root/Development/ray/src/hd/rhcopy.c
Revision: 3.33
Committed: Thu Nov 7 23:17:58 2019 UTC (6 years ago) by greg
Changes since 3.32: +9 -3 lines
Added check for byte-swapping
2 static const char RCSid[] = "$Id: rhcopy.c,v 3.32 2019/10/21 18:19:32 greg Exp $";
5 * Copy data into a holodeck file
6 */
7
8 #include "platform.h"
9 #include "rterror.h"
10 #include "holo.h"
11 #include "view.h"
12
13 #ifndef BKBSIZE
14 #define BKBSIZE 256 /* beam clump size (kilobytes) */
15 #endif
16
17 int checkdepth = 1; /* check depth (!-d option)? */
18 int checkrepeats = 0; /* check for repeats (-u option)? */
19 int frompicz; /* input from pictures & depth-buffers? */
20 int noutsects; /* number of output sections */
21 char obstr, unobstr; /* flag pointer values */
22
23 char *progname; /* global argv[0] */
24
25 struct phead {
26 VIEW vw;
27 double expos;
28 short gotview;
29 short badfmt;
30 short altprims;
31 };
32 static int openholo(char *fname, int append);
33 static void addray(FVECT ro, FVECT rd, double d, COLR cv);
34 static gethfunc holheadline;
35 static int bpcmp(const void *b1p, const void *b2p);
36 static int addclump(HOLO *hp, int *bq, int nb);
37 static void addholo(char *hdf);
38 static gethfunc picheadline;
39 static void addpicz(char *pcf, char *zbf);
40
41
42
43 int
44 main(
45 int argc,
46 char *argv[]
47 )
48 {
49 int i;
50
51 progname = argv[0];
52 frompicz = -1;
53 for (i = 2; i < argc && argv[i][0] == '-'; i++)
54 switch (argv[i][1]) {
55 case 'u':
56 checkrepeats = 1;
57 break;
58 case 'd':
59 checkdepth = 0;
60 break;
61 case 'h':
62 frompicz = 0;
63 break;
64 case 'p':
65 frompicz = 1;
66 break;
67 default:
68 goto userr;
69 }
70 if (i >= argc || frompicz < 0)
71 goto userr;
72 if (frompicz && (argc-i)%2)
73 goto userr;
74 noutsects = openholo(argv[1], 1);
75 if (frompicz) {
76 for ( ; i < argc; i += 2)
77 addpicz(argv[i], argv[i+1]);
78 } else {
79 if (BKBSIZE*1024*1.5 > hdcachesize)
80 hdcachesize = BKBSIZE*1024*1.5;
81 for ( ; i < argc; i++)
82 addholo(argv[i]);
83 }
84 quit(0);
85 userr:
86 fprintf(stderr, "Usage: %s output.hdk [-u][-d] -h inp1.hdk ..\n",
87 progname);
88 fprintf(stderr, " Or: %s output.hdk [-u][-d] -p inp1.hdr inp1.zbf ..\n",
89 progname);
90 exit(1);
91 }
92
93
94 #define H_BADF 01
95 #define H_OBST 02
96 #define H_OBSF 04
97 #define H_SWAP 010
98
99 static int
100 holheadline( /* check holodeck header line */
101 char *s,
102 void *vhf
103 )
104 {
105 int be;
106 char fmt[MAXFMTLEN];
107 int *hf = vhf;
108
109 if (formatval(fmt, s)) {
110 if (strcmp(fmt, HOLOFMT))
111 *hf |= H_BADF;
112 else
113 *hf &= ~H_BADF;
114 return(0);
115 }
116 if (!strncmp(s, "OBSTRUCTIONS=", 13)) {
117 s += 13;
118 while (*s == ' ') s++;
119 if ((*s == 't') | (*s == 'T'))
120 *hf |= H_OBST;
121 else if ((*s == 'f') | (*s == 'F'))
