root/radiance/ray/src/hd/holofile.c
Revision: 3.42
Committed: Sat Feb 22 02:07:24 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.41: +20 -23 lines
# User Rev Content
1 gregl 3.1 #ifndef lint
2 greg 3.42 static const char RCSid[] = "$Id$";
3 gregl 3.1 #endif
4     /*
5     * Routines for managing holodeck files
6     *
7     * 9/30/97 GWLarson
8     */
9
10     #include "holo.h"
11
12     #ifndef CACHESIZE
13 gwlarson 3.35 #ifdef BIGMEM
14 gwlarson 3.38 #define CACHESIZE 17 /* default cache size (Mbytes, 0==inf) */
15 gwlarson 3.35 #else
16 gwlarson 3.38 #define CACHESIZE 5
17 gwlarson 3.35 #endif
18 gregl 3.1 #endif
19     #ifndef FREEBEAMS
20 gwlarson 3.25 #define FREEBEAMS 1500 /* maximum beams to free at a time */
21 gregl 3.1 #endif
22     #ifndef PCTFREE
23 gregl 3.21 #define PCTFREE 15 /* maximum fraction to free (%) */
24 gregl 3.1 #endif
25 gwlarson 3.31 #ifndef MAXFRAGB
26     #define MAXFRAGB 16 /* fragment blocks/file to track (0==inf) */
27 gregl 3.15 #endif
28 gwlarson 3.32 #ifndef FF_DEFAULT
29     /* when to free a beam fragment */
30 gwlarson 3.39 #define FF_DEFAULT (FF_WRITE|FF_KILL)
31 gwlarson 3.32 #endif
32 gwlarson 3.29 #ifndef MINDIRSEL
33     /* minimum directory seek length */
34     #define MINDIRSEL (4*BUFSIZ/sizeof(BEAMI))
35     #endif
36 gregl 3.1
37 gregl 3.6 #ifndef BSD
38     #define write writebuf /* safe i/o routines */
39     #define read readbuf
40     #endif
41 gregl 3.4
42 gwlarson 3.31 #define FRAGBLK 512 /* number of fragments to allocate at a time */
43 gregl 3.4
44 gwlarson 3.32 int hdfragflags = FF_DEFAULT; /* tells when to free fragments */
45 gregl 3.14 unsigned hdcachesize = CACHESIZE*1024*1024; /* target cache size */
46 gwlarson 3.32 unsigned long hdclock; /* clock value */
47 gregl 3.1
48     HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */
49
50 gregl 3.16 static struct fraglist {
51 gregl 3.1 short nlinks; /* number of holodeck sections using us */
52 gwlarson 3.41 short writable; /* 0 read-only, <0 write error encountered */
53 gregl 3.13 int nfrags; /* number of known fragments */
54 gregl 3.4 BEAMI *fi; /* fragments, descending file position */
55 gregl 3.1 long flen; /* last known file length */
56 gregl 3.16 } *hdfragl; /* fragment lists, indexed by file descriptor */
57 gregl 3.1
58 gregl 3.16 static int nhdfragls; /* size of hdfragl array */
59 gregl 3.1
60 gregl 3.4
61 gwlarson 3.40 HOLO *
62     hdalloc(hproto) /* allocate and set holodeck section based on grid */
63     HDGRID *hproto;
64     {
65     HOLO hdhead;
66     register HOLO *hp;
67     int n;
68     /* copy grid to temporary header */
69     bcopy((char *)hproto, (char *)&hdhead, sizeof(HDGRID));
70     /* compute grid vectors and sizes */
71     hdcompgrid(&hdhead);
72     /* allocate header with directory */
73     n = sizeof(HOLO)+nbeams(&hdhead)*sizeof(BEAMI);
74     if ((hp = (HOLO *)malloc(n)) == NULL)
75     return(NULL);
76     /* copy header information */
77     copystruct(hp, &hdhead);
78     /* allocate and clear beam list */
79     hp->bl = (BEAM **)malloc((nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM));
80     if (hp->bl == NULL) {
81 greg 3.42 free((void *)hp);
82 gwlarson 3.40 return(NULL);
83     }
84     bzero((char *)hp->bl, (nbeams(hp)+1)*sizeof(BEAM *)+sizeof(BEAM));
85     hp->bl[0] = (BEAM *)(hp->bl+nbeams(hp)+1); /* set blglob(hp) */
86     hp->fd = -1;
87     hp->dirty = 0;
88     hp->priv = NULL;
89     /* clear beam directory */
90     bzero((char *)hp->bi, (nbeams(hp)+1)*sizeof(BEAMI));
91     return(hp); /* all is well */
92     }
93
94
95 gwlarson 3.26 char *
96     hdrealloc(ptr, siz, rout) /* (re)allocate memory, retry then error */
97     char *ptr;
98     unsigned siz;
99     char *rout;
100     {
101     register char *newp;
102     /* call malloc/realloc */
103     if (ptr == NULL) newp = (char *)malloc(siz);
104     else newp = (char *)realloc(ptr, siz);
105     /* check success */
106     if (newp == NULL && rout != NULL) {
