--- ray/src/hd/rhcopy.c 1998/11/09 17:11:40 3.10 +++ ray/src/hd/rhcopy.c 2010/09/30 15:43:30 3.26 @@ -1,33 +1,50 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rhcopy.c,v 3.26 2010/09/30 15:43:30 greg Exp $"; #endif - /* * Copy data into a holodeck file */ +#include "platform.h" +#include "rterror.h" #include "holo.h" #include "view.h" -#include "resolu.h" #ifndef BKBSIZE #define BKBSIZE 256 /* beam clump size (kilobytes) */ #endif -int checkdepth = 1; /* check depth (!-f option)? */ -int checkrepeats = 0; /* check for repeats (-c option)? */ +int checkdepth = 1; /* check depth (!-d option)? */ +int checkrepeats = 0; /* check for repeats (-u option)? */ int frompicz; /* input from pictures & depth-buffers? */ int noutsects; /* number of output sections */ char obstr, unobstr; /* flag pointer values */ char *progname; /* global argv[0] */ +struct phead { + VIEW vw; + double expos; + short gotview; + short badfmt; + short altprims; +}; +static int openholo(char *fname, int append); +static void addray(FVECT ro, FVECT rd, double d, COLR cv); +static gethfunc holheadline; +static int bpcmp(const void *b1p, const void *b2p); +static int addclump(HOLO *hp, int *bq, int nb); +static void addholo(char *hdf); +static gethfunc picheadline; +static void addpicz(char *pcf, char *zbf); -main(argc, argv) -int argc; -char *argv[]; + + +int +main( + int argc, + char *argv[] +) { int i; @@ -68,7 +85,7 @@ char *argv[]; userr: fprintf(stderr, "Usage: %s output.hdk [-u][-d] -h inp1.hdk ..\n", progname); - fprintf(stderr, " Or: %s output.hdk [-u][-d] -p inp1.pic inp1.zbf ..\n", + fprintf(stderr, " Or: %s output.hdk [-u][-d] -p inp1.hdr inp1.zbf ..\n", progname); exit(1); } @@ -78,12 +95,14 @@ userr: #define H_OBST 02 #define H_OBSF 04 -int -holheadline(s, hf) /* check holodeck header line */ -register char *s; -int *hf; +static int +holheadline( /* check holodeck header line */ + register char *s, + void *vhf +) { char fmt[32]; + int *hf = vhf; if (formatval(fmt, s)) { if (strcmp(fmt, HOLOFMT)) @@ -95,9 +114,9 @@ int *hf; if (!strncmp(s, "OBSTRUCTIONS=", 13)) { s += 13; while (*s == ' ') s++; - if (*s == 't' | *s == 'T') + if ((*s == 't') | (*s == 'T')) *hf |= H_OBST; - else if (*s == 'f' | *s == 'F') + else if ((*s == 'f') | (*s == 'F')) *hf |= H_OBSF; else error(WARNING, "bad OBSTRUCTIONS value in holodeck"); @@ -107,15 +126,15 @@ int *hf; } int -openholo(fname, append) /* open existing holodeck file for i/o */ -char *fname; -int append; +openholo( /* open existing holodeck file for i/o */ + char *fname, + int append +) { - extern long ftell(); FILE *fp; int fd; int hflags = 0; - long nextloc; + off_t nextloc; int n; /* open holodeck file */ if ((fp = fopen(fname, append ? "r+" : "r")) == NULL) { @@ -133,7 +152,7 @@ int append; nextloc = ftell(fp); /* get stdio position */ fclose(fp); /* done with stdio */ for (n = 0; nextloc > 0L; n++) { /* initialize each section */ - lseek(fd, nextloc, 0); + lseek(fd, nextloc, SEEK_SET); read(fd, (char *)&nextloc, sizeof(nextloc)); hdinit(fd, NULL)->priv = hflags&H_OBST ? &obstr : hflags&H_OBSF ? &unobstr : (char *)NULL; @@ -146,10 +165,13 @@ int append; #undef H_OBSF -addray(ro, rd, d, cv) /* add a ray to our output holodeck */ -FVECT ro, rd; -double d; -COLR cv; +void +addray( /* add a ray to our output holodeck */ + FVECT ro, + FVECT rd, + double d, + COLR cv +) { int sn, bi, n; register HOLO *hp; @@ -175,7 +197,7 @@ COLR cv; bi = hdbindex(hp, gc); /* check for duplicates */ if (checkrepeats && (bp = hdgetbeam(hp, bi)) != NULL) { for (n = bp->nrm, rv = hdbray(bp); n--; rv++) - if (rv->d == dc && + if ((hp->priv != NULL || rv->d == dc) && rv->r[0][0] == rr[0][0] && rv->r[0][1] == rr[0][1] && rv->r[1][0] == rr[1][0] && @@ -193,32 +215,61 @@ COLR cv; } -addbeam(bp, hb) /* add a beam to our output holodeck */ -register BEAM *bp; -register HDBEAMI *hb; +static BEAMI *beamdir; + +static int +bpcmp( /* compare beam positions on disk */ + const void *b1p, + const void *b2p +) { + register off_t pdif = beamdir[*(int*)b1p].fo - beamdir[*(int*)b2p].fo; + + if (pdif > 0L) return(1); + if (pdif < 0L) return(-1); + return(0); +} + +static