| 1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ SGI";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Routines for managing holodeck files
| 9 |
| 10 |
* 9/30/97 GWLarson
| 11 |
| 12 |
| 13 |
#include "holo.h"
| 14 |
| 15 |
#ifndef CACHESIZE
| 16 |
#define CACHESIZE 16 /* default cache size (Mbytes, 0==inf) */
| 17 |
#endif
| 18 |
#ifndef FREEBEAMS
| 19 |
#define FREEBEAMS 512 /* maximum beams to free at a time */
| 20 |
#endif
| 21 |
#ifndef PCTFREE
| 22 |
#define PCTFREE 20 /* maximum fraction to free (%) */
| 23 |
#endif
| 24 |
| 25 |
/* define MAXFRAG if you want to limit fragment tracking memory */
| 26 |
| 27 |
#ifndef BSD
| 28 |
#define write writebuf /* safe i/o routines */
| 29 |
#define read readbuf
| 30 |
#endif
| 31 |
| 32 |
#define FRAGBLK 64 /* number of fragments to allocate at a time */
| 33 |
| 34 |
int hdcachesize = CACHESIZE*1024*1024; /* target cache size (bytes) */
| 35 |
unsigned long hdclock; /* clock value */
| 36 |
| 37 |
HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */
| 38 |
| 39 |
static struct fragment {
| 40 |
short nlinks; /* number of holodeck sections using us */
| 41 |
short nfrags; /* number of known fragments */
| 42 |
BEAMI *fi; /* fragments, descending file position */
| 43 |
long flen; /* last known file length */
| 44 |
} *hdfrag; /* fragment lists, indexed by file descriptor */
| 45 |
| 46 |
static int nhdfrags; /* size of hdfrag array */
| 47 |
| 48 |
| 49 |
hdattach(fd) /* start tracking file fragments for some section */
| 50 |
register int fd;
| 51 |
| 52 |
if (fd >= nhdfrags) {
| 53 |
if (nhdfrags)
| 54 |
hdfrag = (struct fragment *)realloc((char *)hdfrag,
| 55 |
(fd+1)*sizeof(struct fragment));
| 56 |
else
| 57 |
hdfrag = (struct fragment *)malloc(
| 58 |
| 59 |
if (hdfrag == NULL)
| 60 |
error(SYSTEM, "out of memory in hdattach");
| 61 |
bzero((char *)(hdfrag+nhdfrags),
| 62 |
(fd+1-nhdfrags)*sizeof(struct fragment));
| 63 |
nhdfrags = fd+1;
| 64 |
| 65 |
hdfrag[fd].nlinks++;
| 66 |
hdfrag[fd].flen = lseek(fd, 0L, 2); /* get file length */
| 67 |
| 68 |
| 69 |
| 70 |
/* Do we need a routine to locate file fragments given known occupants? */
| 71 |
| 72 |
| 73 |
hdrelease(fd) /* stop tracking file fragments for some section */
| 74 |
register int fd;
| 75 |
| 76 |
if (fd < 0 | fd >= nhdfrags || !hdfrag[fd].nlinks)
| 77 |
return;
| 78 |
if (!--hdfrag[fd].nlinks && hdfrag[fd].nfrags) {
| 79 |
free((char *)hdfrag[fd].fi);
| 80 |
hdfrag[fd].fi = NULL;
| 81 |
hdfrag[fd].nfrags = 0;
| 82 |
| 83 |
| 84 |
| 85 |
| 86 |
markdirty(hp) /* mark holodeck section directory dirty */
| 87 |
register HOLO *hp;
| 88 |
| 89 |
static BEAMI smudge = {0, -1};
