root/radiance/ray/src/hd/holofile.c
Revision: 3.1
Committed: Fri Oct 31 10:23:29 1997 UTC (27 years, 7 months ago) by gregl
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Routines for managing holodeck files
9 *
10 * 9/30/97 GWLarson
11 */
12
13 #include "holo.h"
14
15 #ifndef CACHESIZE
16 #define CACHESIZE 16 /* default cache size (Mbytes, 0==inf) */
17 #endif
18 #ifndef FREEBEAMS
19 #define FREEBEAMS 1024 /* maximum beams to free at a time */
20 #endif
21 #ifndef PCTFREE
22 #define PCTFREE 12 /* maximum fraction to free (%) */
23 #endif
24 #ifndef FFDMAX
25 #define FFDMAX 64 /* max. file descriptor for tracking */
26 #endif
27 #ifndef MAXFRAG
28 #define MAXFRAG 2048 /* maximum fragments tracked in each file */
29 #endif
30
31 int hdcachesize = CACHESIZE*1024*1024; /* target cache size (bytes) */
32 unsigned long hdclock; /* clock value */
33
34 HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */
35
36 static struct fragment {
37 short nlinks; /* number of holodeck sections using us */
38 short nfrags; /* number of known fragments */
39 BEAMI fi[MAXFRAG]; /* fragments, descending file position */
40 long flen; /* last known file length */
41 } *hdfrag[FFDMAX]; /* fragment lists, indexed by file descriptor */
42
43
44 hdattach(fd) /* start tracking file fragments for some section */
45 register int fd;
46 {
47 if (fd >= FFDMAX)
48 return; /* descriptor out of range */
49 if (hdfrag[fd] == NULL) {
50 if ((hdfrag[fd] = (struct fragment *)
51 malloc(sizeof(struct fragment))) == NULL)
52 return; /* should flag error? */
53 hdfrag[fd]->nlinks = 0;
54 hdfrag[fd]->nfrags = 0;
55 }
56 hdfrag[fd]->nlinks++;
57 hdfrag[fd]->flen = lseek(fd, 0L, 2); /* get file length */
58 }
59
60
61 /* Do we need a routine to locate file fragments given known occupants? */
62
63
64 hdrelease(fd) /* stop tracking file fragments for some section */
65 register int fd;
66 {
67 if (fd >= FFDMAX || hdfrag[fd] == NULL)
68 return;
69 if (!--hdfrag[fd]->nlinks) {
70 free((char *)hdfrag[fd]);
71 hdfrag[fd] = NULL;
72 }
73 }
74
75
76 HOLO *
77 hdinit(fd, hproto) /* initialize a holodeck section in a file */
78 int fd; /* corresponding file descriptor */
79 HDGRID *hproto; /* holodeck section grid */
80 {
81 long fpos;
82 register HOLO *hp;
83 register int n;
84 /* prepare for system errors */
85 errno = 0;
86 if ((fpos = lseek(fd, 0L, 1)) < 0)
87 error(SYSTEM, "cannot determine holodeck file position");
88 if (hproto == NULL) { /* assume we're loading it */
89 HDGRID hpr;
90 /* load header */
91 if (read(fd, (char *)&hpr, sizeof(HDGRID)) != sizeof(HDGRID))
92 error(SYSTEM, "cannot load holodeck header");
93 /* allocate grid */
94 if ((hp = hdalloc(&hpr)) == NULL)
95 goto memerr;
96 /* load beam directory */
97 n = nbeams(hp)*sizeof(BEAMI);
98 if (read(fd, (char *)(hp->bi+1), n) != n)
99 error(SYSTEM, "failure loading holodeck directory");
100 } else { /* assume we're creating it */
101 if ((hp = hdalloc(hproto)) == NULL)
102 goto memerr;
103 /* write header and skeleton */
104 n = nbeams(hp)*sizeof(BEAMI);
105 if (write(fd, (char *)hproto, sizeof(HDGRID)) !=
106 sizeof(HDGRID) ||
107 write(fd, (char *)(hp->bi+1), n) != n)
108 error(SYSTEM, "cannot write header to holodeck file");
109 }
110 hp->fd = fd;
111 hp->dirty = 0;
112 biglob(hp)->fo = fpos + sizeof(HDGRID);
113 biglob(hp)->nrd = 0; /* count rays on disk */
114 for (n = nbeams(hp); n > 0; n--)
115 biglob(hp)->nrd += hp->bi[n].nrd;
116 /* add to holodeck list */
117 for (n = 0; n < HDMAX; n++)
