--- ray/src/hd/holofile.c 1997/12/29 15:17:45 3.15 +++ ray/src/hd/holofile.c 2003/05/13 17:58:33 3.44 @@ -1,9 +1,6 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: holofile.c,v 3.44 2003/05/13 17:58:33 greg Exp $"; #endif - /* * Routines for managing holodeck files * @@ -13,90 +10,142 @@ static char SCCSid[] = "$SunId$ SGI"; #include "holo.h" #ifndef CACHESIZE -#define CACHESIZE 16 /* default cache size (Mbytes, 0==inf) */ +#ifdef BIGMEM +#define CACHESIZE 17 /* default cache size (Mbytes, 0==inf) */ +#else +#define CACHESIZE 5 #endif +#endif #ifndef FREEBEAMS -#define FREEBEAMS 512 /* maximum beams to free at a time */ +#define FREEBEAMS 1500 /* maximum beams to free at a time */ #endif #ifndef PCTFREE -#define PCTFREE 20 /* maximum fraction to free (%) */ +#define PCTFREE 15 /* maximum fraction to free (%) */ #endif -#ifndef MAXFRAG -#define MAXFRAG 131000 /* maximum fragments/file to track (0==inf) */ +#ifndef MAXFRAGB +#define MAXFRAGB 16 /* fragment blocks/file to track (0==inf) */ #endif +#ifndef FF_DEFAULT + /* when to free a beam fragment */ +#define FF_DEFAULT (FF_WRITE|FF_KILL) +#endif +#ifndef MINDIRSEL + /* minimum directory seek length */ +#define MINDIRSEL (4*BUFSIZ/sizeof(BEAMI)) +#endif #ifndef BSD #define write writebuf /* safe i/o routines */ #define read readbuf #endif -#define FRAGBLK 64 /* number of fragments to allocate at a time */ +#define FRAGBLK 512 /* number of fragments to allocate at a time */ +int hdfragflags = FF_DEFAULT; /* tells when to free fragments */ unsigned hdcachesize = CACHESIZE*1024*1024; /* target cache size */ -unsigned long hdclock; /* clock value */ +unsigned long hdclock; /* clock value */ HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */ -static struct fragment { +static struct fraglist { short nlinks; /* number of holodeck sections using us */ - short writerr; /* write error encountered */ + short writable; /* 0 read-only, <0 write error encountered */ int nfrags; /* number of known fragments */ BEAMI *fi; /* fragments, descending file position */ long flen; /* last known file length */ -} *hdfrag; /* fragment lists, indexed by file descriptor */ +} *hdfragl; /* fragment lists, indexed by file descriptor */ -static int nhdfrags; /* size of hdfrag array */ +static int nhdfragls; /* size of hdfragl array */ -hdattach(fd) /* start tracking file fragments for some section */ -register int fd; +HOLO * +hdalloc(hproto) /* allocate and set holodeck section based on grid */ +HDGRID *hproto; { - if (fd >= nhdfrags) { - if (nhdfrags) - hdfrag = (struct fragment *)realloc((char *)hdfrag, - (fd+1)*sizeof(struct fragment)); - else - hdfrag = (struct fragment *)malloc( - (fd+1)*sizeof(struct fragment)); - if (hdfrag == NULL) - error(SYSTEM, "out of memory in hdattach"); - bzero((char *)(hdfrag+nhdfrags), - (fd+1-nhdfrags)*sizeof(struct fragment)); - nhdfrags = fd+1; + HOLO hdhead; + register HOLO *hp; + int n; + /* copy grid to temporary header */ + bcopy((void *)hproto, (void *)&hdhead, sizeof(HDGRID)); + /* compute grid vectors and sizes */ + hdcompgrid(&hdhead); + /* allocate header with directory */ + n = sizeof(HOLO)+nbeams(&hdhead)*sizeof(BEAMI); + if ((hp = (HOLO *)malloc(n)) == NULL) + return(NULL); + /* copy header information */ + copystruct(hp, &hdhead); + /* allocate and clear beam list */ + hp->bl = (BEAM **)malloc((nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM)); + if (hp->bl == NULL) { + free((void *)hp); + return(NULL); } - hdfrag[fd].nlinks++; - hdfrag[fd].flen = lseek(fd, 0L, 2); /* get file length */ + bzero((void *)hp->bl, (nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM)); + hp->bl[0] = (BEAM *)(hp->bl+nbeams(hp)+1); /* set blglob(hp) */ + hp->fd = -1; + hp->dirty = 0; + hp->priv = NULL; + /* clear beam directory */ + bzero((void *)hp->bi, (nbeams(hp)+1)*sizeof(BEAMI)); + return(hp); /* all is well */ } -/* Do we need a routine to locate file fragments given known occupants? */ +char * +hdrealloc(ptr, siz, rout) /* (re)allocate memory, retry then error */ +char *ptr; +unsigned siz; +char *rout; +{ + register char *newp; + /* call malloc/realloc */ + if (ptr == NULL) newp = (char *)malloc(siz); + else newp = (char *)realloc((void *)ptr, siz); + /* check success */ + if (newp == NULL && rout != NULL) { + hdfreecache(25, NULL); /* free some memory */ + errno = 0; /* retry */ + newp = hdrealloc(ptr, siz, NULL); + if (newp == NULL) { /* give up and report error */ + sprintf(errmsg, "out of memory in %s", rout); + error(SYSTEM, errmsg); + } + } + return(newp); +} -hdrelease(fd) /* stop tracking file fragments for some section */ +hdattach(fd, wr) /* start tracking file fragments for some section */ register int fd; +int wr; { - if (fd < 0 | fd >= nhdfrags || !hdfrag[fd].nlinks) - return; - if (!--hdfrag[fd].nlinks && hdfrag[fd].nfrags) { - free((char *)hdfrag[fd].fi); - hdfrag[fd].fi = NULL; - hdfrag[fd].nfrags = 0; + if (fd >= nhdfragls) { + hdfragl = (struct fraglist *)hdrealloc((char *)hdfragl, + (fd+1)*sizeof(struct fraglist), "hdattach"); + bzero((void *)(hdfragl+nhdfragls), + (fd+1-nhdfragls)*sizeof(struct fraglist)); + nhdfragls = fd+1; } + hdfragl[fd].nlinks++; + hdfragl[fd].writable = wr; /* set writable flag */ + hdfragl[fd].flen = lseek(fd, (off_t)0L, 2); /* get file length */ } -markdirty(hp) /* mark holodeck section directory dirty */ -register HOLO *hp; -{ - static BEAMI smudge = {0, -1}; +/* Do we need a routine to locate file fragments given known occupants? */ - if (hp->dirty) /* already marked? */ + +hdrelease(fd) /* stop tracking file fragments for some section */ +register int fd; +{ + if (fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks) return; - hp->dirty = 1; - if (lseek(hp->fd, biglob(hp)->fo+(nbeams(hp)-1)*sizeof(BEAMI), 0) < 0 - || write(hp->fd, (char *)&smudge, - sizeof(BEAMI)) != sizeof(BEAMI)) - error(SYSTEM, "seek/write error in markdirty"); + if (!--hdfragl[fd].nlinks && hdfragl[fd].nfrags) { + free((void *)hdfragl[fd].fi); + hdfragl[fd].fi = NULL; + hdfragl[fd].nfrags = 0; + } } @@ -105,12 +154,14 @@ hdinit(fd, hproto) /* initialize a holodeck section in int fd; /* corresponding file descriptor */ HDGRID *hproto; /* holodeck section grid */ { + long rtrunc; long fpos; + int writable; register HOLO *hp; register int n; /* prepare for system errors */ errno = 0; - if ((fpos = lseek(fd, 0L, 1)) < 0) + if ((fpos = lseek(fd, (off_t)0L, 1)) < 0) error(SYSTEM, "cannot determine holodeck file position"); if (hproto == NULL) { /* assume we're loading it */ HDGRID hpr; @@ -125,9 +176,20 @@ HDGRID *hproto; /* holodeck section grid */ if (read(fd, (char *)(hp->bi+1), n) != n) error(SYSTEM, "failure loading holodeck directory"); /* check that it's clean */ - if (hp->bi[nbeams(hp)].fo < 0) - error(USER, "dirty holodeck section"); - } else { /* assume we're creating it */ + for (n = nbeams(hp); n > 0; n--) + if (hp->bi[n].fo < 0) { + hp->bi[n].fo = 0; + error(WARNING, "dirty holodeck section"); + break; + } + /* check writability */ + if (fd < nhdfragls && hdfragl[fd].nlinks) + writable = hdfragl[fd].writable; + else + writable = lseek(fd, (off_t)fpos, 0) == fpos && + write(fd, (char *)hp, sizeof(HDGRID)) == + sizeof(HDGRID); + } else { /* else assume we're creating it */ if ((hp = hdalloc(hproto)) == NULL) goto memerr; /* write header and skeleton */ @@ -136,21 +198,28 @@ HDGRID *hproto; /* holodeck section grid */ sizeof(HDGRID) || write(fd, (char *)(hp->bi+1), n) != n) error(SYSTEM, "cannot write header to holodeck file"); + writable = 1; } hp->fd = fd; hp->dirty = 0; biglob(hp)->fo = fpos + sizeof(HDGRID); /* start tracking fragments */ - hdattach(fd); + hdattach(fd, writable); /* check rays on disk */ fpos = hdfilen(fd); - biglob(hp)->nrd = 0; + biglob(hp)->nrd = rtrunc = 0; for (n = hproto == NULL ? nbeams(hp) : 0; n > 0; n--) if (hp->bi[n].nrd) - if (hp->bi[n].fo + hp->bi[n].nrd > fpos) - hp->bi[n].nrd = 0; /* off end */ - else + if (hp->bi[n].fo+hp->bi[n].nrd*sizeof(RAYVAL) > fpos) { + rtrunc += hp->bi[n].nrd; + hp->bi[n].nrd = 0; + } else biglob(hp)->nrd += hp->bi[n].nrd; + if (rtrunc) { + sprintf(errmsg, "truncated section, %ld rays lost (%.1f%%)", + rtrunc, 100.*rtrunc/(rtrunc+biglob(hp)->nrd)); + error(WARNING, errmsg); + } /* add to holodeck list */ for (n = 0; n < HDMAX; n++) if (hdlist[n] == NULL) { @@ -164,6 +233,57 @@ memerr: } +hdmarkdirty(hp, i) /* mark holodeck directory position dirty */ +register HOLO *hp; +int i; +{ + static BEAMI smudge = {0, -1}; + int mindist, minpos; + register int j; + + if (!hp->dirty++) { /* write smudge first time */ + if (lseek(hp->fd, (off_t)(biglob(hp)->fo+(i-1)*sizeof(BEAMI)), 0) < 0 + || write(hp->fd, (char *)&smudge, + sizeof(BEAMI)) != sizeof(BEAMI)) + error(SYSTEM, "seek/write error in hdmarkdirty"); + hp->dirseg[0].s = i; + hp->dirseg[0].n = 1; + return; + } + /* insert into segment list */ + for (j = hp->dirty; j--; ) { + if (!j || hp->dirseg[j-1].s < i) { + hp->dirseg[j].s = i; + hp->dirseg[j].n = 1; + break; + } + copystruct(hp->dirseg+j, hp->dirseg+(j-1)); + } + do { /* check neighbors */ + mindist = nbeams(hp); /* find closest */ + for (j = hp->dirty; --j; ) + if (hp->dirseg[j].s - + (hp->dirseg[j-1].s + hp->dirseg[j-1].n) + < mindist) { + minpos = j; + mindist = hp->dirseg[j].s - + (hp->dirseg[j-1].s + hp->dirseg[j-1].n); + } + /* good enough? */ + if (hp->dirty <= MAXDIRSE && mindist > MINDIRSEL) + break; + j = minpos - 1; /* coalesce neighbors */ + if (hp->dirseg[j].s + hp->dirseg[j].n < + hp->dirseg[minpos].s + hp->dirseg[minpos].n) + hp->dirseg[j].n = hp->dirseg[minpos].s + + hp->dirseg[minpos].n - hp->dirseg[j].s; + hp->dirty--; + while (++j < hp->dirty) /* close the gap */ + copystruct(hp->dirseg+j, hp->dirseg+(j+1)); + } while (mindist <= MINDIRSEL); +} + + int hdsync(hp, all) /* update beams and directory on disk */ register HOLO *hp; @@ -183,13 +303,16 @@ int all; hdsyncbeam(hp, j); if (!hp->dirty) /* directory clean? */ return(0); - errno = 0; - if (lseek(hp->fd, biglob(hp)->fo, 0) < 0) - error(SYSTEM, "cannot seek on holodeck file"); - n = nbeams(hp)*sizeof(BEAMI); - if (write(hp->fd, (char *)(hp->bi+1), n) != n) - error(SYSTEM, "cannot update holodeck section directory"); - hp->dirty = 0; + errno = 0; /* write dirty segments */ + for (j = 0; j < hp->dirty; j++) { + if (lseek(hp->fd, (off_t)(biglob(hp)->fo + + (hp->dirseg[j].s-1)*sizeof(BEAMI)), 0) < 0) + error(SYSTEM, "cannot seek on holodeck file"); + n = hp->dirseg[j].n * sizeof(BEAMI); + if (write(hp->fd, (char *)(hp->bi+hp->dirseg[j].s), n) != n) + error(SYSTEM, "cannot update