root/radiance/ray/src/hd/holofile.c
Revision: 3.41
Committed: Thu Aug 5 15:53:09 1999 UTC (25 years, 11 months ago) by gwlarson
Changes since 3.40: +26 -11 lines
added -r option for read-only holodecks
1 /* Copyright (c) 1999 Regents of the University of California */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Routines for managing holodeck files
9 *
10 * 9/30/97 GWLarson
11 */
12
13 #include "holo.h"
14
15 #ifndef CACHESIZE
16 #ifdef BIGMEM
17 #define CACHESIZE 17 /* default cache size (Mbytes, 0==inf) */
18 #else
19 #define CACHESIZE 5
20 #endif
21 #endif
22 #ifndef FREEBEAMS
23 #define FREEBEAMS 1500 /* maximum beams to free at a time */
24 #endif
25 #ifndef PCTFREE
26 #define PCTFREE 15 /* maximum fraction to free (%) */
27 #endif
28 #ifndef MAXFRAGB
29 #define MAXFRAGB 16 /* fragment blocks/file to track (0==inf) */
30 #endif
31 #ifndef FF_DEFAULT
32 /* when to free a beam fragment */
33 #define FF_DEFAULT (FF_WRITE|FF_KILL)
34 #endif
35 #ifndef MINDIRSEL
36 /* minimum directory seek length */
37 #define MINDIRSEL (4*BUFSIZ/sizeof(BEAMI))
38 #endif
39
40 #ifndef BSD
41 #define write writebuf /* safe i/o routines */
42 #define read readbuf
43 #endif
44
45 #define FRAGBLK 512 /* number of fragments to allocate at a time */
46
47 int hdfragflags = FF_DEFAULT; /* tells when to free fragments */
48 unsigned hdcachesize = CACHESIZE*1024*1024; /* target cache size */
49 unsigned long hdclock; /* clock value */
50
51 HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */
52
53 static struct fraglist {
54 short nlinks; /* number of holodeck sections using us */
55 short writable; /* 0 read-only, <0 write error encountered */
56 int nfrags; /* number of known fragments */
57 BEAMI *fi; /* fragments, descending file position */
58 long flen; /* last known file length */
59 } *hdfragl; /* fragment lists, indexed by file descriptor */
60
61 static int nhdfragls; /* size of hdfragl array */
62
63
64 HOLO *
65 hdalloc(hproto) /* allocate and set holodeck section based on grid */
66 HDGRID *hproto;
67 {
68 HOLO hdhead;
69 register HOLO *hp;
70 int n;
71 /* copy grid to temporary header */
72 bcopy((char *)hproto, (char *)&hdhead, sizeof(HDGRID));
73 /* compute grid vectors and sizes */
74 hdcompgrid(&hdhead);
75 /* allocate header with directory */
76 n = sizeof(HOLO)+nbeams(&hdhead)*sizeof(BEAMI);
77 if ((hp = (HOLO *)malloc(n)) == NULL)
78 return(NULL);
79 /* copy header information */
80 copystruct(hp, &hdhead);
81 /* allocate and clear beam list */
82 hp->bl = (BEAM **)malloc((nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM));
83 if (hp->bl == NULL) {
84 free((char *)hp);
85 return(NULL);
86 }
87 bzero((char *)hp->bl, (nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM));
88 hp->bl[0] = (BEAM *)(hp->bl+nbeams(hp)+1); /* set blglob(hp) */
89 hp->fd = -1;
90 hp->dirty = 0;
91 hp->priv = NULL;
92 /* clear beam directory */
93 bzero((char *)hp->bi, (nbeams(hp)+1)*sizeof(BEAMI));
94 return(hp); /* all is well */
95 }
96
97
98 char *
99 hdrealloc(ptr, siz, rout) /* (re)allocate memory, retry then error */
100 char *ptr;
101 unsigned siz;
102 char *rout;
103 {
104 register char *newp;
105 /* call malloc/realloc */
106 if (ptr == NULL) newp = (char *)malloc(siz);
107 else newp = (char *)realloc(ptr, siz);
