root/radiance/ray/src/hd/holofile.c
Revision: 3.38
Committed: Thu Feb 25 13:25:38 1999 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.37: +2 -2 lines
reduced default cache size
1 /* Copyright (c) 1999 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Routines for managing holodeck files
9 *
10 * 9/30/97 GWLarson
11 */
12
13 #include "holo.h"
14
15 #ifndef CACHESIZE
16 #ifdef BIGMEM
17 #define CACHESIZE 17 /* default cache size (Mbytes, 0==inf) */
18 #else
19 #define CACHESIZE 5
20 #endif
21 #endif
22 #ifndef FREEBEAMS
23 #define FREEBEAMS 1500 /* maximum beams to free at a time */
24 #endif
25 #ifndef PCTFREE
26 #define PCTFREE 15 /* maximum fraction to free (%) */
27 #endif
28 #ifndef MAXFRAGB
29 #define MAXFRAGB 16 /* fragment blocks/file to track (0==inf) */
30 #endif
31 #ifndef FF_DEFAULT
32 /* when to free a beam fragment */
33 #define FF_DEFAULT (FF_ALLOC|FF_WRITE|FF_KILL)
34 #endif
35 #ifndef MINDIRSEL
36 /* minimum directory seek length */
37 #define MINDIRSEL (4*BUFSIZ/sizeof(BEAMI))
38 #endif
39
40 #ifndef BSD
41 #define write writebuf /* safe i/o routines */
42 #define read readbuf
43 #endif
44
45 #define FRAGBLK 512 /* number of fragments to allocate at a time */
46
47 int hdfragflags = FF_DEFAULT; /* tells when to free fragments */
48 unsigned hdcachesize = CACHESIZE*1024*1024; /* target cache size */
49 unsigned long hdclock; /* clock value */
50
51 HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */
52
53 static struct fraglist {
54 short nlinks; /* number of holodeck sections using us */
55 short writerr; /* write error encountered */
56 int nfrags; /* number of known fragments */
57 BEAMI *fi; /* fragments, descending file position */
58 long flen; /* last known file length */
59 } *hdfragl; /* fragment lists, indexed by file descriptor */
60
61 static int nhdfragls; /* size of hdfragl array */
62
63
64 char *
65 hdrealloc(ptr, siz, rout) /* (re)allocate memory, retry then error */
66 char *ptr;
67 unsigned siz;
68 char *rout;
69 {
70 register char *newp;
71 /* call malloc/realloc */
72 if (ptr == NULL) newp = (char *)malloc(siz);
73 else newp = (char *)realloc(ptr, siz);
74 /* check success */
75 if (newp == NULL && rout != NULL) {
76 hdfreecache(25, NULL); /* free some memory */
77 errno = 0; /* retry */
78 newp = hdrealloc(ptr, siz, NULL);
79 if (newp == NULL) { /* give up and report error */
80 sprintf(errmsg, "out of memory in %s", rout);
81 error(SYSTEM, errmsg);
82 }
83 }
84 return(newp);
85 }
86
87
88 hdattach(fd) /* start tracking file fragments for some section */
89 register int fd;
90 {
91 if (fd >= nhdfragls) {
92 hdfragl = (struct fraglist *)hdrealloc((char *)hdfragl,
93 (fd+1)*sizeof(struct fraglist), "hdattach");
94 bzero((char *)(hdfragl+nhdfragls),
95 (fd+1-nhdfragls)*sizeof(struct fraglist));
96 nhdfragls = fd+1;
97 }
98 hdfragl[fd].nlinks++;
99 hdfragl[fd].flen = lseek(fd, 0L, 2); /* get file length */
100 }
101
102
103 /* Do we need a routine to locate file fragments given known occupants? */
104
105
