| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: holofile.c,v 3.57 2004/09/09 01:41:21 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Routines for managing holodeck files
| 6 |
| 7 |
* 9/30/97 GWLarson
| 8 |
| 9 |
| 10 |
#include "copyright.h"
| 11 |
| 12 |
#include <string.h>
| 13 |
| 14 |
#include "platform.h"
| 15 |
#include "rtprocess.h"
| 16 |
| 17 |
#include "holo.h"
| 18 |
| 19 |
#ifndef CACHESIZE
| 20 |
#ifdef SMLMEM
| 21 |
#define CACHESIZE 10
| 22 |
#else
| 23 |
#define CACHESIZE 100 /* default cache size (Mbytes, 0==inf) */
| 24 |
#endif
| 25 |
#endif
| 26 |
#ifndef FREEBEAMS
| 27 |
#define FREEBEAMS 1500 /* maximum beams to free at a time */
| 28 |
#endif
| 29 |
#ifndef PCTFREE
| 30 |
#define PCTFREE 15 /* maximum fraction to free (%) */
| 31 |
#endif
| 32 |
#ifndef MAXFRAGB
| 33 |
#define MAXFRAGB 64 /* fragment blocks/file to track (0==inf) */
| 34 |
#endif
| 35 |
#ifndef FF_DEFAULT
| 36 |
/* when to free a beam fragment */
| 37 |
#define FF_DEFAULT (FF_WRITE|FF_KILL)
| 38 |
#endif
| 39 |
#ifndef MINDIRSEL
| 40 |
/* minimum directory seek length */
| 41 |
#define MINDIRSEL (4*BUFSIZ/sizeof(BEAMI))
| 42 |
#endif
| 43 |
| 44 |
#ifndef BSD
| 45 |
#define write writebuf /* safe i/o routines */
| 46 |
#define read readbuf
| 47 |
#endif
| 48 |
| 49 |
#define FRAGBLK 512 /* number of fragments to allocate at a time */
| 50 |
| 51 |
int hdfragflags = FF_DEFAULT; /* tells when to free fragments */
| 52 |
unsigned hdcachesize = CACHESIZE*1024*1024; /* target cache size */
| 53 |
unsigned long hdclock; /* clock value */
| 54 |
| 55 |
HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */
| 56 |
| 57 |
static struct fraglist {
| 58 |
short nlinks; /* number of holodeck sections using us */
| 59 |
short writable; /* 0 read-only, <0 write error encountered */
| 60 |
int nfrags; /* number of known fragments */
| 61 |
BEAMI *fi; /* fragments, descending file position */
| 62 |
off_t flen; /* last known file length */
| 63 |
} *hdfragl; /* fragment lists, indexed by file descriptor */
| 64 |
| 65 |
static int nhdfragls; /* size of hdfragl array */
| 66 |
| 67 |
static HOLO *hdalloc(HDGRID *hproto);
| 68 |
static char *hdrealloc(char *ptr, unsigned siz, char *rout);
| 69 |
static void hdattach(int fd, int wr);
| 70 |
static void hdrelease(int fd);
| 71 |
static void hdmarkdirty(HOLO *hp, int i);
| 72 |
static unsigned int hdmemuse(int all);
| 73 |
static int hdfilord(const void *hb1, const void *hb2);
| 74 |
static off_t hdallocfrag(int fd, uint32 nrays);
| 75 |
static int hdsyncbeam(HOLO *hp, int i);
| 76 |
static int hdlrulist(HDBEAMI *hb, int nents, int n, HOLO *hp);
| 77 |
static int hdfreecache(int pct, HOLO *honly);
| 78 |
| 79 |
| 80 |
| 81 |
HOLO *
| 82 |
hdalloc( /* allocate and set holodeck section based on grid */
| 83 |
HDGRID *hproto
| 84 |
| 85 |
| 86 |
HOLO hdhead;
| 87 |
register HOLO *hp;
| 88 |
int n;
| 89 |
/* copy grid to temporary header */
| 90 |
memcpy((void *)&hdhead, (void *)hproto, sizeof(HDGRID));
| 91 |
/* compute grid vectors and sizes */
| 92 |
hdcompgrid(&hdhead);
| 93 |
/* allocate header with directory */
| 94 |
n = sizeof(HOLO)+nbeams(&hdhead)*sizeof(BEAMI);
| 95 |
if ((hp = (HOLO *)malloc(n)) == NULL)
| 96 |
return(NULL);
| 97 |
/* copy header information */
| 98 |
*hp = hdhead;
| 99 |
/* allocate and clear beam list */
| 100 |
hp->bl = (BEAM **)malloc((nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM));
| 101 |
if (hp->bl == NULL) {
| 102 |
free((void *)hp);
| 103 |
return(NULL);
| 104 |
| 105 |
memset((void *)hp->bl, '\0', (nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM));
| 106 |
hp->bl[0] = (BEAM *)(hp->bl+nbeams(hp)+1); /* set blglob(hp) */
| 107 |
hp->fd = -1;
| 108 |
