--- ray/src/hd/rhcopy.c 1997/12/18 09:33:42 3.1 +++ ray/src/hd/rhcopy.c 1998/01/07 09:23:02 3.5 @@ -12,9 +12,11 @@ static char SCCSid[] = "$SunId$ SGI"; #include "view.h" #include "resolu.h" +int checkdepth = 1; /* check depth (!-f option)? */ +int checkrepeats = 0; /* check for repeats (-c option)? */ int frompicz; /* input from pictures & depth-buffers? */ int noutsects; /* number of output sections */ -int obstructions = -1; /* interior obstructions allowed? */ +char obstr, unobstr; /* flag pointer values */ char *progname; /* global argv[0] */ @@ -26,56 +28,75 @@ char *argv[]; int i; progname = argv[0]; - if (argc < 4) + frompicz = -1; + for (i = 2; i < argc && argv[i][0] == '-'; i++) + switch (argv[i][1]) { + case 'c': + checkrepeats = 1; + break; + case 'f': + checkdepth = 0; + break; + case 'h': + frompicz = 0; + break; + case 'p': + frompicz = 1; + break; + default: + goto userr; + } + if (i >= argc || frompicz < 0) goto userr; - if (!strcmp(argv[2], "-h")) - frompicz = 0; - else if (!strcmp(argv[2], "-pz")) - frompicz = 1; - else + if (frompicz && (argc-i)%2) goto userr; - if (frompicz && (argc-3)%2) - goto userr; noutsects = openholo(argv[1], 1); if (frompicz) - for (i = 3; i < argc; i += 2) + for ( ; i < argc; i += 2) addpicz(argv[i], argv[i+1]); else - for (i = 3; i < argc; i++) + for ( ; i < argc; i++) addholo(argv[i]); quit(0); userr: - fprintf(stderr, "Usage: %s output.hdk -h inp1.hdk ..\n", progname); - fprintf(stderr, " Or: %s output.hdk -pz inp1.pic inp1.zbf ..\n", + fprintf(stderr, "Usage: %s output.hdk [-c][-f] -h inp1.hdk ..\n", progname); + fprintf(stderr, " Or: %s output.hdk [-c][-f] -pz inp1.pic inp1.zbf ..\n", + progname); exit(1); } -holheadline(s, bf) /* check holodeck header line */ +#define H_BADF 01 +#define H_OBST 02 +#define H_OBSF 04 + +holheadline(s, hf) /* check holodeck header line */ register char *s; -int *bf; +int *hf; { char fmt[32]; if (formatval(fmt, s)) { - *bf = strcmp(fmt, HOLOFMT); + if (strcmp(fmt, HOLOFMT)) + *hf |= H_BADF; + else + *hf &= ~H_BADF; return; } if (!strncmp(s, "OBSTRUCTIONS=", 13)) { s += 13; while (*s == ' ') s++; if (*s == 't' | *s == 'T') - obstructions = 1; + *hf |= H_OBST; else if (*s == 'f' | *s == 'F') - obstructions = 0; + *hf |= H_OBSF; else error(WARNING, "bad OBSTRUCTIONS value in holodeck"); return; } } - int openholo(fname, append) /* open existing holodeck file for i/o */ char *fname; @@ -84,8 +105,8 @@ int append; extern long ftell(); FILE *fp; int fd; - int badfmt = 0; - int4 nextloc; + int hflags = 0; + long nextloc; int n; /* open holodeck file */ if ((fp = fopen(fname, append ? "r+" : "r")) == NULL) { @@ -94,11 +115,8 @@ int append; error(SYSTEM, errmsg); } /* check header and magic number */ - if (append) - badfmt |= getheader(fp, holheadline, &badfmt) < 0; - else - badfmt = checkheader(fp, HOLOFMT, NULL) < 0; - if (badfmt || getw(fp) != HOLOMAGIC) { + if (getheader(fp, holheadline, &hflags) < 0 || + hflags&H_BADF || getw(fp) != HOLOMAGIC) { sprintf(errmsg, "file \"%s\" not in holodeck format", fname); error(USER, errmsg); } @@ -106,24 +124,31 @@ int append; nextloc = ftell(fp); /* get stdio position */ fclose(fp); /* done with stdio */ for (n = 0; nextloc > 0L; n++) { /* initialize each section */ - lseek(fd, (long)nextloc, 0); + lseek(fd, nextloc, 0); read(fd, (char *)&nextloc, sizeof(nextloc)); - hdinit(fd, NULL); + hdinit(fd, NULL)->priv = hflags&H_OBST ? &obstr : + hflags&H_OBSF ? &unobstr : (char *)NULL; } return(n); } +#undef H_BADF +#undef H_OBST +#undef H_OBSF + addray(ro, rd, d, cv) /* add a ray to our output holodeck */ FVECT ro, rd; double d; COLR cv; { - int sn; + int sn, bi, n; register HOLO *hp; GCOORD gc[2]; BYTE rr[2][2]; + BEAM *bp; double d0, d1; + unsigned dc; register RAYVAL *rv; /* check each output section */ for (sn = noutsects; sn--; ) { @@ -131,16 +156,30 @@ COLR cv; d0 = hdinter(gc, rr, &d1, hp, ro, rd); if (d <= d0 || d1 < -0.001) continue; /* missed section */ - if (obstructions > 0 && d0 < -0.001) - continue; /* ray starts too late */ - if (!obstructions && d < 0.999*d1) - continue; /* ray ends too soon */ - /* should we check for duplicates? */ - rv = hdnewrays(hp, hdbindex(hp, gc), 1); + if (checkdepth) { /* check depth */ + if (hp->priv == &obstr && d0 < -0.001) + continue; /* ray starts too late */ + if (hp->priv == &unobstr && d < 0.999*d1) + continue; /* ray ends too soon */ + } + dc = hdcode(hp, d-d0); + bi = hdbindex(hp, gc); /* check for duplicates */ + if (checkrepeats && (bp = hdgetbeam(hp, bi)) != NULL) { + for (n = bp->nrm, rv = hdbray(bp); n--; rv++) + if (rv->d == dc && + rv->r[0][0] == rr[0][0] && + rv->r[0][1] == rr[0][1] && + rv->r[1][0] == rr[1][0] && + rv->r[1][1] == rr[1][1]) + break; + if (n >= 0) + continue; /* found a matching ray */ + } + rv = hdnewrays(hp, bi, 1); + rv->d = dc; rv->r[0][0] = rr[0][0]; rv->r[0][1] = rr[0][1]; rv->r[1][0] = rr[1][0]; rv->r[1][1] = rr[1][1]; copycolr(rv->v, cv); - rv->d = hdcode(hp, d-d0); } } @@ -151,25 +190,40 @@ char *hdf; int fd; register HOLO *hp; register BEAM *bp; + register HDBEAMI *hbl; GCOORD gc[2]; FVECT ro, rd; double d; int i, j; register int k; - - openholo(hdf, 0); /* open the holodeck for reading */ + /* open the holodeck for reading */ + openholo(hdf, 0); fd = hdlist[noutsects]->fd; /* remember the file handle */ while ((hp = hdlist[noutsects]) != NULL) { /* load each section */ - for (j = nbeams(hp); j > 0; j--) /* load each beam */ - if ((bp = hdgetbeam(hp, j)) != NULL) { - hdbcoord(gc, hp, j); + hbl = (HDBEAMI *)malloc(nbeams(hp)*sizeof(HDBEAMI)); + if (hbl == NULL) + error(SYSTEM, "out of memory in addholo"); + for (j = nbeams(hp); j > 0; j--) { /* sort the beams */ + hbl[j].h = hp; + hbl[j].b = j; + } + qsort((char *)hbl, nbeams(hp), sizeof(HDBEAMI), hdfilord); + for (j = 0; j < nbeams(hp); j++) /* load each beam */ + if ((bp = hdgetbeam(hp, hbl[j].b)) != NULL) { + hdbcoord(gc, hp, hbl[j].b); for (k = bp->nrm; k--; ) { - hdray(ro, rd, hp, gc, hdbray(bp)[k].r); - d = hddepth(hp, hdbray(bp)[k].d); + d = hdray(ro, rd, + hp, gc, hdbray(bp)[k].r); + if (hp->priv == &unobstr) + VSUM(ro, ro, rd, d); + else + d = 0.; + d = hddepth(hp, hdbray(bp)[k].d) - d; addray(ro, rd, d, hdbray(bp)[k].v); } - hdfreebeam(hp, j); /* free the beam */ + hdfreebeam(hp, hbl[j].b); /* free beam */ } + free((char *)hbl); /* free beam list */ hddone(hp); /* free the section */ } close(fd); /* close the file */
