root/radiance/ray/src/hd/holofile.c
Revision: 3.52
Committed: Sun Jul 27 22:12:02 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 3.51: +9 -8 lines
2 static const char RCSid[] = "$Id: holofile.c,v 3.51 2003/07/21 22:30:18 schorsch Exp $";
5 * Routines for managing holodeck files
6 *
7 * 9/30/97 GWLarson
8 */
9
10 #include "copyright.h"
11
12 #include <string.h>
13
14 #include "holo.h"
15
16 #ifndef CACHESIZE
17 #ifdef SMLMEM
18 #define CACHESIZE 5
19 #else
20 #define CACHESIZE 17 /* default cache size (Mbytes, 0==inf) */
21 #endif
22 #endif
23 #ifndef FREEBEAMS
24 #define FREEBEAMS 1500 /* maximum beams to free at a time */
25 #endif
26 #ifndef PCTFREE
27 #define PCTFREE 15 /* maximum fraction to free (%) */
28 #endif
29 #ifndef MAXFRAGB
30 #define MAXFRAGB 16 /* fragment blocks/file to track (0==inf) */
31 #endif
32 #ifndef FF_DEFAULT
33 /* when to free a beam fragment */
34 #define FF_DEFAULT (FF_WRITE|FF_KILL)
35 #endif
36 #ifndef MINDIRSEL
37 /* minimum directory seek length */
38 #define MINDIRSEL (4*BUFSIZ/sizeof(BEAMI))
39 #endif
40
41 #ifndef BSD
42 #define write writebuf /* safe i/o routines */
43 #define read readbuf
44 #endif
45
46 #define FRAGBLK 512 /* number of fragments to allocate at a time */
47
48 int hdfragflags = FF_DEFAULT; /* tells when to free fragments */
49 unsigned hdcachesize = CACHESIZE*1024*1024; /* target cache size */
50 unsigned long hdclock; /* clock value */
51
52 HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */
53
54 static struct fraglist {
55 short nlinks; /* number of holodeck sections using us */
56 short writable; /* 0 read-only, <0 write error encountered */
57 int nfrags; /* number of known fragments */
58 BEAMI *fi; /* fragments, descending file position */
59 off_t flen; /* last known file length */
60 } *hdfragl; /* fragment lists, indexed by file descriptor */
61
62 static int nhdfragls; /* size of hdfragl array */
63
64
65 HOLO *
66 hdalloc(hproto) /* allocate and set holodeck section based on grid */
67 HDGRID *hproto;
68 {
69 HOLO hdhead;
70 register HOLO *hp;
71 int n;
72 /* copy grid to temporary header */
73 memcpy((void *)&hdhead, (void *)hproto, sizeof(HDGRID));
74 /* compute grid vectors and sizes */
75 hdcompgrid(&hdhead);
76 /* allocate header with directory */
77 n = sizeof(HOLO)+nbeams(&hdhead)*sizeof(BEAMI);
78 if ((hp = (HOLO *)malloc(n)) == NULL)
79 return(NULL);
80 /* copy header information */
81 *hp = hdhead;
82 /* allocate and clear beam list */
83 hp->bl = (BEAM **)malloc((nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM));
84 if (hp->bl == NULL) {
85 free((void *)hp);
86 return(NULL);
87 }
88 memset((void *)hp->bl, '\0', (nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM));
89 hp->bl[0] = (BEAM *)(hp->bl+nbeams(hp)+1); /* set blglob(hp) */
90 hp->fd = -1;
91 hp->dirty = 0;
92 hp->priv = NULL;
93 /* clear beam directory */
94 memset((void *)hp->bi, '\0', (nbeams(hp)+1)*sizeof(BEAMI));
95 return(hp); /* all is well */
96 }
97
98
99 char *
100 hdrealloc(ptr, siz, rout) /* (re)allocate memory, retry then error */
101 char *ptr;
102 unsigned siz;
103 char *rout;
104 {
105 register char *newp;
106 /* call malloc/realloc */
107 if (ptr == NULL) newp = (char *)malloc(siz);
108 else newp = (char *)realloc((void *)ptr, siz);
