root/radiance/ray/src/hd/holofile.c
Revision: 3.55
Committed: Thu Jan 1 11:21:55 2004 UTC (21 years, 5 months ago) by schorsch
Changes since 3.54: +132 -87 lines
Ansification and prototypes.
2 static const char RCSid[] = "$Id: holofile.c,v 3.54 2003/10/22 02:06:34 greg Exp $";
5 * Routines for managing holodeck files
6 *
7 * 9/30/97 GWLarson
8 */
9
10 #include "copyright.h"
11
12 #include <string.h>
13
14 #include "platform.h"
15 #include "rtprocess.h"
16
17 #include "holo.h"
18
19 #ifndef CACHESIZE
20 #ifdef SMLMEM
21 #define CACHESIZE 5
22 #else
23 #define CACHESIZE 17 /* default cache size (Mbytes, 0==inf) */
24 #endif
25 #endif
26 #ifndef FREEBEAMS
27 #define FREEBEAMS 1500 /* maximum beams to free at a time */
28 #endif
29 #ifndef PCTFREE
30 #define PCTFREE 15 /* maximum fraction to free (%) */
31 #endif
32 #ifndef MAXFRAGB
33 #define MAXFRAGB 16 /* fragment blocks/file to track (0==inf) */
34 #endif
35 #ifndef FF_DEFAULT
36 /* when to free a beam fragment */
37 #define FF_DEFAULT (FF_WRITE|FF_KILL)
38 #endif
39 #ifndef MINDIRSEL
40 /* minimum directory seek length */
41 #define MINDIRSEL (4*BUFSIZ/sizeof(BEAMI))
42 #endif
43
44 #ifndef BSD
45 #define write writebuf /* safe i/o routines */
46 #define read readbuf
47 #endif
48
49 #define FRAGBLK 512 /* number of fragments to allocate at a time */
50
51 int hdfragflags = FF_DEFAULT; /* tells when to free fragments */
52 unsigned hdcachesize = CACHESIZE*1024*1024; /* target cache size */
53 unsigned long hdclock; /* clock value */
54
55 HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */
56
57 static struct fraglist {
58 short nlinks; /* number of holodeck sections using us */
59 short writable; /* 0 read-only, <0 write error encountered */
60 int nfrags; /* number of known fragments */
61 BEAMI *fi; /* fragments, descending file position */
62 off_t flen; /* last known file length */
63 } *hdfragl; /* fragment lists, indexed by file descriptor */
64
65 static int nhdfragls; /* size of hdfragl array */
66
67 static HOLO *hdalloc(HDGRID *hproto);
68 static char *hdrealloc(char *ptr, unsigned siz, char *rout);
69 static void hdattach(int fd, int wr);
70 static void hdrelease(int fd);
71 static void hdmarkdirty(HOLO *hp, int i);
72 static unsigned int hdmemuse(int all);
73 static int hdfilord(const void *hb1, const void *hb2);
74 static off_t hdallocfrag(int fd, uint32 nrays);
75 static int hdsyncbeam(HOLO *hp, int i);
76 static int hdlrulist(HDBEAMI *hb, int nents, int n, HOLO *hp);
77 static int hdfreecache(int pct, HOLO *honly);
78
79
80
81 HOLO *
82 hdalloc( /* allocate and set holodeck section based on grid */
83 HDGRID *hproto
84 )
85 {
86 HOLO hdhead;
87 register HOLO *hp;
88 int n;
89 /* copy grid to temporary header */
90 memcpy((void *)&hdhead, (void *)hproto, sizeof(HDGRID));
91 /* compute grid vectors and sizes */
92 hdcompgrid(&hdhead);
93 /* allocate header with directory */
94 n = sizeof(HOLO)+nbeams(&hdhead)*sizeof(BEAMI);
95 if ((hp = (HOLO *)malloc(n)) == NULL)
96 return(NULL);
97 /* copy header information */
98 *hp = hdhead;
99 /* allocate and clear beam list */
100 hp->bl = (BEAM **)malloc((nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM));
101 if (hp->bl == NULL) {
102 free((void *)hp);
103 return(NULL);
104 }
105 memset((void *)hp->bl, '\0', (nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM));
106 hp->bl[0] = (BEAM *)(hp->bl+nbeams(hp)+1); /* set blglob(hp) */
