root/radiance/ray/src/hd/rhcopy.c
Revision: 3.27
Committed: Fri May 20 02:06:39 2011 UTC (14 years, 1 month ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R1, rad4R2P1
Changes since 3.26: +2 -2 lines
# User Rev Content
1 gregl 3.1 #ifndef lint
2 greg 3.27 static const char RCSid[] = "$Id: rhcopy.c,v 3.26 2010/09/30 15:43:30 greg Exp $";
3 gregl 3.1 #endif
4     /*
5     * Copy data into a holodeck file
6     */
7
8 greg 3.21 #include "platform.h"
9 schorsch 3.22 #include "rterror.h"
10 gregl 3.1 #include "holo.h"
11     #include "view.h"
12
13 gwlarson 3.10 #ifndef BKBSIZE
14     #define BKBSIZE 256 /* beam clump size (kilobytes) */
15 gregl 3.7 #endif
16
17 gwlarson 3.14 int checkdepth = 1; /* check depth (!-d option)? */
18     int checkrepeats = 0; /* check for repeats (-u option)? */
19 gregl 3.1 int frompicz; /* input from pictures & depth-buffers? */
20     int noutsects; /* number of output sections */
21 gregl 3.2 char obstr, unobstr; /* flag pointer values */
22 gregl 3.1
23     char *progname; /* global argv[0] */
24
25 schorsch 3.22 struct phead {
26     VIEW vw;
27     double expos;
28     short gotview;
29     short badfmt;
30     short altprims;
31     };
32     static int openholo(char *fname, int append);
33     static void addray(FVECT ro, FVECT rd, double d, COLR cv);
34 schorsch 3.23 static gethfunc holheadline;
35 schorsch 3.22 static int bpcmp(const void *b1p, const void *b2p);
36     static int addclump(HOLO *hp, int *bq, int nb);
37     static void addholo(char *hdf);
38 schorsch 3.23 static gethfunc picheadline;
39 schorsch 3.22 static void addpicz(char *pcf, char *zbf);
40
41
42 gregl 3.1
43 schorsch 3.22 int
44     main(
45     int argc,
46     char *argv[]
47     )
48 gregl 3.1 {
49     int i;
50
51     progname = argv[0];
52 gregl 3.5 frompicz = -1;
53     for (i = 2; i < argc && argv[i][0] == '-'; i++)
54     switch (argv[i][1]) {
55 gregl 3.8 case 'u':
56 gregl 3.5 checkrepeats = 1;
57     break;
58 gregl 3.8 case 'd':
59 gregl 3.5 checkdepth = 0;
60     break;
61     case 'h':
62     frompicz = 0;
63     break;
64     case 'p':
65     frompicz = 1;
66     break;
67     default:
68     goto userr;
69     }
70     if (i >= argc || frompicz < 0)
71 gregl 3.1 goto userr;
72 gregl 3.5 if (frompicz && (argc-i)%2)
73 gregl 3.1 goto userr;
74     noutsects = openholo(argv[1], 1);
75 gwlarson 3.10 if (frompicz) {
76 gregl 3.5 for ( ; i < argc; i += 2)
77 gregl 3.1 addpicz(argv[i], argv[i+1]);
78 gwlarson 3.10 } else {
79     if (BKBSIZE*1024*1.5 > hdcachesize)
80     hdcachesize = BKBSIZE*1024*1.5;
81 gregl 3.5 for ( ; i < argc; i++)
82 gregl 3.1 addholo(argv[i]);
83 gwlarson 3.10 }
84 gregl 3.1 quit(0);
85     userr:
86 gregl 3.8 fprintf(stderr, "Usage: %s output.hdk [-u][-d] -h inp1.hdk ..\n",
87 gregl 3.1 progname);
88 greg 3.24 fprintf(stderr, " Or: %s output.hdk [-u][-d] -p inp1.hdr inp1.zbf ..\n",
89 gregl 3.5 progname);
90 gregl 3.1 exit(1);
91     }
92
93
94 gregl 3.2 #define H_BADF 01
95     #define H_OBST 02
96     #define H_OBSF 04
97
98 schorsch 3.23 static int
99 schorsch 3.22 holheadline( /* check holodeck header line */
100     register char *s,
101 schorsch 3.23 void *vhf
102 schorsch 3.22 )
103 gregl 3.1 {
104     char fmt[32];
105 schorsch 3.23 int *hf = vhf;
106 gregl 3.1
107     if (formatval(fmt, s)) {
108 gregl 3.2 if (strcmp(fmt, HOLOFMT))
109     *hf |= H_BADF;
110     else
111     *hf &= ~H_BADF;
112 gwlarson 3.9 return(0);
113 gregl 3.1 }
114     if (!strncmp(s, "OBSTRUCTIONS=", 13)) {
