root/radiance/ray/src/hd/holofile.c
Revision: 3.49
Committed: Mon Jun 30 14:59:11 2003 UTC (22 years ago) by schorsch
Changes since 3.48: +11 -7 lines
2 static const char RCSid[] = "$Id: holofile.c,v 3.48 2003/06/20 00:25:49 greg Exp $";
5 * Routines for managing holodeck files
6 *
7 * 9/30/97 GWLarson
8 */
9
10 #include "copyright.h"
11
12 #include <string.h>
13
14 #include "holo.h"
15
16 #ifndef CACHESIZE
17 #ifdef SMLMEM
18 #define CACHESIZE 5
19 #else
20 #define CACHESIZE 17 /* default cache size (Mbytes, 0==inf) */
21 #endif
22 #endif
23 #ifndef FREEBEAMS
24 #define FREEBEAMS 1500 /* maximum beams to free at a time */
25 #endif
26 #ifndef PCTFREE
27 #define PCTFREE 15 /* maximum fraction to free (%) */
28 #endif
29 #ifndef MAXFRAGB
30 #define MAXFRAGB 16 /* fragment blocks/file to track (0==inf) */
31 #endif
32 #ifndef FF_DEFAULT
33 /* when to free a beam fragment */
34 #define FF_DEFAULT (FF_WRITE|FF_KILL)
35 #endif
36 #ifndef MINDIRSEL
37 /* minimum directory seek length */
38 #define MINDIRSEL (4*BUFSIZ/sizeof(BEAMI))
39 #endif
40
41 #ifndef BSD
42 #define write writebuf /* safe i/o routines */
43 #define read readbuf
44 #endif
45
46 #define FRAGBLK 512 /* number of fragments to allocate at a time */
47
48 int hdfragflags = FF_DEFAULT; /* tells when to free fragments */
49 unsigned hdcachesize = CACHESIZE*1024*1024; /* target cache size */
50 unsigned long hdclock; /* clock value */
51
52 HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */
53
54 static struct fraglist {
55 short nlinks; /* number of holodeck sections using us */
56 short writable; /* 0 read-only, <0 write error encountered */
57 int nfrags; /* number of known fragments */
58 BEAMI *fi; /* fragments, descending file position */
59 off_t flen; /* last known file length */
60 } *hdfragl; /* fragment lists, indexed by file descriptor */
61
62 static int nhdfragls; /* size of hdfragl array */
63
64
65 HOLO *
66 hdalloc(hproto) /* allocate and set holodeck section based on grid */
67 HDGRID *hproto;
68 {
69 HOLO hdhead;
70 register HOLO *hp;
71 int n;
72 /* copy grid to temporary header */
73 memcpy((void *)&hdhead, (void *)hproto, sizeof(HDGRID));
74 /* compute grid vectors and sizes */
75 hdcompgrid(&hdhead);
76 /* allocate header with directory */
77 n = sizeof(HOLO)+nbeams(&hdhead)*sizeof(BEAMI);
78 if ((hp = (HOLO *)malloc(n)) == NULL)
79 return(NULL);
80 /* copy header information */
81 copystruct(hp, &hdhead);
82 /* allocate and clear beam list */
83 hp->bl = (BEAM **)malloc((nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM));
84 if (hp->bl == NULL) {
85 free((void *)hp);
86 return(NULL);
87 }
88 memset((void *)hp->bl, '\0', (nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM));
89 hp->bl[0] = (BEAM *)(hp->bl+nbeams(hp)+1); /* set blglob(hp) */
90 hp->fd = -1;
91 hp->dirty = 0;
92 hp->priv = NULL;
93 /* clear beam directory */
94 memset((void *)hp->bi, '\0', (nbeams(hp)+1)*sizeof(BEAMI));
95 return(hp); /* all is well */
96 }
97
98
99 char *
100 hdrealloc(ptr, siz, rout) /* (re)allocate memory, retry then error */
101 char *ptr;
102 unsigned siz;
103 char *rout;
104 {
105 register char *newp;
106 /* call malloc/realloc */
107 if (ptr == NULL) newp = (char *)malloc(siz);
108 else newp = (char *)realloc((void *)ptr, siz);
