /* precomputed cones for drawing */
| 83 |
| 84 |
static int inpresflags; /* input result flags */
| 85 |
| 86 |
static int headlocked = 0; /* lock vertical motion */
| 87 |
| 88 |
static int resizewindow(), getevent(), getkey(), moveview(),
| 89 |
initcones(), freecones(),
| 90 |
getmove(), fixwindow(), mytmflags();
| 91 |
| 92 |
| 93 |
dev_open(id) /* initialize X11 driver */
| 94 |
char *id;
| 95 |
| 96 |
extern char *getenv();
| 97 |
static RGBPRIMS myprims = STDPRIMS;
| 98 |
static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,8,
| 99 |
GLX_GREEN_SIZE,8, GLX_BLUE_SIZE,8,
| 100 |
GLX_DEPTH_SIZE,15, None};
| 101 |
char *ev;
| 102 |
double gamval = GAMMA;
| 103 |
RGBPRIMP dpri = stdprims;
| 104 |
XSetWindowAttributes ourwinattr;
| 105 |
XWMHints ourxwmhints;
| 106 |
XSizeHints oursizhints;
| 107 |
/* set quadtree globals */
| 108 |
qtMinNodesiz = 3;
| 109 |
qtDepthEps = 0.07;
| 110 |
/* open display server */
| 111 |
ourdisplay = XOpenDisplay(NULL);
| 112 |
if (ourdisplay == NULL)
| 113 |
error(USER, "cannot open X-windows; DISPLAY variable set?\n");
| 114 |
/* find a usable visual */
| 115 |
ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
| 116 |
if (ourvinf == NULL)
| 117 |
error(USER, "no suitable visuals available");
| 118 |
/* get a context */
| 119 |
gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
| 120 |
/* set gamma and tone mapping */
| 121 |
if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
| 122 |
|| (ev = getenv("DISPLAY_GAMMA")) != NULL)
| 123 |
gamval = atof(ev);
| 124 |
if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL &&
| 125 |
sscanf(ev, "%f %f %f %f %f %f %f %f",
| 126 |
&myprims[RED][CIEX],&myprims[RED][CIEY],
| 127 |
&myprims[GRN][CIEX],&myprims[GRN][CIEY],
| 128 |
&myprims[BLU][CIEX],&myprims[BLU][CIEY],
| 129 |
&myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6)
| 130 |
dpri = myprims;
| 131 |
if (tmInit(mytmflags(), dpri, gamval) == NULL)
| 132 |
error(SYSTEM, "not enough memory in dev_open");
| 133 |
/* open window */
| 134 |
ourwinattr.background_pixel = ourblack;
| 135 |
ourwinattr.border_pixel = ourblack;
| 136 |
ourwinattr.event_mask = ourmask;
| 137 |
/* this is stupid */
| 138 |
ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
| 139 |
ourvinf->visual, AllocNone);
| 140 |
gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
| 141 |
DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
| 142 |
DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
| 143 |
BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
| 144 |
CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
| 145 |
if (gwind == 0)
| 146 |
error(SYSTEM, "cannot create window\n");
| 147 |
XStoreName(ourdisplay, gwind, id);
| 148 |
/* set window manager hints */
| 149 |
