--- ray/src/hd/rhcopy.c 1998/01/07 09:23:02 3.5 +++ ray/src/hd/rhcopy.c 2003/05/29 16:26:22 3.16 @@ -1,19 +1,19 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rhcopy.c,v 3.16 2003/05/29 16:26:22 greg Exp $"; #endif - /* * Copy data into a holodeck file */ #include "holo.h" #include "view.h" -#include "resolu.h" -int checkdepth = 1; /* check depth (!-f option)? */ -int checkrepeats = 0; /* check for repeats (-c option)? */ +#ifndef BKBSIZE +#define BKBSIZE 256 /* beam clump size (kilobytes) */ +#endif + +int checkdepth = 1; /* check depth (!-d option)? */ +int checkrepeats = 0; /* check for repeats (-u option)? */ int frompicz; /* input from pictures & depth-buffers? */ int noutsects; /* number of output sections */ char obstr, unobstr; /* flag pointer values */ @@ -31,10 +31,10 @@ char *argv[]; frompicz = -1; for (i = 2; i < argc && argv[i][0] == '-'; i++) switch (argv[i][1]) { - case 'c': + case 'u': checkrepeats = 1; break; - case 'f': + case 'd': checkdepth = 0; break; case 'h': @@ -51,17 +51,20 @@ char *argv[]; if (frompicz && (argc-i)%2) goto userr; noutsects = openholo(argv[1], 1); - if (frompicz) + if (frompicz) { for ( ; i < argc; i += 2) addpicz(argv[i], argv[i+1]); - else + } else { + if (BKBSIZE*1024*1.5 > hdcachesize) + hdcachesize = BKBSIZE*1024*1.5; for ( ; i < argc; i++) addholo(argv[i]); + } quit(0); userr: - fprintf(stderr, "Usage: %s output.hdk [-c][-f] -h inp1.hdk ..\n", + fprintf(stderr, "Usage: %s output.hdk [-u][-d] -h inp1.hdk ..\n", progname); - fprintf(stderr, " Or: %s output.hdk [-c][-f] -pz inp1.pic inp1.zbf ..\n", + fprintf(stderr, " Or: %s output.hdk [-u][-d] -p inp1.pic inp1.zbf ..\n", progname); exit(1); } @@ -71,6 +74,7 @@ userr: #define H_OBST 02 #define H_OBSF 04 +int holheadline(s, hf) /* check holodeck header line */ register char *s; int *hf; @@ -82,7 +86,7 @@ int *hf; *hf |= H_BADF; else *hf &= ~H_BADF; - return; + return(0); } if (!strncmp(s, "OBSTRUCTIONS=", 13)) { s += 13; @@ -93,8 +97,9 @@ int *hf; *hf |= H_OBSF; else error(WARNING, "bad OBSTRUCTIONS value in holodeck"); - return; + return(0); } + return(0); } int @@ -102,7 +107,6 @@ openholo(fname, append) /* open existing holodeck fil char *fname; int append; { - extern long ftell(); FILE *fp; int fd; int hflags = 0; @@ -115,7 +119,7 @@ int append; error(SYSTEM, errmsg); } /* check header and magic number */ - if (getheader(fp, holheadline, &hflags) < 0 || + if (getheader(fp, holheadline, (char *)&hflags) < 0 || hflags&H_BADF || getw(fp) != HOLOMAGIC) { sprintf(errmsg, "file \"%s\" not in holodeck format", fname); error(USER, errmsg); @@ -124,7 +128,7 @@ int append; nextloc = ftell(fp); /* get stdio position */ fclose(fp); /* done with stdio */ for (n = 0; nextloc > 0L; n++) { /* initialize each section */ - lseek(fd, nextloc, 0); + lseek(fd, (off_t)nextloc, 0); read(fd, (char *)&nextloc, sizeof(nextloc)); hdinit(fd, NULL)->priv = hflags&H_OBST ? &obstr : hflags&H_OBSF ? &unobstr : (char *)NULL; @@ -166,7 +170,7 @@ COLR cv; bi = hdbindex(hp, gc); /* check for duplicates */ if (checkrepeats && (bp = hdgetbeam(hp, bi)) != NULL) { for (n = bp->nrm, rv = hdbray(bp); n--; rv++) - if (rv->d == dc && + if ((hp->priv != NULL || rv->d == dc) && rv->r[0][0] == rr[0][0] && rv->r[0][1] == rr[0][1] && rv->r[1][0] == rr[1][0] && @@ -184,49 +188,66 @@ COLR cv; } -addholo(hdf) /* add a holodeck file */ -char *hdf; +static BEAMI *beamdir; + +static int +bpcmp(b1p, b2p) /* compare beam positions on disk */ +int *b1p, *b2p; { - int fd; - register HOLO *hp; - register BEAM *bp; - register HDBEAMI *hbl; + register off_t pdif = beamdir[*b1p].fo - beamdir[*b2p].fo; + + if (pdif > 0L) return(1); + if (pdif < 0L) return(-1); + return(0); +} + +static int +addclump(hp, bq, nb) /* transfer the given clump and free */ +HOLO *hp; +int *bq, nb; +{ GCOORD gc[2]; FVECT ro, rd; double d; - int i, j; + int i; register int k; + register BEAM *bp; + /* sort based on file position */ + beamdir = hp->bi; + qsort((char *)bq, nb, sizeof(*bq), bpcmp); + /* transfer each beam */ + for (i = 0; i < nb; i++) { + bp = hdgetbeam(hp, bq[i]); + hdbcoord(gc, hp, bq[i]); + /* add each ray to output */ + for (k = bp->nrm; k--; ) { + d = hdray(ro, rd, hp, gc, hdbray(bp)[k].r); + if (hp->priv == &unobstr) + VSUM(ro, ro, rd, d); + else + d = 0.; + d = hddepth(hp, hdbray(bp)[k].d) - d; + addray(ro, rd, d, hdbray(bp)[k].v); + } + hdfreebeam(hp, bq[i]); /* free the beam */ + } + return(0); +} + +addholo(hdf) /* add a holodeck file */ +char *hdf; +{ + int fd; /* open the holodeck for reading */ openholo(hdf, 0); fd = hdlist[noutsects]->fd; /* remember the file handle */ - while ((hp = hdlist[noutsects]) != NULL) { /* load each section */ - hbl = (HDBEAMI *)malloc(nbeams(hp)*sizeof(HDBEAMI)); - if (hbl == NULL) - error(SYSTEM, "out of memory in addholo"); - for (j = nbeams(hp); j > 0; j--) { /* sort the beams */ - hbl[j].h = hp; - hbl[j].b = j; - } - qsort((char *)hbl, nbeams(hp), sizeof(HDBEAMI), hdfilord); - for (j = 0; j < nbeams(hp); j++) /* load each beam */ - if ((bp = hdgetbeam(hp, hbl[j].b)) != NULL) { - hdbcoord(gc, hp, hbl[j].b); - for (k = bp->nrm; k--; ) { - d = hdray(ro, rd, - hp, gc, hdbray(bp)[k].r); - if (hp->priv == &unobstr) - VSUM(ro, ro, rd, d); - else - d = 0.; - d = hddepth(hp, hdbray(bp)[k].d) - d; - addray(ro, rd, d, hdbray(bp)[k].v); - } - hdfreebeam(hp, hbl[j].b); /* free beam */ - } - free((char *)hbl); /* free beam list */ - hddone(hp); /* free the section */ + while (hdlist[noutsects] != NULL) { /* load each section */ + /* clump the beams */ + clumpbeams(hdlist[noutsects], 0, BKBSIZE*1024, addclump); + hddone(hdlist[noutsects]); /* free the section */ } - close(fd); /* close the file */ + close(fd); /* close input file */ + hdflush(NULL); /* flush output */ } @@ -239,6 +260,7 @@ struct phead { }; +int picheadline(s, ph) /* process picture header line */ char *s; struct phead *ph; @@ -247,20 +269,21 @@ struct phead *ph; if (formatval(fmt, s)) { ph->badfmt = strcmp(fmt, COLRFMT); - return; + return(0); } if (isprims(s)) { ph->altprims++; /* don't want to deal with this */ - return; + return(0); } if (isexpos(s)) { ph->expos *= exposval(s); - return; + return(0); } if (isview(s)) { ph->gotview += sscanview(&ph->vw, s); - return; + return(0); } + return(0); } @@ -294,7 +317,7 @@ char *pcf, *zbf; copystruct(&phd.vw, &stdview); phd.expos = 1.0; phd.badfmt = phd.gotview = phd.altprims = 0; - if (getheader(pfp, picheadline, &phd) < 0 || + if (getheader(pfp, picheadline, (char *)&phd) < 0 || phd.badfmt || !fgetsresolu(&prs, pfp)) { sprintf(errmsg, "bad format for picture file \"%s\"", pcf); error(USER, errmsg); @@ -359,14 +382,17 @@ char *pcf, *zbf; addray(ro, rd, (double)zscn[i], cscn[i]); } } + /* write output and free beams */ + hdflush(NULL); /* clean up */ - free((char *)cscn); - free((char *)zscn); + free((void *)cscn); + free((void *)zscn); fclose(pfp); close(zfd); } +void eputs(s) /* put error message to stderr */ register char *s; { @@ -386,6 +412,7 @@ register char *s; } +void quit(code) /* exit the program gracefully */ int code; {