122 *hf |= H_OBSF;
123 else
124 error(WARNING, "bad OBSTRUCTIONS value in holodeck");
125 return(0);
126 }
127 if ((be = isbigendian(s)) >= 0) {
128 if (be != nativebigendian())
129 *hf |= H_SWAP;
130 }
131 return(0);
132 }
133
134 int
135 openholo( /* open existing holodeck file for i/o */
136 char *fname,
137 int append
138 )
139 {
140 FILE *fp;
141 int fd;
142 int hflags = 0;
143 off_t nextloc;
144 int n;
145 /* open holodeck file */
146 if ((fp = fopen(fname, append ? "rb+" : "rb")) == NULL) {
147 sprintf(errmsg, "cannot open \"%s\" for %s", fname,
148 append ? "appending" : "reading");
149 error(SYSTEM, errmsg);
150 }
151 /* check header and magic number */
152 if (getheader(fp, holheadline, &hflags) < 0 ||
153 hflags&(H_BADF|H_SWAP) || getw(fp) != HOLOMAGIC) {
154 sprintf(errmsg, "holodeck \"%s\" not in expected format", fname);
155 error(USER, errmsg);
156 }
157 fd = dup(fileno(fp)); /* dup file handle */
158 nextloc = ftell(fp); /* get stdio position */
159 fclose(fp); /* done with stdio */
160 for (n = 0; nextloc > 0L; n++) { /* initialize each section */
161 lseek(fd, nextloc, SEEK_SET);
162 read(fd, (char *)&nextloc, sizeof(nextloc));
163 hdinit(fd, NULL)->priv = hflags&H_OBST ? &obstr :
164 hflags&H_OBSF ? &unobstr : (char *)NULL;
165 }
166 return(n);
167 }
168
169 #undef H_BADF
170 #undef H_OBST
171 #undef H_OBSF
172
173
174 void
175 addray( /* add a ray to our output holodeck */
176 FVECT ro,
177 FVECT rd,
178 double d,
179 COLR cv
180 )
181 {
182 int sn, bi, n;
183 HOLO *hp;
184 GCOORD gc[2];
185 uby8 rr[2][2];
186 BEAM *bp;
187 double d0, d1;
188 unsigned dc;
189 RAYVAL *rv;
190 /* check each output section */
191 for (sn = noutsects; sn--; ) {
192 hp = hdlist[sn];
193 d0 = hdinter(gc, rr, &d1, hp, ro, rd);
194 if (d <= d0 || d1 < -0.001)
195 continue; /* missed section */
196 if (checkdepth) { /* check depth */
197 if (hp->priv == &obstr && d0 < -0.001)
198 continue; /* ray starts too late */
199 if (hp->priv == &unobstr && d < 0.999*d1)
200 continue; /* ray ends too soon */
201 }
202 dc = hdcode(hp, d-d0);
203 bi = hdbindex(hp, gc); /* check for duplicates */
204 if (checkrepeats && (bp = hdgetbeam(hp, bi)) != NULL) {
205 for (n = bp->nrm, rv = hdbray(bp); n--; rv++)
206 if ((hp->priv != NULL || rv->d == dc) &&
207 rv->r[0][0] == rr[0][0] &&
208 rv->r[0][1] == rr[0][1] &&
209 rv->r[1][0] == rr[1][0] &&
210 rv->r[1][1] == rr[1][1])
211 break;
212 if (n >= 0)
213 continue; /* found a matching ray */
214 }
215 rv = hdnewrays(hp, bi, 1);
216 rv->d = dc;
217 rv->r[0][0] = rr[0][0]; rv->r[0][1] = rr[0][1];
218 rv->r[1][0] = rr[1][0]; rv->r[1][1] = rr[1][1];
219 copycolr(rv->v, cv);
220 }
221 }
222
223
224 static BEAMI *beamdir;
225
226 static int
227 bpcmp( /* compare beam positions on disk */
228 const void *b1p,
229 const void *b2p
