1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* Geometry drawing operations for OpenGL driver. |
6 |
7 |
8 |
#include "radogl.h" |
9 |
#include "rhdriver.h" |
10 |
11 |
#ifndef MAXGEO |
12 |
#define MAXGEO 8 /* maximum geometry list length */ |
13 |
#endif |
14 |
#ifndef MAXPORT |
15 |
#define MAXPORT (MAXGEO*4) /* maximum number of portal files */ |
16 |
#endif |
17 |
18 |
int gmPortals = 0; /* current portal GL list id */ |
19 |
static int Nlists = 0; /* number of lists allocated */ |
20 |
static char *curportlist[MAXPORT]; /* current portal list */ |
21 |
static char *newportlist[MAXPORT]; /* new portal file list */ |
22 |
23 |
static struct gmEntry { |
24 |
char *gfile; /* geometry file name */ |
25 |
FVECT cent; /* centroid */ |
26 |
FLOAT rad; /* radius */ |
27 |
int listid; /* display list identifier */ |
28 |
int nlists; /* number of lists allocated */ |
29 |
} gmCurrent[MAXGEO], gmNext[MAXGEO]; /* current and next list */ |
30 |
31 |
#define FORALLGEOM(ot,i) for (i=0;i<MAXGEO&&ot[i].gfile!=NULL;i++) |
32 |
33 |
#define FORALLPORT(pl,i) for (i=0;i<MAXPORT&&pl[i]!=NULL;i++) |
34 |
35 |
extern char *nextword(); |
36 |
37 |
38 |
gmNewGeom(file) /* add new geometry to next list */ |
39 |
char *file; |
40 |
41 |
register int i, j; |
42 |
/* check if already in next list */ |
43 |
FORALLGEOM(gmNext, i) |
44 |
if (!strcmp(file, gmNext[i].gfile)) |
45 |
return; |
46 |
if (i >= MAXGEO) { |
47 |
error(WARNING, "too many section octrees -- ignoring extra"); |
48 |
return; |
49 |
50 |
/* check if copy in current list */ |
51 |
FORALLGEOM(gmCurrent, j) |
52 |
if (!strcmp(file, gmCurrent[j].gfile)) { |
53 |
copystruct(&gmNext[i], &gmCurrent[j]); |
54 |
return; |
55 |
56 |
/* else load new octree */ |
57 |
gmNext[i].gfile = savestr(file); |
58 |
dolights = 0; |
59 |
domats = 1; |
60 |
gmNext[i].listid = rgl_octlist(file, gmNext[i].cent, &gmNext[i].rad, |
61 |
&gmNext[i].nlists); |
62 |
gmNext[i].rad *= 1.732; /* go to corners */ |
63 |
#ifdef DEBUG |
64 |
fprintf(stderr, "Loaded octree \"%s\" into listID %d with radius %f\n", |
65 |
file, gmNext[i].listid, gmNext[i].rad); |
66 |
#endif |
67 |
68 |
69 |
70 |
gmEndGeom() /* make next list current */ |
71 |
72 |
73 |
74 |
FORALLGEOM(gmCurrent, i) { |
75 |
FORALLGEOM(gmNext, j) |
76 |
if (gmNext[j].listid == gmCurrent[i].listid) |
77 |
break; |
78 |
if (j >= MAXGEO || gmNext[j].gfile == NULL) { |
79 |
glDeleteLists(gmCurrent[i].listid, /* not found */ |
80 |
gmCurrent[i].nlists); |
81 |
freestr(gmCurrent[i].gfile); |
82 |
83 |
84 |
bcopy((char *)gmNext, (char *)gmCurrent, sizeof(gmNext)); |
85 |
bzero((char *)gmNext, sizeof(gmNext)); |
86 |
87 |
88 |
89 |
int |
90 |
gmDrawGeom() /* draw current list of octrees */ |
91 |
92 |
register int n; |
93 |
94 |
FORALLGEOM(gmCurrent, n) |
95 |
glCallList(gmCurrent[n].listid); |
96 |
return(n); |
97 |
98 |
99 |
100 |
gmDrawPortals(r, g, b, a) /* draw portals with specific RGBA value */ |