ourxwmhints.flags = InputHint|IconPixmapHint;
| 150 |
ourxwmhints.input = True;
| 151 |
ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
| 152 |
gwind, x11icon_bits, x11icon_width, x11icon_height);
| 153 |
XSetWMHints(ourdisplay, gwind, &ourxwmhints);
| 154 |
oursizhints.min_width = MINWIDTH;
| 155 |
oursizhints.min_height = MINHEIGHT;
| 156 |
oursizhints.flags = PMinSize;
| 157 |
XSetNormalHints(ourdisplay, gwind, &oursizhints);
| 158 |
/* set GLX context */
| 159 |
glXMakeCurrent(ourdisplay, gwind, gctx);
| 160 |
glEnable(GL_DEPTH_TEST);
| 161 |
glDepthFunc(GL_LEQUAL);
| 162 |
glShadeModel(GL_FLAT);
| 163 |
glDisable(GL_DITHER);
| 164 |
glDisable(GL_CULL_FACE);
| 165 |
glMatrixMode(GL_PROJECTION);
| 166 |
glOrtho(0., 1., 0., 1., -.01, 1.01);
| 167 |
glTranslated(0., 0., -1.01);
| 168 |
/* figure out sensible view */
| 169 |
pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
| 170 |
DisplayWidth(ourdisplay, ourscreen);
| 171 |
pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
| 172 |
DisplayHeight(ourdisplay, ourscreen);
| 173 |
copystruct(&odev.v, &stdview);
| 174 |
odev.v.type = VT_PER;
| 175 |
/* map the window */
| 176 |
XMapWindow(ourdisplay, gwind);
| 177 |
dev_input(); /* sets size and view angles */
| 178 |
/* allocate our leaf pile */
| 179 |
if (!qtAllocLeaves(DisplayWidth(ourdisplay,ourscreen) *
| 180 |
DisplayHeight(ourdisplay,ourscreen) * 3 /
| 181 |
(qtMinNodesiz*qtMinNodesiz*2)))
| 182 |
error(SYSTEM, "insufficient memory for value storage");
| 183 |
odev.name = id;
| 184 |
odev.ifd = ConnectionNumber(ourdisplay);
| 185 |
/* initialize cone array */
| 186 |
initcones();
| 187 |
| 188 |
| 189 |
| 190 |
dev_close() /* close our display and free resources */
| 191 |
| 192 |
glXMakeCurrent(ourdisplay, None, NULL);
| 193 |
glXDestroyContext(ourdisplay, gctx);
| 194 |
XDestroyWindow(ourdisplay, gwind);
| 195 |
gwind = 0;
| 196 |
XCloseDisplay(ourdisplay);
| 197 |
ourdisplay = NULL;
| 198 |
qtFreeLeaves();
| 199 |
tmDone(NULL);
| 200 |
freecones();
| 201 |
odev.v.type = 0;
| 202 |
odev.hres = odev.vres = 0;
| 203 |
odev.ifd = -1;
| 204 |
| 205 |
| 206 |
| 207 |
dev_clear() /* clear our quadtree */
| 208 |
| 209 |
qtCompost(100);
| 210 |
glClear(GL_DEPTH_BUFFER_BIT);
| 211 |
rayqleft = 0; /* hold off update */
| 212 |
| 213 |
| 214 |
| 215 |
int
| 216 |
dev_view(nv) /* assign new driver view */
| 217 |
register VIEW *nv;
| 218 |
| 219 |
if (nv->type == VT_PAR || /* check view legality */
| 220 |
nv->horiz > 160. || nv->vert > 160.) {
| 221 |
error(COMMAND, "illegal view type/angle");
| 222 |
nv->type = odev.v.type;
| 223 |
nv->horiz = odev.v.horiz;
| 224 |
nv->vert = odev.v.vert;
| 225 |
return(0);
| 226 |
| 227 |
if (nv->vfore > FTINY) {
| 228 |
error(COMMAND, "cannot handle fore clipping");