section directory"); + } + hp->dirty = 0; /* all clean */ return(1); } @@ -213,11 +336,11 @@ int all; /* include overhead (painful) */ } } if (all) - for (j = 0; j < nhdfrags; j++) { - total += sizeof(struct fragment); - if (hdfrag[j].nfrags) + for (j = 0; j < nhdfragls; j++) { + total += sizeof(struct fraglist); + if (hdfragl[j].nfrags) total += FRAGBLK*sizeof(BEAMI) * - ((hdfrag[j].nfrags-1)/FRAGBLK + 1) ; + ((hdfragl[j].nfrags-1)/FRAGBLK + 1) ; } return(total); } @@ -231,14 +354,14 @@ int fd; if (fd < 0) return(-1); - if (fd >= nhdfrags || !hdfrag[fd].nlinks) { - if ((fpos = lseek(fd, 0L, 1)) < 0) + if (fd >= nhdfragls || !hdfragl[fd].nlinks) { + if ((fpos = lseek(fd, (off_t)0L, 1)) < 0) return(-1); - flen = lseek(fd, 0L, 2); - lseek(fd, fpos, 0); + flen = lseek(fd, (off_t)0L, 2); + lseek(fd, (off_t)fpos, 0); return(flen); } - return(hdfrag[fd].flen); + return(hdfragl[fd].flen); } @@ -277,22 +400,20 @@ int nr; /* number of new rays desired */ RAYVAL *p; int n; - if (nr <= 0) - return(NULL); - if (i < 1 | i > nbeams(hp)) - error(CONSISTENCY, "bad beam index given to hdnewrays"); + if (nr <= 0) return(NULL); + CHECK(i < 1 | i > nbeams(hp), + CONSISTENCY, "bad beam index given to hdnewrays"); if (hp->bl[i] != NULL) hp->bl[i]->tick = hdclock; /* preempt swap */ if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize) hdfreecache(PCTFREE, NULL); /* free some space */ - errno = 0; if (hp->bl[i] == NULL) { /* allocate (and load) */ n = hp->bi[i].nrd + nr; - if ((hp->bl[i] = (BEAM *)malloc(hdbsiz(n))) == NULL) - goto memerr; + hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdnewrays"); blglob(hp)->nrm += n; - if (n = hp->bl[i]->nrm = hp->bi[i].nrd) { - if (lseek(hp->fd, hp->bi[i].fo, 0) < 0) + if ((n = hp->bl[i]->nrm = hp->bi[i].nrd)) { + errno = 0; + if (lseek(hp->fd, (off_t)hp->bi[i].fo, 0) < 0) error(SYSTEM, "seek error on holodeck file"); n *= sizeof(RAYVAL); if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) @@ -300,20 +421,17 @@ int nr; /* number of new rays desired */ "error reading beam from holodeck file"); } } else { /* just grow in memory */ - hp->bl[i] = (BEAM *)realloc( (char *)hp->bl[i], - hdbsiz(hp->bl[i]->nrm + nr) ); - if (hp->bl[i] == NULL) - goto memerr; + hp->bl[i] = (BEAM *)hdrealloc((char *)hp->bl[i], + hdbsiz(hp->bl[i]->nrm + nr), "hdnewrays"); blglob(hp)->nrm += nr; } + if (hdfragflags&FF_ALLOC && hp->bi[i].nrd) + hdfreefrag(hp, i); /* relinquish old fragment */ p = hdbray(hp->bl[i]) + hp->bl[i]->nrm; hp->bl[i]->nrm += nr; /* update in-core structure */ - bzero((char *)p, nr*sizeof(RAYVAL)); - hp->bl[i]->tick = hdclock; /* update LRU clock */ - blglob(hp)->tick = hdclock++; + bzero((void *)p, nr*sizeof(RAYVAL)); + blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */ return(p); /* point to new rays */ -memerr: - error(SYSTEM, "out of memory in hdnewrays"); } @@ -324,39 +442,45 @@ register int i; { register int n; - if (i < 1 | i > nbeams(hp)) - error(CONSISTENCY, "bad beam index given to hdgetbeam"); + CHECK(i < 1 | i > nbeams(hp), + CONSISTENCY, "bad beam index given to hdgetbeam"); if (hp->bl[i] == NULL) { /* load from disk */ if (!