106 hdrelease(fd) /* stop tracking file fragments for some section */
107 register int fd;
108 {
109 if (fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks)
110 return;
111 if (!--hdfragl[fd].nlinks && hdfragl[fd].nfrags) {
112 free((char *)hdfragl[fd].fi);
113 hdfragl[fd].fi = NULL;
114 hdfragl[fd].nfrags = 0;
115 }
116 }
117
118
119 HOLO *
120 hdinit(fd, hproto) /* initialize a holodeck section in a file */
121 int fd; /* corresponding file descriptor */
122 HDGRID *hproto; /* holodeck section grid */
123 {
124 long rtrunc;
125 long fpos;
126 register HOLO *hp;
127 register int n;
128 /* prepare for system errors */
129 errno = 0;
130 if ((fpos = lseek(fd, 0L, 1)) < 0)
131 error(SYSTEM, "cannot determine holodeck file position");
132 if (hproto == NULL) { /* assume we're loading it */
133 HDGRID hpr;
134 /* load header */
135 if (read(fd, (char *)&hpr, sizeof(HDGRID)) != sizeof(HDGRID))
136 error(SYSTEM, "cannot load holodeck header");
137 /* allocate grid */
138 if ((hp = hdalloc(&hpr)) == NULL)
139 goto memerr;
140 /* load beam directory */
141 n = nbeams(hp)*sizeof(BEAMI);
142 if (read(fd, (char *)(hp->bi+1), n) != n)
143 error(SYSTEM, "failure loading holodeck directory");
144 /* check that it's clean */
145 for (n = nbeams(hp); n > 0; n--)
146 if (hp->bi[n].fo < 0) {
147 hp->bi[n].fo = 0;
148 error(WARNING, "dirty holodeck section");
149 break;
150 }
151 } else { /* assume we're creating it */
152 if ((hp = hdalloc(hproto)) == NULL)
153 goto memerr;
154 /* write header and skeleton */
155 n = nbeams(hp)*sizeof(BEAMI);
156 if (write(fd, (char *)hproto, sizeof(HDGRID)) !=
157 sizeof(HDGRID) ||
158 write(fd, (char *)(hp->bi+1), n) != n)
159 error(SYSTEM, "cannot write header to holodeck file");
160 }
161 hp->fd = fd;
162 hp->dirty = 0;
163 biglob(hp)->fo = fpos + sizeof(HDGRID);
164 /* start tracking fragments */
165 hdattach(fd);
166 /* check rays on disk */
167 fpos = hdfilen(fd);
168 biglob(hp)->nrd = rtrunc = 0;
169 for (n = hproto == NULL ? nbeams(hp) : 0; n > 0; n--)
170 if (hp->bi[n].nrd)
171 if (hp->bi[n].fo+hp->bi[n].nrd*sizeof(RAYVAL) > fpos) {
172 rtrunc += hp->bi[n].nrd;
173 hp->bi[n].nrd = 0;
174 } else
175 biglob(hp)->nrd += hp->bi[n].nrd;
176 if (rtrunc) {
177 sprintf(errmsg, "truncated section, %ld rays lost (%.1f%%)",
178 rtrunc, 100.*rtrunc/(rtrunc+biglob(hp)->nrd));
179 error(WARNING, errmsg);
180 }
181 /* add to holodeck list */
182 for (n = 0; n < HDMAX; n++)
183 if (hdlist[n] == NULL) {
184 hdlist[n] = hp;
185 break;
186 }
187 /* all done */
188 return(hp);
189 memerr:
190 error(SYSTEM, "cannot allocate holodeck grid");
191 }
192
193
194 hdmarkdirty(hp, i) /* mark holodeck directory position dirty */
195 register HOLO *hp;
196 int i;
197 {
198 static BEAMI smudge = {0, -1};
199 int mindist, minpos;
200 register int j;
201
202 if (!hp->dirty++) { /* write smudge first time */
203 if (lseek(hp->fd, biglob(hp)->fo+(i-1)*sizeof(BEAMI), 0) < 0
204 || write(hp->fd, (char *)&smudge,
205 sizeof(BEAMI)) != sizeof(BEAMI))
206 error(SYSTEM, "seek/write error in hdmarkdirty");
207 hp->dirseg[0].s = i;
