1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Copy data into a holodeck file |
9 |
10 |
11 |
#include "holo.h" |
12 |
#include "view.h" |
13 |
#include "resolu.h" |
14 |
15 |
int checkdepth = 1; /* check depth (!-f option)? */ |
16 |
int checkrepeats = 0; /* check for repeats (-c option)? */ |
17 |
int frompicz; /* input from pictures & depth-buffers? */ |
18 |
int noutsects; /* number of output sections */ |
19 |
char obstr, unobstr; /* flag pointer values */ |
20 |
21 |
char *progname; /* global argv[0] */ |
22 |
23 |
24 |
main(argc, argv) |
25 |
int argc; |
26 |
char *argv[]; |
27 |
28 |
int i; |
29 |
30 |
progname = argv[0]; |
31 |
frompicz = -1; |
32 |
for (i = 2; i < argc && argv[i][0] == '-'; i++) |
33 |
switch (argv[i][1]) { |
34 |
case 'c': |
35 |
checkrepeats = 1; |
36 |
break; |
37 |
case 'f': |
38 |
checkdepth = 0; |
39 |
break; |
40 |
case 'h': |
41 |
frompicz = 0; |
42 |
break; |
43 |
case 'p': |
44 |
frompicz = 1; |
45 |
break; |
46 |
default: |
47 |
goto userr; |
48 |
49 |
if (i >= argc || frompicz < 0) |
50 |
goto userr; |
51 |
if (frompicz && (argc-i)%2) |
52 |
goto userr; |
53 |
noutsects = openholo(argv[1], 1); |
54 |
if (frompicz) |
55 |
for ( ; i < argc; i += 2) |
56 |
addpicz(argv[i], argv[i+1]); |
57 |
else |
58 |
for ( ; i < argc; i++) |
59 |
addholo(argv[i]); |
60 |
quit(0); |
61 |
userr: |
62 |
fprintf(stderr, "Usage: %s output.hdk [-c][-f] -h inp1.hdk ..\n", |
63 |
progname); |
64 |
fprintf(stderr, " Or: %s output.hdk [-c][-f] -pz inp1.pic inp1.zbf ..\n", |
65 |
progname); |
66 |
exit(1); |
67 |
68 |
69 |
70 |
#define H_BADF 01 |
71 |
#define H_OBST 02 |
72 |
#define H_OBSF 04 |
73 |
74 |
holheadline(s, hf) /* check holodeck header line */ |
75 |
register char *s; |
76 |
int *hf; |
77 |
78 |
char fmt[32]; |
79 |
80 |
if (formatval(fmt, s)) { |
81 |
if (strcmp(fmt, HOLOFMT)) |
82 |
*hf |= H_BADF; |
83 |
else |
84 |
*hf &= ~H_BADF; |
85 |
return; |
86 |
87 |
if (!strncmp(s, "OBSTRUCTIONS=", 13)) { |
88 |
s += 13; |
89 |
while (*s == ' ') s++; |
90 |
if (*s == 't' | *s == 'T') |
91 |
*hf |= H_OBST; |
92 |
else if (*s == 'f' | *s == 'F') |
93 |
*hf |= H_OBSF; |
94 |
else |
95 |
error(WARNING, "bad OBSTRUCTIONS value in holodeck"); |
96 |
return; |
97 |
98 |
99 |
100 |
int |
101 |
openholo(fname, append) /* open existing holodeck file for i/o */ |
102 |
char *fname; |
103 |
int append; |
104 |
105 |
extern long ftell(); |
106 |
FILE *fp; |
107 |
int fd; |
108 |
int hflags = 0; |
109 |
long nextloc; |
110 |
int n; |
111 |
/* open holodeck file */ |
112 |
if ((fp = fopen(fname, append ? "r+" : "r")) == NULL) { |
113 |
sprintf(errmsg, "cannot open \"%s\" for %s", fname, |
114 |
append ? "appending" : "reading"); |
115 |