107 hp->fd = -1;
108 hp->dirty = 0;
109 hp->priv = NULL;
110 /* clear beam directory */
111 memset((void *)hp->bi, '\0', (nbeams(hp)+1)*sizeof(BEAMI));
112 return(hp); /* all is well */
113 }
114
115
116 char *
117 hdrealloc( /* (re)allocate memory, retry then error */
118 char *ptr,
119 unsigned siz,
120 char *rout
121 )
122 {
123 register char *newp;
124 /* call malloc/realloc */
125 if (ptr == NULL) newp = (char *)malloc(siz);
126 else newp = (char *)realloc((void *)ptr, siz);
127 /* check success */
128 if (newp == NULL && rout != NULL) {
129 hdfreecache(25, NULL); /* free some memory */
130 errno = 0; /* retry */
131 newp = hdrealloc(ptr, siz, NULL);
132 if (newp == NULL) { /* give up and report error */
133 sprintf(errmsg, "out of memory in %s", rout);
134 error(SYSTEM, errmsg);
135 }
136 }
137 return(newp);
138 }
139
140
141 void
142 hdattach( /* start tracking file fragments for some section */
143 register int fd,
144 int wr
145 )
146 {
147 if (fd >= nhdfragls) {
148 hdfragl = (struct fraglist *)hdrealloc((char *)hdfragl,
149 (fd+1)*sizeof(struct fraglist), "hdattach");
150 memset((void *)(hdfragl+nhdfragls),
151 '\0', (fd+1-nhdfragls)*sizeof(struct fraglist));
152 nhdfragls = fd+1;
153 }
154 hdfragl[fd].nlinks++;
155 hdfragl[fd].writable = wr; /* set writable flag */
156 /* get file length */
157 hdfragl[fd].flen = lseek(fd, (off_t)0, SEEK_END);
158 }
159
160
161 /* Do we need a routine to locate file fragments given known occupants? */
162
163
164 void
165 hdrelease( /* stop tracking file fragments for some section */
166 register int fd
167 )
168 {
169 if ((fd < 0) | (fd >= nhdfragls) || !hdfragl[fd].nlinks)
170 return;
171 if (!--hdfragl[fd].nlinks && hdfragl[fd].nfrags) {
172 free((void *)hdfragl[fd].fi);
173 hdfragl[fd].fi = NULL;
174 hdfragl[fd].nfrags = 0;
175 }
176 }
177
178
179 extern HOLO *
180 hdinit( /* initialize a holodeck section in a file */
181 int fd, /* corresponding file descriptor */
182 HDGRID *hproto /* holodeck section grid */
183 )
184 {
185 off_t rtrunc;
186 off_t fpos;
187 int writable;
188 register HOLO *hp;
189 register int n;
190 /* prepare for system errors */
191 errno = 0;
192 if ((fpos = lseek(fd, (off_t)0, SEEK_CUR)) < 0)
193 error(SYSTEM, "cannot determine holodeck file position");
194 if (hproto == NULL) { /* assume we're loading it */
195 HDGRID hpr;
196 /* load header */
197 if (read(fd, (char *)&hpr, sizeof(HDGRID)) != sizeof(HDGRID))
198 error(SYSTEM, "cannot load holodeck header");
199 /* allocate grid */
200 if ((hp = hdalloc(&hpr)) == NULL)
201 goto memerr;
202 /* load beam directory */
203 n = nbeams(hp)*sizeof(BEAMI);
204 if (read(fd, (char *)(hp->bi+1), n) != n)
205 error(SYSTEM, "failure loading holodeck directory");
206 /* check that it's clean */
207 for (n = nbeams(hp); n > 0; n--)
208 if (hp->bi[n].fo < 0) {
209 hp->bi[n].fo = 0;
210 error(WARNING, "dirty holodeck section");
211 break;
212 }
213 /* check writability */
214 if (fd < nhdfragls && hdfragl[fd].nlinks)
215 writable = hdfragl[fd].writable;
216 else
217 writable = lseek(fd, fpos, SEEK_SET) == fpos &&
218 write(fd, (char *)hp, sizeof(HDGRID)) ==
219 sizeof(HDGRID);
220 } else { /* else assume we're creating it */
221 if ((hp = hdalloc(hproto)) == NULL)
222 goto memerr;
223 /* write header and skeleton */
224 n = nbeams(hp)*sizeof(BEAMI);
225 if (write(fd, (char *)hproto, sizeof(HDGRID)) !=