hp->dirty = 0;
| 109 |
hp->priv = NULL;
| 110 |
/* clear beam directory */
| 111 |
memset((void *)hp->bi, '\0', (nbeams(hp)+1)*sizeof(BEAMI));
| 112 |
return(hp); /* all is well */
| 113 |
| 114 |
| 115 |
| 116 |
char *
| 117 |
hdrealloc( /* (re)allocate memory, retry then error */
| 118 |
char *ptr,
| 119 |
unsigned siz,
| 120 |
char *rout
| 121 |
| 122 |
| 123 |
register char *newp;
| 124 |
/* call malloc/realloc */
| 125 |
if (ptr == NULL) newp = (char *)malloc(siz);
| 126 |
else newp = (char *)realloc((void *)ptr, siz);
| 127 |
/* check success */
| 128 |
if (newp == NULL && rout != NULL) {
| 129 |
hdfreecache(25, NULL); /* free some memory */
| 130 |
errno = 0; /* retry */
| 131 |
newp = hdrealloc(ptr, siz, NULL);
| 132 |
if (newp == NULL) { /* give up and report error */
| 133 |
sprintf(errmsg, "out of memory in %s", rout);
| 134 |
error(SYSTEM, errmsg);
| 135 |
| 136 |
| 137 |
return(newp);
| 138 |
| 139 |
| 140 |
| 141 |
void
| 142 |
hdattach( /* start tracking file fragments for some section */
| 143 |
register int fd,
| 144 |
int wr
| 145 |
| 146 |
| 147 |
if (fd >= nhdfragls) {
| 148 |
hdfragl = (struct fraglist *)hdrealloc((char *)hdfragl,
| 149 |
(fd+1)*sizeof(struct fraglist), "hdattach");
| 150 |
memset((void *)(hdfragl+nhdfragls),
| 151 |
'\0', (fd+1-nhdfragls)*sizeof(struct fraglist));
| 152 |
nhdfragls = fd+1;
| 153 |
| 154 |
hdfragl[fd].nlinks++;
| 155 |
hdfragl[fd].writable = wr; /* set writable flag */
| 156 |
/* get file length */
| 157 |
hdfragl[fd].flen = lseek(fd, (off_t)0, SEEK_END);
| 158 |
| 159 |
| 160 |
| 161 |
/* Do we need a routine to locate file fragments given known occupants? */
| 162 |
| 163 |
| 164 |
void
| 165 |
hdrelease( /* stop tracking file fragments for some section */
| 166 |
register int fd
| 167 |
| 168 |
| 169 |
if ((fd < 0) | (fd >= nhdfragls) || !hdfragl[fd].nlinks)
| 170 |
return;
| 171 |
if (!--hdfragl[fd].nlinks && hdfragl[fd].nfrags) {
| 172 |
free((void *)hdfragl[fd].fi);
| 173 |
hdfragl[fd].fi = NULL;
| 174 |
hdfragl[fd].nfrags = 0;
| 175 |
| 176 |
| 177 |
| 178 |
| 179 |
extern HOLO *
| 180 |
hdinit( /* initialize a holodeck section in a file */
| 181 |
int fd, /* corresponding file descriptor */
| 182 |
HDGRID *hproto /* holodeck section grid */
| 183 |
| 184 |
| 185 |
off_t rtrunc;
| 186 |
off_t fpos;
| 187 |
int writable;
| 188 |
register HOLO *hp;
| 189 |
register int n;
| 190 |
/* prepare for system errors */
| 191 |
errno = 0;
| 192 |
if ((fpos = lseek(fd, (off_t)0, SEEK_CUR)) < 0)
| 193 |
error(SYSTEM, "cannot determine holodeck file position");
| 194 |
if (hproto == NULL) { /* assume we're loading it */
| 195 |
HDGRID hpr;
| 196 |
/* load header */
| 197 |
if (read(fd, (char *)&hpr, sizeof(HDGRID)) != sizeof(HDGRID))
| 198 |
error(SYSTEM, "cannot load holodeck header");
| 199 |
/* allocate grid */
| 200 |
if ((hp = hdalloc(&hpr)) == NULL)
| 201 |
goto memerr;
| 202 |
/* load beam directory */
| 203 |
n = nbeams(hp)*sizeof(BEAMI);
| 204 |
if (read(fd, (char *)(hp->bi+1), n) != n)
| 205 |
error(SYSTEM, "failure loading holodeck directory");
| 206 |
/* check that it's clean */
| 207 |
for (n = nbeams(hp); n > 0; n--)
| 208 |
if (hp->bi[n].fo < 0) {
| 209 |
hp->bi[n].fo = 0;
| 210 |
error(WARNING, "dirty holodeck section");
| 211 |
break;
| 212 |
| 213 |
/* check writability */
| 214 |
if (fd < nhdfragls && hdfragl[fd].nlinks)
| 215 |
writable = hdfragl[fd].writable;
| 216 |
else
| 217 |
writable = lseek(fd, fpos, SEEK_SET) == fpos &&
| 218 |
write(fd, (char *)hp, sizeof(HDGRID)) ==
| 219 |
sizeof(HDGRID);
| 220 |
} else { /* else assume we're creating it */
| 221 |
if ((hp = hdalloc(hproto)) == NULL)
| 222 |
goto memerr;
| 223 |
/* write header and skeleton */
| 224 |