109 /* check success */
110 if (newp == NULL && rout != NULL) {
111 hdfreecache(25, NULL); /* free some memory */
112 errno = 0; /* retry */
113 newp = hdrealloc(ptr, siz, NULL);
114 if (newp == NULL) { /* give up and report error */
115 sprintf(errmsg, "out of memory in %s", rout);
116 error(SYSTEM, errmsg);
117 }
118 }
119 return(newp);
120 }
121
122
123 hdattach(fd, wr) /* start tracking file fragments for some section */
124 register int fd;
125 int wr;
126 {
127 if (fd >= nhdfragls) {
128 hdfragl = (struct fraglist *)hdrealloc((char *)hdfragl,
129 (fd+1)*sizeof(struct fraglist), "hdattach");
130 memset((void *)(hdfragl+nhdfragls),
131 '\0', (fd+1-nhdfragls)*sizeof(struct fraglist));
132 nhdfragls = fd+1;
133 }
134 hdfragl[fd].nlinks++;
135 hdfragl[fd].writable = wr; /* set writable flag */
136 hdfragl[fd].flen = lseek(fd, (off_t)0, 2); /* get file length */
137 }
138
139
140 /* Do we need a routine to locate file fragments given known occupants? */
141
142
143 hdrelease(fd) /* stop tracking file fragments for some section */
144 register int fd;
145 {
146 if ((fd < 0) | (fd >= nhdfragls) || !hdfragl[fd].nlinks)
147 return;
148 if (!--hdfragl[fd].nlinks && hdfragl[fd].nfrags) {
149 free((void *)hdfragl[fd].fi);
150 hdfragl[fd].fi = NULL;
151 hdfragl[fd].nfrags = 0;
152 }
153 }
154
155
156 HOLO *
157 hdinit(fd, hproto) /* initialize a holodeck section in a file */
158 int fd; /* corresponding file descriptor */
159 HDGRID *hproto; /* holodeck section grid */
160 {
161 off_t rtrunc;
162 off_t fpos;
163 int writable;
164 register HOLO *hp;
165 register int n;
166 /* prepare for system errors */
167 errno = 0;
168 if ((fpos = lseek(fd, (off_t)0, 1)) < 0)
169 error(SYSTEM, "cannot determine holodeck file position");
170 if (hproto == NULL) { /* assume we're loading it */
171 HDGRID hpr;
172 /* load header */
173 if (read(fd, (char *)&hpr, sizeof(HDGRID)) != sizeof(HDGRID))
174 error(SYSTEM, "cannot load holodeck header");
175 /* allocate grid */
176 if ((hp = hdalloc(&hpr)) == NULL)
177 goto memerr;
178 /* load beam directory */
179 n = nbeams(hp)*sizeof(BEAMI);
180 if (read(fd, (char *)(hp->bi+1), n) != n)
181 error(SYSTEM, "failure loading holodeck directory");
182 /* check that it's clean */
183 for (n = nbeams(hp); n > 0; n--)
184 if (hp->bi[n].fo < 0) {
185 hp->bi[n].fo = 0;
186 error(WARNING, "dirty holodeck section");
187 break;
188 }
189 /* check writability */
190 if (fd < nhdfragls && hdfragl[fd].nlinks)
191 writable = hdfragl[fd].writable;
192 else
193 writable = lseek(fd, fpos, 0) == fpos &&
194 write(fd, (char *)hp, sizeof(HDGRID)) ==
195 sizeof(HDGRID);
196 } else { /* else assume we're creating it */
197 if ((hp = hdalloc(hproto)) == NULL)
198 goto memerr;
199 /* write header and skeleton */
200 n = nbeams(hp)*sizeof(BEAMI);
201 if (write(fd, (char *)hproto, sizeof(HDGRID)) !=
202 sizeof(HDGRID) ||
203 write(fd, (char *)(hp->bi+1), n) != n)
204 error(SYSTEM, "cannot write header to holodeck file");
205 writable = 1;
206 }
207 hp->fd = fd;
208 hp->dirty = 0;
209 biglob(hp)->fo = fpos + sizeof(HDGRID);
210 /* start tracking fragments */
211 hdattach(fd, writable);
212 /* check rays on disk */
213 fpos = hdfilen(fd);
214 biglob(hp)->nrd = rtrunc = 0;
215 for (n = hproto == NULL ? nbeams(hp) : 0; n > 0; n--)