107     hdfreecache(25, NULL); /* free some memory */
108     errno = 0; /* retry */
109     newp = hdrealloc(ptr, siz, NULL);
110     if (newp == NULL) { /* give up and report error */
111     sprintf(errmsg, "out of memory in %s", rout);
112     error(SYSTEM, errmsg);
113     }
114     }
115     return(newp);
116     }
117
118
119 gwlarson 3.41 hdattach(fd, wr) /* start tracking file fragments for some section */
120 gregl 3.1 register int fd;
121 gwlarson 3.41 int wr;
122 gregl 3.1 {
123 gregl 3.16 if (fd >= nhdfragls) {
124 gwlarson 3.26 hdfragl = (struct fraglist *)hdrealloc((char *)hdfragl,
125     (fd+1)*sizeof(struct fraglist), "hdattach");
126 gregl 3.16 bzero((char *)(hdfragl+nhdfragls),
127     (fd+1-nhdfragls)*sizeof(struct fraglist));
128     nhdfragls = fd+1;
129 gregl 3.1 }
130 gregl 3.16 hdfragl[fd].nlinks++;
131 gwlarson 3.41 hdfragl[fd].writable = wr; /* set writable flag */
132 greg 3.42 hdfragl[fd].flen = lseek(fd, (off_t)0L, 2); /* get file length */
133 gregl 3.1 }
134
135
136     /* Do we need a routine to locate file fragments given known occupants? */
137
138
139     hdrelease(fd) /* stop tracking file fragments for some section */
140     register int fd;
141     {
142 gregl 3.16 if (fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks)
143 gregl 3.1 return;
144 gregl 3.16 if (!--hdfragl[fd].nlinks && hdfragl[fd].nfrags) {
145 greg 3.42 free((void *)hdfragl[fd].fi);
146 gregl 3.16 hdfragl[fd].fi = NULL;
147     hdfragl[fd].nfrags = 0;
148 gregl 3.1 }
149     }
150
151
152     HOLO *
153     hdinit(fd, hproto) /* initialize a holodeck section in a file */
154     int fd; /* corresponding file descriptor */
155     HDGRID *hproto; /* holodeck section grid */
156     {
157 gwlarson 3.22 long rtrunc;
158 gregl 3.1 long fpos;
159 gwlarson 3.41 int writable;
160 gregl 3.1 register HOLO *hp;
161     register int n;
162     /* prepare for system errors */
163     errno = 0;
164 greg 3.42 if ((fpos = lseek(fd, (off_t)0L, 1)) < 0)
165 gregl 3.1 error(SYSTEM, "cannot determine holodeck file position");
166     if (hproto == NULL) { /* assume we're loading it */
167     HDGRID hpr;
168     /* load header */
169     if (read(fd, (char *)&hpr, sizeof(HDGRID)) != sizeof(HDGRID))
170     error(SYSTEM, "cannot load holodeck header");
171     /* allocate grid */
172     if ((hp = hdalloc(&hpr)) == NULL)
173     goto memerr;
174     /* load beam directory */
175     n = nbeams(hp)*sizeof(BEAMI);
176     if (read(fd, (char *)(hp->bi+1), n) != n)
177     error(SYSTEM, "failure loading holodeck directory");
178 gregl 3.6 /* check that it's clean */
179 gwlarson 3.28 for (n = nbeams(hp); n > 0; n--)
180     if (hp->bi[n].fo < 0) {
181     hp->bi[n].fo = 0;
182     error(WARNING, "dirty holodeck section");
183     break;
184     }
185 gwlarson 3.41 /* check writability */
186     if (fd < nhdfragls && hdfragl[fd].nlinks)
187     writable = hdfragl[fd].writable;
188     else
189 greg 3.42 writable = lseek(fd, (off_t)fpos, 0) == fpos &&
190 gwlarson 3.41 write(fd, (char *)hp, sizeof(HDGRID)) ==
191     sizeof(HDGRID);
192     } else { /* else assume we're creating it */
193 gregl 3.1 if ((hp = hdalloc(hproto)) == NULL)
194     goto memerr;
195     /* write header and skeleton */
196     n = nbeams(hp)*sizeof(BEAMI);
197     if (write(fd, (char *)hproto, sizeof(HDGRID)) !=
198     sizeof(HDGRID) ||
199     write(fd, (char *)(hp->bi+1), n) != n)
200     error(SYSTEM, "cannot write header to holodeck file");
201 gwlarson 3.41 writable = 1;
202 gregl 3.1 }
203     hp->fd = fd;
204     hp->dirty = 0;
205     biglob(hp)->fo = fpos + sizeof(HDGRID);
206 gregl 3.13 /* start tracking fragments */
207 gwlarson 3.41 hdattach(fd, writable);
208 gregl 3.13 /* check rays on disk */
209     fpos = hdfilen(fd);
210 gwlarson 3.22 biglob(hp)->nrd = rtrunc = 0;
211 gregl 3.13 for (n = hproto == NULL ? nbeams(hp) : 0; n > 0; n--)
212     if (hp->bi[n].nrd)
213 gwlarson 3.27 if (hp->bi[n].fo+hp->bi[n].nrd*sizeof(RAYVAL) > fpos) {