118 if (hdlist[n] == NULL) {
119 hdlist[n] = hp;
120 break;
121 }
122 /* start tracking fragments (last) */
123 hdattach(fd);
124 /* all done */
125 return(hp);
126 memerr:
127 error(SYSTEM, "cannot allocate holodeck grid");
128 }
129
130
131 int
132 hdsync(hp) /* update directory on disk if necessary */
133 register HOLO *hp;
134 {
135 register int j, n;
136
137 if (hp == NULL) { /* do all */
138 n = 0;
139 for (j = 0; hdlist[j] != NULL; j++)
140 n += hdsync(hdlist[j]);
141 return(n);
142 }
143 if (!hp->dirty) /* check first */
144 return(0);
145 if (lseek(hp->fd, biglob(hp)->fo, 0) < 0)
146 error(SYSTEM, "cannot seek on holodeck file");
147 n = nbeams(hp)*sizeof(BEAMI);
148 if (write(hp->fd, (char *)(hp->bi+1), n) != n)
149 error(SYSTEM, "cannot update holodeck section directory");
150 hp->dirty = 0;
151 return(1);
152 }
153
154
155 long
156 hdmemuse(all) /* return memory usage (in bytes) */
157 int all; /* include overhead (painful) */
158 {
159 long total = 0;
160 register int i, j;
161
162 for (j = 0; hdlist[j] != NULL; j++) {
163 total += blglob(hdlist[j])->nrm * sizeof(RAYVAL);
164 if (all) {
165 total += sizeof(HOLO) + sizeof(BEAM *) +
166 nbeams(hdlist[j]) *
167 (sizeof(BEAM *)+sizeof(BEAMI));
168 for (i = nbeams(hdlist[j]); i > 0; i--)
169 if (hdlist[j]->bl[i] != NULL)
170 total += sizeof(BEAM);
171 }
172 }
173 if (all)
174 for (j = 0; j < FFDMAX; j++)
175 if (hdfrag[j] != NULL)
176 total += sizeof(struct fragment);
177 return(total);
178 }
179
180
181 long
182 hdfiluse(fd, all) /* compute file usage (in bytes) */
183 int fd; /* open file descriptor to check */
184 int all; /* include overhead and unflushed data */
185 {
186 long total = 0;
187 register int i, j;
188
189 for (j = 0; hdlist[j] != NULL; j++) {
190 if (hdlist[j]->fd != fd)
191 continue;
192 total += biglob(hdlist[j])->nrd * sizeof(RAYVAL);
193 if (all) {
194 for (i = nbeams(hdlist[j]); i > 0; i--)
195 if (hdlist[j]->bl[i] != NULL)
196 total += sizeof(RAYVAL) *
197 (hdlist[j]->bl[i]->nrm -
198 hdlist[j]->bi[i].nrd);
199 total += sizeof(HDGRID) +
200 nbeams(hdlist[j])*sizeof(BEAMI);
201 }
202 }
203 return(total); /* does not include fragments */
204 }
205
206
207 RAYVAL *
208 hdnewrays(hp, i, nr) /* allocate space for add'l rays and return pointer */
209 register HOLO *hp;
210 register int i;
211 int nr; /* number of new rays desired */
212 {
213 RAYVAL *p;
214 int n;
215
216 if (nr <= 0)
217 return(NULL);
218 if (i < 1 | i > nbeams(hp))
219 error(CONSISTENCY, "bad beam index given to hdnewrays");
220 if (hp->bl[i] != NULL)
221 hp->bl[i]->tick = hdclock; /* preempt swap */
222 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
223 hdfreecache(PCTFREE, NULL); /* free some space */
224 if (hp->bl[i] == NULL) { /* allocate (and load) */
225 n = hp->bi[i].nrd + nr;
226 if ((hp->bl[i] = (BEAM *)malloc(hdbsiz(n))) == NULL)
227 goto memerr;
228 blglob(hp)->nrm += n;
229 if (n = hp->bl[i]->nrm = hp->bi[i].nrd) {
230 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
231 error(SYSTEM, "seek error on holodeck file");
232 n *= sizeof(RAYVAL);
233 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
234 error(SYSTEM,
235 "error reading beam from holodeck file");
236 }
237 } else { /* just grow in memory */
238 hp->bl[i] = (BEAM *)realloc( (char *)hp->bl[i],
239 hdbsiz(hp->bl[i]->nrm + nr) );
240 if (hp->bl[i] == NULL)
241 goto memerr;
242 blglob(hp)->nrm += nr;
243 }
244 p = hdbray(hp->bl[i]) + hp->bl[i]->nrm;
245 hp->bl[i]->nrm += nr; /* update in-core structure */
