root/radiance/ray/src/hd/holofile.c
Revision: 3.53
Committed: Mon Oct 20 16:01:55 2003 UTC (20 years, 5 months ago) by greg
Changes since 3.52: +17 -13 lines
2 static const char RCSid[] = "$Id: holofile.c,v 3.52 2003/07/27 22:12:02 schorsch Exp $";
5 * Routines for managing holodeck files
6 *
7 * 9/30/97 GWLarson
8 */
9
10 #include "copyright.h"
11
12 #include <string.h>
13
14 #include "holo.h"
15
16 #include "platform.h"
17
18 #ifndef CACHESIZE
19 #ifdef SMLMEM
20 #define CACHESIZE 5
21 #else
22 #define CACHESIZE 17 /* default cache size (Mbytes, 0==inf) */
23 #endif
24 #endif
25 #ifndef FREEBEAMS
26 #define FREEBEAMS 1500 /* maximum beams to free at a time */
27 #endif
28 #ifndef PCTFREE
29 #define PCTFREE 15 /* maximum fraction to free (%) */
30 #endif
31 #ifndef MAXFRAGB
32 #define MAXFRAGB 16 /* fragment blocks/file to track (0==inf) */
33 #endif
34 #ifndef FF_DEFAULT
35 /* when to free a beam fragment */
36 #define FF_DEFAULT (FF_WRITE|FF_KILL)
37 #endif
38 #ifndef MINDIRSEL
39 /* minimum directory seek length */
40 #define MINDIRSEL (4*BUFSIZ/sizeof(BEAMI))
41 #endif
42
43 #ifndef BSD
44 #define write writebuf /* safe i/o routines */
45 #define read readbuf
46 #endif
47
48 #define FRAGBLK 512 /* number of fragments to allocate at a time */
49
50 int hdfragflags = FF_DEFAULT; /* tells when to free fragments */
51 unsigned hdcachesize = CACHESIZE*1024*1024; /* target cache size */
52 unsigned long hdclock; /* clock value */
53
54 HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */
55
56 static struct fraglist {
57 short nlinks; /* number of holodeck sections using us */
58 short writable; /* 0 read-only, <0 write error encountered */
59 int nfrags; /* number of known fragments */
60 BEAMI *fi; /* fragments, descending file position */
61 off_t flen; /* last known file length */
62 } *hdfragl; /* fragment lists, indexed by file descriptor */
63
64 static int nhdfragls; /* size of hdfragl array */
65
66
67 HOLO *
68 hdalloc(hproto) /* allocate and set holodeck section based on grid */
69 HDGRID *hproto;
70 {
71 HOLO hdhead;
72 register HOLO *hp;
73 int n;
74 /* copy grid to temporary header */
75 memcpy((void *)&hdhead, (void *)hproto, sizeof(HDGRID));
76 /* compute grid vectors and sizes */
77 hdcompgrid(&hdhead);
78 /* allocate header with directory */
79 n = sizeof(HOLO)+nbeams(&hdhead)*sizeof(BEAMI);
80 if ((hp = (HOLO *)malloc(n)) == NULL)
81 return(NULL);
82 /* copy header information */
83 *hp = hdhead;
84 /* allocate and clear beam list */
85 hp->bl = (BEAM **)malloc((nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM));
86 if (hp->bl == NULL) {
87 free((void *)hp);
88 return(NULL);
89 }
90 memset((void *)hp->bl, '\0', (nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM));
91 hp->bl[0] = (BEAM *)(hp->bl+nbeams(hp)+1); /* set blglob(hp) */
92 hp->fd = -1;
93 hp->dirty = 0;
94 hp->priv = NULL;
95 /* clear beam directory */
96 memset((void *)hp->bi, '\0', (nbeams(hp)+1)*sizeof(BEAMI));
97 return(hp); /* all is well */
98 }
99
100
101 char *
102 hdrealloc(ptr, siz, rout) /* (re)allocate memory, retry then error */
103 char *ptr;
104 unsigned siz;
105 char *rout;
106 {
107 register char *newp;
108 /* call malloc/realloc */
109 if (ptr == NULL) newp = (char *)malloc(siz);
110 else newp = (char *)realloc((void *)ptr, siz);
