| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rhcopy.c,v 3.35 2022/11/16 00:44:04 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Copy data into a holodeck file
| 6 |
| 7 |
| 8 |
#include "platform.h"
| 9 |
#include "rterror.h"
| 10 |
#include "holo.h"
| 11 |
#include "view.h"
| 12 |
| 13 |
#ifndef BKBSIZE
| 14 |
#define BKBSIZE 256 /* beam clump size (kilobytes) */
| 15 |
#endif
| 16 |
/* possible operations */
| 17 |
#define FROM_HOLO 1 /* copy between holodecks */
| 18 |
#define FROM_PICZ 2 /* copy from HDR + depth to holodeck */
| 19 |
#define FROM_STDIN 3 /* copy from stdin to holodeck */
| 20 |
#define TO_STDOUT 4 /* copy rays from holodeck to stdout */
| 21 |
| 22 |
int operation = 0; /* what we are doing */
| 23 |
char *rspec = ""; /* ray details for i/o */
| 24 |
int checkdepth = 1; /* check depth (!-d option)? */
| 25 |
int checkrepeats = 0; /* check for repeats (-u option)? */
| 26 |
int nholosects; /* number of original holodeck sections */
| 27 |
int iofmt = 'a'; /* input/output format for rays */
| 28 |
| 29 |
/* holodeck flags */
| 30 |
#define H_BADF 01 /* bad format */
| 31 |
#define H_OBST 02 /* OBSTRUCTIONS= True */
| 32 |
#define H_OBSF 04 /* OBSTRUCTIONS= False */
| 33 |
#define H_VDST 010 /* VDISTANCE= True */
| 34 |
#define H_SWAP 020 /* byte order is different */
| 35 |
| 36 |
char *progname; /* global argv[0] */
| 37 |
| 38 |
struct phead {
| 39 |
VIEW vw;
| 40 |
double expos;
| 41 |
short gotview;
| 42 |
short badfmt;
| 43 |
short altprims;
| 44 |
| 45 |
| 46 |
typedef struct {
| 47 |
FVECT ro;
| 48 |
FVECT rd;
| 49 |
RREAL d;
| 50 |
COLR cv;
| 51 |
} RAYPAR;
| 52 |
| 53 |
static int openholo(char *fname, int append);
| 54 |
static void addray(RAYPAR *rp);
| 55 |
static int readval(RREAL *v, int n, FILE *fp);
| 56 |
static void readrays(FILE *fp);
| 57 |
static int writeval(RREAL *v, int n, FILE *fp);
| 58 |
static int write_ray(RAYPAR *rp, FILE *fp);
| 59 |
static void writerays(FILE *fp);
| 60 |
static gethfunc holheadline;
| 61 |
static int bpcmp(const void *b1p, const void *b2p);
| 62 |
static int addclump(HOLO *hp, int *bq, int nb);
| 63 |
static void addholo(char *hdf);
| 64 |
static gethfunc picheadline;
| 65 |
static void addpicz(char *pcf, char *zbf);
| 66 |
| 67 |
| 68 |
int
| 69 |
main(
| 70 |
int argc,
| 71 |
char *argv[]
| 72 |
| 73 |
| 74 |
int i;
| 75 |
| 76 |
progname = argv[0];
| 77 |
for (i = 2; i < argc && argv[i][0] == '-'; i++)
| 78 |
switch (argv[i][1]) {
| 79 |
case 'u':
| 80 |
checkrepeats = 1;
| 81 |
break;
| 82 |
case 'd':
| 83 |
checkdepth = 0;
| 84 |
break;
| 85 |
case 'f':
| 86 |
iofmt = argv[i][2];
| 87 |
if (!strchr("afd", iofmt))
| 88 |
