--- ray/src/hd/rhcopy.c 2004/01/01 11:21:55 3.22 +++ ray/src/hd/rhcopy.c 2018/08/02 18:33:42 3.30 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rhcopy.c,v 3.22 2004/01/01 11:21:55 schorsch Exp $"; +static const char RCSid[] = "$Id: rhcopy.c,v 3.30 2018/08/02 18:33:42 greg Exp $"; #endif /* * Copy data into a holodeck file @@ -31,11 +31,11 @@ struct phead { }; static int openholo(char *fname, int append); static void addray(FVECT ro, FVECT rd, double d, COLR cv); -static int holheadline(char *s, int *hf); +static gethfunc holheadline; static int bpcmp(const void *b1p, const void *b2p); static int addclump(HOLO *hp, int *bq, int nb); static void addholo(char *hdf); -static int picheadline(char *s, struct phead *ph); +static gethfunc picheadline; static void addpicz(char *pcf, char *zbf); @@ -85,7 +85,7 @@ main( userr: fprintf(stderr, "Usage: %s output.hdk [-u][-d] -h inp1.hdk ..\n", progname); - fprintf(stderr, " Or: %s output.hdk [-u][-d] -p inp1.pic inp1.zbf ..\n", + fprintf(stderr, " Or: %s output.hdk [-u][-d] -p inp1.hdr inp1.zbf ..\n", progname); exit(1); } @@ -95,13 +95,14 @@ userr: #define H_OBST 02 #define H_OBSF 04 -int +static int holheadline( /* check holodeck header line */ register char *s, - int *hf + void *vhf ) { - char fmt[32]; + char fmt[MAXFMTLEN]; + int *hf = vhf; if (formatval(fmt, s)) { if (strcmp(fmt, HOLOFMT)) @@ -133,7 +134,7 @@ openholo( /* open existing holodeck file for i/o */ FILE *fp; int fd; int hflags = 0; - long nextloc; + off_t nextloc; int n; /* open holodeck file */ if ((fp = fopen(fname, append ? "r+" : "r")) == NULL) { @@ -142,7 +143,7 @@ openholo( /* open existing holodeck file for i/o */ error(SYSTEM, errmsg); } /* check header and magic number */ - if (getheader(fp, holheadline, (char *)&hflags) < 0 || + if (getheader(fp, holheadline, &hflags) < 0 || hflags&H_BADF || getw(fp) != HOLOMAGIC) { sprintf(errmsg, "file \"%s\" not in holodeck format", fname); error(USER, errmsg); @@ -151,7 +152,7 @@ openholo( /* open existing holodeck file for i/o */ nextloc = ftell(fp); /* get stdio position */ fclose(fp); /* done with stdio */ for (n = 0; nextloc > 0L; n++) { /* initialize each section */ - lseek(fd, (off_t)nextloc, SEEK_SET); + lseek(fd, nextloc, SEEK_SET); read(fd, (char *)&nextloc, sizeof(nextloc)); hdinit(fd, NULL)->priv = hflags&H_OBST ? &obstr : hflags&H_OBSF ? &unobstr : (char *)NULL; @@ -175,7 +176,7 @@ addray( /* add a ray to our output holodeck */ int sn, bi, n; register HOLO *hp; GCOORD gc[2]; - BYTE rr[2][2]; + uby8 rr[2][2]; BEAM *bp; double d0, d1; unsigned dc; @@ -285,13 +286,14 @@ addholo( /* add a holodeck file */ -int +static int picheadline( /* process picture header line */ char *s, - struct phead *ph + void *vph ) { char fmt[32]; + struct phead *ph = vph; if (formatval(fmt, s)) { ph->badfmt = strcmp(fmt, COLRFMT); @@ -346,7 +348,7 @@ addpicz( /* add a picture + depth-buffer */ phd.vw = stdview; phd.expos = 1.0; phd.badfmt = phd.gotview = phd.altprims = 0; - if (getheader(pfp, picheadline, (char *)&phd) < 0 || + if (getheader(pfp, picheadline, &phd) < 0 || phd.badfmt || !fgetsresolu(&prs, pfp)) { sprintf(errmsg, "bad format for picture file \"%s\"", pcf); error(USER, errmsg); @@ -357,7 +359,7 @@ addpicz( /* add a picture + depth-buffer */ error(USER, errmsg); } if (phd.altprims) { - sprintf(errmsg, "ignoring primary values in picture \"%s\"", + sprintf(errmsg, "ignoring color primaries in picture \"%s\"", pcf); error(WARNING, errmsg); } @@ -396,6 +398,8 @@ addpicz( /* add a picture + depth-buffer */ error(USER, errmsg); } for (i = scanlen(&prs); i--; ) { /* do each pixel */ + if (zscn[i] <= 0.0) + continue; /* illegal depth */ pix2loc(vl, &prs, i, j); aftd = viewray(ro, rd, &phd.vw, vl[0], vl[1]); if (aftd < -FTINY)