111 /* check success */
112 if (newp == NULL && rout != NULL) {
113 hdfreecache(25, NULL); /* free some memory */
114 errno = 0; /* retry */
115 newp = hdrealloc(ptr, siz, NULL);
116 if (newp == NULL) { /* give up and report error */
117 sprintf(errmsg, "out of memory in %s", rout);
118 error(SYSTEM, errmsg);
119 }
120 }
121 return(newp);
122 }
123
124
125 hdattach(fd, wr) /* start tracking file fragments for some section */
126 register int fd;
127 int wr;
128 {
129 if (fd >= nhdfragls) {
130 hdfragl = (struct fraglist *)hdrealloc((char *)hdfragl,
131 (fd+1)*sizeof(struct fraglist), "hdattach");
132 memset((void *)(hdfragl+nhdfragls),
133 '\0', (fd+1-nhdfragls)*sizeof(struct fraglist));
134 nhdfragls = fd+1;
135 }
136 hdfragl[fd].nlinks++;
137 hdfragl[fd].writable = wr; /* set writable flag */
138 /* get file length */
139 hdfragl[fd].flen = lseek(fd, (off_t)0, SEEK_END);
140 }
141
142
143 /* Do we need a routine to locate file fragments given known occupants? */
144
145
146 hdrelease(fd) /* stop tracking file fragments for some section */
147 register int fd;
148 {
149 if ((fd < 0) | (fd >= nhdfragls) || !hdfragl[fd].nlinks)
150 return;
151 if (!--hdfragl[fd].nlinks && hdfragl[fd].nfrags) {
152 free((void *)hdfragl[fd].fi);
153 hdfragl[fd].fi = NULL;
154 hdfragl[fd].nfrags = 0;
155 }
156 }
157
158
159 HOLO *
160 hdinit(fd, hproto) /* initialize a holodeck section in a file */
161 int fd; /* corresponding file descriptor */
162 HDGRID *hproto; /* holodeck section grid */
163 {
164 off_t rtrunc;
165 off_t fpos;
166 int writable;
167 register HOLO *hp;
168 register int n;
169 /* prepare for system errors */
170 errno = 0;
171 if ((fpos = lseek(fd, (off_t)0, SEEK_CUR)) < 0)
172 error(SYSTEM, "cannot determine holodeck file position");
173 if (hproto == NULL) { /* assume we're loading it */
174 HDGRID hpr;
175 /* load header */
176 if (read(fd, (char *)&hpr, sizeof(HDGRID)) != sizeof(HDGRID))
177 error(SYSTEM, "cannot load holodeck header");
178 /* allocate grid */
179 if ((hp = hdalloc(&hpr)) == NULL)
180 goto memerr;
181 /* load beam directory */
182 n = nbeams(hp)*sizeof(BEAMI);
183 if (read(fd, (char *)(hp->bi+1), n) != n)
184 error(SYSTEM, "failure loading holodeck directory");
185 /* check that it's clean */
186 for (n = nbeams(hp); n > 0; n--)
187 if (hp->bi[n].fo < 0) {
188 hp->bi[n].fo = 0;
189 error(WARNING, "dirty holodeck section");
190 break;
191 }
192 /* check writability */
193 if (fd < nhdfragls && hdfragl[fd].nlinks)
194 writable = hdfragl[fd].writable;
195 else
196 writable = lseek(fd, fpos, SEEK_SET) == fpos &&
197 write(fd, (char *)hp, sizeof(HDGRID)) ==
198 sizeof(HDGRID);
199 } else { /* else assume we're creating it */
200 if ((hp = hdalloc(hproto)) == NULL)
201 goto memerr;
202 /* write header and skeleton */
203 n = nbeams(hp)*sizeof(BEAMI);
204 if (write(fd, (char *)hproto, sizeof(HDGRID)) !=
205 sizeof(HDGRID) ||
206 write(fd, (char *)(hp->bi+1), n) != n)
207 error(SYSTEM, "cannot write header to holodeck file");
208 writable = 1;
209 }
210 hp->fd = fd;
211 hp->dirty = 0;
212 biglob(hp)->fo = fpos + sizeof(HDGRID);
213 /* start tracking fragments */
214 hdattach(fd, writable);
215 /* check rays on disk */
216 fpos = hdfilen(fd);
217 biglob(hp)->nrd = rtrunc = 0;