214 gwlarson 3.22 rtrunc += hp->bi[n].nrd;
215     hp->bi[n].nrd = 0;
216     } else
217 gregl 3.13 biglob(hp)->nrd += hp->bi[n].nrd;
218 gwlarson 3.22 if (rtrunc) {
219     sprintf(errmsg, "truncated section, %ld rays lost (%.1f%%)",
220     rtrunc, 100.*rtrunc/(rtrunc+biglob(hp)->nrd));
221     error(WARNING, errmsg);
222     }
223 gregl 3.1 /* add to holodeck list */
224     for (n = 0; n < HDMAX; n++)
225     if (hdlist[n] == NULL) {
226     hdlist[n] = hp;
227     break;
228     }
229     /* all done */
230     return(hp);
231     memerr:
232     error(SYSTEM, "cannot allocate holodeck grid");
233     }
234
235
236 gwlarson 3.37 hdmarkdirty(hp, i) /* mark holodeck directory position dirty */
237 gwlarson 3.28 register HOLO *hp;
238     int i;
239     {
240     static BEAMI smudge = {0, -1};
241     int mindist, minpos;
242     register int j;
243
244     if (!hp->dirty++) { /* write smudge first time */
245 greg 3.42 if (lseek(hp->fd, (off_t)(biglob(hp)->fo+(i-1)*sizeof(BEAMI)), 0) < 0
246 gwlarson 3.28 || write(hp->fd, (char *)&smudge,
247     sizeof(BEAMI)) != sizeof(BEAMI))
248 gwlarson 3.37 error(SYSTEM, "seek/write error in hdmarkdirty");
249 gwlarson 3.28 hp->dirseg[0].s = i;
250     hp->dirseg[0].n = 1;
251     return;
252     }
253     /* insert into segment list */
254     for (j = hp->dirty; j--; ) {
255     if (!j || hp->dirseg[j-1].s < i) {
256     hp->dirseg[j].s = i;
257     hp->dirseg[j].n = 1;
258     break;
259     }
260     copystruct(hp->dirseg+j, hp->dirseg+(j-1));
261     }
262 gwlarson 3.29 do { /* check neighbors */
263     mindist = nbeams(hp); /* find closest */
264     for (j = hp->dirty; --j; )
265     if (hp->dirseg[j].s -
266     (hp->dirseg[j-1].s + hp->dirseg[j-1].n)
267     < mindist) {
268     minpos = j;
269     mindist = hp->dirseg[j].s -
270 gwlarson 3.28 (hp->dirseg[j-1].s + hp->dirseg[j-1].n);
271 gwlarson 3.29 }
272     /* good enough? */
273     if (hp->dirty <= MAXDIRSE && mindist > MINDIRSEL)
274     break;
275 gwlarson 3.28 j = minpos - 1; /* coalesce neighbors */
276     if (hp->dirseg[j].s + hp->dirseg[j].n <
277 gwlarson 3.29 hp->dirseg[minpos].s + hp->dirseg[minpos].n)
278 gwlarson 3.28 hp->dirseg[j].n = hp->dirseg[minpos].s +
279     hp->dirseg[minpos].n - hp->dirseg[j].s;
280 gwlarson 3.29 hp->dirty--;
281     while (++j < hp->dirty) /* close the gap */
282 gwlarson 3.28 copystruct(hp->dirseg+j, hp->dirseg+(j+1));
283 gwlarson 3.29 } while (mindist <= MINDIRSEL);
284 gwlarson 3.28 }
285
286
287 gregl 3.1 int
288 gregl 3.12 hdsync(hp, all) /* update beams and directory on disk */
289 gregl 3.1 register HOLO *hp;
290 gregl 3.12 int all;
291 gregl 3.1 {
292     register int j, n;
293
294 gregl 3.12 if (hp == NULL) { /* do all holodecks */
295 gregl 3.1 n = 0;
296     for (j = 0; hdlist[j] != NULL; j++)
297 gregl 3.12 n += hdsync(hdlist[j], all);
298 gregl 3.1 return(n);
299     }
300 gregl 3.12 /* sync the beams */
301 gregl 3.15 for (j = (all ? nbeams(hp) : 0); j > 0; j--)
302 gregl 3.12 if (hp->bl[j] != NULL)
303     hdsyncbeam(hp, j);
304 gregl 3.13 if (!hp->dirty) /* directory clean? */
305 gregl 3.1 return(0);
306 gwlarson 3.28 errno = 0; /* write dirty segments */
307     for (j = 0; j < hp->dirty; j++) {
308 greg 3.42 if (lseek(hp->fd, (off_t)(biglob(hp)->fo +
309     (hp->dirseg[j].s-1)*sizeof(BEAMI)), 0) < 0)
310 gwlarson 3.28 error(SYSTEM, "cannot seek on holodeck file");
311     n = hp->dirseg[j].n * sizeof(BEAMI);
312     if (write(hp->fd, (char *)(hp->bi+hp->dirseg[j].s), n) != n)
313     error(SYSTEM, "cannot update section directory");
314     }
315     hp->dirty = 0; /* all clean */
316 gregl 3.1 return(1);
317     }
318
319
320 gregl 3.14 unsigned
321 gregl 3.1 hdmemuse(all) /* return memory usage (in bytes) */
322     int all; /* include overhead (painful) */
323     {
324     long total = 0;
325     register int i, j;
326
327     for (j = 0; hdlist[j] != NULL; j++) {
328     total += blglob(hdlist[j])->nrm * sizeof(RAYVAL);
329     if (all) {
330     total += sizeof(HOLO) + sizeof(BEAM *) +