109 /* check success */
110 if (newp == NULL && rout != NULL) {
111 hdfreecache(25, NULL); /* free some memory */
112 errno = 0; /* retry */
113 newp = hdrealloc(ptr, siz, NULL);
114 if (newp == NULL) { /* give up and report error */
115 sprintf(errmsg, "out of memory in %s", rout);
116 error(SYSTEM, errmsg);
117 }
118 }
119 return(newp);
120 }
121
122
123 hdattach(fd, wr) /* start tracking file fragments for some section */
124 register int fd;
125 int wr;
126 {
127 if (fd >= nhdfragls) {
128 hdfragl = (struct fraglist *)hdrealloc((char *)hdfragl,
129 (fd+1)*sizeof(struct fraglist), "hdattach");
130 memset((void *)(hdfragl+nhdfragls),
131 '\0', (fd+1-nhdfragls)*sizeof(struct fraglist));
132 nhdfragls = fd+1;
133 }
134 hdfragl[fd].nlinks++;
135 hdfragl[fd].writable = wr; /* set writable flag */
136 hdfragl[fd].flen = lseek(fd, (off_t)0, 2); /* get file length */
137 }
138
139
140 /* Do we need a routine to locate file fragments given known occupants? */
141
142
143 hdrelease(fd) /* stop tracking file fragments for some section */
144 register int fd;
145 {
146 if (fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks)
147 return;
148 if (!--hdfragl[fd].nlinks && hdfragl[fd].nfrags) {
149 free((void *)hdfragl[fd].fi);
150 hdfragl[fd].fi = NULL;
151 hdfragl[fd].nfrags = 0;
152 }
153 }
154
155
156 HOLO *
157 hdinit(fd, hproto) /* initialize a holodeck section in a file */
158 int fd; /* corresponding file descriptor */
159 HDGRID *hproto; /* holodeck section grid */
160 {
161 off_t rtrunc;
162 off_t fpos;
163 int writable;
164 register HOLO *hp;
165 register int n;
166 /* prepare for system errors */
167 errno = 0;
168 if ((fpos = lseek(fd, (off_t)0, 1)) < 0)
169 error(SYSTEM, "cannot determine holodeck file position");
170 if (hproto == NULL) { /* assume we're loading it */
171 HDGRID hpr;
172 /* load header */
173 if (read(fd, (char *)&hpr, sizeof(HDGRID)) != sizeof(HDGRID))
174 error(SYSTEM, "cannot load holodeck header");
175 /* allocate grid */
176 if ((hp = hdalloc(&hpr)) == NULL)
177 goto memerr;
178 /* load beam directory */
179 n = nbeams(hp)*sizeof(BEAMI);
180 if (read(fd, (char *)(hp->bi+1), n) != n)
181 error(SYSTEM, "failure loading holodeck directory");
182 /* check that it's clean */
183 for (n = nbeams(hp); n > 0; n--)
184 if (hp->bi[n].fo < 0) {
185 hp->bi[n].fo = 0;
186 error(WARNING, "dirty holodeck section");
187 break;
188 }
189 /* check writability */
190 if (fd < nhdfragls && hdfragl[fd].nlinks)
191 writable = hdfragl[fd].writable;
192 else
193 writable = lseek(fd, fpos, 0) == fpos &&
194 write(fd, (char *)hp, sizeof(HDGRID)) ==
195 sizeof(HDGRID);
196 } else { /* else assume we're creating it */
197 if ((hp = hdalloc(hproto)) == NULL)
198 goto memerr;
199 /* write header and skeleton */
200 n = nbeams(hp)*sizeof(BEAMI);
201 if (write(fd, (char *)hproto, sizeof(HDGRID)) !=
202 sizeof(HDGRID) ||
203 write(fd, (char *)(hp->bi+1), n) != n)
204 error(SYSTEM, "cannot write header to holodeck file");
205 writable = 1;
206 }
207 hp->fd = fd;
208 hp->dirty = 0;
209 biglob(hp)->fo = fpos + sizeof(HDGRID);
210 /* start tracking fragments */
211 hdattach(fd, writable);
212 /* check rays on disk */
213 fpos = hdfilen(fd);
214 biglob(hp)->nrd = rtrunc = 0;
215 for (n = hproto == NULL ? nbeams(hp) : 0; n > 0; n--)