error(USER, "-f? i/o format must be 'a', 'f', or 'd'");
| 89 |
break;
| 90 |
case 'h':
| 91 |
operation = FROM_HOLO;
| 92 |
break;
| 93 |
case 'p':
| 94 |
operation = FROM_PICZ;
| 95 |
break;
| 96 |
case 'i':
| 97 |
operation = FROM_STDIN;
| 98 |
rspec = argv[i]+2;
| 99 |
break;
| 100 |
case 'o':
| 101 |
operation = TO_STDOUT;
| 102 |
rspec = argv[i]+2;
| 103 |
break;
| 104 |
default:
| 105 |
goto userr;
| 106 |
| 107 |
if (!operation | (i > argc-((operation==FROM_HOLO)|(operation==FROM_PICZ))))
| 108 |
goto userr;
| 109 |
if (operation == FROM_PICZ && (argc-i)%2)
| 110 |
goto userr;
| 111 |
nholosects = openholo(argv[1], (operation != TO_STDOUT));
| 112 |
/* check requested i/o is compatible */
| 113 |
if (strchr(rspec, 'l') && !(*(int *)hdlist[0]->priv & H_VDST))
| 114 |
error(USER, "i/o parameter 'l' incompatible with VDISTANCE=False");
| 115 |
if (strchr(rspec, 'L') && *(int *)hdlist[0]->priv & H_VDST)
| 116 |
error(USER, "i/o parameter 'L' incompatible with VDISTANCE=True");
| 117 |
| 118 |
switch (operation) { /* perform requested operation */
| 119 |
case FROM_PICZ:
| 120 |
for ( ; i < argc; i += 2)
| 121 |
addpicz(argv[i], argv[i+1]);
| 122 |
break;
| 123 |
case FROM_HOLO:
| 124 |
if (BKBSIZE*1024*1.5 > hdcachesize)
| 125 |
hdcachesize = BKBSIZE*1024*1.5;
| 126 |
for ( ; i < argc; i++)
| 127 |
addholo(argv[i]);
| 128 |
break;
| 129 |
case FROM_STDIN:
| 130 |
readrays(stdin);
| 131 |
break;
| 132 |
case TO_STDOUT:
| 133 |
writerays(stdout);
| 134 |
break;
| 135 |
| 136 |
quit(0);
| 137 |
userr:
| 138 |
fprintf(stderr, "Usage: %s dest.hdk [-u][-d] -h inp1.hdk ..\n",
| 139 |
progname);
| 140 |
fprintf(stderr, " Or: %s dest.hdk [-u][-d] -p inp1.hdr inp1.zbf ..\n",
| 141 |
progname);
| 142 |
fprintf(stderr, " Or: %s dest.hdk [-f{a|f|d}][-u][-d] -i[odplLv]\n",
| 143 |
progname);
| 144 |
fprintf(stderr, " Or: %s src.hdk [-f{a|f|d}] -o[odplLv] ..\n",
| 145 |
progname);
| 146 |
exit(1);
| 147 |
| 148 |
| 149 |
static int
| 150 |
holheadline( /* check holodeck header line */
| 151 |
char *s,
| 152 |
void *vhf
| 153 |
| 154 |
| 155 |
int be;
| 156 |
char fmt[MAXFMTLEN];
| 157 |
int *hf = (int *)vhf;
| 158 |
| 159 |
if (formatval(fmt, s)) {
| 160 |
if (strcmp(fmt, HOLOFMT))
| 161 |
*hf |= H_BADF;
| 162 |
else
| 163 |
*hf &= ~H_BADF;
| 164 |
return(0);
| 165 |
| 166 |
if (!strncmp(s, "OBSTRUCTIONS=", 13)) {
| 167 |
s += 13;
| 168 |
while (*s == ' ') s++;
| 169 |
if ((*s == 't') | (*s == 'T'))
| 170 |
*hf |= H_OBST;
| 171 |
else if ((*s == 'f') | (*s == 'F'))
| 172 |
*hf |= H_OBSF;
| 173 |
else
| 174 |
error(WARNING, "bad OBSTRUCTIONS value in holodeck");
| 175 |
return(0);
| 176 |
| 177 |
if (!strncmp(s, "VDISTANCE=", 10)) {
| 178 |
s += 10;
| 179 |