115     s += 13;
116     while (*s == ' ') s++;
117 schorsch 3.19 if ((*s == 't') | (*s == 'T'))
118 gregl 3.2 *hf |= H_OBST;
119 schorsch 3.19 else if ((*s == 'f') | (*s == 'F'))
120 gregl 3.2 *hf |= H_OBSF;
121 gregl 3.1 else
122     error(WARNING, "bad OBSTRUCTIONS value in holodeck");
123 gwlarson 3.9 return(0);
124 gregl 3.1 }
125 gwlarson 3.9 return(0);
126 gregl 3.1 }
127
128     int
129 schorsch 3.22 openholo( /* open existing holodeck file for i/o */
130     char *fname,
131     int append
132     )
133 gregl 3.1 {
134     FILE *fp;
135     int fd;
136 gregl 3.2 int hflags = 0;
137 greg 3.26 off_t nextloc;
138 gregl 3.1 int n;
139     /* open holodeck file */
140     if ((fp = fopen(fname, append ? "r+" : "r")) == NULL) {
141     sprintf(errmsg, "cannot open \"%s\" for %s", fname,
142     append ? "appending" : "reading");
143     error(SYSTEM, errmsg);
144     }
145     /* check header and magic number */
146 schorsch 3.23 if (getheader(fp, holheadline, &hflags) < 0 ||
147 gregl 3.2 hflags&H_BADF || getw(fp) != HOLOMAGIC) {
148 gregl 3.1 sprintf(errmsg, "file \"%s\" not in holodeck format", fname);
149     error(USER, errmsg);
150     }
151     fd = dup(fileno(fp)); /* dup file handle */
152     nextloc = ftell(fp); /* get stdio position */
153     fclose(fp); /* done with stdio */
154     for (n = 0; nextloc > 0L; n++) { /* initialize each section */
155 greg 3.26 lseek(fd, nextloc, SEEK_SET);
156 gregl 3.1 read(fd, (char *)&nextloc, sizeof(nextloc));
157 gregl 3.2 hdinit(fd, NULL)->priv = hflags&H_OBST ? &obstr :
158     hflags&H_OBSF ? &unobstr : (char *)NULL;
159 gregl 3.1 }
160     return(n);
161     }
162
163 gregl 3.2 #undef H_BADF
164     #undef H_OBST
165     #undef H_OBSF
166 gregl 3.1
167 gregl 3.2
168 schorsch 3.22 void
169     addray( /* add a ray to our output holodeck */
170     FVECT ro,
171     FVECT rd,
172     double d,
173     COLR cv
174     )
175 gregl 3.1 {
176 gregl 3.5 int sn, bi, n;
177 gregl 3.1 register HOLO *hp;
178     GCOORD gc[2];
179 greg 3.27 uby8 rr[2][2];
180 gregl 3.5 BEAM *bp;
181 gregl 3.1 double d0, d1;
182 gregl 3.5 unsigned dc;
183 gregl 3.1 register RAYVAL *rv;
184     /* check each output section */
185     for (sn = noutsects; sn--; ) {
186     hp = hdlist[sn];
187     d0 = hdinter(gc, rr, &d1, hp, ro, rd);
188     if (d <= d0 || d1 < -0.001)
189     continue; /* missed section */
190 gregl 3.5 if (checkdepth) { /* check depth */
191     if (hp->priv == &obstr && d0 < -0.001)
192     continue; /* ray starts too late */
193     if (hp->priv == &unobstr && d < 0.999*d1)
194     continue; /* ray ends too soon */
195     }
196     dc = hdcode(hp, d-d0);
197     bi = hdbindex(hp, gc); /* check for duplicates */
198     if (checkrepeats && (bp = hdgetbeam(hp, bi)) != NULL) {
199     for (n = bp->nrm, rv = hdbray(bp); n--; rv++)
200 gwlarson 3.12 if ((hp->priv != NULL || rv->d == dc) &&
201 gregl 3.5 rv->r[0][0] == rr[0][0] &&
202     rv->r[0][1] == rr[0][1] &&
203     rv->r[1][0] == rr[1][0] &&
204     rv->r[1][1] == rr[1][1])
205     break;
206     if (n >= 0)
207     continue; /* found a matching ray */
208     }
209     rv = hdnewrays(hp, bi, 1);
210     rv->d = dc;
211 gregl 3.1 rv->r[0][0] = rr[0][0]; rv->r[0][1] = rr[0][1];
212     rv->r[1][0] = rr[1][0]; rv->r[1][1] = rr[1][1];
213     copycolr(rv->v, cv);
214     }
215     }
216
217
218 gwlarson 3.11 static BEAMI *beamdir;
219
220     static int
221 schorsch 3.22 bpcmp( /* compare beam positions on disk */