216 if (hp->bi[n].nrd)
217 if (hp->bi[n].fo+hp->bi[n].nrd*sizeof(RAYVAL) > fpos) {
218 rtrunc += hp->bi[n].nrd;
219 hp->bi[n].nrd = 0;
220 } else
221 biglob(hp)->nrd += hp->bi[n].nrd;
222 if (rtrunc) {
223 sprintf(errmsg, "truncated section, %ld rays lost (%.1f%%)",
224 rtrunc, 100.*rtrunc/(rtrunc+biglob(hp)->nrd));
225 error(WARNING, errmsg);
226 }
227 /* add to holodeck list */
228 for (n = 0; n < HDMAX; n++)
229 if (hdlist[n] == NULL) {
230 hdlist[n] = hp;
231 break;
232 }
233 /* all done */
234 return(hp);
235 memerr:
236 error(SYSTEM, "cannot allocate holodeck grid");
237 }
238
239
240 hdmarkdirty(hp, i) /* mark holodeck directory position dirty */
241 register HOLO *hp;
242 int i;
243 {
244 static BEAMI smudge = {0, -1};
245 int mindist, minpos;
246 register int j;
247
248 if (!hp->dirty++) { /* write smudge first time */
249 if (lseek(hp->fd, biglob(hp)->fo+(i-1)*sizeof(BEAMI), 0) < 0
250 || write(hp->fd, (char *)&smudge,
251 sizeof(BEAMI)) != sizeof(BEAMI))
252 error(SYSTEM, "seek/write error in hdmarkdirty");
253 hp->dirseg[0].s = i;
254 hp->dirseg[0].n = 1;
255 return;
256 }
257 /* insert into segment list */
258 for (j = hp->dirty; j--; ) {
259 if (!j || hp->dirseg[j-1].s < i) {
260 hp->dirseg[j].s = i;
261 hp->dirseg[j].n = 1;
262 break;
263 }
264 copystruct(hp->dirseg+j, hp->dirseg+(j-1));
265 }
266 do { /* check neighbors */
267 mindist = nbeams(hp); /* find closest */
268 for (j = hp->dirty; --j; )
269 if (hp->dirseg[j].s -
270 (hp->dirseg[j-1].s + hp->dirseg[j-1].n)
271 < mindist) {
272 minpos = j;
273 mindist = hp->dirseg[j].s -
274 (hp->dirseg[j-1].s + hp->dirseg[j-1].n);
275 }
276 /* good enough? */
277 if (hp->dirty <= MAXDIRSE && mindist > MINDIRSEL)
278 break;
279 j = minpos - 1; /* coalesce neighbors */
280 if (hp->dirseg[j].s + hp->dirseg[j].n <
281 hp->dirseg[minpos].s + hp->dirseg[minpos].n)
282 hp->dirseg[j].n = hp->dirseg[minpos].s +
283 hp->dirseg[minpos].n - hp->dirseg[j].s;
284 hp->dirty--;
285 while (++j < hp->dirty) /* close the gap */
286 copystruct(hp->dirseg+j, hp->dirseg+(j+1));
287 } while (mindist <= MINDIRSEL);
288 }
289
290
291 int
292 hdsync(hp, all) /* update beams and directory on disk */
293 register HOLO *hp;
294 int all;
295 {
296 register int j, n;
297
298 if (hp == NULL) { /* do all holodecks */
299 n = 0;
300 for (j = 0; hdlist[j] != NULL; j++)
301 n += hdsync(hdlist[j], all);
302 return(n);
303 }
304 /* sync the beams */
305 for (j = (all ? nbeams(hp) : 0); j > 0; j--)
306 if (hp->bl[j] != NULL)
307 hdsyncbeam(hp, j);
308 if (!hp->dirty) /* directory clean? */
309 return(0);
310 errno = 0; /* write dirty segments */
311 for (j = 0; j < hp->dirty; j++) {
312 if (lseek(hp->fd, biglob(hp)->fo +
313 (hp->dirseg[j].s-1)*sizeof(BEAMI), 0) < 0)
314 error(SYSTEM, "cannot seek on holodeck file");
315 n = hp->dirseg[j].n * sizeof(BEAMI);
316 if (write(hp->fd, (char *)(hp->bi+hp->dirseg[j].s), n) != n)
317 error(SYSTEM, "cannot update section directory");
318 }
319 hp->dirty = 0; /* all clean */
320 return(1);
321 }
322
323
324 unsigned
325 hdmemuse(all) /* return memory usage (in bytes) */
326 int all; /* include overhead (painful) */
327 {
328 long total = 0;
329 register int i, j;
330
331 for (j = 0; hdlist[j] != NULL; j++) {
332 total += blglob(hdlist[j])->nrm * sizeof(RAYVAL);