| 90 |
| 91 |
if (hp->dirty) /* already marked? */
| 92 |
return;
| 93 |
hp->dirty = 1;
| 94 |
if (lseek(hp->fd, biglob(hp)->fo+(nbeams(hp)-1)*sizeof(BEAMI), 0) < 0
| 95 |
|| write(hp->fd, (char *)&smudge,
| 96 |
sizeof(BEAMI)) != sizeof(BEAMI))
| 97 |
error(SYSTEM, "seek/write error in markdirty");
| 98 |
| 99 |
| 100 |
| 101 |
HOLO *
| 102 |
hdinit(fd, hproto) /* initialize a holodeck section in a file */
| 103 |
int fd; /* corresponding file descriptor */
| 104 |
HDGRID *hproto; /* holodeck section grid */
| 105 |
| 106 |
long fpos;
| 107 |
register HOLO *hp;
| 108 |
register int n;
| 109 |
/* prepare for system errors */
| 110 |
errno = 0;
| 111 |
if ((fpos = lseek(fd, 0L, 1)) < 0)
| 112 |
error(SYSTEM, "cannot determine holodeck file position");
| 113 |
if (hproto == NULL) { /* assume we're loading it */
| 114 |
HDGRID hpr;
| 115 |
/* load header */
| 116 |
if (read(fd, (char *)&hpr, sizeof(HDGRID)) != sizeof(HDGRID))
| 117 |
error(SYSTEM, "cannot load holodeck header");
| 118 |
/* allocate grid */
| 119 |
if ((hp = hdalloc(&hpr)) == NULL)
| 120 |
goto memerr;
| 121 |
/* load beam directory */
| 122 |
n = nbeams(hp)*sizeof(BEAMI);
| 123 |
if (read(fd, (char *)(hp->bi+1), n) != n)
| 124 |
error(SYSTEM, "failure loading holodeck directory");
| 125 |
/* check that it's clean */
| 126 |
if (hp->bi[nbeams(hp)].fo < 0)
| 127 |
error(USER, "dirty holodeck section");
| 128 |
} else { /* assume we're creating it */
| 129 |
if ((hp = hdalloc(hproto)) == NULL)
| 130 |
goto memerr;
| 131 |
/* write header and skeleton */
| 132 |
| 133 |
if (write(fd, (char *)hproto, sizeof(HDGRID)) !=
| 134 |
sizeof(HDGRID) ||
| 135 |
write(fd, (char *)(hp->bi+1), n) != n)
| 136 |
error(SYSTEM, "cannot write header to holodeck file");
| 137 |
| 138 |
hp->fd = fd;
| 139 |
hp->dirty = 0;
| 140 |
biglob(hp)->fo = fpos + sizeof(HDGRID);
| 141 |
biglob(hp)->nrd = 0; /* count rays on disk */
| 142 |
for (n = nbeams(hp); n > 0; n--)
| 143 |
biglob(hp)->nrd += hp->bi[n].nrd;
| 144 |
/* add to holodeck list */
| 145 |
for (n = 0; n < HDMAX; n++)
| 146 |
if (hdlist[n] == NULL) {
| 147 |
hdlist[n] = hp;
| 148 |
break;
| 149 |
| 150 |
/* start tracking fragments (last) */
| 151 |
hdattach(fd);
| 152 |
/* all done */
| 153 |
return(hp);
| 154 |
memerr:
| 155 |
error(SYSTEM, "cannot allocate holodeck grid");
| 156 |
| 157 |
| 158 |
| 159 |
int
| 160 |
hdsync(hp, all) /* update beams and directory on disk */
| 161 |
register HOLO *hp;
| 162 |
int all;
| 163 |
| 164 |
register int j, n;
| 165 |
| 166 |
if (hp == NULL) { /* do all holodecks */
| 167 |
n = 0;
| 168 |
for (j = 0; hdlist[j] != NULL; j++)
| 169 |
n += hdsync(hdlist[j], all);
| 170 |