208 hp->dirseg[0].n = 1;
209 return;
210 }
211 /* insert into segment list */
212 for (j = hp->dirty; j--; ) {
213 if (!j || hp->dirseg[j-1].s < i) {
214 hp->dirseg[j].s = i;
215 hp->dirseg[j].n = 1;
216 break;
217 }
218 copystruct(hp->dirseg+j, hp->dirseg+(j-1));
219 }
220 do { /* check neighbors */
221 mindist = nbeams(hp); /* find closest */
222 for (j = hp->dirty; --j; )
223 if (hp->dirseg[j].s -
224 (hp->dirseg[j-1].s + hp->dirseg[j-1].n)
225 < mindist) {
226 minpos = j;
227 mindist = hp->dirseg[j].s -
228 (hp->dirseg[j-1].s + hp->dirseg[j-1].n);
229 }
230 /* good enough? */
231 if (hp->dirty <= MAXDIRSE && mindist > MINDIRSEL)
232 break;
233 j = minpos - 1; /* coalesce neighbors */
234 if (hp->dirseg[j].s + hp->dirseg[j].n <
235 hp->dirseg[minpos].s + hp->dirseg[minpos].n)
236 hp->dirseg[j].n = hp->dirseg[minpos].s +
237 hp->dirseg[minpos].n - hp->dirseg[j].s;
238 hp->dirty--;
239 while (++j < hp->dirty) /* close the gap */
240 copystruct(hp->dirseg+j, hp->dirseg+(j+1));
241 } while (mindist <= MINDIRSEL);
242 }
243
244
245 int
246 hdsync(hp, all) /* update beams and directory on disk */
247 register HOLO *hp;
248 int all;
249 {
250 register int j, n;
251
252 if (hp == NULL) { /* do all holodecks */
253 n = 0;
254 for (j = 0; hdlist[j] != NULL; j++)
255 n += hdsync(hdlist[j], all);
256 return(n);
257 }
258 /* sync the beams */
259 for (j = (all ? nbeams(hp) : 0); j > 0; j--)
260 if (hp->bl[j] != NULL)
261 hdsyncbeam(hp, j);
262 if (!hp->dirty) /* directory clean? */
263 return(0);
264 errno = 0; /* write dirty segments */
265 for (j = 0; j < hp->dirty; j++) {
266 if (lseek(hp->fd, biglob(hp)->fo +
267 (hp->dirseg[j].s-1)*sizeof(BEAMI), 0) < 0)
268 error(SYSTEM, "cannot seek on holodeck file");
269 n = hp->dirseg[j].n * sizeof(BEAMI);
270 if (write(hp->fd, (char *)(hp->bi+hp->dirseg[j].s), n) != n)
271 error(SYSTEM, "cannot update section directory");
272 }
273 hp->dirty = 0; /* all clean */
274 return(1);
275 }
276
277
278 unsigned
279 hdmemuse(all) /* return memory usage (in bytes) */
280 int all; /* include overhead (painful) */
281 {
282 long total = 0;
283 register int i, j;
284
285 for (j = 0; hdlist[j] != NULL; j++) {
286 total += blglob(hdlist[j])->nrm * sizeof(RAYVAL);
287 if (all) {
288 total += sizeof(HOLO) + sizeof(BEAM *) +
289 nbeams(hdlist[j]) *
290 (sizeof(BEAM *)+sizeof(BEAMI));
291 for (i = nbeams(hdlist[j]); i > 0; i--)
292 if (hdlist[j]->bl[i] != NULL)
293 total += sizeof(BEAM);
294 }
295 }
296 if (all)
297 for (j = 0; j < nhdfragls; j++) {
298 total += sizeof(struct fraglist);
299 if (hdfragl[j].nfrags)
300 total += FRAGBLK*sizeof(BEAMI) *
301 ((hdfragl[j].nfrags-1)/FRAGBLK + 1) ;
302 }
303 return(total);
304 }
305
306
307 long
308 hdfilen(fd) /* return file length for fd */
309 int fd;
310 {
311 long fpos, flen;
312
313 if (fd < 0)
314 return(-1);
315 if (fd >= nhdfragls || !hdfragl[fd].nlinks) {
316 if ((fpos = lseek(fd, 0L, 1)) < 0)
317 return(-1);
318 flen = lseek(fd, 0L, 2);
319 lseek(fd, fpos, 0);
320 return(flen);
321 }
322 return(hdfragl[fd].flen);
323 }