331     nbeams(hdlist[j]) *
332     (sizeof(BEAM *)+sizeof(BEAMI));
333     for (i = nbeams(hdlist[j]); i > 0; i--)
334     if (hdlist[j]->bl[i] != NULL)
335     total += sizeof(BEAM);
336     }
337     }
338     if (all)
339 gregl 3.16 for (j = 0; j < nhdfragls; j++) {
340     total += sizeof(struct fraglist);
341     if (hdfragl[j].nfrags)
342 gregl 3.4 total += FRAGBLK*sizeof(BEAMI) *
343 gregl 3.16 ((hdfragl[j].nfrags-1)/FRAGBLK + 1) ;
344 gregl 3.4 }
345 gregl 3.1 return(total);
346 gregl 3.8 }
347
348
349     long
350     hdfilen(fd) /* return file length for fd */
351     int fd;
352     {
353     long fpos, flen;
354
355     if (fd < 0)
356     return(-1);
357 gregl 3.16 if (fd >= nhdfragls || !hdfragl[fd].nlinks) {
358 greg 3.42 if ((fpos = lseek(fd, (off_t)0L, 1)) < 0)
359 gregl 3.8 return(-1);
360 greg 3.42 flen = lseek(fd, (off_t)0L, 2);
361     lseek(fd, (off_t)fpos, 0);
362 gregl 3.8 return(flen);
363     }
364 gregl 3.16 return(hdfragl[fd].flen);
365 gregl 3.1 }
366
367
368     long
369     hdfiluse(fd, all) /* compute file usage (in bytes) */
370     int fd; /* open file descriptor to check */
371     int all; /* include overhead and unflushed data */
372     {
373     long total = 0;
374     register int i, j;
375
376     for (j = 0; hdlist[j] != NULL; j++) {
377     if (hdlist[j]->fd != fd)
378     continue;
379     total += biglob(hdlist[j])->nrd * sizeof(RAYVAL);
380     if (all) {
381     for (i = nbeams(hdlist[j]); i > 0; i--)
382     if (hdlist[j]->bl[i] != NULL)
383     total += sizeof(RAYVAL) *
384     (hdlist[j]->bl[i]->nrm -
385     hdlist[j]->bi[i].nrd);
386     total += sizeof(HDGRID) +
387     nbeams(hdlist[j])*sizeof(BEAMI);
388     }
389     }
390     return(total); /* does not include fragments */
391     }
392
393
394     RAYVAL *
395     hdnewrays(hp, i, nr) /* allocate space for add'l rays and return pointer */
396     register HOLO *hp;
397     register int i;
398     int nr; /* number of new rays desired */
399     {
400     RAYVAL *p;
401     int n;
402
403 gwlarson 3.32 if (nr <= 0) return(NULL);
404     CHECK(i < 1 | i > nbeams(hp),
405     CONSISTENCY, "bad beam index given to hdnewrays");
406 gregl 3.1 if (hp->bl[i] != NULL)
407     hp->bl[i]->tick = hdclock; /* preempt swap */
408     if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
409     hdfreecache(PCTFREE, NULL); /* free some space */
410     if (hp->bl[i] == NULL) { /* allocate (and load) */
411     n = hp->bi[i].nrd + nr;
412 gwlarson 3.26 hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdnewrays");
413 gregl 3.1 blglob(hp)->nrm += n;
414 gwlarson 3.32 if ((n = hp->bl[i]->nrm = hp->bi[i].nrd)) {
415 gwlarson 3.26 errno = 0;
416 greg 3.42 if (lseek(hp->fd, (off_t)hp->bi[i].fo, 0) < 0)
417 gregl 3.1 error(SYSTEM, "seek error on holodeck file");
418     n *= sizeof(RAYVAL);
419     if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
420     error(SYSTEM,
421     "error reading beam from holodeck file");
422     }
423     } else { /* just grow in memory */
424 gwlarson 3.26 hp->bl[i] = (BEAM *)hdrealloc((char *)hp->bl[i],
425     hdbsiz(hp->bl[i]->nrm + nr), "hdnewrays");
426 gregl 3.1 blglob(hp)->nrm += nr;
427     }
428 gwlarson 3.32 if (hdfragflags&FF_ALLOC && hp->bi[i].nrd)
429     hdfreefrag(hp, i); /* relinquish old fragment */
430 gregl 3.1 p = hdbray(hp->bl[i]) + hp->bl[i]->nrm;
431     hp->bl[i]->nrm += nr; /* update in-core structure */
432     bzero((char *)p, nr*sizeof(RAYVAL));
433 gwlarson 3.25 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
434 gregl 3.1 return(p); /* point to new rays */
435     }
436
437
438     BEAM *
439     hdgetbeam(hp, i) /* get beam (from file if necessary) */
440     register HOLO *hp;
441     register int i;
442     {
443     register int n;
444
445 gwlarson 3.32 CHECK(i < 1 | i > nbeams(hp),
446     CONSISTENCY, "bad beam index given to hdgetbeam");
447 gregl 3.1 if (hp->bl[i] == NULL) { /* load from disk */
448     if (!(n = hp->bi[i].nrd))