| 180 |
| 181 |
*hf |= H_VDST;
| 182 |
else if ((*s != 'f') % (*s != 'F'))
| 183 |
error(WARNING, "bad VDISTANCE value in holodeck");
| 184 |
return(0);
| 185 |
| 186 |
if ((be = isbigendian(s)) >= 0) {
| 187 |
if (be != nativebigendian())
| 188 |
*hf |= H_SWAP;
| 189 |
return(0);
| 190 |
| 191 |
return(0);
| 192 |
| 193 |
| 194 |
int
| 195 |
openholo( /* open existing holodeck file for i/o */
| 196 |
char *fname,
| 197 |
int append
| 198 |
| 199 |
| 200 |
FILE *fp;
| 201 |
int fd;
| 202 |
int hflags = 0;
| 203 |
int *hfstore;
| 204 |
off_t nextloc;
| 205 |
int n;
| 206 |
/* open holodeck file */
| 207 |
if ((fp = fopen(fname, append ? "rb+" : "rb")) == NULL) {
| 208 |
sprintf(errmsg, "cannot open \"%s\" for %s", fname,
| 209 |
append ? "appending" : "reading");
| 210 |
error(SYSTEM, errmsg);
| 211 |
| 212 |
/* check header and magic number */
| 213 |
if (getheader(fp, holheadline, &hflags) < 0 ||
| 214 |
hflags&(H_BADF|H_SWAP) || getw(fp) != HOLOMAGIC) {
| 215 |
sprintf(errmsg, "holodeck \"%s\" not in expected format", fname);
| 216 |
error(USER, errmsg);
| 217 |
| 218 |
fd = dup(fileno(fp)); /* dup file handle */
| 219 |
nextloc = ftell(fp); /* get stdio position */
| 220 |
fclose(fp); /* done with stdio */
| 221 |
hfstore = (int *)malloc(sizeof(int)); /* tiny memory leak but who cares? */
| 222 |
*hfstore = hflags;
| 223 |
for (n = 0; nextloc > 0L; n++) { /* initialize each section */
| 224 |
lseek(fd, nextloc, SEEK_SET);
| 225 |
read(fd, (char *)&nextloc, sizeof(nextloc));
| 226 |
hdinit(fd, NULL)->priv = hfstore;
| 227 |
| 228 |
return(n);
| 229 |
| 230 |
| 231 |
void
| 232 |
addray( /* add a ray to our output holodeck */
| 233 |
RAYPAR *rp
| 234 |
| 235 |
| 236 |
int sn, bi, n;
| 237 |
HOLO *hp;
| 238 |
GCOORD gc[2];
| 239 |
uby8 rr[2][2];
| 240 |
BEAM *bp;
| 241 |
double d0, d1;
| 242 |
unsigned dc;
| 243 |
RAYVAL *rv;
| 244 |
/* check each output section */
| 245 |
for (sn = nholosects; sn--; ) {
| 246 |
hp = hdlist[sn];
| 247 |
d0 = hdinter(gc, rr, &d1, hp, rp->ro, rp->rd);
| 248 |
if (rp->d <= d0 || d1 < -0.001)
| 249 |
continue; /* missed section */
| 250 |
if (checkdepth) { /* check depth */
| 251 |
if (*(int *)hp->priv & H_OBST && d0 < -0.001)
| 252 |
continue; /* ray starts too late */
| 253 |
if (*(int *)hp->priv & H_OBSF && rp->d < 0.999*d1)
| 254 |
continue; /* ray ends too soon */
| 255 |
| 256 |
dc = hdcode(hp, rp->d-d0);
| 257 |
bi = hdbindex(hp, gc); /* check for duplicates */
| 258 |
if (checkrepeats && (bp = hdgetbeam(hp, bi)) != NULL) {
| 259 |
for (n = bp->nrm, rv = hdbray(bp); n--; rv++)
| 260 |
if ((rv->d == dc || *(int *)hp->priv & (H_OBST|H_OBSF)) &&
| 261 |
rv->r[0][0] == rr[0][0] &&
| 262 |
