root/radiance/ray/src/hd/holofile.c
Revision: 3.25
Committed: Fri Sep 18 13:51:01 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.24: +15 -5 lines
added debugging statement to track hdfreecache() performance
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Routines for managing holodeck files
9 *
10 * 9/30/97 GWLarson
11 */
12
13 #include "holo.h"
14
15 #ifndef CACHESIZE
16 #define CACHESIZE 16 /* default cache size (Mbytes, 0==inf) */
17 #endif
18 #ifndef FREEBEAMS
19 #define FREEBEAMS 1500 /* maximum beams to free at a time */
20 #endif
21 #ifndef PCTFREE
22 #define PCTFREE 15 /* maximum fraction to free (%) */
23 #endif
24 #ifndef MAXFRAG
25 #define MAXFRAG 32767 /* maximum fragments/file to track (0==inf) */
26 #endif
27
28 #ifndef BSD
29 #define write writebuf /* safe i/o routines */
30 #define read readbuf
31 #endif
32
33 #define FRAGBLK 256 /* number of fragments to allocate at a time */
34
35 unsigned hdcachesize = CACHESIZE*1024*1024; /* target cache size */
36 unsigned long hdclock; /* clock value */
37
38 HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */
39
40 static struct fraglist {
41 short nlinks; /* number of holodeck sections using us */
42 short writerr; /* write error encountered */
43 int nfrags; /* number of known fragments */
44 BEAMI *fi; /* fragments, descending file position */
45 long flen; /* last known file length */
46 } *hdfragl; /* fragment lists, indexed by file descriptor */
47
48 static int nhdfragls; /* size of hdfragl array */
49
50
51 hdattach(fd) /* start tracking file fragments for some section */
52 register int fd;
53 {
54 if (fd >= nhdfragls) {
55 if (nhdfragls)
56 hdfragl = (struct fraglist *)realloc((char *)hdfragl,
57 (fd+1)*sizeof(struct fraglist));
58 else
59 hdfragl = (struct fraglist *)malloc(
60 (fd+1)*sizeof(struct fraglist));
61 if (hdfragl == NULL)
62 error(SYSTEM, "out of memory in hdattach");
63 bzero((char *)(hdfragl+nhdfragls),
64 (fd+1-nhdfragls)*sizeof(struct fraglist));
65 nhdfragls = fd+1;
66 }
67 hdfragl[fd].nlinks++;
68 hdfragl[fd].flen = lseek(fd, 0L, 2); /* get file length */
69 }
70
71
72 /* Do we need a routine to locate file fragments given known occupants? */
73
74
75 hdrelease(fd) /* stop tracking file fragments for some section */
76 register int fd;
77 {
78 if (fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks)
79 return;
80 if (!--hdfragl[fd].nlinks && hdfragl[fd].nfrags) {
81 free((char *)hdfragl[fd].fi);
82 hdfragl[fd].fi = NULL;
83 hdfragl[fd].nfrags = 0;
84 }
85 }
86
87
88 markdirty(hp) /* mark holodeck section directory dirty */
89 register HOLO *hp;
90 {
91 static BEAMI smudge = {0, -1};
92
93 if (hp->dirty) /* already marked? */
94 return;
95 hp->dirty = 1;
96 if (lseek(hp->fd, biglob(hp)->fo+(nbeams(hp)-1)*sizeof(BEAMI), 0) < 0
97 || write(hp->fd, (char *)&smudge,
98 sizeof(BEAMI)) != sizeof(BEAMI))
99 error(SYSTEM, "seek/write error in markdirty");
100 }
101
102
103 HOLO *
104 hdinit(fd, hproto) /* initialize a holodeck section in a file */
105 int fd; /* corresponding file descriptor */