error(SYSTEM, errmsg); |
116 |
117 |
/* check header and magic number */ |
118 |
if (getheader(fp, holheadline, &hflags) < 0 || |
119 |
hflags&H_BADF || getw(fp) != HOLOMAGIC) { |
120 |
sprintf(errmsg, "file \"%s\" not in holodeck format", fname); |
121 |
error(USER, errmsg); |
122 |
123 |
fd = dup(fileno(fp)); /* dup file handle */ |
124 |
nextloc = ftell(fp); /* get stdio position */ |
125 |
fclose(fp); /* done with stdio */ |
126 |
for (n = 0; nextloc > 0L; n++) { /* initialize each section */ |
127 |
lseek(fd, nextloc, 0); |
128 |
read(fd, (char *)&nextloc, sizeof(nextloc)); |
129 |
hdinit(fd, NULL)->priv = hflags&H_OBST ? &obstr : |
130 |
hflags&H_OBSF ? &unobstr : (char *)NULL; |
131 |
132 |
return(n); |
133 |
134 |
135 |
#undef H_BADF |
136 |
#undef H_OBST |
137 |
#undef H_OBSF |
138 |
139 |
140 |
addray(ro, rd, d, cv) /* add a ray to our output holodeck */ |
141 |
FVECT ro, rd; |
142 |
double d; |
143 |
COLR cv; |
144 |
145 |
int sn, bi, n; |
146 |
register HOLO *hp; |
147 |
GCOORD gc[2]; |
148 |
BYTE rr[2][2]; |
149 |
BEAM *bp; |
150 |
double d0, d1; |
151 |
unsigned dc; |
152 |
register RAYVAL *rv; |
153 |
/* check each output section */ |
154 |
for (sn = noutsects; sn--; ) { |
155 |
hp = hdlist[sn]; |
156 |
d0 = hdinter(gc, rr, &d1, hp, ro, rd); |
157 |
if (d <= d0 || d1 < -0.001) |
158 |
continue; /* missed section */ |
159 |
if (checkdepth) { /* check depth */ |
160 |
if (hp->priv == &obstr && d0 < -0.001) |
161 |
continue; /* ray starts too late */ |
162 |
if (hp->priv == &unobstr && d < 0.999*d1) |
163 |
continue; /* ray ends too soon */ |
164 |
165 |
dc = hdcode(hp, d-d0); |
166 |
bi = hdbindex(hp, gc); /* check for duplicates */ |
167 |
if (checkrepeats && (bp = hdgetbeam(hp, bi)) != NULL) { |
168 |
for (n = bp->nrm, rv = hdbray(bp); n--; rv++) |
169 |
if (rv->d == dc && |
170 |
rv->r[0][0] == rr[0][0] && |
171 |
rv->r[0][1] == rr[0][1] && |
172 |
rv->r[1][0] == rr[1][0] && |
173 |
rv->r[1][1] == rr[1][1]) |
174 |
break; |
175 |
if (n >= 0) |
176 |
continue; /* found a matching ray */ |
177 |
178 |
rv = hdnewrays(hp, bi, 1); |
179 |
rv->d = dc; |
180 |
rv->r[0][0] = rr[0][0]; rv->r[0][1] = rr[0][1]; |
181 |
rv->r[1][0] = rr[1][0]; rv->r[1][1] = rr[1][1]; |
182 |
copycolr(rv->v, cv); |
183 |
184 |
185 |
186 |
187 |
addholo(hdf) /* add a holodeck file */ |
188 |
char *hdf; |
189 |
190 |
int fd; |
191 |
192 |
register BEAM *bp; |
193 |
register HDBEAMI *hbl; |
194 |
GCOORD gc[2]; |
195 |
FVECT ro, rd; |
196 |
double d; |
197 |
int i, j; |
198 |
register int k; |
199 |
/* open the holodeck for reading */ |
200 |
openholo(hdf, 0); |
201 |
fd = hdlist[noutsects]->fd; /* remember the file handle */ |
202 |
while ((hp = hdlist[noutsects]) != NULL) { /* load each section */ |