108 /* check success */
109 if (newp == NULL && rout != NULL) {
110 hdfreecache(25, NULL); /* free some memory */
111 errno = 0; /* retry */
112 newp = hdrealloc(ptr, siz, NULL);
113 if (newp == NULL) { /* give up and report error */
114 sprintf(errmsg, "out of memory in %s", rout);
115 error(SYSTEM, errmsg);
116 }
117 }
118 return(newp);
119 }
120
121
122 hdattach(fd, wr) /* start tracking file fragments for some section */
123 register int fd;
124 int wr;
125 {
126 if (fd >= nhdfragls) {
127 hdfragl = (struct fraglist *)hdrealloc((char *)hdfragl,
128 (fd+1)*sizeof(struct fraglist), "hdattach");
129 bzero((char *)(hdfragl+nhdfragls),
130 (fd+1-nhdfragls)*sizeof(struct fraglist));
131 nhdfragls = fd+1;
132 }
133 hdfragl[fd].nlinks++;
134 hdfragl[fd].writable = wr; /* set writable flag */
135 hdfragl[fd].flen = lseek(fd, 0L, 2); /* get file length */
136 }
137
138
139 /* Do we need a routine to locate file fragments given known occupants? */
140
141
142 hdrelease(fd) /* stop tracking file fragments for some section */
143 register int fd;
144 {
145 if (fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks)
146 return;
147 if (!--hdfragl[fd].nlinks && hdfragl[fd].nfrags) {
148 free((char *)hdfragl[fd].fi);
149 hdfragl[fd].fi = NULL;
150 hdfragl[fd].nfrags = 0;
151 }
152 }
153
154
155 HOLO *
156 hdinit(fd, hproto) /* initialize a holodeck section in a file */
157 int fd; /* corresponding file descriptor */
158 HDGRID *hproto; /* holodeck section grid */
159 {
160 long rtrunc;
161 long fpos;
162 int writable;
163 register HOLO *hp;
164 register int n;
165 /* prepare for system errors */
166 errno = 0;
167 if ((fpos = lseek(fd, 0L, 1)) < 0)
168 error(SYSTEM, "cannot determine holodeck file position");
169 if (hproto == NULL) { /* assume we're loading it */
170 HDGRID hpr;
171 /* load header */
172 if (read(fd, (char *)&hpr, sizeof(HDGRID)) != sizeof(HDGRID))
173 error(SYSTEM, "cannot load holodeck header");
174 /* allocate grid */
175 if ((hp = hdalloc(&hpr)) == NULL)
176 goto memerr;
177 /* load beam directory */
178 n = nbeams(hp)*sizeof(BEAMI);
179 if (read(fd, (char *)(hp->bi+1), n) != n)
180 error(SYSTEM, "failure loading holodeck directory");
181 /* check that it's clean */
182 for (n = nbeams(hp); n > 0; n--)
183 if (hp->bi[n].fo < 0) {
184 hp->bi[n].fo = 0;
185 error(WARNING, "dirty holodeck section");
186 break;
187 }
188 /* check writability */
189 if (fd < nhdfragls && hdfragl[fd].nlinks)
190 writable = hdfragl[fd].writable;
191 else
192 writable = lseek(fd, fpos, 0) == fpos &&
193 write(fd, (char *)hp, sizeof(HDGRID)) ==
194 sizeof(HDGRID);
195 } else { /* else assume we're creating it */
196 if ((hp = hdalloc(hproto)) == NULL)
197 goto memerr;
198 /* write header and skeleton */
199 n = nbeams(hp)*sizeof(BEAMI);
200 if (write(fd, (char *)hproto, sizeof(HDGRID)) !=
201 sizeof(HDGRID) ||
202 write(fd, (char *)(hp->bi+1), n) != n)
203 error(SYSTEM, "cannot write header to holodeck file");
204 writable = 1;
205 }
206 hp->fd = fd;
207 hp->dirty = 0;
208 biglob(hp)->fo = fpos + sizeof(HDGRID);
209 /* start tracking fragments */
210 hdattach(fd, writable);
211 /* check rays on disk */
212 fpos = hdfilen(fd);
213 biglob(hp)->nrd = rtrunc = 0;
214 for (n = hproto == NULL ? nbeams(hp) : 0; n > 0; n--)