226 sizeof(HDGRID) ||
227 write(fd, (char *)(hp->bi+1), n) != n)
228 error(SYSTEM, "cannot write header to holodeck file");
229 writable = 1;
230 }
231 hp->fd = fd;
232 hp->dirty = 0;
233 biglob(hp)->fo = fpos + sizeof(HDGRID);
234 /* start tracking fragments */
235 hdattach(fd, writable);
236 /* check rays on disk */
237 fpos = hdfilen(fd);
238 biglob(hp)->nrd = rtrunc = 0;
239 for (n = hproto == NULL ? nbeams(hp) : 0; n > 0; n--)
240 if (hp->bi[n].nrd) {
241 if (hp->bi[n].fo+hp->bi[n].nrd*sizeof(RAYVAL) > fpos) {
242 rtrunc += hp->bi[n].nrd;
243 hp->bi[n].nrd = 0;
244 } else
245 biglob(hp)->nrd += hp->bi[n].nrd;
246 }
247 if (rtrunc) {
248 sprintf(errmsg, "truncated section, %ld rays lost (%.1f%%)",
249 rtrunc, 100.*rtrunc/(rtrunc+biglob(hp)->nrd));
250 error(WARNING, errmsg);
251 }
252 /* add to holodeck list */
253 for (n = 0; n < HDMAX; n++)
254 if (hdlist[n] == NULL) {
255 hdlist[n] = hp;
256 break;
257 }
258 /* all done */
259 return(hp);
260 memerr:
261 error(SYSTEM, "cannot allocate holodeck grid");
262 return NULL; /* pro forma return */
263 }
264
265
266 void
267 hdmarkdirty( /* mark holodeck directory position dirty */
268 register HOLO *hp,
269 int i
270 )
271 {
272 static BEAMI smudge = {0, -1};
273 int mindist, minpos;
274 register int j;
275
276 if (!hp->dirty++) { /* write smudge first time */
277 if (lseek(hp->fd, biglob(hp)->fo+(i-1)*sizeof(BEAMI),
278 SEEK_SET) < 0 ||
279 write(hp->fd, (char *)&smudge,
280 sizeof(BEAMI)) != sizeof(BEAMI))
281 error(SYSTEM, "seek/write error in hdmarkdirty");
282 hp->dirseg[0].s = i;
283 hp->dirseg[0].n = 1;
284 return;
285 }
286 /* insert into segment list */
287 for (j = hp->dirty; j--; ) {
288 if (!j || hp->dirseg[j-1].s < i) {
289 hp->dirseg[j].s = i;
290 hp->dirseg[j].n = 1;
291 break;
292 }
293 *(hp->dirseg+j) = *(hp->dirseg+(j-1));
294 }
295 do { /* check neighbors */
296 mindist = nbeams(hp); /* find closest */
297 for (j = hp->dirty; --j; )
298 if (hp->dirseg[j].s -
299 (hp->dirseg[j-1].s + hp->dirseg[j-1].n)
300 < mindist) {
301 minpos = j;
302 mindist = hp->dirseg[j].s -
303 (hp->dirseg[j-1].s + hp->dirseg[j-1].n);
304 }
305 /* good enough? */
306 if (hp->dirty <= MAXDIRSE && mindist > MINDIRSEL)
307 break;
308 j = minpos - 1; /* coalesce neighbors */
309 if (hp->dirseg[j].s + hp->dirseg[j].n <
310 hp->dirseg[minpos].s + hp->dirseg[minpos].n)
311 hp->dirseg[j].n = hp->dirseg[minpos].s +
312 hp->dirseg[minpos].n - hp->dirseg[j].s;
313 hp->dirty--;
314 while (++j < hp->dirty) /* close the gap */
315 *(hp->dirseg+j) = *(hp->dirseg+(j+1));
316 } while (mindist <= MINDIRSEL);
317 }
318
319
320 extern int
321 hdsync( /* update beams and directory on disk */
322 register HOLO *hp,
323 int all
324 )
325 {
326 register int j, n;
327
328 if (hp == NULL) { /* do all holodecks */
329 n = 0;
330 for (j = 0; hdlist[j] != NULL; j++)
331 n += hdsync(hdlist[j], all);
332 return(n);
333 }
334 /* sync the beams */
335 for (j = (all ? nbeams(hp) : 0); j > 0; j--)
336 if (hp->bl[j] != NULL)
337 hdsyncbeam(hp, j);
338 if (!hp->dirty) /* directory clean? */
339 return(0);
340 errno = 0; /* write dirty segments */
341 for (j = 0; j < hp->dirty; j++) {
342 if (lseek(hp->fd, biglob(hp)->fo +
343 (hp->dirseg[j].s-1)*sizeof(BEAMI), SEEK_SET) < 0)
344 error(SYSTEM, "cannot seek on holodeck file");
345 n = hp->dirseg[j].n * sizeof(BEAMI);
346 if (write(hp->fd, (char *)(hp->bi+hp->dirseg[j].s), n) != n)
