--- ray/src/hd/rhcopy.c 2018/08/02 18:33:42 3.30 +++ ray/src/hd/rhcopy.c 2018/10/05 19:19:16 3.31 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rhcopy.c,v 3.30 2018/08/02 18:33:42 greg Exp $"; +static const char RCSid[] = "$Id: rhcopy.c,v 3.31 2018/10/05 19:19:16 greg Exp $"; #endif /* * Copy data into a holodeck file @@ -97,7 +97,7 @@ userr: static int holheadline( /* check holodeck header line */ - register char *s, + char *s, void *vhf ) { @@ -174,13 +174,13 @@ addray( /* add a ray to our output holodeck */ ) { int sn, bi, n; - register HOLO *hp; + HOLO *hp; GCOORD gc[2]; uby8 rr[2][2]; BEAM *bp; double d0, d1; unsigned dc; - register RAYVAL *rv; + RAYVAL *rv; /* check each output section */ for (sn = noutsects; sn--; ) { hp = hdlist[sn]; @@ -223,7 +223,7 @@ bpcmp( /* compare beam positions on disk */ const void *b2p ) { - register off_t pdif = beamdir[*(int*)b1p].fo - beamdir[*(int*)b2p].fo; + off_t pdif = beamdir[*(int*)b1p].fo - beamdir[*(int*)b2p].fo; if (pdif > 0L) return(1); if (pdif < 0L) return(-1); @@ -241,8 +241,8 @@ addclump( /* transfer the given clump and free */ FVECT ro, rd; double d; int i; - register int k; - register BEAM *bp; + int k; + BEAM *bp; /* sort based on file position */ beamdir = hp->bi; qsort((char *)bq, nb, sizeof(*bq), bpcmp); @@ -334,7 +334,7 @@ addpicz( /* add a picture + depth-buffer */ double aftd; COLOR ctmp; int j; - register int i; + int i; /* open files */ if ((pfp = fopen(pcf, "r")) == NULL) { sprintf(errmsg, "cannot open picture file \"%s\"", pcf); @@ -427,7 +427,7 @@ addpicz( /* add a picture + depth-buffer */ void eputs( /* put error message to stderr */ - register char *s + char *s ) { static int midline = 0;