215 if (hp->bi[n].nrd)
216 if (hp->bi[n].fo+hp->bi[n].nrd*sizeof(RAYVAL) > fpos) {
217 rtrunc += hp->bi[n].nrd;
218 hp->bi[n].nrd = 0;
219 } else
220 biglob(hp)->nrd += hp->bi[n].nrd;
221 if (rtrunc) {
222 sprintf(errmsg, "truncated section, %ld rays lost (%.1f%%)",
223 rtrunc, 100.*rtrunc/(rtrunc+biglob(hp)->nrd));
224 error(WARNING, errmsg);
225 }
226 /* add to holodeck list */
227 for (n = 0; n < HDMAX; n++)
228 if (hdlist[n] == NULL) {
229 hdlist[n] = hp;
230 break;
231 }
232 /* all done */
233 return(hp);
234 memerr:
235 error(SYSTEM, "cannot allocate holodeck grid");
236 }
237
238
239 hdmarkdirty(hp, i) /* mark holodeck directory position dirty */
240 register HOLO *hp;
241 int i;
242 {
243 static BEAMI smudge = {0, -1};
244 int mindist, minpos;
245 register int j;
246
247 if (!hp->dirty++) { /* write smudge first time */
248 if (lseek(hp->fd, biglob(hp)->fo+(i-1)*sizeof(BEAMI), 0) < 0
249 || write(hp->fd, (char *)&smudge,
250 sizeof(BEAMI)) != sizeof(BEAMI))
251 error(SYSTEM, "seek/write error in hdmarkdirty");
252 hp->dirseg[0].s = i;
253 hp->dirseg[0].n = 1;
254 return;
255 }
256 /* insert into segment list */
257 for (j = hp->dirty; j--; ) {
258 if (!j || hp->dirseg[j-1].s < i) {
259 hp->dirseg[j].s = i;
260 hp->dirseg[j].n = 1;
261 break;
262 }
263 copystruct(hp->dirseg+j, hp->dirseg+(j-1));
264 }
265 do { /* check neighbors */
266 mindist = nbeams(hp); /* find closest */
267 for (j = hp->dirty; --j; )
268 if (hp->dirseg[j].s -
269 (hp->dirseg[j-1].s + hp->dirseg[j-1].n)
270 < mindist) {
271 minpos = j;
272 mindist = hp->dirseg[j].s -
273 (hp->dirseg[j-1].s + hp->dirseg[j-1].n);
274 }
275 /* good enough? */
276 if (hp->dirty <= MAXDIRSE && mindist > MINDIRSEL)
277 break;
278 j = minpos - 1; /* coalesce neighbors */
279 if (hp->dirseg[j].s + hp->dirseg[j].n <
280 hp->dirseg[minpos].s + hp->dirseg[minpos].n)
281 hp->dirseg[j].n = hp->dirseg[minpos].s +
282 hp->dirseg[minpos].n - hp->dirseg[j].s;
283 hp->dirty--;
284 while (++j < hp->dirty) /* close the gap */
285 copystruct(hp->dirseg+j, hp->dirseg+(j+1));
286 } while (mindist <= MINDIRSEL);
287 }
288
289
290 int
291 hdsync(hp, all) /* update beams and directory on disk */
292 register HOLO *hp;
293 int all;
294 {
295 register int j, n;
296
297 if (hp == NULL) { /* do all holodecks */
298 n = 0;
299 for (j = 0; hdlist[j] != NULL; j++)
300 n += hdsync(hdlist[j], all);
301 return(n);
302 }
303 /* sync the beams */
304 for (j = (all ? nbeams(hp) : 0); j > 0; j--)
305 if (hp->bl[j] != NULL)
306 hdsyncbeam(hp, j);
307 if (!hp->dirty) /* directory clean? */
308 return(0);
309 errno = 0; /* write dirty segments */
310 for (j = 0; j < hp->dirty; j++) {
311 if (lseek(hp->fd, biglob(hp)->fo +
312 (hp->dirseg[j].s-1)*sizeof(BEAMI), 0) < 0)
313 error(SYSTEM, "cannot seek on holodeck file");
314 n = hp->dirseg[j].n * sizeof(BEAMI);
315 if (write(hp->fd, (char *)(hp->bi+hp->dirseg[j].s), n) != n)
316 error(SYSTEM, "cannot update section directory");
317 }
318 hp->dirty = 0; /* all clean */
319 return(1);
320 }
321
322
323 unsigned
324 hdmemuse(all) /* return memory usage (in bytes) */
325 int all; /* include overhead (painful) */
326 {
327 long total = 0;
328 register int i, j;
329
330 for (j = 0; hdlist[j] != NULL; j++) {
331 total += blglob(hdlist[j])->nrm * sizeof(RAYVAL);