rv->r[0][1] == rr[0][1] &&
| 263 |
rv->r[1][0] == rr[1][0] &&
| 264 |
rv->r[1][1] == rr[1][1])
| 265 |
break;
| 266 |
if (n >= 0)
| 267 |
continue; /* found a matching ray */
| 268 |
| 269 |
rv = hdnewrays(hp, bi, 1);
| 270 |
rv->d = dc;
| 271 |
rv->r[0][0] = rr[0][0]; rv->r[0][1] = rr[0][1];
| 272 |
rv->r[1][0] = rr[1][0]; rv->r[1][1] = rr[1][1];
| 273 |
copycolr(rv->v, rp->cv);
| 274 |
| 275 |
| 276 |
| 277 |
/* Read n-vector from file stream */
| 278 |
static int
| 279 |
| 280 |
| 281 |
int i;
| 282 |
#ifdef SMLFLT
| 283 |
double vd[3];
| 284 |
switch (iofmt) {
| 285 |
case 'f':
| 286 |
return getbinary(v, sizeof(float), n, fp);
| 287 |
case 'd':
| 288 |
n = getbinary(vd, sizeof(double), n, fp);
| 289 |
for (i = n; i-- > 0; ) v[i] = vd[i];
| 290 |
return n;
| 291 |
case 'a':
| 292 |
for (i = 0; i < n; i++)
| 293 |
if (fscanf(fp, "%f ", &v[i]) != 1)
| 294 |
break;
| 295 |
return i;
| 296 |
| 297 |
#else
| 298 |
float vf[3];
| 299 |
switch (iofmt) {
| 300 |
case 'd':
| 301 |
return getbinary(v, sizeof(double), n, fp);
| 302 |
case 'f':
| 303 |
n = getbinary(vf, sizeof(float), n, fp);
| 304 |
for (i = n; i-- > 0; ) v[i] = vf[i];
| 305 |
return n;
| 306 |
case 'a':
| 307 |
| 308 |
if (fscanf(fp, "%lf ", &v[i]) != 1)
| 309 |
break;
| 310 |
return i;
| 311 |
| 312 |
#endif
| 313 |
return -1;
| 314 |
| 315 |
| 316 |
#define GOT_ORG 0x01
| 317 |
#define GOT_DIR 0x02
| 318 |
#define GOT_LEN 0x04
| 319 |
#define GOT_VAL 0x10
| 320 |
#define ALSO_POS 0x20
| 321 |
#define BAD_DIR 0x40
| 322 |
#define BAD_LEN 0x80
| 323 |
| 324 |
/* Read rays from stream and add to holodeck */
| 325 |
static void
| 326 |
readrays(FILE *fp)
| 327 |
| 328 |
if (iofmt != 'a')
| 329 |
SET_FILE_BINARY(fp);
| 330 |
#ifdef getc_unlocked
| 331 |
flockfile(fp);
| 332 |
#endif
| 333 |
while (!feof(fp)) { /* read entirety of input */
| 334 |
RAYPAR ryp;
| 335 |
FVECT pos;
| 336 |
FVECT col;
| 337 |
int flags = 0;
| 338 |
int i;
| 339 |
for (i = 0; rspec[i]; i++) {
| 340 |
switch (rspec[i]) {
| 341 |
case 'o': /* ray origin */
| 342 |
if (readval(ryp.ro, 3, fp) < 3)
| 343 |
break;
| 344 |
flags |= GOT_ORG;
| 345 |
continue;
| 346 |
case 'd': /* ray direction */
| 347 |
if (readval(ryp.rd, 3, fp) < 3)
| 348 |
break;
| 349 |
if (normalize(ryp.rd) == 0)
| 350 |
flags |= BAD_DIR;
| 351 |
else
| 352 |
flags |= GOT_DIR;
| 353 |
continue;
| 354 |
case 'p': /* ray intersection */
| 355 |
if (readval(pos, 3, fp) < 3)
| 356 |
break;
| 357 |
flags |= ALSO_POS;
| 358 |
continue;
| 359 |
case 'L': /* ray first length */
| 360 |
case 'l': /* ray virtual length */
| 361 |
if (readval(&ryp.d, 1, fp) < 1)
| 362 |
break;
| 363 |
if (ryp.d <= FTINY)
| 364 |
flags |= BAD_LEN;
| 365 |
else
| 366 |