333 if (all) {
334 total += sizeof(HOLO) + sizeof(BEAM *) +
335 nbeams(hdlist[j]) *
336 (sizeof(BEAM *)+sizeof(BEAMI));
337 for (i = nbeams(hdlist[j]); i > 0; i--)
338 if (hdlist[j]->bl[i] != NULL)
339 total += sizeof(BEAM);
340 }
341 }
342 if (all)
343 for (j = 0; j < nhdfragls; j++) {
344 total += sizeof(struct fraglist);
345 if (hdfragl[j].nfrags)
346 total += FRAGBLK*sizeof(BEAMI) *
347 ((hdfragl[j].nfrags-1)/FRAGBLK + 1) ;
348 }
349 return(total);
350 }
351
352
353 off_t
354 hdfilen(fd) /* return file length for fd */
355 int fd;
356 {
357 off_t fpos, flen;
358
359 if (fd < 0)
360 return(-1);
361 if (fd >= nhdfragls || !hdfragl[fd].nlinks) {
362 if ((fpos = lseek(fd, (off_t)0, 1)) < 0)
363 return(-1);
364 flen = lseek(fd, (off_t)0, 2);
365 lseek(fd, fpos, 0);
366 return(flen);
367 }
368 return(hdfragl[fd].flen);
369 }
370
371
372 off_t
373 hdfiluse(fd, all) /* compute file usage (in bytes) */
374 int fd; /* open file descriptor to check */
375 int all; /* include overhead and unflushed data */
376 {
377 off_t total = 0;
378 register int i, j;
379
380 for (j = 0; hdlist[j] != NULL; j++) {
381 if (hdlist[j]->fd != fd)
382 continue;
383 total += biglob(hdlist[j])->nrd * sizeof(RAYVAL);
384 if (all) {
385 for (i = nbeams(hdlist[j]); i > 0; i--)
386 if (hdlist[j]->bl[i] != NULL)
387 total += sizeof(RAYVAL) *
388 (hdlist[j]->bl[i]->nrm -
389 hdlist[j]->bi[i].nrd);
390 total += sizeof(HDGRID) +
391 nbeams(hdlist[j])*sizeof(BEAMI);
392 }
393 }
394 return(total); /* does not include fragments */
395 }
396
397
398 RAYVAL *
399 hdnewrays(hp, i, nr) /* allocate space for add'l rays and return pointer */
400 register HOLO *hp;
401 register int i;
402 int nr; /* number of new rays desired */
403 {
404 RAYVAL *p;
405 int n;
406
407 if (nr <= 0) return(NULL);
408 CHECK(i < 1 | i > nbeams(hp),
409 CONSISTENCY, "bad beam index given to hdnewrays");
410 if (hp->bl[i] != NULL)
411 hp->bl[i]->tick = hdclock; /* preempt swap */
412 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
413 hdfreecache(PCTFREE, NULL); /* free some space */
414 if (hp->bl[i] == NULL) { /* allocate (and load) */
415 n = hp->bi[i].nrd + nr;
416 hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdnewrays");
417 blglob(hp)->nrm += n;
418 if ((n = hp->bl[i]->nrm = hp->bi[i].nrd)) {
419 errno = 0;
420 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
421 error(SYSTEM, "seek error on holodeck file");
422 n *= sizeof(RAYVAL);
423 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
424 error(SYSTEM,
425 "error reading beam from holodeck file");
426 }
427 } else { /* just grow in memory */
428 hp->bl[i] = (BEAM *)hdrealloc((char *)hp->bl[i],
429 hdbsiz(hp->bl[i]->nrm + nr), "hdnewrays");
430 blglob(hp)->nrm += nr;
431 }
432 if (hdfragflags&FF_ALLOC && hp->bi[i].nrd)
433 hdfreefrag(hp, i); /* relinquish old fragment */
434 p = hdbray(hp->bl[i]) + hp->bl[i]->nrm;
435 hp->bl[i]->nrm += nr; /* update in-core structure */
436 memset((void *)p, '\0', nr*sizeof(RAYVAL));
437 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
438 return(p); /* point to new rays */
439 }
440
441
442 BEAM *
443 hdgetbeam(hp, i) /* get beam (from file if necessary) */
444 register HOLO *hp;
445 register int i;
446 {
447 register int n;
448
