root/radiance/ray/src/hd/holofile.c
Revision: 3.20
Committed: Mon Jan 5 16:45:24 1998 UTC (27 years, 4 months ago) by gregl
changed dirty holodeck to just a warning
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Routines for managing holodeck files
9 *
10 * 9/30/97 GWLarson
11 */
12
13 #include "holo.h"
14
15 #ifndef CACHESIZE
16 #define CACHESIZE 16 /* default cache size (Mbytes, 0==inf) */
17 #endif
18 #ifndef FREEBEAMS
19 #define FREEBEAMS 512 /* maximum beams to free at a time */
20 #endif
21 #ifndef PCTFREE
22 #define PCTFREE 20 /* maximum fraction to free (%) */
23 #endif
24 #ifndef MAXFRAG
25 #define MAXFRAG 32767 /* maximum fragments/file to track (0==inf) */
26 #endif
27
28 #ifndef BSD
29 #define write writebuf /* safe i/o routines */
30 #define read readbuf
31 #endif
32
33 #define FRAGBLK 256 /* number of fragments to allocate at a time */
34
35 unsigned hdcachesize = CACHESIZE*1024*1024; /* target cache size */
36 unsigned long hdclock; /* clock value */
37
38 HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */
39
40 static struct fraglist {
41 short nlinks; /* number of holodeck sections using us */
42 short writerr; /* write error encountered */
43 int nfrags; /* number of known fragments */
44 BEAMI *fi; /* fragments, descending file position */
45 long flen; /* last known file length */
46 } *hdfragl; /* fragment lists, indexed by file descriptor */
47
48 static int nhdfragls; /* size of hdfragl array */
49
50
51 hdattach(fd) /* start tracking file fragments for some section */
52 register int fd;
53 {
54 if (fd >= nhdfragls) {
55 if (nhdfragls)
56 hdfragl = (struct fraglist *)realloc((char *)hdfragl,
57 (fd+1)*sizeof(struct fraglist));
58 else
59 hdfragl = (struct fraglist *)malloc(
60 (fd+1)*sizeof(struct fraglist));
61 if (hdfragl == NULL)
62 error(SYSTEM, "out of memory in hdattach");
63 bzero((char *)(hdfragl+nhdfragls),
64 (fd+1-nhdfragls)*sizeof(struct fraglist));
65 nhdfragls = fd+1;
66 }
67 hdfragl[fd].nlinks++;
68 hdfragl[fd].flen = lseek(fd, 0L, 2); /* get file length */
69 }
70
71
72 /* Do we need a routine to locate file fragments given known occupants? */
73
74
75 hdrelease(fd) /* stop tracking file fragments for some section */
76 register int fd;
77 {
78 if (fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks)
79 return;
80 if (!--hdfragl[fd].nlinks && hdfragl[fd].nfrags) {
81 free((char *)hdfragl[fd].fi);
82 hdfragl[fd].fi = NULL;
83 hdfragl[fd].nfrags = 0;
84 }
85 }
86
87
88 markdirty(hp) /* mark holodeck section directory dirty */
89 register HOLO *hp;
90 {
91 static BEAMI smudge = {0, -1};
92
93 if (hp->dirty) /* already marked? */
94 return;
95 hp->dirty = 1;
96 if (lseek(hp->fd, biglob(hp)->fo+(nbeams(hp)-1)*sizeof(BEAMI), 0) < 0
97 || write(hp->fd, (char *)&smudge,
98 sizeof(BEAMI)) != sizeof(BEAMI))
99 error(SYSTEM, "seek/write error in markdirty");
100 }
101
102
103 HOLO *
104 hdinit(fd, hproto) /* initialize a holodeck section in a file */