332 if (all) {
333 total += sizeof(HOLO) + sizeof(BEAM *) +
334 nbeams(hdlist[j]) *
335 (sizeof(BEAM *)+sizeof(BEAMI));
336 for (i = nbeams(hdlist[j]); i > 0; i--)
337 if (hdlist[j]->bl[i] != NULL)
338 total += sizeof(BEAM);
339 }
340 }
341 if (all)
342 for (j = 0; j < nhdfragls; j++) {
343 total += sizeof(struct fraglist);
344 if (hdfragl[j].nfrags)
345 total += FRAGBLK*sizeof(BEAMI) *
346 ((hdfragl[j].nfrags-1)/FRAGBLK + 1) ;
347 }
348 return(total);
349 }
350
351
352 long
353 hdfilen(fd) /* return file length for fd */
354 int fd;
355 {
356 long fpos, flen;
357
358 if (fd < 0)
359 return(-1);
360 if (fd >= nhdfragls || !hdfragl[fd].nlinks) {
361 if ((fpos = lseek(fd, 0L, 1)) < 0)
362 return(-1);
363 flen = lseek(fd, 0L, 2);
364 lseek(fd, fpos, 0);
365 return(flen);
366 }
367 return(hdfragl[fd].flen);
368 }
369
370
371 long
372 hdfiluse(fd, all) /* compute file usage (in bytes) */
373 int fd; /* open file descriptor to check */
374 int all; /* include overhead and unflushed data */
375 {
376 long total = 0;
377 register int i, j;
378
379 for (j = 0; hdlist[j] != NULL; j++) {
380 if (hdlist[j]->fd != fd)
381 continue;
382 total += biglob(hdlist[j])->nrd * sizeof(RAYVAL);
383 if (all) {
384 for (i = nbeams(hdlist[j]); i > 0; i--)
385 if (hdlist[j]->bl[i] != NULL)
386 total += sizeof(RAYVAL) *
387 (hdlist[j]->bl[i]->nrm -
388 hdlist[j]->bi[i].nrd);
389 total += sizeof(HDGRID) +
390 nbeams(hdlist[j])*sizeof(BEAMI);
391 }
392 }
393 return(total); /* does not include fragments */
394 }
395
396
397 RAYVAL *
398 hdnewrays(hp, i, nr) /* allocate space for add'l rays and return pointer */
399 register HOLO *hp;
400 register int i;
401 int nr; /* number of new rays desired */
402 {
403 RAYVAL *p;
404 int n;
405
406 if (nr <= 0) return(NULL);
407 CHECK(i < 1 | i > nbeams(hp),
408 CONSISTENCY, "bad beam index given to hdnewrays");
409 if (hp->bl[i] != NULL)
410 hp->bl[i]->tick = hdclock; /* preempt swap */
411 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
412 hdfreecache(PCTFREE, NULL); /* free some space */
413 if (hp->bl[i] == NULL) { /* allocate (and load) */
414 n = hp->bi[i].nrd + nr;
415 hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdnewrays");
416 blglob(hp)->nrm += n;
417 if ((n = hp->bl[i]->nrm = hp->bi[i].nrd)) {
418 errno = 0;
419 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
420 error(SYSTEM, "seek error on holodeck file");
421 n *= sizeof(RAYVAL);
422 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
423 error(SYSTEM,
424 "error reading beam from holodeck file");
425 }
426 } else { /* just grow in memory */
427 hp->bl[i] = (BEAM *)hdrealloc((char *)hp->bl[i],
428 hdbsiz(hp->bl[i]->nrm + nr), "hdnewrays");
429 blglob(hp)->nrm += nr;
430 }
431 if (hdfragflags&FF_ALLOC && hp->bi[i].nrd)
432 hdfreefrag(hp, i); /* relinquish old fragment */
433 p = hdbray(hp->bl[i]) + hp->bl[i]->nrm;
434 hp->bl[i]->nrm += nr; /* update in-core structure */
435 bzero((char *)p, nr*sizeof(RAYVAL));
436 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
437 return(p); /* point to new rays */
438 }
439
440
441 BEAM *
442 hdgetbeam(hp, i) /* get beam (from file if necessary) */
443 register HOLO *hp;
444 register int i;
445 {
446 register int n;
447
448 CHECK(i < 1 | i > nbeams(hp),