216 if (hp->bi[n].nrd) {
217 if (hp->bi[n].fo+hp->bi[n].nrd*sizeof(RAYVAL) > fpos) {
218 rtrunc += hp->bi[n].nrd;
219 hp->bi[n].nrd = 0;
220 } else
221 biglob(hp)->nrd += hp->bi[n].nrd;
222 }
223 if (rtrunc) {
224 sprintf(errmsg, "truncated section, %ld rays lost (%.1f%%)",
225 rtrunc, 100.*rtrunc/(rtrunc+biglob(hp)->nrd));
226 error(WARNING, errmsg);
227 }
228 /* add to holodeck list */
229 for (n = 0; n < HDMAX; n++)
230 if (hdlist[n] == NULL) {
231 hdlist[n] = hp;
232 break;
233 }
234 /* all done */
235 return(hp);
236 memerr:
237 error(SYSTEM, "cannot allocate holodeck grid");
238 }
239
240
241 hdmarkdirty(hp, i) /* mark holodeck directory position dirty */
242 register HOLO *hp;
243 int i;
244 {
245 static BEAMI smudge = {0, -1};
246 int mindist, minpos;
247 register int j;
248
249 if (!hp->dirty++) { /* write smudge first time */
250 if (lseek(hp->fd, biglob(hp)->fo+(i-1)*sizeof(BEAMI), 0) < 0
251 || write(hp->fd, (char *)&smudge,
252 sizeof(BEAMI)) != sizeof(BEAMI))
253 error(SYSTEM, "seek/write error in hdmarkdirty");
254 hp->dirseg[0].s = i;
255 hp->dirseg[0].n = 1;
256 return;
257 }
258 /* insert into segment list */
259 for (j = hp->dirty; j--; ) {
260 if (!j || hp->dirseg[j-1].s < i) {
261 hp->dirseg[j].s = i;
262 hp->dirseg[j].n = 1;
263 break;
264 }
265 *(hp->dirseg+j) = *(hp->dirseg+(j-1));
266 }
267 do { /* check neighbors */
268 mindist = nbeams(hp); /* find closest */
269 for (j = hp->dirty; --j; )
270 if (hp->dirseg[j].s -
271 (hp->dirseg[j-1].s + hp->dirseg[j-1].n)
272 < mindist) {
273 minpos = j;
274 mindist = hp->dirseg[j].s -
275 (hp->dirseg[j-1].s + hp->dirseg[j-1].n);
276 }
277 /* good enough? */
278 if (hp->dirty <= MAXDIRSE && mindist > MINDIRSEL)
279 break;
280 j = minpos - 1; /* coalesce neighbors */
281 if (hp->dirseg[j].s + hp->dirseg[j].n <
282 hp->dirseg[minpos].s + hp->dirseg[minpos].n)
283 hp->dirseg[j].n = hp->dirseg[minpos].s +
284 hp->dirseg[minpos].n - hp->dirseg[j].s;
285 hp->dirty--;
286 while (++j < hp->dirty) /* close the gap */
287 *(hp->dirseg+j) = *(hp->dirseg+(j+1));
288 } while (mindist <= MINDIRSEL);
289 }
290
291
292 int
293 hdsync(hp, all) /* update beams and directory on disk */
294 register HOLO *hp;
295 int all;
296 {
297 register int j, n;
298
299 if (hp == NULL) { /* do all holodecks */
300 n = 0;
301 for (j = 0; hdlist[j] != NULL; j++)
302 n += hdsync(hdlist[j], all);
303 return(n);
304 }
305 /* sync the beams */
306 for (j = (all ? nbeams(hp) : 0); j > 0; j--)
307 if (hp->bl[j] != NULL)
308 hdsyncbeam(hp, j);
309 if (!hp->dirty) /* directory clean? */
310 return(0);
311 errno = 0; /* write dirty segments */
312 for (j = 0; j < hp->dirty; j++) {
313 if (lseek(hp->fd, biglob(hp)->fo +
314 (hp->dirseg[j].s-1)*sizeof(BEAMI), 0) < 0)
315 error(SYSTEM, "cannot seek on holodeck file");
316 n = hp->dirseg[j].n * sizeof(BEAMI);
317 if (write(hp->fd, (char *)(hp->bi+hp->dirseg[j].s), n) != n)
318 error(SYSTEM, "cannot update section directory");
319 }
320 hp->dirty = 0; /* all clean */
321 return(1);
322 }
323
324
325 unsigned
326 hdmemuse(all) /* return memory usage (in bytes) */
327 int all; /* include overhead (painful) */
328 {
329 long total = 0;
330 register int i, j;
331
332 for (j = 0; hdlist[j] != NULL; j++) {
333 total += blglob(hdlist[j])->nrm * sizeof(RAYVAL);
