--- ray/src/hd/rhcopy.c 1998/01/07 10:49:12 3.6 +++ ray/src/hd/rhcopy.c 2019/11/07 23:17:58 3.33 @@ -1,29 +1,50 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rhcopy.c,v 3.33 2019/11/07 23:17:58 greg Exp $"; #endif - /* * Copy data into a holodeck file */ +#include "platform.h" +#include "rterror.h" #include "holo.h" #include "view.h" -#include "resolu.h" -int checkdepth = 1; /* check depth (!-f option)? */ -int checkrepeats = 0; /* check for repeats (-c option)? */ +#ifndef BKBSIZE +#define BKBSIZE 256 /* beam clump size (kilobytes) */ +#endif + +int checkdepth = 1; /* check depth (!-d option)? */ +int checkrepeats = 0; /* check for repeats (-u option)? */ int frompicz; /* input from pictures & depth-buffers? */ int noutsects; /* number of output sections */ char obstr, unobstr; /* flag pointer values */ char *progname; /* global argv[0] */ +struct phead { + VIEW vw; + double expos; + short gotview; + short badfmt; + short altprims; +}; +static int openholo(char *fname, int append); +static void addray(FVECT ro, FVECT rd, double d, COLR cv); +static gethfunc holheadline; +static int bpcmp(const void *b1p, const void *b2p); +static int addclump(HOLO *hp, int *bq, int nb); +static void addholo(char *hdf); +static gethfunc picheadline; +static void addpicz(char *pcf, char *zbf); -main(argc, argv) -int argc; -char *argv[]; + + +int +main( + int argc, + char *argv[] +) { int i; @@ -31,10 +52,10 @@ char *argv[]; frompicz = -1; for (i = 2; i < argc && argv[i][0] == '-'; i++) switch (argv[i][1]) { - case 'c': + case 'u': checkrepeats = 1; break; - case 'f': + case 'd': checkdepth = 0; break; case 'h': @@ -51,17 +72,20 @@ char *argv[]; if (frompicz && (argc-i)%2) goto userr; noutsects = openholo(argv[1], 1); - if (frompicz) + if (frompicz) { for ( ; i < argc; i += 2) addpicz(argv[i], argv[i+1]); - else + } else { + if (BKBSIZE*1024*1.5 > hdcachesize) + hdcachesize = BKBSIZE*1024*1.5; for ( ; i < argc; i++) addholo(argv[i]); + } quit(0); userr: - fprintf(stderr, "Usage: %s output.hdk [-c][-f] -h inp1.hdk ..\n", + fprintf(stderr, "Usage: %s output.hdk [-u][-d] -h inp1.hdk ..\n", progname); - fprintf(stderr, " Or: %s output.hdk [-c][-f] -pz inp1.pic inp1.zbf ..\n", + fprintf(stderr, " Or: %s output.hdk [-u][-d] -p inp1.hdr inp1.zbf ..\n", progname); exit(1); } @@ -70,61 +94,71 @@ userr: #define H_BADF 01 #define H_OBST 02 #define H_OBSF 04 +#define H_SWAP 010 -holheadline(s, hf) /* check holodeck header line */ -register char *s; -int *hf; +static int +holheadline( /* check holodeck header line */ + char *s, + void *vhf +) { - char fmt[32]; + int be; + char fmt[MAXFMTLEN]; + int *hf = vhf; if (formatval(fmt, s)) { if (strcmp(fmt, HOLOFMT)) *hf |= H_BADF; else *hf &= ~H_BADF; - return; + return(0); } if (!strncmp(s, "OBSTRUCTIONS=", 13)) { s += 13; while (*s == ' ') s++; - if (*s == 't' | *s == 'T') + if ((*s == 't') | (*s == 'T')) *hf |= H_OBST; - else if (*s == 'f' | *s == 'F') + else if ((*s == 'f') | (*s == 'F')) *hf |= H_OBSF; else error(WARNING, "bad OBSTRUCTIONS value in holodeck"); - return; + return(0); } + if ((be = isbigendian(s)) >= 0) { + if (be != nativebigendian()) + *hf |= H_SWAP; + } + return(0); } int -openholo(fname, append) /* open existing holodeck file for i/o */ -char *fname; -int append; +openholo( /* open existing holodeck file for i/o */ + char *fname, + int append +) { - extern long ftell(); FILE *fp; int fd; int hflags = 0; - long nextloc; + off_t nextloc; int n; /* open holodeck file */ - if ((fp = fopen(fname, append ? "r+" : "r")) == NULL) { + if ((fp = fopen(fname, append ? "rb+" : "rb")) == NULL) { sprintf(errmsg, "cannot open \"%s\" for %s", fname, append ? "appending" : "reading"); error(SYSTEM, errmsg); } /* check header and magic number */ if (getheader(fp, holheadline, &hflags) < 0 || - hflags&H_BADF || getw(fp) != HOLOMAGIC) { - sprintf(errmsg, "file \"%s\" not in holodeck format", fname); + hflags&(H_BADF|H_SWAP) || getw(fp) != HOLOMAGIC) { + sprintf(errmsg, "holodeck \"%s\" not in expected format", fname); error(USER, errmsg); } fd = dup(fileno(fp)); /* dup file handle */ nextloc = ftell(fp); /* get stdio position */ fclose(fp); /* done with stdio */ for (n = 0; nextloc > 0L; n++) { /* initialize each section */ - lseek(fd, nextloc, 0); + lseek(fd, nextloc, SEEK_SET); read(fd, (char *)&nextloc, sizeof(nextloc)); hdinit(fd, NULL)->priv = hflags&H_OBST ? &obstr : hflags&H_OBSF ? &unobstr : (char *)NULL; @@ -137,19 +171,22 @@ int append; #undef H_OBSF -addray(ro, rd, d, cv) /* add a ray to our output holodeck */ -FVECT ro, rd; -double d; -COLR cv; +void +addray( /* add a ray to our output holodeck */ + FVECT ro, + FVECT rd, + double d, + COLR cv +) { int sn, bi, n; - register HOLO *hp; + HOLO *hp; GCOORD gc[2]; - BYTE rr[2][2]; + uby8 rr[2][2]; BEAM *bp; double d0, d1; unsigned dc; - register RAYVAL *rv; + RAYVAL *rv; /* check each output section */ for (sn = noutsects; sn--; ) { hp = hdlist[sn]; @@ -166,7 +203,7 @@ COLR cv; bi = hdbindex(hp, gc); /* check for duplicates */ if (checkrepeats && (bp = hdgetbeam(hp, bi)) != NULL) { for (n = bp->nrm, rv = hdbray(bp); n--; rv++) - if (rv->d == dc && + if ((hp->priv != NULL || rv->d == dc) && rv->r[0][0] == rr[0][0] && rv->r[0][1] == rr[0][1] && rv->r[1][0] == rr[1][0] && @@ -184,88 +221,111 @@ COLR cv; } -addholo(hdf) /* add a holodeck file */ -char *hdf; +static BEAMI *beamdir; + +static int +bpcmp( /* compare beam positions on disk */ + const void *b1p, + const void *b2p +) { - int fd; - register HOLO *hp; - register BEAM *bp; - register HDBEAMI *hbl; + off_t pdif = beamdir[*(int*)b1p].fo - beamdir[*(int*)b2p].fo; + + if (pdif > 0L) return(1); + if (pdif < 0L) return(-1); + return(0); +} + +static int +addclump( /* transfer the given clump and free */ + HOLO *hp, + int *bq, + int nb +) +{ GCOORD gc[2]; FVECT ro, rd; double d; - int i, j; - register int k; + int i; + int k; + BEAM *bp; + /* sort based on file position */ + beamdir = hp->bi; + qsort((char *)bq, nb, sizeof(*bq), bpcmp); + /* transfer each beam */ + for (i = 0; i < nb; i++) { + bp = hdgetbeam(hp, bq[i]); + hdbcoord(gc, hp, bq[i]); + /* add each ray to output */ + for (k = bp->nrm; k--; ) { + d = hdray(ro, rd, hp, gc, hdbray(bp)[k].r); + if (hp->priv == &unobstr) + VSUM(ro, ro, rd, d); + else + d = 0.; + d = hddepth(hp, hdbray(bp)[k].d) - d; + addray(ro, rd, d, hdbray(bp)[k].v); + } + hdfreebeam(hp, bq[i]); /* free the beam */ + } + return(0); +} + + +void +addholo( /* add a holodeck file */ + char *hdf +) +{ + int fd; /* open the holodeck for reading */ openholo(hdf, 0); fd = hdlist[noutsects]->fd; /* remember the file handle */ - while ((hp = hdlist[noutsects]) != NULL) { /* load each section */ - hbl = (HDBEAMI *)malloc(nbeams(hp)*sizeof(HDBEAMI)); - if (hbl == NULL) - error(SYSTEM, "out of memory in addholo"); - for (j = nbeams(hp); j--; ) { /* sort the beams */ - hbl[j].h = hp; - hbl[j].b = j+1; - } - qsort((char *)hbl, nbeams(hp), sizeof(HDBEAMI), hdfilord); - for (j = 0; j < nbeams(hp); j++) /* load each beam */ - if ((bp = hdgetbeam(hp, hbl[j].b)) != NULL) { - hdbcoord(gc, hp, hbl[j].b); - for (k = bp->nrm; k--; ) { - d = hdray(ro, rd, - hp, gc, hdbray(bp)[k].r); - if (hp->priv == &unobstr) - VSUM(ro, ro, rd, d); - else - d = 0.; - d = hddepth(hp, hdbray(bp)[k].d) - d; - addray(ro, rd, d, hdbray(bp)[k].v); - } - hdfreebeam(hp, hbl[j].b); /* free beam */ - } - free((char *)hbl); /* free beam list */ - hddone(hp); /* free the section */ + while (hdlist[noutsects] != NULL) { /* load each section */ + /* clump the beams */ + clumpbeams(hdlist[noutsects], 0, BKBSIZE*1024, addclump); + hddone(hdlist[noutsects]); /* free the