| 225 |
if (write(fd, (char *)hproto, sizeof(HDGRID)) !=
| 226 |
sizeof(HDGRID) ||
| 227 |
write(fd, (char *)(hp->bi+1), n) != n)
| 228 |
error(SYSTEM, "cannot write header to holodeck file");
| 229 |
writable = 1;
| 230 |
| 231 |
hp->fd = fd;
| 232 |
hp->dirty = 0;
| 233 |
biglob(hp)->fo = fpos + sizeof(HDGRID);
| 234 |
/* start tracking fragments */
| 235 |
hdattach(fd, writable);
| 236 |
/* check rays on disk */
| 237 |
fpos = hdfilen(fd);
| 238 |
biglob(hp)->nrd = rtrunc = 0;
| 239 |
for (n = hproto == NULL ? nbeams(hp) : 0; n > 0; n--)
| 240 |
if (hp->bi[n].nrd) {
| 241 |
if (hp->bi[n].fo+hp->bi[n].nrd*sizeof(RAYVAL) > fpos) {
| 242 |
rtrunc += hp->bi[n].nrd;
| 243 |
hp->bi[n].nrd = 0;
| 244 |
} else
| 245 |
biglob(hp)->nrd += hp->bi[n].nrd;
| 246 |
| 247 |
if (rtrunc) {
| 248 |
sprintf(errmsg, "truncated section, %ld rays lost (%.1f%%)",
| 249 |
rtrunc, 100.*rtrunc/(rtrunc+biglob(hp)->nrd));
| 250 |
error(WARNING, errmsg);
| 251 |
| 252 |
/* add to holodeck list */
| 253 |
for (n = 0; n < HDMAX; n++)
| 254 |
if (hdlist[n] == NULL) {
| 255 |
hdlist[n] = hp;
| 256 |
break;
| 257 |
| 258 |
/* all done */
| 259 |
return(hp);
| 260 |
memerr:
| 261 |
error(SYSTEM, "cannot allocate holodeck grid");
| 262 |
return NULL; /* pro forma return */
| 263 |
| 264 |
| 265 |
| 266 |
void
| 267 |
hdmarkdirty( /* mark holodeck directory position dirty */
| 268 |
register HOLO *hp,
| 269 |
int i
| 270 |
| 271 |
| 272 |
static BEAMI smudge = {0, -1};
| 273 |
int mindist, minpos;
| 274 |
register int j;
| 275 |
| 276 |
if (!hp->dirty++) { /* write smudge first time */
| 277 |
if (lseek(hp->fd, biglob(hp)->fo+(i-1)*sizeof(BEAMI),
| 278 |
SEEK_SET) < 0 ||
| 279 |
write(hp->fd, (char *)&smudge,
| 280 |
sizeof(BEAMI)) != sizeof(BEAMI))
| 281 |
error(SYSTEM, "seek/write error in hdmarkdirty");
| 282 |
hp->dirseg[0].s = i;
| 283 |
hp->dirseg[0].n = 1;
| 284 |
return;
| 285 |
| 286 |
/* insert into segment list */
| 287 |
for (j = hp->dirty; j--; ) {
| 288 |
if (!j || hp->dirseg[j-1].s < i) {
| 289 |
hp->dirseg[j].s = i;
| 290 |
hp->dirseg[j].n = 1;
| 291 |
break;
| 292 |
| 293 |
*(hp->dirseg+j) = *(hp->dirseg+(j-1));
| 294 |
| 295 |
do { /* check neighbors */
| 296 |
mindist = nbeams(hp); /* find closest */
| 297 |
for (j = hp->dirty; --j; )
| 298 |
if (hp->dirseg[j].s -
| 299 |
(hp->dirseg[j-1].s + hp->dirseg[j-1].n)
| 300 |
< mindist) {
| 301 |
minpos = j;
| 302 |
mindist = hp->dirseg[j].s -
| 303 |
(hp->dirseg[j-1].s + hp->dirseg[j-1].n);
| 304 |
| 305 |
/* good enough? */
| 306 |
if (hp->dirty <= MAXDIRSE && mindist > MINDIRSEL)
| 307 |
break;
| 308 |
j = minpos - 1; /* coalesce neighbors */
| 309 |
if (hp->dirseg[j].s + hp->dirseg[j].n <
| 310 |
hp->dirseg[minpos].s + hp->dirseg[minpos].n)
| 311 |
hp->dirseg[j].n = hp->dirseg[minpos].s +
| 312 |
hp->dirseg[minpos].n - hp->dirseg[j].s;
| 313 |
hp->dirty--;
| 314 |
while (++j < hp->dirty) /* close the gap */
| 315 |
*(hp->dirseg+j) = *(hp->dirseg+(j+1));
| 316 |
} while (mindist <= MINDIRSEL);
| 317 |
| 318 |
| 319 |
| 320 |
extern int
| 321 |
hdsync( /* update beams and directory on disk */
| 322 |
register HOLO *hp,
| 323 |
int all
| 324 |
| 325 |
| 326 |
register int j, n;
| 327 |
| 328 |
if (hp == NULL) { /* do all holodecks */
| 329 |
n = 0;
| 330 |
for (j = 0; hdlist[j] != NULL; j++)
| 331 |
n += hdsync(hdlist[j], all);
| 332 |
return(n);
| 333 |
| 334 |
/* sync the beams */
| 335 |
for (j = (all ? nbeams(hp) : 0); j > 0; j--)
| 336 |
if (hp->bl[j] != NULL)
| 337 |
hdsyncbeam(hp, j);
| 338 |
if (!hp->dirty) /* directory clean? */
| 339 |
return(0);
| 340 |
errno = 0; /* write dirty segments */
| 341 |
for (j = 0; j < hp->dirty; j++) {
| 342 |
if (lseek(hp->fd, biglob(hp)->fo +
| 343 |