334 if (all) {
335 total += sizeof(HOLO) + sizeof(BEAM *) +
336 nbeams(hdlist[j]) *
337 (sizeof(BEAM *)+sizeof(BEAMI));
338 for (i = nbeams(hdlist[j]); i > 0; i--)
339 if (hdlist[j]->bl[i] != NULL)
340 total += sizeof(BEAM);
341 }
342 }
343 if (all)
344 for (j = 0; j < nhdfragls; j++) {
345 total += sizeof(struct fraglist);
346 if (hdfragl[j].nfrags)
347 total += FRAGBLK*sizeof(BEAMI) *
348 ((hdfragl[j].nfrags-1)/FRAGBLK + 1) ;
349 }
350 return(total);
351 }
352
353
354 off_t
355 hdfilen(fd) /* return file length for fd */
356 int fd;
357 {
358 off_t fpos, flen;
359
360 if (fd < 0)
361 return(-1);
362 if (fd >= nhdfragls || !hdfragl[fd].nlinks) {
363 if ((fpos = lseek(fd, (off_t)0, 1)) < 0)
364 return(-1);
365 flen = lseek(fd, (off_t)0, 2);
366 lseek(fd, fpos, 0);
367 return(flen);
368 }
369 return(hdfragl[fd].flen);
370 }
371
372
373 off_t
374 hdfiluse(fd, all) /* compute file usage (in bytes) */
375 int fd; /* open file descriptor to check */
376 int all; /* include overhead and unflushed data */
377 {
378 off_t total = 0;
379 register int i, j;
380
381 for (j = 0; hdlist[j] != NULL; j++) {
382 if (hdlist[j]->fd != fd)
383 continue;
384 total += biglob(hdlist[j])->nrd * sizeof(RAYVAL);
385 if (all) {
386 for (i = nbeams(hdlist[j]); i > 0; i--)
387 if (hdlist[j]->bl[i] != NULL)
388 total += sizeof(RAYVAL) *
389 (hdlist[j]->bl[i]->nrm -
390 hdlist[j]->bi[i].nrd);
391 total += sizeof(HDGRID) +
392 nbeams(hdlist[j])*sizeof(BEAMI);
393 }
394 }
395 return(total); /* does not include fragments */
396 }
397
398
399 RAYVAL *
400 hdnewrays(hp, i, nr) /* allocate space for add'l rays and return pointer */
401 register HOLO *hp;
402 register int i;
403 int nr; /* number of new rays desired */
404 {
405 RAYVAL *p;
406 int n;
407
408 if (nr <= 0) return(NULL);
409 CHECK((i < 1) | (i > nbeams(hp)),
410 CONSISTENCY, "bad beam index given to hdnewrays");
411 if (hp->bl[i] != NULL)
412 hp->bl[i]->tick = hdclock; /* preempt swap */
413 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
414 hdfreecache(PCTFREE, NULL); /* free some space */
415 if (hp->bl[i] == NULL) { /* allocate (and load) */
416 n = hp->bi[i].nrd + nr;
417 hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdnewrays");
418 blglob(hp)->nrm += n;
419 if ((n = hp->bl[i]->nrm = hp->bi[i].nrd)) {
420 errno = 0;
421 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
422 error(SYSTEM, "seek error on holodeck file");
423 n *= sizeof(RAYVAL);
424 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
425 error(SYSTEM,
426 "error reading beam from holodeck file");
427 }
428 } else { /* just grow in memory */
429 hp->bl[i] = (BEAM *)hdrealloc((char *)hp->bl[i],
430 hdbsiz(hp->bl[i]->nrm + nr), "hdnewrays");
431 blglob(hp)->nrm += nr;
432 }
433 if (hdfragflags&FF_ALLOC && hp->bi[i].nrd)
434 hdfreefrag(hp, i); /* relinquish old fragment */
435 p = hdbray(hp->bl[i]) + hp->bl[i]->nrm;
436 hp->bl[i]->nrm += nr; /* update in-core structure */
437 memset((void *)p, '\0', nr*sizeof(RAYVAL));
438 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
439 return(p); /* point to new rays */
440 }
441
442
443 BEAM *
444 hdgetbeam(hp, i) /* get beam (from file if necessary) */
445 register HOLO *hp;
446 register int i;
447 {
448 register int n;
449