347 error(SYSTEM, "cannot update section directory");
348 }
349 hp->dirty = 0; /* all clean */
350 return(1);
351 }
352
353
354 unsigned int
355 hdmemuse( /* return memory usage (in bytes) */
356 int all /* include overhead (painful) */
357 )
358 {
359 long total = 0;
360 register int i, j;
361
362 for (j = 0; hdlist[j] != NULL; j++) {
363 total += blglob(hdlist[j])->nrm * sizeof(RAYVAL);
364 if (all) {
365 total += sizeof(HOLO) + sizeof(BEAM *) +
366 nbeams(hdlist[j]) *
367 (sizeof(BEAM *)+sizeof(BEAMI));
368 for (i = nbeams(hdlist[j]); i > 0; i--)
369 if (hdlist[j]->bl[i] != NULL)
370 total += sizeof(BEAM);
371 }
372 }
373 if (all)
374 for (j = 0; j < nhdfragls; j++) {
375 total += sizeof(struct fraglist);
376 if (hdfragl[j].nfrags)
377 total += FRAGBLK*sizeof(BEAMI) *
378 ((hdfragl[j].nfrags-1)/FRAGBLK + 1) ;
379 }
380 return(total);
381 }
382
383
384 extern off_t
385 hdfilen( /* return file length for fd */
386 int fd
387 )
388 {
389 off_t fpos, flen;
390
391 if (fd < 0)
392 return(-1);
393 if (fd >= nhdfragls || !hdfragl[fd].nlinks) {
394 if ((fpos = lseek(fd, (off_t)0, SEEK_CUR)) < 0)
395 return(-1);
396 flen = lseek(fd, (off_t)0, SEEK_END);
397 lseek(fd, fpos, SEEK_SET);
398 return(flen);
399 }
400 return(hdfragl[fd].flen);
401 }
402
403
404 extern off_t
405 hdfiluse( /* compute file usage (in bytes) */
406 int fd, /* open file descriptor to check */
407 int all /* include overhead and unflushed data */
408 )
409 {
410 off_t total = 0;
411 register int i, j;
412
413 for (j = 0; hdlist[j] != NULL; j++) {
414 if (hdlist[j]->fd != fd)
415 continue;
416 total += biglob(hdlist[j])->nrd * sizeof(RAYVAL);
417 if (all) {
418 for (i = nbeams(hdlist[j]); i > 0; i--)
419 if (hdlist[j]->bl[i] != NULL)
420 total += sizeof(RAYVAL) *
421 (hdlist[j]->bl[i]->nrm -
422 hdlist[j]->bi[i].nrd);
423 total += sizeof(HDGRID) +
424 nbeams(hdlist[j])*sizeof(BEAMI);
425 }
426 }
427 return(total); /* does not include fragments */
428 }
429
430
431 extern RAYVAL *
432 hdnewrays( /* allocate space for add'l rays and return pointer */
433 register HOLO *hp,
434 register int i,
435 int nr /* number of new rays desired */
436 )
437 {
438 RAYVAL *p;
439 int n;
440
441 if (nr <= 0) return(NULL);
442 CHECK((i < 1) | (i > nbeams(hp)),
443 CONSISTENCY, "bad beam index given to hdnewrays");
444 if (hp->bl[i] != NULL)
445 hp->bl[i]->tick = hdclock; /* preempt swap */
446 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
447 hdfreecache(PCTFREE, NULL); /* free some space */
448 if (hp->bl[i] == NULL) { /* allocate (and load) */
449 n = hp->bi[i].nrd + nr;
450 hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdnewrays");
451 blglob(hp)->nrm += n;
452 if ((n = hp->bl[i]->nrm = hp->bi[i].nrd)) {
453 errno = 0;
454 if (lseek(hp->fd, hp->bi[i].fo, SEEK_SET) < 0)
455 error(SYSTEM, "seek error on holodeck file");
456 n *= sizeof(RAYVAL);
457 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
458 error(SYSTEM,
459 "error reading beam from holodeck file");
460 }
461 } else { /* just grow in memory */
462 hp->bl[i] = (BEAM *)hdrealloc((char *)hp->bl[i],
463 hdbsiz(hp->bl[i]->nrm + nr), "hdnewrays");
464 blglob(hp)->nrm += nr;
465 }
466 if (hdfragflags&FF_ALLOC && hp->bi[i].nrd)
467 hdfreefrag(hp, i); /* relinquish old fragment */
468 p = hdbray(hp->bl[i]) + hp->bl[i]->nrm;
469 hp->bl[i]->nrm += nr; /* update in-core structure */
470 memset((void *)p, '\0', nr*sizeof(RAYVAL));
