root/Development/ray/src/hd/holofile.c
Revision: 3.61
Committed: Fri Oct 5 19:19:16 2018 UTC (7 years, 1 month ago) by greg
CVS Tags: rad5R4, rad5R3, rad5R2
Changes since 3.60: +58 -58 lines
2 static const char RCSid[] = "$Id: holofile.c,v 3.60 2016/03/06 01:13:17 schorsch Exp $";
5 * Routines for managing holodeck files
6 *
7 * 9/30/97 GWLarson
8 */
9
10 #include "copyright.h"
11
12 #include <string.h>
13
14 #include "platform.h"
15 #include "rtprocess.h"
16
17 #include "holo.h"
18
19 #ifndef CACHESIZE
20 #ifdef SMLMEM
21 #define CACHESIZE 10
22 #else
23 #define CACHESIZE 100 /* default cache size (Mbytes, 0==inf) */
24 #endif
25 #endif
26 #ifndef FREEBEAMS
27 #define FREEBEAMS 1500 /* maximum beams to free at a time */
28 #endif
29 #ifndef PCTFREE
30 #define PCTFREE 15 /* maximum fraction to free (%) */
31 #endif
32 #ifndef MAXFRAGB
33 #define MAXFRAGB 64 /* fragment blocks/file to track (0==inf) */
34 #endif
35 #ifndef FF_DEFAULT
36 /* when to free a beam fragment */
37 #define FF_DEFAULT (FF_WRITE|FF_KILL)
38 #endif
39 #ifndef MINDIRSEL
40 /* minimum directory seek length */
41 #define MINDIRSEL (4*BUFSIZ/sizeof(BEAMI))
42 #endif
43
44 #ifndef BSD
45 #ifdef write /* platform.h renames those for Windows */
46 #undef write
47 #endif
48 #define write writebuf /* safe i/o routines */
49 #ifdef read
50 #undef read
51 #endif
52 #define read readbuf
53 #endif
54
55 #define FRAGBLK 512 /* number of fragments to allocate at a time */
56
57 int hdfragflags = FF_DEFAULT; /* tells when to free fragments */
58 unsigned hdcachesize = CACHESIZE*1024*1024; /* target cache size */
59 unsigned long hdclock; /* clock value */
60
61 HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */
62
63 static struct fraglist {
64 short nlinks; /* number of holodeck sections using us */
65 short writable; /* 0 read-only, <0 write error encountered */
66 int nfrags; /* number of known fragments */
67 BEAMI *fi; /* fragments, descending file position */
68 off_t flen; /* last known file length */
69 } *hdfragl; /* fragment lists, indexed by file descriptor */
70
71 static int nhdfragls; /* size of hdfragl array */
72
73 static HOLO *hdalloc(HDGRID *hproto);
74 static char *hdrealloc(char *ptr, unsigned siz, char *rout);
75 static void hdattach(int fd, int wr);
76 static void hdrelease(int fd);
77 static void hdmarkdirty(HOLO *hp, int i);
78 static unsigned int hdmemuse(int all);
79 static int hdfilord(const void *hb1, const void *hb2);
80 static off_t hdallocfrag(int fd, uint32 nrays);
81 static int hdsyncbeam(HOLO *hp, int i);
82 static int hdlrulist(HDBEAMI *hb, int nents, int n, HOLO *hp);
83 static int hdfreecache(int pct, HOLO *honly);
84
85
86
87 HOLO *
88 hdalloc( /* allocate and set holodeck section based on grid */
89 HDGRID *hproto
90 )
91 {
92 HOLO hdhead;
93 HOLO *hp;
94 int n;
95 /* copy grid to temporary header */
96 memcpy((void *)&hdhead, (void *)hproto, sizeof(HDGRID));
97 /* compute grid vectors and sizes */
98 hdcompgrid(&hdhead);
99 /* allocate header with directory */
100 n = sizeof(HOLO)+nbeams(&hdhead)*sizeof(BEAMI);
101 if ((hp = (HOLO *)malloc(n)) == NULL)
102 return(NULL);
103 /* copy header information */
104 *hp = hdhead;
105 /* allocate and clear beam list */
106 hp->bl = (BEAM **)malloc((nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM));
107 if (hp->bl == NULL) {
108 free((void *)hp);