105 int fd; /* corresponding file descriptor */
106 HDGRID *hproto; /* holodeck section grid */
107 {
108 long fpos;
109 register HOLO *hp;
110 register int n;
111 /* prepare for system errors */
112 errno = 0;
113 if ((fpos = lseek(fd, 0L, 1)) < 0)
114 error(SYSTEM, "cannot determine holodeck file position");
115 if (hproto == NULL) { /* assume we're loading it */
116 HDGRID hpr;
117 /* load header */
118 if (read(fd, (char *)&hpr, sizeof(HDGRID)) != sizeof(HDGRID))
119 error(SYSTEM, "cannot load holodeck header");
120 /* allocate grid */
121 if ((hp = hdalloc(&hpr)) == NULL)
122 goto memerr;
123 /* load beam directory */
124 n = nbeams(hp)*sizeof(BEAMI);
125 if (read(fd, (char *)(hp->bi+1), n) != n)
126 error(SYSTEM, "failure loading holodeck directory");
127 /* check that it's clean */
128 if (hp->bi[nbeams(hp)].fo < 0)
129 error(WARNING, "dirty holodeck section");
130 } else { /* assume we're creating it */
131 if ((hp = hdalloc(hproto)) == NULL)
132 goto memerr;
133 /* write header and skeleton */
134 n = nbeams(hp)*sizeof(BEAMI);
135 if (write(fd, (char *)hproto, sizeof(HDGRID)) !=
136 sizeof(HDGRID) ||
137 write(fd, (char *)(hp->bi+1), n) != n)
138 error(SYSTEM, "cannot write header to holodeck file");
139 }
140 hp->fd = fd;
141 hp->dirty = 0;
142 biglob(hp)->fo = fpos + sizeof(HDGRID);
143 /* start tracking fragments */
144 hdattach(fd);
145 /* check rays on disk */
146 fpos = hdfilen(fd);
147 biglob(hp)->nrd = 0;
148 for (n = hproto == NULL ? nbeams(hp) : 0; n > 0; n--)
149 if (hp->bi[n].nrd)
150 if (hp->bi[n].fo + hp->bi[n].nrd > fpos)
151 hp->bi[n].nrd = 0; /* off end */
152 else
153 biglob(hp)->nrd += hp->bi[n].nrd;
154 /* add to holodeck list */
155 for (n = 0; n < HDMAX; n++)
156 if (hdlist[n] == NULL) {
157 hdlist[n] = hp;
158 break;
159 }
160 /* all done */
161 return(hp);
162 memerr:
163 error(SYSTEM, "cannot allocate holodeck grid");
164 }
165
166
167 int
168 hdsync(hp, all) /* update beams and directory on disk */
169 register HOLO *hp;
170 int all;
171 {
172 register int j, n;
173
174 if (hp == NULL) { /* do all holodecks */
175 n = 0;
176 for (j = 0; hdlist[j] != NULL; j++)
177 n += hdsync(hdlist[j], all);
178 return(n);
179 }
180 /* sync the beams */
181 for (j = (all ? nbeams(hp) : 0); j > 0; j--)
182 if (hp->bl[j] != NULL)
183 hdsyncbeam(hp, j);
184 if (!hp->dirty) /* directory clean? */
185 return(0);
186 errno = 0;
187 if (lseek(hp->fd, biglob(hp)->fo, 0) < 0)
188 error(SYSTEM, "cannot seek on holodeck file");
189 n = nbeams(hp)*sizeof(BEAMI);
190 if (write(hp->fd, (char *)(hp->bi+1), n) != n)
191 error(SYSTEM, "cannot update holodeck section directory");
192 hp->dirty = 0;
193 return(1);
194 }
195
196
197 unsigned
198 hdmemuse(all) /* return memory usage (in bytes) */
199 int all; /* include overhead (painful) */
200 {
201 long total = 0;
202 register int i, j;
203
204 for (j = 0; hdlist[j] != NULL; j++) {
205 total += blglob(hdlist[j])->nrm * sizeof(RAYVAL);
