root/radiance/ray/src/hd/rhcopy.c
Revision: 3.13
Committed: Mon Feb 1 10:22:46 1999 UTC (25 years, 3 months ago) by gwlarson
Changes since 3.12: +2 -1 lines
made caching code slightly more efficient
1 /* Copyright (c) 1999 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Copy data into a holodeck file
9 */
10
11 #include "holo.h"
12 #include "view.h"
13 #include "resolu.h"
14
15 #ifndef BKBSIZE
16 #define BKBSIZE 256 /* beam clump size (kilobytes) */
17 #endif
18
19 int checkdepth = 1; /* check depth (!-f option)? */
20 int checkrepeats = 0; /* check for repeats (-c option)? */
21 int frompicz; /* input from pictures & depth-buffers? */
22 int noutsects; /* number of output sections */
23 char obstr, unobstr; /* flag pointer values */
24
25 char *progname; /* global argv[0] */
26
27
28 main(argc, argv)
29 int argc;
30 char *argv[];
31 {
32 int i;
33
34 progname = argv[0];
35 frompicz = -1;
36 for (i = 2; i < argc && argv[i][0] == '-'; i++)
37 switch (argv[i][1]) {
38 case 'u':
39 checkrepeats = 1;
40 break;
41 case 'd':
42 checkdepth = 0;
43 break;
44 case 'h':
45 frompicz = 0;
46 break;
47 case 'p':
48 frompicz = 1;
49 break;
50 default:
51 goto userr;
52 }
53 if (i >= argc || frompicz < 0)
54 goto userr;
55 if (frompicz && (argc-i)%2)
56 goto userr;
57 noutsects = openholo(argv[1], 1);
58 if (frompicz) {
59 for ( ; i < argc; i += 2)
60 addpicz(argv[i], argv[i+1]);
61 } else {
62 if (BKBSIZE*1024*1.5 > hdcachesize)
63 hdcachesize = BKBSIZE*1024*1.5;
64 for ( ; i < argc; i++)
65 addholo(argv[i]);
66 }
67 quit(0);
68 userr:
69 fprintf(stderr, "Usage: %s output.hdk [-u][-d] -h inp1.hdk ..\n",
70 progname);
71 fprintf(stderr, " Or: %s output.hdk [-u][-d] -p inp1.pic inp1.zbf ..\n",
72 progname);
73 exit(1);
74 }
75
76
77 #define H_BADF 01
78 #define H_OBST 02
79 #define H_OBSF 04
80
81 int
82 holheadline(s, hf) /* check holodeck header line */
83 register char *s;
84 int *hf;
85 {
86 char fmt[32];
87
88 if (formatval(fmt, s)) {
89 if (strcmp(fmt, HOLOFMT))
90 *hf |= H_BADF;
91 else
92 *hf &= ~H_BADF;
93 return(0);
94 }
95 if (!strncmp(s, "OBSTRUCTIONS=", 13)) {
96 s += 13;
97 while (*s == ' ') s++;
98 if (*s == 't' | *s == 'T')
99 *hf |= H_OBST;
100 else if (*s == 'f' | *s == 'F')
101 *hf |= H_OBSF;
102 else
103 error(WARNING, "bad OBSTRUCTIONS value in holodeck");
104 return(0);
105 }
106 return(0);
107 }
108
109 int
110 openholo(fname, append) /* open existing holodeck file for i/o */
111 char *fname;
112 int append;
113 {
114 extern long ftell();
115 FILE *fp;
116 int fd;
117 int hflags = 0;
118 long nextloc;
119 int n;
120 /* open holodeck file */
121 if ((fp = fopen(fname, append ? "r+" : "r")) == NULL) {
122 sprintf(errmsg, "cannot open \"%s\" for %s", fname,
123 append ? "appending" : "reading");
124 error(SYSTEM, errmsg);
125 }
126 /* check header and magic number */
127 if (getheader(fp, holheadline, &hflags) < 0 ||
128 hflags&H_BADF || getw(fp) != HOLOMAGIC) {
129 sprintf(errmsg, "file \"%s\" not in holodeck format", fname);
130 error(USER, errmsg);
131 }
132 fd = dup(fileno(fp)); /* dup file handle */
133 nextloc = ftell(fp); /* get stdio position */
134 fclose(fp); /* done with stdio */
135 for (n = 0; nextloc > 0L; n++) { /* initialize each section */
136 lseek(fd, nextloc, 0);
137 read(fd, (char *)&nextloc, sizeof(nextloc));
138 hdinit(fd, NULL)->priv = hflags&H_OBST ? &obstr :
139 hflags&H_OBSF ? &unobstr : (char *)NULL;
140 }
141 return(n);
142 }
143
144 #undef H_BADF
145 #undef H_OBST
146 #undef H_OBSF
147
148