230 )
231 {
232 off_t pdif = beamdir[*(int*)b1p].fo - beamdir[*(int*)b2p].fo;
233
234 if (pdif > 0L) return(1);
235 if (pdif < 0L) return(-1);
236 return(0);
237 }
238
239 static int
240 addclump( /* transfer the given clump and free */
241 HOLO *hp,
242 int *bq,
243 int nb
244 )
245 {
246 GCOORD gc[2];
247 FVECT ro, rd;
248 double d;
249 int i;
250 int k;
251 BEAM *bp;
252 /* sort based on file position */
253 beamdir = hp->bi;
254 qsort((char *)bq, nb, sizeof(*bq), bpcmp);
255 /* transfer each beam */
256 for (i = 0; i < nb; i++) {
257 bp = hdgetbeam(hp, bq[i]);
258 hdbcoord(gc, hp, bq[i]);
259 /* add each ray to output */
260 for (k = bp->nrm; k--; ) {
261 d = hdray(ro, rd, hp, gc, hdbray(bp)[k].r);
262 if (hp->priv == &unobstr)
263 VSUM(ro, ro, rd, d);
264 else
265 d = 0.;
266 d = hddepth(hp, hdbray(bp)[k].d) - d;
267 addray(ro, rd, d, hdbray(bp)[k].v);
268 }
269 hdfreebeam(hp, bq[i]); /* free the beam */
270 }
271 return(0);
272 }
273
274
275 void
276 addholo( /* add a holodeck file */
277 char *hdf
278 )
279 {
280 int fd;
281 /* open the holodeck for reading */
282 openholo(hdf, 0);
283 fd = hdlist[noutsects]->fd; /* remember the file handle */
284 while (hdlist[noutsects] != NULL) { /* load each section */
285 /* clump the beams */
286 clumpbeams(hdlist[noutsects], 0, BKBSIZE*1024, addclump);
287 hddone(hdlist[noutsects]); /* free the section */
288 }
289 close(fd); /* close input file */
290 hdflush(NULL); /* flush output */
291 }
292
293
294
295 static int
296 picheadline( /* process picture header line */
297 char *s,
298 void *vph
299 )
300 {
301 char fmt[32];
302 struct phead *ph = vph;
303
304 if (formatval(fmt, s)) {
305 ph->badfmt = strcmp(fmt, COLRFMT);
306 return(0);
307 }
308 if (isprims(s)) {
309 ph->altprims++; /* don't want to deal with this */
310 return(0);
311 }
312 if (isexpos(s)) {
313 ph->expos *= exposval(s);
314 return(0);
315 }
316 if (isview(s)) {
317 ph->gotview += sscanview(&ph->vw, s);
318 return(0);
319 }
320 return(0);
321 }
322
323
324 void
325 addpicz( /* add a picture + depth-buffer */
326 char *pcf,
327 char *zbf
328 )
329 {
330 FILE *pfp;
331 int zfd;
332 COLR *cscn;
333 float *zscn;
334 struct phead phd;
335 int eshft;
336 double emult;
337 RESOLU prs;
338 RREAL vl[2];
339 FVECT ro, rd;
340 double aftd;
341 COLOR ctmp;
342 int j;
343 int i;
344 /* open files */
345 if ((pfp = fopen(pcf, "rb")) == NULL) {
346 sprintf(errmsg, "cannot open picture file \"%s\"", pcf);
347 error(SYSTEM, pcf);
348 }
349 if ((zfd = open(zbf, O_RDONLY)) < 0) {
350 sprintf(errmsg, "cannot open depth file \"%s\"", zbf);
351 error(SYSTEM, pcf);
352 }
353 SET_FD_BINARY(zfd);
354 /* load picture header */
355 phd.vw = stdview;
356 phd.expos = 1.0;
357 phd.badfmt = phd.gotview = phd.altprims = 0;
358 if (getheader(pfp, picheadline, &phd) < 0 ||