324
325
326 long
327 hdfiluse(fd, all) /* compute file usage (in bytes) */
328 int fd; /* open file descriptor to check */
329 int all; /* include overhead and unflushed data */
330 {
331 long total = 0;
332 register int i, j;
333
334 for (j = 0; hdlist[j] != NULL; j++) {
335 if (hdlist[j]->fd != fd)
336 continue;
337 total += biglob(hdlist[j])->nrd * sizeof(RAYVAL);
338 if (all) {
339 for (i = nbeams(hdlist[j]); i > 0; i--)
340 if (hdlist[j]->bl[i] != NULL)
341 total += sizeof(RAYVAL) *
342 (hdlist[j]->bl[i]->nrm -
343 hdlist[j]->bi[i].nrd);
344 total += sizeof(HDGRID) +
345 nbeams(hdlist[j])*sizeof(BEAMI);
346 }
347 }
348 return(total); /* does not include fragments */
349 }
350
351
352 RAYVAL *
353 hdnewrays(hp, i, nr) /* allocate space for add'l rays and return pointer */
354 register HOLO *hp;
355 register int i;
356 int nr; /* number of new rays desired */
357 {
358 RAYVAL *p;
359 int n;
360
361 if (nr <= 0) return(NULL);
362 CHECK(i < 1 | i > nbeams(hp),
363 CONSISTENCY, "bad beam index given to hdnewrays");
364 if (hp->bl[i] != NULL)
365 hp->bl[i]->tick = hdclock; /* preempt swap */
366 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
367 hdfreecache(PCTFREE, NULL); /* free some space */
368 if (hp->bl[i] == NULL) { /* allocate (and load) */
369 n = hp->bi[i].nrd + nr;
370 hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdnewrays");
371 blglob(hp)->nrm += n;
372 if ((n = hp->bl[i]->nrm = hp->bi[i].nrd)) {
373 errno = 0;
374 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
375 error(SYSTEM, "seek error on holodeck file");
376 n *= sizeof(RAYVAL);
377 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
378 error(SYSTEM,
379 "error reading beam from holodeck file");
380 }
381 } else { /* just grow in memory */
382 hp->bl[i] = (BEAM *)hdrealloc((char *)hp->bl[i],
383 hdbsiz(hp->bl[i]->nrm + nr), "hdnewrays");
384 blglob(hp)->nrm += nr;
385 }
386 if (hdfragflags&FF_ALLOC && hp->bi[i].nrd)
387 hdfreefrag(hp, i); /* relinquish old fragment */
388 p = hdbray(hp->bl[i]) + hp->bl[i]->nrm;
389 hp->bl[i]->nrm += nr; /* update in-core structure */
390 bzero((char *)p, nr*sizeof(RAYVAL));
391 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
392 return(p); /* point to new rays */
393 }
394
395
396 BEAM *
397 hdgetbeam(hp, i) /* get beam (from file if necessary) */
398 register HOLO *hp;
399 register int i;
400 {
401 register int n;
402
403 CHECK(i < 1 | i > nbeams(hp),
404 CONSISTENCY, "bad beam index given to hdgetbeam");
405 if (hp->bl[i] == NULL) { /* load from disk */
406 if (!(n = hp->bi[i].nrd))
407 return(NULL);
408 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
409 hdfreecache(PCTFREE, NULL); /* get free space */
410 hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdgetbeam");
411 blglob(hp)->nrm += hp->bl[i]->nrm = n;
412 errno = 0;
413 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
414 error(SYSTEM, "seek error on holodeck file");
415 n *= sizeof(RAYVAL);
416 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