| 229 |
nv->vfore = 0.;
| 230 |
return(0);
| 231 |
| 232 |
if (nv != &odev.v) {
| 233 |
if (!FEQ(nv->horiz,odev.v.horiz) || /* resize window? */
| 234 |
!FEQ(nv->vert,odev.v.vert)) {
| 235 |
int dw = DisplayWidth(ourdisplay,ourscreen);
| 236 |
int dh = DisplayHeight(ourdisplay,ourscreen);
| 237 |
| 238 |
dw -= 25; /* for window frame */
| 239 |
dh -= 50;
| 240 |
odev.hres = 2.*VIEWDIST/pwidth *
| 241 |
tan(PI/180./2.*nv->horiz);
| 242 |
odev.vres = 2.*VIEWDIST/pheight *
| 243 |
tan(PI/180./2.*nv->vert);
| 244 |
if (odev.hres > dw) {
| 245 |
odev.vres = dw * odev.vres / odev.hres;
| 246 |
odev.hres = dw;
| 247 |
| 248 |
if (odev.vres > dh) {
| 249 |
odev.hres = dh * odev.hres / odev.vres;
| 250 |
odev.vres = dh;
| 251 |
| 252 |
XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres);
| 253 |
dev_input(); /* get resize event */
| 254 |
| 255 |
copystruct(&odev.v, nv);
| 256 |
| 257 |
if (nxtzmax > FTINY) {
| 258 |
curzmax = nxtzmax;
| 259 |
nxtzmax = 0.;
| 260 |
| 261 |
| 262 |
qtReplant();
| 263 |
return(1);
| 264 |
| 265 |
| 266 |
| 267 |
VIEW *
| 268 |
dev_auxview(n, hvres) /* return nth auxiliary view */
| 269 |
int n;
| 270 |
int hvres[2];
| 271 |
| 272 |
if (n)
| 273 |
return(NULL);
| 274 |
hvres[0] = odev.hres; hvres[1] = odev.vres;
| 275 |
return(&odev.v);
| 276 |
| 277 |
| 278 |
| 279 |
int
| 280 |
dev_input() /* get X11 input */
| 281 |
| 282 |
inpresflags = 0;
| 283 |
| 284 |
do
| 285 |
getevent();
| 286 |
| 287 |
while (XQLength(ourdisplay) > 0);
| 288 |
| 289 |
return(inpresflags);
| 290 |
| 291 |
| 292 |
| 293 |
int
| 294 |
dev_flush() /* flush output */
| 295 |
| 296 |
qtUpdate();
| 297 |
glFlush();
| 298 |
rayqleft = RAYQLEN;
| 299 |
return(XPending(ourdisplay));
| 300 |
| 301 |
| 302 |
| 303 |
dev_cone(rgb, ip, rad) /* render a cone in view coordinates */
| 304 |
BYTE rgb[3];
| 305 |
FVECT ip;
| 306 |
double rad;
| 307 |
| 308 |
register int ci, j;
| 309 |
double apexh, basez;
| 310 |
/* is window mapped? */
| 311 |
if (!mapped)
| 312 |
return;
| 313 |
/* compute apex height (0. to 1.) */
| 314 |
if (ip[2] > 1e6)
| 315 |
apexh = 1. - 1./DEPTHFACT;
| 316 |
else {
| 317 |
if (ip[2] > nxtzmax)
| 318 |
nxtzmax = ip[2];
| 319 |
if (ip[2] >= curzmax)
| 320 |
| 321 |
else
| 322 |
apexh = 1. - ip[2]/(curzmax*DEPTHFACT);
| 323 |
| 324 |
rad *= 1.25; /* find conservative cone match */
| 325 |
for (ci = 0; ci < MAXCONE-1; ci++)
| 326 |
if (cone[ci].rad >= rad)
| 327 |
break;
| 328 |
/* draw it */
| 329 |
glColor3ub(rgb[0], rgb[1], rgb[2]);
| 330 |
glBegin(GL_TRIANGLE_FAN);
| 331 |
glVertex3d(ip[0], ip[1], apexh); /* start with apex */
| 332 |
basez = apexh*cone[ci].va[0][2]; /* base z's all the same */
| 333 |
for (j = 0; j < cone[ci].nverts; j++) /* draw each face */
| 334 |