449 CONSISTENCY, "bad beam index given to hdgetbeam");
450 if (hp->bl[i] == NULL) { /* load from disk */
451 if (!(n = hp->bi[i].nrd))
452 return(NULL);
453 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
454 hdfreecache(PCTFREE, NULL); /* get free space */
455 hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdgetbeam");
456 blglob(hp)->nrm += hp->bl[i]->nrm = n;
457 errno = 0;
458 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
459 error(SYSTEM, "seek error on holodeck file");
460 n *= sizeof(RAYVAL);
461 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
462 error(SYSTEM, "error reading beam from holodeck file");
463 if (hdfragflags&FF_READ)
464 hdfreefrag(hp, i); /* relinquish old frag. */
465 }
466 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
467 return(hp->bl[i]);
468 }
469
470
471 int
472 hdfilord(hb1, hb2) /* order beams for quick loading */
473 register HDBEAMI *hb1, *hb2;
474 {
475 register long c;
476 /* residents go first */
477 if (hb2->h->bl[hb2->b] != NULL)
478 return(hb1->h->bl[hb1->b] == NULL);
479 if (hb1->h->bl[hb1->b] != NULL)
480 return(-1);
481 /* otherwise sort by file descriptor */
482 if ((c = hb1->h->fd - hb2->h->fd))
483 return(c);
484 /* then by position in file */
485 c = hb1->h->bi[hb1->b].fo - hb2->h->bi[hb2->b].fo;
486 return(c > 0 ? 1 : c < 0 ? -1 : 0);
487 }
488
489
490 hdloadbeams(hb, n, bf) /* load a list of beams in optimal order */
491 register HDBEAMI *hb; /* list gets sorted by hdfilord() */
492 int n; /* list length */
493 int (*bf)(); /* callback function (optional) */
494 {
495 unsigned origcachesize, memuse;
496 int bytesloaded, needbytes, bytes2free;
497 register BEAM *bp;
498 register int i;
499 /* precheck consistency */
500 if (n <= 0) return;
501 for (i = n; i--; )
502 if (hb[i].h==NULL || hb[i].b<1 | hb[i].b>nbeams(hb[i].h))
503 error(CONSISTENCY, "bad beam in hdloadbeams");
504 /* sort list for optimal access */
505 qsort((char *)hb, n, sizeof(HDBEAMI), hdfilord);
506 bytesloaded = 0; /* run through loaded beams */
507 for ( ; n && (bp = hb->h->bl[hb->b]) != NULL; n--, hb++) {
508 bp->tick = hdclock; /* preempt swap */
509 bytesloaded += bp->nrm;
510 if (bf != NULL)
511 (*bf)(bp, hb);
512 }
513 bytesloaded *= sizeof(RAYVAL);
514 if ((origcachesize = hdcachesize) > 0) {
515 needbytes = 0; /* figure out memory needs */
516 for (i = n; i--; )
517 needbytes += hb[i].h->bi[hb[i].b].nrd;
518 needbytes *= sizeof(RAYVAL);
519 do { /* free enough memory */
520 memuse = hdmemuse(0);
521 bytes2free = needbytes - (int)(hdcachesize-memuse);
522 if (bytes2free > (int)(memuse - bytesloaded))
523 bytes2free = memuse - bytesloaded;
524 } while (bytes2free > 0 &&
525 hdfreecache(100*bytes2free/memuse, NULL) < 0);
526 hdcachesize = 0; /* load beams w/o swap */
527 }
528 for (i = 0; i < n; i++)
529 if ((bp = hdgetbeam(hb[i].h, hb[i].b)) != NULL && bf != NULL)
530 (*bf)(bp, hb+i);
531 hdcachesize = origcachesize; /* resume dynamic swapping */
532 }
533
534
535 int
536 hdfreefrag(hp, i) /* free a file fragment */
537 HOLO *hp;
538 int i;
539 {
540 register BEAMI *bi = &hp->bi[i];
541 register struct fraglist *f;
542 register int j, k;
543
544 if (bi->nrd <= 0)
545 return(0);
546 DCHECK(hp->fd < 0 | hp->fd >= nhdfragls || !hdfragl[hp->fd].nlinks,