flags |= GOT_LEN;
| 367 |
continue;
| 368 |
case 'v': /* ray value */
| 369 |
if (readval(col, 3, fp) < 3)
| 370 |
break;
| 371 |
setcolr(ryp.cv, col[0], col[1], col[2]);
| 372 |
flags |= GOT_VAL;
| 373 |
continue;
| 374 |
default:
| 375 |
sprintf(errmsg, "unsupported parameter '%c' in -i%s",
| 376 |
rspec[i], rspec);
| 377 |
| 378 |
| 379 |
if (!flags) /* got nothing, so may be normal EOF */
| 380 |
return;
| 381 |
| 382 |
if (flags & (BAD_DIR|BAD_LEN))
| 383 |
continue; /* just a bad ray is all -- skip */
| 384 |
if (!(flags & GOT_VAL))
| 385 |
goto missingData;
| 386 |
if ((flags & (GOT_ORG|GOT_DIR|GOT_LEN)) != (GOT_ORG|GOT_DIR|GOT_LEN)) {
| 387 |
if (!(flags & ALSO_POS))
| 388 |
goto missingData;
| 389 |
if (flags & GOT_ORG) {
| 390 |
VSUB(ryp.rd, pos, ryp.ro);
| 391 |
ryp.d = normalize(ryp.rd);
| 392 |
if (ryp.d == 0)
| 393 |
continue;
| 394 |
} else if ((flags & (GOT_DIR|GOT_LEN)) == (GOT_DIR|GOT_LEN)) {
| 395 |
VSUM(ryp.ro, pos, ryp.rd, -ryp.d);
| 396 |
} else
| 397 |
goto missingData;
| 398 |
| 399 |
addray(&ryp); /* add our ray to holodeck */
| 400 |
| 401 |
return;
| 402 |
missingData:
| 403 |
sprintf(errmsg, "insufficient data in -i%s", rspec);
| 404 |
| 405 |
| 406 |
| 407 |
/* Write vector value to file stream */
| 408 |
static int
| 409 |
| 410 |
| 411 |
int i;
| 412 |
| 413 |
if (iofmt == 'a') {
| 414 |
| 415 |
if (fprintf(fp, "\t%.4e", v[i]) < 0)
| 416 |
break;
| 417 |
return i;
| 418 |
| 419 |
#ifdef SMLFLT
| 420 |
if (iofmt == 'd') {
| 421 |
double vd[3];
| 422 |
for (i = n; i--; ) vd[i] = v[i];
| 423 |
return putbinary(vd, sizeof(double), n, fp);
| 424 |
| 425 |
#else
| 426 |
if (iofmt == 'f') {
| 427 |
float vf[3];
| 428 |
for (i = n; i--; ) vf[i] = v[i];
| 429 |
return putbinary(vf, sizeof(float), n, fp);
| 430 |
| 431 |
#endif
| 432 |
return putbinary(v, sizeof(*v), n, fp);
| 433 |
| 434 |
| 435 |
/* Write out an individual ray as requested */
| 436 |
static int
| 437 |
| 438 |
| 439 |
COLOR cval;
| 440 |
FVECT v3;
| 441 |
char *typ = rspec;
| 442 |
| 443 |
for ( ; ; ) {
| 444 |
switch (*typ++) {
| 445 |
| 446 |
if (writeval(rp->ro, 3, fp) < 3)
| 447 |
break;
| 448 |
continue;
| 449 |
| 450 |
if (writeval(rp->rd, 3, fp) < 3)
| 451 |
break;
| 452 |
continue;
| 453 |
| 454 |
VSUM(v3, rp->ro, rp->rd, rp->d);
| 455 |
if (writeval(v3, 3, fp) < 3)
| 456 |
break;
| 457 |
continue;
| 458 |
| 459 |
| 460 |
if (writeval(&rp->d, 1, fp) < 1)
| 461 |
break;
| 462 |
continue;
| 463 |
| 464 |
colr_color(cval, rp->cv);
| 465 |
VCOPY(v3, cval);
| 466 |
| 467 |
break;
| 468 |
continue;
| 469 |
case '\0': /* end of spec -- success */
| 470 |
if (iofmt == 'a')
| 471 |
fputc('\n', fp);
| 472 |
return(1);
| 473 |
default:
