root/radiance/ray/src/hd/holofile.c
Revision 3.42 - (view) (download) (annotate) - [select for diffs]
Changes since 3.41: +20 -23 lines
Diff to previous 3.41 , to selected 3.33
Thu Aug 5 15:53:09 1999 UTC (24 years, 9 months ago) by gwlarson
Changes since 3.40: +26 -11 lines
Diff to previous 3.40 , to selected 3.33
added -r option for read-only holodecks
Revision 3.40 - (view) (download) (annotate) - [select for diffs]
Fri Mar 12 09:37:48 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.39: +34 -0 lines
Diff to previous 3.39 , to selected 3.33
moved hdalloc() from holo.c to holofile.c
Tue Mar 9 08:40:11 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.38: +12 -10 lines
Diff to previous 3.38 , to selected 3.33
changed default fragment handling flags
fixed problem with inconsistent directory updating
Thu Feb 25 13:25:38 1999 UTC (25 years, 3 months ago) by gwlarson
Changes since 3.37: +2 -2 lines
Diff to previous 3.37 , to selected 3.33
reduced default cache size
Wed Feb 10 17:09:20 1999 UTC (25 years, 3 months ago) by gwlarson
Changes since 3.36: +4 -5 lines
Diff to previous 3.36 , to selected 3.33
changed markdirty() to hdmarkdirty() to avoid naming conflicts
Mon Feb 1 09:56:18 1999 UTC (25 years, 3 months ago) by gwlarson
Changes since 3.35: +7 -0 lines
Diff to previous 3.35 , to selected 3.33
made caching code slightly more efficient
Mon Jan 25 09:58:41 1999 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.34: +5 -1 lines
Diff to previous 3.34 , to selected 3.33
changed default CACHESIZE based on BIGMEM macro
Tue Jan 19 10:08:34 1999 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.33: +4 -2 lines
Diff to previous 3.33
fixed occupied disk sample accounting in biglob(hp)->nrd
Revision 3.33 - (view) (download) (annotate) - [selected]
Sat Jan 9 09:16:14 1999 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.32: +13 -14 lines
Diff to previous 3.32
changed to first-fit algorithm in hdallocfrag()
Thu Jan 7 22:04:49 1999 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.31: +72 -48 lines
Diff to previous 3.31 , to selected 3.33
Wed Dec 30 11:30:04 1998 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.30: +9 -6 lines
Diff to previous 3.30 , to selected 3.33
made it so we don't toss off large fragment for smaller one
fixed accumulation of empty fragments when maximum list size reached
Thu Dec 10 10:45:02 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.29: +1 -1 lines
Diff to previous 3.29 , to selected 3.33
reduced size of fragment list to speed hdflush() calls
Wed Nov 11 10:56:07 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.28: +20 -13 lines
Diff to previous 3.28 , to selected 3.33
modified markdirty() to ensure that no gap is smaller than BUFSIZ*4
Mon Nov 9 17:10:53 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.27: +65 -25 lines
Diff to previous 3.27 , to selected 3.33
changed section directory code to write in segments
Wed Nov 4 16:44:16 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.26: +3 -2 lines
Diff to previous 3.26 , to selected 3.33
bug fixes in hdinit() and hddone()
Fri Sep 18 16:47:27 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 3.25: +40 -24 lines
Diff to previous 3.25 , to selected 3.33
added recovery from memory allocation errors
Fri Sep 18 13:51:01 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 3.24: +15 -5 lines
Diff to previous 3.24 , to selected 3.33
added debugging statement to track hdfreecache() performance
Tue Sep 15 14:26:23 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 3.23: +2 -0 lines
Diff to previous 3.23 , to selected 3.33
free fragment list in hddone(NULL) call
Wed Aug 12 17:53:59 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.22: +4 -4 lines
Diff to previous 3.22 , to selected 3.33
changed parameters to function passed to hdloadbeams()
Thu Feb 12 16:30:04 1998 UTC (26 years, 3 months ago) by gwlarson
Changes since 3.21: +11 -4 lines
Diff to previous 3.21 , to selected 3.33
added warning for truncated sections
Wed Jan 7 17:31:00 1998 UTC (26 years, 4 months ago) by gregl
Diff to previous 3.20 , to selected 3.33
parameter tuning -- doubled FREEBEAMS
Mon Jan 5 16:45:24 1998 UTC (26 years, 4 months ago) by gregl
Diff to previous 3.19 , to selected 3.33
changed dirty holodeck to just a warning
Sun Jan 4 12:32:53 1998 UTC (26 years, 4 months ago) by gregl
Changes since 3.18: +109 -80 lines
Diff to previous 3.18 , to selected 3.33
took fragment resource management out of hdsyncbeam()
Thu Jan 1 16:40:38 1998 UTC (26 years, 4 months ago) by gregl
Changes since 3.17: +2 -5 lines
Diff to previous 3.17 , to selected 3.33
changed hdsync() call before error() in hdsyncbeam()
Thu Jan 1 13:00:14 1998 UTC (26 years, 4 months ago) by gregl
Changes since 3.16: +23 -14 lines
Diff to previous 3.16 , to selected 3.33
Wed Dec 31 11:35:39 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.15: +41 -38 lines
Diff to previous 3.15 , to selected 3.33
more minor improvements to hdsyncbeam()
Mon Dec 29 15:17:45 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.14: +44 -42 lines
Diff to previous 3.14 , to selected 3.33
slight efficiency improvement in fragment code of hdsyncbeam()
Thu Dec 18 15:12:23 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.13: +90 -34 lines
Diff to previous 3.13 , to selected 3.33
Fri Dec 12 21:29:34 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.12: +22 -12 lines
Diff to previous 3.12 , to selected 3.33
made recovery from file write errors more robust
Fri Dec 12 19:52:31 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.11: +25 -12 lines
Diff to previous 3.11 , to selected 3.33
modified hdsync() to optionally sync all unflushed beams
Thu Dec 11 19:57:58 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.10: +30 -25 lines
Diff to previous 3.10 , to selected 3.33
made beam writing safer in the event of signals
Thu Dec 11 11:29:35 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.9: +45 -3 lines
Diff to previous 3.9 , to selected 3.33
added function to delete beams and clobber holodecks
Thu Dec 11 09:35:58 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.8: +5 -1 lines
Diff to previous 3.8 , to selected 3.33
added preventative measure following write error in hdfreebeam()
Tue Nov 11 11:31:54 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.7: +20 -1 lines
Diff to previous 3.7 , to selected 3.33
made file length testing more efficient
Thu Nov 6 09:50:12 1997 UTC (26 years, 6 months ago) by gregl
Diff to previous 3.6 , to selected 3.33
undefined MAXFRAG
Thu Nov 6 09:37:04 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.5: +24 -1 lines
Diff to previous 3.5 , to selected 3.33
added marking and detection of inconsistent holodeck files
Wed Nov 5 17:28:49 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.4: +9 -10 lines
Diff to previous 3.4 , to selected 3.33
changed some constants related to paging
Tue Nov 4 10:42:03 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.3: +53 -30 lines
Diff to previous 3.3 , to selected 3.33
dynamically allocate fragment lists
Mon Nov 3 13:40:22 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.2: +11 -7 lines
Diff to previous 3.2 , to selected 3.33
bug fixes in hdgetbi()
Fri Oct 31 15:48:32 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.1: +20 -17 lines
Diff to previous 3.1 , to selected 3.33
initial bug fixes (hdgetbi)
Fri Oct 31 10:23:29 1997 UTC (26 years, 6 months ago) by gregl
Diff to selected 3.33