417 error(SYSTEM, "error reading beam from holodeck file");
418 if (hdfragflags&FF_READ)
419 hdfreefrag(hp, i); /* relinquish old frag. */
420 }
421 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
422 return(hp->bl[i]);
423 }
424
425
426 int
427 hdfilord(hb1, hb2) /* order beams for quick loading */
428 register HDBEAMI *hb1, *hb2;
429 {
430 register long c;
431 /* residents go first */
432 if (hb2->h->bl[hb2->b] != NULL)
433 return(hb1->h->bl[hb1->b] == NULL);
434 if (hb1->h->bl[hb1->b] != NULL)
435 return(-1);
436 /* otherwise sort by file descriptor */
437 if ((c = hb1->h->fd - hb2->h->fd))
438 return(c);
439 /* then by position in file */
440 c = hb1->h->bi[hb1->b].fo - hb2->h->bi[hb2->b].fo;
441 return(c > 0 ? 1 : c < 0 ? -1 : 0);
442 }
443
444
445 hdloadbeams(hb, n, bf) /* load a list of beams in optimal order */
446 register HDBEAMI *hb; /* list gets sorted by hdfilord() */
447 int n; /* list length */
448 int (*bf)(); /* callback function (optional) */
449 {
450 unsigned origcachesize, memuse;
451 int bytesloaded, needbytes, bytes2free;
452 register BEAM *bp;
453 register int i;
454 /* precheck consistency */
455 if (n <= 0) return;
456 for (i = n; i--; )
457 if (hb[i].h==NULL || hb[i].b<1 | hb[i].b>nbeams(hb[i].h))
458 error(CONSISTENCY, "bad beam in hdloadbeams");
459 /* sort list for optimal access */
460 qsort((char *)hb, n, sizeof(HDBEAMI), hdfilord);
461 bytesloaded = 0; /* run through loaded beams */
462 for ( ; n && (bp = hb->h->bl[hb->b]) != NULL; n--, hb++) {
463 bp->tick = hdclock; /* preempt swap */
464 bytesloaded += bp->nrm;
465 if (bf != NULL)
466 (*bf)(bp, hb);
467 }
468 bytesloaded *= sizeof(RAYVAL);
469 if ((origcachesize = hdcachesize) > 0) {
470 needbytes = 0; /* figure out memory needs */
471 for (i = n; i--; )
472 needbytes += hb[i].h->bi[hb[i].b].nrd;
473 needbytes *= sizeof(RAYVAL);
474 do { /* free enough memory */
475 memuse = hdmemuse(0);
476 bytes2free = needbytes - (int)(hdcachesize-memuse);
477 if (bytes2free > (int)(memuse - bytesloaded))
478 bytes2free = memuse - bytesloaded;
479 } while (bytes2free > 0 &&
480 hdfreecache(100*bytes2free/memuse, NULL) < 0);
481 hdcachesize = 0; /* load beams w/o swap */
482 }
483 for (i = 0; i < n; i++)
484 if ((bp = hdgetbeam(hb[i].h, hb[i].b)) != NULL && bf != NULL)
485 (*bf)(bp, hb+i);
486 hdcachesize = origcachesize; /* resume dynamic swapping */
487 }
488
489
490 int
491 hdfreefrag(hp, i) /* free a file fragment */
492 HOLO *hp;
493 int i;
494 {
495 register BEAMI *bi = &hp->bi[i];
496 register struct fraglist *f;
497 register int j, k;
498
499 if (bi->nrd <= 0)
500 return(0);
501 DCHECK(hp->fd < 0 | hp->fd >= nhdfragls || !hdfragl[hp->fd].nlinks,
502 CONSISTENCY, "bad file descriptor in hdfreefrag");
503 f = &hdfragl[hp->fd];
504 if (f->nfrags % FRAGBLK == 0) { /* delete empty remnants */
505 for (j = k = 0; k < f->nfrags; j++, k++) {
506 while (f->fi[k].nrd == 0)
507 if (++k >= f->nfrags)
508 goto endloop;
509 if (k > j)
510 copystruct(f->fi+j, f->fi+k);
511 }
512 endloop:
513 f->nfrags = j;
514 }
515 j = f->nfrags++; /* allocate a slot in free list */
