Added check for byte-swapping
Added binary option for Windows
Added check for zero in z-buffer input
Improved wording of error message
Changed holodeck section pointers to off_t to avoid issues with rhcopy
Fixed 64-bit bug in rhcopy and rhoptimize
Ansification and prototypes.
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
removed unnecessary call to hdfreebeams() that increased fragmentation
made caching code slightly more efficient
improved duplicate ray checking
change clumpbeams() callback function to take clump's queue
moved routines to clumpbeams.c and made rhcopy clump beams
changed -c option to -u and -f option to -d
tried to fix poor performance of sorted load by going to partial sort
fixed bug from sorting change (3.4
added -f (fudge distance check) and -c (check repeats) options
change code to read beams in file order
went back to use of long file pointers
made checking of OBSTRUCTIONS variable more accurate