(n = hp->bi[i].nrd)) return(NULL); if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize) hdfreecache(PCTFREE, NULL); /* get free space */ - errno = 0; - if ((hp->bl[i] = (BEAM *)malloc(hdbsiz(n))) == NULL) - error(SYSTEM, "cannot allocate memory for beam"); + hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdgetbeam"); blglob(hp)->nrm += hp->bl[i]->nrm = n; - if (lseek(hp->fd, hp->bi[i].fo, 0) < 0) + errno = 0; + if (lseek(hp->fd, (off_t)hp->bi[i].fo, 0) < 0) error(SYSTEM, "seek error on holodeck file"); n *= sizeof(RAYVAL); if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) error(SYSTEM, "error reading beam from holodeck file"); + if (hdfragflags&FF_READ) + hdfreefrag(hp, i); /* relinquish old frag. */ } - hp->bl[i]->tick = hdclock; /* update LRU clock */ - blglob(hp)->tick = hdclock++; + blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */ return(hp->bl[i]); } int -hdfilord(hb1, hb2) /* order beams for optimal loading */ +hdfilord(hb1, hb2) /* order beams for quick loading */ register HDBEAMI *hb1, *hb2; { - register int c; - /* sort by file descriptor first */ + register long c; + /* residents go first */ + if (hb2->h->bl[hb2->b] != NULL) + return(hb1->h->bl[hb1->b] == NULL); + if (hb1->h->bl[hb1->b] != NULL) + return(-1); + /* otherwise sort by file descriptor */ if ((c = hb1->h->fd - hb2->h->fd)) return(c); /* then by position in file */ - return(hb1->h->bi[hb1->b].fo - hb2->h->bi[hb2->b].fo); + c = hb1->h->bi[hb1->b].fo - hb2->h->bi[hb2->b].fo; + return(c > 0 ? 1 : c < 0 ? -1 : 0); } @@ -366,123 +490,62 @@ int n; /* list length */ int (*bf)(); /* callback function (optional) */ { unsigned origcachesize, memuse; - register BEAM *bp; int bytesloaded, needbytes, bytes2free; + register BEAM *bp; register int i; /* precheck consistency */ + if (n <= 0) return; for (i = n; i--; ) - if (hb[i].h == NULL || hb[i].b < 1 | hb[i].b > nbeams(hb[i].h)) + if (hb[i].h==NULL || hb[i].b<1 | hb[i].b>nbeams(hb[i].h)) error(CONSISTENCY, "bad beam in hdloadbeams"); /* sort list for optimal access */ - qsort((char *)hb, n, sizeof(HDBEAMI), hdfilord); - bytesloaded = needbytes = 0; /* figure out memory needs */ + qsort((void *)hb, n, sizeof(HDBEAMI), hdfilord); + bytesloaded = 0; /* run through loaded beams */ + for ( ; n && (bp = hb->h->bl[hb->b]) != NULL; n--, hb++) { + bp->tick = hdclock; /* preempt swap */ + bytesloaded += bp->nrm; + if (bf != NULL) + (*bf)(bp, hb); + } + bytesloaded *= sizeof(RAYVAL); if ((origcachesize = hdcachesize) > 0) { + needbytes = 0; /* figure out memory needs */ for (i = n; i--; ) - if ((bp = hb[i].h->bl[hb[i].b]) != NULL) { - bp->tick = hdclock; /* preempt swap */ - bytesloaded += bp->nrm; - } else /* prepare to load */ - needbytes += hb[i].h->bi[hb[i].b].nrd; - bytesloaded *= sizeof(RAYVAL); + needbytes += hb[i].h->bi[hb[i].b].nrd; needbytes *= sizeof(RAYVAL); do { /* free enough memory */ memuse = hdmemuse(0); - bytes2free = needbytes - (signed)(hdcachesize-memuse); - if (bytes2free > (signed)(memuse - bytesloaded)) + bytes2free = needbytes - (int)(hdcachesize-memuse); + if (bytes2free > (int)(memuse - bytesloaded)) bytes2free = memuse - bytesloaded; } while (bytes2free > 0 && hdfreecache(100*bytes2free/memuse, NULL) < 0); + hdcachesize = 0; /* load beams w/o swap */ } - hdcachesize = 0; /* load the ordered beams w/o swap */ for (i = 0; i < n; i++) if ((bp = hdgetbeam(hb[i].h, hb[i].b)) != NULL && bf != NULL) - (*bf)(bp, hb[i].h, hb[i].b); + (*bf)(bp, hb+i); hdcachesize = origcachesize; /* resume dynamic swapping */ } int -hdsyncbeam(hp, i) /* sync beam in memory with beam on disk */ -register HOLO *hp; -register int i; +hdfreefrag(hp, i) /* free a file fragment */ +HOLO *hp; +int i; { - unsigned int nrays; - long nfo; - unsigned int n; - /* check file status */ - if (hdfrag[hp->fd].writerr) - return(-1); -#ifdef DEBUG - if (i < 1 | i > nbeams(hp)) - error(CONSISTENCY, "bad