(hp->dirseg[j].s-1)*sizeof(BEAMI), SEEK_SET) < 0)
| 344 |
error(SYSTEM, "cannot seek on holodeck file");
| 345 |
n = hp->dirseg[j].n * sizeof(BEAMI);
| 346 |
if (write(hp->fd, (char *)(hp->bi+hp->dirseg[j].s), n) != n)
| 347 |
error(SYSTEM, "cannot update section directory");
| 348 |
| 349 |
hp->dirty = 0; /* all clean */
| 350 |
return(1);
| 351 |
| 352 |
| 353 |
| 354 |
unsigned int
| 355 |
hdmemuse( /* return memory usage (in bytes) */
| 356 |
int all /* include overhead (painful) */
| 357 |
| 358 |
| 359 |
long total = 0;
| 360 |
register int i, j;
| 361 |
| 362 |
for (j = 0; hdlist[j] != NULL; j++) {
| 363 |
total += blglob(hdlist[j])->nrm * sizeof(RAYVAL);
| 364 |
if (all) {
| 365 |
total += sizeof(HOLO) + sizeof(BEAM *) +
| 366 |
nbeams(hdlist[j]) *
| 367 |
(sizeof(BEAM *)+sizeof(BEAMI));
| 368 |
for (i = nbeams(hdlist[j]); i > 0; i--)
| 369 |
if (hdlist[j]->bl[i] != NULL)
| 370 |
total += sizeof(BEAM);
| 371 |
| 372 |
| 373 |
if (all)
| 374 |
for (j = 0; j < nhdfragls; j++) {
| 375 |
total += sizeof(struct fraglist);
| 376 |
if (hdfragl[j].nfrags)
| 377 |
total += FRAGBLK*sizeof(BEAMI) *
| 378 |
((hdfragl[j].nfrags-1)/FRAGBLK + 1) ;
| 379 |
| 380 |
return(total);
| 381 |
| 382 |
| 383 |
| 384 |
extern off_t
| 385 |
hdfilen( /* return file length for fd */
| 386 |
int fd
| 387 |
| 388 |
| 389 |
off_t fpos, flen;
| 390 |
| 391 |
if (fd < 0)
| 392 |
return(-1);
| 393 |
if (fd >= nhdfragls || !hdfragl[fd].nlinks) {
| 394 |
| 395 |
return(-1);
| 396 |
| 397 |
lseek(fd, fpos, SEEK_SET);
| 398 |
return(flen);
| 399 |
| 400 |
return(hdfragl[fd].flen);
| 401 |
| 402 |
| 403 |
| 404 |
extern off_t
| 405 |
hdfiluse( /* compute file usage (in bytes) */
| 406 |
int fd /* open file descriptor to check */
| 407 |
| 408 |
| 409 |
off_t total = 0;
| 410 |
register int j;
| 411 |
| 412 |
| 413 |
if (hdlist[j]->fd != fd)
| 414 |
continue;
| 415 |
total += biglob(hdlist[j])->nrd * sizeof(RAYVAL);
| 416 |
total += nbeams(hdlist[j])*sizeof(BEAMI) + sizeof(HDGRID);
| 417 |
#if 0
| 418 |
| 419 |
| 420 |
total += sizeof(RAYVAL) *
| 421 |
(hdlist[j]->bl[i]->nrm -
| 422 |
hdlist[j]->bi[i].nrd);
| 423 |
#endif
| 424 |
| 425 |
return(total); /* doesn't include fragments, unflushed rays */
| 426 |
| 427 |
| 428 |
| 429 |
extern RAYVAL *
| 430 |
hdnewrays( /* allocate space for add'l rays and return pointer */
| 431 |
register HOLO *hp,
| 432 |
register int i,
| 433 |
int nr /* number of new rays desired */
| 434 |
| 435 |
| 436 |
RAYVAL *p;
| 437 |
int n;
| 438 |
| 439 |
if (nr <= 0) return(NULL);
| 440 |
CHECK((i < 1) | (i > nbeams(hp)),
| 441 |
CONSISTENCY, "bad beam index given to hdnewrays");
| 442 |
if (hp->bl[i] != NULL)
| 443 |
hp->bl[i]->tick = hdclock; /* preempt swap */
| 444 |
if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
| 445 |
hdfreecache(PCTFREE, NULL); /* free some space */
| 446 |
if (hp->bl[i] == NULL) { /* allocate (and load) */
| 447 |
n = hp->bi[i].nrd + nr;
| 448 |
hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdnewrays");
| 449 |
blglob(hp)->nrm += n;
| 450 |
if ((n = hp->bl[i]->nrm = hp->bi[i].nrd)) {
| 451 |
errno = 0;
| 452 |
if (lseek(hp->fd, hp->bi[i].fo, SEEK_SET) < 0)
| 453 |
error(SYSTEM, "seek error on holodeck file");
| 454 |
n *= sizeof(RAYVAL);
| 455 |
if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
| 456 |
error(SYSTEM,
| 457 |
"error reading beam from holodeck file");
| 458 |
| 459 |
} else { /* just grow in memory */
| 460 |
hp->bl[i] = (BEAM *)hdrealloc((char *)hp->bl[i],
| 461 |
hdbsiz(hp->bl[i]->nrm + nr), "hdnewrays");
| 462 |
blglob(hp)->nrm += nr;
| 463 |
| 464 |
if (hdfragflags&FF_ALLOC && hp->bi[i].nrd)
| 465 |
hdfreefrag(hp, i); /* relinquish old fragment */
| 466 |
p = hdbray(hp->bl[i]) + hp->bl[i]->nrm;