206 if (all) {
207 total += sizeof(HOLO) + sizeof(BEAM *) +
208 nbeams(hdlist[j]) *
209 (sizeof(BEAM *)+sizeof(BEAMI));
210 for (i = nbeams(hdlist[j]); i > 0; i--)
211 if (hdlist[j]->bl[i] != NULL)
212 total += sizeof(BEAM);
213 }
214 }
215 if (all)
216 for (j = 0; j < nhdfragls; j++) {
217 total += sizeof(struct fraglist);
218 if (hdfragl[j].nfrags)
219 total += FRAGBLK*sizeof(BEAMI) *
220 ((hdfragl[j].nfrags-1)/FRAGBLK + 1) ;
221 }
222 return(total);
223 }
224
225
226 long
227 hdfilen(fd) /* return file length for fd */
228 int fd;
229 {
230 long fpos, flen;
231
232 if (fd < 0)
233 return(-1);
234 if (fd >= nhdfragls || !hdfragl[fd].nlinks) {
235 if ((fpos = lseek(fd, 0L, 1)) < 0)
236 return(-1);
237 flen = lseek(fd, 0L, 2);
238 lseek(fd, fpos, 0);
239 return(flen);
240 }
241 return(hdfragl[fd].flen);
242 }
243
244
245 long
246 hdfiluse(fd, all) /* compute file usage (in bytes) */
247 int fd; /* open file descriptor to check */
248 int all; /* include overhead and unflushed data */
249 {
250 long total = 0;
251 register int i, j;
252
253 for (j = 0; hdlist[j] != NULL; j++) {
254 if (hdlist[j]->fd != fd)
255 continue;
256 total += biglob(hdlist[j])->nrd * sizeof(RAYVAL);
257 if (all) {
258 for (i = nbeams(hdlist[j]); i > 0; i--)
259 if (hdlist[j]->bl[i] != NULL)
260 total += sizeof(RAYVAL) *
261 (hdlist[j]->bl[i]->nrm -
262 hdlist[j]->bi[i].nrd);
263 total += sizeof(HDGRID) +
264 nbeams(hdlist[j])*sizeof(BEAMI);
265 }
266 }
267 return(total); /* does not include fragments */
268 }
269
270
271 RAYVAL *
272 hdnewrays(hp, i, nr) /* allocate space for add'l rays and return pointer */
273 register HOLO *hp;
274 register int i;
275 int nr; /* number of new rays desired */
276 {
277 RAYVAL *p;
278 int n;
279
280 if (nr <= 0)
281 return(NULL);
282 if (i < 1 | i > nbeams(hp))
283 error(CONSISTENCY, "bad beam index given to hdnewrays");
284 if (hp->bl[i] != NULL)
285 hp->bl[i]->tick = hdclock; /* preempt swap */
286 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
287 hdfreecache(PCTFREE, NULL); /* free some space */
288 errno = 0;
289 if (hp->bl[i] == NULL) { /* allocate (and load) */
290 n = hp->bi[i].nrd + nr;
291 if ((hp->bl[i] = (BEAM *)malloc(hdbsiz(n))) == NULL)
292 goto memerr;
293 blglob(hp)->nrm += n;
294 if (n = hp->bl[i]->nrm = hp->bi[i].nrd) {
295 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
296 error(SYSTEM, "seek error on holodeck file");
297 n *= sizeof(RAYVAL);
298 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
299 error(SYSTEM,
300 "error reading beam from holodeck file");
301 }
302 } else { /* just grow in memory */
303 hp->bl[i] = (BEAM *)realloc( (char *)hp->bl[i],
304 hdbsiz(hp->bl[i]->nrm + nr) );
305 if (hp->bl[i] == NULL)
306 goto memerr;
307 blglob(hp)->nrm += nr;
308 }
309 p = hdbray(hp->bl[i]) + hp->bl[i]->nrm;
310 hp->bl[i]->nrm += nr; /* update in-core structure */
311 bzero((char *)p, nr*sizeof(RAYVAL));
312 hp->bl[i]->tick = hdclock; /* update LRU clock */
