--- ray/src/hd/rhcopy.c 1999/01/09 09:16:31 3.12 +++ ray/src/hd/rhcopy.c 2018/10/05 19:19:16 3.31 @@ -1,33 +1,50 @@ -/* Copyright (c) 1999 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rhcopy.c,v 3.31 2018/10/05 19:19:16 greg Exp $"; #endif - /* * Copy data into a holodeck file */ +#include "platform.h" +#include "rterror.h" #include "holo.h" #include "view.h" -#include "resolu.h" #ifndef BKBSIZE #define BKBSIZE 256 /* beam clump size (kilobytes) */ #endif -int checkdepth = 1; /* check depth (!-f option)? */ -int checkrepeats = 0; /* check for repeats (-c option)? */ +int checkdepth = 1; /* check depth (!-d option)? */ +int checkrepeats = 0; /* check for repeats (-u option)? */ int frompicz; /* input from pictures & depth-buffers? */ int noutsects; /* number of output sections */ char obstr, unobstr; /* flag pointer values */ char *progname; /* global argv[0] */ +struct phead { + VIEW vw; + double expos; + short gotview; + short badfmt; + short altprims; +}; +static int openholo(char *fname, int append); +static void addray(FVECT ro, FVECT rd, double d, COLR cv); +static gethfunc holheadline; +static int bpcmp(const void *b1p, const void *b2p); +static int addclump(HOLO *hp, int *bq, int nb); +static void addholo(char *hdf); +static gethfunc picheadline; +static void addpicz(char *pcf, char *zbf); -main(argc, argv) -int argc; -char *argv[]; + + +int +main( + int argc, + char *argv[] +) { int i; @@ -68,7 +85,7 @@ char *argv[]; userr: fprintf(stderr, "Usage: %s output.hdk [-u][-d] -h inp1.hdk ..\n", progname); - fprintf(stderr, " Or: %s output.hdk [-u][-d] -p inp1.pic inp1.zbf ..\n", + fprintf(stderr, " Or: %s output.hdk [-u][-d] -p inp1.hdr inp1.zbf ..\n", progname); exit(1); } @@ -78,12 +95,14 @@ userr: #define H_OBST 02 #define H_OBSF 04 -int -holheadline(s, hf) /* check holodeck header line */ -register char *s; -int *hf; +static int +holheadline( /* check holodeck header line */ + char *s, + void *vhf +) { - char fmt[32]; + char fmt[MAXFMTLEN]; + int *hf = vhf; if (formatval(fmt, s)) { if (strcmp(fmt, HOLOFMT)) @@ -95,9 +114,9 @@ int *hf; if (!strncmp(s, "OBSTRUCTIONS=", 13)) { s += 13; while (*s == ' ') s++; - if (*s == 't' | *s == 'T') + if ((*s == 't') | (*s == 'T')) *hf |= H_OBST; - else if (*s == 'f' | *s == 'F') + else if ((*s == 'f') | (*s == 'F')) *hf |= H_OBSF; else error(WARNING, "bad OBSTRUCTIONS value in holodeck"); @@ -107,15 +126,15 @@ int *hf; } int -openholo(fname, append) /* open existing holodeck file for i/o */ -char *fname; -int append; +openholo( /* open existing holodeck file for i/o */ + char *fname, + int append +) { - extern long ftell(); FILE *fp; int fd; int hflags = 0; - long nextloc; + off_t nextloc; int n; /* open holodeck file */ if ((fp = fopen(fname, append ? "r+" : "r")) == NULL) { @@ -133,7 +152,7 @@ int append; nextloc = ftell(fp); /* get stdio position */ fclose(fp); /* done with stdio */ for (n = 0; nextloc > 0L; n++) { /* initialize each section */ - lseek(fd, nextloc, 0); + lseek(fd, nextloc, SEEK_SET); read(fd, (char *)&nextloc, sizeof(nextloc)); hdinit(fd, NULL)->priv = hflags&H_OBST ? &obstr : hflags&H_OBSF ? &unobstr : (char *)NULL; @@ -146,19 +165,22 @@ int append; #undef H_OBSF -addray(ro, rd, d, cv) /* add a ray to our output holodeck */ -FVECT ro, rd; -double d; -COLR cv; +void +addray( /* add a ray to our output holodeck */ + FVECT ro, + FVECT rd, + double d, + COLR cv +) { int sn, bi, n; - register HOLO *hp; + HOLO *hp; GCOORD gc[2]; - BYTE rr[2][2]; + uby8 rr[2][2]; BEAM *bp; double d0, d1; unsigned dc; - register RAYVAL *rv; + RAYVAL *rv; /* check each output section */ for (sn = noutsects; sn--; ) { hp = hdlist[sn]; @@ -196,10 +218,12 @@ COLR cv; static BEAMI *beamdir; static int -bpcmp(b1p, b2p) /* compare beam positions on disk */ -int *b1p, *b2p; +bpcmp( /* compare beam positions on disk */ + const void *b1p, + const void *b2p +) { - register long pdif = beamdir[*b1p].fo - beamdir[*b2p].fo; + off_t