218 for (n = hproto == NULL ? nbeams(hp) : 0; n > 0; n--)
219 if (hp->bi[n].nrd) {
220 if (hp->bi[n].fo+hp->bi[n].nrd*sizeof(RAYVAL) > fpos) {
221 rtrunc += hp->bi[n].nrd;
222 hp->bi[n].nrd = 0;
223 } else
224 biglob(hp)->nrd += hp->bi[n].nrd;
225 }
226 if (rtrunc) {
227 sprintf(errmsg, "truncated section, %ld rays lost (%.1f%%)",
228 rtrunc, 100.*rtrunc/(rtrunc+biglob(hp)->nrd));
229 error(WARNING, errmsg);
230 }
231 /* add to holodeck list */
232 for (n = 0; n < HDMAX; n++)
233 if (hdlist[n] == NULL) {
234 hdlist[n] = hp;
235 break;
236 }
237 /* all done */
238 return(hp);
239 memerr:
240 error(SYSTEM, "cannot allocate holodeck grid");
241 }
242
243
244 hdmarkdirty(hp, i) /* mark holodeck directory position dirty */
245 register HOLO *hp;
246 int i;
247 {
248 static BEAMI smudge = {0, -1};
249 int mindist, minpos;
250 register int j;
251
252 if (!hp->dirty++) { /* write smudge first time */
253 if (lseek(hp->fd, biglob(hp)->fo+(i-1)*sizeof(BEAMI),
254 SEEK_SET) < 0 ||
255 write(hp->fd, (char *)&smudge,
256 sizeof(BEAMI)) != sizeof(BEAMI))
257 error(SYSTEM, "seek/write error in hdmarkdirty");
258 hp->dirseg[0].s = i;
259 hp->dirseg[0].n = 1;
260 return;
261 }
262 /* insert into segment list */
263 for (j = hp->dirty; j--; ) {
264 if (!j || hp->dirseg[j-1].s < i) {
265 hp->dirseg[j].s = i;
266 hp->dirseg[j].n = 1;
267 break;
268 }
269 *(hp->dirseg+j) = *(hp->dirseg+(j-1));
270 }
271 do { /* check neighbors */
272 mindist = nbeams(hp); /* find closest */
273 for (j = hp->dirty; --j; )
274 if (hp->dirseg[j].s -
275 (hp->dirseg[j-1].s + hp->dirseg[j-1].n)
276 < mindist) {
277 minpos = j;
278 mindist = hp->dirseg[j].s -
279 (hp->dirseg[j-1].s + hp->dirseg[j-1].n);
280 }
281 /* good enough? */
282 if (hp->dirty <= MAXDIRSE && mindist > MINDIRSEL)
283 break;
284 j = minpos - 1; /* coalesce neighbors */
285 if (hp->dirseg[j].s + hp->dirseg[j].n <
286 hp->dirseg[minpos].s + hp->dirseg[minpos].n)
287 hp->dirseg[j].n = hp->dirseg[minpos].s +
288 hp->dirseg[minpos].n - hp->dirseg[j].s;
289 hp->dirty--;
290 while (++j < hp->dirty) /* close the gap */
291 *(hp->dirseg+j) = *(hp->dirseg+(j+1));
292 } while (mindist <= MINDIRSEL);
293 }
294
295
296 int
297 hdsync(hp, all) /* update beams and directory on disk */
298 register HOLO *hp;
299 int all;
300 {
301 register int j, n;
302
303 if (hp == NULL) { /* do all holodecks */
304 n = 0;
305 for (j = 0; hdlist[j] != NULL; j++)
306 n += hdsync(hdlist[j], all);
307 return(n);
308 }
309 /* sync the beams */
310 for (j = (all ? nbeams(hp) : 0); j > 0; j--)
311 if (hp->bl[j] != NULL)
312 hdsyncbeam(hp, j);
313 if (!hp->dirty) /* directory clean? */
314 return(0);
315 errno = 0; /* write dirty segments */
316 for (j = 0; j < hp->dirty; j++) {
317 if (lseek(hp->fd, biglob(hp)->fo +
318 (hp->dirseg[j].s-1)*sizeof(BEAMI), SEEK_SET) < 0)
319 error(SYSTEM, "cannot seek on holodeck file");
320 n = hp->dirseg[j].n * sizeof(BEAMI);
321 if (write(hp->fd, (char *)(hp->bi+hp->dirseg[j].s), n) != n)
322 error(SYSTEM, "cannot update section directory");
323 }
324 hp->dirty = 0; /* all clean */
325 return(1);
326 }
327
328
329 unsigned
330 hdmemuse(all) /* return memory usage (in bytes) */
331 int all; /* include overhead (painful) */
332 {
333 long total = 0;
334 register int i, j;
335
336 for (j = 0; hdlist[j] != NULL; j++) {