516 #if MAXFRAGB
517 if (j >= MAXFRAGB*FRAGBLK) {
518 f->nfrags = j--; /* stop list growth */
519 if (bi->nrd <= f->fi[j].nrd)
520 return(0); /* new one no better than discard */
521 }
522 #endif
523 if (j % FRAGBLK == 0) { /* more (or less) free list space */
524 register BEAMI *newp;
525 if (f->fi == NULL)
526 newp = (BEAMI *)malloc((j+FRAGBLK)*sizeof(BEAMI));
527 else
528 newp = (BEAMI *)realloc((char *)f->fi,
529 (j+FRAGBLK)*sizeof(BEAMI));
530 if (newp == NULL) {
531 f->nfrags--; /* graceful failure */
532 return(0);
533 }
534 f->fi = newp;
535 }
536 for ( ; ; j--) { /* insert in descending list */
537 if (!j || bi->fo < f->fi[j-1].fo) {
538 f->fi[j].fo = bi->fo;
539 f->fi[j].nrd = bi->nrd;
540 break;
541 }
542 copystruct(f->fi+j, f->fi+(j-1));
543 }
544 /* coalesce adjacent fragments */
545 /* successors never empty */
546 if (j && f->fi[j-1].fo == f->fi[j].fo + f->fi[j].nrd*sizeof(RAYVAL)) {
547 f->fi[j].nrd += f->fi[j-1].nrd;
548 f->fi[j-1].nrd = 0;
549 }
550 for (k = j+1; k < f->nfrags; k++) /* get non-empty predecessor */
551 if (f->fi[k].nrd) {
552 if (f->fi[j].fo == f->fi[k].fo +
553 f->fi[k].nrd*sizeof(RAYVAL)) {
554 f->fi[k].nrd += f->fi[j].nrd;
555 f->fi[j].nrd = 0;
556 }
557 break;
558 }
559 biglob(hp)->nrd -= bi->nrd; /* tell fragment it's free */
560 bi->nrd = 0;
561 bi->fo = 0L;
562 return(1);
563 }
564
565
566 int
567 hdfragOK(fd, listlen, listsiz) /* get fragment list status for file */
568 int fd;
569 int *listlen;
570 register int4 *listsiz;
571 {
572 register struct fraglist *f;
573 register int i;
574
575 if (fd < 0 | fd >= nhdfragls || !(f = &hdfragl[fd])->nlinks)
576 return(0); /* listless */
577 if (listlen != NULL)
578 *listlen = f->nfrags;
579 if (listsiz != NULL)
580 for (i = f->nfrags, *listsiz = 0; i--; )
581 *listsiz += f->fi[i].nrd;
582 #if MAXFRAGB
583 return(f->nfrags < MAXFRAGB*FRAGBLK);
584 #else
585 return(1); /* list never fills up */
586 #endif
587 }
588
589
590 long
591 hdallocfrag(fd, nrays) /* allocate a file fragment */
592 int fd;
593 unsigned int4 nrays;
594 {
595 register struct fraglist *f;
596 register int j;
597 long nfo;
598
599 if (nrays == 0)
600 return(-1L);
601 DCHECK(fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks,
602 CONSISTENCY, "bad file descriptor in hdallocfrag");
603 f = &hdfragl[fd];
604 for (j = f->nfrags; j-- > 0; ) /* first fit algorithm */
605 if (f->fi[j].nrd >= nrays)
606 break;
607 if (j < 0) { /* no fragment -- extend file */
608 nfo = f->flen;
609 f->flen += nrays*sizeof(RAYVAL);
610 } else { /* else use fragment */
611 nfo = f->fi[j].fo;
612 f->fi[j].fo += nrays*sizeof(RAYVAL);
613 f->fi[j].nrd -= nrays;
614 }
615 return(nfo);
616 }
617
618
619 int
620 hdsyncbeam(hp, i) /* sync beam in memory with beam on disk */
621 register HOLO *hp;
622 register int i;
623 {
624 unsigned int4 nrays;
625 unsigned int n;
626 long nfo;
627 /* check file status */
628 if (hdfragl[hp->fd].writerr)
629 return(-1);
630 DCHECK(i < 1 | i > nbeams(hp),
631 CONSISTENCY, "bad beam index in hdsyncbeam");