313 blglob(hp)->tick = hdclock++;
314 return(p); /* point to new rays */
315 memerr:
316 error(SYSTEM, "out of memory in hdnewrays");
317 }
318
319
320 BEAM *
321 hdgetbeam(hp, i) /* get beam (from file if necessary) */
322 register HOLO *hp;
323 register int i;
324 {
325 register int n;
326
327 if (i < 1 | i > nbeams(hp))
328 error(CONSISTENCY, "bad beam index given to hdgetbeam");
329 if (hp->bl[i] == NULL) { /* load from disk */
330 if (!(n = hp->bi[i].nrd))
331 return(NULL);
332 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
333 hdfreecache(PCTFREE, NULL); /* get free space */
334 errno = 0;
335 if ((hp->bl[i] = (BEAM *)malloc(hdbsiz(n))) == NULL)
336 error(SYSTEM, "cannot allocate memory for beam");
337 blglob(hp)->nrm += hp->bl[i]->nrm = n;
338 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
339 error(SYSTEM, "seek error on holodeck file");
340 n *= sizeof(RAYVAL);
341 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
342 error(SYSTEM, "error reading beam from holodeck file");
343 }
344 hp->bl[i]->tick = hdclock; /* update LRU clock */
345 blglob(hp)->tick = hdclock++;
346 return(hp->bl[i]);
347 }
348
349
350 int
351 hdfilord(hb1, hb2) /* order beams for quick loading */
352 register HDBEAMI *hb1, *hb2;
353 {
354 register long c;
355 /* residents go first */
356 if (hb2->h->bl[hb2->b] != NULL)
357 return(hb1->h->bl[hb1->b] == NULL);
358 if (hb1->h->bl[hb1->b] != NULL)
359 return(-1);
360 /* otherwise sort by file descriptor */
361 if ((c = hb1->h->fd - hb2->h->fd))
362 return(c);
363 /* then by position in file */
364 c = hb1->h->bi[hb1->b].fo - hb2->h->bi[hb2->b].fo;
365 return(c > 0 ? 1 : c < 0 ? -1 : 0);
366 }
367
368
369 hdloadbeams(hb, n, bf) /* load a list of beams in optimal order */
370 register HDBEAMI *hb; /* list gets sorted by hdfilord() */
371 int n; /* list length */
372 int (*bf)(); /* callback function (optional) */
373 {
374 unsigned origcachesize, memuse;
375 register BEAM *bp;
376 int bytesloaded, needbytes, bytes2free;
377 register int i;
378 /* precheck consistency */
379 for (i = n; i--; )
380 if (hb[i].h == NULL || hb[i].b < 1 | hb[i].b > nbeams(hb[i].h))
381 error(CONSISTENCY, "bad beam in hdloadbeams");
382 /* sort list for optimal access */
383 qsort((char *)hb, n, sizeof(HDBEAMI), hdfilord);
384 bytesloaded = 0; /* run through loaded beams */
385 for ( ; n && (bp = hb->h->bl[hb->b]) != NULL; n--, hb++) {
386 bp->tick = hdclock; /* preempt swap */
387 bytesloaded += bp->nrm;
388 if (bf != NULL)
389 (*bf)(bp, hb->h, hb->b);
390 }
391 bytesloaded *= sizeof(RAYVAL);
392 if ((origcachesize = hdcachesize) > 0) {
393 needbytes = 0; /* figure out memory needs */
394 for (i = n; i--; )
395 needbytes += hb[i].h->bi[hb[i].b].nrd;
396 needbytes *= sizeof(RAYVAL);
397 do { /* free enough memory */
398 memuse = hdmemuse(0);
399 bytes2free = needbytes - (int)(hdcachesize-memuse);
400 if (bytes2free > (int)(memuse - bytesloaded))
401 bytes2free = memuse - bytesloaded;
