1 |
/* Copyright (c) 1999 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Copy data into a holodeck file |
9 |
10 |
11 |
#include "holo.h" |
12 |
#include "view.h" |
13 |
#include "resolu.h" |
14 |
15 |
#ifndef BKBSIZE |
16 |
#define BKBSIZE 256 /* beam clump size (kilobytes) */ |
17 |
#endif |
18 |
19 |
int checkdepth = 1; /* check depth (!-f option)? */ |
20 |
int checkrepeats = 0; /* check for repeats (-c option)? */ |
21 |
int frompicz; /* input from pictures & depth-buffers? */ |
22 |
int noutsects; /* number of output sections */ |
23 |
char obstr, unobstr; /* flag pointer values */ |
24 |
25 |
char *progname; /* global argv[0] */ |
26 |
27 |
28 |
main(argc, argv) |
29 |
int argc; |
30 |
char *argv[]; |
31 |
32 |
int i; |
33 |
34 |
progname = argv[0]; |
35 |
frompicz = -1; |
36 |
for (i = 2; i < argc && argv[i][0] == '-'; i++) |
37 |
switch (argv[i][1]) { |
38 |
case 'u': |
39 |
checkrepeats = 1; |
40 |
break; |
41 |
case 'd': |
42 |
checkdepth = 0; |
43 |
break; |
44 |
case 'h': |
45 |
frompicz = 0; |
46 |
break; |
47 |
case 'p': |
48 |
frompicz = 1; |
49 |
break; |
50 |
default: |
51 |
goto userr; |
52 |
53 |
if (i >= argc || frompicz < 0) |
54 |
goto userr; |
55 |
if (frompicz && (argc-i)%2) |
56 |
goto userr; |
57 |
noutsects = openholo(argv[1], 1); |
58 |
if (frompicz) { |
59 |
for ( ; i < argc; i += 2) |
60 |
addpicz(argv[i], argv[i+1]); |
61 |
} else { |
62 |
if (BKBSIZE*1024*1.5 > hdcachesize) |
63 |
hdcachesize = BKBSIZE*1024*1.5; |
64 |
for ( ; i < argc; i++) |
65 |
addholo(argv[i]); |
66 |
67 |
quit(0); |
68 |
userr: |
69 |
fprintf(stderr, "Usage: %s output.hdk [-u][-d] -h inp1.hdk ..\n", |
70 |
progname); |
71 |
fprintf(stderr, " Or: %s output.hdk [-u][-d] -p inp1.pic inp1.zbf ..\n", |
72 |
progname); |
73 |
exit(1); |
74 |
75 |
76 |
77 |
#define H_BADF 01 |
78 |
#define H_OBST 02 |
79 |
#define H_OBSF 04 |
80 |
81 |
int |
82 |
holheadline(s, hf) /* check holodeck header line */ |
83 |
register char *s; |
84 |
int *hf; |
85 |
86 |
char fmt[32]; |
87 |
88 |
if (formatval(fmt, s)) { |
89 |
if (strcmp(fmt, HOLOFMT)) |
90 |
*hf |= H_BADF; |
91 |
else |
92 |
*hf &= ~H_BADF; |
93 |
return(0); |
94 |
95 |
if (!strncmp(s, "OBSTRUCTIONS=", 13)) { |
96 |
s += 13; |
97 |
while (*s == ' ') s++; |
98 |
if (*s == 't' | *s == 'T') |
99 |
*hf |= H_OBST; |
100 |
else if (*s == 'f' | *s == 'F') |
101 |
*hf |= H_OBSF; |
102 |
else |
103 |
error(WARNING, "bad OBSTRUCTIONS value in holodeck"); |
104 |
return(0); |
105 |
106 |
return(0); |
107 |
108 |
109 |
int |
110 |
openholo(fname, append) /* open existing holodeck file for i/o */ |
111 |
char *fname; |
112 |
int append; |
113 |
114 |
extern long ftell(); |
115 |
FILE *fp; |
116 |
int fd; |
117 |
int hflags = 0; |
118 |
long nextloc; |
119 |
int n; |
120 |
/* open holodeck file */ |
121 |
if ((fp = fopen(fname, append ? "r+" : "r")) == NULL) { |
122 |
sprintf(errmsg, "cannot open \"%s\" for %s", fname, |