| 467 |
hp->bl[i]->nrm += nr; /* update in-core structure */
| 468 |
memset((void *)p, '\0', nr*sizeof(RAYVAL));
| 469 |
blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
| 470 |
return(p); /* point to new rays */
| 471 |
| 472 |
| 473 |
| 474 |
extern BEAM *
| 475 |
hdgetbeam( /* get beam (from file if necessary) */
| 476 |
register HOLO *hp,
| 477 |
register int i
| 478 |
| 479 |
| 480 |
register int n;
| 481 |
| 482 |
| 483 |
CONSISTENCY, "bad beam index given to hdgetbeam");
| 484 |
if (hp->bl[i] == NULL) { /* load from disk */
| 485 |
if (!(n = hp->bi[i].nrd))
| 486 |
return(NULL);
| 487 |
| 488 |
hdfreecache(PCTFREE, NULL); /* get free space */
| 489 |
hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdgetbeam");
| 490 |
blglob(hp)->nrm += hp->bl[i]->nrm = n;
| 491 |
errno = 0;
| 492 |
| 493 |
| 494 |
| 495 |
| 496 |
error(SYSTEM, "error reading beam from holodeck file");
| 497 |
if (hdfragflags&FF_READ)
| 498 |
hdfreefrag(hp, i); /* relinquish old frag. */
| 499 |
| 500 |
| 501 |
return(hp->bl[i]);
| 502 |
| 503 |
| 504 |
| 505 |
int
| 506 |
hdfilord( /* order beams for quick loading */
| 507 |
register const void *hb1,
| 508 |
register const void *hb2
| 509 |
| 510 |
| 511 |
register off_t c;
| 512 |
/* residents go first */
| 513 |
if (((HDBEAMI*)hb2)->h->bl[((HDBEAMI*)hb2)->b] != NULL)
| 514 |
return(((HDBEAMI*)hb1)->h->bl[((HDBEAMI*)hb1)->b] == NULL);
| 515 |
if (((HDBEAMI*)hb1)->h->bl[((HDBEAMI*)hb1)->b] != NULL)
| 516 |
return(-1);
| 517 |
/* otherwise sort by file descriptor */
| 518 |
if (((HDBEAMI*)hb1)->h->fd != ((HDBEAMI*)hb2)->h->fd)
| 519 |
return(((HDBEAMI*)hb1)->h->fd - ((HDBEAMI*)hb2)->h->fd);
| 520 |
/* then by position in file */
| 521 |
c = ((HDBEAMI*)hb1)->h->bi[((HDBEAMI*)hb1)->b].fo
| 522 |
- ((HDBEAMI*)hb2)->h->bi[((HDBEAMI*)hb2)->b].fo;
| 523 |
return(c > 0 ? 1 : c < 0 ? -1 : 0);
| 524 |
| 525 |
| 526 |
| 527 |
extern void
| 528 |
hdloadbeams( /* load a list of beams in optimal order */
| 529 |
register HDBEAMI *hb, /* list gets sorted by hdfilord() */
| 530 |
int n, /* list length */
| 531 |
void (*bf)(BEAM *bp, HDBEAMI *hb) /* callback function (optional) */
| 532 |
| 533 |
| 534 |
unsigned origcachesize, memuse;
| 535 |
int bytesloaded, needbytes, bytes2free;
| 536 |
register BEAM *bp;
| 537 |
register int i;
| 538 |
/* precheck consistency */
| 539 |
if (n <= 0) return;
| 540 |
for (i = n; i--; )
| 541 |
if (hb[i].h==NULL || (hb[i].b<1) | (hb[i].b>nbeams(hb[i].h)))
| 542 |
error(CONSISTENCY, "bad beam in hdloadbeams");
| 543 |
/* sort list for optimal access */
| 544 |
qsort((void *)hb, n, sizeof(HDBEAMI), hdfilord);
| 545 |
bytesloaded = 0; /* run through loaded beams */
| 546 |
for ( ; n && (bp = hb->h->bl[hb->b]) != NULL; n--, hb++) {
| 547 |
bp->tick = hdclock; /* preempt swap */
| 548 |
bytesloaded += bp->nrm;
| 549 |
if (bf != NULL)
| 550 |
(*bf)(bp, hb);
| 551 |
| 552 |
bytesloaded *= sizeof(RAYVAL);
| 553 |
if ((origcachesize = hdcachesize) > 0) {
| 554 |
needbytes = 0; /* figure out memory needs */
| 555 |
for (i = n; i--; )
| 556 |
needbytes += hb[i].h->bi[hb[i].b].nrd;
| 557 |
needbytes *= sizeof(RAYVAL);
| 558 |
do { /* free enough memory */
| 559 |
memuse = hdmemuse(0);
| 560 |
bytes2free = needbytes - (int)(hdcachesize-memuse);
| 561 |
if (bytes2free > (int)(memuse - bytesloaded))
| 562 |
bytes2free = memuse - bytesloaded;
| 563 |
} while (bytes2free > 0 &&
| 564 |
hdfreecache(100*bytes2free/memuse, NULL) < 0);
| 565 |
hdcachesize = 0; /* load beams w/o swap */
| 566 |
| 567 |
for (i = 0; i < n; i++)
| 568 |
if ((bp = hdgetbeam(hb[i].h, hb[i].b)) != NULL && bf != NULL)
| 569 |
(*bf)(bp, hb+i);
| 570 |
hdcachesize = origcachesize; /* resume dynamic swapping */
| 571 |