402 } while (bytes2free > 0 &&
403 hdfreecache(100*bytes2free/memuse, NULL) < 0);
404 hdcachesize = 0; /* load beams w/o swap */
405 }
406 for (i = 0; i < n; i++)
407 if ((bp = hdgetbeam(hb[i].h, hb[i].b)) != NULL && bf != NULL)
408 (*bf)(bp, hb[i].h, hb[i].b);
409 hdcachesize = origcachesize; /* resume dynamic swapping */
410 }
411
412
413 hdfreefrag(fd, bi) /* free a file fragment */
414 int fd;
415 register BEAMI *bi;
416 {
417 register struct fraglist *f;
418 register int j, k;
419
420 if (bi->nrd == 0)
421 return;
422 #ifdef DEBUG
423 if (fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks)
424 error(CONSISTENCY, "bad file descriptor in hdfreefrag");
425 #endif
426 f = &hdfragl[fd];
427 if (f->nfrags % FRAGBLK == 0) { /* delete empty remnants */
428 for (j = k = 0; k < f->nfrags; j++, k++) {
429 while (f->fi[k].nrd == 0)
430 if (++k >= f->nfrags)
431 goto endloop;
432 if (k > j)
433 copystruct(f->fi+j, f->fi+k);
434 }
435 endloop:
436 f->nfrags = j;
437 }
438 j = f->nfrags++; /* allocate a slot in free list */
439 #if MAXFRAG
440 if (j >= MAXFRAG-1)
441 f->nfrags--;
442 #endif
443 if (j % FRAGBLK == 0) { /* more free list space */
444 if (f->fi == NULL)
445 f->fi = (BEAMI *)malloc(FRAGBLK*sizeof(BEAMI));
446 else
447 f->fi = (BEAMI *)realloc((char *)f->fi,
448 (j+FRAGBLK)*sizeof(BEAMI));
449 if (f->fi == NULL)
450 error(SYSTEM, "out of memory in hdfreefrag");
451 }
452 for ( ; ; j--) { /* insert in descending list */
453 if (!j || bi->fo < f->fi[j-1].fo) {
454 f->fi[j].fo = bi->fo;
455 f->fi[j].nrd = bi->nrd;
456 break;
457 }
458 copystruct(f->fi+j, f->fi+(j-1));
459 }
460 /* coalesce adjacent fragments */
461 /* successors never empty */
462 if (j && f->fi[j-1].fo == f->fi[j].fo + f->fi[j].nrd*sizeof(RAYVAL)) {
463 f->fi[j].nrd += f->fi[j-1].nrd;
464 f->fi[j-1].nrd = 0;
465 }
466 for (k = j+1; k < f->nfrags; k++) /* get non-empty predecessor */
467 if (f->fi[k].nrd) {
468 if (f->fi[j].fo == f->fi[k].fo +
469 f->fi[k].nrd*sizeof(RAYVAL)) {
470 f->fi[k].nrd += f->fi[j].nrd;
471 f->fi[j].nrd = 0;
472 }
473 break;
474 }
475 }
476
477
478 long
479 hdallocfrag(fd, nrays) /* allocate a file fragment */
480 int fd;
481 unsigned int4 nrays;
482 {
483 register struct fraglist *f;
484 register int j, k;
485 long nfo;
486
487 if (nrays == 0)
488 return(-1L);
489 #ifdef DEBUG
490 if (fd < 0 | fd >= nhdfragls || !hdfragl[fd].nlinks)
491 error(CONSISTENCY, "bad file descriptor in hdallocfrag");
492 #endif
493 f = &hdfragl[fd];
494 k = -1; /* find closest-sized fragment */
495 for (j = f->nfrags; j-- > 0; )
496 if (f->fi[j].nrd >= nrays &&
497 (k < 0 || f->fi[j].nrd < f->fi[k].nrd))
498 if (f->fi[k=j].nrd == nrays)
499 break;
500 if (k < 0) { /* no fragment -- extend file */
501 nfo = f->flen;
502 f->flen += nrays*sizeof(RAYVAL);
503 } else { /* else use fragment */
504 nfo = f->fi[k].fo;
505 f->fi[k].fo += nrays*sizeof(RAYVAL);
506 f->fi[k].nrd -= nrays;
507 }
508 return(nfo);