449 CHECK(i < 1 | i > nbeams(hp),
450 CONSISTENCY, "bad beam index given to hdgetbeam");
451 if (hp->bl[i] == NULL) { /* load from disk */
452 if (!(n = hp->bi[i].nrd))
453 return(NULL);
454 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
455 hdfreecache(PCTFREE, NULL); /* get free space */
456 hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdgetbeam");
457 blglob(hp)->nrm += hp->bl[i]->nrm = n;
458 errno = 0;
459 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
460 error(SYSTEM, "seek error on holodeck file");
461 n *= sizeof(RAYVAL);
462 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
463 error(SYSTEM, "error reading beam from holodeck file");
464 if (hdfragflags&FF_READ)
465 hdfreefrag(hp, i); /* relinquish old frag. */
466 }
467 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
468 return(hp->bl[i]);
469 }
470
471
472 int
473 hdfilord(hb1, hb2) /* order beams for quick loading */
474 register HDBEAMI *hb1, *hb2;
475 {
476 register off_t c;
477 /* residents go first */
478 if (hb2->h->bl[hb2->b] != NULL)
479 return(hb1->h->bl[hb1->b] == NULL);
480 if (hb1->h->bl[hb1->b] != NULL)
481 return(-1);
482 /* otherwise sort by file descriptor */
483 if (hb1->h->fd != hb2->h->fd)
484 return(hb1->h->fd - hb2->h->fd);
485 /* then by position in file */
486 c = hb1->h->bi[hb1->b].fo - hb2->h->bi[hb2->b].fo;
487 return(c > 0 ? 1 : c < 0 ? -1 : 0);
488 }
489
490
491 hdloadbeams(hb, n, bf) /* load a list of beams in optimal order */
492 register HDBEAMI *hb; /* list gets sorted by hdfilord() */
493 int n; /* list length */
494 int (*bf)(); /* callback function (optional) */
495 {
496 unsigned origcachesize, memuse;
497 int bytesloaded, needbytes, bytes2free;
498 register BEAM *bp;
499 register int i;
500 /* precheck consistency */
501 if (n <= 0) return;
502 for (i = n; i--; )
503 if (hb[i].h==NULL || hb[i].b<1 | hb[i].b>nbeams(hb[i].h))
504 error(CONSISTENCY, "bad beam in hdloadbeams");
505 /* sort list for optimal access */
506 qsort((void *)hb, n, sizeof(HDBEAMI), hdfilord);
507 bytesloaded = 0; /* run through loaded beams */
508 for ( ; n && (bp = hb->h->bl[hb->b]) != NULL; n--, hb++) {
509 bp->tick = hdclock; /* preempt swap */
510 bytesloaded += bp->nrm;
511 if (bf != NULL)
512 (*bf)(bp, hb);
513 }
514 bytesloaded *= sizeof(RAYVAL);
515 if ((origcachesize = hdcachesize) > 0) {
516 needbytes = 0; /* figure out memory needs */
517 for (i = n; i--; )
518 needbytes += hb[i].h->bi[hb[i].b].nrd;
519 needbytes *= sizeof(RAYVAL);
520 do { /* free enough memory */
521 memuse = hdmemuse(0);
522 bytes2free = needbytes - (int)(hdcachesize-memuse);
523 if (bytes2free > (int)(memuse - bytesloaded))
524 bytes2free = memuse - bytesloaded;
525 } while (bytes2free > 0 &&
526 hdfreecache(100*bytes2free/memuse, NULL) < 0);
527 hdcachesize = 0; /* load beams w/o swap */
528 }
529 for (i = 0; i < n; i++)
530 if ((bp = hdgetbeam(hb[i].h, hb[i].b)) != NULL && bf != NULL)
531 (*bf)(bp, hb+i);
532 hdcachesize = origcachesize; /* resume dynamic swapping */
533 }
534
535
536 int
537 hdfreefrag(hp, i) /* free a file fragment */
538 HOLO *hp;
539 int i;
540 {
541 register BEAMI *bi = &hp->bi[i];
542 register struct fraglist *f;
543 register int j, k;
544
545 if (bi->nrd <= 0)
546 return(0);
547 DCHECK(hp->fd < 0 | hp->fd >= nhdfragls || !hdfragl[hp->fd].nlinks,