106 HDGRID *hproto; /* holodeck section grid */
107 {
108 long rtrunc;
109 long fpos;
110 register HOLO *hp;
111 register int n;
112 /* prepare for system errors */
113 errno = 0;
114 if ((fpos = lseek(fd, 0L, 1)) < 0)
115 error(SYSTEM, "cannot determine holodeck file position");
116 if (hproto == NULL) { /* assume we're loading it */
117 HDGRID hpr;
118 /* load header */
119 if (read(fd, (char *)&hpr, sizeof(HDGRID)) != sizeof(HDGRID))
120 error(SYSTEM, "cannot load holodeck header");
121 /* allocate grid */
122 if ((hp = hdalloc(&hpr)) == NULL)
123 goto memerr;
124 /* load beam directory */
125 n = nbeams(hp)*sizeof(BEAMI);
126 if (read(fd, (char *)(hp->bi+1), n) != n)
127 error(SYSTEM, "failure loading holodeck directory");
128 /* check that it's clean */
129 if (hp->bi[nbeams(hp)].fo < 0)
130 error(WARNING, "dirty holodeck section");
131 } else { /* assume we're creating it */
132 if ((hp = hdalloc(hproto)) == NULL)
133 goto memerr;
134 /* write header and skeleton */
135 n = nbeams(hp)*sizeof(BEAMI);
136 if (write(fd, (char *)hproto, sizeof(HDGRID)) !=
137 sizeof(HDGRID) ||
138 write(fd, (char *)(hp->bi+1), n) != n)
139 error(SYSTEM, "cannot write header to holodeck file");
140 }
141 hp->fd = fd;
142 hp->dirty = 0;
143 biglob(hp)->fo = fpos + sizeof(HDGRID);
144 /* start tracking fragments */
145 hdattach(fd);
146 /* check rays on disk */
147 fpos = hdfilen(fd);
148 biglob(hp)->nrd = rtrunc = 0;
149 for (n = hproto == NULL ? nbeams(hp) : 0; n > 0; n--)
150 if (hp->bi[n].nrd)
151 if (hp->bi[n].fo + hp->bi[n].nrd > fpos) {
152 rtrunc += hp->bi[n].nrd;
153 hp->bi[n].nrd = 0;
154 } else
155 biglob(hp)->nrd += hp->bi[n].nrd;
156 if (rtrunc) {
157 sprintf(errmsg, "truncated section, %ld rays lost (%.1f%%)",
158 rtrunc, 100.*rtrunc/(rtrunc+biglob(hp)->nrd));
159 error(WARNING, errmsg);
160 }
161 /* add to holodeck list */
162 for (n = 0; n < HDMAX; n++)
163 if (hdlist[n] == NULL) {
164 hdlist[n] = hp;
165 break;
166 }
167 /* all done */
168 return(hp);
169 memerr:
170 error(SYSTEM, "cannot allocate holodeck grid");
171 }
172
173
174 int
175 hdsync(hp, all) /* update beams and directory on disk */
176 register HOLO *hp;
177 int all;
178 {
179 register int j, n;
180
181 if (hp == NULL) { /* do all holodecks */
182 n = 0;
183 for (j = 0; hdlist[j] != NULL; j++)
184 n += hdsync(hdlist[j], all);
185 return(n);
186 }
187 /* sync the beams */
188 for (j = (all ? nbeams(hp) : 0); j > 0; j--)
189 if (hp->bl[j] != NULL)
190 hdsyncbeam(hp, j);
191 if (!hp->dirty) /* directory clean? */
192 return(0);
193 errno = 0;
194 if (lseek(hp->fd, biglob(hp)->fo, 0) < 0)
195 error(SYSTEM, "cannot seek on holodeck file");
196 n = nbeams(hp)*sizeof(BEAMI);
197 if (write(hp->fd, (char *)(hp->bi+1), n) != n)
198 error(SYSTEM, "cannot update holodeck section directory");
199 hp->dirty = 0;
200 return(1);
201 }
202
203
204 unsigned
205 hdmemuse(all) /* return memory usage (in bytes) */
206 int all; /* include overhead (painful) */
207 {
208 long total = 0;
209 register int i, j;