return(n);
| 171 |
| 172 |
/* sync the beams */
| 173 |
for (j = all ? nbeams(hp) : 0; j > 0; j--)
| 174 |
if (hp->bl[j] != NULL)
| 175 |
hdsyncbeam(hp, j);
| 176 |
if (!hp->dirty) /* directory dirty? */
| 177 |
return(0);
| 178 |
errno = 0;
| 179 |
if (lseek(hp->fd, biglob(hp)->fo, 0) < 0)
| 180 |
error(SYSTEM, "cannot seek on holodeck file");
| 181 |
| 182 |
if (write(hp->fd, (char *)(hp->bi+1), n) != n)
| 183 |
error(SYSTEM, "cannot update holodeck section directory");
| 184 |
hp->dirty = 0;
| 185 |
return(1);
| 186 |
| 187 |
| 188 |
| 189 |
long
| 190 |
hdmemuse(all) /* return memory usage (in bytes) */
| 191 |
int all; /* include overhead (painful) */
| 192 |
| 193 |
long total = 0;
| 194 |
register int i, j;
| 195 |
| 196 |
for (j = 0; hdlist[j] != NULL; j++) {
| 197 |
total += blglob(hdlist[j])->nrm * sizeof(RAYVAL);
| 198 |
if (all) {
| 199 |
total += sizeof(HOLO) + sizeof(BEAM *) +
| 200 |
nbeams(hdlist[j]) *
| 201 |
(sizeof(BEAM *)+sizeof(BEAMI));
| 202 |
for (i = nbeams(hdlist[j]); i > 0; i--)
| 203 |
if (hdlist[j]->bl[i] != NULL)
| 204 |
total += sizeof(BEAM);
| 205 |
| 206 |
| 207 |
if (all)
| 208 |
for (j = 0; j < nhdfrags; j++) {
| 209 |
total += sizeof(struct fragment);
| 210 |
if (hdfrag[j].nfrags)
| 211 |
total += FRAGBLK*sizeof(BEAMI) *
| 212 |
((hdfrag[j].nfrags-1)/FRAGBLK + 1) ;
| 213 |
| 214 |
return(total);
| 215 |
| 216 |
| 217 |
| 218 |
long
| 219 |
hdfilen(fd) /* return file length for fd */
| 220 |
int fd;
| 221 |
| 222 |
long fpos, flen;
| 223 |
| 224 |
if (fd < 0)
| 225 |
return(-1);
| 226 |
if (fd >= nhdfrags || !hdfrag[fd].nlinks) {
| 227 |
| 228 |
return(-1);
| 229 |
| 230 |
lseek(fd, fpos, 0);
| 231 |
return(flen);
| 232 |
| 233 |
return(hdfrag[fd].flen);
| 234 |
| 235 |
| 236 |
| 237 |
long
| 238 |
hdfiluse(fd, all) /* compute file usage (in bytes) */
| 239 |
int fd; /* open file descriptor to check */
| 240 |
int all; /* include overhead and unflushed data */
| 241 |
| 242 |
long total = 0;
| 243 |
register int i, j;
| 244 |
| 245 |
| 246 |
if (hdlist[j]->fd != fd)
| 247 |
continue;
| 248 |
total += biglob(hdlist[j])->nrd * sizeof(RAYVAL);
| 249 |
if (all) {
| 250 |
| 251 |
| 252 |
total += sizeof(RAYVAL) *
| 253 |
(hdlist[j]->bl[i]->nrm -
| 254 |
hdlist[j]->bi[i].nrd);
| 255 |
total += sizeof(HDGRID) +
| 256 |
nbeams(hdlist[j])*sizeof(BEAMI);
| 257 |
| 258 |
| 259 |
return(total); /* does not include fragments */
| 260 |
| 261 |
| 262 |
| 263 |
RAYVAL *
| 264 |
hdnewrays(hp, i, nr) /* allocate space for add'l rays and return pointer */
| 265 |
register HOLO *hp;
| 266 |
register int i;
| 267 |
int nr; /* number of new rays desired */
| 268 |
| 269 |
RAYVAL *p;
| 270 |