548 CONSISTENCY, "bad file descriptor in hdfreefrag");
549 f = &hdfragl[hp->fd];
550 if (!f->writable)
551 return(0);
552 if (f->nfrags % FRAGBLK == 0) { /* delete empty remnants */
553 for (j = k = 0; k < f->nfrags; j++, k++) {
554 while (f->fi[k].nrd == 0)
555 if (++k >= f->nfrags)
556 goto endloop;
557 if (k > j)
558 copystruct(f->fi+j, f->fi+k);
559 }
560 endloop:
561 f->nfrags = j;
562 }
563 j = f->nfrags++; /* allocate a slot in free list */
564 #if MAXFRAGB
565 if (j >= MAXFRAGB*FRAGBLK) {
566 f->nfrags = j--; /* stop list growth */
567 if (bi->nrd <= f->fi[j].nrd)
568 return(0); /* new one no better than discard */
569 }
570 #endif
571 if (j % FRAGBLK == 0) { /* more (or less) free list space */
572 register BEAMI *newp;
573 if (f->fi == NULL)
574 newp = (BEAMI *)malloc((j+FRAGBLK)*sizeof(BEAMI));
575 else
576 newp = (BEAMI *)realloc((void *)f->fi,
577 (j+FRAGBLK)*sizeof(BEAMI));
578 if (newp == NULL) {
579 f->nfrags--; /* graceful failure */
580 return(0);
581 }
582 f->fi = newp;
583 }
584 for ( ; ; j--) { /* insert in descending list */
585 if (!j || bi->fo < f->fi[j-1].fo) {
586 f->fi[j].fo = bi->fo;
587 f->fi[j].nrd = bi->nrd;
588 break;
589 }
590 copystruct(f->fi+j, f->fi+(j-1));
591 }
592 /* coalesce adjacent fragments */
593 /* successors never empty */
594 if (j && f->fi[j-1].fo == f->fi[j].fo + f->fi[j].nrd*sizeof(RAYVAL)) {
595 f->fi[j].nrd += f->fi[j-1].nrd;
596 f->fi[j-1].nrd = 0;
597 }
598 for (k = j+1; k < f->nfrags; k++) /* get non-empty predecessor */
599 if (f->fi[k].nrd) {
600 if (f->fi[j].fo == f->fi[k].fo +
601 f->fi[k].nrd*sizeof(RAYVAL)) {
602 f->fi[k].nrd += f->fi[j].nrd;
603 f->fi[j].nrd = 0;
604 }
605 break;
606 }
607 biglob(hp)->nrd -= bi->nrd; /* tell fragment it's free */
608 bi->nrd = 0;
609 bi->fo = 0;
610 hdmarkdirty(hp, i); /* assume we'll reallocate */
611 return(1);
612 }
613
614
615 int
616 hdfragOK(fd, listlen, listsiz) /* get fragment list status for file */
617 int fd;
618 int *listlen;
619 register int32 *listsiz;
620 {
621 register struct fraglist *f;
622 register int i;
623
624 if (fd < 0 | fd >= nhdfragls || !(f = &hdfragl[fd])->nlinks)
625 return(0); /* listless */
626 if (listlen != NULL)
627 *listlen = f->nfrags;
628 if (listsiz != NULL)
629 for (i = f->nfrags, *listsiz = 0; i--; )
630 *listsiz += f->fi[i].nrd;
631 #if MAXFRAGB
632 return(f->nfrags < MAXFRAGB*FRAGBLK);
633 #else
634 return(1); /* list never fills up */
635 #endif
636 }
637
638
639 off_t
640 hdallocfrag(fd, nrays) /* allocate a file fragment */
641 int fd;
642 uint32 nrays;
643 {
644 register struct fraglist *f;
645 register int j;
646 off_t nfo;
647
648 if (nrays == 0)
649 return(-1L);
650 DCHECK(fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks,
651 CONSISTENCY, "bad file descriptor in hdallocfrag");
652 f = &hdfragl[fd];
653 for (j = f->nfrags; j-- > 0; ) /* first fit algorithm */
654 if (f->fi[j].nrd >= nrays)
655 break;
656 if (j < 0) { /* no fragment -- extend file */
657 nfo = f->flen;
658 f->flen += nrays*sizeof(RAYVAL);
659 } else { /* else use fragment */
660 nfo = f->fi[j].fo;
661 f->fi[j].fo += nrays*sizeof(RAYVAL);
662 f->fi[j].nrd -= nrays;
663 }
664 return(nfo);
665 }
666
667
668 int
669 hdsyncbeam(hp, i) /* sync beam in memory with beam on disk */
