root/radiance/ray/src/hd/rhcopy.c
Changes since 3.14: +8 -10 lines
Diff to previous 3.14
Revision 3.14 - (view) (download) (annotate) - [selected]
Mon Mar 8 17:32:26 1999 UTC (25 years, 3 months ago) by gwlarson
Changes since 3.13: +2 -3 lines
Diff to previous 3.13
removed unnecessary call to hdfreebeams() that increased fragmentation
Mon Feb 1 10:22:46 1999 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.12: +2 -1 lines
Diff to previous 3.12 , to selected 3.14
made caching code slightly more efficient
Sat Jan 9 09:16:31 1999 UTC (25 years, 5 months ago) by gwlarson
Diff to previous 3.11 , to selected 3.14
improved duplicate ray checking
Thu Nov 12 15:06:00 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.10: +42 -19 lines
Diff to previous 3.10 , to selected 3.14
change clumpbeams() callback function to take clump's queue
Mon Nov 9 17:11:40 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.9: +39 -44 lines
Diff to previous 3.9 , to selected 3.14
moved routines to clumpbeams.c and made rhcopy clump beams
Tue Oct 27 08:49:50 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.8: +10 -6 lines
Diff to previous 3.8 , to selected 3.14
Fri Jan 23 09:05:14 1998 UTC (26 years, 4 months ago) by gregl
Changes since 3.7: +4 -4 lines
Diff to previous 3.7 , to selected 3.14
changed -c option to -u and -f option to -d
Wed Jan 7 17:46:18 1998 UTC (26 years, 5 months ago) by gregl
Changes since 3.6: +23 -15 lines
Diff to previous 3.6 , to selected 3.14
tried to fix poor performance of sorted load by going to partial sort
Wed Jan 7 10:49:12 1998 UTC (26 years, 5 months ago) by gregl
Diff to previous 3.5 , to selected 3.14
fixed bug from sorting change (3.4
Wed Jan 7 09:23:02 1998 UTC (26 years, 5 months ago) by gregl
Changes since 3.4: +51 -20 lines
Diff to previous 3.4 , to selected 3.14
added -f (fudge distance check) and -c (check repeats) options
Tue Jan 6 22:02:22 1998 UTC (26 years, 5 months ago) by gregl
Changes since 3.3: +16 -6 lines
Diff to previous 3.3 , to selected 3.14
change code to read beams in file order
Tue Jan 6 05:57:07 1998 UTC (26 years, 5 months ago) by gregl
Diff to previous 3.2 , to selected 3.14
went back to use of long file pointers
Thu Dec 18 10:03:29 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.1: +31 -18 lines
Diff to previous 3.1 , to selected 3.14
made checking of OBSTRUCTIONS variable more accurate
Thu Dec 18 09:33:42 1997 UTC (26 years, 5 months ago) by gregl
Diff to selected 3.14