450 CHECK((i < 1) | (i > nbeams(hp)),
451 CONSISTENCY, "bad beam index given to hdgetbeam");
452 if (hp->bl[i] == NULL) { /* load from disk */
453 if (!(n = hp->bi[i].nrd))
454 return(NULL);
455 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
456 hdfreecache(PCTFREE, NULL); /* get free space */
457 hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdgetbeam");
458 blglob(hp)->nrm += hp->bl[i]->nrm = n;
459 errno = 0;
460 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
461 error(SYSTEM, "seek error on holodeck file");
462 n *= sizeof(RAYVAL);
463 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
464 error(SYSTEM, "error reading beam from holodeck file");
465 if (hdfragflags&FF_READ)
466 hdfreefrag(hp, i); /* relinquish old frag. */
467 }
468 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
469 return(hp->bl[i]);
470 }
471
472
473 int
474 hdfilord(hb1, hb2) /* order beams for quick loading */
475 register HDBEAMI *hb1, *hb2;
476 {
477 register off_t c;
478 /* residents go first */
479 if (hb2->h->bl[hb2->b] != NULL)
480 return(hb1->h->bl[hb1->b] == NULL);
481 if (hb1->h->bl[hb1->b] != NULL)
482 return(-1);
483 /* otherwise sort by file descriptor */
484 if (hb1->h->fd != hb2->h->fd)
485 return(hb1->h->fd - hb2->h->fd);
486 /* then by position in file */
487 c = hb1->h->bi[hb1->b].fo - hb2->h->bi[hb2->b].fo;
488 return(c > 0 ? 1 : c < 0 ? -1 : 0);
489 }
490
491
492 hdloadbeams(hb, n, bf) /* load a list of beams in optimal order */
493 register HDBEAMI *hb; /* list gets sorted by hdfilord() */
494 int n; /* list length */
495 void (*bf)(); /* callback function (optional) */
496 {
497 unsigned origcachesize, memuse;
498 int bytesloaded, needbytes, bytes2free;
499 register BEAM *bp;
500 register int i;
501 /* precheck consistency */
502 if (n <= 0) return;
503 for (i = n; i--; )
504 if (hb[i].h==NULL || (hb[i].b<1) | (hb[i].b>nbeams(hb[i].h)))
505 error(CONSISTENCY, "bad beam in hdloadbeams");
506 /* sort list for optimal access */
507 qsort((void *)hb, n, sizeof(HDBEAMI), hdfilord);
508 bytesloaded = 0; /* run through loaded beams */
509 for ( ; n && (bp = hb->h->bl[hb->b]) != NULL; n--, hb++) {
510 bp->tick = hdclock; /* preempt swap */
511 bytesloaded += bp->nrm;
512 if (bf != NULL)
513 (*bf)(bp, hb);
514 }
515 bytesloaded *= sizeof(RAYVAL);
516 if ((origcachesize = hdcachesize) > 0) {
517 needbytes = 0; /* figure out memory needs */
518 for (i = n; i--; )
519 needbytes += hb[i].h->bi[hb[i].b].nrd;
520 needbytes *= sizeof(RAYVAL);
521 do { /* free enough memory */
522 memuse = hdmemuse(0);
523 bytes2free = needbytes - (int)(hdcachesize-memuse);
524 if (bytes2free > (int)(memuse - bytesloaded))
525 bytes2free = memuse - bytesloaded;
526 } while (bytes2free > 0 &&
527 hdfreecache(100*bytes2free/memuse, NULL) < 0);
528 hdcachesize = 0; /* load beams w/o swap */
529 }
530 for (i = 0; i < n; i++)
531 if ((bp = hdgetbeam(hb[i].h, hb[i].b)) != NULL && bf != NULL)
532 (*bf)(bp, hb+i);
533 hdcachesize = origcachesize; /* resume dynamic swapping */
534 }
535
536
537 int
538 hdfreefrag(hp, i) /* free a file fragment */
539 HOLO *hp;
540 int i;
541 {
542 register BEAMI *bi = &hp->bi[i];
543 register struct fraglist *f;
544 register int j, k;
545
546 if (bi->nrd <= 0)
547 return(0);