int n;
| 271 |
| 272 |
if (nr <= 0)
| 273 |
return(NULL);
| 274 |
if (i < 1 | i > nbeams(hp))
| 275 |
error(CONSISTENCY, "bad beam index given to hdnewrays");
| 276 |
if (hp->bl[i] != NULL)
| 277 |
hp->bl[i]->tick = hdclock; /* preempt swap */
| 278 |
if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
| 279 |
hdfreecache(PCTFREE, NULL); /* free some space */
| 280 |
errno = 0;
| 281 |
if (hp->bl[i] == NULL) { /* allocate (and load) */
| 282 |
n = hp->bi[i].nrd + nr;
| 283 |
if ((hp->bl[i] = (BEAM *)malloc(hdbsiz(n))) == NULL)
| 284 |
goto memerr;
| 285 |
blglob(hp)->nrm += n;
| 286 |
if (n = hp->bl[i]->nrm = hp->bi[i].nrd) {
| 287 |
if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
| 288 |
error(SYSTEM, "seek error on holodeck file");
| 289 |
n *= sizeof(RAYVAL);
| 290 |
if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
| 291 |
error(SYSTEM,
| 292 |
"error reading beam from holodeck file");
| 293 |
| 294 |
} else { /* just grow in memory */
| 295 |
hp->bl[i] = (BEAM *)realloc( (char *)hp->bl[i],
| 296 |
hdbsiz(hp->bl[i]->nrm + nr) );
| 297 |
| 298 |
goto memerr;
| 299 |
blglob(hp)->nrm += nr;
| 300 |
| 301 |
p = hdbray(hp->bl[i]) + hp->bl[i]->nrm;
| 302 |
hp->bl[i]->nrm += nr; /* update in-core structure */
| 303 |
bzero((char *)p, nr*sizeof(RAYVAL));
| 304 |
hp->bl[i]->tick = ++hdclock; /* update LRU clock */
| 305 |
blglob(hp)->tick = hdclock;
| 306 |
return(p); /* point to new rays */
| 307 |
memerr:
| 308 |
error(SYSTEM, "out of memory in hdnewrays");
| 309 |
| 310 |
| 311 |
| 312 |
BEAM *
| 313 |
hdgetbeam(hp, i) /* get beam (from file if necessary) */
| 314 |
register HOLO *hp;
| 315 |
register int i;
| 316 |
| 317 |
register int n;
| 318 |
| 319 |
| 320 |
error(CONSISTENCY, "bad beam index given to hdgetbeam");
| 321 |
if (hp->bl[i] == NULL) { /* load from disk */
| 322 |
if (!(n = hp->bi[i].nrd))
| 323 |
return(NULL);
| 324 |
| 325 |
hdfreecache(PCTFREE, NULL); /* get free space */
| 326 |
errno = 0;
| 327 |
| 328 |
error(SYSTEM, "cannot allocate memory for beam");
| 329 |
blglob(hp)->nrm += hp->bl[i]->nrm = n;
| 330 |
| 331 |
| 332 |
| 333 |
| 334 |
error(SYSTEM, "error reading beam from holodeck file");
| 335 |
| 336 |
| 337 |
| 338 |
return(hp->bl[i]);
| 339 |
| 340 |
| 341 |
| 342 |
int
| 343 |
hdsyncbeam(hp, i) /* sync beam in memory with beam on disk */
| 344 |
register HOLO *hp;
| 345 |
register int i;
| 346 |
| 347 |
unsigned int nrays;
| 348 |
long nfo;
| 349 |
unsigned int n;
| 350 |
#ifdef DEBUG
| 351 |
| 352 |
error(CONSISTENCY, "bad beam index in hdsyncbeam");
| 353 |
#endif
| 354 |
/* is current fragment OK? */
| 355 |
if (hp->bl[i] == NULL || (nrays = hp->bl[i]->nrm) == hp->bi[i].nrd)