547 CONSISTENCY, "bad file descriptor in hdfreefrag");
548 f = &hdfragl[hp->fd];
549 if (!f->writable)
550 return(0);
551 if (f->nfrags % FRAGBLK == 0) { /* delete empty remnants */
552 for (j = k = 0; k < f->nfrags; j++, k++) {
553 while (f->fi[k].nrd == 0)
554 if (++k >= f->nfrags)
555 goto endloop;
556 if (k > j)
557 copystruct(f->fi+j, f->fi+k);
558 }
559 endloop:
560 f->nfrags = j;
561 }
562 j = f->nfrags++; /* allocate a slot in free list */
563 #if MAXFRAGB
564 if (j >= MAXFRAGB*FRAGBLK) {
565 f->nfrags = j--; /* stop list growth */
566 if (bi->nrd <= f->fi[j].nrd)
567 return(0); /* new one no better than discard */
568 }
569 #endif
570 if (j % FRAGBLK == 0) { /* more (or less) free list space */
571 register BEAMI *newp;
572 if (f->fi == NULL)
573 newp = (BEAMI *)malloc((j+FRAGBLK)*sizeof(BEAMI));
574 else
575 newp = (BEAMI *)realloc((char *)f->fi,
576 (j+FRAGBLK)*sizeof(BEAMI));
577 if (newp == NULL) {
578 f->nfrags--; /* graceful failure */
579 return(0);
580 }
581 f->fi = newp;
582 }
583 for ( ; ; j--) { /* insert in descending list */
584 if (!j || bi->fo < f->fi[j-1].fo) {
585 f->fi[j].fo = bi->fo;
586 f->fi[j].nrd = bi->nrd;
587 break;
588 }
589 copystruct(f->fi+j, f->fi+(j-1));
590 }
591 /* coalesce adjacent fragments */
592 /* successors never empty */
593 if (j && f->fi[j-1].fo == f->fi[j].fo + f->fi[j].nrd*sizeof(RAYVAL)) {
594 f->fi[j].nrd += f->fi[j-1].nrd;
595 f->fi[j-1].nrd = 0;
596 }
597 for (k = j+1; k < f->nfrags; k++) /* get non-empty predecessor */
598 if (f->fi[k].nrd) {
599 if (f->fi[j].fo == f->fi[k].fo +
600 f->fi[k].nrd*sizeof(RAYVAL)) {
601 f->fi[k].nrd += f->fi[j].nrd;
602 f->fi[j].nrd = 0;
603 }
604 break;
605 }
606 biglob(hp)->nrd -= bi->nrd; /* tell fragment it's free */
607 bi->nrd = 0;
608 bi->fo = 0L;
609 hdmarkdirty(hp, i); /* assume we'll reallocate */
610 return(1);
611 }
612
613
614 int
615 hdfragOK(fd, listlen, listsiz) /* get fragment list status for file */
616 int fd;
617 int *listlen;
618 register int4 *listsiz;
619 {
620 register struct fraglist *f;
621 register int i;
622
623 if (fd < 0 | fd >= nhdfragls || !(f = &hdfragl[fd])->nlinks)
624 return(0); /* listless */
625 if (listlen != NULL)
626 *listlen = f->nfrags;
627 if (listsiz != NULL)
628 for (i = f->nfrags, *listsiz = 0; i--; )
629 *listsiz += f->fi[i].nrd;
630 #if MAXFRAGB
631 return(f->nfrags < MAXFRAGB*FRAGBLK);
632 #else
633 return(1); /* list never fills up */
634 #endif
635 }
636
637
638 long
639 hdallocfrag(fd, nrays) /* allocate a file fragment */
640 int fd;
641 unsigned int4 nrays;
642 {
643 register struct fraglist *f;
644 register int j;
645 long nfo;
646
647 if (nrays == 0)
648 return(-1L);
649 DCHECK(fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks,
650 CONSISTENCY, "bad file descriptor in hdallocfrag");
651 f = &hdfragl[fd];
652 for (j = f->nfrags; j-- > 0; ) /* first fit algorithm */
653 if (f->fi[j].nrd >= nrays)
654 break;
655 if (j < 0) { /* no fragment -- extend file */
656 nfo = f->flen;
657 f->flen += nrays*sizeof(RAYVAL);
658 } else { /* else use fragment */
659 nfo = f->fi[j].fo;
660 f->fi[j].fo += nrays*sizeof(RAYVAL);
661 f->fi[j].nrd -= nrays;
662 }
663 return(nfo);
664 }
665
666
667 int
668 hdsyncbeam(hp, i) /* sync beam in memory with beam on disk */
669 register HOLO *hp;