109 return(NULL);
110 }
111 memset((void *)hp->bl, '\0', (nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM));
112 hp->bl[0] = (BEAM *)(hp->bl+nbeams(hp)+1); /* set blglob(hp) */
113 hp->fd = -1;
114 hp->dirty = 0;
115 hp->priv = NULL;
116 /* clear beam directory */
117 memset((void *)hp->bi, '\0', (nbeams(hp)+1)*sizeof(BEAMI));
118 return(hp); /* all is well */
119 }
120
121
122 char *
123 hdrealloc( /* (re)allocate memory, retry then error */
124 char *ptr,
125 unsigned siz,
126 char *rout
127 )
128 {
129 char *newp;
130 /* call malloc/realloc */
131 if (ptr == NULL) newp = (char *)malloc(siz);
132 else newp = (char *)realloc((void *)ptr, siz);
133 /* check success */
134 if (newp == NULL && rout != NULL) {
135 hdfreecache(25, NULL); /* free some memory */
136 errno = 0; /* retry */
137 newp = hdrealloc(ptr, siz, NULL);
138 if (newp == NULL) { /* give up and report error */
139 sprintf(errmsg, "out of memory in %s", rout);
140 error(SYSTEM, errmsg);
141 }
142 }
143 return(newp);
144 }
145
146
147 void
148 hdattach( /* start tracking file fragments for some section */
149 int fd,
150 int wr
151 )
152 {
153 if (fd >= nhdfragls) {
154 hdfragl = (struct fraglist *)hdrealloc((char *)hdfragl,
155 (fd+1)*sizeof(struct fraglist), "hdattach");
156 memset((void *)(hdfragl+nhdfragls),
157 '\0', (fd+1-nhdfragls)*sizeof(struct fraglist));
158 nhdfragls = fd+1;
159 }
160 hdfragl[fd].nlinks++;
161 hdfragl[fd].writable = wr; /* set writable flag */
162 /* get file length */
163 hdfragl[fd].flen = lseek(fd, (off_t)0, SEEK_END);
164 }
165
166
167 /* Do we need a routine to locate file fragments given known occupants? */
168
169
170 void
171 hdrelease( /* stop tracking file fragments for some section */
172 int fd
173 )
174 {
175 if ((fd < 0) | (fd >= nhdfragls) || !hdfragl[fd].nlinks)
176 return;
177 if (!--hdfragl[fd].nlinks && hdfragl[fd].nfrags) {
178 free((void *)hdfragl[fd].fi);
179 hdfragl[fd].fi = NULL;
180 hdfragl[fd].nfrags = 0;
181 }
182 }
183
184
185 HOLO *
186 hdinit( /* initialize a holodeck section in a file */
187 int fd, /* corresponding file descriptor */
188 HDGRID *hproto /* holodeck section grid */
189 )
190 {
191 off_t rtrunc;
192 off_t fpos;
193 int writable;
194 HOLO *hp;
195 int n;
196 /* prepare for system errors */
197 errno = 0;
198 if ((fpos = lseek(fd, (off_t)0, SEEK_CUR)) < 0)
199 error(SYSTEM, "cannot determine holodeck file position");
200 if (hproto == NULL) { /* assume we're loading it */
201 HDGRID hpr;
202 /* load header */
203 if (read(fd, (char *)&hpr, sizeof(HDGRID)) != sizeof(HDGRID))
204 error(SYSTEM, "cannot load holodeck header");
205 /* allocate grid */
206 if ((hp = hdalloc(&hpr)) == NULL)
207 goto memerr;
208 /* load beam directory */
209 n = nbeams(hp)*sizeof(BEAMI);
210 if (read(fd, (char *)(hp->bi+1), n) != n)
211 error(SYSTEM, "failure loading holodeck directory");
212 /* check that it's clean */
213 for (n = nbeams(hp); n > 0; n--)
214 if (hp->bi[n].fo < 0) {
215 hp->bi[n].fo = 0;
216 error(WARNING, "dirty holodeck section");
217 break;
218 }
219 /* check writability */
220 if (fd < nhdfragls && hdfragl[fd].nlinks)
221 writable = hdfragl[fd].writable;
222 else
223 writable = lseek(fd, fpos, SEEK_SET) == fpos &&
224 write(fd, (char *)hp, sizeof(HDGRID)) ==
225 sizeof(HDGRID);
226 } else { /* else assume we're creating it */