| 356 |
return(0);
| 357 |
/* check file status */
| 358 |
if (hp->dirty < 0)
| 359 |
return(-1);
| 360 |
| 361 |
if (hp->fd >= nhdfrags || !hdfrag[hp->fd].nlinks) /* untracked */
| 362 |
hp->bi[i].fo = lseek(hp->fd, 0L, 2);
| 363 |
| 364 |
else if (hp->bi[i].fo + hp->bi[i].nrd*sizeof(RAYVAL) ==
| 365 |
hdfrag[hp->fd].flen) /* EOF special case */
| 366 |
hdfrag[hp->fd].flen = (nfo=hp->bi[i].fo) + nrays*sizeof(RAYVAL);
| 367 |
| 368 |
else { /* general case */
| 369 |
register struct fragment *f = &hdfrag[hp->fd];
| 370 |
register int j, k;
| 371 |
/* relinquish old fragment */
| 372 |
if (hp->bi[i].nrd) {
| 373 |
j = f->nfrags++;
| 374 |
#ifdef MAXFRAG
| 375 |
if (j >= MAXFRAG-1)
| 376 |
f->nfrags--;
| 377 |
#endif
| 378 |
if (j % FRAGBLK == 0) { /* more frag. space */
| 379 |
if (f->fi == NULL)
| 380 |
f->fi = (BEAMI *)malloc(
| 381 |
FRAGBLK*sizeof(BEAMI));
| 382 |
else
| 383 |
f->fi = (BEAMI *)realloc((char *)f->fi,
| 384 |
(j+FRAGBLK)*sizeof(BEAMI));
| 385 |
if (f->fi == NULL)
| 386 |
error(SYSTEM,
| 387 |
"out of memory in hdsyncbeam");
| 388 |
| 389 |
for ( ; ; j--) { /* insert in descending list */
| 390 |
if (!j || hp->bi[i].fo < f->fi[j-1].fo) {
| 391 |
f->fi[j].fo = hp->bi[i].fo;
| 392 |
f->fi[j].nrd = hp->bi[i].nrd;
| 393 |
break;
| 394 |
| 395 |
copystruct(f->fi+j, f->fi+j-1);
| 396 |
| 397 |
/* coalesce adjacent fragments */
| 398 |
for (j = k = 0; k < f->nfrags; j++, k++) {
| 399 |
if (k > j)
| 400 |
copystruct(f->fi+j, f->fi+k);
| 401 |
while (k+1 < f->nfrags && f->fi[k+1].fo +
| 402 |
f->fi[k+1].nrd*sizeof(RAYVAL)
| 403 |
== f->fi[j].fo) {
| 404 |
f->fi[j].fo -=
| 405 |
f->fi[++k].nrd*sizeof(RAYVAL);
| 406 |
f->fi[j].nrd += f->fi[k].nrd;
| 407 |
| 408 |
| 409 |
f->nfrags = j;
| 410 |
| 411 |
k = -1; /* find closest-sized fragment */
| 412 |
for (j = nrays ? f->nfrags : 0; j-- > 0; )
| 413 |
if (f->fi[j].nrd >= nrays &&
| 414 |
(k < 0 || f->fi[j].nrd < f->fi[k].nrd))
| 415 |
if (f->fi[k=j].nrd == nrays)
| 416 |
break;
| 417 |
if (k < 0) { /* no fragment -- extend file */
| 418 |
nfo = f->flen;
| 419 |
f->flen += nrays*sizeof(RAYVAL);
| 420 |
} else { /* else use fragment */
| 421 |
nfo = f->fi[k].fo;
| 422 |
if (f->fi[k].nrd == nrays) { /* delete fragment */
| 423 |
f->nfrags--;
| 424 |
for (j = k; j < f->nfrags; j++)
| 425 |
copystruct(f->fi+j, f->fi+j+1);
| 426 |
} else { /* else shrink it */
| 427 |
f->fi[k].fo += nrays*sizeof(RAYVAL);
| 428 |
f->fi[k].nrd -= nrays;
| 429 |
| 430 |
| 431 |
| 432 |
if (nrays) { /* write the new fragment */
| 433 |
errno = 0;
| 434 |
if (lseek(hp->fd, nfo, 0) < 0)
| 435 |
| 436 |
n = hp->bl[i]->nrm * sizeof(RAYVAL);
| 437 |