449     return(NULL);
450     if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
451     hdfreecache(PCTFREE, NULL); /* get free space */
452 gwlarson 3.26 hp->bl[i] = (BEAM *)hdrealloc(NULL, hdbsiz(n), "hdgetbeam");
453     blglob(hp)->nrm += hp->bl[i]->nrm = n;
454 gregl 3.1 errno = 0;
455 greg 3.42 if (lseek(hp->fd, (off_t)hp->bi[i].fo, 0) < 0)
456 gregl 3.1 error(SYSTEM, "seek error on holodeck file");
457     n *= sizeof(RAYVAL);
458     if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
459     error(SYSTEM, "error reading beam from holodeck file");
460 gwlarson 3.32 if (hdfragflags&FF_READ)
461     hdfreefrag(hp, i); /* relinquish old frag. */
462 gregl 3.1 }
463 gwlarson 3.25 blglob(hp)->tick = hp->bl[i]->tick = hdclock++; /* update LRU clock */
464 gregl 3.1 return(hp->bl[i]);
465     }
466
467
468     int
469 gregl 3.17 hdfilord(hb1, hb2) /* order beams for quick loading */
470 gregl 3.14 register HDBEAMI *hb1, *hb2;
471     {
472 gregl 3.17 register long c;
473     /* residents go first */
474     if (hb2->h->bl[hb2->b] != NULL)
475     return(hb1->h->bl[hb1->b] == NULL);
476     if (hb1->h->bl[hb1->b] != NULL)
477     return(-1);
478     /* otherwise sort by file descriptor */
479 gregl 3.14 if ((c = hb1->h->fd - hb2->h->fd))
480     return(c);
481     /* then by position in file */
482 gregl 3.17 c = hb1->h->bi[hb1->b].fo - hb2->h->bi[hb2->b].fo;
483     return(c > 0 ? 1 : c < 0 ? -1 : 0);
484 gregl 3.14 }
485
486
487     hdloadbeams(hb, n, bf) /* load a list of beams in optimal order */
488     register HDBEAMI *hb; /* list gets sorted by hdfilord() */
489     int n; /* list length */
490     int (*bf)(); /* callback function (optional) */
491     {
492     unsigned origcachesize, memuse;
493 gwlarson 3.23 int bytesloaded, needbytes, bytes2free;
494 gregl 3.14 register BEAM *bp;
495     register int i;
496     /* precheck consistency */
497 gwlarson 3.25 if (n <= 0) return;
498 gregl 3.14 for (i = n; i--; )
499 gwlarson 3.32 if (hb[i].h==NULL || hb[i].b<1 | hb[i].b>nbeams(hb[i].h))
500 gregl 3.14 error(CONSISTENCY, "bad beam in hdloadbeams");
501     /* sort list for optimal access */
502     qsort((char *)hb, n, sizeof(HDBEAMI), hdfilord);
503 gregl 3.17 bytesloaded = 0; /* run through loaded beams */
504     for ( ; n && (bp = hb->h->bl[hb->b]) != NULL; n--, hb++) {
505 gwlarson 3.23 bp->tick = hdclock; /* preempt swap */
506 gregl 3.17 bytesloaded += bp->nrm;
507     if (bf != NULL)
508 gwlarson 3.23 (*bf)(bp, hb);
509 gregl 3.17 }
510     bytesloaded *= sizeof(RAYVAL);
511 gregl 3.15 if ((origcachesize = hdcachesize) > 0) {
512 gregl 3.17 needbytes = 0; /* figure out memory needs */
513 gregl 3.15 for (i = n; i--; )
514 gregl 3.17 needbytes += hb[i].h->bi[hb[i].b].nrd;
515 gregl 3.15 needbytes *= sizeof(RAYVAL);
516     do { /* free enough memory */
517     memuse = hdmemuse(0);
518 gregl 3.17 bytes2free = needbytes - (int)(hdcachesize-memuse);
519     if (bytes2free > (int)(memuse - bytesloaded))
520 gregl 3.15 bytes2free = memuse - bytesloaded;
521     } while (bytes2free > 0 &&
522     hdfreecache(100*bytes2free/memuse, NULL) < 0);
523 gregl 3.17 hdcachesize = 0; /* load beams w/o swap */
524 gregl 3.15 }
525 gregl 3.14 for (i = 0; i < n; i++)
526     if ((bp = hdgetbeam(hb[i].h, hb[i].b)) != NULL && bf != NULL)
527 gwlarson 3.23 (*bf)(bp, hb+i);
528 gregl 3.14 hdcachesize = origcachesize; /* resume dynamic swapping */
529     }
530
531
532 gwlarson 3.33 int
533 gwlarson 3.32 hdfreefrag(hp, i) /* free a file fragment */
534     HOLO *hp;
535     int i;
536 gregl 3.19 {
537 gwlarson 3.32 register BEAMI *bi = &hp->bi[i];
538 gregl 3.19 register struct fraglist *f;
539     register int j, k;
540
541 gwlarson 3.32 if (bi->nrd <= 0)
542 gwlarson 3.33 return(0);
543 gwlarson 3.32 DCHECK(hp->fd < 0 | hp->fd >= nhdfragls || !hdfragl[hp->fd].nlinks,
544     CONSISTENCY, "bad file descriptor in hdfreefrag");
545     f = &hdfragl[hp->fd];
546 gwlarson 3.41 if (!f->writable)
547     return(0);