glVertex3d(ip[0]+cone[ci].va[j][0], ip[1]+cone[ci].va[j][1],
| 335 |
basez);
| 336 |
/* connect last to first */
| 337 |
glVertex3d(ip[0]+cone[ci].va[0][0], ip[1]+cone[ci].va[0][1], basez);
| 338 |
glEnd(); /* all done */
| 339 |
| 340 |
| 341 |
| 342 |
static int
| 343 |
mytmflags() /* figure out tone mapping flags */
| 344 |
| 345 |
extern char *progname;
| 346 |
register char *cp, *tail;
| 347 |
/* find basic name */
| 348 |
for (cp = tail = progname; *cp; cp++)
| 349 |
if (*cp == '/')
| 350 |
tail = cp+1;
| 351 |
for (cp = tail; *cp && *cp != '.'; cp++)
| 352 |
| 353 |
if (cp-tail == 3 && !strncmp(tail, "glx", 3))
| 354 |
return(TM_F_CAMERA|TM_F_NOSTDERR);
| 355 |
if (cp-tail == 4 && !strncmp(tail, "glxh", 4))
| 356 |
return(TM_F_HUMAN|TM_F_NOSTDERR);
| 357 |
error(USER, "illegal driver name");
| 358 |
| 359 |
| 360 |
| 361 |
static
| 362 |
initcones() /* initialize cone vertices */
| 363 |
| 364 |
register int i, j;
| 365 |
double minrad, d;
| 366 |
| 367 |
if (cone[0].nverts)
| 368 |
freecones();
| 369 |
minrad = 2.*qtMinNodesiz/(double)(DisplayWidth(ourdisplay,ourscreen) +
| 370 |
DisplayHeight(ourdisplay,ourscreen));
| 371 |
for (i = 0; i < MAXCONE; i++) {
| 372 |
d = (double)i/(MAXCONE-1); d *= d; /* x^2 distribution */
| 373 |
cone[i].rad = minrad + (1.-minrad)*d;
| 374 |
cone[i].nverts = MINVERT + 0.5 + (MAXVERT-MINVERT)*d;
| 375 |
cone[i].va = (FVECT *)malloc(cone[i].nverts*sizeof(FVECT));
| 376 |
if (cone[i].va == NULL)
| 377 |
error(SYSTEM, "out of memory in initcones");
| 378 |
for (j = cone[i].nverts; j--; ) {
| 379 |
d = 2.*PI * (j+.5) / (cone[i].nverts);
| 380 |
cone[i].va[j][0] = cos(d) * cone[i].rad;
| 381 |
cone[i].va[j][1] = sin(d) * cone[i].rad;
| 382 |
cone[i].va[j][2] = 1. - cone[i].rad;
| 383 |
| 384 |
| 385 |
| 386 |
| 387 |
| 388 |
static
| 389 |
freecones() /* free cone vertices */
| 390 |
| 391 |
register int i;
| 392 |
| 393 |
for (i = MAXCONE; i--; )
| 394 |
if (cone[i].nverts) {
| 395 |
free((char *)cone[i].va);
| 396 |
cone[i].va = NULL;
| 397 |
cone[i].nverts = 0;
| 398 |
| 399 |
| 400 |
| 401 |
| 402 |
static
| 403 |
getevent() /* get next event */
| 404 |
| 405 |
XNextEvent(ourdisplay, levptr(XEvent));
| 406 |
switch (levptr(XEvent)->type) {
| 407 |
case ConfigureNotify:
| 408 |
resizewindow(levptr(XConfigureEvent));
| 409 |
break;
| 410 |
case UnmapNotify:
| 411 |
mapped = 0;
| 412 |
break;
| 413 |
case MapNotify:
| 414 |
mapped = 1;
| 415 |
break;
| 416 |
case Expose:
| 417 |
fixwindow(levptr(XExposeEvent));
| 418 |
break;
| 419 |
case KeyPress:
| 420 |
getkey(levptr(XKeyPressedEvent));
| 421 |
break;
| 422 |
case ButtonPress:
| 423 |
getmove(levptr(XButtonPressedEvent));
| 424 |
break;
| 425 |
| 426 |
| 427 |
| 428 |
| 429 |
static
| 430 |
draw3dline(wp) /* draw 3d line in world coordinates */