if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) {
| 438 |
hp->dirty = -1; /* avoid recursive error */
| 439 |
error(SYSTEM, "write error in hdsyncbeam");
| 440 |
| 441 |
| 442 |
biglob(hp)->nrd += nrays - hp->bi[i].nrd;
| 443 |
hp->bi[i].nrd = nrays;
| 444 |
hp->bi[i].fo = nfo;
| 445 |
markdirty(hp); /* section directory now out of date */
| 446 |
return(1);
| 447 |
| 448 |
| 449 |
| 450 |
int
| 451 |
hdfreebeam(hp, i) /* free beam, writing if dirty */
| 452 |
register HOLO *hp;
| 453 |
register int i;
| 454 |
| 455 |
int nchanged;
| 456 |
| 457 |
if (hp == NULL) { /* clear all holodecks */
| 458 |
nchanged = 0;
| 459 |
for (i = 0; hdlist[i] != NULL; i++)
| 460 |
nchanged += hdfreebeam(hdlist[i], 0);
| 461 |
return(nchanged);
| 462 |
| 463 |
if (i == 0) { /* clear entire holodeck */
| 464 |
nchanged = 0;
| 465 |
for (i = nbeams(hp); i > 0; i--)
| 466 |
| 467 |
nchanged += hdfreebeam(hp, i);
| 468 |
return(nchanged);
| 469 |
| 470 |
#ifdef DEBUG
| 471 |
| 472 |
error(CONSISTENCY, "bad beam index to hdfreebeam");
| 473 |
#endif
| 474 |
| 475 |
return(0);
| 476 |
/* check for additions */
| 477 |
nchanged = hp->bl[i]->nrm - hp->bi[i].nrd;
| 478 |
if (nchanged)
| 479 |
hdsyncbeam(hp, i); /* write new fragment */
| 480 |
blglob(hp)->nrm -= hp->bl[i]->nrm;
| 481 |
free((char *)hp->bl[i]); /* free memory */
| 482 |
hp->bl[i] = NULL;
| 483 |
return(nchanged);
| 484 |
| 485 |
| 486 |
| 487 |
int
| 488 |
hdkillbeam(hp, i) /* delete beam from holodeck */
| 489 |
register HOLO *hp;
| 490 |
register int i;
| 491 |
| 492 |
static BEAM emptybeam;
| 493 |
int nchanged;
| 494 |
| 495 |
if (hp == NULL) { /* clobber all holodecks */
| 496 |
nchanged = 0;
| 497 |
| 498 |
nchanged += hdkillbeam(hdlist[i], 0);
| 499 |
return(nchanged);
| 500 |
| 501 |
if (i == 0) { /* clobber entire holodeck */
| 502 |
nchanged = 0;
| 503 |
| 504 |
if (hp->bi[i].nrd > 0 || hp->bl[i] != NULL)
| 505 |
nchanged += hdkillbeam(hp, i);
| 506 |
#ifdef DEBUG
| 507 |
if (biglob(hp)->nrd != 0 | blglob(hp)->nrm != 0)
| 508 |
error(CONSISTENCY, "bad beam count in hdkillbeam");
| 509 |
#endif
| 510 |
return(nchanged);
| 511 |
| 512 |
#ifdef DEBUG
| 513 |
| 514 |
error(CONSISTENCY, "bad beam index to hdkillbeam");
| 515 |
#endif
| 516 |
if (hp->bl[i] != NULL) { /* free memory */
| 517 |
blglob(hp)->nrm -= nchanged = hp->bl[i]->nrm;
| 518 |
| 519 |
} else
| 520 |
nchanged = hp->bi[i].nrd;
| 521 |
if (hp->bi[i].nrd) { /* free file fragment */
| 522 |
hp->bl[i] = &emptybeam;
| 523 |
hdsyncbeam(hp, i);
| 524 |
| 525 |
hp->bl[i] = NULL;
| 526 |
return(nchanged);
| 527 |
| 528 |
| 529 |
| 530 |
hdlrulist(ha, ba, n, hp) /* add beams from holodeck to LRU list */
