root/radiance/ray/src/hd/rhcopy.c
Mon Feb 6 22:40:21 2023 UTC (15 months, 2 weeks ago) by greg
Changes since 3.35: +2 -2 lines
Diff to previous 3.35 , to selected 3.10
Wed Nov 16 00:44:04 2022 UTC (18 months ago) by greg
Changes since 3.34: +32 -22 lines
Diff to previous 3.34 , to selected 3.10
perf(rhcopy): Improved performance by sorting beams according to disk location
Wed Nov 16 00:12:49 2022 UTC (18 months ago) by greg
Changes since 3.33: +374 -72 lines
Diff to previous 3.33 , to selected 3.10
feat(rhcopy): Added -i* and -o* options for reading and writing rays
Thu Nov 7 23:17:58 2019 UTC (4 years, 6 months ago) by greg
Changes since 3.32: +9 -3 lines
Diff to previous 3.32 , to selected 3.10
Added check for byte-swapping
Mon Oct 21 18:19:32 2019 UTC (4 years, 7 months ago) by greg
Changes since 3.31: +7 -6 lines
Diff to previous 3.31 , to selected 3.10
Added binary option for Windows
Fri Oct 5 19:19:16 2018 UTC (5 years, 7 months ago) by greg
Changes since 3.30: +9 -9 lines
Diff to previous 3.30 , to selected 3.10
Thu Aug 2 18:33:42 2018 UTC (5 years, 9 months ago) by greg
Changes since 3.29: +2 -2 lines
Diff to previous 3.29 , to selected 3.10
Wed May 3 21:15:06 2017 UTC (7 years ago) by greg
Changes since 3.28: +3 -1 lines
Diff to previous 3.28 , to selected 3.10
Added check for zero in z-buffer input
Wed May 3 18:05:15 2017 UTC (7 years ago) by greg
Changes since 3.27: +2 -2 lines
Diff to previous 3.27 , to selected 3.10
Improved wording of error message
Changes since 3.26: +2 -2 lines
Diff to previous 3.26 , to selected 3.10
Thu Sep 30 15:43:30 2010 UTC (13 years, 7 months ago) by greg
Changes since 3.25: +3 -3 lines
Diff to previous 3.25 , to selected 3.10
Changed holodeck section pointers to off_t to avoid issues with rhcopy
Sun Sep 26 15:39:10 2010 UTC (13 years, 7 months ago) by greg
Diff to previous 3.24 , to selected 3.10
Fixed 64-bit bug in rhcopy and rhoptimize
Mon Nov 10 19:08:19 2008 UTC (15 years, 6 months ago) by greg
Diff to previous 3.23 , to selected 3.10
Fri Jan 2 11:42:01 2004 UTC (20 years, 4 months ago) by schorsch
Changes since 3.22: +11 -9 lines
Diff to previous 3.22 , to selected 3.10
Changes since 3.21: +69 -39 lines
Diff to previous 3.21 , to selected 3.10
Ansification and prototypes.
Diff to previous 3.20 , to selected 3.10
Changes since 3.19: +3 -2 lines
Diff to previous 3.19 , to selected 3.10
Changes since 3.18: +6 -6 lines
Diff to previous 3.18 , to selected 3.10
Diff to previous 3.17 , to selected 3.10
Changes since 3.16: +2 -2 lines
Diff to previous 3.16 , to selected 3.10
Thu May 29 16:26:22 2003 UTC (20 years, 11 months ago) by greg
Changes since 3.15: +1 -2 lines
Diff to previous 3.15 , to selected 3.10
Changes since 3.14: +8 -10 lines
Diff to previous 3.14 , to selected 3.10
Mon Mar 8 17:32:26 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.13: +2 -3 lines
Diff to previous 3.13 , to selected 3.10
removed unnecessary call to hdfreebeams() that increased fragmentation
Mon Feb 1 10:22:46 1999 UTC (25 years, 3 months ago) by gwlarson
Changes since 3.12: +2 -1 lines
Diff to previous 3.12 , to selected 3.10
made caching code slightly more efficient
Sat Jan 9 09:16:31 1999 UTC (25 years, 4 months ago) by gwlarson
Diff to previous 3.11 , to selected 3.10
improved duplicate ray checking
Thu Nov 12 15:06:00 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.10: +42 -19 lines
Diff to previous 3.10
change clumpbeams() callback function to take clump's queue
Revision 3.10 - (view) (download) (annotate) - [selected]
Mon Nov 9 17:11:40 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.9: +39 -44 lines
Diff to previous 3.9
moved routines to clumpbeams.c and made rhcopy clump beams
Tue Oct 27 08:49:50 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.8: +10 -6 lines
Diff to previous 3.8 , to selected 3.10
Fri Jan 23 09:05:14 1998 UTC (26 years, 4 months ago) by gregl
Changes since 3.7: +4 -4 lines
Diff to previous 3.7 , to selected 3.10
changed -c option to -u and -f option to -d
Wed Jan 7 17:46:18 1998 UTC (26 years, 4 months ago) by gregl
Changes since 3.6: +23 -15 lines
Diff to previous 3.6 , to selected 3.10
tried to fix poor performance of sorted load by going to partial sort
Wed Jan 7 10:49:12 1998 UTC (26 years, 4 months ago) by gregl
Diff to previous 3.5 , to selected 3.10
fixed bug from sorting change (3.4
Wed Jan 7 09:23:02 1998 UTC (26 years, 4 months ago) by gregl
Changes since 3.4: +51 -20 lines
Diff to previous 3.4 , to selected 3.10
added -f (fudge distance check) and -c (check repeats) options
Tue Jan 6 22:02:22 1998 UTC (26 years, 4 months ago) by gregl
Changes since 3.3: +16 -6 lines
Diff to previous 3.3 , to selected 3.10
change code to read beams in file order
Tue Jan 6 05:57:07 1998 UTC (26 years, 4 months ago) by gregl
Diff to previous 3.2 , to selected 3.10
went back to use of long file pointers
Thu Dec 18 10:03:29 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.1: +31 -18 lines
Diff to previous 3.1 , to selected 3.10
made checking of OBSTRUCTIONS variable more accurate
Thu Dec 18 09:33:42 1997 UTC (26 years, 5 months ago) by gregl
Diff to selected 3.10