227 if ((hp = hdalloc(hproto)) == NULL)
228 goto memerr;
229 /* write header and skeleton */
230 n = nbeams(hp)*sizeof(BEAMI);
231 if (write(fd, (char *)hproto, sizeof(HDGRID)) !=
232 sizeof(HDGRID) ||
233 write(fd, (char *)(hp->bi+1), n) != n)
234 error(SYSTEM, "cannot write header to holodeck file");
235 writable = 1;
236 }
237 hp->fd = fd;
238 hp->dirty = 0;
239 biglob(hp)->fo = fpos + sizeof(HDGRID);
240 /* start tracking fragments */
241 hdattach(fd, writable);
242 /* check rays on disk */
243 fpos = hdfilen(fd);
244 biglob(hp)->nrd = rtrunc = 0;
245 for (n = hproto == NULL ? nbeams(hp) : 0; n > 0; n--)
246 if (hp->bi[n].nrd) {
247 if (hp->bi[n].fo+hp->bi[n].nrd*sizeof(RAYVAL) > fpos) {
248 rtrunc += hp->bi[n].nrd;
249 hp->bi[n].nrd = 0;
250 } else
251 biglob(hp)->nrd += hp->bi[n].nrd;
252 }
253 if (rtrunc) {
254 sprintf(errmsg, "truncated section, %ld rays lost (%.1f%%)",
255 (long)rtrunc,
256 100.*rtrunc/(rtrunc+biglob(hp)->nrd));
257 error(WARNING, errmsg);
258 }
259 /* add to holodeck list */
260 for (n = 0; n < HDMAX; n++)
261 if (hdlist[n] == NULL) {
262 hdlist[n] = hp;
263 break;
264 }
265 /* all done */
266 return(hp);
267 memerr:
268 error(SYSTEM, "cannot allocate holodeck grid");
269 return NULL; /* pro forma return */
270 }
271
272
273 void
274 hdmarkdirty( /* mark holodeck directory position dirty */
275 HOLO *hp,
276 int i
277 )
278 {
279 static BEAMI smudge = {0, -1};
280 int mindist, minpos;
281 int j;
282
283 if (!hp->dirty++) { /* write smudge first time */
284 if (lseek(hp->fd, biglob(hp)->fo+(i-1)*sizeof(BEAMI),
285 SEEK_SET) < 0 ||
286 write(hp->fd, (char *)&smudge,
287 sizeof(BEAMI)) != sizeof(BEAMI))
288 error(SYSTEM, "seek/write error in hdmarkdirty");
289 hp->dirseg[0].s = i;
290 hp->dirseg[0].n = 1;
291 return;
292 }
293 /* insert into segment list */
294 for (j = hp->dirty; j--; ) {
295 if (!j || hp->dirseg[j-1].s < i) {
296 hp->dirseg[j].s = i;
297 hp->dirseg[j].n = 1;
298 break;
299 }
300 *(hp->dirseg+j) = *(hp->dirseg+(j-1));
301 }
302 do { /* check neighbors */
303 mindist = nbeams(hp); /* find closest */
304 for (j = hp->dirty; --j; )
305 if (hp->dirseg[j].s -
306 (hp->dirseg[j-1].s + hp->dirseg[j-1].n)
307 < mindist) {
308 minpos = j;
309 mindist = hp->dirseg[j].s -
310 (hp->dirseg[j-1].s + hp->dirseg[j-1].n);
311 }
312 /* good enough? */
313 if (hp->dirty <= MAXDIRSE && mindist > MINDIRSEL)
314 break;
315 j = minpos - 1; /* coalesce neighbors */
316 if (hp->dirseg[j].s + hp->dirseg[j].n <
317 hp->dirseg[minpos].s + hp->dirseg[minpos].n)
318 hp->dirseg[j].n = hp->dirseg[minpos].s +
319 hp->dirseg[minpos].n - hp->dirseg[j].s;
320 hp->dirty--;
321 while (++j < hp->dirty) /* close the gap */
322 *(hp->dirseg+j) = *(hp->dirseg+(j+1));
323 } while (mindist <= MINDIRSEL);
324 }
325
326
327 int
328 hdsync( /* update beams and directory on disk */
329 HOLO *hp,
330 int all
331 )
332 {
333 int j, n;
334
335 if (hp == NULL) { /* do all holodecks */
336 n = 0;
337 for (j = 0; hdlist[j] != NULL; j++)
338 n += hdsync(hdlist[j], all);
339 return(n);
340 }
341 /* sync the beams */
342 for (j = (all ? nbeams(hp) : 0); j > 0; j--)
343 if (hp->bl[j] != NULL)
344 hdsyncbeam(hp, j);
345 if (!hp->dirty) /* directory clean? */
346 return(0);
347 errno = 0; /* write dirty segments */
348 for (j = 0; j < hp->dirty; j++) {
349 if (lseek(hp->fd, biglob(hp)->fo +
350 (hp->dirseg[j].s-1)*sizeof(BEAMI), SEEK_SET) < 0)