509 }
510
511
512 int
513 hdsyncbeam(hp, i) /* sync beam in memory with beam on disk */
514 register HOLO *hp;
515 register int i;
516 {
517 unsigned int4 nrays;
518 unsigned int n;
519 long nfo;
520 /* check file status */
521 if (hdfragl[hp->fd].writerr)
522 return(-1);
523 #ifdef DEBUG
524 if (i < 1 | i > nbeams(hp))
525 error(CONSISTENCY, "bad beam index in hdsyncbeam");
526 #endif
527 /* is current fragment OK? */
528 if (hp->bl[i] == NULL || (nrays = hp->bl[i]->nrm) == hp->bi[i].nrd)
529 return(0);
530 if (hp->bi[i].nrd) /* relinquish old fragment */
531 hdfreefrag(hp->fd, &hp->bi[i]);
532 if (nrays) { /* get and write new fragment */
533 nfo = hdallocfrag(hp->fd, nrays);
534 errno = 0;
535 if (lseek(hp->fd, nfo, 0) < 0)
536 error(SYSTEM, "cannot seek on holodeck file");
537 n = hp->bl[i]->nrm * sizeof(RAYVAL);
538 if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) {
539 hdfragl[hp->fd].writerr++;
540 hdsync(NULL, 0); /* sync directories */
541 error(SYSTEM, "write error in hdsyncbeam");
542 }
543 hp->bi[i].fo = nfo;
544 } else
545 hp->bi[i].fo = 0L;
546 biglob(hp)->nrd += nrays - hp->bi[i].nrd;
547 hp->bi[i].nrd = nrays;
548 markdirty(hp); /* section directory now out of date */
549 return(1);
550 }
551
552
553 int
554 hdfreebeam(hp, i) /* free beam, writing if dirty */
555 register HOLO *hp;
556 register int i;
557 {
558 int nchanged;
559
560 if (hp == NULL) { /* clear all holodecks */
561 nchanged = 0;
562 for (i = 0; hdlist[i] != NULL; i++)
563 nchanged += hdfreebeam(hdlist[i], 0);
564 return(nchanged);
565 }
566 if (hdfragl[hp->fd].writerr) /* check for file error */
567 return(0);
568 if (i == 0) { /* clear entire holodeck */
569 nchanged = 0;
570 for (i = nbeams(hp); i > 0; i--)
571 if (hp->bl[i] != NULL)
572 nchanged += hdfreebeam(hp, i);
573 return(nchanged);
574 }
575 #ifdef DEBUG
576 if (i < 1 | i > nbeams(hp))
577 error(CONSISTENCY, "bad beam index to hdfreebeam");
578 #endif
579 if (hp->bl[i] == NULL)
580 return(0);
581 /* check for additions */
582 nchanged = hp->bl[i]->nrm - hp->bi[i].nrd;
583 if (nchanged)
584 hdsyncbeam(hp, i); /* write new fragment */
585 blglob(hp)->nrm -= hp->bl[i]->nrm;
586 free((char *)hp->bl[i]); /* free memory */
587 hp->bl[i] = NULL;
588 return(nchanged);
589 }
590
591
592 int
593 hdkillbeam(hp, i) /* delete beam from holodeck */
594 register HOLO *hp;
595 register int i;
596 {
597 static BEAM emptybeam;
598 int nchanged;
599
600 if (hp == NULL) { /* clobber all holodecks */
601 nchanged = 0;
602 for (i = 0; hdlist[i] != NULL; i++)
603 nchanged += hdkillbeam(hdlist[i], 0);
604 return(nchanged);
605 }
606 if (i == 0) { /* clobber entire holodeck */
607 nchanged = 0;
608 for (i = nbeams(hp); i > 0; i--)
609 if (hp->bi[i].nrd > 0 || hp->bl[i] != NULL)
610 nchanged += hdkillbeam(hp, i);
611 #ifdef DEBUG
612 if (biglob(hp)->nrd != 0 | blglob(hp)->nrm != 0)
613 error(CONSISTENCY, "bad beam count in hdkillbeam");
614 #endif
615 return(nchanged);