471 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
472 return(p); /* point to new rays */
473 }
474
475
476 extern BEAM *
477 hdgetbeam( /* get beam (from file if necessary) */
478 register HOLO *hp,
479 register int i
480 )
481 {
482 register int n;
483
484 CHECK((i < 1) | (i > nbeams(hp)),
485 CONSISTENCY, "bad beam index given to hdgetbeam");
486 if (hp->bl[i] == NULL) { /* load from disk */
487 if (!(n = hp->bi[i].nrd))
488 return(NULL);
489 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
490 hdfreecache(PCTFREE, NULL); /* get free space */
491 hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdgetbeam");
492 blglob(hp)->nrm += hp->bl[i]->nrm = n;
493 errno = 0;
494 if (lseek(hp->fd, hp->bi[i].fo, SEEK_SET) < 0)
495 error(SYSTEM, "seek error on holodeck file");
496 n *= sizeof(RAYVAL);
497 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
498 error(SYSTEM, "error reading beam from holodeck file");
499 if (hdfragflags&FF_READ)
500 hdfreefrag(hp, i); /* relinquish old frag. */
501 }
502 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
503 return(hp->bl[i]);
504 }
505
506
507 int
508 hdfilord( /* order beams for quick loading */
509 register const void *hb1,
510 register const void *hb2
511 )
512 {
513 register off_t c;
514 /* residents go first */
515 if (((HDBEAMI*)hb2)->h->bl[((HDBEAMI*)hb2)->b] != NULL)
516 return(((HDBEAMI*)hb1)->h->bl[((HDBEAMI*)hb1)->b] == NULL);
517 if (((HDBEAMI*)hb1)->h->bl[((HDBEAMI*)hb1)->b] != NULL)
518 return(-1);
519 /* otherwise sort by file descriptor */
520 if (((HDBEAMI*)hb1)->h->fd != ((HDBEAMI*)hb2)->h->fd)
521 return(((HDBEAMI*)hb1)->h->fd - ((HDBEAMI*)hb2)->h->fd);
522 /* then by position in file */
523 c = ((HDBEAMI*)hb1)->h->bi[((HDBEAMI*)hb1)->b].fo
524 - ((HDBEAMI*)hb2)->h->bi[((HDBEAMI*)hb2)->b].fo;
525 return(c > 0 ? 1 : c < 0 ? -1 : 0);
526 }
527
528
529 extern void
530 hdloadbeams( /* load a list of beams in optimal order */
531 register HDBEAMI *hb, /* list gets sorted by hdfilord() */
532 int n, /* list length */
533 void (*bf)(BEAM *bp, HDBEAMI *hb) /* callback function (optional) */
534 )
535 {
536 unsigned origcachesize, memuse;
537 int bytesloaded, needbytes, bytes2free;
538 register BEAM *bp;
539 register int i;
540 /* precheck consistency */
541 if (n <= 0) return;
542 for (i = n; i--; )
543 if (hb[i].h==NULL || (hb[i].b<1) | (hb[i].b>nbeams(hb[i].h)))
544 error(CONSISTENCY, "bad beam in hdloadbeams");
545 /* sort list for optimal access */
546 qsort((void *)hb, n, sizeof(HDBEAMI), hdfilord);
547 bytesloaded = 0; /* run through loaded beams */
548 for ( ; n && (bp = hb->h->bl[hb->b]) != NULL; n--, hb++) {
549 bp->tick = hdclock; /* preempt swap */
550 bytesloaded += bp->nrm;
551 if (bf != NULL)
552 (*bf)(bp, hb);
553 }
554 bytesloaded *= sizeof(RAYVAL);
555 if ((origcachesize = hdcachesize) > 0) {
556 needbytes = 0; /* figure out memory needs */
557 for (i = n; i--; )
558 needbytes += hb[i].h->bi[hb[i].b].nrd;
559 needbytes *= sizeof(RAYVAL);
560 do { /* free enough memory */
561 memuse = hdmemuse(0);
562 bytes2free = needbytes - (int)(hdcachesize-memuse);
563 if (bytes2free > (int)(memuse - bytesloaded))
564 bytes2free = memuse - bytesloaded;
565 } while (bytes2free > 0 &&
566 hdfreecache(100*bytes2free/memuse, NULL) < 0);
567 hdcachesize = 0; /* load beams w/o swap */
568 }
569 for (i = 0; i < n; i++)
570 if ((bp = hdgetbeam(hb[i].h, hb[i].b)) != NULL && bf != NULL)