210
211 for (j = 0; hdlist[j] != NULL; j++) {
212 total += blglob(hdlist[j])->nrm * sizeof(RAYVAL);
213 if (all) {
214 total += sizeof(HOLO) + sizeof(BEAM *) +
215 nbeams(hdlist[j]) *
216 (sizeof(BEAM *)+sizeof(BEAMI));
217 for (i = nbeams(hdlist[j]); i > 0; i--)
218 if (hdlist[j]->bl[i] != NULL)
219 total += sizeof(BEAM);
220 }
221 }
222 if (all)
223 for (j = 0; j < nhdfragls; j++) {
224 total += sizeof(struct fraglist);
225 if (hdfragl[j].nfrags)
226 total += FRAGBLK*sizeof(BEAMI) *
227 ((hdfragl[j].nfrags-1)/FRAGBLK + 1) ;
228 }
229 return(total);
230 }
231
232
233 long
234 hdfilen(fd) /* return file length for fd */
235 int fd;
236 {
237 long fpos, flen;
238
239 if (fd < 0)
240 return(-1);
241 if (fd >= nhdfragls || !hdfragl[fd].nlinks) {
242 if ((fpos = lseek(fd, 0L, 1)) < 0)
243 return(-1);
244 flen = lseek(fd, 0L, 2);
245 lseek(fd, fpos, 0);
246 return(flen);
247 }
248 return(hdfragl[fd].flen);
249 }
250
251
252 long
253 hdfiluse(fd, all) /* compute file usage (in bytes) */
254 int fd; /* open file descriptor to check */
255 int all; /* include overhead and unflushed data */
256 {
257 long total = 0;
258 register int i, j;
259
260 for (j = 0; hdlist[j] != NULL; j++) {
261 if (hdlist[j]->fd != fd)
262 continue;
263 total += biglob(hdlist[j])->nrd * sizeof(RAYVAL);
264 if (all) {
265 for (i = nbeams(hdlist[j]); i > 0; i--)
266 if (hdlist[j]->bl[i] != NULL)
267 total += sizeof(RAYVAL) *
268 (hdlist[j]->bl[i]->nrm -
269 hdlist[j]->bi[i].nrd);
270 total += sizeof(HDGRID) +
271 nbeams(hdlist[j])*sizeof(BEAMI);
272 }
273 }
274 return(total); /* does not include fragments */
275 }
276
277
278 RAYVAL *
279 hdnewrays(hp, i, nr) /* allocate space for add'l rays and return pointer */
280 register HOLO *hp;
281 register int i;
282 int nr; /* number of new rays desired */
283 {
284 RAYVAL *p;
285 int n;
286
287 if (nr <= 0)
288 return(NULL);
289 if (i < 1 | i > nbeams(hp))
290 error(CONSISTENCY, "bad beam index given to hdnewrays");
291 if (hp->bl[i] != NULL)
292 hp->bl[i]->tick = hdclock; /* preempt swap */
293 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
294 hdfreecache(PCTFREE, NULL); /* free some space */
295 errno = 0;
296 if (hp->bl[i] == NULL) { /* allocate (and load) */
297 n = hp->bi[i].nrd + nr;
298 if ((hp->bl[i] = (BEAM *)malloc(hdbsiz(n))) == NULL)
299 goto memerr;
300 blglob(hp)->nrm += n;
301 if (n = hp->bl[i]->nrm = hp->bi[i].nrd) {
302 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
303 error(SYSTEM, "seek error on holodeck file");
304 n *= sizeof(RAYVAL);
305 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
306 error(SYSTEM,
307 "error reading beam from holodeck file");
308 }
309 } else { /* just grow in memory */
310 hp->bl[i] = (BEAM *)realloc( (char *)hp->bl[i],
311 hdbsiz(hp->bl[i]->nrm + nr) );
312 if (hp->bl[i] == NULL)
313 goto memerr;
314 blglob(hp)->nrm += nr;
315 }
316 p = hdbray(hp->bl[i]) + hp->bl[i]->nrm;
317 hp->bl[i]->nrm += nr; /* update in-core structure */
318 bzero((char *)p, nr*sizeof(RAYVAL));