351 error(SYSTEM, "cannot seek on holodeck file");
352 n = hp->dirseg[j].n * sizeof(BEAMI);
353 if (write(hp->fd, (char *)(hp->bi+hp->dirseg[j].s), n) != n)
354 error(SYSTEM, "cannot update section directory");
355 }
356 hp->dirty = 0; /* all clean */
357 return(1);
358 }
359
360
361 unsigned int
362 hdmemuse( /* return memory usage (in bytes) */
363 int all /* include overhead (painful) */
364 )
365 {
366 long total = 0;
367 int i, j;
368
369 for (j = 0; hdlist[j] != NULL; j++) {
370 total += blglob(hdlist[j])->nrm * sizeof(RAYVAL);
371 if (all) {
372 total += sizeof(HOLO) + sizeof(BEAM *) +
373 nbeams(hdlist[j]) *
374 (sizeof(BEAM *)+sizeof(BEAMI));
375 for (i = nbeams(hdlist[j]); i > 0; i--)
376 if (hdlist[j]->bl[i] != NULL)
377 total += sizeof(BEAM);
378 }
379 }
380 if (all)
381 for (j = 0; j < nhdfragls; j++) {
382 total += sizeof(struct fraglist);
383 if (hdfragl[j].nfrags)
384 total += FRAGBLK*sizeof(BEAMI) *
385 ((hdfragl[j].nfrags-1)/FRAGBLK + 1) ;
386 }
387 return(total);
388 }
389
390
391 off_t
392 hdfilen( /* return file length for fd */
393 int fd
394 )
395 {
396 off_t fpos, flen;
397
398 if (fd < 0)
399 return(-1);
400 if (fd >= nhdfragls || !hdfragl[fd].nlinks) {
401 if ((fpos = lseek(fd, (off_t)0, SEEK_CUR)) < 0)
402 return(-1);
403 flen = lseek(fd, (off_t)0, SEEK_END);
404 lseek(fd, fpos, SEEK_SET);
405 return(flen);
406 }
407 return(hdfragl[fd].flen);
408 }
409
410
411 off_t
412 hdfiluse( /* compute file usage (in bytes) */
413 int fd /* open file descriptor to check */
414 )
415 {
416 off_t total = 0;
417 int j;
418
419 for (j = 0; hdlist[j] != NULL; j++) {
420 if (hdlist[j]->fd != fd)
421 continue;
422 total += biglob(hdlist[j])->nrd * sizeof(RAYVAL);
423 total += nbeams(hdlist[j])*sizeof(BEAMI) + sizeof(HDGRID);
424 #if 0
425 for (i = nbeams(hdlist[j]); i > 0; i--)
426 if (hdlist[j]->bl[i] != NULL)
427 total += sizeof(RAYVAL) *
428 (hdlist[j]->bl[i]->nrm -
429 hdlist[j]->bi[i].nrd);
430 #endif
431 }
432 return(total); /* doesn't include fragments, unflushed rays */
433 }
434
435
436 RAYVAL *
437 hdnewrays( /* allocate space for add'l rays and return pointer */
438 HOLO *hp,
439 int i,
440 int nr /* number of new rays desired */
441 )
442 {
443 RAYVAL *p;
444 int n;
445
446 if (nr <= 0) return(NULL);
447 CHECK((i < 1) | (i > nbeams(hp)),
448 CONSISTENCY, "bad beam index given to hdnewrays");
449 if (hp->bl[i] != NULL)
450 hp->bl[i]->tick = hdclock; /* preempt swap */
451 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
452 hdfreecache(PCTFREE, NULL); /* free some space */
453 if (hp->bl[i] == NULL) { /* allocate (and load) */
454 n = hp->bi[i].nrd + nr;
455 hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdnewrays");
456 blglob(hp)->nrm += n;
457 if ((n = hp->bl[i]->nrm = hp->bi[i].nrd)) {
458 errno = 0;
459 if (lseek(hp->fd, hp->bi[i].fo, SEEK_SET) < 0)
460 error(SYSTEM, "seek error on holodeck file");
461 n *= sizeof(RAYVAL);
462 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
463 error(SYSTEM,
464 "error reading beam from holodeck file");
465 }
466 } else { /* just grow in memory */
467 hp->bl[i] = (BEAM *)hdrealloc((char *)hp->bl[i],
468 hdbsiz(hp->bl[i]->nrm + nr), "hdnewrays");
469 blglob(hp)->nrm += nr;
470 }
471 if (hdfragflags&FF_ALLOC && hp->bi[i].nrd)
472 hdfreefrag(hp, i); /* relinquish old fragment */
