root/radiance/ray/src/hd/rhd_ctab.c
Revision: 3.6
Committed: Fri May 20 02:06:39 2011 UTC (14 years, 1 month ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R2P1
Changes since 3.5: +3 -3 lines
# User Rev Content
1 gregl 3.1 #ifndef lint
2 greg 3.6 static const char RCSid[] = "$Id: rhd_ctab.c,v 3.5 2004/01/01 11:21:55 schorsch Exp $";
3 gregl 3.1 #endif
4     /*
5     * Allocate and control dynamic color table.
6     *
7     * We start off with a uniform partition of color space.
8     * As pixels are sent to the frame buffer, a histogram is built.
9     * When a new color table is requested, the histogram is used
10     * to make a pseudo-optimal partition, after which the
11     * histogram is cleared. This algorithm
12     * performs only as well as the next drawing's color
13     * distribution is correlated to the last.
14     *
15     * This module is essentially identical to src/rt/colortab.c,
16     * except there is no color mapping, since the tm library is used.
17     */
18
19 schorsch 3.4 #include <string.h>
20
21 gregl 3.1 #include "standard.h"
22 schorsch 3.5 #include "rhdisp.h"
23 gregl 3.1 #include "color.h"
24     /* histogram resolution */
25     #define NRED 24
26     #define NGRN 32
27     #define NBLU 16
28     #define HMAX NGRN
29     /* minimum box count for adaptive partition */
30     #define MINSAMP 7
31     /* maximum distance^2 before color reassign */
32     #define MAXDST2 12
33     /* color partition tree */
34     #define CNODE short
35     #define set_branch(p,c) ((c)<<2|(p))
36     #define set_pval(pv) ((pv)<<2|3)
37     #define is_branch(cn) (((cn)&3)!=3)
38     #define is_pval(cn) (((cn)&3)==3)
39     #define part(cn) ((cn)>>2)
40     #define prim(cn) ((cn)&3)
41     #define pval(cn) ((cn)>>2)
42     /* our color table */
43     static struct tabent {
44     long sum[3]; /* sum of colors using this entry */
45     int n; /* number of colors */
46 greg 3.6 uby8 ent[3]; /* current table value */
47 gregl 3.1 } *clrtab = NULL;
48     /* color cube partition */
49     static CNODE *ctree = NULL;
50     /* histogram of colors used */
51     static unsigned short histo[NRED][NGRN][NBLU];
52     /* initial color cube boundary */
53     static int CLRCUBE[3][2] = {{0,NRED},{0,NGRN},{0,NBLU}};
54
55 schorsch 3.5 static void cut(CNODE *tree, int level, int box[3][2], int c0, int c1);
56     static int split(int box[3][2]);
57 gregl 3.1
58
59 schorsch 3.5
60     extern int
61     new_ctab( /* start new color table with max ncolors */
62     int ncolors
63     )
64 gregl 3.1 {
65     int treesize;
66
67     if (ncolors < 1)
68     return(0);
69     /* free old tables */
70     if (clrtab != NULL)
71 greg 3.2 free((void *)clrtab);
72 gregl 3.1 if (ctree != NULL)
73 greg 3.2 free((void *)ctree);
74 gregl 3.1 /* get new tables */
75     for (treesize = 1; treesize < ncolors; treesize <<= 1)
76     ;
77     treesize <<= 1;
78     clrtab = (struct tabent *)calloc(ncolors, sizeof(struct tabent));
79     ctree = (CNODE *)malloc(treesize*sizeof(CNODE));
80     if (clrtab == NULL || ctree == NULL)
81     return(0);
82     /* partition color space */
83     cut(ctree, 0, CLRCUBE, 0, ncolors);
84     /* clear histogram */
85 schorsch 3.4 memset((void *)histo, '\0', sizeof(histo));
86 gregl 3.1 /* return number of colors used */
87     return(ncolors);
88     }
89
90
91 schorsch 3.5 extern int
92     get_pixel( /* get pixel for color */
93 greg 3.6 uby8 rgb[3],
94 schorsch 3.5 void (*set_pixel)(int h, int r, int g, int b)
95     )
96 gregl 3.1 {
97     int r, g, b;
98     int cv[3];
99     register CNODE *tp;
100     register int h;
101     /* get desired color */
102     r = rgb[RED];
103     g = rgb[GRN];
104     b = rgb[BLU];
105     /* reduce resolution */
106     cv[RED] = (r*NRED)>>8;
107     cv[GRN] = (g*NGRN)>>8;
108     cv[BLU] = (b*NBLU)>>8;
109     /* add to histogram */