548 DCHECK(hp->fd < 0 | hp->fd >= nhdfragls || !hdfragl[hp->fd].nlinks,
549 CONSISTENCY, "bad file descriptor in hdfreefrag");
550 f = &hdfragl[hp->fd];
551 if (!f->writable)
552 return(0);
553 if (f->nfrags % FRAGBLK == 0) { /* delete empty remnants */
554 for (j = k = 0; k < f->nfrags; j++, k++) {
555 while (f->fi[k].nrd == 0)
556 if (++k >= f->nfrags)
557 goto endloop;
558 if (k > j)
559 *(f->fi+j) = *(f->fi+k);
560 }
561 endloop:
562 f->nfrags = j;
563 }
564 j = f->nfrags++; /* allocate a slot in free list */
565 #if MAXFRAGB
566 if (j >= MAXFRAGB*FRAGBLK) {
567 f->nfrags = j--; /* stop list growth */
568 if (bi->nrd <= f->fi[j].nrd)
569 return(0); /* new one no better than discard */
570 }
571 #endif
572 if (j % FRAGBLK == 0) { /* more (or less) free list space */
573 register BEAMI *newp;
574 if (f->fi == NULL)
575 newp = (BEAMI *)malloc((j+FRAGBLK)*sizeof(BEAMI));
576 else
577 newp = (BEAMI *)realloc((void *)f->fi,
578 (j+FRAGBLK)*sizeof(BEAMI));
579 if (newp == NULL) {
580 f->nfrags--; /* graceful failure */
581 return(0);
582 }
583 f->fi = newp;
584 }
585 for ( ; ; j--) { /* insert in descending list */
586 if (!j || bi->fo < f->fi[j-1].fo) {
587 f->fi[j].fo = bi->fo;
588 f->fi[j].nrd = bi->nrd;
589 break;
590 }
591 *(f->fi+j) = *(f->fi+(j-1));
592 }
593 /* coalesce adjacent fragments */
594 /* successors never empty */
595 if (j && f->fi[j-1].fo == f->fi[j].fo + f->fi[j].nrd*sizeof(RAYVAL)) {
596 f->fi[j].nrd += f->fi[j-1].nrd;
597 f->fi[j-1].nrd = 0;
598 }
599 for (k = j+1; k < f->nfrags; k++) /* get non-empty predecessor */
600 if (f->fi[k].nrd) {
601 if (f->fi[j].fo == f->fi[k].fo +
602 f->fi[k].nrd*sizeof(RAYVAL)) {
603 f->fi[k].nrd += f->fi[j].nrd;
604 f->fi[j].nrd = 0;
605 }
606 break;
607 }
608 biglob(hp)->nrd -= bi->nrd; /* tell fragment it's free */
609 bi->nrd = 0;
610 bi->fo = 0;
611 hdmarkdirty(hp, i); /* assume we'll reallocate */
612 return(1);
613 }
614
615
616 int
617 hdfragOK(fd, listlen, listsiz) /* get fragment list status for file */
618 int fd;
619 int *listlen;
620 register int32 *listsiz;
621 {
622 register struct fraglist *f;
623 register int i;
624
625 if ((fd < 0) | (fd >= nhdfragls) || !(f = &hdfragl[fd])->nlinks)
626 return(0); /* listless */
627 if (listlen != NULL)
628 *listlen = f->nfrags;
629 if (listsiz != NULL)
630 for (i = f->nfrags, *listsiz = 0; i--; )
631 *listsiz += f->fi[i].nrd;
632 #if MAXFRAGB
633 return(f->nfrags < MAXFRAGB*FRAGBLK);
634 #else
635 return(1); /* list never fills up */
636 #endif
637 }
638
639
640 off_t
641 hdallocfrag(fd, nrays) /* allocate a file fragment */
642 int fd;
643 uint32 nrays;
644 {
645 register struct fraglist *f;
646 register int j;
647 off_t nfo;
648
649 if (nrays == 0)
650 return(-1L);
651 DCHECK(fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks,
652 CONSISTENCY, "bad file descriptor in hdallocfrag");
653 f = &hdfragl[fd];
654 for (j = f->nfrags; j-- > 0; ) /* first fit algorithm */
655 if (f->fi[j].nrd >= nrays)
656 break;
657 if (j < 0) { /* no fragment -- extend file */
658 nfo = f->flen;
659 f->flen += nrays*sizeof(RAYVAL);
660 } else { /* else use fragment */
661 nfo = f->fi[j].fo;
662 f->fi[j].fo += nrays*sizeof(RAYVAL);
663 f->fi[j].nrd -= nrays;
664 }
665 return(nfo);
666 }
667
668
669 int
670 hdsyncbeam(hp, i) /* sync beam in memory with beam on disk */