473 p = hdbray(hp->bl[i]) + hp->bl[i]->nrm;
474 hp->bl[i]->nrm += nr; /* update in-core structure */
475 memset((void *)p, '\0', nr*sizeof(RAYVAL));
476 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
477 return(p); /* point to new rays */
478 }
479
480
481 BEAM *
482 hdgetbeam( /* get beam (from file if necessary) */
483 HOLO *hp,
484 int i
485 )
486 {
487 int n;
488
489 CHECK((i < 1) | (i > nbeams(hp)),
490 CONSISTENCY, "bad beam index given to hdgetbeam");
491 if (hp->bl[i] == NULL) { /* load from disk */
492 if (!(n = hp->bi[i].nrd))
493 return(NULL);
494 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
495 hdfreecache(PCTFREE, NULL); /* get free space */
496 hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdgetbeam");
497 blglob(hp)->nrm += hp->bl[i]->nrm = n;
498 errno = 0;
499 if (lseek(hp->fd, hp->bi[i].fo, SEEK_SET) < 0)
500 error(SYSTEM, "seek error on holodeck file");
501 n *= sizeof(RAYVAL);
502 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
503 error(SYSTEM, "error reading beam from holodeck file");
504 if (hdfragflags&FF_READ)
505 hdfreefrag(hp, i); /* relinquish old frag. */
506 }
507 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
508 return(hp->bl[i]);
509 }
510
511
512 int
513 hdfilord( /* order beams for quick loading */
514 const void *hb1,
515 const void *hb2
516 )
517 {
518 off_t c;
519 /* residents go first */
520 if (((HDBEAMI*)hb2)->h->bl[((HDBEAMI*)hb2)->b] != NULL)
521 return(((HDBEAMI*)hb1)->h->bl[((HDBEAMI*)hb1)->b] == NULL);
522 if (((HDBEAMI*)hb1)->h->bl[((HDBEAMI*)hb1)->b] != NULL)
523 return(-1);
524 /* otherwise sort by file descriptor */
525 if (((HDBEAMI*)hb1)->h->fd != ((HDBEAMI*)hb2)->h->fd)
526 return(((HDBEAMI*)hb1)->h->fd - ((HDBEAMI*)hb2)->h->fd);
527 /* then by position in file */
528 c = ((HDBEAMI*)hb1)->h->bi[((HDBEAMI*)hb1)->b].fo
529 - ((HDBEAMI*)hb2)->h->bi[((HDBEAMI*)hb2)->b].fo;
530 return(c > 0 ? 1 : c < 0 ? -1 : 0);
531 }
532
533
534 void
535 hdloadbeams( /* load a list of beams in optimal order */
536 HDBEAMI *hb, /* list gets sorted by hdfilord() */
537 int n, /* list length */
538 void (*bf)(BEAM *bp, HDBEAMI *hb) /* callback function (optional) */
539 )
540 {
541 unsigned origcachesize, memuse;
542 int bytesloaded, needbytes, bytes2free;
543 BEAM *bp;
544 int i;
545 /* precheck consistency */
546 if (n <= 0) return;
547 for (i = n; i--; )
548 if (hb[i].h==NULL || (hb[i].b<1) | (hb[i].b>nbeams(hb[i].h)))
549 error(CONSISTENCY, "bad beam in hdloadbeams");
550 /* sort list for optimal access */
551 qsort((void *)hb, n, sizeof(HDBEAMI), hdfilord);
552 bytesloaded = 0; /* run through loaded beams */
553 for ( ; n && (bp = hb->h->bl[hb->b]) != NULL; n--, hb++) {
554 bp->tick = hdclock; /* preempt swap */
555 bytesloaded += bp->nrm;
556 if (bf != NULL)
557 (*bf)(bp, hb);
558 }
559 bytesloaded *= sizeof(RAYVAL);
560 if ((origcachesize = hdcachesize) > 0) {
561 needbytes = 0; /* figure out memory needs */
562 for (i = n; i--; )
563 needbytes += hb[i].h->bi[hb[i].b].nrd;
564 needbytes *= sizeof(RAYVAL);
565 do { /* free enough memory */
566 memuse = hdmemuse(0);
567 bytes2free = needbytes - (int)(hdcachesize-memuse);
568 if (bytes2free > (int)(memuse - bytesloaded))
569 bytes2free = memuse - bytesloaded;
570 } while (bytes2free > 0 &&
571 hdfreecache(100*bytes2free/memuse, NULL) < 0);
572 hdcachesize = 0; /* load beams w/o swap */
