--- ray/src/hd/rhd_glx.c 1998/08/20 09:32:52 3.20 +++ ray/src/hd/rhd_glx.c 1998/08/25 18:11:17 3.22 @@ -124,7 +124,7 @@ char *id; XSizeHints oursizhints; /* check for unsupported stereo */ #ifdef NOSTEREO - error(USER, "stereo display driver unavailable"); + error(INTERNAL, "stereo display driver unavailable"); #endif /* open display server */ ourdisplay = XOpenDisplay(NULL); @@ -272,41 +272,41 @@ register VIEW *nv; nv->vert = odev.v.vert; return(0); } - if (nv != &odev.v && /* resize window? */ - (!FEQ(nv->horiz,odev.v.horiz) || - !FEQ(nv->vert,odev.v.vert))) { - int dw = DisplayWidth(ourdisplay,ourscreen); - int dh = DisplayHeight(ourdisplay,ourscreen); + if (nv != &odev.v) { + /* resize window? */ + if (!FEQ(nv->horiz,odev.v.horiz) || + !FEQ(nv->vert,odev.v.vert)) { + int dw = DisplayWidth(ourdisplay,ourscreen); + int dh = DisplayHeight(ourdisplay,ourscreen); - dw -= 25; /* for window frame */ - dh -= 50; + dw -= 25; /* for window frame */ + dh -= 50; #ifdef STEREO - dh /= 2; + dh /= 2; #endif - odev.hres = 2.*VIEWDIST/pwidth * - tan(PI/180./2.*nv->horiz); - odev.vres = 2.*VIEWDIST/pheight * - tan(PI/180./2.*nv->vert); - if (odev.hres > dw) { - odev.vres = dw * odev.vres / odev.hres; - odev.hres = dw; + odev.hres = 2.*VIEWDIST/pwidth * + tan(PI/180./2.*nv->horiz); + odev.vres = 2.*VIEWDIST/pheight * + tan(PI/180./2.*nv->vert); + if (odev.hres > dw) { + odev.vres = dw * odev.vres / odev.hres; + odev.hres = dw; + } + if (odev.vres > dh) { + odev.hres = dh * odev.hres / odev.vres; + odev.vres = dh; + } + XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres); + dev_input(); /* get resize event */ } - if (odev.vres > dh) { - odev.hres = dh * odev.hres / odev.vres; - odev.vres = dh; - } - XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres); - dev_input(); /* get resize event */ - } - copystruct(&odev.v, nv); /* setview() already called */ - setglpersp(&odev.v); + copystruct(&odev.v, nv); /* setview() already called */ #ifdef STEREO - copystruct(&vwright, nv); - d = eyesepdist / sqrt(nv->hn2); - VSUM(vwright.vp, nv->vp, nv->hvec, d); - /* setview(&vwright); -- Unnecessary */ + copystruct(&vwright, nv); + d = eyesepdist / sqrt(nv->hn2); + VSUM(vwright.vp, nv->vp, nv->hvec, d); + /* setview(&vwright); -- Unnecessary */ #endif - checkglerr("setting view"); + } wipeclean(); return(1); } @@ -367,8 +367,7 @@ FVECT d, p; return; } #endif - smNewSamp(c, d, p); /* add to display representation */ - if (p != NULL) { + if (p != NULL) { /* add depth to our range */ depth = (p[0] - odev.v.vp[0])*d[0] + (p[1] - odev.v.vp[1])*d[1] + (p[2] - odev.v.vp[2])*d[2]; @@ -379,6 +378,7 @@ FVECT d, p; maxdpth = depth; } } + smNewSamp(c, d, p); /* add to display representation */ if (!--rayqleft) dev_flush(); /* flush output */ } @@ -387,22 +387,24 @@ FVECT d, p; int dev_flush() /* flush output */ { + if (mapped) { #ifdef STEREO - pushright(); /* update right eye */ - glClear(GL_DEPTH_BUFFER_BIT); - smUpdate(&vwright, 100); + pushright(); /* update right eye */ + glClear(GL_DEPTH_BUFFER_BIT); + smUpdate(&vwright, 100); #ifdef DOBJ - dobj_render(); /* usually in foreground */ + dobj_render(); /* usually in foreground */ #endif - popright(); /* update left eye */ - glClear(GL_DEPTH_BUFFER_BIT); + popright(); /* update left eye */ + glClear(GL_DEPTH_BUFFER_BIT); #endif - smUpdate(&odev.v, 100); + smUpdate(&odev.v, 100); + checkglerr("rendering mesh"); #ifdef DOBJ - dobj_render(); + dobj_render(); #endif - glFlush(); /* flush OGL */ - checkglerr("flushing display"); + glFlush(); /* flush OGL */ + } rayqleft = RAYQLEN; /* flush X11 and return # pending */ return(odev.inpready = XPending(ourdisplay)); @@ -501,13 +503,15 @@ register