359 phd.badfmt || !fgetsresolu(&prs, pfp)) {
360 sprintf(errmsg, "bad format for picture file \"%s\"", pcf);
361 error(USER, errmsg);
362 }
363 if (!phd.gotview || setview(&phd.vw) != NULL) {
364 sprintf(errmsg, "missing/illegal view in picture \"%s\"",
365 pcf);
366 error(USER, errmsg);
367 }
368 if (phd.altprims) {
369 sprintf(errmsg, "ignoring color primaries in picture \"%s\"",
370 pcf);
371 error(WARNING, errmsg);
372 }
373 /* figure out what to do about exposure */
374 if ((phd.expos < 0.99) | (phd.expos > 1.01)) {
375 emult = -log(phd.expos)/log(2.);
376 eshft = emult >= 0. ? emult+.5 : emult-.5;
377 emult -= (double)eshft;
378 if ((emult <= 0.01) & (emult >= -0.01))
379 emult = -1.;
380 else {
381 emult = 1./phd.expos;
382 eshft = 0;
383 }
384 } else {
385 emult = -1.;
386 eshft = 0;
387 }
388 /* allocate buffers */
389 cscn = (COLR *)malloc(scanlen(&prs)*sizeof(COLR));
390 zscn = (float *)malloc(scanlen(&prs)*sizeof(float));
391 if ((cscn == NULL) | (zscn == NULL))
392 error(SYSTEM, "out of memory in addpicz");
393 /* read and process each scanline */
394 for (j = 0; j < numscans(&prs); j++) {
395 i = scanlen(&prs); /* read colrs */
396 if (freadcolrs(cscn, i, pfp) < 0) {
397 sprintf(errmsg, "error reading picture \"%s\"", pcf);
398 error(USER, errmsg);
399 }
400 if (eshft) /* shift exposure */
401 shiftcolrs(cscn, i, eshft);
402 /* read depth */
403 if (read(zfd, zscn, i*sizeof(float)) != i*sizeof(float)) {
404 sprintf(errmsg, "error reading depth file \"%s\"", zbf);
405 error(USER, errmsg);
406 }
407 while (i--) { /* process each pixel */
408 if (zscn[i] <= 0.0)
409 continue; /* illegal depth */
410 pix2loc(vl, &prs, i, j);
411 aftd = viewray(ro, rd, &phd.vw, vl[0], vl[1]);
412 if (aftd < -FTINY)
413 continue; /* off view */
414 if (aftd > FTINY && zscn[i] > aftd)
415 continue; /* aft clipped */
416 if (emult > 0.) { /* whatta pain */
417 colr_color(ctmp, cscn[i]);
418 scalecolor(ctmp, emult);
419 setcolr(cscn[i], colval(ctmp,RED),
420 colval(ctmp,GRN), colval(ctmp,BLU));
421 }
422 addray(ro, rd, (double)zscn[i], cscn[i]);
423 }
424 }
425 /* write output and free beams */
426 hdflush(NULL);
427 /* clean up */
428 free((void *)cscn);
429 free((void *)zscn);
430 fclose(pfp);
431 close(zfd);
432 }
433
434
435 void
436 eputs( /* put error message to stderr */
437 char *s
438 )
439 {
440 static int midline = 0;
441
442 if (!*s)
443 return;
444 if (!midline++) { /* prepend line with program name */
445 fputs(progname, stderr);
446 fputs(": ", stderr);
447 }
448 fputs(s, stderr);
449 if (s[strlen(s)-1] == '\n') {
450 fflush(stderr);
451 midline = 0;
452 }
453 }
454
455
456 void
457 quit( /* exit the program gracefully */
458 int code
459 )
460 {
461 hdsync(NULL, 1); /* write out any buffered data */
462 exit(code);
463 }