670 register int i;
671 {
672 int fragfreed;
673 unsigned int4 nrays;
674 unsigned int n;
675 long nfo;
676 /* check file status */
677 if (hdfragl[hp->fd].writable <= 0)
678 return(hdfragl[hp->fd].writable);
679 DCHECK(i < 1 | i > nbeams(hp),
680 CONSISTENCY, "bad beam index in hdsyncbeam");
681 /* is current fragment OK? */
682 if (hp->bl[i] == NULL || (nrays = hp->bl[i]->nrm) == hp->bi[i].nrd)
683 return(0);
684 /* relinquish old fragment? */
685 fragfreed = hdfragflags&FF_WRITE && hp->bi[i].nrd && hdfreefrag(hp,i);
686 if (nrays) { /* get and write new fragment */
687 nfo = hdallocfrag(hp->fd, nrays);
688 errno = 0;
689 if (lseek(hp->fd, nfo, 0) < 0)
690 error(SYSTEM, "cannot seek on holodeck file");
691 n = hp->bl[i]->nrm * sizeof(RAYVAL);
692 if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) {
693 hdfragl[hp->fd].writable = -1;
694 hdsync(NULL, 0); /* sync directories */
695 error(SYSTEM, "write error in hdsyncbeam");
696 }
697 hp->bi[i].fo = nfo;
698 } else
699 hp->bi[i].fo = 0L;
700 biglob(hp)->nrd += nrays - hp->bi[i].nrd;
701 hp->bi[i].nrd = nrays;
702 if (!fragfreed)
703 hdmarkdirty(hp, i); /* need to flag dir. ent. */
704 return(1);
705 }
706
707
708 int
709 hdfreebeam(hp, i) /* free beam, writing if dirty */
710 register HOLO *hp;
711 register int i;
712 {
713 int nchanged;
714
715 if (hp == NULL) { /* clear all holodecks */
716 nchanged = 0;
717 for (i = 0; hdlist[i] != NULL; i++)
718 nchanged += hdfreebeam(hdlist[i], 0);
719 return(nchanged);
720 }
721 if (hdfragl[hp->fd].writable < 0) /* check for file error */
722 return(0);
723 if (i == 0) { /* clear entire holodeck */
724 if (blglob(hp)->nrm == 0)
725 return(0); /* already clear */
726 nchanged = 0;
727 for (i = nbeams(hp); i > 0; i--)
728 if (hp->bl[i] != NULL)
729 nchanged += hdfreebeam(hp, i);
730 DCHECK(blglob(hp)->nrm != 0,
731 CONSISTENCY, "bad beam count in hdfreebeam");
732 return(nchanged);
733 }
734 DCHECK(i < 1 | i > nbeams(hp),
735 CONSISTENCY, "bad beam index to hdfreebeam");
736 if (hp->bl[i] == NULL)
737 return(0);
738 /* check for additions */
739 nchanged = hp->bl[i]->nrm - hp->bi[i].nrd;
740 if (nchanged)
741 hdsyncbeam(hp, i); /* write new fragment */
742 blglob(hp)->nrm -= hp->bl[i]->nrm;
743 free((char *)hp->bl[i]); /* free memory */
744 hp->bl[i] = NULL;
745 return(nchanged);
746 }
747
748
749 int
750 hdkillbeam(hp, i) /* delete beam from holodeck */
751 register HOLO *hp;
752 register int i;
753 {
754 int nchanged;
755
756 if (hp == NULL) { /* clobber all holodecks */
757 nchanged = 0;
758 for (i = 0; hdlist[i] != NULL; i++)
759 nchanged += hdkillbeam(hdlist[i], 0);
760 return(nchanged);
761 }
762 if (i == 0) { /* clobber entire holodeck */
763 if (biglob(hp)->nrd == 0 & blglob(hp)->nrm == 0)
764 return(0); /* already empty */
765 nchanged = 0;
766 nchanged = 0;
767 for (i = nbeams(hp); i > 0; i--)
768 if (hp->bi[i].nrd > 0 || hp->bl[i] != NULL)
769 nchanged += hdkillbeam(hp, i);
770 DCHECK(biglob(hp)->nrd != 0 | blglob(hp)->nrm != 0,
771 CONSISTENCY, "bad beam count in hdkillbeam");
772 return(nchanged);
773 }
774 DCHECK(i < 1 | i > nbeams(hp), CONSISTENCY,
775 "bad beam index to hdkillbeam");
776 DCHECK(!hdfragl[hp->fd].writable, CONSISTENCY,
777 "hdkillbeam called on read-only holodeck");
