--- ray/src/hd/rhd_geom.c 1998/12/21 11:42:37 3.3 +++ ray/src/hd/rhd_geom.c 2003/06/30 14:59:11 3.12 @@ -1,13 +1,12 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rhd_geom.c,v 3.12 2003/06/30 14:59:11 schorsch Exp $"; #endif - /* * Geometry drawing operations for OpenGL driver. */ +#include + #include "radogl.h" #include "rhdriver.h" @@ -19,21 +18,23 @@ static char SCCSid[] = "$SunId$ SGI"; #endif int gmPortals = 0; /* current portal GL list id */ +static int Nlists = 0; /* number of lists allocated */ static char *curportlist[MAXPORT]; /* current portal list */ static char *newportlist[MAXPORT]; /* new portal file list */ static struct gmEntry { char *gfile; /* geometry file name */ FVECT cent; /* centroid */ - FLOAT rad; /* radius */ + RREAL rad; /* radius */ int listid; /* display list identifier */ + int nlists; /* number of lists allocated */ } gmCurrent[MAXGEO], gmNext[MAXGEO]; /* current and next list */ #define FORALLGEOM(ot,i) for (i=0;i= MAXGEO || gmNext[j].gfile == NULL) - glDeleteLists(gmCurrent[i].listid, 1); /* not found */ + if (j >= MAXGEO || gmNext[j].gfile == NULL) { + glDeleteLists(gmCurrent[i].listid, /* not found */ + gmCurrent[i].nlists); + freestr(gmCurrent[i].gfile); + } } - bcopy((char *)gmNext, (char *)gmCurrent, sizeof(gmNext)); - bzero((char *)gmNext, sizeof(gmNext)); + memcpy((void *)gmCurrent, (void *)gmNext, sizeof(gmNext)); + memset((void *)gmNext, '\0', sizeof(gmNext)); } int -gmDrawGeom() /* draw current list of octrees (and ports) */ +gmDrawGeom() /* draw current list of octrees */ { register int n; @@ -102,7 +108,7 @@ int r, g, b, a; GL_POLYGON_BIT|GL_LIGHTING_BIT); glDisable(GL_LIGHTING); glDisable(GL_DITHER); - glShadeModel(GL_SMOOTH); + glShadeModel(GL_FLAT); glPolygonMode(GL_FRONT_AND_BACK, GL_FILL); /* don't actually write depth */ glDepthMask(GL_FALSE); @@ -144,11 +150,7 @@ char *pflist; if (pflist == NULL) return; - while (*pflist) { - atos(newfile, sizeof(newfile), pflist); - if (!*newfile) - break; - pflist = sskip(pflist); + while ((pflist = nextword(newfile, sizeof(newfile), pflist)) != NULL) { FORALLPORT(newportlist,i) if (!strcmp(newportlist[i], newfile)) goto endloop; /* in list already */ @@ -178,7 +180,7 @@ gmEndPortal() /* close portal list and return GL lis FORALLPORT(newportlist, n); if (!n) { /* free old GL list */ if (gmPortals) - glDeleteLists(gmPortals, 1); + glDeleteLists(gmPortals, Nlists); gmPortals = 0; } else qsort(newportlist, n, sizeof(char *), sstrcmp); @@ -191,12 +193,12 @@ gmEndPortal() /* close portal list and return GL lis FORALLPORT(newportlist, n); dolights = 0; domats = 0; - gmPortals = rgl_filelist(n, newportlist); + gmPortals = rgl_filelist(n, newportlist, &Nlists); break; } FORALLPORT(curportlist, n) /* free old file list */ freestr(curportlist[n]); - bcopy((char *)newportlist, (char *)curportlist, sizeof(newportlist)); - bzero((char *)newportlist, sizeof(newportlist)); + memcpy((void *)curportlist, (void *)newportlist, sizeof(newportlist)); + memset((void *)newportlist, '\0', sizeof(newportlist)); return(gmPortals); /* return GL list id */ }