149 addray(ro, rd, d, cv) /* add a ray to our output holodeck */
150 FVECT ro, rd;
151 double d;
152 COLR cv;
153 {
154 int sn, bi, n;
155 register HOLO *hp;
156 GCOORD gc[2];
157 BYTE rr[2][2];
158 BEAM *bp;
159 double d0, d1;
160 unsigned dc;
161 register RAYVAL *rv;
162 /* check each output section */
163 for (sn = noutsects; sn--; ) {
164 hp = hdlist[sn];
165 d0 = hdinter(gc, rr, &d1, hp, ro, rd);
166 if (d <= d0 || d1 < -0.001)
167 continue; /* missed section */
168 if (checkdepth) { /* check depth */
169 if (hp->priv == &obstr && d0 < -0.001)
170 continue; /* ray starts too late */
171 if (hp->priv == &unobstr && d < 0.999*d1)
172 continue; /* ray ends too soon */
173 }
174 dc = hdcode(hp, d-d0);
175 bi = hdbindex(hp, gc); /* check for duplicates */
176 if (checkrepeats && (bp = hdgetbeam(hp, bi)) != NULL) {
177 for (n = bp->nrm, rv = hdbray(bp); n--; rv++)
178 if ((hp->priv != NULL || rv->d == dc) &&
179 rv->r[0][0] == rr[0][0] &&
180 rv->r[0][1] == rr[0][1] &&
181 rv->r[1][0] == rr[1][0] &&
182 rv->r[1][1] == rr[1][1])
183 break;
184 if (n >= 0)
185 continue; /* found a matching ray */
186 }
187 rv = hdnewrays(hp, bi, 1);
188 rv->d = dc;
189 rv->r[0][0] = rr[0][0]; rv->r[0][1] = rr[0][1];
190 rv->r[1][0] = rr[1][0]; rv->r[1][1] = rr[1][1];
191 copycolr(rv->v, cv);
192 }
193 }
194
195
196 static BEAMI *beamdir;
197
198 static int
199 bpcmp(b1p, b2p) /* compare beam positions on disk */
200 int *b1p, *b2p;
201 {
202 register long pdif = beamdir[*b1p].fo - beamdir[*b2p].fo;
203
204 if (pdif > 0L) return(1);
205 if (pdif < 0L) return(-1);
206 return(0);
207 }
208
209 static int
210 addclump(hp, bq, nb) /* transfer the given clump and free */
211 HOLO *hp;
212 int *bq, nb;
213 {
214 GCOORD gc[2];
215 FVECT ro, rd;
216 double d;
217 int i;
218 register int k;
219 register BEAM *bp;
220 /* sort based on file position */
221 beamdir = hp->bi;
222 qsort((char *)bq, nb, sizeof(*bq), bpcmp);
223 /* transfer each beam */
224 for (i = 0; i < nb; i++) {
225 bp = hdgetbeam(hp, bq[i]);
226 hdbcoord(gc, hp, bq[i]);
227 /* add each ray to output */
228 for (k = bp->nrm; k--; ) {
229 d = hdray(ro, rd, hp, gc, hdbray(bp)[k].r);
230 if (hp->priv == &unobstr)
231 VSUM(ro, ro, rd, d);
232 else
233 d = 0.;
234 d = hddepth(hp, hdbray(bp)[k].d) - d;
235 addray(ro, rd, d, hdbray(bp)[k].v);
236 }
237 hdfreebeam(hp, bq[i]); /* free the beam */
238 }
239 hdfreebeam(NULL, 0); /* write & free clump */
240 return(0);
241 }
242
243 addholo(hdf) /* add a holodeck file */
244 char *hdf;
245 {
246 int fd;
247 /* open the holodeck for reading */
248 openholo(hdf, 0);
249 fd = hdlist[noutsects]->fd; /* remember the file handle */
250 while (hdlist[noutsects] != NULL) { /* load each section */
251 /* clump the beams */
252 clumpbeams(hdlist[noutsects], 0, BKBSIZE*1024, addclump);
253 hddone(hdlist[noutsects]); /* free the section */
254 }
255 close(fd); /* close input file */
256 hdflush(NULL); /* flush output */
257 }
258
259
260 struct phead {
261 VIEW vw;
262 double expos;
263 short gotview;
264 short badfmt;
265 short altprims;
266 };
267
268
269 int
270 picheadline(s, ph) /* process picture header line */
271 char *s;
272 struct phead *ph;
273 {
274 char fmt[32];
275
276 if (formatval(fmt, s)) {
277 ph->badfmt = strcmp(fmt, COLRFMT);
278 return(0);
279 }
280 if (isprims(s)) {
281 ph->altprims++; /* don't want to deal with this */
282 return(0);
283 }
284 if (isexpos(s)) {
285 ph->expos *= exposval(s);
286 return(0);
287 }
288 if (isview(s)) {
289 ph->gotview += sscanview(&ph->vw, s);
290 return(0);
291 }