pdif = beamdir[*(int*)b1p].fo - beamdir[*(int*)b2p].fo; if (pdif > 0L) return(1); if (pdif < 0L) return(-1); @@ -207,16 +231,18 @@ int *b1p, *b2p; } static int -addclump(hp, bq, nb) /* transfer the given clump and free */ -HOLO *hp; -int *bq, nb; +addclump( /* transfer the given clump and free */ + HOLO *hp, + int *bq, + int nb +) { GCOORD gc[2]; FVECT ro, rd; double d; int i; - register int k; - register BEAM *bp; + int k; + BEAM *bp; /* sort based on file position */ beamdir = hp->bi; qsort((char *)bq, nb, sizeof(*bq), bpcmp); @@ -236,12 +262,14 @@ int *bq, nb; } hdfreebeam(hp, bq[i]); /* free the beam */ } - hdflush(NULL); /* write & free clump */ return(0); } -addholo(hdf) /* add a holodeck file */ -char *hdf; + +void +addholo( /* add a holodeck file */ + char *hdf +) { int fd; /* open the holodeck for reading */ @@ -253,24 +281,19 @@ char *hdf; hddone(hdlist[noutsects]); /* free the section */ } close(fd); /* close input file */ + hdflush(NULL); /* flush output */ } -struct phead { - VIEW vw; - double expos; - short gotview; - short badfmt; - short altprims; -}; - -int -picheadline(s, ph) /* process picture header line */ -char *s; -struct phead *ph; +static int +picheadline( /* process picture header line */ + char *s, + void *vph +) { char fmt[32]; + struct phead *ph = vph; if (formatval(fmt, s)) { ph->badfmt = strcmp(fmt, COLRFMT); @@ -292,8 +315,11 @@ struct phead *ph; } -addpicz(pcf, zbf) /* add a picture + depth-buffer */ -char *pcf, *zbf; +void +addpicz( /* add a picture + depth-buffer */ + char *pcf, + char *zbf +) { FILE *pfp; int zfd; @@ -303,12 +329,12 @@ char *pcf, *zbf; int eshft; double emult; RESOLU prs; - FLOAT vl[2]; + RREAL vl[2]; FVECT ro, rd; double aftd; COLOR ctmp; int j; - register int i; + int i; /* open files */ if ((pfp = fopen(pcf, "r")) == NULL) { sprintf(errmsg, "cannot open picture file \"%s\"", pcf); @@ -319,7 +345,7 @@ char *pcf, *zbf; error(SYSTEM, pcf); } /* load picture header */ - copystruct(&phd.vw, &stdview); + phd.vw = stdview; phd.expos = 1.0; phd.badfmt = phd.gotview = phd.altprims = 0; if (getheader(pfp, picheadline, &phd) < 0 || @@ -333,16 +359,16 @@ char *pcf, *zbf; error(USER, errmsg); } if (phd.altprims) { - sprintf(errmsg, "ignoring primary values in picture \"%s\"", + sprintf(errmsg, "ignoring color primaries in picture \"%s\"", pcf); error(WARNING, errmsg); } /* figure out what to do about exposure */ - if (phd.expos < 0.99 | phd.expos > 1.01) { + if ((phd.expos < 0.99) | (phd.expos > 1.01)) { emult = -log(phd.expos)/log(2.); eshft = emult >= 0. ? emult+.5 : emult-.5; emult -= (double)eshft; - if (emult <= 0.01 & emult >= -0.01) + if ((emult <= 0.01) & (emult >= -0.01)) emult = -1.; else { emult = 1./phd.expos; @@ -355,7 +381,7 @@ char *pcf, *zbf; /* allocate buffers */ cscn = (COLR *)malloc(scanlen(&prs)*sizeof(COLR)); zscn = (float *)malloc(scanlen(&prs)*sizeof(float)); - if (cscn == NULL | zscn == NULL) + if ((cscn == NULL) | (zscn == NULL)) error(SYSTEM, "out of memory in addpicz"); /* read and process each scanline */ for (j = 0; j < numscans(&prs); j++) { @@ -372,6 +398,8 @@ char *pcf, *zbf; error(USER, errmsg); } for (i = scanlen(&prs); i--; ) { /* do each pixel */ + if (zscn[i] <= 0.0) + continue; /* illegal depth */ pix2loc(vl, &prs, i, j); aftd = viewray(ro, rd, &phd.vw, vl[0], vl[1]); if (aftd < -FTINY) @@ -390,15 +418,17 @@ char *pcf, *zbf; /* write output and free beams */ hdflush(NULL); /* clean up */ - free((char *)cscn); - free((char *)zscn); + free((void *)cscn); + free((void *)zscn); fclose(pfp); close(zfd); } -eputs(s) /* put error message to stderr */ -register char *s; +void +eputs( /* put error message to stderr */ + char *s +) { static int midline = 0; @@ -416,8 +446,10 @@ register char *s; } -quit(code) /* exit the program gracefully */ -int code; +void +quit( /* exit the program gracefully */ + int code +) { hdsync(NULL, 1); /* write out any buffered data */ exit(code);