571 (*bf)(bp, hb+i);
572 hdcachesize = origcachesize; /* resume dynamic swapping */
573 }
574
575
576 extern int
577 hdfreefrag( /* free a file fragment */
578 HOLO *hp,
579 int i
580 )
581 {
582 register BEAMI *bi = &hp->bi[i];
583 register struct fraglist *f;
584 register int j, k;
585
586 if (bi->nrd <= 0)
587 return(0);
588 DCHECK(hp->fd < 0 | hp->fd >= nhdfragls || !hdfragl[hp->fd].nlinks,
589 CONSISTENCY, "bad file descriptor in hdfreefrag");
590 f = &hdfragl[hp->fd];
591 if (!f->writable)
592 return(0);
593 if (f->nfrags % FRAGBLK == 0) { /* delete empty remnants */
594 for (j = k = 0; k < f->nfrags; j++, k++) {
595 while (f->fi[k].nrd == 0)
596 if (++k >= f->nfrags)
597 goto endloop;
598 if (k > j)
599 *(f->fi+j) = *(f->fi+k);
600 }
601 endloop:
602 f->nfrags = j;
603 }
604 j = f->nfrags++; /* allocate a slot in free list */
605 #if MAXFRAGB
606 if (j >= MAXFRAGB*FRAGBLK) {
607 f->nfrags = j--; /* stop list growth */
608 if (bi->nrd <= f->fi[j].nrd)
609 return(0); /* new one no better than discard */
610 }
611 #endif
612 if (j % FRAGBLK == 0) { /* more (or less) free list space */
613 register BEAMI *newp;
614 if (f->fi == NULL)
615 newp = (BEAMI *)malloc((j+FRAGBLK)*sizeof(BEAMI));
616 else
617 newp = (BEAMI *)realloc((void *)f->fi,
618 (j+FRAGBLK)*sizeof(BEAMI));
619 if (newp == NULL) {
620 f->nfrags--; /* graceful failure */
621 return(0);
622 }
623 f->fi = newp;
624 }
625 for ( ; ; j--) { /* insert in descending list */
626 if (!j || bi->fo < f->fi[j-1].fo) {
627 f->fi[j].fo = bi->fo;
628 f->fi[j].nrd = bi->nrd;
629 break;
630 }
631 *(f->fi+j) = *(f->fi+(j-1));
632 }
633 /* coalesce adjacent fragments */
634 /* successors never empty */
635 if (j && f->fi[j-1].fo == f->fi[j].fo + f->fi[j].nrd*sizeof(RAYVAL)) {
636 f->fi[j].nrd += f->fi[j-1].nrd;
637 f->fi[j-1].nrd = 0;
638 }
639 for (k = j+1; k < f->nfrags; k++) /* get non-empty predecessor */
640 if (f->fi[k].nrd) {
641 if (f->fi[j].fo == f->fi[k].fo +
642 f->fi[k].nrd*sizeof(RAYVAL)) {
643 f->fi[k].nrd += f->fi[j].nrd;
644 f->fi[j].nrd = 0;
645 }
646 break;
647 }
648 biglob(hp)->nrd -= bi->nrd; /* tell fragment it's free */
649 bi->nrd = 0;
650 bi->fo = 0;
651 hdmarkdirty(hp, i); /* assume we'll reallocate */
652 return(1);
653 }
654
655
656 extern int
657 hdfragOK( /* get fragment list status for file */
658 int fd,
659 int *listlen,
660 register int32 *listsiz
661 )
662 {
663 register struct fraglist *f;
664 register int i;
665
666 if ((fd < 0) | (fd >= nhdfragls) || !(f = &hdfragl[fd])->nlinks)
667 return(0); /* listless */
668 if (listlen != NULL)
669 *listlen = f->nfrags;
670 if (listsiz != NULL)
671 for (i = f->nfrags, *listsiz = 0; i--; )
672 *listsiz += f->fi[i].nrd;
673 #if MAXFRAGB
674 return(f->nfrags < MAXFRAGB*FRAGBLK);
675 #else
676 return(1); /* list never fills up */
677 #endif
678 }
679
680
681 off_t
682 hdallocfrag( /* allocate a file fragment */
683 int fd,
684 uint32 nrays
685 )
686 {
687 register struct fraglist *f;
688 register int j;
689 off_t nfo;
690
691 if (nrays == 0)
692 return(-1L);
693 DCHECK(fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks,
694 CONSISTENCY, "bad file descriptor in hdallocfrag");
695 f = &hdfragl[fd];
696 for (j = f->nfrags; j-- > 0; ) /* first fit algorithm */
697 if (f->fi[j].nrd >= nrays)
698 break;
699 if (j < 0) { /* no fragment -- extend file */
700 nfo = f->flen;
701 f->flen += nrays*sizeof(RAYVAL);