671 register HOLO *hp;
672 register int i;
673 {
674 int fragfreed;
675 uint32 nrays;
676 unsigned int n;
677 off_t nfo;
678 /* check file status */
679 if (hdfragl[hp->fd].writable <= 0)
680 return(hdfragl[hp->fd].writable);
681 DCHECK(i < 1 | i > nbeams(hp),
682 CONSISTENCY, "bad beam index in hdsyncbeam");
683 /* is current fragment OK? */
684 if (hp->bl[i] == NULL || (nrays = hp->bl[i]->nrm) == hp->bi[i].nrd)
685 return(0);
686 /* relinquish old fragment? */
687 fragfreed = hdfragflags&FF_WRITE && hp->bi[i].nrd && hdfreefrag(hp,i);
688 if (nrays) { /* get and write new fragment */
689 nfo = hdallocfrag(hp->fd, nrays);
690 errno = 0;
691 if (lseek(hp->fd, nfo, 0) < 0)
692 error(SYSTEM, "cannot seek on holodeck file");
693 n = hp->bl[i]->nrm * sizeof(RAYVAL);
694 if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) {
695 hdfragl[hp->fd].writable = -1;
696 hdsync(NULL, 0); /* sync directories */
697 error(SYSTEM, "write error in hdsyncbeam");
698 }
699 hp->bi[i].fo = nfo;
700 } else
701 hp->bi[i].fo = 0;
702 biglob(hp)->nrd += nrays - hp->bi[i].nrd;
703 hp->bi[i].nrd = nrays;
704 if (!fragfreed)
705 hdmarkdirty(hp, i); /* need to flag dir. ent. */
706 return(1);
707 }
708
709
710 int
711 hdfreebeam(hp, i) /* free beam, writing if dirty */
712 register HOLO *hp;
713 register int i;
714 {
715 int nchanged;
716
717 if (hp == NULL) { /* clear all holodecks */
718 nchanged = 0;
719 for (i = 0; hdlist[i] != NULL; i++)
720 nchanged += hdfreebeam(hdlist[i], 0);
721 return(nchanged);
722 }
723 if (hdfragl[hp->fd].writable < 0) /* check for file error */
724 return(0);
725 if (i == 0) { /* clear entire holodeck */
726 if (blglob(hp)->nrm == 0)
727 return(0); /* already clear */
728 nchanged = 0;
729 for (i = nbeams(hp); i > 0; i--)
730 if (hp->bl[i] != NULL)
731 nchanged += hdfreebeam(hp, i);
732 DCHECK(blglob(hp)->nrm != 0,
733 CONSISTENCY, "bad beam count in hdfreebeam");
734 return(nchanged);
735 }
736 DCHECK(i < 1 | i > nbeams(hp),
737 CONSISTENCY, "bad beam index to hdfreebeam");
738 if (hp->bl[i] == NULL)
739 return(0);
740 /* check for additions */
741 nchanged = hp->bl[i]->nrm - hp->bi[i].nrd;
742 if (nchanged)
743 hdsyncbeam(hp, i); /* write new fragment */
744 blglob(hp)->nrm -= hp->bl[i]->nrm;
745 free((void *)hp->bl[i]); /* free memory */
746 hp->bl[i] = NULL;
747 return(nchanged);
748 }
749
750
751 int
752 hdkillbeam(hp, i) /* delete beam from holodeck */
753 register HOLO *hp;
754 register int i;
755 {
756 int nchanged;
757
758 if (hp == NULL) { /* clobber all holodecks */
759 nchanged = 0;
760 for (i = 0; hdlist[i] != NULL; i++)
761 nchanged += hdkillbeam(hdlist[i], 0);
762 return(nchanged);
763 }
764 if (i == 0) { /* clobber entire holodeck */
765 if ((biglob(hp)->nrd == 0) & (blglob(hp)->nrm == 0))
766 return(0); /* already empty */
767 nchanged = 0;
768 nchanged = 0;
769 for (i = nbeams(hp); i > 0; i--)
770 if (hp->bi[i].nrd > 0 || hp->bl[i] != NULL)
771 nchanged += hdkillbeam(hp, i);
772 DCHECK(biglob(hp)->nrd != 0 | blglob(hp)->nrm != 0,
773 CONSISTENCY, "bad beam count in hdkillbeam");
774 return(nchanged);
775 }
776 DCHECK(i < 1 | i > nbeams(hp), CONSISTENCY,
777 "bad beam index to hdkillbeam");
778 DCHECK(!hdfragl[hp->fd].writable, CONSISTENCY,
779 "hdkillbeam called on read-only holodeck");