632 /* is current fragment OK? */
633 if (hp->bl[i] == NULL || (nrays = hp->bl[i]->nrm) == hp->bi[i].nrd)
634 return(0);
635 if (hdfragflags&FF_WRITE && hp->bi[i].nrd)
636 hdfreefrag(hp, i); /* relinquish old fragment */
637 if (nrays) { /* get and write new fragment */
638 nfo = hdallocfrag(hp->fd, nrays);
639 errno = 0;
640 if (lseek(hp->fd, nfo, 0) < 0)
641 error(SYSTEM, "cannot seek on holodeck file");
642 n = hp->bl[i]->nrm * sizeof(RAYVAL);
643 if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) {
644 hdfragl[hp->fd].writerr++;
645 hdsync(NULL, 0); /* sync directories */
646 error(SYSTEM, "write error in hdsyncbeam");
647 }
648 hp->bi[i].fo = nfo;
649 } else
650 hp->bi[i].fo = 0L;
651 biglob(hp)->nrd += nrays - hp->bi[i].nrd;
652 hp->bi[i].nrd = nrays;
653 hdmarkdirty(hp, i); /* section directory now out of date */
654 return(1);
655 }
656
657
658 int
659 hdfreebeam(hp, i) /* free beam, writing if dirty */
660 register HOLO *hp;
661 register int i;
662 {
663 int nchanged;
664
665 if (hp == NULL) { /* clear all holodecks */
666 nchanged = 0;
667 for (i = 0; hdlist[i] != NULL; i++)
668 nchanged += hdfreebeam(hdlist[i], 0);
669 return(nchanged);
670 }
671 if (hdfragl[hp->fd].writerr) /* check for file error */
672 return(0);
673 if (i == 0) { /* clear entire holodeck */
674 if (blglob(hp)->nrm == 0)
675 return(0); /* already clear */
676 nchanged = 0;
677 for (i = nbeams(hp); i > 0; i--)
678 if (hp->bl[i] != NULL)
679 nchanged += hdfreebeam(hp, i);
680 DCHECK(blglob(hp)->nrm != 0,
681 CONSISTENCY, "bad beam count in hdfreebeam");
682 return(nchanged);
683 }
684 DCHECK(i < 1 | i > nbeams(hp),
685 CONSISTENCY, "bad beam index to hdfreebeam");
686 if (hp->bl[i] == NULL)
687 return(0);
688 /* check for additions */
689 nchanged = hp->bl[i]->nrm - hp->bi[i].nrd;
690 if (nchanged)
691 hdsyncbeam(hp, i); /* write new fragment */
692 blglob(hp)->nrm -= hp->bl[i]->nrm;
693 free((char *)hp->bl[i]); /* free memory */
694 hp->bl[i] = NULL;
695 return(nchanged);
696 }
697
698
699 int
700 hdkillbeam(hp, i) /* delete beam from holodeck */
701 register HOLO *hp;
702 register int i;
703 {
704 int nchanged;
705
706 if (hp == NULL) { /* clobber all holodecks */
707 nchanged = 0;
708 for (i = 0; hdlist[i] != NULL; i++)
709 nchanged += hdkillbeam(hdlist[i], 0);
710 return(nchanged);
711 }
712 if (i == 0) { /* clobber entire holodeck */
713 if (biglob(hp)->nrd == 0 & blglob(hp)->nrm == 0)
714 return(0); /* already empty */
715 nchanged = 0;
716 nchanged = 0;
717 for (i = nbeams(hp); i > 0; i--)
718 if (hp->bi[i].nrd > 0 || hp->bl[i] != NULL)
719 nchanged += hdkillbeam(hp, i);
720 DCHECK(biglob(hp)->nrd != 0 | blglob(hp)->nrm != 0,
721 CONSISTENCY, "bad beam count in hdkillbeam");
722 return(nchanged);
723 }
724 DCHECK(i < 1 | i > nbeams(hp),
725 CONSISTENCY, "bad beam index to hdkillbeam");
726 if (hp->bl[i] != NULL) { /* free memory */
727 blglob(hp)->nrm -= nchanged = hp->bl[i]->nrm;
728 free((char *)hp->bl[i]);
729 } else
730 nchanged = hp->bi[i].nrd;
731 if (hp->bi[i].nrd) {
732 if (hdfragflags&FF_KILL)