702 } else { /* else use fragment */
703 nfo = f->fi[j].fo;
704 f->fi[j].fo += nrays*sizeof(RAYVAL);
705 f->fi[j].nrd -= nrays;
706 }
707 return(nfo);
708 }
709
710
711 int
712 hdsyncbeam( /* sync beam in memory with beam on disk */
713 register HOLO *hp,
714 register int i
715 )
716 {
717 int fragfreed;
718 uint32 nrays;
719 unsigned int n;
720 off_t nfo;
721 /* check file status */
722 if (hdfragl[hp->fd].writable <= 0)
723 return(hdfragl[hp->fd].writable);
724 DCHECK(i < 1 | i > nbeams(hp),
725 CONSISTENCY, "bad beam index in hdsyncbeam");
726 /* is current fragment OK? */
727 if (hp->bl[i] == NULL || (nrays = hp->bl[i]->nrm) == hp->bi[i].nrd)
728 return(0);
729 /* relinquish old fragment? */
730 fragfreed = hdfragflags&FF_WRITE && hp->bi[i].nrd && hdfreefrag(hp,i);
731 if (nrays) { /* get and write new fragment */
732 nfo = hdallocfrag(hp->fd, nrays);
733 errno = 0;
734 if (lseek(hp->fd, nfo, SEEK_SET) < 0)
735 error(SYSTEM, "cannot seek on holodeck file");
736 n = hp->bl[i]->nrm * sizeof(RAYVAL);
737 if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) {
738 hdfragl[hp->fd].writable = -1;
739 hdsync(NULL, 0); /* sync directories */
740 error(SYSTEM, "write error in hdsyncbeam");
741 }
742 hp->bi[i].fo = nfo;
743 } else
744 hp->bi[i].fo = 0;
745 biglob(hp)->nrd += nrays - hp->bi[i].nrd;
746 hp->bi[i].nrd = nrays;
747 if (!fragfreed)
748 hdmarkdirty(hp, i); /* need to flag dir. ent. */
749 return(1);
750 }
751
752
753 extern int
754 hdfreebeam( /* free beam, writing if dirty */
755 register HOLO *hp,
756 register int i
757 )
758 {
759 int nchanged;
760
761 if (hp == NULL) { /* clear all holodecks */
762 nchanged = 0;
763 for (i = 0; hdlist[i] != NULL; i++)
764 nchanged += hdfreebeam(hdlist[i], 0);
765 return(nchanged);
766 }
767 if (hdfragl[hp->fd].writable < 0) /* check for file error */
768 return(0);
769 if (i == 0) { /* clear entire holodeck */
770 if (blglob(hp)->nrm == 0)
771 return(0); /* already clear */
772 nchanged = 0;
773 for (i = nbeams(hp); i > 0; i--)
774 if (hp->bl[i] != NULL)
775 nchanged += hdfreebeam(hp, i);
776 DCHECK(blglob(hp)->nrm != 0,
777 CONSISTENCY, "bad beam count in hdfreebeam");
778 return(nchanged);
779 }
780 DCHECK(i < 1 | i > nbeams(hp),
781 CONSISTENCY, "bad beam index to hdfreebeam");
782 if (hp->bl[i] == NULL)
783 return(0);
784 /* check for additions */
785 nchanged = hp->bl[i]->nrm - hp->bi[i].nrd;
786 if (nchanged)
787 hdsyncbeam(hp, i); /* write new fragment */
788 blglob(hp)->nrm -= hp->bl[i]->nrm;
789 free((void *)hp->bl[i]); /* free memory */
790 hp->bl[i] = NULL;
791 return(nchanged);
792 }
793
794
795 extern int
796 hdkillbeam( /* delete beam from holodeck */
797 register HOLO *hp,
798 register int i
799 )
800 {
801 int nchanged;
802
803 if (hp == NULL) { /* clobber all holodecks */
804 nchanged = 0;
805 for (i = 0; hdlist[i] != NULL; i++)
806 nchanged += hdkillbeam(hdlist[i], 0);
807 return(nchanged);
808 }
809 if (i == 0) { /* clobber entire holodeck */
810 if ((biglob(hp)->nrd == 0) & (blglob(hp)->nrm == 0))
811 return(0); /* already empty */
812 nchanged = 0;
813 nchanged = 0;
814 for (i = nbeams(hp); i > 0; i--)
815 if (hp->bi[i].nrd > 0 || hp->bl[i] != NULL)
816 nchanged += hdkillbeam(hp, i);
817 DCHECK(biglob(hp)->nrd != 0 | blglob(hp)->nrm != 0,
818 CONSISTENCY, "bad beam count in hdkillbeam");
819 return(nchanged);
820 }
821 DCHECK(i < 1 | i > nbeams(hp), CONSISTENCY,