319 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
320 return(p); /* point to new rays */
321 memerr:
322 error(SYSTEM, "out of memory in hdnewrays");
323 }
324
325
326 BEAM *
327 hdgetbeam(hp, i) /* get beam (from file if necessary) */
328 register HOLO *hp;
329 register int i;
330 {
331 register int n;
332
333 if (i < 1 | i > nbeams(hp))
334 error(CONSISTENCY, "bad beam index given to hdgetbeam");
335 if (hp->bl[i] == NULL) { /* load from disk */
336 if (!(n = hp->bi[i].nrd))
337 return(NULL);
338 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
339 hdfreecache(PCTFREE, NULL); /* get free space */
340 errno = 0;
341 if ((hp->bl[i] = (BEAM *)malloc(hdbsiz(n))) == NULL)
342 error(SYSTEM, "cannot allocate memory for beam");
343 blglob(hp)->nrm += hp->bl[i]->nrm = n;
344 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
345 error(SYSTEM, "seek error on holodeck file");
346 n *= sizeof(RAYVAL);
347 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
348 error(SYSTEM, "error reading beam from holodeck file");
349 }
350 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
351 return(hp->bl[i]);
352 }
353
354
355 int
356 hdfilord(hb1, hb2) /* order beams for quick loading */
357 register HDBEAMI *hb1, *hb2;
358 {
359 register long c;
360 /* residents go first */
361 if (hb2->h->bl[hb2->b] != NULL)
362 return(hb1->h->bl[hb1->b] == NULL);
363 if (hb1->h->bl[hb1->b] != NULL)
364 return(-1);
365 /* otherwise sort by file descriptor */
366 if ((c = hb1->h->fd - hb2->h->fd))
367 return(c);
368 /* then by position in file */
369 c = hb1->h->bi[hb1->b].fo - hb2->h->bi[hb2->b].fo;
370 return(c > 0 ? 1 : c < 0 ? -1 : 0);
371 }
372
373
374 hdloadbeams(hb, n, bf) /* load a list of beams in optimal order */
375 register HDBEAMI *hb; /* list gets sorted by hdfilord() */
376 int n; /* list length */
377 int (*bf)(); /* callback function (optional) */
378 {
379 unsigned origcachesize, memuse;
380 int bytesloaded, needbytes, bytes2free;
381 register BEAM *bp;
382 register int i;
383 /* precheck consistency */
384 if (n <= 0) return;
385 for (i = n; i--; )
386 if (hb[i].h == NULL || hb[i].b < 1 | hb[i].b > nbeams(hb[i].h))
387 error(CONSISTENCY, "bad beam in hdloadbeams");
388 /* sort list for optimal access */
389 qsort((char *)hb, n, sizeof(HDBEAMI), hdfilord);
390 bytesloaded = 0; /* run through loaded beams */
391 for ( ; n && (bp = hb->h->bl[hb->b]) != NULL; n--, hb++) {
392 bp->tick = hdclock; /* preempt swap */
393 bytesloaded += bp->nrm;
394 if (bf != NULL)
395 (*bf)(bp, hb);
396 }
397 bytesloaded *= sizeof(RAYVAL);
398 if ((origcachesize = hdcachesize) > 0) {
399 needbytes = 0; /* figure out memory needs */
400 for (i = n; i--; )
401 needbytes += hb[i].h->bi[hb[i].b].nrd;
402 needbytes *= sizeof(RAYVAL);
403 do { /* free enough memory */
404 memuse = hdmemuse(0);
405 bytes2free = needbytes - (int)(hdcachesize-memuse);
406 if (bytes2free > (int)(memuse - bytesloaded))
407 bytes2free = memuse - bytesloaded;
408 } while (bytes2free > 0 &&
409 hdfreecache(100*bytes2free/memuse, NULL) < 0);
