--- ray/src/hd/holofile.c 2003/06/13 15:27:04 3.47 +++ ray/src/hd/holofile.c 2003/07/07 17:21:50 3.50 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: holofile.c,v 3.47 2003/06/13 15:27:04 greg Exp $"; +static const char RCSid[] = "$Id: holofile.c,v 3.50 2003/07/07 17:21:50 greg Exp $"; #endif /* * Routines for managing holodeck files @@ -7,6 +7,10 @@ static const char RCSid[] = "$Id: holofile.c,v 3.47 20 * 9/30/97 GWLarson */ +#include "copyright.h" + +#include + #include "holo.h" #ifndef CACHESIZE @@ -66,7 +70,7 @@ HDGRID *hproto; register HOLO *hp; int n; /* copy grid to temporary header */ - bcopy((void *)hproto, (void *)&hdhead, sizeof(HDGRID)); + memcpy((void *)&hdhead, (void *)hproto, sizeof(HDGRID)); /* compute grid vectors and sizes */ hdcompgrid(&hdhead); /* allocate header with directory */ @@ -81,13 +85,13 @@ HDGRID *hproto; free((void *)hp); return(NULL); } - bzero((void *)hp->bl, (nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM)); + memset((void *)hp->bl, '\0', (nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM)); hp->bl[0] = (BEAM *)(hp->bl+nbeams(hp)+1); /* set blglob(hp) */ hp->fd = -1; hp->dirty = 0; hp->priv = NULL; /* clear beam directory */ - bzero((void *)hp->bi, (nbeams(hp)+1)*sizeof(BEAMI)); + memset((void *)hp->bi, '\0', (nbeams(hp)+1)*sizeof(BEAMI)); return(hp); /* all is well */ } @@ -123,8 +127,8 @@ int wr; if (fd >= nhdfragls) { hdfragl = (struct fraglist *)hdrealloc((char *)hdfragl, (fd+1)*sizeof(struct fraglist), "hdattach"); - bzero((void *)(hdfragl+nhdfragls), - (fd+1-nhdfragls)*sizeof(struct fraglist)); + memset((void *)(hdfragl+nhdfragls), + '\0', (fd+1-nhdfragls)*sizeof(struct fraglist)); nhdfragls = fd+1; } hdfragl[fd].nlinks++; @@ -429,7 +433,7 @@ int nr; /* number of new rays desired */ hdfreefrag(hp, i); /* relinquish old fragment */ p = hdbray(hp->bl[i]) + hp->bl[i]->nrm; hp->bl[i]->nrm += nr; /* update in-core structure */ - bzero((void *)p, nr*sizeof(RAYVAL)); + memset((void *)p, '\0', nr*sizeof(RAYVAL)); blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */ return(p); /* point to new rays */ } @@ -487,7 +491,7 @@ register HDBEAMI *hb1, *hb2; hdloadbeams(hb, n, bf) /* load a list of beams in optimal order */ register HDBEAMI *hb; /* list gets sorted by hdfilord() */ int n; /* list length */ -int (*bf)(); /* callback function (optional) */ +void (*bf)(); /* callback function (optional) */ { unsigned origcachesize, memuse; int bytesloaded, needbytes, bytes2free; @@ -612,7 +616,7 @@ int hdfragOK(fd, listlen, listsiz) /* get fragment list status for file */ int fd; int *listlen; -register int4 *listsiz; +register int32 *listsiz; { register struct fraglist *f; register int i; @@ -635,7 +639,7 @@ register int4 *listsiz; off_t hdallocfrag(fd, nrays) /* allocate a file fragment */ int fd; -unsigned int4 nrays; +uint32 nrays; { register struct fraglist *f; register int j; @@ -667,7 +671,7 @@ register HOLO *hp; register int i; { int fragfreed; - unsigned int4 nrays; + uint32 nrays; unsigned int n; off_t nfo; /* check file status */