| 474 |
sprintf(errmsg, "unsupported parameter '%c' in -o%s", typ[-1], rspec);
| 475 |
| 476 |
break; /* land here on error */
| 477 |
| 478 |
return 0; /* write error? */
| 479 |
| 480 |
| 481 |
static BEAMI *beamdir;
| 482 |
| 483 |
static int
| 484 |
bpcmp( /* compare beam positions on disk */
| 485 |
const void *b1p,
| 486 |
const void *b2p
| 487 |
| 488 |
| 489 |
off_t pdif = beamdir[*(int *)b1p].fo - beamdir[*(int *)b2p].fo;
| 490 |
| 491 |
if (pdif > 0L) return(1);
| 492 |
if (pdif < 0L) return(-1);
| 493 |
return(0);
| 494 |
| 495 |
| 496 |
/* Write all rays from holodeck to stream */
| 497 |
static void
| 498 |
writerays(FILE *fp)
| 499 |
| 500 |
int sn, bi, k;
| 501 |
GCOORD gc[2];
| 502 |
RAYVAL *rv;
| 503 |
RAYPAR ryp;
| 504 |
| 505 |
if (!*rspec) {
| 506 |
error(WARNING, "empty -o* output spec, quitting");
| 507 |
return;
| 508 |
| 509 |
if (iofmt != 'a')
| 510 |
| 511 |
| 512 |
flockfile(fp);
| 513 |
#endif
| 514 |
for (sn = 0; sn < nholosects; sn++) { /* write each holodeck section */
| 515 |
HOLO *hp = hdlist[sn];
| 516 |
int nb = nbeams(hp); /* sort beams by file location */
| 517 |
int *bq = (int *)malloc(nb*sizeof(int));
| 518 |
if (!bq)
| 519 |
error(SYSTEM, "out of memory in writerays()");
| 520 |
for (bi = nb; bi--; ) bq[bi] = bi+1;
| 521 |
beamdir = hp->bi;
| 522 |
qsort(bq, nb, sizeof(*bq), bpcmp);
| 523 |
for (bi = 0; bi < nb; bi++) {
| 524 |
BEAM *bp = hdgetbeam(hp, bq[bi]);
| 525 |
if (!bp) /* empty beam? */
| 526 |
continue;
| 527 |
hdbcoord(gc, hp, bq[bi]);
| 528 |
rv = hdbray(bp);
| 529 |
for (k = bp->nrm; k--; rv++) {
| 530 |
ryp.d = hdray(ryp.ro, ryp.rd, hp, gc, rv->r);
| 531 |
if (*(int *)hp->priv & H_OBSF)
| 532 |
VSUM(ryp.ro, ryp.ro, ryp.rd, ryp.d);
| 533 |
else
| 534 |
ryp.d = 0.;
| 535 |
ryp.d = hddepth(hp, rv->d) - ryp.d;
| 536 |
copycolr(ryp.cv, rv->v);
| 537 |
if (!write_ray(&ryp, fp)) {
| 538 |
free(bq);
| 539 |
goto writError;
| 540 |
| 541 |
| 542 |
hdfreebeam(hp, bq[bi]);
| 543 |
| 544 |
free(bq);
| 545 |
| 546 |
if (fflush(fp) != EOF)
| 547 |
return;
| 548 |
writError:
| 549 |
error(SYSTEM, "error writing holodeck rays");
| 550 |
| 551 |
| 552 |
static int
| 553 |
addclump( /* transfer the given clump and free */
| 554 |
HOLO *hp,
| 555 |
int *bq,
| 556 |
int nb
| 557 |
| 558 |
| 559 |
GCOORD gc[2];
| 560 |
RAYPAR ryp;
| 561 |
RAYVAL *rv;
| 562 |
int i;
| 563 |
int k;
| 564 |
BEAM *bp;
| 565 |
/* sort based on file position */
| 566 |
beamdir = hp->bi;
| 567 |
| 568 |
/* transfer each beam */
| 569 |
for (i = 0; i < nb; i++) {
| 570 |
bp = hdgetbeam(hp, bq[i]);
| 571 |
hdbcoord(gc, hp, bq[i]);
| 572 |
rv = hdbray(bp); /* add each ray to output */
| 573 |
| 574 |
| 575 |
| 576 |
| 577 |