822 "bad beam index to hdkillbeam");
823 DCHECK(!hdfragl[hp->fd].writable, CONSISTENCY,
824 "hdkillbeam called on read-only holodeck");
825 if (hp->bl[i] != NULL) { /* free memory */
826 blglob(hp)->nrm -= nchanged = hp->bl[i]->nrm;
827 free((void *)hp->bl[i]);
828 hp->bl[i] = NULL;
829 } else
830 nchanged = hp->bi[i].nrd;
831 if (hp->bi[i].nrd && !(hdfragflags&FF_KILL && hdfreefrag(hp,i))) {
832 biglob(hp)->nrd -= hp->bi[i].nrd; /* free failed */
833 hp->bi[i].nrd = 0;
834 hp->bi[i].fo = 0;
835 hdmarkdirty(hp, i);
836 }
837 return(nchanged);
838 }
839
840
841 int
842 hdlrulist( /* add beams from holodeck to LRU list */
843 register HDBEAMI *hb, /* beam list */
844 int nents, /* current list length */
845 int n, /* maximum list length */
846 register HOLO *hp /* section we're adding from */
847 )
848 {
849 register int i, j;
850 /* insert each beam from hp */
851 for (i = 1; i <= nbeams(hp); i++) {
852 if (hp->bl[i] == NULL) /* check if loaded */
853 continue;
854 #if 0
855 if (hp->bl[i]->tick == hdclock) /* preempt swap? */
856 continue;
857 #endif
858 if ((j = ++nents) >= n) /* grow list if we can */
859 nents--;
860 for ( ; ; ) { /* bubble into place */
861 if (!--j || hp->bl[i]->tick >=
862 hb[j-1].h->bl[hb[j-1].b]->tick) {
863 hb[j].h = hp;
864 hb[j].b = i;
865 break;
866 }
867 *(hb+j) = *(hb+(j-1));
868 }
869 }
870 return(nents); /* return new list length */
871 }
872
873
874 int
875 hdfreecache( /* free up cache space, writing changes */
876 int pct, /* maximum percentage to free */
877 register HOLO *honly /* NULL means check all */
878 )
879 {
880 HDBEAMI hb[FREEBEAMS];
881 int freetarget;
882 int n;
883 register int i;
884 #ifdef DEBUG
885 unsigned membefore;
886
887 membefore = hdmemuse(0);
888 #endif
889 /* compute free target */
890 freetarget = (honly != NULL) ? blglob(honly)->nrm :
891 hdmemuse(0)/sizeof(RAYVAL) ;
892 freetarget = freetarget*pct/100;
893 if (freetarget <= 0)
894 return(0);
895 /* find least recently used */
896 n = 0;
897 if (honly != NULL)
898 n = hdlrulist(hb, n, FREEBEAMS, honly);
899 else
900 for (i = 0; hdlist[i] != NULL; i++)
901 n = hdlrulist(hb, n, FREEBEAMS, hdlist[i]);
902 /* free LRU beams */
903 for (i = 0; i < n; i++) {
904 hdfreebeam(hb[i].h, hb[i].b);
905 if ((freetarget -= hb[i].h->bi[hb[i].b].nrd) <= 0)
906 break;
907 }
908 hdsync(honly, 0); /* synchronize directories as necessary */
909 #ifdef DEBUG
910 sprintf(errmsg,
911 "%dK before, %dK after hdfreecache (%dK total), %d rays short\n",
912 membefore>>10, hdmemuse(0)>>10, hdmemuse(1)>>10, freetarget);
913 wputs(errmsg);
914 #endif
915 return(-freetarget); /* return how far past goal we went */
916 }
917
918
919 extern void
920 hddone( /* clean up holodeck section and free */
921 register HOLO *hp /* NULL means clean up all */
922 )
923 {
924 register int i;
925
926 if (hp == NULL) { /* NULL means clean up everything */
927 while (hdlist[0] != NULL)
928 hddone(hdlist[0]);
929 free((void *)hdfragl);
930 hdfragl = NULL; nhdfragls = 0;
931 return;
932 }
933 /* flush all data and free memory */
934 hdflush(hp);
935 /* release fragment resources */
936 hdrelease(hp->fd);
937 /* remove hp from active list */
938 for (i = 0; hdlist[i] != NULL; i++)
939 if (hdlist[i] == hp) {
940 while ((hdlist[i] = hdlist[i+1]) != NULL)
941 i++;
942 break;
943 }
944 free((void *)hp->bl); /* free beam list */
945 free((void *)hp); /* free holodeck struct */
946 }