548 gregl 3.19 if (f->nfrags % FRAGBLK == 0) { /* delete empty remnants */
549     for (j = k = 0; k < f->nfrags; j++, k++) {
550     while (f->fi[k].nrd == 0)
551     if (++k >= f->nfrags)
552     goto endloop;
553     if (k > j)
554     copystruct(f->fi+j, f->fi+k);
555     }
556     endloop:
557     f->nfrags = j;
558     }
559     j = f->nfrags++; /* allocate a slot in free list */
560 gwlarson 3.31 #if MAXFRAGB
561     if (j >= MAXFRAGB*FRAGBLK) {
562     f->nfrags = j--; /* stop list growth */
563     if (bi->nrd <= f->fi[j].nrd)
564 gwlarson 3.33 return(0); /* new one no better than discard */
565 gwlarson 3.31 }
566 gregl 3.19 #endif
567 gwlarson 3.32 if (j % FRAGBLK == 0) { /* more (or less) free list space */
568 gwlarson 3.26 register BEAMI *newp;
569 gregl 3.19 if (f->fi == NULL)
570 gwlarson 3.26 newp = (BEAMI *)malloc((j+FRAGBLK)*sizeof(BEAMI));
571 gregl 3.19 else
572 gwlarson 3.26 newp = (BEAMI *)realloc((char *)f->fi,
573 gregl 3.19 (j+FRAGBLK)*sizeof(BEAMI));
574 gwlarson 3.26 if (newp == NULL) {
575     f->nfrags--; /* graceful failure */
576 gwlarson 3.33 return(0);
577 gwlarson 3.26 }
578     f->fi = newp;
579 gregl 3.19 }
580     for ( ; ; j--) { /* insert in descending list */
581     if (!j || bi->fo < f->fi[j-1].fo) {
582     f->fi[j].fo = bi->fo;
583     f->fi[j].nrd = bi->nrd;
584     break;
585     }
586     copystruct(f->fi+j, f->fi+(j-1));
587     }
588     /* coalesce adjacent fragments */
589     /* successors never empty */
590     if (j && f->fi[j-1].fo == f->fi[j].fo + f->fi[j].nrd*sizeof(RAYVAL)) {
591     f->fi[j].nrd += f->fi[j-1].nrd;
592     f->fi[j-1].nrd = 0;
593     }
594     for (k = j+1; k < f->nfrags; k++) /* get non-empty predecessor */
595     if (f->fi[k].nrd) {
596     if (f->fi[j].fo == f->fi[k].fo +
597     f->fi[k].nrd*sizeof(RAYVAL)) {
598     f->fi[k].nrd += f->fi[j].nrd;
599     f->fi[j].nrd = 0;
600     }
601     break;
602     }
603 gwlarson 3.32 biglob(hp)->nrd -= bi->nrd; /* tell fragment it's free */
604     bi->nrd = 0;
605 gwlarson 3.34 bi->fo = 0L;
606 gwlarson 3.39 hdmarkdirty(hp, i); /* assume we'll reallocate */
607 gwlarson 3.33 return(1);
608 gregl 3.19 }
609
610
611 gwlarson 3.32 int
612     hdfragOK(fd, listlen, listsiz) /* get fragment list status for file */
613     int fd;
614     int *listlen;
615     register int4 *listsiz;
616     {
617     register struct fraglist *f;
618     register int i;
619
620     if (fd < 0 | fd >= nhdfragls || !(f = &hdfragl[fd])->nlinks)
621     return(0); /* listless */
622     if (listlen != NULL)
623     *listlen = f->nfrags;
624     if (listsiz != NULL)
625     for (i = f->nfrags, *listsiz = 0; i--; )
626     *listsiz += f->fi[i].nrd;
627     #if MAXFRAGB
628     return(f->nfrags < MAXFRAGB*FRAGBLK);
629     #else
630     return(1); /* list never fills up */
631     #endif
632     }
633
634
635 gregl 3.19 long
636     hdallocfrag(fd, nrays) /* allocate a file fragment */
637     int fd;
638     unsigned int4 nrays;
639     {
640     register struct fraglist *f;
641 gwlarson 3.33 register int j;
642 gregl 3.19 long nfo;
643
644     if (nrays == 0)
645     return(-1L);
646 gwlarson 3.32 DCHECK(fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks,
647     CONSISTENCY, "bad file descriptor in hdallocfrag");
648 gregl 3.19 f = &hdfragl[fd];
649 gwlarson 3.33 for (j = f->nfrags; j-- > 0; ) /* first fit algorithm */
650     if (f->fi[j].nrd >= nrays)
651     break;
652     if (j < 0) { /* no fragment -- extend file */
653 gregl 3.19 nfo = f->flen;
654     f->flen += nrays*sizeof(RAYVAL);
655     } else { /* else use fragment */
656 gwlarson 3.33 nfo = f->fi[j].fo;
657     f->fi[j].fo += nrays*sizeof(RAYVAL);
658     f->fi[j].nrd -= nrays;
659 gregl 3.19 }
660     return(nfo);
661     }
662
663
664 gregl 3.14 int
665 gregl 3.12 hdsyncbeam(hp, i) /* sync beam in memory with beam on disk */
666 gregl 3.1 register HOLO *hp;
667     register int i;
668     {
669 gwlarson 3.39 int fragfreed;
670 gregl 3.19 unsigned int4 nrays;