| 431 |
register FVECT wp[2];
| 432 |
| 433 |
glVertex3d(wp[0][0], wp[0][1], wp[0][2]);
| 434 |
glVertex3d(wp[1][0], wp[1][1], wp[1][2]);
| 435 |
| 436 |
| 437 |
| 438 |
static
| 439 |
draw_grids() /* draw holodeck section grids */
| 440 |
| 441 |
static BYTE gridrgba[4] = {0x0, 0xff, 0xff, 0x00};
| 442 |
double xmin, xmax, ymin, ymax, zmin, zmax;
| 443 |
double d, cx, sx, crad;
| 444 |
FVECT vx, vy;
| 445 |
register int i, j;
| 446 |
/* can we even do it? */
| 447 |
if (!mapped || odev.v.type != VT_PER)
| 448 |
return;
| 449 |
/* compute view frustum */
| 450 |
if (normalize(odev.v.vdir) == 0.0)
| 451 |
return;
| 452 |
zmin = 0.01;
| 453 |
zmax = 10000.;
| 454 |
if (odev.v.vfore > FTINY)
| 455 |
zmin = odev.v.vfore;
| 456 |
if (odev.v.vaft > FTINY)
| 457 |
zmax = odev.v.vaft;
| 458 |
xmax = zmin * tan(PI/180./2. * odev.v.horiz);
| 459 |
xmin = -xmax;
| 460 |
d = odev.v.hoff * (xmax - xmin);
| 461 |
xmin += d; xmax += d;
| 462 |
ymax = zmin * tan(PI/180./2. * odev.v.vert);
| 463 |
ymin = -ymax;
| 464 |
d = odev.v.voff * (ymax - ymin);
| 465 |
ymin += d; ymax += d;
| 466 |
/* set view matrix */
| 467 |
| 468 |
glPushMatrix();
| 469 |
glLoadIdentity();
| 470 |
glFrustum(xmin, xmax, ymin, ymax, zmin, zmax);
| 471 |
gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2],
| 472 |
odev.v.vp[0] + odev.v.vdir[0],
| 473 |
odev.v.vp[1] + odev.v.vdir[1],
| 474 |
odev.v.vp[2] + odev.v.vdir[2],
| 475 |
odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]);
| 476 |
glDisable(GL_DEPTH_TEST); /* write no depth values */
| 477 |
glColor4ub(gridrgba[0], gridrgba[1], gridrgba[2], gridrgba[3]);
| 478 |
glBegin(GL_LINES); /* draw each grid line */
| 479 |
gridlines(draw3dline);
| 480 |
glEnd();
| 481 |
glEnable(GL_DEPTH_TEST); /* restore rendering params */
| 482 |
glPopMatrix();
| 483 |
| 484 |
| 485 |
| 486 |
static
| 487 |
moveview(dx, dy, mov, orb) /* move our view */
| 488 |
int dx, dy, mov, orb;
| 489 |
| 490 |
VIEW nv;
| 491 |
FVECT odir, v1;
| 492 |
double d;
| 493 |
register int li;
| 494 |
/* start with old view */
| 495 |
copystruct(&nv, &odev.v);
| 496 |
/* change view direction */
| 497 |
if (mov | orb) {
| 498 |
if ((li = qtFindLeaf(dx, dy)) < 0)
| 499 |
return(0); /* not on window */
| 500 |
VSUM(odir, qtL.wp[li], nv.vp, -1.);
| 501 |
} else {
| 502 |
if (viewray(nv.vp, nv.vdir, &odev.v,
| 503 |
(dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY)
| 504 |
return(0); /* outside view */
| 505 |
| 506 |
if (orb && mov) { /* orbit left/right */
| 507 |
spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
| 508 |
VSUM(nv.vp, qtL.wp[li], odir, -1.);
| 509 |
spinvector(nv.vdir, nv.vdir, nv.vup, d);
| 510 |
} else if (orb) { /* orbit up/down */
| 511 |
fcross(v1, odir, nv.vup);
| 512 |
if (normalize(v1) == 0.)
