--- ray/src/hd/holofile.c 1997/11/05 17:28:49 3.5 +++ ray/src/hd/holofile.c 1997/12/12 21:29:34 3.13 @@ -22,8 +22,13 @@ static char SCCSid[] = "$SunId$ SGI"; #define PCTFREE 20 /* maximum fraction to free (%) */ #endif -#define MAXFRAG (128*FRAGBLK) /* maximum fragments per file */ +/* define MAXFRAG if you want to limit fragment tracking memory */ +#ifndef BSD +#define write writebuf /* safe i/o routines */ +#define read readbuf +#endif + #define FRAGBLK 64 /* number of fragments to allocate at a time */ int hdcachesize = CACHESIZE*1024*1024; /* target cache size (bytes) */ @@ -33,7 +38,8 @@ HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term static struct fragment { short nlinks; /* number of holodeck sections using us */ - short nfrags; /* number of known fragments */ + short writerr; /* write error encountered */ + int nfrags; /* number of known fragments */ BEAMI *fi; /* fragments, descending file position */ long flen; /* last known file length */ } *hdfrag; /* fragment lists, indexed by file descriptor */ @@ -68,7 +74,7 @@ register int fd; hdrelease(fd) /* stop tracking file fragments for some section */ register int fd; { - if (fd >= nhdfrags || !hdfrag[fd].nlinks) + if (fd < 0 | fd >= nhdfrags || !hdfrag[fd].nlinks) return; if (!--hdfrag[fd].nlinks && hdfrag[fd].nfrags) { free((char *)hdfrag[fd].fi); @@ -78,6 +84,21 @@ register int fd; } +markdirty(hp) /* mark holodeck section directory dirty */ +register HOLO *hp; +{ + static BEAMI smudge = {0, -1}; + + if (hp->dirty) /* already marked? */ + return; + hp->dirty = 1; + if (lseek(hp->fd, biglob(hp)->fo+(nbeams(hp)-1)*sizeof(BEAMI), 0) < 0 + || write(hp->fd, (char *)&smudge, + sizeof(BEAMI)) != sizeof(BEAMI)) + error(SYSTEM, "seek/write error in markdirty"); +} + + HOLO * hdinit(fd, hproto) /* initialize a holodeck section in a file */ int fd; /* corresponding file descriptor */ @@ -102,6 +123,9 @@ HDGRID *hproto; /* holodeck section grid */ n = nbeams(hp)*sizeof(BEAMI); if (read(fd, (char *)(hp->bi+1), n) != n) error(SYSTEM, "failure loading holodeck directory"); + /* check that it's clean */ + if (hp->bi[nbeams(hp)].fo < 0) + error(USER, "dirty holodeck section"); } else { /* assume we're creating it */ if ((hp = hdalloc(hproto)) == NULL) goto memerr; @@ -115,17 +139,23 @@ HDGRID *hproto; /* holodeck section grid */ hp->fd = fd; hp->dirty = 0; biglob(hp)->fo = fpos + sizeof(HDGRID); - biglob(hp)->nrd = 0; /* count rays on disk */ - for (n = nbeams(hp); n > 0; n--) - biglob(hp)->nrd += hp->bi[n].nrd; + /* start tracking fragments */ + hdattach(fd); + /* check rays on disk */ + fpos = hdfilen(fd); + biglob(hp)->nrd = 0; + for (n = hproto == NULL ? nbeams(hp) : 0; n > 0; n--) + if (hp->bi[n].nrd) + if (hp->bi[n].fo + hp->bi[n].nrd > fpos) + hp->bi[n].nrd = 0; /* off end */ + else + biglob(hp)->nrd += hp->bi[n].nrd; /* add to holodeck list */ for (n = 0; n < HDMAX; n++) if (hdlist[n] == NULL) { hdlist[n] = hp; break; } - /* start tracking fragments (last) */ - hdattach(fd); /* all done */ return(hp); memerr: @@ -134,18 +164,23 @@ memerr: int -hdsync(hp) /* update directory on disk if necessary */ +hdsync(hp, all) /* update beams and directory on disk */ register HOLO *hp; +int all; { register int j, n; - if (hp == NULL) { /* do all */ + if (hp == NULL) { /* do all holodecks */ n = 0; for (j = 0; hdlist[j] != NULL; j++) - n += hdsync(hdlist[j]); + n += hdsync(hdlist[j], all); return(n); } - if (!hp->dirty) /* check first */ + /* sync the beams */ + for (j = all ? nbeams(hp) : 0; j > 0; j--) + if (hp->bl[j] != NULL) + hdsyncbeam(hp, j); + if (!hp->dirty) /* directory clean? */ return(0); errno = 0; if (lseek(hp->fd, biglob(hp)->fo, 0) < 0) @@ -188,6 +223,25 @@ int all; /* include overhead (painful) */ long +hdfilen(fd) /* return file length for fd */ +int fd; +{ + long fpos, flen; + + if (fd < 0) + return(-1); + if (fd >= nhdfrags || !hdfrag[fd].nlinks) { + if ((fpos = lseek(fd, 0L, 1)) < 0) + return(-1); + flen = lseek(fd, 0L, 2); + lseek(fd, fpos, 0); + return(flen); + } + return(hdfrag[fd].flen); +} + + +long hdfiluse(fd, all) /* compute file usage (in bytes) */ int fd; /* open file descriptor to check */ int all; /* include overhead and unflushed data */ @@ -293,21 +347,30 @@ register int i; int -hdgetbi(hp, i) /* allocate a file fragment */ +hdsyncbeam(hp, i) /* sync beam in memory with beam on disk */ register HOLO *hp; register int i; { - int nrays = hp->bl[i]->nrm; - - if (hp->bi[i].nrd == nrays) /* current one will do? */ + unsigned int nrays; + long nfo; + unsigned int n; + /* check file status */ + if (hdfrag[hp->fd].writerr) + return(-1); +#ifdef DEBUG + if (i < 1 | i > nbeams(hp)) + error(CONSISTENCY, "bad beam index in hdsyncbeam"); +#endif + /* is current fragment OK? */ + if (hp->bl[i] == NULL || (nrays = hp->bl[i]->nrm) == hp->bi[i].nrd) return(0); - + /* locate fragment */ if (hp->fd >= nhdfrags || !hdfrag[hp->fd].nlinks) /* untracked */ hp->bi[i].fo = lseek(hp->fd, 0L, 2); else if (hp->bi[i].fo + hp->bi[i].nrd*sizeof(RAYVAL) == hdfrag[hp->fd].flen) /* EOF special case */ - hdfrag[hp->fd].flen = hp->bi[i].fo + nrays*sizeof(RAYVAL); + hdfrag[hp->fd].flen = (nfo=hp->bi[i].fo) + nrays*sizeof(RAYVAL); else { /* general case */ register struct fragment *f = &hdfrag[hp->fd]; @@ -328,7 +391,7 @@ register int i; (j+FRAGBLK)*sizeof(BEAMI)); if (f->fi == NULL) error(SYSTEM, - "out of memory in hdgetbi"); + "out of memory in hdsyncbeam"); } for ( ; ; j--) { /* insert in descending list */ if (!j || hp->bi[i].fo < f->fi[j-1].fo) { @@ -353,16 +416,16 @@ register int i; f->nfrags = j; } k = -1; /* find closest-sized fragment */ - for (j = f->nfrags; j-- > 0; ) + for (j = nrays ? f->nfrags : 0; j-- > 0; ) if (f->fi[j].nrd >= nrays && (k < 0 || f->fi[j].nrd < f->fi[k].nrd)) if (f->fi[k=j].nrd == nrays) break; if (k < 0) { /* no fragment -- extend file */ - hp->bi[i].fo = f->flen; + nfo = f->flen; f->flen += nrays*sizeof(RAYVAL); } else { /* else use fragment */ - hp->bi[i].fo = f->fi[k].fo; + nfo = f->fi[k].fo; if (f->fi[k].nrd == nrays) { /* delete fragment */ f->nfrags--; for (j = k; j < f->nfrags; j++) @@ -373,9 +436,21 @@ register int i; } } } + if (nrays) { /* write the new fragment */ + errno = 0; + if (lseek(hp->fd, nfo, 0) < 0) + error(SYSTEM, "cannot seek on holodeck file"); + n = hp->bl[i]->nrm * sizeof(RAYVAL); + if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) { + hdfrag[hp->fd].writerr++; + hdsync(hp, 0); /* sync directory */ + error(SYSTEM, "write error in hdsyncbeam"); + } + } biglob(hp)->nrd += nrays - hp->bi[i].nrd; hp->bi[i].nrd = nrays; - hp->dirty++; /* section directory now out of date */ + hp->bi[i].fo = nfo; + markdirty(hp); /* section directory now out of date */ return(1); } @@ -385,7 +460,7 @@ hdfreebeam(hp, i) /* free beam, writing if dirty */ register HOLO *hp; register int i; { - int nchanged, n; + int nchanged; if (hp == NULL) { /* clear all holodecks */ nchanged = 0; @@ -393,27 +468,25 @@ register int i; nchanged += hdfreebeam(hdlist[i], 0); return(nchanged); } + if (hdfrag[hp->fd].writerr) /* check for file error */ + return(0); if (i == 0) { /* clear entire holodeck */ nchanged = 0; - for (i = 1; i <= nbeams(hp); i++) - nchanged += hdfreebeam(hp, i); + for (i = nbeams(hp); i > 0; i--) + if (hp->bl[i] != NULL) + nchanged += hdfreebeam(hp, i); return(nchanged); } +#ifdef DEBUG if (i < 1 | i > nbeams(hp)) error(CONSISTENCY, "bad beam index to hdfreebeam"); +#endif if (hp->bl[i] == NULL) return(0); /* check for additions */ nchanged = hp->bl[i]->nrm - hp->bi[i].nrd; - if (nchanged) { - hdgetbi(hp, i); /* allocate a file position */ - errno = 0; - if (lseek(hp->fd, hp->bi[i].fo, 0) < 0) - error(SYSTEM, "cannot seek on holodeck file"); - n = hp->bl[i]->nrm * sizeof(RAYVAL); - if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) - error(SYSTEM, "write error in hdfreebeam"); - } + if (nchanged) + hdsyncbeam(hp, i); /* write new fragment */ blglob(hp)->nrm -= hp->bl[i]->nrm; free((char *)hp->bl[i]); /* free memory */ hp->bl[i] = NULL; @@ -421,6 +494,49 @@ register int i; } +int +hdkillbeam(hp, i) /* delete beam from holodeck */ +register HOLO *hp; +register int i; +{ + static BEAM emptybeam; + int nchanged; + + if (hp == NULL) { /* clobber all holodecks */ + nchanged = 0; + for (i = 0; hdlist[i] != NULL; i++) + nchanged += hdkillbeam(hdlist[i], 0); + return(nchanged); + } + if (i == 0) { /* clobber entire holodeck */ + nchanged = 0; + for (i = nbeams(hp); i > 0; i--) + if (hp->bi[i].nrd > 0 || hp->bl[i] != NULL) + nchanged += hdkillbeam(hp, i); +#ifdef DEBUG + if (biglob(hp)->nrd != 0 | blglob(hp)->nrm != 0) + error(CONSISTENCY, "bad beam count in hdkillbeam"); +#endif + return(nchanged); + } +#ifdef DEBUG + if (i < 1 | i > nbeams(hp)) + error(CONSISTENCY, "bad beam index to hdkillbeam"); +#endif + if (hp->bl[i] != NULL) { /* free memory */ + blglob(hp)->nrm -= nchanged = hp->bl[i]->nrm; + free((char *)hp->bl[i]); + } else + nchanged = hp->bi[i].nrd; + if (hp->bi[i].nrd) { /* free file fragment */ + hp->bl[i] = &emptybeam; + hdsyncbeam(hp, i); + } + hp->bl[i] = NULL; + return(nchanged); +} + + hdlrulist(ha, ba, n, hp) /* add beams from holodeck to LRU list */ register HOLO *ha[]; /* section list (NULL terminated) */ register int ba[]; /* beam index to go with section */ @@ -434,7 +550,7 @@ register HOLO *hp; /* section we're adding from */ ; nents = j; /* insert each beam from hp */ - for (i = nbeams(hp); i > 0; i-- ) { + for (i = nbeams(hp); i > 0; i--) { if (hp->bl[i] == NULL) /* check if loaded */ continue; if ((j = ++nents) > n) /* grow list if we can */ @@ -481,7 +597,7 @@ register HOLO *honly; /* NULL means check all */ if ((freetarget -= hp[i]->bi[bn[i]].nrd) <= 0) break; } - hdsync(honly); /* synchronize directories as necessary */ + hdsync(honly, 0); /* synchronize directories as necessary */ }