573 }
574 for (i = 0; i < n; i++)
575 if ((bp = hdgetbeam(hb[i].h, hb[i].b)) != NULL && bf != NULL)
576 (*bf)(bp, hb+i);
577 hdcachesize = origcachesize; /* resume dynamic swapping */
578 }
579
580
581 int
582 hdfreefrag( /* free a file fragment */
583 HOLO *hp,
584 int i
585 )
586 {
587 BEAMI *bi = &hp->bi[i];
588 struct fraglist *f;
589 int j, k;
590
591 if (bi->nrd <= 0)
592 return(0);
593 DCHECK(hp->fd < 0 | hp->fd >= nhdfragls || !hdfragl[hp->fd].nlinks,
594 CONSISTENCY, "bad file descriptor in hdfreefrag");
595 f = &hdfragl[hp->fd];
596 if (!f->writable)
597 return(0);
598 if (f->nfrags % FRAGBLK == 0) { /* delete empty remnants */
599 for (j = k = 0; k < f->nfrags; j++, k++) {
600 while (f->fi[k].nrd == 0)
601 if (++k >= f->nfrags)
602 goto endloop;
603 if (k > j)
604 *(f->fi+j) = *(f->fi+k);
605 }
606 endloop:
607 f->nfrags = j;
608 }
609 j = f->nfrags++; /* allocate a slot in free list */
610 #if MAXFRAGB
611 if (j >= MAXFRAGB*FRAGBLK) {
612 f->nfrags = j--; /* stop list growth */
613 if (bi->nrd <= f->fi[j].nrd)
614 return(0); /* new one no better than discard */
615 }
616 #endif
617 if (j % FRAGBLK == 0) { /* more (or less) free list space */
618 BEAMI *newp;
619 if (f->fi == NULL)
620 newp = (BEAMI *)malloc((j+FRAGBLK)*sizeof(BEAMI));
621 else
622 newp = (BEAMI *)realloc((void *)f->fi,
623 (j+FRAGBLK)*sizeof(BEAMI));
624 if (newp == NULL) {
625 f->nfrags--; /* graceful failure */
626 return(0);
627 }
628 f->fi = newp;
629 }
630 for ( ; ; j--) { /* insert in descending list */
631 if (!j || bi->fo < f->fi[j-1].fo) {
632 f->fi[j].fo = bi->fo;
633 f->fi[j].nrd = bi->nrd;
634 break;
635 }
636 *(f->fi+j) = *(f->fi+(j-1));
637 }
638 /* coalesce adjacent fragments */
639 /* successors never empty */
640 if (j && f->fi[j-1].fo == f->fi[j].fo + f->fi[j].nrd*sizeof(RAYVAL)) {
641 f->fi[j].nrd += f->fi[j-1].nrd;
642 f->fi[j-1].nrd = 0;
643 }
644 for (k = j+1; k < f->nfrags; k++) /* get non-empty predecessor */
645 if (f->fi[k].nrd) {
646 if (f->fi[j].fo == f->fi[k].fo +
647 f->fi[k].nrd*sizeof(RAYVAL)) {
648 f->fi[k].nrd += f->fi[j].nrd;
649 f->fi[j].nrd = 0;
650 }
651 break;
652 }
653 biglob(hp)->nrd -= bi->nrd; /* tell fragment it's free */
654 bi->nrd = 0;
655 bi->fo = 0;
656 hdmarkdirty(hp, i); /* assume we'll reallocate */
657 return(1);
658 }
659
660
661 int
662 hdfragOK( /* get fragment list status for file */
663 int fd,
664 int *listlen,
665 int32 *listsiz
666 )
667 {
668 struct fraglist *f;
669 int i;
670
671 if ((fd < 0) | (fd >= nhdfragls) || !(f = &hdfragl[fd])->nlinks)
672 return(0); /* listless */
673 if (listlen != NULL)
674 *listlen = f->nfrags;
675 if (listsiz != NULL)
676 for (i = f->nfrags, *listsiz = 0; i--; )
677 *listsiz += f->fi[i].nrd;
678 #if MAXFRAGB
679 return(f->nfrags < MAXFRAGB*FRAGBLK);
680 #else
681 return(1); /* list never fills up */
682 #endif
683 }
684
685
686 off_t
687 hdallocfrag( /* allocate a file fragment */
688 int fd,
689 uint32 nrays
690 )
691 {
692 struct fraglist *f;
693 int j;
694 off_t nfo;
695
696 if (nrays == 0)
697 return(-1L);
698 DCHECK(fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks,
699 CONSISTENCY, "bad file descriptor in hdallocfrag");
700 f = &hdfragl[fd];
701 for (j = f->nfrags; j-- > 0; ) /* first fit algorithm */
702 if (f->fi[j].nrd >= nrays)
703 break;
704 if (j < 0) { /* no fragment -- extend file */
705 nfo = f->flen;