292 return(0);
293 }
294
295
296 addpicz(pcf, zbf) /* add a picture + depth-buffer */
297 char *pcf, *zbf;
298 {
299 FILE *pfp;
300 int zfd;
301 COLR *cscn;
302 float *zscn;
303 struct phead phd;
304 int eshft;
305 double emult;
306 RESOLU prs;
307 FLOAT vl[2];
308 FVECT ro, rd;
309 double aftd;
310 COLOR ctmp;
311 int j;
312 register int i;
313 /* open files */
314 if ((pfp = fopen(pcf, "r")) == NULL) {
315 sprintf(errmsg, "cannot open picture file \"%s\"", pcf);
316 error(SYSTEM, pcf);
317 }
318 if ((zfd = open(zbf, O_RDONLY)) < 0) {
319 sprintf(errmsg, "cannot open depth file \"%s\"", zbf);
320 error(SYSTEM, pcf);
321 }
322 /* load picture header */
323 copystruct(&phd.vw, &stdview);
324 phd.expos = 1.0;
325 phd.badfmt = phd.gotview = phd.altprims = 0;
326 if (getheader(pfp, picheadline, &phd) < 0 ||
327 phd.badfmt || !fgetsresolu(&prs, pfp)) {
328 sprintf(errmsg, "bad format for picture file \"%s\"", pcf);
329 error(USER, errmsg);
330 }
331 if (!phd.gotview || setview(&phd.vw) != NULL) {
332 sprintf(errmsg, "missing/illegal view in picture \"%s\"",
333 pcf);
334 error(USER, errmsg);
335 }
336 if (phd.altprims) {
337 sprintf(errmsg, "ignoring primary values in picture \"%s\"",
338 pcf);
339 error(WARNING, errmsg);
340 }
341 /* figure out what to do about exposure */
342 if (phd.expos < 0.99 | phd.expos > 1.01) {
343 emult = -log(phd.expos)/log(2.);
344 eshft = emult >= 0. ? emult+.5 : emult-.5;
345 emult -= (double)eshft;
346 if (emult <= 0.01 & emult >= -0.01)
347 emult = -1.;
348 else {
349 emult = 1./phd.expos;
350 eshft = 0;
351 }
352 } else {
353 emult = -1.;
354 eshft = 0;
355 }
356 /* allocate buffers */
357 cscn = (COLR *)malloc(scanlen(&prs)*sizeof(COLR));
358 zscn = (float *)malloc(scanlen(&prs)*sizeof(float));
359 if (cscn == NULL | zscn == NULL)
360 error(SYSTEM, "out of memory in addpicz");
361 /* read and process each scanline */
362 for (j = 0; j < numscans(&prs); j++) {
363 i = scanlen(&prs); /* read colrs */
364 if (freadcolrs(cscn, i, pfp) < 0) {
365 sprintf(errmsg, "error reading picture \"%s\"", pcf);
366 error(USER, errmsg);
367 }
368 if (eshft) /* shift exposure */
369 shiftcolrs(cscn, i, eshft);
370 i *= sizeof(float); /* read depth */
371 if (read(zfd, (char *)zscn, i) != i) {
372 sprintf(errmsg, "error reading depth file \"%s\"", zbf);
373 error(USER, errmsg);
374 }
375 for (i = scanlen(&prs); i--; ) { /* do each pixel */
376 pix2loc(vl, &prs, i, j);
377 aftd = viewray(ro, rd, &phd.vw, vl[0], vl[1]);
378 if (aftd < -FTINY)
379 continue; /* off view */
380 if (aftd > FTINY && zscn[i] > aftd)
381 continue; /* aft clipped */
382 if (emult > 0.) { /* whatta pain */
383 colr_color(ctmp, cscn[i]);
384 scalecolor(ctmp, emult);
385 setcolr(cscn[i], colval(ctmp,RED),
386 colval(ctmp,GRN), colval(ctmp,BLU));
387 }
388 addray(ro, rd, (double)zscn[i], cscn[i]);
389 }
390 }
391 /* write output and free beams */
392 hdflush(NULL);
393 /* clean up */
394 free((char *)cscn);
395 free((char *)zscn);
396 fclose(pfp);
397 close(zfd);
398 }
399
400
401 eputs(s) /* put error message to stderr */
402 register char *s;
403 {
404 static int midline = 0;
405
406 if (!*s)
407 return;
408 if (!midline++) { /* prepend line with program name */
409 fputs(progname, stderr);
410 fputs(": ", stderr);
411 }
412 fputs(s, stderr);
413 if (s[strlen(s)-1] == '\n') {
414 fflush(stderr);
415 midline = 0;
416 }
417 }
418
419
420 quit(code) /* exit the program gracefully */
421 int code;
422 {
423 hdsync(NULL, 1); /* write out any buffered data */
424 exit(code);
425 }