222     const void *b1p,
223     const void *b2p
224     )
225 gregl 3.1 {
226 schorsch 3.22 register off_t pdif = beamdir[*(int*)b1p].fo - beamdir[*(int*)b2p].fo;
227 gwlarson 3.11
228     if (pdif > 0L) return(1);
229     if (pdif < 0L) return(-1);
230     return(0);
231     }
232
233     static int
234 schorsch 3.22 addclump( /* transfer the given clump and free */
235     HOLO *hp,
236     int *bq,
237     int nb
238     )
239 gwlarson 3.11 {
240 gregl 3.1 GCOORD gc[2];
241     FVECT ro, rd;
242     double d;
243 gwlarson 3.11 int i;
244 gregl 3.1 register int k;
245 gwlarson 3.11 register BEAM *bp;
246     /* sort based on file position */
247     beamdir = hp->bi;
248     qsort((char *)bq, nb, sizeof(*bq), bpcmp);
249     /* transfer each beam */
250     for (i = 0; i < nb; i++) {
251     bp = hdgetbeam(hp, bq[i]);
252     hdbcoord(gc, hp, bq[i]);
253     /* add each ray to output */
254     for (k = bp->nrm; k--; ) {
255     d = hdray(ro, rd, hp, gc, hdbray(bp)[k].r);
256     if (hp->priv == &unobstr)
257     VSUM(ro, ro, rd, d);
258     else
259     d = 0.;
260     d = hddepth(hp, hdbray(bp)[k].d) - d;
261     addray(ro, rd, d, hdbray(bp)[k].v);
262     }
263     hdfreebeam(hp, bq[i]); /* free the beam */
264 gwlarson 3.10 }
265 gwlarson 3.11 return(0);
266 gwlarson 3.10 }
267
268 schorsch 3.22
269     void
270     addholo( /* add a holodeck file */
271     char *hdf
272     )
273 gwlarson 3.10 {
274     int fd;
275 gregl 3.4 /* open the holodeck for reading */
276     openholo(hdf, 0);
277 gregl 3.1 fd = hdlist[noutsects]->fd; /* remember the file handle */
278 gwlarson 3.10 while (hdlist[noutsects] != NULL) { /* load each section */
279     /* clump the beams */
280 gwlarson 3.11 clumpbeams(hdlist[noutsects], 0, BKBSIZE*1024, addclump);
281 gwlarson 3.10 hddone(hdlist[noutsects]); /* free the section */
282 gregl 3.1 }
283 gwlarson 3.10 close(fd); /* close input file */
284 gwlarson 3.13 hdflush(NULL); /* flush output */
285 gregl 3.1 }
286
287
288
289 schorsch 3.23 static int
290 schorsch 3.22 picheadline( /* process picture header line */
291     char *s,
292 schorsch 3.23 void *vph
293 schorsch 3.22 )
294 gregl 3.1 {
295     char fmt[32];
296 schorsch 3.23 struct phead *ph = vph;
297 gregl 3.1
298     if (formatval(fmt, s)) {
299     ph->badfmt = strcmp(fmt, COLRFMT);
300 gwlarson 3.9 return(0);
301 gregl 3.1 }
302     if (isprims(s)) {
303     ph->altprims++; /* don't want to deal with this */
304 gwlarson 3.9 return(0);
305 gregl 3.1 }
306     if (isexpos(s)) {
307     ph->expos *= exposval(s);
308 gwlarson 3.9 return(0);
309 gregl 3.1 }
310     if (isview(s)) {
311     ph->gotview += sscanview(&ph->vw, s);
312 gwlarson 3.9 return(0);
313 gregl 3.1 }
314 gwlarson 3.9 return(0);
315 gregl 3.1 }
316
317
318 schorsch 3.22 void
319     addpicz( /* add a picture + depth-buffer */
320     char *pcf,
321     char *zbf
322     )
323 gregl 3.1 {
324     FILE *pfp;
325     int zfd;
326     COLR *cscn;
327     float *zscn;
328     struct phead phd;
329     int eshft;
330     double emult;
331     RESOLU prs;
332 schorsch 3.17 RREAL vl[2];
333 gregl 3.1 FVECT ro, rd;
334     double aftd;
335     COLOR ctmp;
336     int j;
337     register int i;
338     /* open files */
339     if ((pfp = fopen(pcf, "r")) == NULL) {
340     sprintf(errmsg, "cannot open picture file \"%s\"", pcf);
341     error(SYSTEM, pcf);
342     }
343     if ((zfd = open(zbf, O_RDONLY)) < 0) {
344     sprintf(errmsg, "cannot open depth file \"%s\"", zbf);
345     error(SYSTEM, pcf);