FVECT wp[2]; static -draw_grids() /* draw holodeck section grids */ +draw_grids(fore) /* draw holodeck section grids */ +int fore; { - static BYTE gridrgba[4] = {0x0, 0xff, 0xff, 0x00}; - if (!mapped) return; - glColor4ub(gridrgba[0], gridrgba[1], gridrgba[2], gridrgba[3]); + if (fore) + glColor4ub(0, 255, 255, 0); + else + glColor4ub(0, 0, 0, 0); glBegin(GL_LINES); /* draw each grid line */ gridlines(draw3dline); glEnd(); @@ -524,30 +528,29 @@ int dx, dy, mov, orb; register int li; /* start with old view */ copystruct(&nv, &odev.v); - /* change view direction */ + /* orient our motion */ if (viewray(v1, odir, &odev.v, (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY) return(0); /* outside view */ - if (mov | orb) { + if (mov | orb) { /* moving relative to geometry */ #ifdef DOBJ - d = dobj_trace(v1, odir); /* check objects */ - /* is holodeck in front? */ - if ((li = smFindSamp(v1, odir)) >= 0 && - (rsL.wp[li][0] - nv.vp[0])*odir[0] + - (rsL.wp[li][1] - nv.vp[1])*odir[1] + - (rsL.wp[li][2] - nv.vp[2])*odir[2] < d) + d = dobj_trace(NULL, v1, odir); /* check objects */ + /* check holodeck */ + if ((li = smFindSamp(v1, odir)) >= 0) { VCOPY(wip, rsL.wp[li]); - else if (d < .99*FHUGE) /* object is closer */ - VSUM(wip, nv.vp, odir, d); - else /* nothing visible */ - return(0); + if (d < .99*FHUGE && d*d <= dist2(v1, wip)) + li = -1; /* object is closer */ + } else if (d >= .99*FHUGE) + return(0); /* nothing visible */ + if (li < 0) + VSUM(wip, v1, odir, d); /* else get object point */ #else if ((li = smFindSamp(v1, odir)) < 0) return(0); /* not on window */ VCOPY(wip, rsL.wp[li]); #endif - VSUM(odir, wip, nv.vp, -1.); - } else + VSUM(odir, wip, odev.v.vp, -1.); + } else /* panning with constant viewpoint */ VCOPY(nv.vdir, odir); if (orb && mov) { /* orbit left/right */ spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov); @@ -566,7 +569,7 @@ int dx, dy, mov, orb; } if (!mov ^ !orb && headlocked) { /* restore head height */ VSUM(v1, odev.v.vp, nv.vp, -1.); - d = DOT(v1, odev.v.vup); + d = DOT(v1, nv.vup); VSUM(nv.vp, nv.vp, odev.v.vup, d); } if (setview(&nv) != NULL) @@ -600,6 +603,7 @@ XButtonPressedEvent *ebut; &rootx, &rooty, &wx, &wy, &statemask)) break; /* on another screen */ + draw_grids(0); /* clear old grid lines */ if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) { sleep(1); lasttime++; @@ -607,16 +611,14 @@ XButtonPressedEvent *ebut; } #ifdef STEREO pushright(); - glClear(GL_COLOR_BUFFER_BIT); - draw_grids(); + draw_grids(1); smUpdate(&vwright, qlevel); #ifdef DOBJ dobj_render(); #endif popright(); #endif - glClear(GL_COLOR_BUFFER_BIT); - draw_grids(); + draw_grids(1); smUpdate(&odev.v, qlevel); #ifdef DOBJ dobj_render(); @@ -694,13 +696,15 @@ register VIEW *vp; static wipeclean() /* prepare for redraw */ { + /* clear depth buffer */ #ifdef STEREO setstereobuf(STEREO_BUFFER_RIGHT); glClear(GL_DEPTH_BUFFER_BIT); setstereobuf(STEREO_BUFFER_LEFT); #endif glClear(GL_DEPTH_BUFFER_BIT); - smClean(); + smClean(); /* reset drawing routines */ + setglpersp(&odev.v); /* reset view & clipping planes */ } @@ -742,17 +746,18 @@ register XKeyPressedEvent *ekey; return; glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); glDisable(GL_DEPTH_TEST); - draw_grids(); + draw_grids(1); #ifdef STEREO pushright(); glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); - draw_grids(); + draw_grids(1); popright(); #endif glEnable(GL_DEPTH_TEST); glFlush(); smInit(rsL.max_samp); /* get rid of old values */ inpresflags |= DFL(DC_REDRAW); /* resend values from server */ + setglpersp(&odev.v); /* reset clipping planes */ rayqleft = 0; /* hold off update */ return; case 'K': /* kill rtrace process(es) */