337 total += blglob(hdlist[j])->nrm * sizeof(RAYVAL);
338 if (all) {
339 total += sizeof(HOLO) + sizeof(BEAM *) +
340 nbeams(hdlist[j]) *
341 (sizeof(BEAM *)+sizeof(BEAMI));
342 for (i = nbeams(hdlist[j]); i > 0; i--)
343 if (hdlist[j]->bl[i] != NULL)
344 total += sizeof(BEAM);
345 }
346 }
347 if (all)
348 for (j = 0; j < nhdfragls; j++) {
349 total += sizeof(struct fraglist);
350 if (hdfragl[j].nfrags)
351 total += FRAGBLK*sizeof(BEAMI) *
352 ((hdfragl[j].nfrags-1)/FRAGBLK + 1) ;
353 }
354 return(total);
355 }
356
357
358 off_t
359 hdfilen(fd) /* return file length for fd */
360 int fd;
361 {
362 off_t fpos, flen;
363
364 if (fd < 0)
365 return(-1);
366 if (fd >= nhdfragls || !hdfragl[fd].nlinks) {
367 if ((fpos = lseek(fd, (off_t)0, SEEK_CUR)) < 0)
368 return(-1);
369 flen = lseek(fd, (off_t)0, SEEK_END);
370 lseek(fd, fpos, SEEK_SET);
371 return(flen);
372 }
373 return(hdfragl[fd].flen);
374 }
375
376
377 off_t
378 hdfiluse(fd, all) /* compute file usage (in bytes) */
379 int fd; /* open file descriptor to check */
380 int all; /* include overhead and unflushed data */
381 {
382 off_t total = 0;
383 register int i, j;
384
385 for (j = 0; hdlist[j] != NULL; j++) {
386 if (hdlist[j]->fd != fd)
387 continue;
388 total += biglob(hdlist[j])->nrd * sizeof(RAYVAL);
389 if (all) {
390 for (i = nbeams(hdlist[j]); i > 0; i--)
391 if (hdlist[j]->bl[i] != NULL)
392 total += sizeof(RAYVAL) *
393 (hdlist[j]->bl[i]->nrm -
394 hdlist[j]->bi[i].nrd);
395 total += sizeof(HDGRID) +
396 nbeams(hdlist[j])*sizeof(BEAMI);
397 }
398 }
399 return(total); /* does not include fragments */
400 }
401
402
403 RAYVAL *
404 hdnewrays(hp, i, nr) /* allocate space for add'l rays and return pointer */
405 register HOLO *hp;
406 register int i;
407 int nr; /* number of new rays desired */
408 {
409 RAYVAL *p;
410 int n;
411
412 if (nr <= 0) return(NULL);
413 CHECK((i < 1) | (i > nbeams(hp)),
414 CONSISTENCY, "bad beam index given to hdnewrays");
415 if (hp->bl[i] != NULL)
416 hp->bl[i]->tick = hdclock; /* preempt swap */
417 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
418 hdfreecache(PCTFREE, NULL); /* free some space */
419 if (hp->bl[i] == NULL) { /* allocate (and load) */
420 n = hp->bi[i].nrd + nr;
421 hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdnewrays");
422 blglob(hp)->nrm += n;
423 if ((n = hp->bl[i]->nrm = hp->bi[i].nrd)) {
424 errno = 0;
425 if (lseek(hp->fd, hp->bi[i].fo, SEEK_SET) < 0)
426 error(SYSTEM, "seek error on holodeck file");
427 n *= sizeof(RAYVAL);
428 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
429 error(SYSTEM,
430 "error reading beam from holodeck file");
431 }
432 } else { /* just grow in memory */
433 hp->bl[i] = (BEAM *)hdrealloc((char *)hp->bl[i],
434 hdbsiz(hp->bl[i]->nrm + nr), "hdnewrays");
435 blglob(hp)->nrm += nr;
436 }
437 if (hdfragflags&FF_ALLOC && hp->bi[i].nrd)
438 hdfreefrag(hp, i); /* relinquish old fragment */
439 p = hdbray(hp->bl[i]) + hp->bl[i]->nrm;
440 hp->bl[i]->nrm += nr; /* update in-core structure */
441 memset((void *)p, '\0', nr*sizeof(RAYVAL));
442 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
443 return(p); /* point to new rays */
444 }
445
446
447 BEAM *
448 hdgetbeam(hp, i) /* get beam (from file if necessary) */
449 register HOLO *hp;
450 register int i;
