--- ray/src/hd/rhcopy.c 2004/01/01 11:21:55 3.22 +++ ray/src/hd/rhcopy.c 2004/01/02 11:42:01 3.23 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rhcopy.c,v 3.22 2004/01/01 11:21:55 schorsch Exp $"; +static const char RCSid[] = "$Id: rhcopy.c,v 3.23 2004/01/02 11:42:01 schorsch Exp $"; #endif /* * Copy data into a holodeck file @@ -31,11 +31,11 @@ struct phead { }; static int openholo(char *fname, int append); static void addray(FVECT ro, FVECT rd, double d, COLR cv); -static int holheadline(char *s, int *hf); +static gethfunc holheadline; static int bpcmp(const void *b1p, const void *b2p); static int addclump(HOLO *hp, int *bq, int nb); static void addholo(char *hdf); -static int picheadline(char *s, struct phead *ph); +static gethfunc picheadline; static void addpicz(char *pcf, char *zbf); @@ -95,13 +95,14 @@ userr: #define H_OBST 02 #define H_OBSF 04 -int +static int holheadline( /* check holodeck header line */ register char *s, - int *hf + void *vhf ) { char fmt[32]; + int *hf = vhf; if (formatval(fmt, s)) { if (strcmp(fmt, HOLOFMT)) @@ -142,7 +143,7 @@ openholo( /* open existing holodeck file for i/o */ error(SYSTEM, errmsg); } /* check header and magic number */ - if (getheader(fp, holheadline, (char *)&hflags) < 0 || + if (getheader(fp, holheadline, &hflags) < 0 || hflags&H_BADF || getw(fp) != HOLOMAGIC) { sprintf(errmsg, "file \"%s\" not in holodeck format", fname); error(USER, errmsg); @@ -285,13 +286,14 @@ addholo( /* add a holodeck file */ -int +static int picheadline( /* process picture header line */ char *s, - struct phead *ph + void *vph ) { char fmt[32]; + struct phead *ph = vph; if (formatval(fmt, s)) { ph->badfmt = strcmp(fmt, COLRFMT); @@ -346,7 +348,7 @@ addpicz( /* add a picture + depth-buffer */ phd.vw = stdview; phd.expos = 1.0; phd.badfmt = phd.gotview = phd.altprims = 0; - if (getheader(pfp, picheadline, (char *)&phd) < 0 || + if (getheader(pfp, picheadline, &phd) < 0 || phd.badfmt || !fgetsresolu(&prs, pfp)) { sprintf(errmsg, "bad format for picture file \"%s\"", pcf); error(USER, errmsg);