733 hdfreefrag(hp, i);
734 biglob(hp)->nrd -= hp->bi[i].nrd;
735 hp->bi[i].nrd = 0; /* make sure it's gone */
736 hp->bi[i].fo = 0L;
737 }
738 hp->bl[i] = NULL;
739 return(nchanged);
740 }
741
742
743 int
744 hdlrulist(hb, nents, n, hp) /* add beams from holodeck to LRU list */
745 register HDBEAMI *hb; /* beam list */
746 int nents; /* current list length */
747 int n; /* maximum list length */
748 register HOLO *hp; /* section we're adding from */
749 {
750 register int i, j;
751 /* insert each beam from hp */
752 for (i = 1; i <= nbeams(hp); i++) {
753 if (hp->bl[i] == NULL) /* check if loaded */
754 continue;
755 #if 0
756 if (hp->bl[i]->tick == hdclock) /* preempt swap? */
757 continue;
758 #endif
759 if ((j = ++nents) >= n) /* grow list if we can */
760 nents--;
761 for ( ; ; ) { /* bubble into place */
762 if (!--j || hp->bl[i]->tick >=
763 hb[j-1].h->bl[hb[j-1].b]->tick) {
764 hb[j].h = hp;
765 hb[j].b = i;
766 break;
767 }
768 copystruct(hb+j, hb+(j-1));
769 }
770 }
771 return(nents); /* return new list length */
772 }
773
774
775 int
776 hdfreecache(pct, honly) /* free up cache space, writing changes */
777 int pct; /* maximum percentage to free */
778 register HOLO *honly; /* NULL means check all */
779 {
780 HDBEAMI hb[FREEBEAMS];
781 int freetarget;
782 int n;
783 register int i;
784 #ifdef DEBUG
785 unsigned membefore;
786
787 membefore = hdmemuse(0);
788 #endif
789 /* compute free target */
790 freetarget = (honly != NULL) ? blglob(honly)->nrm :
791 hdmemuse(0)/sizeof(RAYVAL) ;
792 freetarget = freetarget*pct/100;
793 if (freetarget <= 0)
794 return(0);
795 /* find least recently used */
796 n = 0;
797 if (honly != NULL)
798 n = hdlrulist(hb, n, FREEBEAMS, honly);
799 else
800 for (i = 0; hdlist[i] != NULL; i++)
801 n = hdlrulist(hb, n, FREEBEAMS, hdlist[i]);
802 /* free LRU beams */
803 for (i = 0; i < n; i++) {
804 hdfreebeam(hb[i].h, hb[i].b);
805 if ((freetarget -= hb[i].h->bi[hb[i].b].nrd) <= 0)
806 break;
807 }
808 hdsync(honly, 0); /* synchronize directories as necessary */
809 #ifdef DEBUG
810 sprintf(errmsg,
811 "%dK before, %dK after hdfreecache (%dK total), %d rays short\n",
812 membefore>>10, hdmemuse(0)>>10, hdmemuse(1)>>10, freetarget);
813 wputs(errmsg);
814 #endif
815 return(-freetarget); /* return how far past goal we went */
816 }
817
818
819 hddone(hp) /* clean up holodeck section and free */
820 register HOLO *hp; /* NULL means clean up all */
821 {
822 register int i;
823
824 if (hp == NULL) { /* NULL means clean up everything */
825 while (hdlist[0] != NULL)
826 hddone(hdlist[0]);
827 free((char *)hdfragl);
828 hdfragl = NULL; nhdfragls = 0;
829 return;
830 }
831 /* flush all data and free memory */
832 hdflush(hp);
833 /* release fragment resources */
834 hdrelease(hp->fd);
835 /* remove hp from active list */
836 for (i = 0; hdlist[i] != NULL; i++)
837 if (hdlist[i] == hp) {
838 while ((hdlist[i] = hdlist[i+1]) != NULL)
839 i++;
840 break;
841 }
842 free((char *)hp->bl); /* free beam list */
843 free((char *)hp); /* free holodeck struct */
844 }