778 if (hp->bl[i] != NULL) { /* free memory */
779 blglob(hp)->nrm -= nchanged = hp->bl[i]->nrm;
780 free((char *)hp->bl[i]);
781 hp->bl[i] = NULL;
782 } else
783 nchanged = hp->bi[i].nrd;
784 if (hp->bi[i].nrd && !(hdfragflags&FF_KILL && hdfreefrag(hp,i))) {
785 biglob(hp)->nrd -= hp->bi[i].nrd; /* free failed */
786 hp->bi[i].nrd = 0;
787 hp->bi[i].fo = 0L;
788 hdmarkdirty(hp, i);
789 }
790 return(nchanged);
791 }
792
793
794 int
795 hdlrulist(hb, nents, n, hp) /* add beams from holodeck to LRU list */
796 register HDBEAMI *hb; /* beam list */
797 int nents; /* current list length */
798 int n; /* maximum list length */
799 register HOLO *hp; /* section we're adding from */
800 {
801 register int i, j;
802 /* insert each beam from hp */
803 for (i = 1; i <= nbeams(hp); i++) {
804 if (hp->bl[i] == NULL) /* check if loaded */
805 continue;
806 #if 0
807 if (hp->bl[i]->tick == hdclock) /* preempt swap? */
808 continue;
809 #endif
810 if ((j = ++nents) >= n) /* grow list if we can */
811 nents--;
812 for ( ; ; ) { /* bubble into place */
813 if (!--j || hp->bl[i]->tick >=
814 hb[j-1].h->bl[hb[j-1].b]->tick) {
815 hb[j].h = hp;
816 hb[j].b = i;
817 break;
818 }
819 copystruct(hb+j, hb+(j-1));
820 }
821 }
822 return(nents); /* return new list length */
823 }
824
825
826 int
827 hdfreecache(pct, honly) /* free up cache space, writing changes */
828 int pct; /* maximum percentage to free */
829 register HOLO *honly; /* NULL means check all */
830 {
831 HDBEAMI hb[FREEBEAMS];
832 int freetarget;
833 int n;
834 register int i;
835 #ifdef DEBUG
836 unsigned membefore;
837
838 membefore = hdmemuse(0);
839 #endif
840 /* compute free target */
841 freetarget = (honly != NULL) ? blglob(honly)->nrm :
842 hdmemuse(0)/sizeof(RAYVAL) ;
843 freetarget = freetarget*pct/100;
844 if (freetarget <= 0)
845 return(0);
846 /* find least recently used */
847 n = 0;
848 if (honly != NULL)
849 n = hdlrulist(hb, n, FREEBEAMS, honly);
850 else
851 for (i = 0; hdlist[i] != NULL; i++)
852 n = hdlrulist(hb, n, FREEBEAMS, hdlist[i]);
853 /* free LRU beams */
854 for (i = 0; i < n; i++) {
855 hdfreebeam(hb[i].h, hb[i].b);
856 if ((freetarget -= hb[i].h->bi[hb[i].b].nrd) <= 0)
857 break;
858 }
859 hdsync(honly, 0); /* synchronize directories as necessary */
860 #ifdef DEBUG
861 sprintf(errmsg,
862 "%dK before, %dK after hdfreecache (%dK total), %d rays short\n",
863 membefore>>10, hdmemuse(0)>>10, hdmemuse(1)>>10, freetarget);
864 wputs(errmsg);
865 #endif
866 return(-freetarget); /* return how far past goal we went */
867 }
868
869
870 hddone(hp) /* clean up holodeck section and free */
871 register HOLO *hp; /* NULL means clean up all */
872 {
873 register int i;
874
875 if (hp == NULL) { /* NULL means clean up everything */
876 while (hdlist[0] != NULL)
877 hddone(hdlist[0]);
878 free((char *)hdfragl);
879 hdfragl = NULL; nhdfragls = 0;
880 return;
881 }
882 /* flush all data and free memory */
883 hdflush(hp);
884 /* release fragment resources */
885 hdrelease(hp->fd);
886 /* remove hp from active list */
887 for (i = 0; hdlist[i] != NULL; i++)
888 if (hdlist[i] == hp) {
889 while ((hdlist[i] = hdlist[i+1]) != NULL)
890 i++;
891 break;
892 }
893 free((char *)hp->bl); /* free beam list */
894 free((char *)hp); /* free holodeck struct */
895 }