else
| 578 |
ryp.d = 0.;
| 579 |
| 580 |
| 581 |
addray(&ryp);
| 582 |
| 583 |
hdfreebeam(hp, bq[i]); /* free the beam */
| 584 |
| 585 |
return(0);
| 586 |
| 587 |
| 588 |
| 589 |
void
| 590 |
addholo( /* add a holodeck file */
| 591 |
char *hdf
| 592 |
| 593 |
| 594 |
int fd;
| 595 |
/* open the holodeck for reading */
| 596 |
openholo(hdf, 0);
| 597 |
fd = hdlist[nholosects]->fd; /* remember the file handle */
| 598 |
while (hdlist[nholosects] != NULL) { /* load each section */
| 599 |
/* clump the beams */
| 600 |
clumpbeams(hdlist[nholosects], 0, BKBSIZE*1024, addclump);
| 601 |
hddone(hdlist[nholosects]); /* free the section */
| 602 |
| 603 |
close(fd); /* close input file */
| 604 |
hdflush(NULL); /* flush output */
| 605 |
| 606 |
| 607 |
| 608 |
| 609 |
static int
| 610 |
picheadline( /* process picture header line */
| 611 |
char *s,
| 612 |
void *vph
| 613 |
| 614 |
| 615 |
char fmt[32];
| 616 |
struct phead *ph = (struct phead *)vph;
| 617 |
| 618 |
| 619 |
ph->badfmt = strcmp(fmt, COLRFMT);
| 620 |
return(0);
| 621 |
| 622 |
if (isprims(s)) {
| 623 |
ph->altprims++; /* don't want to deal with this */
| 624 |
return(0);
| 625 |
| 626 |
if (isexpos(s)) {
| 627 |
ph->expos *= exposval(s);
| 628 |
return(0);
| 629 |
| 630 |
if (isview(s)) {
| 631 |
ph->gotview += sscanview(&ph->vw, s);
| 632 |
return(0);
| 633 |
| 634 |
return(0);
| 635 |
| 636 |
| 637 |
| 638 |
void
| 639 |
addpicz( /* add a picture + depth-buffer */
| 640 |
char *pcf,
| 641 |
char *zbf
| 642 |
| 643 |
| 644 |
FILE *pfp;
| 645 |
int zfd;
| 646 |
COLR *cscn;
| 647 |
float *zscn;
| 648 |
struct phead phd;
| 649 |
int eshft;
| 650 |
double emult;
| 651 |
RESOLU prs;
| 652 |
RREAL vl[2];
| 653 |
RAYPAR ryp;
| 654 |
double aftd;
| 655 |
int j, i;
| 656 |
/* open picture & get header */
| 657 |
if ((pfp = fopen(pcf, "rb")) == NULL) {
| 658 |
sprintf(errmsg, "cannot open picture file \"%s\"", pcf);
| 659 |
error(SYSTEM, pcf);
| 660 |
| 661 |
phd.vw = stdview;
| 662 |
phd.expos = 1.0;
| 663 |
phd.badfmt = phd.gotview = phd.altprims = 0;
| 664 |
if (getheader(pfp, picheadline, &phd) < 0 ||
| 665 |
phd.badfmt || !fgetsresolu(&prs, pfp)) {
| 666 |
sprintf(errmsg, "bad format for picture file \"%s\"", pcf);
| 667 |
| 668 |
| 669 |
if (!phd.gotview || setview(&phd.vw) != NULL) {
| 670 |
sprintf(errmsg, "missing/illegal view in picture \"%s\"",
| 671 |
pcf);
| 672 |
| 673 |
| 674 |
if (phd.altprims) {
| 675 |
sprintf(errmsg, "ignoring color primaries in picture \"%s\"",
| 676 |
pcf);
| 677 |
error(WARNING, errmsg);
| 678 |
| 679 |
/* open depth buffer */
| 680 |
if ((zfd = open_float_depth(zbf, prs.xr*prs.yr)) < 0)
| 681 |
quit(1);
| 682 |
/* figure out what to do about exposure */