| 572 |
| 573 |
| 574 |
extern int
| 575 |
hdfreefrag( /* free a file fragment */
| 576 |
HOLO *hp,
| 577 |
int i
| 578 |
| 579 |
| 580 |
register BEAMI *bi = &hp->bi[i];
| 581 |
register struct fraglist *f;
| 582 |
register int j, k;
| 583 |
| 584 |
if (bi->nrd <= 0)
| 585 |
return(0);
| 586 |
DCHECK(hp->fd < 0 | hp->fd >= nhdfragls || !hdfragl[hp->fd].nlinks,
| 587 |
CONSISTENCY, "bad file descriptor in hdfreefrag");
| 588 |
f = &hdfragl[hp->fd];
| 589 |
if (!f->writable)
| 590 |
return(0);
| 591 |
if (f->nfrags % FRAGBLK == 0) { /* delete empty remnants */
| 592 |
for (j = k = 0; k < f->nfrags; j++, k++) {
| 593 |
while (f->fi[k].nrd == 0)
| 594 |
if (++k >= f->nfrags)
| 595 |
goto endloop;
| 596 |
if (k > j)
| 597 |
*(f->fi+j) = *(f->fi+k);
| 598 |
| 599 |
endloop:
| 600 |
f->nfrags = j;
| 601 |
| 602 |
j = f->nfrags++; /* allocate a slot in free list */
| 603 |
#if MAXFRAGB
| 604 |
if (j >= MAXFRAGB*FRAGBLK) {
| 605 |
f->nfrags = j--; /* stop list growth */
| 606 |
if (bi->nrd <= f->fi[j].nrd)
| 607 |
return(0); /* new one no better than discard */
| 608 |
| 609 |
#endif
| 610 |
if (j % FRAGBLK == 0) { /* more (or less) free list space */
| 611 |
register BEAMI *newp;
| 612 |
if (f->fi == NULL)
| 613 |
newp = (BEAMI *)malloc((j+FRAGBLK)*sizeof(BEAMI));
| 614 |
else
| 615 |
newp = (BEAMI *)realloc((void *)f->fi,
| 616 |
| 617 |
if (newp == NULL) {
| 618 |
f->nfrags--; /* graceful failure */
| 619 |
return(0);
| 620 |
| 621 |
f->fi = newp;
| 622 |
| 623 |
for ( ; ; j--) { /* insert in descending list */
| 624 |
if (!j || bi->fo < f->fi[j-1].fo) {
| 625 |
f->fi[j].fo = bi->fo;
| 626 |
f->fi[j].nrd = bi->nrd;
| 627 |
break;
| 628 |
| 629 |
*(f->fi+j) = *(f->fi+(j-1));
| 630 |
| 631 |
/* coalesce adjacent fragments */
| 632 |
/* successors never empty */
| 633 |
if (j && f->fi[j-1].fo == f->fi[j].fo + f->fi[j].nrd*sizeof(RAYVAL)) {
| 634 |
f->fi[j].nrd += f->fi[j-1].nrd;
| 635 |
f->fi[j-1].nrd = 0;
| 636 |
| 637 |
for (k = j+1; k < f->nfrags; k++) /* get non-empty predecessor */
| 638 |
if (f->fi[k].nrd) {
| 639 |
if (f->fi[j].fo == f->fi[k].fo +
| 640 |
f->fi[k].nrd*sizeof(RAYVAL)) {
| 641 |
f->fi[k].nrd += f->fi[j].nrd;
| 642 |
f->fi[j].nrd = 0;
| 643 |
| 644 |
break;
| 645 |
| 646 |
biglob(hp)->nrd -= bi->nrd; /* tell fragment it's free */
| 647 |
bi->nrd = 0;
| 648 |
bi->fo = 0;
| 649 |
hdmarkdirty(hp, i); /* assume we'll reallocate */
| 650 |
return(1);
| 651 |
| 652 |
| 653 |
| 654 |
extern int
| 655 |
hdfragOK( /* get fragment list status for file */
| 656 |
int fd,
| 657 |
int *listlen,
| 658 |
register int32 *listsiz
| 659 |
| 660 |
| 661 |
| 662 |
register int i;
| 663 |
| 664 |
if ((fd < 0) | (fd >= nhdfragls) || !(f = &hdfragl[fd])->nlinks)
| 665 |
return(0); /* listless */
| 666 |
if (listlen != NULL)
| 667 |
*listlen = f->nfrags;
| 668 |
if (listsiz != NULL)
| 669 |
for (i = f->nfrags, *listsiz = 0; i--; )
| 670 |
*listsiz += f->fi[i].nrd;
| 671 |
#if MAXFRAGB
| 672 |
return(f->nfrags < MAXFRAGB*FRAGBLK);
| 673 |
#else
| 674 |
return(1); /* list never fills up */
| 675 |
#endif
| 676 |
| 677 |
| 678 |
| 679 |
off_t
| 680 |
hdallocfrag( /* allocate a file fragment */
| 681 |
int fd,
| 682 |
uint32 nrays
| 683 |
| 684 |
| 685 |
| 686 |
register int j;
| 687 |
off_t nfo;
| 688 |
| 689 |
if (nrays == 0)
| 690 |
return(-1L);
| 691 |
DCHECK(fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks,
| 692 |
CONSISTENCY, "bad file descriptor in hdallocfrag");
| 693 |
f = &hdfragl[fd];
| 694 |
for (j = f->nfrags; j-- > 0; ) /* first fit algorithm */
| 695 |
if (f->fi[j].nrd >= nrays)
| 696 |
break;
| 697 |
if (j < 0) { /* no fragment -- extend file */
| 698 |
nfo = f->flen;
| 699 |
f->flen += nrays*sizeof(RAYVAL);
| 700 |