670 register HOLO *hp;
671 register int i;
672 {
673 int fragfreed;
674 uint32 nrays;
675 unsigned int n;
676 off_t nfo;
677 /* check file status */
678 if (hdfragl[hp->fd].writable <= 0)
679 return(hdfragl[hp->fd].writable);
680 DCHECK(i < 1 | i > nbeams(hp),
681 CONSISTENCY, "bad beam index in hdsyncbeam");
682 /* is current fragment OK? */
683 if (hp->bl[i] == NULL || (nrays = hp->bl[i]->nrm) == hp->bi[i].nrd)
684 return(0);
685 /* relinquish old fragment? */
686 fragfreed = hdfragflags&FF_WRITE && hp->bi[i].nrd && hdfreefrag(hp,i);
687 if (nrays) { /* get and write new fragment */
688 nfo = hdallocfrag(hp->fd, nrays);
689 errno = 0;
690 if (lseek(hp->fd, nfo, 0) < 0)
691 error(SYSTEM, "cannot seek on holodeck file");
692 n = hp->bl[i]->nrm * sizeof(RAYVAL);
693 if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) {
694 hdfragl[hp->fd].writable = -1;
695 hdsync(NULL, 0); /* sync directories */
696 error(SYSTEM, "write error in hdsyncbeam");
697 }
698 hp->bi[i].fo = nfo;
699 } else
700 hp->bi[i].fo = 0;
701 biglob(hp)->nrd += nrays - hp->bi[i].nrd;
702 hp->bi[i].nrd = nrays;
703 if (!fragfreed)
704 hdmarkdirty(hp, i); /* need to flag dir. ent. */
705 return(1);
706 }
707
708
709 int
710 hdfreebeam(hp, i) /* free beam, writing if dirty */
711 register HOLO *hp;
712 register int i;
713 {
714 int nchanged;
715
716 if (hp == NULL) { /* clear all holodecks */
717 nchanged = 0;
718 for (i = 0; hdlist[i] != NULL; i++)
719 nchanged += hdfreebeam(hdlist[i], 0);
720 return(nchanged);
721 }
722 if (hdfragl[hp->fd].writable < 0) /* check for file error */
723 return(0);
724 if (i == 0) { /* clear entire holodeck */
725 if (blglob(hp)->nrm == 0)
726 return(0); /* already clear */
727 nchanged = 0;
728 for (i = nbeams(hp); i > 0; i--)
729 if (hp->bl[i] != NULL)
730 nchanged += hdfreebeam(hp, i);
731 DCHECK(blglob(hp)->nrm != 0,
732 CONSISTENCY, "bad beam count in hdfreebeam");
733 return(nchanged);
734 }
735 DCHECK(i < 1 | i > nbeams(hp),
736 CONSISTENCY, "bad beam index to hdfreebeam");
737 if (hp->bl[i] == NULL)
738 return(0);
739 /* check for additions */
740 nchanged = hp->bl[i]->nrm - hp->bi[i].nrd;
741 if (nchanged)
742 hdsyncbeam(hp, i); /* write new fragment */
743 blglob(hp)->nrm -= hp->bl[i]->nrm;
744 free((void *)hp->bl[i]); /* free memory */
745 hp->bl[i] = NULL;
746 return(nchanged);
747 }
748
749
750 int
751 hdkillbeam(hp, i) /* delete beam from holodeck */
752 register HOLO *hp;
753 register int i;
754 {
755 int nchanged;
756
757 if (hp == NULL) { /* clobber all holodecks */
758 nchanged = 0;
759 for (i = 0; hdlist[i] != NULL; i++)
760 nchanged += hdkillbeam(hdlist[i], 0);
761 return(nchanged);
762 }
763 if (i == 0) { /* clobber entire holodeck */
764 if (biglob(hp)->nrd == 0 & blglob(hp)->nrm == 0)
765 return(0); /* already empty */
766 nchanged = 0;
767 nchanged = 0;
768 for (i = nbeams(hp); i > 0; i--)
769 if (hp->bi[i].nrd > 0 || hp->bl[i] != NULL)
770 nchanged += hdkillbeam(hp, i);
771 DCHECK(biglob(hp)->nrd != 0 | blglob(hp)->nrm != 0,
772 CONSISTENCY, "bad beam count in hdkillbeam");
773 return(nchanged);
774 }
775 DCHECK(i < 1 | i > nbeams(hp), CONSISTENCY,
776 "bad beam index to hdkillbeam");
777 DCHECK(!hdfragl[hp->fd].writable, CONSISTENCY,
778 "hdkillbeam called on read-only holodeck");