| 513 |
return(0);
| 514 |
spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
| 515 |
| 516 |
spinvector(nv.vdir, nv.vdir, v1, d);
| 517 |
} else if (mov) { /* move forward/backward */
| 518 |
d = MOVPCT/100. * mov;
| 519 |
VSUM(nv.vp, nv.vp, odir, d);
| 520 |
| 521 |
if (!mov ^ !orb && headlocked) { /* restore head height */
| 522 |
VSUM(v1, odev.v.vp, nv.vp, -1.);
| 523 |
d = DOT(v1, odev.v.vup);
| 524 |
VSUM(nv.vp, nv.vp, odev.v.vup, d);
| 525 |
| 526 |
if (setview(&nv) != NULL)
| 527 |
return(0); /* illegal view */
| 528 |
dev_view(&nv);
| 529 |
inpresflags |= DFL(DC_SETVIEW);
| 530 |
return(1);
| 531 |
| 532 |
| 533 |
| 534 |
static
| 535 |
getmove(ebut) /* get view change */
| 536 |
XButtonPressedEvent *ebut;
| 537 |
| 538 |
int movdir = MOVDIR(ebut->button);
| 539 |
int movorb = MOVORB(ebut->state);
| 540 |
int oldnodesiz = qtMinNodesiz;
| 541 |
Window rootw, childw;
| 542 |
int rootx, rooty, wx, wy;
| 543 |
unsigned int statemask;
| 544 |
| 545 |
qtMinNodesiz = 24; /* accelerate update rate */
| 546 |
XNoOp(ourdisplay);
| 547 |
| 548 |
while (!XCheckMaskEvent(ourdisplay,
| 549 |
ButtonReleaseMask, levptr(XEvent))) {
| 550 |
| 551 |
if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
| 552 |
&rootx, &rooty, &wx, &wy, &statemask))
| 553 |
break; /* on another screen */
| 554 |
| 555 |
if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) {
| 556 |
sleep(1);
| 557 |
continue;
| 558 |
| 559 |
glClear(GL_COLOR_BUFFER_BIT);
| 560 |
qtUpdate();
| 561 |
draw_grids();
| 562 |
glFlush();
| 563 |
| 564 |
if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */
| 565 |
movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
| 566 |
wx = levptr(XButtonReleasedEvent)->x;
| 567 |
wy = levptr(XButtonReleasedEvent)->y;
| 568 |
moveview(wx, odev.vres-1-wy, movdir, movorb);
| 569 |
| 570 |
dev_flush();
| 571 |
| 572 |
qtMinNodesiz = oldnodesiz; /* restore quadtree resolution */
| 573 |
| 574 |
| 575 |
| 576 |
static
| 577 |
getkey(ekey) /* get input key */
| 578 |
register XKeyPressedEvent *ekey;
| 579 |
| 580 |
int n;
| 581 |
char buf[8];
| 582 |
| 583 |
n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
| 584 |
if (n != 1)
| 585 |
return;
| 586 |
switch (buf[0]) {
| 587 |
case 'h': /* turn on height motion lock */
| 588 |
headlocked = 1;
| 589 |
return;
| 590 |
case 'H': /* turn off height motion lock */
| 591 |
headlocked = 0;
| 592 |
return;
| 593 |
case 'l': /* retrieve last view */
| 594 |
inpresflags |= DFL(DC_LASTVIEW);
| 595 |
return;
| 596 |
case 'p': /* pause computation */
| 597 |
inpresflags |= DFL(DC_PAUSE);
| 598 |
return;
| 599 |
case 'v': /* spit out view */
| 600 |
inpresflags |= DFL(DC_GETVIEW);
| 601 |
return;
| 602 |