410 hdcachesize = 0; /* load beams w/o swap */
411 }
412 for (i = 0; i < n; i++)
413 if ((bp = hdgetbeam(hb[i].h, hb[i].b)) != NULL && bf != NULL)
414 (*bf)(bp, hb+i);
415 hdcachesize = origcachesize; /* resume dynamic swapping */
416 }
417
418
419 hdfreefrag(fd, bi) /* free a file fragment */
420 int fd;
421 register BEAMI *bi;
422 {
423 register struct fraglist *f;
424 register int j, k;
425
426 if (bi->nrd == 0)
427 return;
428 #ifdef DEBUG
429 if (fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks)
430 error(CONSISTENCY, "bad file descriptor in hdfreefrag");
431 #endif
432 f = &hdfragl[fd];
433 if (f->nfrags % FRAGBLK == 0) { /* delete empty remnants */
434 for (j = k = 0; k < f->nfrags; j++, k++) {
435 while (f->fi[k].nrd == 0)
436 if (++k >= f->nfrags)
437 goto endloop;
438 if (k > j)
439 copystruct(f->fi+j, f->fi+k);
440 }
441 endloop:
442 f->nfrags = j;
443 }
444 j = f->nfrags++; /* allocate a slot in free list */
445 #if MAXFRAG
446 if (j >= MAXFRAG-1)
447 f->nfrags--;
448 #endif
449 if (j % FRAGBLK == 0) { /* more free list space */
450 if (f->fi == NULL)
451 f->fi = (BEAMI *)malloc(FRAGBLK*sizeof(BEAMI));
452 else
453 f->fi = (BEAMI *)realloc((char *)f->fi,
454 (j+FRAGBLK)*sizeof(BEAMI));
455 if (f->fi == NULL)
456 error(SYSTEM, "out of memory in hdfreefrag");
457 }
458 for ( ; ; j--) { /* insert in descending list */
459 if (!j || bi->fo < f->fi[j-1].fo) {
460 f->fi[j].fo = bi->fo;
461 f->fi[j].nrd = bi->nrd;
462 break;
463 }
464 copystruct(f->fi+j, f->fi+(j-1));
465 }
466 /* coalesce adjacent fragments */
467 /* successors never empty */
468 if (j && f->fi[j-1].fo == f->fi[j].fo + f->fi[j].nrd*sizeof(RAYVAL)) {
469 f->fi[j].nrd += f->fi[j-1].nrd;
470 f->fi[j-1].nrd = 0;
471 }
472 for (k = j+1; k < f->nfrags; k++) /* get non-empty predecessor */
473 if (f->fi[k].nrd) {
474 if (f->fi[j].fo == f->fi[k].fo +
475 f->fi[k].nrd*sizeof(RAYVAL)) {
476 f->fi[k].nrd += f->fi[j].nrd;
477 f->fi[j].nrd = 0;
478 }
479 break;
480 }
481 }
482
483
484 long
485 hdallocfrag(fd, nrays) /* allocate a file fragment */
486 int fd;
487 unsigned int4 nrays;
488 {
489 register struct fraglist *f;
490 register int j, k;
491 long nfo;
492
493 if (nrays == 0)
494 return(-1L);
495 #ifdef DEBUG
496 if (fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks)
497 error(CONSISTENCY, "bad file descriptor in hdallocfrag");
498 #endif
499 f = &hdfragl[fd];
500 k = -1; /* find closest-sized fragment */
501 for (j = f->nfrags; j-- > 0; )
502 if (f->fi[j].nrd >= nrays &&
503 (k < 0 || f->fi[j].nrd < f->fi[k].nrd))
504 if (f->fi[k=j].nrd == nrays)
505 break;
506 if (k < 0) { /* no fragment -- extend file */
507 nfo = f->flen;
508 f->flen += nrays*sizeof(RAYVAL);
509 } else { /* else use fragment */
510 nfo = f->fi[k].fo;
511 f->fi[k].fo += nrays*sizeof(RAYVAL);
512 f->fi[k].nrd -= nrays;
513 }
514 return(nfo);
515 }
516
517
518 int
519 hdsyncbeam(hp, i) /* sync beam in memory with beam on disk */
520 register HOLO *hp;
521 register int i;
522 {
523 unsigned int4 nrays;
524 unsigned int n;
525 long nfo;