203 |
hbl = (HDBEAMI *)malloc(nbeams(hp)*sizeof(HDBEAMI)); |
204 |
if (hbl == NULL) |
205 |
error(SYSTEM, "out of memory in addholo"); |
206 |
for (j = nbeams(hp); j > 0; j--) { /* sort the beams */ |
207 |
hbl[j].h = hp; |
208 |
hbl[j].b = j; |
209 |
210 |
qsort((char *)hbl, nbeams(hp), sizeof(HDBEAMI), hdfilord); |
211 |
for (j = 0; j < nbeams(hp); j++) /* load each beam */ |
212 |
if ((bp = hdgetbeam(hp, hbl[j].b)) != NULL) { |
213 |
hdbcoord(gc, hp, hbl[j].b); |
214 |
for (k = bp->nrm; k--; ) { |
215 |
d = hdray(ro, rd, |
216 |
hp, gc, hdbray(bp)[k].r); |
217 |
if (hp->priv == &unobstr) |
218 |
VSUM(ro, ro, rd, d); |
219 |
else |
220 |
d = 0.; |
221 |
d = hddepth(hp, hdbray(bp)[k].d) - d; |
222 |
addray(ro, rd, d, hdbray(bp)[k].v); |
223 |
224 |
hdfreebeam(hp, hbl[j].b); /* free beam */ |
225 |
226 |
free((char *)hbl); /* free beam list */ |
227 |
hddone(hp); /* free the section */ |
228 |
229 |
close(fd); /* close the file */ |
230 |
231 |
232 |
233 |
struct phead { |
234 |
VIEW vw; |
235 |
double expos; |
236 |
short gotview; |
237 |
short badfmt; |
238 |
short altprims; |
239 |
240 |
241 |
242 |
picheadline(s, ph) /* process picture header line */ |
243 |
char *s; |
244 |
struct phead *ph; |
245 |
246 |
char fmt[32]; |
247 |
248 |
249 |
ph->badfmt = strcmp(fmt, COLRFMT); |
250 |
return; |
251 |
252 |
if (isprims(s)) { |
253 |
ph->altprims++; /* don't want to deal with this */ |
254 |
return; |
255 |
256 |
if (isexpos(s)) { |
257 |
ph->expos *= exposval(s); |
258 |
return; |
259 |
260 |
if (isview(s)) { |
261 |
ph->gotview += sscanview(&ph->vw, s); |
262 |
return; |
263 |
264 |
265 |
266 |
267 |
addpicz(pcf, zbf) /* add a picture + depth-buffer */ |
268 |
char *pcf, *zbf; |
269 |
270 |
FILE *pfp; |
271 |
int zfd; |
272 |
COLR *cscn; |
273 |
float *zscn; |
274 |
struct phead phd; |
275 |
int eshft; |
276 |
double emult; |
277 |
RESOLU prs; |
278 |
FLOAT vl[2]; |
279 |
FVECT ro, rd; |
280 |
double aftd; |
281 |
COLOR ctmp; |
282 |
int j; |
283 |
register int i; |
284 |
/* open files */ |
285 |
if ((pfp = fopen(pcf, "r")) == NULL) { |
286 |
sprintf(errmsg, "cannot open picture file \"%s\"", pcf); |
287 |
error(SYSTEM, pcf); |
288 |
289 |
if ((zfd = open(zbf, O_RDONLY)) < 0) { |
290 |
sprintf(errmsg, "cannot open depth file \"%s\"", zbf); |
291 |
292 |
293 |
/* load picture header */ |
294 |
copystruct(&phd.vw, &stdview); |
295 |
phd.expos = 1.0; |
296 |
phd.badfmt = phd.gotview = phd.altprims = 0; |
297 |
if (getheader(pfp, picheadline, &phd) < 0 || |
298 |
phd.badfmt || !fgetsresolu(&prs, pfp)) { |
299 |
sprintf(errmsg, "bad format for picture file \"%s\"", pcf); |
300 |
301 |
302 |
if (!phd.gotview || setview(&phd.vw) != NULL) { |