101 |
int r, g, b, a; |
102 |
103 |
if (!gmPortals || r<0 & g<0 & b<0 & a<0) |
104 |
return; |
105 |
glPushAttrib(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT| |
106 |
GL_POLYGON_BIT|GL_LIGHTING_BIT); |
107 |
glDisable(GL_LIGHTING); |
108 |
glDisable(GL_DITHER); |
109 |
glShadeModel(GL_FLAT); |
110 |
glPolygonMode(GL_FRONT_AND_BACK, GL_FILL); |
111 |
/* don't actually write depth */ |
112 |
glDepthMask(GL_FALSE); |
113 |
/* draw only selected channels */ |
114 |
glColorMask(r>=0, g>=0, b>=0, a>=0); |
115 |
glColor4ub(r&0xff, g&0xff, b&0xff, a&0xff); |
116 |
glCallList(gmPortals); /* draw them portals */ |
117 |
glPopAttrib(); |
118 |
119 |
120 |
121 |
gmDepthLimit(dl, vorg, vdir) /* compute approximate depth limits for view */ |
122 |
double dl[2]; |
123 |
FVECT vorg, vdir; |
124 |
125 |
FVECT v; |
126 |
double dcent; |
127 |
register int i; |
128 |
129 |
dl[0] = FHUGE; dl[1] = 0.; |
130 |
131 |
VSUB(v, gmCurrent[i].cent, vorg); |
132 |
dcent = DOT(v, vdir); |
133 |
if (dl[0] > dcent-gmCurrent[i].rad) |
134 |
dl[0] = dcent-gmCurrent[i].rad; |
135 |
if (dl[1] < dcent+gmCurrent[i].rad) |
136 |
dl[1] = dcent+gmCurrent[i].rad; |
137 |
138 |
if (dl[0] < 0.) |
139 |
dl[0] = 0.; |
140 |
141 |
142 |
143 |
gmNewPortal(pflist) /* add portal file(s) to our new list */ |
144 |
char *pflist; |
145 |
146 |
147 |
char newfile[128]; |
148 |
149 |
if (pflist == NULL) |
150 |
return; |
151 |
while ((pflist = nextword(newfile, sizeof(newfile), pflist)) != NULL) { |
152 |
FORALLPORT(newportlist,i) |
153 |
if (!strcmp(newportlist[i], newfile)) |
154 |
goto endloop; /* in list already */ |
155 |
if (i >= MAXPORT) { |
156 |
error(WARNING, "too many portals -- ignoring extra"); |
157 |
return; |
158 |
159 |
newportlist[i] = savestr(newfile); |
160 |
endloop:; |
161 |
162 |
163 |
164 |
165 |
static int |
166 |
sstrcmp(ss0, ss1) |
167 |
char **ss0, **ss1; |
168 |
169 |
return(strcmp(*ss0, *ss1)); |
170 |
171 |
172 |
173 |
int |
174 |
gmEndPortal() /* close portal list and return GL list */ |
175 |
176 |
register int n; |
177 |
178 |
FORALLPORT(newportlist, n); |
179 |
if (!n) { /* free old GL list */ |
180 |
if (gmPortals) |
181 |
glDeleteLists(gmPortals, Nlists); |
182 |
gmPortals = 0; |
183 |
} else |
184 |
qsort(newportlist, n, sizeof(char *), sstrcmp); |
185 |
FORALLPORT(newportlist, n) /* compare sorted lists */ |
186 |
if (curportlist[n] == NULL || |
187 |
strcmp(curportlist[n],newportlist[n])) { |
188 |
/* load new list */ |
189 |
if (gmPortals) |
190 |
glDeleteLists(gmPortals, 1); |
191 |
192 |
dolights = 0; |
193 |
domats = 0; |
194 |
gmPortals = rgl_filelist(n, newportlist, &Nlists); |
195 |
break; |
196 |
197 |
FORALLPORT(curportlist, n) /* free old file list */ |
198 |
freestr(curportlist[n]); |
199 |
bcopy((char *)newportlist, (char *)curportlist, sizeof(newportlist)); |
200 |
bzero((char *)newportlist, sizeof(newportlist)); |
201 |
return(gmPortals); /* return GL list id */ |
202 |