706 f->flen += nrays*sizeof(RAYVAL);
707 } else { /* else use fragment */
708 nfo = f->fi[j].fo;
709 f->fi[j].fo += nrays*sizeof(RAYVAL);
710 f->fi[j].nrd -= nrays;
711 }
712 return(nfo);
713 }
714
715
716 int
717 hdsyncbeam( /* sync beam in memory with beam on disk */
718 HOLO *hp,
719 int i
720 )
721 {
722 int fragfreed;
723 uint32 nrays;
724 unsigned int n;
725 off_t nfo;
726 /* check file status */
727 if (hdfragl[hp->fd].writable <= 0)
728 return(hdfragl[hp->fd].writable);
729 DCHECK(i < 1 | i > nbeams(hp),
730 CONSISTENCY, "bad beam index in hdsyncbeam");
731 /* is current fragment OK? */
732 if (hp->bl[i] == NULL || (nrays = hp->bl[i]->nrm) == hp->bi[i].nrd)
733 return(0);
734 /* relinquish old fragment? */
735 fragfreed = hdfragflags&FF_WRITE && hp->bi[i].nrd && hdfreefrag(hp,i);
736 if (nrays) { /* get and write new fragment */
737 nfo = hdallocfrag(hp->fd, nrays);
738 errno = 0;
739 if (lseek(hp->fd, nfo, SEEK_SET) < 0)
740 error(SYSTEM, "cannot seek on holodeck file");
741 n = hp->bl[i]->nrm * sizeof(RAYVAL);
742 if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) {
743 hdfragl[hp->fd].writable = -1;
744 hdsync(NULL, 0); /* sync directories */
745 error(SYSTEM, "write error in hdsyncbeam");
746 }
747 hp->bi[i].fo = nfo;
748 } else
749 hp->bi[i].fo = 0;
750 biglob(hp)->nrd += nrays - hp->bi[i].nrd;
751 hp->bi[i].nrd = nrays;
752 if (!fragfreed)
753 hdmarkdirty(hp, i); /* need to flag dir. ent. */
754 return(1);
755 }
756
757
758 int
759 hdfreebeam( /* free beam, writing if dirty */
760 HOLO *hp,
761 int i
762 )
763 {
764 int nchanged;
765
766 if (hp == NULL) { /* clear all holodecks */
767 nchanged = 0;
768 for (i = 0; hdlist[i] != NULL; i++)
769 nchanged += hdfreebeam(hdlist[i], 0);
770 return(nchanged);
771 }
772 if (hdfragl[hp->fd].writable < 0) /* check for file error */
773 return(0);
774 if (i == 0) { /* clear entire holodeck */
775 if (blglob(hp)->nrm == 0)
776 return(0); /* already clear */
777 nchanged = 0;
778 for (i = nbeams(hp); i > 0; i--)
779 if (hp->bl[i] != NULL)
780 nchanged += hdfreebeam(hp, i);
781 DCHECK(blglob(hp)->nrm != 0,
782 CONSISTENCY, "bad beam count in hdfreebeam");
783 return(nchanged);
784 }
785 DCHECK(i < 1 | i > nbeams(hp),
786 CONSISTENCY, "bad beam index to hdfreebeam");
787 if (hp->bl[i] == NULL)
788 return(0);
789 /* check for additions */
790 nchanged = hp->bl[i]->nrm - hp->bi[i].nrd;
791 if (nchanged)
792 hdsyncbeam(hp, i); /* write new fragment */
793 blglob(hp)->nrm -= hp->bl[i]->nrm;
794 free((void *)hp->bl[i]); /* free memory */
795 hp->bl[i] = NULL;
796 return(nchanged);
797 }
798
799
800 int
801 hdkillbeam( /* delete beam from holodeck */
802 HOLO *hp,
803 int i
804 )
805 {
806 int nchanged;
807
808 if (hp == NULL) { /* clobber all holodecks */
809 nchanged = 0;
810 for (i = 0; hdlist[i] != NULL; i++)
811 nchanged += hdkillbeam(hdlist[i], 0);
812 return(nchanged);
813 }
814 if (i == 0) { /* clobber entire holodeck */
815 if ((biglob(hp)->nrd == 0) & (blglob(hp)->nrm == 0))
816 return(0); /* already empty */
817 nchanged = 0;
818 nchanged = 0;
819 for (i = nbeams(hp); i > 0; i--)
820 if (hp->bi[i].nrd > 0 || hp->bl[i] != NULL)
821 nchanged += hdkillbeam(hp, i);
822 DCHECK(biglob(hp)->nrd != 0 | blglob(hp)->nrm != 0,
823 CONSISTENCY, "bad beam count in hdkillbeam");
824 return(nchanged);
825 }
826 DCHECK(i < 1 | i > nbeams(hp), CONSISTENCY,