303 |
sprintf(errmsg, "missing/illegal view in picture \"%s\"", |
304 |
pcf); |
305 |
306 |
307 |
if (phd.altprims) { |
308 |
sprintf(errmsg, "ignoring primary values in picture \"%s\"", |
309 |
pcf); |
310 |
error(WARNING, errmsg); |
311 |
312 |
/* figure out what to do about exposure */ |
313 |
if (phd.expos < 0.99 | phd.expos > 1.01) { |
314 |
emult = -log(phd.expos)/log(2.); |
315 |
eshft = emult >= 0. ? emult+.5 : emult-.5; |
316 |
emult -= (double)eshft; |
317 |
if (emult <= 0.01 & emult >= -0.01) |
318 |
emult = -1.; |
319 |
else { |
320 |
emult = 1./phd.expos; |
321 |
eshft = 0; |
322 |
323 |
} else { |
324 |
emult = -1.; |
325 |
eshft = 0; |
326 |
327 |
/* allocate buffers */ |
328 |
cscn = (COLR *)malloc(scanlen(&prs)*sizeof(COLR)); |
329 |
zscn = (float *)malloc(scanlen(&prs)*sizeof(float)); |
330 |
if (cscn == NULL | zscn == NULL) |
331 |
error(SYSTEM, "out of memory in addpicz"); |
332 |
/* read and process each scanline */ |
333 |
for (j = 0; j < numscans(&prs); j++) { |
334 |
i = scanlen(&prs); /* read colrs */ |
335 |
if (freadcolrs(cscn, i, pfp) < 0) { |
336 |
sprintf(errmsg, "error reading picture \"%s\"", pcf); |
337 |
338 |
339 |
if (eshft) /* shift exposure */ |
340 |
shiftcolrs(cscn, i, eshft); |
341 |
i *= sizeof(float); /* read depth */ |
342 |
if (read(zfd, (char *)zscn, i) != i) { |
343 |
sprintf(errmsg, "error reading depth file \"%s\"", zbf); |
344 |
345 |
346 |
for (i = scanlen(&prs); i--; ) { /* do each pixel */ |
347 |
pix2loc(vl, &prs, i, j); |
348 |
aftd = viewray(ro, rd, &phd.vw, vl[0], vl[1]); |
349 |
if (aftd < -FTINY) |
350 |
continue; /* off view */ |
351 |
if (aftd > FTINY && zscn[i] > aftd) |
352 |
continue; /* aft clipped */ |
353 |
if (emult > 0.) { /* whatta pain */ |
354 |
colr_color(ctmp, cscn[i]); |
355 |
scalecolor(ctmp, emult); |
356 |
setcolr(cscn[i], colval(ctmp,RED), |
357 |
colval(ctmp,GRN), colval(ctmp,BLU)); |
358 |
359 |
addray(ro, rd, (double)zscn[i], cscn[i]); |
360 |
361 |
362 |
/* clean up */ |
363 |
free((char *)cscn); |
364 |
free((char *)zscn); |
365 |
fclose(pfp); |
366 |
close(zfd); |
367 |
368 |
369 |
370 |
eputs(s) /* put error message to stderr */ |
371 |
register char *s; |
372 |
373 |
static int midline = 0; |
374 |
375 |
if (!*s) |
376 |
return; |
377 |
if (!midline++) { /* prepend line with program name */ |
378 |
fputs(progname, stderr); |
379 |
fputs(": ", stderr); |
380 |
381 |
fputs(s, stderr); |
382 |
if (s[strlen(s)-1] == '\n') { |
383 |
fflush(stderr); |
384 |
midline = 0; |
385 |
386 |
387 |
388 |
389 |
quit(code) /* exit the program gracefully */ |
390 |
int code; |
391 |
392 |
hdsync(NULL, 1); /* write out any buffered data */ |
393 |
exit(code); |
394 |