451 {
452 register int n;
453
454 CHECK((i < 1) | (i > nbeams(hp)),
455 CONSISTENCY, "bad beam index given to hdgetbeam");
456 if (hp->bl[i] == NULL) { /* load from disk */
457 if (!(n = hp->bi[i].nrd))
458 return(NULL);
459 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
460 hdfreecache(PCTFREE, NULL); /* get free space */
461 hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdgetbeam");
462 blglob(hp)->nrm += hp->bl[i]->nrm = n;
463 errno = 0;
464 if (lseek(hp->fd, hp->bi[i].fo, SEEK_SET) < 0)
465 error(SYSTEM, "seek error on holodeck file");
466 n *= sizeof(RAYVAL);
467 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
468 error(SYSTEM, "error reading beam from holodeck file");
469 if (hdfragflags&FF_READ)
470 hdfreefrag(hp, i); /* relinquish old frag. */
471 }
472 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
473 return(hp->bl[i]);
474 }
475
476
477 int
478 hdfilord(hb1, hb2) /* order beams for quick loading */
479 register HDBEAMI *hb1, *hb2;
480 {
481 register off_t c;
482 /* residents go first */
483 if (hb2->h->bl[hb2->b] != NULL)
484 return(hb1->h->bl[hb1->b] == NULL);
485 if (hb1->h->bl[hb1->b] != NULL)
486 return(-1);
487 /* otherwise sort by file descriptor */
488 if (hb1->h->fd != hb2->h->fd)
489 return(hb1->h->fd - hb2->h->fd);
490 /* then by position in file */
491 c = hb1->h->bi[hb1->b].fo - hb2->h->bi[hb2->b].fo;
492 return(c > 0 ? 1 : c < 0 ? -1 : 0);
493 }
494
495
496 hdloadbeams(hb, n, bf) /* load a list of beams in optimal order */
497 register HDBEAMI *hb; /* list gets sorted by hdfilord() */
498 int n; /* list length */
499 void (*bf)(); /* callback function (optional) */
500 {
501 unsigned origcachesize, memuse;
502 int bytesloaded, needbytes, bytes2free;
503 register BEAM *bp;
504 register int i;
505 /* precheck consistency */
506 if (n <= 0) return;
507 for (i = n; i--; )
508 if (hb[i].h==NULL || (hb[i].b<1) | (hb[i].b>nbeams(hb[i].h)))
509 error(CONSISTENCY, "bad beam in hdloadbeams");
510 /* sort list for optimal access */
511 qsort((void *)hb, n, sizeof(HDBEAMI), hdfilord);
512 bytesloaded = 0; /* run through loaded beams */
513 for ( ; n && (bp = hb->h->bl[hb->b]) != NULL; n--, hb++) {
514 bp->tick = hdclock; /* preempt swap */
515 bytesloaded += bp->nrm;
516 if (bf != NULL)
517 (*bf)(bp, hb);
518 }
519 bytesloaded *= sizeof(RAYVAL);
520 if ((origcachesize = hdcachesize) > 0) {
521 needbytes = 0; /* figure out memory needs */
522 for (i = n; i--; )
523 needbytes += hb[i].h->bi[hb[i].b].nrd;
524 needbytes *= sizeof(RAYVAL);
525 do { /* free enough memory */
526 memuse = hdmemuse(0);
527 bytes2free = needbytes - (int)(hdcachesize-memuse);
528 if (bytes2free > (int)(memuse - bytesloaded))
529 bytes2free = memuse - bytesloaded;
530 } while (bytes2free > 0 &&
531 hdfreecache(100*bytes2free/memuse, NULL) < 0);
532 hdcachesize = 0; /* load beams w/o swap */
533 }
534 for (i = 0; i < n; i++)
535 if ((bp = hdgetbeam(hb[i].h, hb[i].b)) != NULL && bf != NULL)
536 (*bf)(bp, hb+i);
537 hdcachesize = origcachesize; /* resume dynamic swapping */
538 }
539
540
541 int
542 hdfreefrag(hp, i) /* free a file fragment */
543 HOLO *hp;
544 int i;
545 {
546 register BEAMI *bi = &hp->bi[i];
547 register struct fraglist *f;
548 register int j, k;
549
550 if (bi->nrd <= 0)
551 return(0);