| 531 |
register HOLO *ha[]; /* section list (NULL terminated) */
| 532 |
register int ba[]; /* beam index to go with section */
| 533 |
int n; /* length of arrays minus 1 */
| 534 |
register HOLO *hp; /* section we're adding from */
| 535 |
| 536 |
register int i, j;
| 537 |
int nents;
| 538 |
/* find last entry in LRU list */
| 539 |
for (j = 0; ha[j] != NULL; j++)
| 540 |
| 541 |
nents = j;
| 542 |
/* insert each beam from hp */
| 543 |
for (i = nbeams(hp); i > 0; i--) {
| 544 |
if (hp->bl[i] == NULL) /* check if loaded */
| 545 |
continue;
| 546 |
if ((j = ++nents) > n) /* grow list if we can */
| 547 |
nents--;
| 548 |
for ( ; ; ) { /* bubble into place */
| 549 |
if (!--j || hp->bl[i]->tick >=
| 550 |
ha[j-1]->bl[ba[j-1]]->tick) {
| 551 |
ha[j] = hp;
| 552 |
ba[j] = i;
| 553 |
break;
| 554 |
| 555 |
ha[j] = ha[j-1];
| 556 |
ba[j] = ba[j-1];
| 557 |
| 558 |
| 559 |
ha[nents] = NULL; /* all done */
| 560 |
ba[nents] = 0;
| 561 |
| 562 |
| 563 |
| 564 |
hdfreecache(pct, honly) /* free up cache space, writing changes */
| 565 |
int pct; /* maximum percentage to free */
| 566 |
register HOLO *honly; /* NULL means check all */
| 567 |
| 568 |
HOLO *hp[FREEBEAMS+1];
| 569 |
int bn[FREEBEAMS+1];
| 570 |
int freetarget;
| 571 |
register int i;
| 572 |
/* compute free target */
| 573 |
freetarget = (honly != NULL) ? blglob(honly)->nrm :
| 574 |
hdmemuse(0)/sizeof(RAYVAL) ;
| 575 |
freetarget = freetarget*pct/100;
| 576 |
/* find least recently used */
| 577 |
hp[0] = NULL;
| 578 |
bn[0] = 0;
| 579 |
if (honly != NULL)
| 580 |
hdlrulist(hp, bn, FREEBEAMS, honly);
| 581 |
else
| 582 |
| 583 |
hdlrulist(hp, bn, FREEBEAMS, hdlist[i]);
| 584 |
/* free LRU beams */
| 585 |
for (i = 0; hp[i] != NULL; i++) {
| 586 |
hdfreebeam(hp[i], bn[i]);
| 587 |
if ((freetarget -= hp[i]->bi[bn[i]].nrd) <= 0)
| 588 |
break;
| 589 |
| 590 |
hdsync(honly, 0); /* synchronize directories as necessary */
| 591 |
| 592 |
| 593 |
| 594 |
hddone(hp) /* clean up holodeck section and free */
| 595 |
register HOLO *hp; /* NULL means clean up all */
| 596 |
| 597 |
register int i;
| 598 |
| 599 |
if (hp == NULL) { /* NULL means clean up everything */
| 600 |
while (hdlist[0] != NULL)
| 601 |
hddone(hdlist[0]);
| 602 |
return;
| 603 |
| 604 |
/* flush all data and free memory */
| 605 |
hdflush(hp);
| 606 |
/* release fragment resources */
| 607 |
hdrelease(hp->fd);
| 608 |
/* remove hp from active list */
| 609 |
| 610 |
if (hdlist[i] == hp) {
| 611 |
while ((hdlist[i] = hdlist[i+1]) != NULL)
| 612 |
i++;
| 613 |
break;
| 614 |
| 615 |
free((char *)hp->bl); /* free beam list */
| 616 |
free((char *)hp); /* free holodeck struct */
| 617 |