123 |
append ? "appending" : "reading"); |
124 |
error(SYSTEM, errmsg); |
125 |
126 |
/* check header and magic number */ |
127 |
if (getheader(fp, holheadline, &hflags) < 0 || |
128 |
hflags&H_BADF || getw(fp) != HOLOMAGIC) { |
129 |
sprintf(errmsg, "file \"%s\" not in holodeck format", fname); |
130 |
error(USER, errmsg); |
131 |
132 |
fd = dup(fileno(fp)); /* dup file handle */ |
133 |
nextloc = ftell(fp); /* get stdio position */ |
134 |
fclose(fp); /* done with stdio */ |
135 |
for (n = 0; nextloc > 0L; n++) { /* initialize each section */ |
136 |
lseek(fd, nextloc, 0); |
137 |
read(fd, (char *)&nextloc, sizeof(nextloc)); |
138 |
hdinit(fd, NULL)->priv = hflags&H_OBST ? &obstr : |
139 |
hflags&H_OBSF ? &unobstr : (char *)NULL; |
140 |
141 |
return(n); |
142 |
143 |
144 |
#undef H_BADF |
145 |
#undef H_OBST |
146 |
#undef H_OBSF |
147 |
148 |
149 |
addray(ro, rd, d, cv) /* add a ray to our output holodeck */ |
150 |
FVECT ro, rd; |
151 |
double d; |
152 |
COLR cv; |
153 |
154 |
int sn, bi, n; |
155 |
register HOLO *hp; |
156 |
GCOORD gc[2]; |
157 |
BYTE rr[2][2]; |
158 |
BEAM *bp; |
159 |
double d0, d1; |
160 |
unsigned dc; |
161 |
register RAYVAL *rv; |
162 |
/* check each output section */ |
163 |
for (sn = noutsects; sn--; ) { |
164 |
hp = hdlist[sn]; |
165 |
d0 = hdinter(gc, rr, &d1, hp, ro, rd); |
166 |
if (d <= d0 || d1 < -0.001) |
167 |
continue; /* missed section */ |
168 |
if (checkdepth) { /* check depth */ |
169 |
if (hp->priv == &obstr && d0 < -0.001) |
170 |
continue; /* ray starts too late */ |
171 |
if (hp->priv == &unobstr && d < 0.999*d1) |
172 |
continue; /* ray ends too soon */ |
173 |
174 |
dc = hdcode(hp, d-d0); |
175 |
bi = hdbindex(hp, gc); /* check for duplicates */ |
176 |
if (checkrepeats && (bp = hdgetbeam(hp, bi)) != NULL) { |
177 |
for (n = bp->nrm, rv = hdbray(bp); n--; rv++) |
178 |
if ((hp->priv != NULL || rv->d == dc) && |
179 |
rv->r[0][0] == rr[0][0] && |
180 |
rv->r[0][1] == rr[0][1] && |
181 |
rv->r[1][0] == rr[1][0] && |
182 |
rv->r[1][1] == rr[1][1]) |
183 |
break; |
184 |
if (n >= 0) |
185 |
continue; /* found a matching ray */ |
186 |
187 |
rv = hdnewrays(hp, bi, 1); |
188 |
rv->d = dc; |
189 |
rv->r[0][0] = rr[0][0]; rv->r[0][1] = rr[0][1]; |
190 |
rv->r[1][0] = rr[1][0]; rv->r[1][1] = rr[1][1]; |
191 |
copycolr(rv->v, cv); |
192 |
193 |
194 |
195 |
196 |
static BEAMI *beamdir; |
197 |
198 |
static int |
199 |
bpcmp(b1p, b2p) /* compare beam positions on disk */ |
200 |
int *b1p, *b2p; |
201 |
202 |
register long pdif = beamdir[*b1p].fo - beamdir[*b2p].fo; |
203 |
204 |
if (pdif > 0L) return(1); |
205 |
if (pdif < 0L) return(-1); |
206 |
return(0); |
207 |
208 |
209 |
static int |
210 |
addclump(hp, bq, nb) /* transfer the given clump and free */ |
211 |
HOLO *hp; |
212 |
int *bq, nb; |
213 |
214 |
GCOORD gc[2]; |
215 |
FVECT ro, rd; |
216 |
double d; |
217 |
int i; |
218 |
register int k; |