552 DCHECK(hp->fd < 0 | hp->fd >= nhdfragls || !hdfragl[hp->fd].nlinks,
553 CONSISTENCY, "bad file descriptor in hdfreefrag");
554 f = &hdfragl[hp->fd];
555 if (!f->writable)
556 return(0);
557 if (f->nfrags % FRAGBLK == 0) { /* delete empty remnants */
558 for (j = k = 0; k < f->nfrags; j++, k++) {
559 while (f->fi[k].nrd == 0)
560 if (++k >= f->nfrags)
561 goto endloop;
562 if (k > j)
563 *(f->fi+j) = *(f->fi+k);
564 }
565 endloop:
566 f->nfrags = j;
567 }
568 j = f->nfrags++; /* allocate a slot in free list */
569 #if MAXFRAGB
570 if (j >= MAXFRAGB*FRAGBLK) {
571 f->nfrags = j--; /* stop list growth */
572 if (bi->nrd <= f->fi[j].nrd)
573 return(0); /* new one no better than discard */
574 }
575 #endif
576 if (j % FRAGBLK == 0) { /* more (or less) free list space */
577 register BEAMI *newp;
578 if (f->fi == NULL)
579 newp = (BEAMI *)malloc((j+FRAGBLK)*sizeof(BEAMI));
580 else
581 newp = (BEAMI *)realloc((void *)f->fi,
582 (j+FRAGBLK)*sizeof(BEAMI));
583 if (newp == NULL) {
584 f->nfrags--; /* graceful failure */
585 return(0);
586 }
587 f->fi = newp;
588 }
589 for ( ; ; j--) { /* insert in descending list */
590 if (!j || bi->fo < f->fi[j-1].fo) {
591 f->fi[j].fo = bi->fo;
592 f->fi[j].nrd = bi->nrd;
593 break;
594 }
595 *(f->fi+j) = *(f->fi+(j-1));
596 }
597 /* coalesce adjacent fragments */
598 /* successors never empty */
599 if (j && f->fi[j-1].fo == f->fi[j].fo + f->fi[j].nrd*sizeof(RAYVAL)) {
600 f->fi[j].nrd += f->fi[j-1].nrd;
601 f->fi[j-1].nrd = 0;
602 }
603 for (k = j+1; k < f->nfrags; k++) /* get non-empty predecessor */
604 if (f->fi[k].nrd) {
605 if (f->fi[j].fo == f->fi[k].fo +
606 f->fi[k].nrd*sizeof(RAYVAL)) {
607 f->fi[k].nrd += f->fi[j].nrd;
608 f->fi[j].nrd = 0;
609 }
610 break;
611 }
612 biglob(hp)->nrd -= bi->nrd; /* tell fragment it's free */
613 bi->nrd = 0;
614 bi->fo = 0;
615 hdmarkdirty(hp, i); /* assume we'll reallocate */
616 return(1);
617 }
618
619
620 int
621 hdfragOK(fd, listlen, listsiz) /* get fragment list status for file */
622 int fd;
623 int *listlen;
624 register int32 *listsiz;
625 {
626 register struct fraglist *f;
627 register int i;
628
629 if ((fd < 0) | (fd >= nhdfragls) || !(f = &hdfragl[fd])->nlinks)
630 return(0); /* listless */
631 if (listlen != NULL)
632 *listlen = f->nfrags;
633 if (listsiz != NULL)
634 for (i = f->nfrags, *listsiz = 0; i--; )
635 *listsiz += f->fi[i].nrd;
636 #if MAXFRAGB
637 return(f->nfrags < MAXFRAGB*FRAGBLK);
638 #else
639 return(1); /* list never fills up */
640 #endif
641 }
642
643
644 off_t
645 hdallocfrag(fd, nrays) /* allocate a file fragment */
646 int fd;
647 uint32 nrays;
648 {
649 register struct fraglist *f;
650 register int j;
651 off_t nfo;
652
653 if (nrays == 0)
654 return(-1L);
655 DCHECK(fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks,
656 CONSISTENCY, "bad file descriptor in hdallocfrag");
657 f = &hdfragl[fd];
658 for (j = f->nfrags; j-- > 0; ) /* first fit algorithm */
659 if (f->fi[j].nrd >= nrays)
660 break;
661 if (j < 0) { /* no fragment -- extend file */
662 nfo = f->flen;
663 f->flen += nrays*sizeof(RAYVAL);
664 } else { /* else use fragment */
665 nfo = f->fi[j].fo;
666 f->fi[j].fo += nrays*sizeof(RAYVAL);
667 f->fi[j].nrd -= nrays;
668 }
669 return(nfo);
670 }
671
672
673 int
674 hdsyncbeam(hp, i) /* sync beam in memory with beam on disk */