110     histo[cv[RED]][cv[GRN]][cv[BLU]]++;
111     /* find pixel in tree */
112     for (tp = ctree, h = 0; is_branch(*tp); h++)
113     if (cv[prim(*tp)] < part(*tp))
114     tp += 1<<h; /* left branch */
115     else
116     tp += 1<<(h+1); /* right branch */
117     h = pval(*tp);
118     /* add to color table */
119     clrtab[h].sum[RED] += r;
120     clrtab[h].sum[GRN] += g;
121     clrtab[h].sum[BLU] += b;
122     clrtab[h].n++;
123     /* recompute average */
124     r = clrtab[h].sum[RED] / clrtab[h].n;
125     g = clrtab[h].sum[GRN] / clrtab[h].n;
126     b = clrtab[h].sum[BLU] / clrtab[h].n;
127     /* check for movement */
128     if (clrtab[h].n == 1 ||
129     (r-clrtab[h].ent[RED])*(r-clrtab[h].ent[RED]) +
130     (g-clrtab[h].ent[GRN])*(g-clrtab[h].ent[GRN]) +
131     (b-clrtab[h].ent[BLU])*(b-clrtab[h].ent[BLU]) > MAXDST2) {
132     clrtab[h].ent[RED] = r;
133     clrtab[h].ent[GRN] = g; /* reassign pixel */
134     clrtab[h].ent[BLU] = b;
135     #ifdef DEBUG
136 schorsch 3.5 {
137     extern char errmsg[];
138     sprintf(errmsg, "pixel %d = (%d,%d,%d) (%d refs)\n",
139     h, r, g, b, clrtab[h].n);
140     eputs(errmsg);
141     }
142 gregl 3.1 #endif
143     (*set_pixel)(h, r, g, b);
144     }
145     return(h); /* return pixel value */
146     }
147
148
149 schorsch 3.5 static void
150     cut( /* partition color space */
151     register CNODE *tree,
152     int level,
153     register int box[3][2],
154     int c0,
155     int c1
156     )
157 gregl 3.1 {
158     int kb[3][2];
159
160     if (c1-c0 <= 1) { /* assign pixel */
161     *tree = set_pval(c0);
162     return;
163     }
164     /* split box */
165     *tree = split(box);
166 schorsch 3.4 memcpy((void *)kb, (void *)box, sizeof(kb));
167 gregl 3.1 /* do left (lesser) branch */
168     kb[prim(*tree)][1] = part(*tree);
169     cut(tree+(1<<level), level+1, kb, c0, (c0+c1)>>1);
170     /* do right branch */
171     kb[prim(*tree)][0] = part(*tree);
172     kb[prim(*tree)][1] = box[prim(*tree)][1];
173     cut(tree+(1<<(level+1)), level+1, kb, (c0+c1)>>1, c1);
174     }
175
176
177     static int
178 schorsch 3.5 split( /* find median cut for box */
179     register int box[3][2]
180     )
181 gregl 3.1 {
182     #define c0 r
183     register int r, g, b;
184     int pri;
185     long t[HMAX], med;
186     /* find dominant axis */
187     pri = RED;
188     if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0])
189     pri = GRN;
190     if (box[BLU][1]-box[BLU][0] > box[pri][1]-box[pri][0])
191     pri = BLU;
192     /* sum histogram over box */
193     med = 0;
194     switch (pri) {
195     case RED:
196     for (r = box[RED][0]; r < box[RED][1]; r++) {
197     t[r] = 0;
198     for (g = box[GRN][0]; g < box[GRN][1]; g++)
199     for (b = box[BLU][0]; b < box[BLU][1]; b++)
200     t[r] += histo[r][g][b];
201     med += t[r];
202     }
203     break;
204     case GRN:
205     for (g = box[GRN][0]; g < box[GRN][1]; g++) {
206     t[g] = 0;
207     for (b = box[BLU][0]; b < box[BLU][1]; b++)
208     for (r = box[RED][0]; r < box[RED][1]; r++)
209     t[g] += histo[r][g][b];
210     med += t[g];
211     }
212     break;
213     case BLU:
214     for (b = box[BLU][0]; b < box[BLU][1]; b++) {
215     t[b] = 0;
216     for (r = box[RED][0]; r < box[RED][1]; r++)
217     for (g = box[GRN][0]; g < box[GRN][1]; g++)
218     t[b] += histo[r][g][b];
219     med += t[b];
220     }
221     break;
222     }
223     if (med < MINSAMP) /* if too sparse, split at midpoint */
224     return(set_branch(pri,(box[pri][0]+box[pri][1])>>1));
225     /* find median position */
226     med >>= 1;
227     for (c0 = box[pri][0]; med > 0; c0++)
228     med -= t[c0];
229     if (c0 > (box[pri][0]+box[pri][1])>>1) /* if past the midpoint */
230     c0--; /* part left of median */
231     return(set_branch(pri,c0));
232     #undef c0
233     }