section */ } - close(fd); /* close the file */ + close(fd); /* close input file */ + hdflush(NULL); /* flush output */ } -struct phead { - VIEW vw; - double expos; - short gotview; - short badfmt; - short altprims; -}; - -picheadline(s, ph) /* process picture header line */ -char *s; -struct phead *ph; +static int +picheadline( /* process picture header line */ + char *s, + void *vph +) { char fmt[32]; + struct phead *ph = vph; if (formatval(fmt, s)) { ph->badfmt = strcmp(fmt, COLRFMT); - return; + return(0); } if (isprims(s)) { ph->altprims++; /* don't want to deal with this */ - return; + return(0); } if (isexpos(s)) { ph->expos *= exposval(s); - return; + return(0); } if (isview(s)) { ph->gotview += sscanview(&ph->vw, s); - return; + return(0); } + return(0); } -addpicz(pcf, zbf) /* add a picture + depth-buffer */ -char *pcf, *zbf; +void +addpicz( /* add a picture + depth-buffer */ + char *pcf, + char *zbf +) { FILE *pfp; int zfd; @@ -275,14 +335,14 @@ char *pcf, *zbf; int eshft; double emult; RESOLU prs; - FLOAT vl[2]; + RREAL vl[2]; FVECT ro, rd; double aftd; COLOR ctmp; int j; - register int i; + int i; /* open files */ - if ((pfp = fopen(pcf, "r")) == NULL) { + if ((pfp = fopen(pcf, "rb")) == NULL) { sprintf(errmsg, "cannot open picture file \"%s\"", pcf); error(SYSTEM, pcf); } @@ -290,8 +350,9 @@ char *pcf, *zbf; sprintf(errmsg, "cannot open depth file \"%s\"", zbf); error(SYSTEM, pcf); } + SET_FD_BINARY(zfd); /* load picture header */ - copystruct(&phd.vw, &stdview); + phd.vw = stdview; phd.expos = 1.0; phd.badfmt = phd.gotview = phd.altprims = 0; if (getheader(pfp, picheadline, &phd) < 0 || @@ -305,16 +366,16 @@ char *pcf, *zbf; error(USER, errmsg); } if (phd.altprims) { - sprintf(errmsg, "ignoring primary values in picture \"%s\"", + sprintf(errmsg, "ignoring color primaries in picture \"%s\"", pcf); error(WARNING, errmsg); } /* figure out what to do about exposure */ - if (phd.expos < 0.99 | phd.expos > 1.01) { + if ((phd.expos < 0.99) | (phd.expos > 1.01)) { emult = -log(phd.expos)/log(2.); eshft = emult >= 0. ? emult+.5 : emult-.5; emult -= (double)eshft; - if (emult <= 0.01 & emult >= -0.01) + if ((emult <= 0.01) & (emult >= -0.01)) emult = -1.; else { emult = 1./phd.expos; @@ -327,7 +388,7 @@ char *pcf, *zbf; /* allocate buffers */ cscn = (COLR *)malloc(scanlen(&prs)*sizeof(COLR)); zscn = (float *)malloc(scanlen(&prs)*sizeof(float)); - if (cscn == NULL | zscn == NULL) + if ((cscn == NULL) | (zscn == NULL)) error(SYSTEM, "out of memory in addpicz"); /* read and process each scanline */ for (j = 0; j < numscans(&prs); j++) { @@ -338,12 +399,14 @@ char *pcf, *zbf; } if (eshft) /* shift exposure */ shiftcolrs(cscn, i, eshft); - i *= sizeof(float); /* read depth */ - if (read(zfd, (char *)zscn, i) != i) { + /* read depth */ + if (read(zfd, zscn, i*sizeof(float)) != i*sizeof(float)) { sprintf(errmsg, "error reading depth file \"%s\"", zbf); error(USER, errmsg); } - for (i = scanlen(&prs); i--; ) { /* do each pixel */ + while (i--) { /* process each pixel */ + if (zscn[i] <= 0.0) + continue; /* illegal depth */ pix2loc(vl, &prs, i, j); aftd = viewray(ro, rd, &phd.vw, vl[0], vl[1]); if (aftd < -FTINY) @@ -359,16 +422,20 @@ char *pcf, *zbf; addray(ro, rd, (double)zscn[i], cscn[i]); } } + /* write output and free beams */ + hdflush(NULL); /* clean up */ - free((char *)cscn); - free((char *)zscn); + free((void *)cscn); + free((void *)zscn); fclose(pfp); close(zfd); } -eputs(s) /* put error message to stderr */ -register char *s; +void +eputs( /* put error message to stderr */ + char *s +) { static int midline = 0; @@ -386,8 +453,10 @@ register char *s; } -quit(code) /* exit the program gracefully */ -int code; +void +quit( /* exit the program gracefully */ + int code +) { hdsync(NULL, 1); /* write out any buffered data */ exit(code);