} else { /* else use fragment */
| 701 |
nfo = f->fi[j].fo;
| 702 |
f->fi[j].fo += nrays*sizeof(RAYVAL);
| 703 |
f->fi[j].nrd -= nrays;
| 704 |
| 705 |
return(nfo);
| 706 |
| 707 |
| 708 |
| 709 |
int
| 710 |
hdsyncbeam( /* sync beam in memory with beam on disk */
| 711 |
register HOLO *hp,
| 712 |
register int i
| 713 |
| 714 |
| 715 |
int fragfreed;
| 716 |
uint32 nrays;
| 717 |
unsigned int n;
| 718 |
off_t nfo;
| 719 |
/* check file status */
| 720 |
if (hdfragl[hp->fd].writable <= 0)
| 721 |
return(hdfragl[hp->fd].writable);
| 722 |
DCHECK(i < 1 | i > nbeams(hp),
| 723 |
CONSISTENCY, "bad beam index in hdsyncbeam");
| 724 |
/* is current fragment OK? */
| 725 |
if (hp->bl[i] == NULL || (nrays = hp->bl[i]->nrm) == hp->bi[i].nrd)
| 726 |
return(0);
| 727 |
/* relinquish old fragment? */
| 728 |
fragfreed = hdfragflags&FF_WRITE && hp->bi[i].nrd && hdfreefrag(hp,i);
| 729 |
if (nrays) { /* get and write new fragment */
| 730 |
nfo = hdallocfrag(hp->fd, nrays);
| 731 |
errno = 0;
| 732 |
if (lseek(hp->fd, nfo, SEEK_SET) < 0)
| 733 |
| 734 |
n = hp->bl[i]->nrm * sizeof(RAYVAL);
| 735 |
if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) {
| 736 |
hdfragl[hp->fd].writable = -1;
| 737 |
hdsync(NULL, 0); /* sync directories */
| 738 |
error(SYSTEM, "write error in hdsyncbeam");
| 739 |
| 740 |
hp->bi[i].fo = nfo;
| 741 |
} else
| 742 |
hp->bi[i].fo = 0;
| 743 |
biglob(hp)->nrd += nrays - hp->bi[i].nrd;
| 744 |
hp->bi[i].nrd = nrays;
| 745 |
if (!fragfreed)
| 746 |
hdmarkdirty(hp, i); /* need to flag dir. ent. */
| 747 |
return(1);
| 748 |
| 749 |
| 750 |
| 751 |
extern int
| 752 |
hdfreebeam( /* free beam, writing if dirty */
| 753 |
register HOLO *hp,
| 754 |
register int i
| 755 |
| 756 |
| 757 |
int nchanged;
| 758 |
| 759 |
if (hp == NULL) { /* clear all holodecks */
| 760 |
nchanged = 0;
| 761 |
for (i = 0; hdlist[i] != NULL; i++)
| 762 |
nchanged += hdfreebeam(hdlist[i], 0);
| 763 |
return(nchanged);
| 764 |
| 765 |
if (hdfragl[hp->fd].writable < 0) /* check for file error */
| 766 |
return(0);
| 767 |
if (i == 0) { /* clear entire holodeck */
| 768 |
if (blglob(hp)->nrm == 0)
| 769 |
return(0); /* already clear */
| 770 |
nchanged = 0;
| 771 |
for (i = nbeams(hp); i > 0; i--)
| 772 |
| 773 |
nchanged += hdfreebeam(hp, i);
| 774 |
DCHECK(blglob(hp)->nrm != 0,
| 775 |
CONSISTENCY, "bad beam count in hdfreebeam");
| 776 |
return(nchanged);
| 777 |
| 778 |
| 779 |
CONSISTENCY, "bad beam index to hdfreebeam");
| 780 |
| 781 |
return(0);
| 782 |
/* check for additions */
| 783 |
nchanged = hp->bl[i]->nrm - hp->bi[i].nrd;
| 784 |
if (nchanged)
| 785 |
hdsyncbeam(hp, i); /* write new fragment */
| 786 |
blglob(hp)->nrm -= hp->bl[i]->nrm;
| 787 |
free((void *)hp->bl[i]); /* free memory */
| 788 |
hp->bl[i] = NULL;
| 789 |
return(nchanged);
| 790 |
| 791 |
| 792 |
| 793 |
extern int
| 794 |
hdkillbeam( /* delete beam from holodeck */
| 795 |
register HOLO *hp,
| 796 |
register int i
| 797 |
| 798 |
| 799 |
int nchanged;
| 800 |
| 801 |
if (hp == NULL) { /* clobber all holodecks */
| 802 |
nchanged = 0;
| 803 |
| 804 |
nchanged += hdkillbeam(hdlist[i], 0);
| 805 |
return(nchanged);
| 806 |
| 807 |
if (i == 0) { /* clobber entire holodeck */
| 808 |
if ((biglob(hp)->nrd == 0) & (blglob(hp)->nrm == 0))
| 809 |
return(0); /* already empty */
| 810 |
nchanged = 0;
| 811 |
nchanged = 0;
| 812 |
| 813 |
if (hp->bi[i].nrd > 0 || hp->bl[i] != NULL)
| 814 |
nchanged += hdkillbeam(hp, i);
| 815 |
DCHECK(biglob(hp)->nrd != 0 | blglob(hp)->nrm != 0,
| 816 |
CONSISTENCY, "bad beam count in hdkillbeam");
| 817 |
return(nchanged);
| 818 |
| 819 |
DCHECK(i < 1 | i > nbeams(hp), CONSISTENCY,
| 820 |
"bad beam index to hdkillbeam");
| 821 |