526 /* check file status */
527 if (hdfragl[hp->fd].writerr)
528 return(-1);
529 #ifdef DEBUG
530 if (i < 1 | i > nbeams(hp))
531 error(CONSISTENCY, "bad beam index in hdsyncbeam");
532 #endif
533 /* is current fragment OK? */
534 if (hp->bl[i] == NULL || (nrays = hp->bl[i]->nrm) == hp->bi[i].nrd)
535 return(0);
536 if (hp->bi[i].nrd) /* relinquish old fragment */
537 hdfreefrag(hp->fd, &hp->bi[i]);
538 if (nrays) { /* get and write new fragment */
539 nfo = hdallocfrag(hp->fd, nrays);
540 errno = 0;
541 if (lseek(hp->fd, nfo, 0) < 0)
542 error(SYSTEM, "cannot seek on holodeck file");
543 n = hp->bl[i]->nrm * sizeof(RAYVAL);
544 if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) {
545 hdfragl[hp->fd].writerr++;
546 hdsync(NULL, 0); /* sync directories */
547 error(SYSTEM, "write error in hdsyncbeam");
548 }
549 hp->bi[i].fo = nfo;
550 } else
551 hp->bi[i].fo = 0L;
552 biglob(hp)->nrd += nrays - hp->bi[i].nrd;
553 hp->bi[i].nrd = nrays;
554 markdirty(hp); /* section directory now out of date */
555 return(1);
556 }
557
558
559 int
560 hdfreebeam(hp, i) /* free beam, writing if dirty */
561 register HOLO *hp;
562 register int i;
563 {
564 int nchanged;
565
566 if (hp == NULL) { /* clear all holodecks */
567 nchanged = 0;
568 for (i = 0; hdlist[i] != NULL; i++)
569 nchanged += hdfreebeam(hdlist[i], 0);
570 return(nchanged);
571 }
572 if (hdfragl[hp->fd].writerr) /* check for file error */
573 return(0);
574 if (i == 0) { /* clear entire holodeck */
575 nchanged = 0;
576 for (i = nbeams(hp); i > 0; i--)
577 if (hp->bl[i] != NULL)
578 nchanged += hdfreebeam(hp, i);
579 return(nchanged);
580 }
581 #ifdef DEBUG
582 if (i < 1 | i > nbeams(hp))
583 error(CONSISTENCY, "bad beam index to hdfreebeam");
584 #endif
585 if (hp->bl[i] == NULL)
586 return(0);
587 /* check for additions */
588 nchanged = hp->bl[i]->nrm - hp->bi[i].nrd;
589 if (nchanged)
590 hdsyncbeam(hp, i); /* write new fragment */
591 blglob(hp)->nrm -= hp->bl[i]->nrm;
592 free((char *)hp->bl[i]); /* free memory */
593 hp->bl[i] = NULL;
594 return(nchanged);
595 }
596
597
598 int
599 hdkillbeam(hp, i) /* delete beam from holodeck */
600 register HOLO *hp;
601 register int i;
602 {
603 static BEAM emptybeam;
604 int nchanged;
605
606 if (hp == NULL) { /* clobber all holodecks */
607 nchanged = 0;
608 for (i = 0; hdlist[i] != NULL; i++)
609 nchanged += hdkillbeam(hdlist[i], 0);
610 return(nchanged);
611 }
612 if (i == 0) { /* clobber entire holodeck */
613 nchanged = 0;
614 for (i = nbeams(hp); i > 0; i--)
615 if (hp->bi[i].nrd > 0 || hp->bl[i] != NULL)
616 nchanged += hdkillbeam(hp, i);
617 #ifdef DEBUG
618 if (biglob(hp)->nrd != 0 | blglob(hp)->nrm != 0)
619 error(CONSISTENCY, "bad beam count in hdkillbeam");
620 #endif
621 return(nchanged);
622 }
623 #ifdef DEBUG
624 if (i < 1 | i > nbeams(hp))
625 error(CONSISTENCY, "bad beam index to hdkillbeam");
626 #endif
627 if (hp->bl[i] != NULL) { /* free memory */
628 blglob(hp)->nrm -= nchanged = hp->bl[i]->nrm;
629 free((char *)hp->bl[i]);
630 } else