616 }
617 #ifdef DEBUG
618 if (i < 1 | i > nbeams(hp))
619 error(CONSISTENCY, "bad beam index to hdkillbeam");
620 #endif
621 if (hp->bl[i] != NULL) { /* free memory */
622 blglob(hp)->nrm -= nchanged = hp->bl[i]->nrm;
623 free((char *)hp->bl[i]);
624 } else
625 nchanged = hp->bi[i].nrd;
626 if (hp->bi[i].nrd) { /* free file fragment */
627 hp->bl[i] = &emptybeam;
628 hdsyncbeam(hp, i);
629 }
630 hp->bl[i] = NULL;
631 return(nchanged);
632 }
633
634
635 int
636 hdlrulist(hb, nents, n, hp) /* add beams from holodeck to LRU list */
637 register HDBEAMI *hb; /* beam list */
638 int nents; /* current list length */
639 int n; /* maximum list length */
640 register HOLO *hp; /* section we're adding from */
641 {
642 register int i, j;
643 /* insert each beam from hp */
644 for (i = nbeams(hp); i > 0; i--) {
645 if (hp->bl[i] == NULL) /* check if loaded */
646 continue;
647 #if 0
648 if (hp->bl[i]->tick == hdclock) /* preempt swap? */
649 continue;
650 #endif
651 if ((j = ++nents) >= n) /* grow list if we can */
652 nents--;
653 for ( ; ; ) { /* bubble into place */
654 if (!--j || hp->bl[i]->tick >=
655 hb[j-1].h->bl[hb[j-1].b]->tick) {
656 hb[j].h = hp;
657 hb[j].b = i;
658 break;
659 }
660 copystruct(hb+j, hb+(j-1));
661 }
662 }
663 return(nents); /* return new list length */
664 }
665
666
667 int
668 hdfreecache(pct, honly) /* free up cache space, writing changes */
669 int pct; /* maximum percentage to free */
670 register HOLO *honly; /* NULL means check all */
671 {
672 HDBEAMI hb[FREEBEAMS];
673 int freetarget;
674 int n;
675 register int i;
676 /* compute free target */
677 freetarget = (honly != NULL) ? blglob(honly)->nrm :
678 hdmemuse(0)/sizeof(RAYVAL) ;
679 freetarget = freetarget*pct/100;
680 if (freetarget <= 0)
681 return(0);
682 /* find least recently used */
683 n = 0;
684 if (honly != NULL)
685 n = hdlrulist(hb, n, FREEBEAMS, honly);
686 else
687 for (i = 0; hdlist[i] != NULL; i++)
688 n = hdlrulist(hb, n, FREEBEAMS, hdlist[i]);
689 /* free LRU beams */
690 for (i = 0; i < n; i++) {
691 hdfreebeam(hb[i].h, hb[i].b);
692 if ((freetarget -= hb[i].h->bi[hb[i].b].nrd) <= 0)
693 break;
694 }
695 hdsync(honly, 0); /* synchronize directories as necessary */
696 return(-freetarget); /* return how far past goal we went */
697 }
698
699
700 hddone(hp) /* clean up holodeck section and free */
701 register HOLO *hp; /* NULL means clean up all */
702 {
703 register int i;
704
705 if (hp == NULL) { /* NULL means clean up everything */
706 while (hdlist[0] != NULL)
707 hddone(hdlist[0]);
708 return;
709 }
710 /* flush all data and free memory */
711 hdflush(hp);
712 /* release fragment resources */
713 hdrelease(hp->fd);
714 /* remove hp from active list */
715 for (i = 0; hdlist[i] != NULL; i++)
716 if (hdlist[i] == hp) {
717 while ((hdlist[i] = hdlist[i+1]) != NULL)
718 i++;
719 break;
720 }
721 free((char *)hp->bl); /* free beam list */
722 free((char *)hp); /* free holodeck struct */
723 }