675 register HOLO *hp;
676 register int i;
677 {
678 int fragfreed;
679 uint32 nrays;
680 unsigned int n;
681 off_t nfo;
682 /* check file status */
683 if (hdfragl[hp->fd].writable <= 0)
684 return(hdfragl[hp->fd].writable);
685 DCHECK(i < 1 | i > nbeams(hp),
686 CONSISTENCY, "bad beam index in hdsyncbeam");
687 /* is current fragment OK? */
688 if (hp->bl[i] == NULL || (nrays = hp->bl[i]->nrm) == hp->bi[i].nrd)
689 return(0);
690 /* relinquish old fragment? */
691 fragfreed = hdfragflags&FF_WRITE && hp->bi[i].nrd && hdfreefrag(hp,i);
692 if (nrays) { /* get and write new fragment */
693 nfo = hdallocfrag(hp->fd, nrays);
694 errno = 0;
695 if (lseek(hp->fd, nfo, SEEK_SET) < 0)
696 error(SYSTEM, "cannot seek on holodeck file");
697 n = hp->bl[i]->nrm * sizeof(RAYVAL);
698 if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) {
699 hdfragl[hp->fd].writable = -1;
700 hdsync(NULL, 0); /* sync directories */
701 error(SYSTEM, "write error in hdsyncbeam");
702 }
703 hp->bi[i].fo = nfo;
704 } else
705 hp->bi[i].fo = 0;
706 biglob(hp)->nrd += nrays - hp->bi[i].nrd;
707 hp->bi[i].nrd = nrays;
708 if (!fragfreed)
709 hdmarkdirty(hp, i); /* need to flag dir. ent. */
710 return(1);
711 }
712
713
714 int
715 hdfreebeam(hp, i) /* free beam, writing if dirty */
716 register HOLO *hp;
717 register int i;
718 {
719 int nchanged;
720
721 if (hp == NULL) { /* clear all holodecks */
722 nchanged = 0;
723 for (i = 0; hdlist[i] != NULL; i++)
724 nchanged += hdfreebeam(hdlist[i], 0);
725 return(nchanged);
726 }
727 if (hdfragl[hp->fd].writable < 0) /* check for file error */
728 return(0);
729 if (i == 0) { /* clear entire holodeck */
730 if (blglob(hp)->nrm == 0)
731 return(0); /* already clear */
732 nchanged = 0;
733 for (i = nbeams(hp); i > 0; i--)
734 if (hp->bl[i] != NULL)
735 nchanged += hdfreebeam(hp, i);
736 DCHECK(blglob(hp)->nrm != 0,
737 CONSISTENCY, "bad beam count in hdfreebeam");
738 return(nchanged);
739 }
740 DCHECK(i < 1 | i > nbeams(hp),
741 CONSISTENCY, "bad beam index to hdfreebeam");
742 if (hp->bl[i] == NULL)
743 return(0);
744 /* check for additions */
745 nchanged = hp->bl[i]->nrm - hp->bi[i].nrd;
746 if (nchanged)
747 hdsyncbeam(hp, i); /* write new fragment */
748 blglob(hp)->nrm -= hp->bl[i]->nrm;
749 free((void *)hp->bl[i]); /* free memory */
750 hp->bl[i] = NULL;
751 return(nchanged);
752 }
753
754
755 int
756 hdkillbeam(hp, i) /* delete beam from holodeck */
757 register HOLO *hp;
758 register int i;
759 {
760 int nchanged;
761
762 if (hp == NULL) { /* clobber all holodecks */
763 nchanged = 0;
764 for (i = 0; hdlist[i] != NULL; i++)
765 nchanged += hdkillbeam(hdlist[i], 0);
766 return(nchanged);
767 }
768 if (i == 0) { /* clobber entire holodeck */
769 if ((biglob(hp)->nrd == 0) & (blglob(hp)->nrm == 0))
770 return(0); /* already empty */
771 nchanged = 0;
772 nchanged = 0;
773 for (i = nbeams(hp); i > 0; i--)
774 if (hp->bi[i].nrd > 0 || hp->bl[i] != NULL)
775 nchanged += hdkillbeam(hp, i);
776 DCHECK(biglob(hp)->nrd != 0 | blglob(hp)->nrm != 0,
777 CONSISTENCY, "bad beam count in hdkillbeam");
778 return(nchanged);
779 }
780 DCHECK(i < 1 | i > nbeams(hp), CONSISTENCY,
781 "bad beam index to hdkillbeam");
782 DCHECK(!hdfragl[hp->fd].writable, CONSISTENCY,
783 "hdkillbeam called on read-only holodeck");