246 bzero((char *)p, nr*sizeof(RAYVAL));
247 hp->bl[i]->tick = ++hdclock; /* update LRU clock */
248 blglob(hp)->tick = hdclock;
249 return(p); /* point to new rays */
250 memerr:
251 error(SYSTEM, "out of memory in hdnewrays");
252 }
253
254
255 BEAM *
256 hdgetbeam(hp, i) /* get beam (from file if necessary) */
257 register HOLO *hp;
258 register int i;
259 {
260 register int n;
261
262 if (i < 1 | i > nbeams(hp))
263 error(CONSISTENCY, "bad beam index given to hdgetbeam");
264 if (hp->bl[i] == NULL) { /* load from disk */
265 if (!(n = hp->bi[i].nrd))
266 return(NULL);
267 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
268 hdfreecache(PCTFREE, NULL); /* get free space */
269 errno = 0;
270 if ((hp->bl[i] = (BEAM *)malloc(hdbsiz(n))) == NULL)
271 error(SYSTEM, "cannot allocate memory for beam");
272 blglob(hp)->nrm += hp->bl[i]->nrm = n;
273 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
274 error(SYSTEM, "seek error on holodeck file");
275 n *= sizeof(RAYVAL);
276 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
277 error(SYSTEM, "error reading beam from holodeck file");
278 }
279 hp->bl[i]->tick = ++hdclock; /* update LRU clock */
280 blglob(hp)->tick = hdclock;
281 return(hp->bl[i]);
282 }
283
284
285 int
286 hdgetbi(hp, i) /* allocate a file fragment */
287 register HOLO *hp;
288 register int i;
289 {
290 int nrays = hp->bl[i]->nrm;
291
292 if (hp->bi[i].nrd == nrays) /* current one will do? */
293 return(0);
294
295 if (hp->fd >= FFDMAX || hdfrag[hp->fd] == NULL) /* untracked */
296 hp->bi[i].fo = lseek(hp->fd, 0L, 2);
297
298 else if (hp->bi[i].fo + hp->bi[i].nrd*sizeof(RAYVAL) ==
299 hdfrag[hp->fd]->flen) /* EOF special case */
300 hdfrag[hp->fd]->flen = hp->bi[i].fo + nrays*sizeof(RAYVAL);
301
302 else { /* general case */
303 register struct fragment *f = hdfrag[hp->fd];
304 register int j, k;
305 /* relinquish old fragment */
306 if ((j = ++f->nfrags) >= MAXFRAG)
307 f->nfrags--;
308 for ( ; ; ) { /* stick it in our descending list */
309 if (!--j || hp->bi[i].fo < f->fi[j-1].fo) {
310 f->fi[j].fo = hp->bi[i].fo;
311 f->fi[j].nrd = hp->bi[i].nrd;
312 break;
313 }
314 copystruct(f->fi+j, f->fi+j-1);
315 }
316 /* coalesce adjacent fragments */
317 for (j = k = 0; k < f->nfrags; j++, k++) {
318 if (j != k)
319 copystruct(f->fi+j, f->fi+k);
320 while (k+1 < f->nfrags &&
321 f->fi[k+1].fo + f->fi[k+1].nrd*sizeof(RAYVAL) ==
322 f->fi[j].fo)
323 f->fi[j].fo -= f->fi[++k].nrd*sizeof(RAYVAL);
324 }
325 f->nfrags = j;
326 k = -1; /* find closest-sized fragment */
327 for (j = f->nfrags; j-- > 0; )
328 if (f->fi[j].nrd >= nrays &&
329 (k < 0 || f->fi[j].nrd < f->fi[k].nrd)
330 && f->fi[k=j].nrd == nrays)
331 break;
332 if (k < 0) { /* no fragment -- extend file */
333 hp->bi[i].fo = f->flen;
334 f->flen += nrays*sizeof(RAYVAL);
335 } else { /* else use fragment */
336 hp->bi[i].fo = f->fi[k].fo;
337 if (f->fi[k].nrd == nrays) { /* delete fragment */
338 f->nfrags--;
339 for (j = k; j < f->nfrags; j++)
340 copystruct(f->fi+j, f->fi+j+1);
341 } else { /* else shrink it */
342 f->fi[k].fo += nrays*sizeof(RAYVAL);
343 f->fi[k].nrd -= nrays;
344 }
345 }
346 }
347 biglob(hp)->nrd += nrays - hp->bi[i].nrd;
348 hp->bi[i].nrd = nrays;
349 hp->dirty++; /* section directory now out of date */
350 return(1);
351 }
352
353
354 int
355 hdfreebeam(hp, i) /* free beam, writing if dirty */
356 register HOLO *hp;
357 register int i;
358 {
359 int nchanged, n;
360
361 if (hp == NULL) { /* clear all holodecks */
