--- ray/src/hd/holofile.c 1999/08/05 15:53:09 3.41 +++ ray/src/hd/holofile.c 2003/05/15 05:13:35 3.45 @@ -1,9 +1,6 @@ -/* Copyright (c) 1999 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: holofile.c,v 3.45 2003/05/15 05:13:35 greg Exp $"; #endif - /* * Routines for managing holodeck files * @@ -13,10 +10,10 @@ static char SCCSid[] = "$SunId$ SGI"; #include "holo.h" #ifndef CACHESIZE -#ifdef BIGMEM -#define CACHESIZE 17 /* default cache size (Mbytes, 0==inf) */ -#else +#ifdef SMLMEM #define CACHESIZE 5 +#else +#define CACHESIZE 17 /* default cache size (Mbytes, 0==inf) */ #endif #endif #ifndef FREEBEAMS @@ -69,7 +66,7 @@ HDGRID *hproto; register HOLO *hp; int n; /* copy grid to temporary header */ - bcopy((char *)hproto, (char *)&hdhead, sizeof(HDGRID)); + bcopy((void *)hproto, (void *)&hdhead, sizeof(HDGRID)); /* compute grid vectors and sizes */ hdcompgrid(&hdhead); /* allocate header with directory */ @@ -81,16 +78,16 @@ HDGRID *hproto; /* allocate and clear beam list */ hp->bl = (BEAM **)malloc((nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM)); if (hp->bl == NULL) { - free((char *)hp); + free((void *)hp); return(NULL); } - bzero((char *)hp->bl, (nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM)); + bzero((void *)hp->bl, (nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM)); hp->bl[0] = (BEAM *)(hp->bl+nbeams(hp)+1); /* set blglob(hp) */ hp->fd = -1; hp->dirty = 0; hp->priv = NULL; /* clear beam directory */ - bzero((char *)hp->bi, (nbeams(hp)+1)*sizeof(BEAMI)); + bzero((void *)hp->bi, (nbeams(hp)+1)*sizeof(BEAMI)); return(hp); /* all is well */ } @@ -104,7 +101,7 @@ char *rout; register char *newp; /* call malloc/realloc */ if (ptr == NULL) newp = (char *)malloc(siz); - else newp = (char *)realloc(ptr, siz); + else newp = (char *)realloc((void *)ptr, siz); /* check success */ if (newp == NULL && rout != NULL) { hdfreecache(25, NULL); /* free some memory */ @@ -126,13 +123,13 @@ int wr; if (fd >= nhdfragls) { hdfragl = (struct fraglist *)hdrealloc((char *)hdfragl, (fd+1)*sizeof(struct fraglist), "hdattach"); - bzero((char *)(hdfragl+nhdfragls), + bzero((void *)(hdfragl+nhdfragls), (fd+1-nhdfragls)*sizeof(struct fraglist)); nhdfragls = fd+1; } hdfragl[fd].nlinks++; hdfragl[fd].writable = wr; /* set writable flag */ - hdfragl[fd].flen = lseek(fd, 0L, 2); /* get file length */ + hdfragl[fd].flen = lseek(fd, (off_t)0L, 2); /* get file length */ } @@ -145,7 +142,7 @@ register int fd; if (fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks) return; if (!--hdfragl[fd].nlinks && hdfragl[fd].nfrags) { - free((char *)hdfragl[fd].fi); + free((void *)hdfragl[fd].fi); hdfragl[fd].fi = NULL; hdfragl[fd].nfrags = 0; } @@ -164,7 +161,7 @@ HDGRID *hproto; /* holodeck section grid */ register int n; /* prepare for system errors */ errno = 0; - if ((fpos = lseek(fd, 0L, 1)) < 0) + if ((fpos = lseek(fd, (off_t)0L, 1)) < 0) error(SYSTEM, "cannot determine holodeck file position"); if (hproto == NULL) { /* assume we're loading it */ HDGRID hpr; @@ -189,7 +186,7 @@ HDGRID *hproto; /* holodeck section grid */ if (fd < nhdfragls && hdfragl[fd].nlinks) writable = hdfragl[fd].writable; else - writable = lseek(fd, fpos, 0) == fpos && + writable = lseek(fd, (off_t)fpos, 0) == fpos && write(fd, (char *)hp, sizeof(HDGRID)) == sizeof(HDGRID); } else { /* else assume we're creating it */ @@ -245,7 +242,7 @@ int i; register int j; if (!hp->dirty++) { /* write smudge first time */ - if (lseek(hp->fd, biglob(hp)->fo+(i-1)*sizeof(BEAMI), 0) < 0 + if (lseek(hp->fd, (off_t)(biglob(hp)->fo+(i-1)*sizeof(BEAMI)), 0) < 0 || write(hp->fd, (char *)&smudge, sizeof(BEAMI)) != sizeof(BEAMI)) error(SYSTEM, "seek/write error in hdmarkdirty"); @@ -308,8 +305,8 @@ int all; return(0); errno = 0; /* write dirty segments */ for (j = 0; j < hp->dirty; j++) { - if (lseek(hp->fd, biglob(hp)->fo + - (hp->dirseg[j].s-1)*sizeof(BEAMI), 0) < 0) + if (lseek(hp->fd, (off_t)(biglob(hp)->fo + + (hp->dirseg[j].s-1)*sizeof(BEAMI)), 0) < 0) error(SYSTEM, "cannot seek on holodeck file"); n = hp->dirseg[j].n * sizeof(BEAMI); if (write(hp->fd, (char *)(hp->bi+hp->dirseg[j].s), n) != n) @@ -358,10 +355,10 @@ int fd; if (fd < 0) return(-1); if (fd >= nhdfragls || !hdfragl[fd].nlinks) { - if ((fpos = lseek(fd, 0L, 1)) < 0) + if ((fpos = lseek(fd, (off_t)0L, 1)) < 0) return(-1); - flen = lseek(fd, 0L, 2); - lseek(fd, fpos, 0); + flen = lseek(fd, (off_t)0L, 2); + lseek(fd, (off_t)fpos, 0); return(flen); } return(hdfragl[fd].flen); @@ -416,7 +413,7 @@ int nr; /* number of new rays desired */ blglob(hp)->nrm += n; if ((n = hp->bl[i]->nrm = hp->bi[i].nrd)) { errno = 0; - if (lseek(hp->fd, hp->bi[i].fo, 0) < 0) + if (lseek(hp->fd, (off_t)hp->bi[i].fo, 0) < 0) error(SYSTEM, "seek error on holodeck file"); n *= sizeof(RAYVAL); if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) @@ -432,7 +429,7 @@ int nr; /* number of new rays desired */ hdfreefrag(hp, i); /* relinquish old fragment */ p = hdbray(hp->bl[i]) + hp->bl[i]->nrm; hp->bl[i]->nrm += nr; /* update in-core structure */ - bzero((char *)p, nr*sizeof(RAYVAL)); + bzero((void *)p, nr*sizeof(RAYVAL)); blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */ return(p); /* point to new rays */ } @@ -455,7 +452,7 @@ register int i; hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdgetbeam"); blglob(hp)->nrm += hp->bl[i]->nrm = n; errno = 0; - if (lseek(hp->fd, hp->bi[i].fo, 0) < 0) + if (lseek(hp->fd, (off_t)hp->bi[i].fo, 0) < 0) error(SYSTEM, "seek error on holodeck file"); n *= sizeof(RAYVAL); if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) @@ -502,7 +499,7 @@ int (*bf)(); /* callback function (optional) */ if (hb[i].h==NULL || hb[i].b<1 | hb[i].b>nbeams(hb[i].h)) error(CONSISTENCY, "bad beam in hdloadbeams"); /* sort list for optimal access */ - qsort((char *)hb, n, sizeof(HDBEAMI), hdfilord); + qsort((void *)hb, n, sizeof(HDBEAMI), hdfilord); bytesloaded = 0; /* run through loaded beams */ for ( ; n && (bp = hb->h->bl[hb->b]) != NULL; n--, hb++) { bp->tick = hdclock; /* preempt swap */ @@ -572,7 +569,7 @@ int i; if (f->fi == NULL) newp = (BEAMI *)malloc((j+FRAGBLK)*sizeof(BEAMI)); else - newp = (BEAMI *)realloc((char *)f->fi, + newp = (BEAMI *)realloc((void *)f->fi, (j+FRAGBLK)*sizeof(BEAMI)); if (newp == NULL) { f->nfrags--; /* graceful failure */ @@ -686,7 +683,7 @@ register int i; if (nrays) { /* get and write new fragment */ nfo = hdallocfrag(hp->fd, nrays); errno = 0; - if (lseek(hp->fd, nfo, 0) < 0) + if (lseek(hp->fd, (off_t)nfo, 0) < 0) error(SYSTEM, "cannot seek on holodeck file"); n = hp->bl[i]->nrm * sizeof(RAYVAL); if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) { @@ -740,7 +737,7 @@ register int i; if (nchanged) hdsyncbeam(hp, i); /* write new fragment */ blglob(hp)->nrm -= hp->bl[i]->nrm; - free((char *)hp->bl[i]); /* free memory */ + free((void *)hp->bl[i]); /* free memory */ hp->bl[i] = NULL; return(nchanged); } @@ -777,7 +774,7 @@ register int i; "hdkillbeam called on read-only holodeck"); if (hp->bl[i] != NULL) { /* free memory */ blglob(hp)->nrm -= nchanged = hp->bl[i]->nrm; - free((char *)hp->bl[i]); + free((void *)hp->bl[i]); hp->bl[i] = NULL; } else nchanged = hp->bi[i].nrd; @@ -875,7 +872,7 @@ register HOLO *hp; /* NULL means clean up all */ if (hp == NULL) { /* NULL means clean up everything */ while (hdlist[0] != NULL) hddone(hdlist[0]); - free((char *)hdfragl); + free((void *)hdfragl); hdfragl = NULL; nhdfragls = 0; return; } @@ -890,6 +887,6 @@ register HOLO *hp; /* NULL means clean up all */ i++; break; } - free((char *)hp->bl); /* free beam list */ - free((char *)hp); /* free holodeck struct */ + free((void *)hp->bl); /* free beam list */ + free((void *)hp); /* free holodeck struct */ }