219 |
register BEAM *bp; |
220 |
/* sort based on file position */ |
221 |
beamdir = hp->bi; |
222 |
qsort((char *)bq, nb, sizeof(*bq), bpcmp); |
223 |
/* transfer each beam */ |
224 |
for (i = 0; i < nb; i++) { |
225 |
bp = hdgetbeam(hp, bq[i]); |
226 |
hdbcoord(gc, hp, bq[i]); |
227 |
/* add each ray to output */ |
228 |
for (k = bp->nrm; k--; ) { |
229 |
d = hdray(ro, rd, hp, gc, hdbray(bp)[k].r); |
230 |
if (hp->priv == &unobstr) |
231 |
VSUM(ro, ro, rd, d); |
232 |
else |
233 |
d = 0.; |
234 |
d = hddepth(hp, hdbray(bp)[k].d) - d; |
235 |
addray(ro, rd, d, hdbray(bp)[k].v); |
236 |
237 |
hdfreebeam(hp, bq[i]); /* free the beam */ |
238 |
239 |
hdfreebeam(NULL, 0); /* write & free clump */ |
240 |
return(0); |
241 |
242 |
243 |
addholo(hdf) /* add a holodeck file */ |
244 |
char *hdf; |
245 |
246 |
int fd; |
247 |
/* open the holodeck for reading */ |
248 |
openholo(hdf, 0); |
249 |
fd = hdlist[noutsects]->fd; /* remember the file handle */ |
250 |
while (hdlist[noutsects] != NULL) { /* load each section */ |
251 |
/* clump the beams */ |
252 |
clumpbeams(hdlist[noutsects], 0, BKBSIZE*1024, addclump); |
253 |
hddone(hdlist[noutsects]); /* free the section */ |
254 |
255 |
close(fd); /* close input file */ |
256 |
hdflush(NULL); /* flush output */ |
257 |
258 |
259 |
260 |
struct phead { |
261 |
VIEW vw; |
262 |
double expos; |
263 |
short gotview; |
264 |
short badfmt; |
265 |
short altprims; |
266 |
267 |
268 |
269 |
int |
270 |
picheadline(s, ph) /* process picture header line */ |
271 |
char *s; |
272 |
struct phead *ph; |
273 |
274 |
char fmt[32]; |
275 |
276 |
277 |
ph->badfmt = strcmp(fmt, COLRFMT); |
278 |
return(0); |
279 |
280 |
if (isprims(s)) { |
281 |
ph->altprims++; /* don't want to deal with this */ |
282 |
return(0); |
283 |
284 |
if (isexpos(s)) { |
285 |
ph->expos *= exposval(s); |
286 |
return(0); |
287 |
288 |
if (isview(s)) { |
289 |
ph->gotview += sscanview(&ph->vw, s); |
290 |
return(0); |
291 |
292 |
return(0); |
293 |
294 |
295 |
296 |
addpicz(pcf, zbf) /* add a picture + depth-buffer */ |
297 |
char *pcf, *zbf; |
298 |
299 |
FILE *pfp; |
300 |
int zfd; |
301 |
COLR *cscn; |
302 |
float *zscn; |
303 |
struct phead phd; |
304 |
int eshft; |
305 |
double emult; |
306 |
RESOLU prs; |
307 |
FLOAT vl[2]; |
308 |
FVECT ro, rd; |
309 |
double aftd; |
310 |
COLOR ctmp; |
311 |
int j; |
312 |
register int i; |
313 |
/* open files */ |
314 |
if ((pfp = fopen(pcf, "r")) == NULL) { |
315 |
sprintf(errmsg, "cannot open picture file \"%s\"", pcf); |
316 |
error(SYSTEM, pcf); |
317 |
318 |
if ((zfd = open(zbf, O_RDONLY)) < 0) { |
319 |
sprintf(errmsg, "cannot open depth file \"%s\"", zbf); |
320 |
321 |
322 |
/* load picture header */ |
323 |
copystruct(&phd.vw, &stdview); |
324 |
phd.expos = 1.0; |
325 |
phd.badfmt = phd.gotview = phd.altprims = 0; |
326 |
if (getheader(pfp, picheadline, &phd) < 0 || |
327 |
phd.badfmt || !fgetsresolu(&prs, pfp)) { |