671     unsigned int n;
672 gregl 3.11 long nfo;
673 gregl 3.13 /* check file status */
674 gwlarson 3.41 if (hdfragl[hp->fd].writable <= 0)
675     return(hdfragl[hp->fd].writable);
676 gwlarson 3.32 DCHECK(i < 1 | i > nbeams(hp),
677     CONSISTENCY, "bad beam index in hdsyncbeam");
678 gregl 3.11 /* is current fragment OK? */
679 gregl 3.12 if (hp->bl[i] == NULL || (nrays = hp->bl[i]->nrm) == hp->bi[i].nrd)
680 gregl 3.1 return(0);
681 gwlarson 3.39 /* relinquish old fragment? */
682     fragfreed = hdfragflags&FF_WRITE && hp->bi[i].nrd && hdfreefrag(hp,i);
683 gregl 3.19 if (nrays) { /* get and write new fragment */
684     nfo = hdallocfrag(hp->fd, nrays);
685 gregl 3.11 errno = 0;
686 greg 3.42 if (lseek(hp->fd, (off_t)nfo, 0) < 0)
687 gregl 3.11 error(SYSTEM, "cannot seek on holodeck file");
688     n = hp->bl[i]->nrm * sizeof(RAYVAL);
689     if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) {
690 gwlarson 3.41 hdfragl[hp->fd].writable = -1;
691 gregl 3.18 hdsync(NULL, 0); /* sync directories */
692 gregl 3.12 error(SYSTEM, "write error in hdsyncbeam");
693 gregl 3.11 }
694 gregl 3.19 hp->bi[i].fo = nfo;
695     } else
696     hp->bi[i].fo = 0L;
697 gwlarson 3.34 biglob(hp)->nrd += nrays - hp->bi[i].nrd;
698     hp->bi[i].nrd = nrays;
699 gwlarson 3.39 if (!fragfreed)
700     hdmarkdirty(hp, i); /* need to flag dir. ent. */
701 gregl 3.1 return(1);
702     }
703
704
705     int
706     hdfreebeam(hp, i) /* free beam, writing if dirty */
707     register HOLO *hp;
708     register int i;
709     {
710 gregl 3.11 int nchanged;
711 gregl 3.1
712     if (hp == NULL) { /* clear all holodecks */
713     nchanged = 0;
714     for (i = 0; hdlist[i] != NULL; i++)
715     nchanged += hdfreebeam(hdlist[i], 0);
716     return(nchanged);
717     }
718 gwlarson 3.41 if (hdfragl[hp->fd].writable < 0) /* check for file error */
719 gregl 3.13 return(0);
720 gregl 3.1 if (i == 0) { /* clear entire holodeck */
721 gwlarson 3.36 if (blglob(hp)->nrm == 0)
722     return(0); /* already clear */
723 gregl 3.1 nchanged = 0;
724 gregl 3.10 for (i = nbeams(hp); i > 0; i--)
725     if (hp->bl[i] != NULL)
726     nchanged += hdfreebeam(hp, i);
727 gwlarson 3.36 DCHECK(blglob(hp)->nrm != 0,
728     CONSISTENCY, "bad beam count in hdfreebeam");
729 gregl 3.1 return(nchanged);
730     }
731 gwlarson 3.32 DCHECK(i < 1 | i > nbeams(hp),
732     CONSISTENCY, "bad beam index to hdfreebeam");
733 gregl 3.1 if (hp->bl[i] == NULL)
734     return(0);
735     /* check for additions */
736     nchanged = hp->bl[i]->nrm - hp->bi[i].nrd;
737 gregl 3.11 if (nchanged)
738 gregl 3.12 hdsyncbeam(hp, i); /* write new fragment */
739 gregl 3.1 blglob(hp)->nrm -= hp->bl[i]->nrm;
740 greg 3.42 free((void *)hp->bl[i]); /* free memory */
741 gregl 3.1 hp->bl[i] = NULL;
742     return(nchanged);
743     }
744
745
746 gregl 3.10 int
747     hdkillbeam(hp, i) /* delete beam from holodeck */
748     register HOLO *hp;
749     register int i;
750     {
751 gregl 3.11 int nchanged;
752 gregl 3.10
753     if (hp == NULL) { /* clobber all holodecks */
754     nchanged = 0;
755     for (i = 0; hdlist[i] != NULL; i++)
756     nchanged += hdkillbeam(hdlist[i], 0);
757     return(nchanged);
758     }
759     if (i == 0) { /* clobber entire holodeck */
760 gwlarson 3.36 if (biglob(hp)->nrd == 0 & blglob(hp)->nrm == 0)
761     return(0); /* already empty */
762     nchanged = 0;
763 gregl 3.10 nchanged = 0;
764     for (i = nbeams(hp); i > 0; i--)
765     if (hp->bi[i].nrd > 0 || hp->bl[i] != NULL)
766     nchanged += hdkillbeam(hp, i);
767 gwlarson 3.32 DCHECK(biglob(hp)->nrd != 0 | blglob(hp)->nrm != 0,
768     CONSISTENCY, "bad beam count in hdkillbeam");
769 gregl 3.10 return(nchanged);
770     }
771 gwlarson 3.41 DCHECK(i < 1 | i > nbeams(hp), CONSISTENCY,
772     "bad beam index to hdkillbeam");
773     DCHECK(!hdfragl[hp->fd].writable, CONSISTENCY,
774     "hdkillbeam called on read-only holodeck");
775 gregl 3.10 if (hp->bl[i] != NULL) { /* free memory */