827 "bad beam index to hdkillbeam");
828 DCHECK(!hdfragl[hp->fd].writable, CONSISTENCY,
829 "hdkillbeam called on read-only holodeck");
830 if (hp->bl[i] != NULL) { /* free memory */
831 blglob(hp)->nrm -= nchanged = hp->bl[i]->nrm;
832 free((void *)hp->bl[i]);
833 hp->bl[i] = NULL;
834 } else
835 nchanged = hp->bi[i].nrd;
836 if (hp->bi[i].nrd && !(hdfragflags&FF_KILL && hdfreefrag(hp,i))) {
837 biglob(hp)->nrd -= hp->bi[i].nrd; /* free failed */
838 hp->bi[i].nrd = 0;
839 hp->bi[i].fo = 0;
840 hdmarkdirty(hp, i);
841 }
842 return(nchanged);
843 }
844
845
846 int
847 hdlrulist( /* add beams from holodeck to LRU list */
848 HDBEAMI *hb, /* beam list */
849 int nents, /* current list length */
850 int n, /* maximum list length */
851 HOLO *hp /* section we're adding from */
852 )
853 {
854 int i, j;
855 /* insert each beam from hp */
856 for (i = 1; i <= nbeams(hp); i++) {
857 if (hp->bl[i] == NULL) /* check if loaded */
858 continue;
859 #if 0
860 if (hp->bl[i]->tick == hdclock) /* preempt swap? */
861 continue;
862 #endif
863 if ((j = ++nents) >= n) /* grow list if we can */
864 nents--;
865 for ( ; ; ) { /* bubble into place */
866 if (!--j || hp->bl[i]->tick >=
867 hb[j-1].h->bl[hb[j-1].b]->tick) {
868 hb[j].h = hp;
869 hb[j].b = i;
870 break;
871 }
872 *(hb+j) = *(hb+(j-1));
873 }
874 }
875 return(nents); /* return new list length */
876 }
877
878
879 int
880 hdfreecache( /* free up cache space, writing changes */
881 int pct, /* maximum percentage to free */
882 HOLO *honly /* NULL means check all */
883 )
884 {
885 HDBEAMI hb[FREEBEAMS];
886 int freetarget;
887 int n;
888 int i;
889 #ifdef DEBUG
890 unsigned membefore;
891
892 membefore = hdmemuse(0);
893 #endif
894 /* compute free target */
895 freetarget = (honly != NULL) ? blglob(honly)->nrm :
896 hdmemuse(0)/sizeof(RAYVAL) ;
897 freetarget = freetarget*pct/100;
898 if (freetarget <= 0)
899 return(0);
900 /* find least recently used */
901 n = 0;
902 if (honly != NULL)
903 n = hdlrulist(hb, n, FREEBEAMS, honly);
904 else
905 for (i = 0; hdlist[i] != NULL; i++)
906 n = hdlrulist(hb, n, FREEBEAMS, hdlist[i]);
907 /* free LRU beams */
908 for (i = 0; i < n; i++) {
909 hdfreebeam(hb[i].h, hb[i].b);
910 if ((freetarget -= hb[i].h->bi[hb[i].b].nrd) <= 0)
911 break;
912 }
913 hdsync(honly, 0); /* synchronize directories as necessary */
914 #ifdef DEBUG
915 sprintf(errmsg,
916 "%dK before, %dK after hdfreecache (%dK total), %d rays short\n",
917 membefore>>10, hdmemuse(0)>>10, hdmemuse(1)>>10, freetarget);
918 wputs(errmsg);
919 #endif
920 return(-freetarget); /* return how far past goal we went */
921 }
922
923
924 void
925 hddone( /* clean up holodeck section and free */
926 HOLO *hp /* NULL means clean up all */
927 )
928 {
929 int i;
930
931 if (hp == NULL) { /* NULL means clean up everything */
932 while (hdlist[0] != NULL)
933 hddone(hdlist[0]);
934 free((void *)hdfragl);
935 hdfragl = NULL; nhdfragls = 0;
936 return;
937 }
938 /* flush all data and free memory */
939 hdflush(hp);
940 /* release fragment resources */
941 hdrelease(hp->fd);
942 /* remove hp from active list */
943 for (i = 0; hdlist[i] != NULL; i++)
944 if (hdlist[i] == hp) {
945 while ((hdlist[i] = hdlist[i+1]) != NULL)
946 i++;
947 break;
948 }
949 free((void *)hp->bl); /* free beam list */
950 free((void *)hp); /* free holodeck struct */
951 }