328 |
sprintf(errmsg, "bad format for picture file \"%s\"", pcf); |
329 |
330 |
331 |
if (!phd.gotview || setview(&phd.vw) != NULL) { |
332 |
sprintf(errmsg, "missing/illegal view in picture \"%s\"", |
333 |
pcf); |
334 |
335 |
336 |
if (phd.altprims) { |
337 |
sprintf(errmsg, "ignoring primary values in picture \"%s\"", |
338 |
pcf); |
339 |
error(WARNING, errmsg); |
340 |
341 |
/* figure out what to do about exposure */ |
342 |
if (phd.expos < 0.99 | phd.expos > 1.01) { |
343 |
emult = -log(phd.expos)/log(2.); |
344 |
eshft = emult >= 0. ? emult+.5 : emult-.5; |
345 |
emult -= (double)eshft; |
346 |
if (emult <= 0.01 & emult >= -0.01) |
347 |
emult = -1.; |
348 |
else { |
349 |
emult = 1./phd.expos; |
350 |
eshft = 0; |
351 |
352 |
} else { |
353 |
emult = -1.; |
354 |
eshft = 0; |
355 |
356 |
/* allocate buffers */ |
357 |
cscn = (COLR *)malloc(scanlen(&prs)*sizeof(COLR)); |
358 |
zscn = (float *)malloc(scanlen(&prs)*sizeof(float)); |
359 |
if (cscn == NULL | zscn == NULL) |
360 |
error(SYSTEM, "out of memory in addpicz"); |
361 |
/* read and process each scanline */ |
362 |
for (j = 0; j < numscans(&prs); j++) { |
363 |
i = scanlen(&prs); /* read colrs */ |
364 |
if (freadcolrs(cscn, i, pfp) < 0) { |
365 |
sprintf(errmsg, "error reading picture \"%s\"", pcf); |
366 |
367 |
368 |
if (eshft) /* shift exposure */ |
369 |
shiftcolrs(cscn, i, eshft); |
370 |
i *= sizeof(float); /* read depth */ |
371 |
if (read(zfd, (char *)zscn, i) != i) { |
372 |
sprintf(errmsg, "error reading depth file \"%s\"", zbf); |
373 |
374 |
375 |
for (i = scanlen(&prs); i--; ) { /* do each pixel */ |
376 |
pix2loc(vl, &prs, i, j); |
377 |
aftd = viewray(ro, rd, &phd.vw, vl[0], vl[1]); |
378 |
if (aftd < -FTINY) |
379 |
continue; /* off view */ |
380 |
if (aftd > FTINY && zscn[i] > aftd) |
381 |
continue; /* aft clipped */ |
382 |
if (emult > 0.) { /* whatta pain */ |
383 |
colr_color(ctmp, cscn[i]); |
384 |
scalecolor(ctmp, emult); |
385 |
setcolr(cscn[i], colval(ctmp,RED), |
386 |
colval(ctmp,GRN), colval(ctmp,BLU)); |
387 |
388 |
addray(ro, rd, (double)zscn[i], cscn[i]); |
389 |
390 |
391 |
/* write output and free beams */ |
392 |
hdflush(NULL); |
393 |
/* clean up */ |
394 |
free((char *)cscn); |
395 |
free((char *)zscn); |
396 |
fclose(pfp); |
397 |
close(zfd); |
398 |
399 |
400 |
401 |
eputs(s) /* put error message to stderr */ |
402 |
register char *s; |
403 |
404 |
static int midline = 0; |
405 |
406 |
if (!*s) |
407 |
return; |
408 |
if (!midline++) { /* prepend line with program name */ |
409 |
fputs(progname, stderr); |
410 |
fputs(": ", stderr); |
411 |
412 |
fputs(s, stderr); |
413 |
if (s[strlen(s)-1] == '\n') { |
414 |
fflush(stderr); |
415 |
midline = 0; |
416 |
417 |
418 |
419 |
420 |
quit(code) /* exit the program gracefully */ |
421 |
int code; |
422 |
423 |
hdsync(NULL, 1); /* write out any buffered data */ |
424 |
exit(code); |
425 |