346     }
347     /* load picture header */
348 schorsch 3.18 phd.vw = stdview;
349 gregl 3.1 phd.expos = 1.0;
350     phd.badfmt = phd.gotview = phd.altprims = 0;
351 schorsch 3.23 if (getheader(pfp, picheadline, &phd) < 0 ||
352 gregl 3.1 phd.badfmt || !fgetsresolu(&prs, pfp)) {
353     sprintf(errmsg, "bad format for picture file \"%s\"", pcf);
354     error(USER, errmsg);
355     }
356     if (!phd.gotview || setview(&phd.vw) != NULL) {
357     sprintf(errmsg, "missing/illegal view in picture \"%s\"",
358     pcf);
359     error(USER, errmsg);
360     }
361     if (phd.altprims) {
362     sprintf(errmsg, "ignoring primary values in picture \"%s\"",
363     pcf);
364     error(WARNING, errmsg);
365     }
366     /* figure out what to do about exposure */
367 schorsch 3.19 if ((phd.expos < 0.99) | (phd.expos > 1.01)) {
368 gregl 3.1 emult = -log(phd.expos)/log(2.);
369     eshft = emult >= 0. ? emult+.5 : emult-.5;
370     emult -= (double)eshft;
371 schorsch 3.19 if ((emult <= 0.01) & (emult >= -0.01))
372 gregl 3.1 emult = -1.;
373     else {
374     emult = 1./phd.expos;
375     eshft = 0;
376     }
377     } else {
378     emult = -1.;
379     eshft = 0;
380     }
381     /* allocate buffers */
382     cscn = (COLR *)malloc(scanlen(&prs)*sizeof(COLR));
383     zscn = (float *)malloc(scanlen(&prs)*sizeof(float));
384 schorsch 3.19 if ((cscn == NULL) | (zscn == NULL))
385 gregl 3.1 error(SYSTEM, "out of memory in addpicz");
386     /* read and process each scanline */
387     for (j = 0; j < numscans(&prs); j++) {
388     i = scanlen(&prs); /* read colrs */
389     if (freadcolrs(cscn, i, pfp) < 0) {
390     sprintf(errmsg, "error reading picture \"%s\"", pcf);
391     error(USER, errmsg);
392     }
393     if (eshft) /* shift exposure */
394     shiftcolrs(cscn, i, eshft);
395     i *= sizeof(float); /* read depth */
396     if (read(zfd, (char *)zscn, i) != i) {
397     sprintf(errmsg, "error reading depth file \"%s\"", zbf);
398     error(USER, errmsg);
399     }
400     for (i = scanlen(&prs); i--; ) { /* do each pixel */
401     pix2loc(vl, &prs, i, j);
402     aftd = viewray(ro, rd, &phd.vw, vl[0], vl[1]);
403     if (aftd < -FTINY)
404     continue; /* off view */
405     if (aftd > FTINY && zscn[i] > aftd)
406     continue; /* aft clipped */
407     if (emult > 0.) { /* whatta pain */
408     colr_color(ctmp, cscn[i]);
409     scalecolor(ctmp, emult);
410     setcolr(cscn[i], colval(ctmp,RED),
411     colval(ctmp,GRN), colval(ctmp,BLU));
412     }
413     addray(ro, rd, (double)zscn[i], cscn[i]);
414     }
415     }
416 gwlarson 3.11 /* write output and free beams */
417     hdflush(NULL);
418 gregl 3.1 /* clean up */
419 greg 3.15 free((void *)cscn);
420     free((void *)zscn);
421 gregl 3.1 fclose(pfp);
422     close(zfd);
423     }
424
425
426 greg 3.15 void
427 schorsch 3.22 eputs( /* put error message to stderr */
428     register char *s
429     )
430 gregl 3.1 {
431     static int midline = 0;
432
433     if (!*s)
434     return;
435     if (!midline++) { /* prepend line with program name */
436     fputs(progname, stderr);
437     fputs(": ", stderr);
438     }
439     fputs(s, stderr);
440     if (s[strlen(s)-1] == '\n') {
441     fflush(stderr);
442     midline = 0;
443     }
444     }
445
446
447 greg 3.15 void
448 schorsch 3.22 quit( /* exit the program gracefully */
449     int code
450     )
451 gregl 3.1 {
452     hdsync(NULL, 1); /* write out any buffered data */
453     exit(code);
454     }