| 683 |
if ((phd.expos < 0.99) | (phd.expos > 1.01)) {
| 684 |
emult = -log(phd.expos)/log(2.);
| 685 |
eshft = emult >= 0. ? emult+.5 : emult-.5;
| 686 |
emult -= (double)eshft;
| 687 |
if ((emult <= 0.01) & (emult >= -0.01))
| 688 |
emult = -1.;
| 689 |
else {
| 690 |
emult = 1./phd.expos;
| 691 |
eshft = 0;
| 692 |
| 693 |
} else {
| 694 |
emult = -1.;
| 695 |
eshft = 0;
| 696 |
| 697 |
/* allocate buffers */
| 698 |
cscn = (COLR *)malloc(scanlen(&prs)*sizeof(COLR));
| 699 |
zscn = (float *)malloc(scanlen(&prs)*sizeof(float));
| 700 |
if ((cscn == NULL) | (zscn == NULL))
| 701 |
error(SYSTEM, "out of memory in addpicz");
| 702 |
/* read and process each scanline */
| 703 |
for (j = 0; j < numscans(&prs); j++) {
| 704 |
i = scanlen(&prs); /* read colrs */
| 705 |
if (freadcolrs(cscn, i, pfp) < 0) {
| 706 |
sprintf(errmsg, "error reading picture \"%s\"", pcf);
| 707 |
| 708 |
| 709 |
if (eshft) /* shift exposure */
| 710 |
shiftcolrs(cscn, i, eshft);
| 711 |
/* read depth */
| 712 |
if (read(zfd, zscn, i*sizeof(float)) != i*sizeof(float)) {
| 713 |
sprintf(errmsg, "error reading depth file \"%s\"", zbf);
| 714 |
| 715 |
| 716 |
while (i--) { /* process each pixel */
| 717 |
if (zscn[i] <= 0.0)
| 718 |
continue; /* illegal depth */
| 719 |
pix2loc(vl, &prs, i, j);
| 720 |
aftd = viewray(ryp.ro, ryp.rd, &phd.vw, vl[0], vl[1]);
| 721 |
if (aftd < -FTINY)
| 722 |
continue; /* off view */
| 723 |
if (aftd > FTINY && zscn[i] > aftd)
| 724 |
continue; /* aft clipped */
| 725 |
ryp.d = (RREAL)zscn[i];
| 726 |
copycolr(ryp.cv, cscn[i]);
| 727 |
if (emult > 0.) { /* whatta pain */
| 728 |
COLOR ctmp;
| 729 |
colr_color(ctmp, ryp.cv);
| 730 |
scalecolor(ctmp, emult);
| 731 |
setcolr(ryp.cv, colval(ctmp,RED),
| 732 |
colval(ctmp,GRN), colval(ctmp,BLU));
| 733 |
| 734 |
addray(&ryp);
| 735 |
| 736 |
| 737 |
/* write output and free beams */
| 738 |
hdflush(NULL);
| 739 |
/* clean up */
| 740 |
free((void *)cscn);
| 741 |
free((void *)zscn);
| 742 |
fclose(pfp);
| 743 |
close(zfd);
| 744 |
| 745 |
| 746 |
| 747 |
void
| 748 |
eputs( /* put error message to stderr */
| 749 |
const char *s
| 750 |
| 751 |
| 752 |
static int midline = 0;
| 753 |
| 754 |
if (!*s)
| 755 |
return;
| 756 |
if (!midline++) { /* prepend line with program name */
| 757 |
fputs(progname, stderr);
| 758 |
fputs(": ", stderr);
| 759 |
| 760 |
fputs(s, stderr);
| 761 |
if (s[strlen(s)-1] == '\n') {
| 762 |
fflush(stderr);
| 763 |
midline = 0;
| 764 |
| 765 |
| 766 |
| 767 |
| 768 |
void
| 769 |
quit( /* exit the program gracefully */
| 770 |
int code
| 771 |
| 772 |
| 773 |
hdsync(NULL, 1); /* write out any buffered data */
| 774 |
exit(code);
| 775 |