784 if (hp->bl[i] != NULL) { /* free memory */
785 blglob(hp)->nrm -= nchanged = hp->bl[i]->nrm;
786 free((void *)hp->bl[i]);
787 hp->bl[i] = NULL;
788 } else
789 nchanged = hp->bi[i].nrd;
790 if (hp->bi[i].nrd && !(hdfragflags&FF_KILL && hdfreefrag(hp,i))) {
791 biglob(hp)->nrd -= hp->bi[i].nrd; /* free failed */
792 hp->bi[i].nrd = 0;
793 hp->bi[i].fo = 0;
794 hdmarkdirty(hp, i);
795 }
796 return(nchanged);
797 }
798
799
800 int
801 hdlrulist(hb, nents, n, hp) /* add beams from holodeck to LRU list */
802 register HDBEAMI *hb; /* beam list */
803 int nents; /* current list length */
804 int n; /* maximum list length */
805 register HOLO *hp; /* section we're adding from */
806 {
807 register int i, j;
808 /* insert each beam from hp */
809 for (i = 1; i <= nbeams(hp); i++) {
810 if (hp->bl[i] == NULL) /* check if loaded */
811 continue;
812 #if 0
813 if (hp->bl[i]->tick == hdclock) /* preempt swap? */
814 continue;
815 #endif
816 if ((j = ++nents) >= n) /* grow list if we can */
817 nents--;
818 for ( ; ; ) { /* bubble into place */
819 if (!--j || hp->bl[i]->tick >=
820 hb[j-1].h->bl[hb[j-1].b]->tick) {
821 hb[j].h = hp;
822 hb[j].b = i;
823 break;
824 }
825 *(hb+j) = *(hb+(j-1));
826 }
827 }
828 return(nents); /* return new list length */
829 }
830
831
832 int
833 hdfreecache(pct, honly) /* free up cache space, writing changes */
834 int pct; /* maximum percentage to free */
835 register HOLO *honly; /* NULL means check all */
836 {
837 HDBEAMI hb[FREEBEAMS];
838 int freetarget;
839 int n;
840 register int i;
841 #ifdef DEBUG
842 unsigned membefore;
843
844 membefore = hdmemuse(0);
845 #endif
846 /* compute free target */
847 freetarget = (honly != NULL) ? blglob(honly)->nrm :
848 hdmemuse(0)/sizeof(RAYVAL) ;
849 freetarget = freetarget*pct/100;
850 if (freetarget <= 0)
851 return(0);
852 /* find least recently used */
853 n = 0;
854 if (honly != NULL)
855 n = hdlrulist(hb, n, FREEBEAMS, honly);
856 else
857 for (i = 0; hdlist[i] != NULL; i++)
858 n = hdlrulist(hb, n, FREEBEAMS, hdlist[i]);
859 /* free LRU beams */
860 for (i = 0; i < n; i++) {
861 hdfreebeam(hb[i].h, hb[i].b);
862 if ((freetarget -= hb[i].h->bi[hb[i].b].nrd) <= 0)
863 break;
864 }
865 hdsync(honly, 0); /* synchronize directories as necessary */
866 #ifdef DEBUG
867 sprintf(errmsg,
868 "%dK before, %dK after hdfreecache (%dK total), %d rays short\n",
869 membefore>>10, hdmemuse(0)>>10, hdmemuse(1)>>10, freetarget);
870 wputs(errmsg);
871 #endif
872 return(-freetarget); /* return how far past goal we went */
873 }
874
875
876 hddone(hp) /* clean up holodeck section and free */
877 register HOLO *hp; /* NULL means clean up all */
878 {
879 register int i;
880
881 if (hp == NULL) { /* NULL means clean up everything */
882 while (hdlist[0] != NULL)
883 hddone(hdlist[0]);
884 free((void *)hdfragl);
885 hdfragl = NULL; nhdfragls = 0;
886 return;
887 }
888 /* flush all data and free memory */
889 hdflush(hp);
890 /* release fragment resources */
891 hdrelease(hp->fd);
892 /* remove hp from active list */
893 for (i = 0; hdlist[i] != NULL; i++)
894 if (hdlist[i] == hp) {
895 while ((hdlist[i] = hdlist[i+1]) != NULL)
896 i++;
897 break;
898 }
899 free((void *)hp->bl); /* free beam list */
900 free((void *)hp); /* free holodeck struct */
901 }