779 if (hp->bl[i] != NULL) { /* free memory */
780 blglob(hp)->nrm -= nchanged = hp->bl[i]->nrm;
781 free((void *)hp->bl[i]);
782 hp->bl[i] = NULL;
783 } else
784 nchanged = hp->bi[i].nrd;
785 if (hp->bi[i].nrd && !(hdfragflags&FF_KILL && hdfreefrag(hp,i))) {
786 biglob(hp)->nrd -= hp->bi[i].nrd; /* free failed */
787 hp->bi[i].nrd = 0;
788 hp->bi[i].fo = 0;
789 hdmarkdirty(hp, i);
790 }
791 return(nchanged);
792 }
793
794
795 int
796 hdlrulist(hb, nents, n, hp) /* add beams from holodeck to LRU list */
797 register HDBEAMI *hb; /* beam list */
798 int nents; /* current list length */
799 int n; /* maximum list length */
800 register HOLO *hp; /* section we're adding from */
801 {
802 register int i, j;
803 /* insert each beam from hp */
804 for (i = 1; i <= nbeams(hp); i++) {
805 if (hp->bl[i] == NULL) /* check if loaded */
806 continue;
807 #if 0
808 if (hp->bl[i]->tick == hdclock) /* preempt swap? */
809 continue;
810 #endif
811 if ((j = ++nents) >= n) /* grow list if we can */
812 nents--;
813 for ( ; ; ) { /* bubble into place */
814 if (!--j || hp->bl[i]->tick >=
815 hb[j-1].h->bl[hb[j-1].b]->tick) {
816 hb[j].h = hp;
817 hb[j].b = i;
818 break;
819 }
820 copystruct(hb+j, hb+(j-1));
821 }
822 }
823 return(nents); /* return new list length */
824 }
825
826
827 int
828 hdfreecache(pct, honly) /* free up cache space, writing changes */
829 int pct; /* maximum percentage to free */
830 register HOLO *honly; /* NULL means check all */
831 {
832 HDBEAMI hb[FREEBEAMS];
833 int freetarget;
834 int n;
835 register int i;
836 #ifdef DEBUG
837 unsigned membefore;
838
839 membefore = hdmemuse(0);
840 #endif
841 /* compute free target */
842 freetarget = (honly != NULL) ? blglob(honly)->nrm :
843 hdmemuse(0)/sizeof(RAYVAL) ;
844 freetarget = freetarget*pct/100;
845 if (freetarget <= 0)
846 return(0);
847 /* find least recently used */
848 n = 0;
849 if (honly != NULL)
850 n = hdlrulist(hb, n, FREEBEAMS, honly);
851 else
852 for (i = 0; hdlist[i] != NULL; i++)
853 n = hdlrulist(hb, n, FREEBEAMS, hdlist[i]);
854 /* free LRU beams */
855 for (i = 0; i < n; i++) {
856 hdfreebeam(hb[i].h, hb[i].b);
857 if ((freetarget -= hb[i].h->bi[hb[i].b].nrd) <= 0)
858 break;
859 }
860 hdsync(honly, 0); /* synchronize directories as necessary */
861 #ifdef DEBUG
862 sprintf(errmsg,
863 "%dK before, %dK after hdfreecache (%dK total), %d rays short\n",
864 membefore>>10, hdmemuse(0)>>10, hdmemuse(1)>>10, freetarget);
865 wputs(errmsg);
866 #endif
867 return(-freetarget); /* return how far past goal we went */
868 }
869
870
871 hddone(hp) /* clean up holodeck section and free */
872 register HOLO *hp; /* NULL means clean up all */
873 {
874 register int i;
875
876 if (hp == NULL) { /* NULL means clean up everything */
877 while (hdlist[0] != NULL)
878 hddone(hdlist[0]);
879 free((void *)hdfragl);
880 hdfragl = NULL; nhdfragls = 0;
881 return;
882 }
883 /* flush all data and free memory */
884 hdflush(hp);
885 /* release fragment resources */
886 hdrelease(hp->fd);
887 /* remove hp from active list */
888 for (i = 0; hdlist[i] != NULL; i++)
889 if (hdlist[i] == hp) {
890 while ((hdlist[i] = hdlist[i+1]) != NULL)
891 i++;
892 break;
893 }
894 free((void *)hp->bl); /* free beam list */
895 free((void *)hp); /* free holodeck struct */
896 }