DCHECK(!hdfragl[hp->fd].writable, CONSISTENCY,
| 822 |
"hdkillbeam called on read-only holodeck");
| 823 |
if (hp->bl[i] != NULL) { /* free memory */
| 824 |
blglob(hp)->nrm -= nchanged = hp->bl[i]->nrm;
| 825 |
| 826 |
hp->bl[i] = NULL;
| 827 |
} else
| 828 |
nchanged = hp->bi[i].nrd;
| 829 |
if (hp->bi[i].nrd && !(hdfragflags&FF_KILL && hdfreefrag(hp,i))) {
| 830 |
biglob(hp)->nrd -= hp->bi[i].nrd; /* free failed */
| 831 |
hp->bi[i].nrd = 0;
| 832 |
hp->bi[i].fo = 0;
| 833 |
hdmarkdirty(hp, i);
| 834 |
| 835 |
return(nchanged);
| 836 |
| 837 |
| 838 |
| 839 |
int
| 840 |
hdlrulist( /* add beams from holodeck to LRU list */
| 841 |
register HDBEAMI *hb, /* beam list */
| 842 |
int nents, /* current list length */
| 843 |
int n, /* maximum list length */
| 844 |
register HOLO *hp /* section we're adding from */
| 845 |
| 846 |
| 847 |
register int i, j;
| 848 |
/* insert each beam from hp */
| 849 |
for (i = 1; i <= nbeams(hp); i++) {
| 850 |
if (hp->bl[i] == NULL) /* check if loaded */
| 851 |
continue;
| 852 |
#if 0
| 853 |
if (hp->bl[i]->tick == hdclock) /* preempt swap? */
| 854 |
continue;
| 855 |
#endif
| 856 |
if ((j = ++nents) >= n) /* grow list if we can */
| 857 |
nents--;
| 858 |
for ( ; ; ) { /* bubble into place */
| 859 |
if (!--j || hp->bl[i]->tick >=
| 860 |
hb[j-1].h->bl[hb[j-1].b]->tick) {
| 861 |
hb[j].h = hp;
| 862 |
hb[j].b = i;
| 863 |
break;
| 864 |
| 865 |
*(hb+j) = *(hb+(j-1));
| 866 |
| 867 |
| 868 |
return(nents); /* return new list length */
| 869 |
| 870 |
| 871 |
| 872 |
int
| 873 |
hdfreecache( /* free up cache space, writing changes */
| 874 |
int pct, /* maximum percentage to free */
| 875 |
register HOLO *honly /* NULL means check all */
| 876 |
| 877 |
| 878 |
HDBEAMI hb[FREEBEAMS];
| 879 |
int freetarget;
| 880 |
int n;
| 881 |
register int i;
| 882 |
#ifdef DEBUG
| 883 |
unsigned membefore;
| 884 |
| 885 |
membefore = hdmemuse(0);
| 886 |
#endif
| 887 |
/* compute free target */
| 888 |
freetarget = (honly != NULL) ? blglob(honly)->nrm :
| 889 |
hdmemuse(0)/sizeof(RAYVAL) ;
| 890 |
freetarget = freetarget*pct/100;
| 891 |
if (freetarget <= 0)
| 892 |
return(0);
| 893 |
/* find least recently used */
| 894 |
n = 0;
| 895 |
if (honly != NULL)
| 896 |
n = hdlrulist(hb, n, FREEBEAMS, honly);
| 897 |
else
| 898 |
| 899 |
n = hdlrulist(hb, n, FREEBEAMS, hdlist[i]);
| 900 |
/* free LRU beams */
| 901 |
for (i = 0; i < n; i++) {
| 902 |
hdfreebeam(hb[i].h, hb[i].b);
| 903 |
if ((freetarget -= hb[i].h->bi[hb[i].b].nrd) <= 0)
| 904 |
break;
| 905 |
| 906 |
hdsync(honly, 0); /* synchronize directories as necessary */
| 907 |
#ifdef DEBUG
| 908 |
sprintf(errmsg,
| 909 |
"%dK before, %dK after hdfreecache (%dK total), %d rays short\n",
| 910 |
membefore>>10, hdmemuse(0)>>10, hdmemuse(1)>>10, freetarget);
| 911 |
wputs(errmsg);
| 912 |
#endif
| 913 |
return(-freetarget); /* return how far past goal we went */
| 914 |
| 915 |
| 916 |
| 917 |
extern void
| 918 |
hddone( /* clean up holodeck section and free */
| 919 |
register HOLO *hp /* NULL means clean up all */
| 920 |
| 921 |
| 922 |
register int i;
| 923 |
| 924 |
if (hp == NULL) { /* NULL means clean up everything */
| 925 |
while (hdlist[0] != NULL)
| 926 |
hddone(hdlist[0]);
| 927 |
free((void *)hdfragl);
| 928 |
hdfragl = NULL; nhdfragls = 0;
| 929 |
return;
| 930 |
| 931 |
/* flush all data and free memory */
| 932 |
hdflush(hp);
| 933 |
/* release fragment resources */
| 934 |
hdrelease(hp->fd);
| 935 |
/* remove hp from active list */
| 936 |
| 937 |
if (hdlist[i] == hp) {
| 938 |
while ((hdlist[i] = hdlist[i+1]) != NULL)
| 939 |
i++;
| 940 |
break;
| 941 |
| 942 |
free((void *)hp->bl); /* free beam list */
| 943 |
free((void *)hp); /* free holodeck struct */
| 944 |
