--- ray/src/hd/holofile.c 1997/12/12 21:29:34 3.13 +++ ray/src/hd/holofile.c 1997/12/18 15:12:23 3.14 @@ -31,7 +31,7 @@ static char SCCSid[] = "$SunId$ SGI"; #define FRAGBLK 64 /* number of fragments to allocate at a time */ -int hdcachesize = CACHESIZE*1024*1024; /* target cache size (bytes) */ +unsigned hdcachesize = CACHESIZE*1024*1024; /* target cache size */ unsigned long hdclock; /* clock value */ HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */ @@ -193,7 +193,7 @@ int all; } -long +unsigned hdmemuse(all) /* return memory usage (in bytes) */ int all; /* include overhead (painful) */ { @@ -308,8 +308,8 @@ int nr; /* number of new rays desired */ p = hdbray(hp->bl[i]) + hp->bl[i]->nrm; hp->bl[i]->nrm += nr; /* update in-core structure */ bzero((char *)p, nr*sizeof(RAYVAL)); - hp->bl[i]->tick = ++hdclock; /* update LRU clock */ - blglob(hp)->tick = hdclock; + hp->bl[i]->tick = hdclock; /* update LRU clock */ + blglob(hp)->tick = hdclock++; return(p); /* point to new rays */ memerr: error(SYSTEM, "out of memory in hdnewrays"); @@ -340,13 +340,68 @@ register int i; if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) error(SYSTEM, "error reading beam from holodeck file"); } - hp->bl[i]->tick = ++hdclock; /* update LRU clock */ - blglob(hp)->tick = hdclock; + hp->bl[i]->tick = hdclock; /* update LRU clock */ + blglob(hp)->tick = hdclock++; return(hp->bl[i]); } int +hdfilord(hb1, hb2) /* order beams for optimal loading */ +register HDBEAMI *hb1, *hb2; +{ + register int c; + /* sort by file descriptor first */ + if ((c = hb1->h->fd - hb2->h->fd)) + return(c); + /* then by position in file */ + return(hb1->h->bi[hb1->b].fo - hb2->h->bi[hb2->b].fo); +} + + +hdloadbeams(hb, n, bf) /* load a list of beams in optimal order */ +register HDBEAMI *hb; /* list gets sorted by hdfilord() */ +int n; /* list length */ +int (*bf)(); /* callback function (optional) */ +{ + unsigned origcachesize, memuse; + register BEAM *bp; + int bytesloaded, needbytes, bytes2free; + register int i; + /* precheck consistency */ + for (i = n; i--; ) + if (hb[i].h == NULL || hb[i].b < 1 | hb[i].b > nbeams(hb[i].h)) + error(CONSISTENCY, "bad beam in hdloadbeams"); + /* sort list for optimal access */ + qsort((char *)hb, n, sizeof(HDBEAMI), hdfilord); + if ((origcachesize = hdcachesize) == 0) + goto loadbeams; + bytesloaded = needbytes = 0; /* figure out memory needs */ + for (i = 0; i < n; i++) + if ((bp = hb[i].h->bl[hb[i].b]) != NULL) { + bp->tick = hdclock; /* preempt swap */ + bytesloaded += bp->nrm; + } else /* prepare to load */ + needbytes += hb[i].h->bi[hb[i].b].nrd; + bytesloaded *= sizeof(RAYVAL); + needbytes *= sizeof(RAYVAL); + do { /* free enough memory */ + memuse = hdmemuse(0); + bytes2free = needbytes - (signed)(hdcachesize-memuse); + if (bytes2free > (signed)(memuse - bytesloaded)) + bytes2free = memuse - bytesloaded; + } while (bytes2free > 0 && + hdfreecache(100*bytes2free/memuse, NULL) < 0); +loadbeams: + hdcachesize = 0; /* load the ordered beams w/o swap */ + for (i = 0; i < n; i++) + if ((bp = hdgetbeam(hb[i].h, hb[i].b)) != NULL && bf != NULL) + (*bf)(bp, hb[i].h, hb[i].b); + hdcachesize = origcachesize; /* resume dynamic swapping */ +} + + +int hdsyncbeam(hp, i) /* sync beam in memory with beam on disk */ register HOLO *hp; register int i; @@ -399,7 +454,7 @@ register int i; f->fi[j].nrd = hp->bi[i].nrd; break; } - copystruct(f->fi+j, f->fi+j-1); + copystruct(f->fi+j, f->fi+(j-1)); } /* coalesce adjacent fragments */ for (j = k = 0; k < f->nfrags; j++, k++) { @@ -429,7 +484,7 @@ register int i; if (f->fi[k].nrd == nrays) { /* delete fragment */ f->nfrags--; for (j = k; j < f->nfrags; j++) - copystruct(f->fi+j, f->fi+j+1); + copystruct(f->fi+j, f->fi+(j+1)); } else { /* else shrink it */ f->fi[k].fo += nrays*sizeof(RAYVAL); f->fi[k].nrd -= nrays; @@ -537,67 +592,68 @@ register int i; } -hdlrulist(ha, ba, n, hp) /* add beams from holodeck to LRU list */ -register HOLO *ha[]; /* section list (NULL terminated) */ -register int ba[]; /* beam index to go with section */ -int n; /* length of arrays minus 1 */ +int +hdlrulist(hb, nents, n, hp) /* add beams from holodeck to LRU list */ +register HDBEAMI *hb; /* beam list */ +int nents; /* current list length */ +int n; /* maximum list length */ register HOLO *hp; /* section we're adding from */ { register int i, j; - int nents; - /* find last entry in LRU list */ - for (j = 0; ha[j] != NULL; j++) - ; - nents = j; /* insert each beam from hp */ for (i = nbeams(hp); i > 0; i--) { if (hp->bl[i] == NULL) /* check if loaded */ continue; - if ((j = ++nents) > n) /* grow list if we can */ +#if 0 + if (hp->bl[i]->tick == hdclock) /* preempt swap? */ + continue; +#endif + if ((j = ++nents) >= n) /* grow list if we can */ nents--; for ( ; ; ) { /* bubble into place */ if (!--j || hp->bl[i]->tick >= - ha[j-1]->bl[ba[j-1]]->tick) { - ha[j] = hp; - ba[j] = i; + hb[j-1].h->bl[hb[j-1].b]->tick) { + hb[j].h = hp; + hb[j].b = i; break; } - ha[j] = ha[j-1]; - ba[j] = ba[j-1]; + copystruct(hb+j, hb+(j-1)); } } - ha[nents] = NULL; /* all done */ - ba[nents] = 0; + return(nents); /* return new list length */ } +int hdfreecache(pct, honly) /* free up cache space, writing changes */ int pct; /* maximum percentage to free */ register HOLO *honly; /* NULL means check all */ { - HOLO *hp[FREEBEAMS+1]; - int bn[FREEBEAMS+1]; + HDBEAMI hb[FREEBEAMS]; int freetarget; + int n; register int i; /* compute free target */ freetarget = (honly != NULL) ? blglob(honly)->nrm : hdmemuse(0)/sizeof(RAYVAL) ; freetarget = freetarget*pct/100; + if (freetarget <= 0) + return(0); /* find least recently used */ - hp[0] = NULL; - bn[0] = 0; + n = 0; if (honly != NULL) - hdlrulist(hp, bn, FREEBEAMS, honly); + n = hdlrulist(hb, n, FREEBEAMS, honly); else for (i = 0; hdlist[i] != NULL; i++) - hdlrulist(hp, bn, FREEBEAMS, hdlist[i]); + n = hdlrulist(hb, n, FREEBEAMS, hdlist[i]); /* free LRU beams */ - for (i = 0; hp[i] != NULL; i++) { - hdfreebeam(hp[i], bn[i]); - if ((freetarget -= hp[i]->bi[bn[i]].nrd) <= 0) + for (i = 0; i < n; i++) { + hdfreebeam(hb[i].h, hb[i].b); + if ((freetarget -= hb[i].h->bi[hb[i].b].nrd) <= 0) break; } hdsync(honly, 0); /* synchronize directories as necessary */ + return(-freetarget); /* return how far past goal we went */ }