int +addclump( /* transfer the given clump and free */ + HOLO *hp, + int *bq, + int nb +) +{ GCOORD gc[2]; FVECT ro, rd; double d; + int i; register int k; - /* get beam coordinates */ - hdbcoord(gc, hb->h, hb->b); - /* add each ray to output */ - for (k = bp->nrm; k--; ) { - d = hdray(ro, rd, hb->h, gc, hdbray(bp)[k].r); - if (hb->h->priv == &unobstr) - VSUM(ro, ro, rd, d); - else - d = 0.; - d = hddepth(hb->h, hdbray(bp)[k].d) - d; - addray(ro, rd, d, hdbray(bp)[k].v); + register BEAM *bp; + /* sort based on file position */ + beamdir = hp->bi; + qsort((char *)bq, nb, sizeof(*bq), bpcmp); + /* transfer each beam */ + for (i = 0; i < nb; i++) { + bp = hdgetbeam(hp, bq[i]); + hdbcoord(gc, hp, bq[i]); + /* add each ray to output */ + for (k = bp->nrm; k--; ) { + d = hdray(ro, rd, hp, gc, hdbray(bp)[k].r); + if (hp->priv == &unobstr) + VSUM(ro, ro, rd, d); + else + d = 0.; + d = hddepth(hp, hdbray(bp)[k].d) - d; + addray(ro, rd, d, hdbray(bp)[k].v); + } + hdfreebeam(hp, bq[i]); /* free the beam */ } - hdfreebeam(hb->h, hb->b); /* free the beam */ + return(0); } -addholo(hdf) /* add a holodeck file */ -char *hdf; +void +addholo( /* add a holodeck file */ + char *hdf +) { int fd; /* open the holodeck for reading */ @@ -226,28 +277,23 @@ char *hdf; fd = hdlist[noutsects]->fd; /* remember the file handle */ while (hdlist[noutsects] != NULL) { /* load each section */ /* clump the beams */ - clumpbeams(hdlist[noutsects], 0, BKBSIZE*1024, addbeam); + clumpbeams(hdlist[noutsects], 0, BKBSIZE*1024, addclump); hddone(hdlist[noutsects]); /* free the section */ } close(fd); /* close input file */ + hdflush(NULL); /* flush output */ } -struct phead { - VIEW vw; - double expos; - short gotview; - short badfmt; - short altprims; -}; - -int -picheadline(s, ph) /* process picture header line */ -char *s; -struct phead *ph; +static int +picheadline( /* process picture header line */ + char *s, + void *vph +) { char fmt[32]; + struct phead *ph = vph; if (formatval(fmt, s)) { ph->badfmt = strcmp(fmt, COLRFMT); @@ -269,8 +315,11 @@ struct phead *ph; } -addpicz(pcf, zbf) /* add a picture + depth-buffer */ -char *pcf, *zbf; +void +addpicz( /* add a picture + depth-buffer */ + char *pcf, + char *zbf +) { FILE *pfp; int zfd; @@ -280,7 +329,7 @@ char *pcf, *zbf; int eshft; double emult; RESOLU prs; - FLOAT vl[2]; + RREAL vl[2]; FVECT ro, rd; double aftd; COLOR ctmp; @@ -296,7 +345,7 @@ char *pcf, *zbf; error(SYSTEM, pcf); } /* load picture header */ - copystruct(&phd.vw, &stdview); + phd.vw = stdview; phd.expos = 1.0; phd.badfmt = phd.gotview = phd.altprims = 0; if (getheader(pfp, picheadline, &phd) < 0 || @@ -315,11 +364,11 @@ char *pcf, *zbf; error(WARNING, errmsg); } /* figure out what to do about exposure */ - if (phd.expos < 0.99 | phd.expos > 1.01) { + if ((phd.expos < 0.99) | (phd.expos > 1.01)) { emult = -log(phd.expos)/log(2.); eshft = emult >= 0. ? emult+.5 : emult-.5; emult -= (double)eshft; - if (emult <= 0.01 & emult >= -0.01) + if ((emult <= 0.01) & (emult >= -0.01)) emult = -1.; else { emult = 1./phd.expos; @@ -332,7 +381,7 @@ char *pcf, *zbf; /* allocate buffers */ cscn = (COLR *)malloc(scanlen(&prs)*sizeof(COLR)); zscn = (float *)malloc(scanlen(&prs)*sizeof(float)); - if (cscn == NULL | zscn == NULL) + if ((cscn == NULL) | (zscn == NULL)) error(SYSTEM, "out of memory in addpicz"); /* read and process each scanline */ for (j = 0; j < numscans(&prs); j++) { @@ -364,18 +413,20 @@ char *pcf, *zbf; addray(ro, rd, (double)zscn[i], cscn[i]); } } - /* write output */ - hdsync(NULL, 1); + /* write output and free beams */ + hdflush(NULL); /* clean up */ - free((char *)cscn); - free((char *)zscn); + free((void *)cscn); + free((void *)zscn); fclose(pfp); close(zfd); } -eputs(s) /* put error message to stderr */ -register char *s; +void +eputs( /* put error message to stderr */ + register char *s +) { static int midline = 0; @@ -393,8 +444,10 @@ register char *s; } -quit(code) /* exit the program gracefully */ -int code; +void +quit( /* exit the program gracefully */ + int code +) { hdsync(NULL, 1); /* write out any buffered data */ exit(code);
