root/radiance/ray/src/hd/rhd_geom.c
Revision: 3.5
Committed: Fri Jan 1 10:41:28 1999 UTC (26 years, 7 months ago) by gwlarson
Changes since 3.4: +2 -1 lines
fixed aft clipping plane problem
1 /* Copyright (c) 1999 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Geometry drawing operations for OpenGL driver.
9 */
10
11 #include "radogl.h"
12 #include "rhdriver.h"
13
14 #ifndef MAXGEO
15 #define MAXGEO 8 /* maximum geometry list length */
16 #endif
17 #ifndef MAXPORT
18 #define MAXPORT (MAXGEO*4) /* maximum number of portal files */
19 #endif
20
21 int gmPortals = 0; /* current portal GL list id */
22 static char *curportlist[MAXPORT]; /* current portal list */
23 static char *newportlist[MAXPORT]; /* new portal file list */
24
25 static struct gmEntry {
26 char *gfile; /* geometry file name */
27 FVECT cent; /* centroid */
28 FLOAT rad; /* radius */
29 int listid; /* display list identifier */
30 } gmCurrent[MAXGEO], gmNext[MAXGEO]; /* current and next list */
31
32 #define FORALLGEOM(ot,i) for (i=0;i<MAXGEO&&ot[i].gfile!=NULL;i++)
33
34 #define FORALLPORT(pl,i) for (i=0;i<MAXPORT&&pl[i]!=NULL;i++)
35
36 extern char *atos(), *sskip(), *sskip2();
37
38
39 gmNewGeom(file) /* add new geometry to next list */
40 char *file;
41 {
42 register int i, j;
43 /* check if already in next list */
44 FORALLGEOM(gmNext, i)
45 if (!strcmp(file, gmNext[i].gfile))
46 return;
47 if (i >= MAXGEO) {
48 error(WARNING, "too many section octrees -- ignoring extra");
49 return;
50 }
51 /* check if copy in current list */
52 FORALLGEOM(gmCurrent, j)
53 if (!strcmp(file, gmCurrent[j].gfile)) {
54 copystruct(&gmNext[i], &gmCurrent[j]);
55 return;
56 }
57 /* else load new octree */
58 gmNext[i].gfile = file;
59 dolights = 0;
60 domats = 1;
61 gmNext[i].listid = rgl_octlist(file, gmNext[i].cent, &gmNext[i].rad);
62 gmNext[i].rad *= 1.732; /* go to corners */
63 #ifdef DEBUG
64 fprintf(stderr, "Loaded octree \"%s\" into listID %d with radius %f\n",
65 file, gmNext[i].listid, gmNext[i].rad);
66 #endif
67 }
68
69
70 gmEndGeom() /* make next list current */
71 {
72 register int i, j;
73
74 FORALLGEOM(gmCurrent, i) {
75 FORALLGEOM(gmNext, j)
76 if (gmNext[j].listid == gmCurrent[i].listid)
77 break;
78 if (j >= MAXGEO || gmNext[j].gfile == NULL)
79 glDeleteLists(gmCurrent[i].listid, 1); /* not found */
80 }
81 bcopy((char *)gmNext, (char *)gmCurrent, sizeof(gmNext));
82 bzero((char *)gmNext, sizeof(gmNext));
83 }
84
85
86 int
87 gmDrawGeom() /* draw current list of octrees (and ports) */
88 {
89 register int n;
90
91 FORALLGEOM(gmCurrent, n)
92 glCallList(gmCurrent[n].listid);
93 return(n);
94 }
95
96
97 gmDrawPortals(r, g, b, a) /* draw portals with specific RGBA value */
98 int r, g, b, a;
99 {
100 if (!gmPortals || r<0 & g<0 & b<0 & a<0)
101 return;
102 glPushAttrib(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT|
103 GL_POLYGON_BIT|GL_LIGHTING_BIT);
104 glDisable(GL_LIGHTING);
105 glDisable(GL_DITHER);
106 glShadeModel(GL_FLAT);
107 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
108 /* don't actually write depth */
109 glDepthMask(GL_FALSE);
110 /* draw only selected channels */
111 glColorMask(r>=0, g>=0, b>=0, a>=0);
112 glColor4ub(r&0xff, g&0xff, b&0xff, a&0xff);
113 glCallList(gmPortals); /* draw them portals */
114 glPopAttrib();
115 }
116
117
118 gmDepthLimit(dl, vorg, vdir) /* compute approximate depth limits for view */
119 double dl[2];
120 FVECT vorg, vdir;
121 {
122 FVECT v;
123 double dcent;
124 register int i;
125
126 dl[0] = FHUGE; dl[1] = 0.;
127 FORALLGEOM(gmCurrent, i) {
128 VSUB(v, gmCurrent[i].cent, vorg);
129 dcent = DOT(v, vdir);
130 if (dl[0] > dcent-gmCurrent[i].rad)
131 dl[0] = dcent-gmCurrent[i].rad;
132 if (dl[1] < dcent+gmCurrent[i].rad)
133 dl[1] = dcent+gmCurrent[i].rad;
134 }
135 if (dl[0] < 0.)
136 dl[0] = 0.;
137 }
138
139
140 gmNewPortal(pflist) /* add portal file(s) to our new list */
141 char *pflist;
142 {
143 register int i, j;
144 char newfile[128];
145
146 if (pflist == NULL)
147 return;
148 while (*pflist) {
149 atos(newfile, sizeof(newfile), pflist);
150 if (!*newfile)
151 break;
152 pflist = sskip(pflist);
153 FORALLPORT(newportlist,i)
154 if (!strcmp(newportlist[i], newfile))
155 goto endloop; /* in list already */
156 if (i >= MAXPORT) {
157 error(WARNING, "too many portals -- ignoring extra");
158 return;
159 }
160 newportlist[i] = savestr(newfile);
161 endloop:;
162 }
163 }
164
165
166 static int
167 sstrcmp(ss0, ss1)
168 char **ss0, **ss1;
169 {
170 return(strcmp(*ss0, *ss1));
171 }
172
173
174 int
175 gmEndPortal() /* close portal list and return GL list */
176 {
177 register int n;
178
179 FORALLPORT(newportlist, n);
180 if (!n) { /* free old GL list */
181 if (gmPortals)
182 glDeleteLists(gmPortals, 1);
183 gmPortals = 0;
184 } else
185 qsort(newportlist, n, sizeof(char *), sstrcmp);
186 FORALLPORT(newportlist, n) /* compare sorted lists */
187 if (curportlist[n] == NULL ||
188 strcmp(curportlist[n],newportlist[n])) {
189 /* load new list */
190 if (gmPortals)
191 glDeleteLists(gmPortals, 1);
192 FORALLPORT(newportlist, n);
193 dolights = 0;
194 domats = 0;
195 gmPortals = rgl_filelist(n, newportlist);
196 break;
197 }
198 FORALLPORT(curportlist, n) /* free old file list */
199 freestr(curportlist[n]);
200 bcopy((char *)newportlist, (char *)curportlist, sizeof(newportlist));
201 bzero((char *)newportlist, sizeof(newportlist));
202 return(gmPortals); /* return GL list id */
203 }