362 nchanged = 0;
363 for (i = 0; hdlist[i] != NULL; i++)
364 nchanged += hdfreebeam(hdlist[i], 0);
365 return(nchanged);
366 }
367 if (i == 0) { /* clear entire holodeck */
368 nchanged = 0;
369 for (i = 1; i <= nbeams(hp); i++)
370 nchanged += hdfreebeam(hp, i);
371 return(nchanged);
372 }
373 if (i < 1 | i > nbeams(hp))
374 error(CONSISTENCY, "bad beam index to hdfreebeam");
375 if (hp->bl[i] == NULL)
376 return(0);
377 /* check for additions */
378 nchanged = hp->bl[i]->nrm - hp->bi[i].nrd;
379 if (nchanged) {
380 hdgetbi(hp, i); /* allocate a file position */
381 errno = 0;
382 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
383 error(SYSTEM, "cannot seek on holodeck file");
384 n = hp->bl[i]->nrm * sizeof(RAYVAL);
385 if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
386 error(SYSTEM, "write error in hdfreebeam");
387 }
388 blglob(hp)->nrm -= hp->bl[i]->nrm;
389 free((char *)hp->bl[i]); /* free memory */
390 hp->bl[i] = NULL;
391 return(nchanged);
392 }
393
394
395 hdlrulist(ha, ba, n, hp) /* add beams from holodeck to LRU list */
396 register HOLO *ha[]; /* section list (NULL terminated) */
397 register int ba[]; /* beam index to go with section */
398 int n; /* length of arrays minus 1 */
399 register HOLO *hp; /* section we're adding from */
400 {
401 register int i, j;
402 int nents;
403 /* find last entry in LRU list */
404 for (j = 0; ha[j] != NULL; j++)
405 ;
406 nents = j;
407 /* insert each beam from hp */
408 for (i = nbeams(hp); i > 0; i-- ) {
409 if (hp->bl[i] == NULL) /* check if loaded */
410 continue;
411 if ((j = ++nents) > n) /* grow list if we can */
412 nents--;
413 for ( ; ; ) { /* bubble into place */
414 if (!--j || hp->bl[i]->tick >=
415 ha[j-1]->bl[ba[j-1]]->tick) {
416 ha[j] = hp;
417 ba[j] = i;
418 break;
419 }
420 ha[j] = ha[j-1];
421 ba[j] = ba[j-1];
422 }
423 }
424 ha[nents] = NULL; /* all done */
425 ba[nents] = 0;
426 }
427
428
429 hdfreecache(pct, honly) /* free up cache space, writing changes */
430 int pct; /* maximum percentage to free */
431 register HOLO *honly; /* NULL means check all */
432 {
433 HOLO *hp[FREEBEAMS+1];
434 int bn[FREEBEAMS+1];
435 int freetarget;
436 register int i;
437 /* compute free target */
438 freetarget = (honly != NULL) ? blglob(honly)->nrm :
439 hdmemuse(0)/sizeof(RAYVAL) ;
440 freetarget = freetarget*pct/100;
441 /* find least recently used */
442 hp[0] = NULL;
443 bn[0] = 0;
444 if (honly != NULL)
445 hdlrulist(hp, bn, FREEBEAMS, honly);
446 else
447 for (i = 0; hdlist[i] != NULL; i++)
448 hdlrulist(hp, bn, FREEBEAMS, hdlist[i]);
449 /* free LRU beams */
450 for (i = 0; hp[i] != NULL; i++) {
451 hdfreebeam(hp[i], bn[i]);
452 if ((freetarget -= hp[i]->bi[bn[i]].nrd) <= 0)
453 break;
454 }
455 hdsync(honly); /* synchronize directories as necessary */
456 }
457
458
459 hddone(hp) /* clean up holodeck section and free */
460 register HOLO *hp; /* NULL means clean up all */
461 {
462 register int i;
463
464 if (hp == NULL) { /* NULL means clean up everything */
465 while (hdlist[0] != NULL)
466 hddone(hdlist[0]);
467 return;
468 }
469 /* flush all data and free memory */
470 hdflush(hp);
471 /* release fragment resources */
472 hdrelease(hp->fd);
473 /* remove hp from active list */
474 for (i = 0; hdlist[i] != NULL; i++)
475 if (hdlist[i] == hp) {
476 while ((hdlist[i] = hdlist[i+1]) != NULL)
477 i++;
478 break;
479 }
480 free((char *)hp->bl); /* free beam list */
481 free((char *)hp); /* free holodeck struct */
482 }