780 if (hp->bl[i] != NULL) { /* free memory */
781 blglob(hp)->nrm -= nchanged = hp->bl[i]->nrm;
782 free((void *)hp->bl[i]);
783 hp->bl[i] = NULL;
784 } else
785 nchanged = hp->bi[i].nrd;
786 if (hp->bi[i].nrd && !(hdfragflags&FF_KILL && hdfreefrag(hp,i))) {
787 biglob(hp)->nrd -= hp->bi[i].nrd; /* free failed */
788 hp->bi[i].nrd = 0;
789 hp->bi[i].fo = 0;
790 hdmarkdirty(hp, i);
791 }
792 return(nchanged);
793 }
794
795
796 int
797 hdlrulist(hb, nents, n, hp) /* add beams from holodeck to LRU list */
798 register HDBEAMI *hb; /* beam list */
799 int nents; /* current list length */
800 int n; /* maximum list length */
801 register HOLO *hp; /* section we're adding from */
802 {
803 register int i, j;
804 /* insert each beam from hp */
805 for (i = 1; i <= nbeams(hp); i++) {
806 if (hp->bl[i] == NULL) /* check if loaded */
807 continue;
808 #if 0
809 if (hp->bl[i]->tick == hdclock) /* preempt swap? */
810 continue;
811 #endif
812 if ((j = ++nents) >= n) /* grow list if we can */
813 nents--;
814 for ( ; ; ) { /* bubble into place */
815 if (!--j || hp->bl[i]->tick >=
816 hb[j-1].h->bl[hb[j-1].b]->tick) {
817 hb[j].h = hp;
818 hb[j].b = i;
819 break;
820 }
821 *(hb+j) = *(hb+(j-1));
822 }
823 }
824 return(nents); /* return new list length */
825 }
826
827
828 int
829 hdfreecache(pct, honly) /* free up cache space, writing changes */
830 int pct; /* maximum percentage to free */
831 register HOLO *honly; /* NULL means check all */
832 {
833 HDBEAMI hb[FREEBEAMS];
834 int freetarget;
835 int n;
836 register int i;
837 #ifdef DEBUG
838 unsigned membefore;
839
840 membefore = hdmemuse(0);
841 #endif
842 /* compute free target */
843 freetarget = (honly != NULL) ? blglob(honly)->nrm :
844 hdmemuse(0)/sizeof(RAYVAL) ;
845 freetarget = freetarget*pct/100;
846 if (freetarget <= 0)
847 return(0);
848 /* find least recently used */
849 n = 0;
850 if (honly != NULL)
851 n = hdlrulist(hb, n, FREEBEAMS, honly);
852 else
853 for (i = 0; hdlist[i] != NULL; i++)
854 n = hdlrulist(hb, n, FREEBEAMS, hdlist[i]);
855 /* free LRU beams */
856 for (i = 0; i < n; i++) {
857 hdfreebeam(hb[i].h, hb[i].b);
858 if ((freetarget -= hb[i].h->bi[hb[i].b].nrd) <= 0)
859 break;
860 }
861 hdsync(honly, 0); /* synchronize directories as necessary */
862 #ifdef DEBUG
863 sprintf(errmsg,
864 "%dK before, %dK after hdfreecache (%dK total), %d rays short\n",
865 membefore>>10, hdmemuse(0)>>10, hdmemuse(1)>>10, freetarget);
866 wputs(errmsg);
867 #endif
868 return(-freetarget); /* return how far past goal we went */
869 }
870
871
872 hddone(hp) /* clean up holodeck section and free */
873 register HOLO *hp; /* NULL means clean up all */
874 {
875 register int i;
876
877 if (hp == NULL) { /* NULL means clean up everything */
878 while (hdlist[0] != NULL)
879 hddone(hdlist[0]);
880 free((void *)hdfragl);
881 hdfragl = NULL; nhdfragls = 0;
882 return;
883 }
884 /* flush all data and free memory */
885 hdflush(hp);
886 /* release fragment resources */
887 hdrelease(hp->fd);
888 /* remove hp from active list */
889 for (i = 0; hdlist[i] != NULL; i++)
890 if (hdlist[i] == hp) {
891 while ((hdlist[i] = hdlist[i+1]) != NULL)
892 i++;
893 break;
894 }
895 free((void *)hp->bl); /* free beam list */
896 free((void *)hp); /* free holodeck struct */
897 }