case '\n':
| 603 |
case '\r': /* resume computation */
| 604 |
inpresflags |= DFL(DC_RESUME);
| 605 |
return;
| 606 |
case CTRL('R'): /* redraw screen */
| 607 |
| 608 |
curzmax = nxtzmax;
| 609 |
nxtzmax = 0.;
| 610 |
| 611 |
| 612 |
qtRedraw(0, 0, odev.hres, odev.vres);
| 613 |
return;
| 614 |
case CTRL('L'): /* refresh from server */
| 615 |
if (inpresflags & DFL(DC_REDRAW))
| 616 |
return;
| 617 |
| 618 |
curzmax = nxtzmax;
| 619 |
nxtzmax = 0.;
| 620 |
| 621 |
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
| 622 |
draw_grids();
| 623 |
glFlush();
| 624 |
qtCompost(100); /* get rid of old values */
| 625 |
inpresflags |= DFL(DC_REDRAW); /* resend values from server */
| 626 |
| 627 |
return;
| 628 |
case 'K': /* kill rtrace process(es) */
| 629 |
inpresflags |= DFL(DC_KILL);
| 630 |
break;
| 631 |
case 'R': /* restart rtrace */
| 632 |
inpresflags |= DFL(DC_RESTART);
| 633 |
break;
| 634 |
case 'C': /* clobber holodeck */
| 635 |
inpresflags |= DFL(DC_CLOBBER);
| 636 |
break;
| 637 |
case 'q': /* quit the program */
| 638 |
inpresflags |= DFL(DC_QUIT);
| 639 |
return;
| 640 |
default:
| 641 |
XBell(ourdisplay, 0);
| 642 |
return;
| 643 |
| 644 |
| 645 |
| 646 |
| 647 |
static
| 648 |
fixwindow(eexp) /* repair damage to window */
| 649 |
register XExposeEvent *eexp;
| 650 |
| 651 |
int xmin, xmax, ymin, ymax;
| 652 |
| 653 |
if (odev.hres == 0 || odev.vres == 0) /* first exposure */
| 654 |
resizewindow((XConfigureEvent *)eexp);
| 655 |
xmin = eexp->x; xmax = eexp->x + eexp->width;
| 656 |
ymin = odev.vres - eexp->y - eexp->height; ymax = odev.vres - eexp->y;
| 657 |
/* clear portion of depth */
| 658 |
glColorMask(GL_FALSE, GL_FALSE, GL_FALSE, GL_FALSE);
| 659 |
glDepthFunc(GL_ALWAYS);
| 660 |
glBegin(GL_POLYGON);
| 661 |
glVertex3d((double)xmin/odev.hres, (double)ymin/odev.vres, 0.);
| 662 |
glVertex3d((double)xmax/odev.hres, (double)ymin/odev.vres, 0.);
| 663 |
glVertex3d((double)xmax/odev.hres, (double)ymax/odev.vres, 0.);
| 664 |
glVertex3d((double)xmin/odev.hres, (double)ymax/odev.vres, 0.);
| 665 |
glEnd();
| 666 |
glColorMask(GL_TRUE, GL_TRUE, GL_TRUE, GL_TRUE);
| 667 |
| 668 |
qtRedraw(xmin, ymin, xmax, ymax);
| 669 |
| 670 |
| 671 |
| 672 |
static
| 673 |
resizewindow(ersz) /* resize window */
| 674 |
register XConfigureEvent *ersz;
| 675 |
| 676 |
glViewport(0, 0, ersz->width, ersz->height);
| 677 |
| 678 |
if (ersz->width == odev.hres && ersz->height == odev.vres)
| 679 |
return;
| 680 |
| 681 |
odev.hres = ersz->width;
| 682 |
odev.vres = ersz->height;
| 683 |
| 684 |
odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres);
| 685 |
odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres);
| 686 |
| 687 |
| 688 |