beam index in hdsyncbeam"); -#endif - /* is current fragment OK? */ - if (hp->bl[i] == NULL || (nrays = hp->bl[i]->nrm) == hp->bi[i].nrd) - return(0); - /* locate fragment */ - if (hp->fd >= nhdfrags || !hdfrag[hp->fd].nlinks) /* untracked */ - hp->bi[i].fo = lseek(hp->fd, 0L, 2); + register BEAMI *bi = &hp->bi[i]; + register struct fraglist *f; + register int j, k; - else if (hp->bi[i].fo + hp->bi[i].nrd*sizeof(RAYVAL) == - hdfrag[hp->fd].flen) /* EOF special case */ - hdfrag[hp->fd].flen = (nfo=hp->bi[i].fo) + nrays*sizeof(RAYVAL); - - else { /* general case */ - register struct fragment *f = &hdfrag[hp->fd]; - register int j, k; - /* relinquish old fragment */ - if (hp->bi[i].nrd) { - j = f->nfrags++; -#if MAXFRAG - if (j >= MAXFRAG-1) - f->nfrags--; -#endif - if (j % FRAGBLK == 0) { /* more frag. space */ - if (f->fi == NULL) - f->fi = (BEAMI *)malloc( - FRAGBLK*sizeof(BEAMI)); - else - f->fi = (BEAMI *)realloc((char *)f->fi, - (j+FRAGBLK)*sizeof(BEAMI)); - if (f->fi == NULL) - error(SYSTEM, - "out of memory in hdsyncbeam"); - } - for ( ; ; j--) { /* insert in descending list */ - if (!j || hp->bi[i].fo < f->fi[j-1].fo) { - f->fi[j].fo = hp->bi[i].fo; - f->fi[j].nrd = hp->bi[i].nrd; - break; - } - copystruct(f->fi+j, f->fi+(j-1)); - } - /* coalesce adjacent fragments */ - if (j && f->fi[j-1].fo == f->fi[j].fo + - f->fi[j].nrd*sizeof(RAYVAL)) { - f->fi[j].nrd += f->fi[j-1].nrd; - f->fi[j-1].nrd = 0; - } - if (j+1 < f->nfrags && f->fi[j].fo == f->fi[j+1].fo + - f->fi[j+1].nrd*sizeof(RAYVAL)) { - f->fi[j+1].nrd += f->fi[j].nrd; - f->fi[j].nrd = 0; - } - } - k = -1; /* find closest-sized fragment */ - for (j = (nrays ? f->nfrags : 0); j-- > 0; ) - if (f->fi[j].nrd >= nrays && - (k < 0 || f->fi[j].nrd < f->fi[k].nrd)) - if (f->fi[k=j].nrd == nrays) - break; - if (k < 0) { /* no fragment -- extend file */ - nfo = f->flen; - f->flen += nrays*sizeof(RAYVAL); - } else { /* else use fragment */ - nfo = f->fi[k].fo; - f->fi[k].fo += nrays*sizeof(RAYVAL); - f->fi[k].nrd -= nrays; - } - /* delete empty remnants */ + if (bi->nrd <= 0) + return(0); + DCHECK(hp->fd < 0 | hp->fd >= nhdfragls || !hdfragl[hp->fd].nlinks, + CONSISTENCY, "bad file descriptor in hdfreefrag"); + f = &hdfragl[hp->fd]; + if (!f->writable) + return(0); + if (f->nfrags % FRAGBLK == 0) { /* delete empty remnants */ for (j = k = 0; k < f->nfrags; j++, k++) { while (f->fi[k].nrd == 0) if (++k >= f->nfrags) @@ -493,21 +556,148 @@ register int i; endloop: f->nfrags = j; } - if (nrays) { /* write the new fragment */ + j = f->nfrags++; /* allocate a slot in free list */ +#if MAXFRAGB + if (j >= MAXFRAGB*FRAGBLK) { + f->nfrags = j--; /* stop list growth */ + if (bi->nrd <= f->fi[j].nrd) + return(0); /* new one no better than discard */ + } +#endif + if (j % FRAGBLK == 0) { /* more (or less) free list space */ + register BEAMI *newp; + if (f->fi == NULL) + newp = (BEAMI *)malloc((j+FRAGBLK)*sizeof(BEAMI)); + else + newp = (BEAMI *)realloc((void *)f->fi, + (j+FRAGBLK)*sizeof(BEAMI)); + if (newp == NULL) { + f->nfrags--; /* graceful failure */ + return(0); + } + f->fi = newp; + } + for ( ; ; j--) { /* insert in descending list */ + if (!j || bi->fo < f->fi[j-1].fo) { + f->fi[j].fo = bi->fo; + f->fi[j].nrd = bi->nrd; + break; + } + copystruct(f->fi+j, f->fi+(j-1)); + } + /* coalesce adjacent fragments */ + /* successors never empty */ + if (j && f->fi[j-1].fo == f->fi[j].fo + f->fi[j].nrd*sizeof(RAYVAL)) { + f->fi[j].nrd += f->fi[j-1].nrd; + f->fi[j-1].nrd = 0; + } + for (k = j+1; k < f->nfrags; k++) /* get non-empty predecessor */ + if (f->fi[k].nrd) { + if (f->fi[j].fo == f->fi[k].fo + + f->fi[k].nrd*sizeof(RAYVAL)) { + f->fi[k].nrd += f->fi[j].nrd; + f->fi[j].nrd = 0; + } + break; + } + biglob(hp)->nrd -= bi->nrd; /* tell fragment it's free */ + bi->nrd = 0; + bi->fo = 0L; + hdmarkdirty(hp, i); /* assume we'll reallocate */ + return(1); +} + + +int +hdfragOK(fd, listlen, listsiz) /* get fragment list status for file */ +int fd; +int *listlen; +register int4 *listsiz; +{ + register struct fraglist *f; + register int i; + + if (fd < 0 | fd >= nhdfragls || !(f = &hdfragl[fd])->nlinks) + return(0); /* listless */ + if (listlen != NULL) + *listlen = f->nfrags; + if (listsiz != NULL) + for (i = f->nfrags, *listsiz = 0; i--; ) + *listsiz += f->fi[i].nrd; +#if MAXFRAGB + return(f->nfrags < MAXFRAGB*FRAGBLK); +#else + return(1); /* list never fills up */ +#endif +} + + +long +hdallocfrag(fd, nrays) /* allocate a file fragment */ +int fd; +unsigned int4 nrays; +{ + register struct fraglist *f; + register int j; + long nfo; + + if (nrays == 0) + return(-1L); + DCHECK(fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks, + CONSISTENCY, "bad file descriptor in hdallocfrag"); + f = &hdfragl[fd]; + for (j = f->nfrags; j-- > 0; ) /* first fit algorithm */ + if (f->fi[j].nrd >= nrays) + break; + if (j < 0) { /* no fragment -- extend file */ + nfo = f->flen; + f->flen += nrays*sizeof(RAYVAL); + } else { /* else use fragment */ + nfo = f->fi[j].fo; + f->fi[j].fo += nrays*sizeof(RAYVAL); + f->fi[j].nrd -= nrays; + } + return(nfo); +} + + +int +hdsyncbeam(hp, i) /* sync beam in memory with beam on disk */ +register HOLO *hp; +register int i; +{ + int fragfreed; + unsigned int4 nrays; + unsigned int n; + long nfo; + /* check file status */ + if (hdfragl[hp->fd].writable <= 0) + return(hdfragl[hp->fd].writable); + DCHECK(i < 1 | i > nbeams(hp), + CONSISTENCY, "bad beam index in hdsyncbeam"); + /* is current fragment OK? */ + if (hp->bl[i] == NULL || (nrays = hp->bl[i]->nrm) == hp->bi[i].nrd) + return(0); + /* relinquish old fragment? */ + fragfreed = hdfragflags&FF_WRITE && hp->bi[i].nrd && hdfreefrag(hp,i); + if (nrays) { /* get and write new fragment */ + nfo = hdallocfrag(hp->fd, nrays); errno = 0; - if (lseek(hp->fd, nfo, 0) < 0) + if (lseek(hp->fd, (off_t)nfo, 0) < 0) error(SYSTEM, "cannot seek on holodeck file"); n = hp->bl[i]->nrm * sizeof(RAYVAL); if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) { - hdfrag[hp->fd].writerr++; - hdsync(hp, 0); /* sync directory */ + hdfragl[hp->fd].writable = -1; + hdsync(NULL, 0); /* sync directories */ error(SYSTEM, "write error in hdsyncbeam"); } - } + hp->bi[i].fo = nfo; + } else + hp->bi[i].fo = 0L; biglob(hp)->nrd += nrays - hp->bi[i].nrd; hp->bi[i].nrd = nrays; - hp->bi[i].fo = nfo; - markdirty(hp); /* section directory now out of date */ + if (!fragfreed) + hdmarkdirty(hp, i); /* need to flag dir. ent. */ return(1); } @@ -525,19 +715,21 @@ register int i; nchanged += hdfreebeam(hdlist[i], 0); return(nchanged); } - if (hdfrag[hp->fd].writerr) /* check for file error */ + if (hdfragl[hp->fd].writable < 0) /* check for file error */ return(0); if (i == 0) { /* clear entire holodeck */ + if (blglob(hp)->nrm == 0) + return(0); /* already clear */ nchanged = 0; for (i = nbeams(hp); i > 0; i--) if (hp->bl[i] != NULL) nchanged += hdfreebeam(hp, i); + DCHECK(blglob(hp)->nrm != 0, + CONSISTENCY, "bad beam count in hdfreebeam"); return(nchanged); } -#ifdef DEBUG - if (i < 1 | i > nbeams(hp)) - error(CONSISTENCY, "bad beam index to hdfreebeam"); -#endif + DCHECK(i < 1 | i > nbeams(hp), + CONSISTENCY, "bad beam index to hdfreebeam"); if (hp->bl[i] == NULL) return(0); /* check for additions */ @@ -545,7 +737,7 @@ register int i; if (nchanged) hdsyncbeam(hp, i); /* write new fragment */ blglob(hp)->nrm -= hp->bl[i]->nrm; - free((char *)hp->bl[i]); /* free memory */ + free((void *)hp->bl[i]); /* free memory */ hp->bl[i] = NULL; return(nchanged); } @@ -556,7 +748,6 @@ hdkillbeam(hp, i) /* delete beam from holodeck */ register HOLO *hp; register int i; { - static BEAM emptybeam; int nchanged; if (hp == NULL) { /* clobber all holodecks */ @@ -566,30 +757,33 @@ register int i; return(nchanged); } if (i == 0) { /* clobber entire holodeck */ + if (biglob(hp)->nrd == 0 & blglob(hp)->nrm == 0) + return(0); /* already empty */ nchanged = 0; + nchanged = 0; for (i = nbeams(hp); i > 0; i--) if (hp->bi[i].nrd > 0 || hp->bl[i] != NULL) nchanged += hdkillbeam(hp, i); -#ifdef DEBUG - if (biglob(hp)->nrd != 0 | blglob(hp)->nrm != 0) - error(CONSISTENCY, "bad beam count in hdkillbeam"); -#endif + DCHECK(biglob(hp)->nrd != 0 | blglob(hp)->nrm != 0, + CONSISTENCY, "bad beam count in hdkillbeam"); return(nchanged); } -#ifdef DEBUG - if (i < 1 | i > nbeams(hp)) - error(CONSISTENCY, "bad beam index to hdkillbeam"); -#endif + DCHECK(i < 1 | i > nbeams(hp), CONSISTENCY, + "bad beam index to hdkillbeam"); + DCHECK(!hdfragl[hp->fd].writable, CONSISTENCY, + "hdkillbeam called on read-only holodeck"); if (hp->bl[i] != NULL) { /* free memory */ blglob(hp)->nrm -= nchanged = hp->bl[i]->nrm; - free((char *)hp->bl[i]); + free((void *)hp->bl[i]); + hp->bl[i] = NULL; } else nchanged = hp->bi[i].nrd; - if (hp->bi[i].nrd) { /* free file fragment */ - hp->bl[i] = &emptybeam; - hdsyncbeam(hp, i); + if (hp->bi[i].nrd && !(hdfragflags&FF_KILL && hdfreefrag(hp,i))) { + biglob(hp)->nrd -= hp->bi[i].nrd; /* free failed */ + hp->bi[i].nrd = 0; + hp->bi[i].fo = 0L; + hdmarkdirty(hp, i); } - hp->bl[i] = NULL; return(nchanged); } @@ -603,7 +797,7 @@ register HOLO *hp; /* section we're adding from */ { register int i, j; /* insert each beam from hp */ - for (i = nbeams(hp); i > 0; i--) { + for (i = 1; i <= nbeams(hp); i++) { if (hp->bl[i] == NULL) /* check if loaded */ continue; #if 0 @@ -635,6 +829,11 @@ register HOLO *honly; /* NULL means check all */ int freetarget; int n; register int i; +#ifdef DEBUG + unsigned membefore; + + membefore = hdmemuse(0); +#endif /* compute free target */ freetarget = (honly != NULL) ? blglob(honly)->nrm : hdmemuse(0)/sizeof(RAYVAL) ; @@ -655,6 +854,12 @@ register HOLO *honly; /* NULL means check all */ break; } hdsync(honly, 0); /* synchronize directories as necessary */ +#ifdef DEBUG + sprintf(errmsg, + "%dK before, %dK after hdfreecache (%dK total), %d rays short\n", + membefore>>10, hdmemuse(0)>>10, hdmemuse(1)>>10, freetarget); + wputs(errmsg); +#endif return(-freetarget); /* return how far past goal we went */ } @@ -667,6 +872,8 @@ register HOLO *hp; /* NULL means clean up all */ if (hp == NULL) { /* NULL means clean up everything */ while (hdlist[0] != NULL) hddone(hdlist[0]); + free((void *)hdfragl); + hdfragl = NULL; nhdfragls = 0; return; } /* flush all data and free memory */ @@ -680,6 +887,6 @@ register HOLO *hp; /* NULL means clean up all */ i++; break; } - free((char *)hp->bl); /* free beam list */ - free((char *)hp); /* free holodeck struct */ + free((void *)hp->bl); /* free beam list */ + free((void *)hp); /* free holodeck struct */ }