776     blglob(hp)->nrm -= nchanged = hp->bl[i]->nrm;
777 greg 3.42 free((void *)hp->bl[i]);
778 gwlarson 3.39 hp->bl[i] = NULL;
779 gregl 3.10 } else
780     nchanged = hp->bi[i].nrd;
781 gwlarson 3.39 if (hp->bi[i].nrd && !(hdfragflags&FF_KILL && hdfreefrag(hp,i))) {
782     biglob(hp)->nrd -= hp->bi[i].nrd; /* free failed */
783     hp->bi[i].nrd = 0;
784 gwlarson 3.32 hp->bi[i].fo = 0L;
785 gwlarson 3.39 hdmarkdirty(hp, i);
786 gregl 3.10 }
787     return(nchanged);
788     }
789
790
791 gregl 3.14 int
792     hdlrulist(hb, nents, n, hp) /* add beams from holodeck to LRU list */
793     register HDBEAMI *hb; /* beam list */
794     int nents; /* current list length */
795     int n; /* maximum list length */
796 gregl 3.1 register HOLO *hp; /* section we're adding from */
797     {
798     register int i, j;
799     /* insert each beam from hp */
800 gregl 3.21 for (i = 1; i <= nbeams(hp); i++) {
801 gregl 3.1 if (hp->bl[i] == NULL) /* check if loaded */
802     continue;
803 gregl 3.14 #if 0
804     if (hp->bl[i]->tick == hdclock) /* preempt swap? */
805     continue;
806     #endif
807     if ((j = ++nents) >= n) /* grow list if we can */
808 gregl 3.1 nents--;
809     for ( ; ; ) { /* bubble into place */
810     if (!--j || hp->bl[i]->tick >=
811 gregl 3.14 hb[j-1].h->bl[hb[j-1].b]->tick) {
812     hb[j].h = hp;
813     hb[j].b = i;
814 gregl 3.1 break;
815     }
816 gregl 3.14 copystruct(hb+j, hb+(j-1));
817 gregl 3.1 }
818     }
819 gregl 3.14 return(nents); /* return new list length */
820 gregl 3.1 }
821
822
823 gregl 3.14 int
824 gregl 3.1 hdfreecache(pct, honly) /* free up cache space, writing changes */
825     int pct; /* maximum percentage to free */
826     register HOLO *honly; /* NULL means check all */
827     {
828 gregl 3.14 HDBEAMI hb[FREEBEAMS];
829 gregl 3.1 int freetarget;
830 gregl 3.14 int n;
831 gregl 3.1 register int i;
832 gwlarson 3.25 #ifdef DEBUG
833     unsigned membefore;
834
835     membefore = hdmemuse(0);
836     #endif
837 gregl 3.1 /* compute free target */
838     freetarget = (honly != NULL) ? blglob(honly)->nrm :
839     hdmemuse(0)/sizeof(RAYVAL) ;
840     freetarget = freetarget*pct/100;
841 gregl 3.14 if (freetarget <= 0)
842     return(0);
843 gregl 3.1 /* find least recently used */
844 gregl 3.14 n = 0;
845 gregl 3.1 if (honly != NULL)
846 gregl 3.14 n = hdlrulist(hb, n, FREEBEAMS, honly);
847 gregl 3.1 else
848     for (i = 0; hdlist[i] != NULL; i++)
849 gregl 3.14 n = hdlrulist(hb, n, FREEBEAMS, hdlist[i]);
850 gregl 3.1 /* free LRU beams */
851 gregl 3.14 for (i = 0; i < n; i++) {
852     hdfreebeam(hb[i].h, hb[i].b);
853     if ((freetarget -= hb[i].h->bi[hb[i].b].nrd) <= 0)
854 gregl 3.1 break;
855     }
856 gregl 3.12 hdsync(honly, 0); /* synchronize directories as necessary */
857 gwlarson 3.25 #ifdef DEBUG
858     sprintf(errmsg,
859     "%dK before, %dK after hdfreecache (%dK total), %d rays short\n",
860     membefore>>10, hdmemuse(0)>>10, hdmemuse(1)>>10, freetarget);
861     wputs(errmsg);
862     #endif
863 gregl 3.14 return(-freetarget); /* return how far past goal we went */
864 gregl 3.1 }
865
866
867     hddone(hp) /* clean up holodeck section and free */
868     register HOLO *hp; /* NULL means clean up all */
869     {
870     register int i;
871
872     if (hp == NULL) { /* NULL means clean up everything */
873     while (hdlist[0] != NULL)
874     hddone(hdlist[0]);
875 greg 3.42 free((void *)hdfragl);
876 gwlarson 3.24 hdfragl = NULL; nhdfragls = 0;
877 gregl 3.1 return;
878     }
879     /* flush all data and free memory */
880 gwlarson 3.37 hdflush(hp);
881 gregl 3.1 /* release fragment resources */
882     hdrelease(hp->fd);
883     /* remove hp from active list */
884     for (i = 0; hdlist[i] != NULL; i++)
885     if (hdlist[i] == hp) {
886     while ((hdlist[i] = hdlist[i+1]) != NULL)
887     i++;
888     break;
889     }
890 greg 3.42 free((void *)hp->bl); /* free beam list */
891     free((void *)hp); /* free holodeck struct */
892 gregl 3.1 }