631 nchanged = hp->bi[i].nrd;
632 if (hp->bi[i].nrd) { /* free file fragment */
633 hp->bl[i] = &emptybeam;
634 hdsyncbeam(hp, i);
635 }
636 hp->bl[i] = NULL;
637 return(nchanged);
638 }
639
640
641 int
642 hdlrulist(hb, nents, n, hp) /* add beams from holodeck to LRU list */
643 register HDBEAMI *hb; /* beam list */
644 int nents; /* current list length */
645 int n; /* maximum list length */
646 register HOLO *hp; /* section we're adding from */
647 {
648 register int i, j;
649 /* insert each beam from hp */
650 for (i = 1; i <= nbeams(hp); i++) {
651 if (hp->bl[i] == NULL) /* check if loaded */
652 continue;
653 #if 0
654 if (hp->bl[i]->tick == hdclock) /* preempt swap? */
655 continue;
656 #endif
657 if ((j = ++nents) >= n) /* grow list if we can */
658 nents--;
659 for ( ; ; ) { /* bubble into place */
660 if (!--j || hp->bl[i]->tick >=
661 hb[j-1].h->bl[hb[j-1].b]->tick) {
662 hb[j].h = hp;
663 hb[j].b = i;
664 break;
665 }
666 copystruct(hb+j, hb+(j-1));
667 }
668 }
669 return(nents); /* return new list length */
670 }
671
672
673 int
674 hdfreecache(pct, honly) /* free up cache space, writing changes */
675 int pct; /* maximum percentage to free */
676 register HOLO *honly; /* NULL means check all */
677 {
678 HDBEAMI hb[FREEBEAMS];
679 int freetarget;
680 int n;
681 register int i;
682 #ifdef DEBUG
683 unsigned membefore;
684
685 membefore = hdmemuse(0);
686 #endif
687 /* compute free target */
688 freetarget = (honly != NULL) ? blglob(honly)->nrm :
689 hdmemuse(0)/sizeof(RAYVAL) ;
690 freetarget = freetarget*pct/100;
691 if (freetarget <= 0)
692 return(0);
693 /* find least recently used */
694 n = 0;
695 if (honly != NULL)
696 n = hdlrulist(hb, n, FREEBEAMS, honly);
697 else
698 for (i = 0; hdlist[i] != NULL; i++)
699 n = hdlrulist(hb, n, FREEBEAMS, hdlist[i]);
700 /* free LRU beams */
701 for (i = 0; i < n; i++) {
702 hdfreebeam(hb[i].h, hb[i].b);
703 if ((freetarget -= hb[i].h->bi[hb[i].b].nrd) <= 0)
704 break;
705 }
706 hdsync(honly, 0); /* synchronize directories as necessary */
707 #ifdef DEBUG
708 sprintf(errmsg,
709 "%dK before, %dK after hdfreecache (%dK total), %d rays short\n",
710 membefore>>10, hdmemuse(0)>>10, hdmemuse(1)>>10, freetarget);
711 wputs(errmsg);
712 #endif
713 return(-freetarget); /* return how far past goal we went */
714 }
715
716
717 hddone(hp) /* clean up holodeck section and free */
718 register HOLO *hp; /* NULL means clean up all */
719 {
720 register int i;
721
722 if (hp == NULL) { /* NULL means clean up everything */
723 while (hdlist[0] != NULL)
724 hddone(hdlist[0]);
725 free((char *)hdfragl);
726 hdfragl = NULL; nhdfragls = 0;
727 return;
728 }
729 /* flush all data and free memory */
730 hdflush(hp);
731 /* release fragment resources */
732 hdrelease(hp->fd);
733 /* remove hp from active list */
734 for (i = 0; hdlist[i] != NULL; i++)
735 if (hdlist[i] == hp) {
736 while ((hdlist[i] = hdlist[i+1]) != NULL)
737 i++;
738 break;
739 }
740 free((char *)hp->bl); /* free beam list */
741 free((char *)hp); /* free holodeck struct */
742 }
